[petsc-users] Error with petsc on OSX with libpng
Amneet Pal Bhalla
asbhalla at sdsu.edu
Wed Feb 27 19:14:47 CST 2019
Ah, I see. I will try to make sure that my Xcode is working. Did you try to
update XCode yet.
On Wed, Feb 27, 2019 at 5:12 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> Can you try the following and see if it makes a difference?
> ./configure --CC=mpicc --CXX=mpicxx --FC=mpif90 --PETSC_ARCH=sierra-dbg
> --with-debugging=1 --download-hypre=1 --with-x=0
> LIBS='-L/usr/local/Cellar/mpich/3.3/lib -lmpifort
> -L/usr/local/Cellar/gcc/8.3.0/lib/gcc/8 -lgfortran'
> For some reason your xcode compiler is giving these warnings during
> linktime - and I don't know why. These warnings are confusing petsc
> configure.
> ld: warning: text-based stub file
> /System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL.tbd and
> library file /System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL
> are out of sync. Falling back to library file for linking.
> Satish
> On Wed, 27 Feb 2019, Amneet Pal Bhalla via petsc-users wrote:
> [NON-Text Body part not included]
Amneet Bhalla
Assistant Professor, Department of Mechanical Engineering
San Diego State University
5500 Campanile Drive
San Diego, CA 92182 USA
Web: https://bhallagroup.wixsite.com/cfdlab
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190227/c8b1c3e2/attachment.html>
