[petsc-users] Error with petsc on OSX with libpng
Balay, Satish
balay at mcs.anl.gov
Wed Feb 27 19:32:46 CST 2019
On Wed, 27 Feb 2019, Amneet Pal Bhalla via petsc-users wrote:
> Ah, I see. I will try to make sure that my Xcode is working. Did you try to
> update XCode yet.
Hm - currently petsc is tested with:
balay at ipro^~ $ xcodebuild -version
Xcode 10.1
Build version 10B61
balay at ipro^~ $ clang --version
Apple LLVM version 10.0.0 (clang-1000.11.45.5)
Target: x86_64-apple-darwin18.2.0
Thread model: posix
InstalledDir: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
Your compiler appears to be a bit older.
Apple LLVM version 10.0.0 (clang-1000.10.44.4)
I don't see any such issues.. [Its likely I don't have command line tools installed - so don't get into this issue]
Satish
