[petsc-users] Question about correctly catching fp_trap
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Thu Jan 3 18:15:21 CST 2019
I've compiled a program using petsc with debugging enabled.
Confirmation of the same : https://pastebin.com/aa0XDheD (check if the
loaded module is indeed petsc+debug, compile)
When I run it in a debugger, I get the error as shown below:
https://pastebin.com/GJtB2Ghz
What am I missing?
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/b3ca0971/attachment.html>
