[petsc-users] Fwd: PETSC installation issues
Balay, Satish balay at mcs.anl.gov
Wed Feb 27 12:04:00 CST 2019
stderr:
/usr/bin/ld: cannot find -lfblas
Looks like a broken/incomplete build - that configure thinks is successful.
Suggest doing a fresh build after 'rm -rf /home/ryan/projects/moose/petsc/linux-c-opt'
Also if using threads - might want to use --download-openblas [or MKL]
Satish
On Wed, 27 Feb 2019, Fande Kong wrote:
> Hi Satish,
> Do you have any idea why the configure failed?
> Thanks,
> Fande
> On Mon, Feb 25, 2019 at 2:57 PM <ryan.c.cooper at uconn.edu> wrote:
> > Greetings,
> > I am having trouble installing Petsc with the given configuration options
> > in the scripts/update_and_rebuild_petsc.sh. I have attached the
> > confiugure.log. I am running Arch linux - kernel 4.20.12, mpi: gcc 8.2.1,
> > mpif77/90: gnu fortran gcc 8.2.1.
> > The main problem is that I keep getting errors for superlu_dist and
> > scalapack that the downloaded file cannot be installed with the given
> > configuration. Are there some other flags I can specify to compile and link
> > the packages with Petsc?
> > You received this message because you are subscribed to the Google Groups
> > "moose-users" group.
> > To unsubscribe from this group and stop receiving emails from it, send an
> > email to moose-users+unsubscribe at googlegroups.com.
> > Visit this group at https://groups.google.com/group/moose-users.
> > To view this discussion on the web visit
> > https://groups.google.com/d/msgid/moose-users/09180386-e88b-4776-94cc-1f0cc00e00f6%40googlegroups.com
> > <https://groups.google.com/d/msgid/moose-users/09180386-e88b-4776-94cc-1f0cc00e00f6%40googlegroups.com?utm_medium=email&utm_source=footer>
> > For more options, visit https://groups.google.com/d/optout.
