[petsc-users] Fwd: PETSC installation issues
Fande Kong
fdkong.jd at gmail.com
Wed Feb 27 11:55:32 CST 2019
Hi Satish,
Do you have any idea why the configure failed?
Fande
On Mon, Feb 25, 2019 at 2:57 PM <ryan.c.cooper at uconn.edu> wrote:
> Greetings,
> I am having trouble installing Petsc with the given configuration options
> in the scripts/update_and_rebuild_petsc.sh. I have attached the
> confiugure.log. I am running Arch linux - kernel 4.20.12, mpi: gcc 8.2.1,
> mpif77/90: gnu fortran gcc 8.2.1.
> The main problem is that I keep getting errors for superlu_dist and
> scalapack that the downloaded file cannot be installed with the given
> configuration. Are there some other flags I can specify to compile and link
> the packages with Petsc?
> You received this message because you are subscribed to the Google Groups
> "moose-users" group.
> To unsubscribe from this group and stop receiving emails from it, send an
> email to moose-users+unsubscribe at googlegroups.com.
> Visit this group at https://groups.google.com/group/moose-users.
> To view this discussion on the web visit
> https://groups.google.com/d/msgid/moose-users/09180386-e88b-4776-94cc-1f0cc00e00f6%40googlegroups.com
> <https://groups.google.com/d/msgid/moose-users/09180386-e88b-4776-94cc-1f0cc00e00f6%40googlegroups.com?utm_medium=email&utm_source=footer>
> For more options, visit https://groups.google.com/d/optout.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190227/36b55705/attachment-0001.html>
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
Starting configure run at Sat, 23 Feb 2019 15:55:51 -0500
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --download-hypre=1 --with-ssl=0 --with-debugging=no --with-pic=1 --with-shared-libraries=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack=1 --download-metis=1 --download-parmetis=1 --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1 --CC=mpicc --CXX=mpicxx --FC=mpif90 --F77=mpif77 --F90=mpif90 --CFLAGS="-fPIC -fopenmp" --CXXFLAGS="-fPIC -fopenmp" --FFLAGS="-fPIC -fopenmp" --FCFLAGS="-fPIC -fopenmp" --F90FLAGS="-fPIC -fopenmp" --F77FLAGS="-fPIC -fopenmp" PETSC_DIR=/home/ryan/projects/moose/petsc
Working directory: /home/ryan/projects/moose/petsc
Machine platform:
('Linux', 'fermi', '4.20.10-arch1-1-ARCH', '#1 SMP PREEMPT Fri Feb 15 17:49:06 UTC 2019', 'x86_64', '')
Python version:
2.7.15 (default, Jan 10 2019, 23:20:52)
[GCC 8.2.1 20181127]
Pushing language C
Popping language C
Pushing language FC
Popping language FC
TEST configureExternalPackagesDir from config.framework(/home/ryan/projects/moose/petsc/config/BuildSystem/config/framework.py:836)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:836)
TEST configureDebuggers from config.utilities.debuggers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
Find a default debugger and determine its arguments
Checking for program /home/ryan/bin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/local/sbin/gdb...not found
Checking for program /usr/bin/gdb...found
Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /home/ryan/bin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/local/sbin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /usr/bin/site_perl/dbx...not found
Checking for program /usr/bin/vendor_perl/dbx...not found
Checking for program /usr/bin/core_perl/dbx...not found
Checking for program /home/ryan/.local/bin/dbx...not found
Checking for program /home/ryan/bin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/local/sbin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /usr/bin/site_perl/xdb...not found
Checking for program /usr/bin/vendor_perl/xdb...not found
Checking for program /usr/bin/core_perl/xdb...not found
Checking for program /home/ryan/.local/bin/xdb...not found
Executing: uname -s
stdout: Linux
Defined make macro "DSYMUTIL" to "true"
Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/home/ryan/projects/moose/petsc/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
Find the Git executable
Checking for program /home/ryan/bin/git...not found
Checking for program /usr/local/bin/git...not found
Checking for program /usr/local/sbin/git...not found
Checking for program /usr/bin/git...found
Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.20.1
TEST configureMercurial from config.sourceControl(/home/ryan/projects/moose/petsc/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
Find the Mercurial executable
Checking for program /home/ryan/bin/hg...not found
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/local/sbin/hg...not found
Checking for program /usr/bin/hg...found
Defined make macro "HG" to "hg"
Executing: hg version -q
stdout: Mercurial Distributed SCM (version 4.9)
TEST configureCLanguage from PETSc.options.languages(/home/ryan/projects/moose/petsc/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
Choose whether to compile the PETSc library using a C or C++ compiler
C language is C
Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/home/ryan/projects/moose/petsc/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
Checks PETSC_DIR and sets if not set
Version Information:
#define PETSC_VERSION_RELEASE 1
#define PETSC_VERSION_MAJOR 3
#define PETSC_VERSION_MINOR 10
#define PETSC_VERSION_SUBMINOR 2
#define PETSC_VERSION_PATCH 0
#define PETSC_VERSION_DATE "unknown"
#define PETSC_VERSION_GIT "unknown"
#define PETSC_VERSION_DATE_GIT "unknown"
#define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_ PETSC_VERSION_EQ
#define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
TEST getDatafilespath from PETSc.options.dataFilesPath(/home/ryan/projects/moose/petsc/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/home/ryan/projects/moose/petsc/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
lib/petsc/bin/maint exists. This appears to be a repository clone
.git directory exists
Executing: cd /home/ryan/projects/moose/petsc && git describe --match "v*"
stdout: v3.10.2-76-ge1487ad806
Executing: cd /home/ryan/projects/moose/petsc && git log -1 --pretty=format:%H
stdout: e1487ad8065c1157da7a4b7f82e219b7fa0de74f
Executing: cd /home/ryan/projects/moose/petsc && git log -1 --pretty=format:%ci
stdout: 2018-12-02 07:19:50 +0100
Executing: cd /home/ryan/projects/moose/petsc && git branch
stdout:
* (HEAD detached at e1487ad806)
master
Defined "VERSION_GIT" to ""v3.10.2-76-ge1487ad806""
Defined "VERSION_DATE_GIT" to ""2018-12-02 07:19:50 +0100""
Defined "VERSION_BRANCH_GIT" to ""(HEAD detached at e1487ad806)""
TEST configureArchitecture from PETSc.options.arch(/home/ryan/projects/moose/petsc/config/PETSc/options/arch.py:36)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:36)
Checks PETSC_ARCH and sets if not set
TEST setInstallDir from PETSc.options.installDir(/home/ryan/projects/moose/petsc/config/PETSc/options/installDir.py:36)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:36)
setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
Defined make macro "PREFIXDIR" to "/home/ryan/projects/moose/petsc/linux-c-opt"
TEST saveReconfigure from PETSc.options.installDir(/home/ryan/projects/moose/petsc/config/PETSc/options/installDir.py:80)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:80)
TEST cleanConfDir from PETSc.options.installDir(/home/ryan/projects/moose/petsc/config/PETSc/options/installDir.py:73)
TESTING: cleanConfDir from PETSc.options.installDir(config/PETSc/options/installDir.py:73)
TEST configureInstallDir from PETSc.options.installDir(/home/ryan/projects/moose/petsc/config/PETSc/options/installDir.py:57)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:57)
Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
Changed persistence directory to /home/ryan/projects/moose/petsc/linux-c-opt/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/home/ryan/projects/moose/petsc/config/PETSc/options/installDir.py:93)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:93)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/ryan/projects/moose/petsc/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/ryan/projects/moose/petsc/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1638)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1638)
**** printenv ****
CSF_SHMessage=/usr/share/opencascade/resources/SHMessage
DRAWHOME=/usr/share/opencascade/resources/DrawResources
XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/ryan
KDE_SESSION_VERSION=5
CSF_StandardLiteDefaults=/usr/share/opencascade/resources/StdResource
MMGT_CLEAR=1
MSC_LICENSE_FILE=27500 at engr-license3.engr.uconn.edu
XCURSOR_SIZE=0
CSF_OCCTResourcePath=/usr/share/opencascade/resources
PWD=/home/ryan/projects/moose/petsc
LOGNAME=ryan
USER=ryan
CSF_XCAFDefaults=/usr/share/opencascade/resources/StdResource
XDG_VTNR=7
CSF_XmlOcafResource=/usr/share/opencascade/resources/XmlOcafResource
DISPLAY=:0
KDE_FULL_SESSION=true
LANG=en_US.UTF-8
PROFILEHOME=
TERM=screen-256color
SHELL=/usr/bin/fish
COLORFGBG=15;0
XAUTHORITY=/home/ryan/.Xauthority
LANGUAGE=en_US
SESSION_MANAGER=local/fermi:@/tmp/.ICE-unix/750,unix/fermi:/tmp/.ICE-unix/750
SHLVL=3
XDG_SESSION_ID=2
XDG_SESSION_TYPE=x11
CSF_IGESDefaults=/usr/share/opencascade/resources/XSTEPResource
SHELL_SESSION_ID=c9813393d6f74f58ba6ea0cb0b929cc1
HG=/usr/bin/hg
KONSOLE_DBUS_WINDOW=/Windows/1
XDG_RUNTIME_DIR=/run/user/1000
PETSC_DIR=/opt/petsc/linux-c-opt
CASROOT=/usr
EDITOR=vim
CSF_PluginDefaults=/usr/share/opencascade/resources/StdResource
XCURSOR_THEME=breeze_cursors
KONSOLE_PROFILE_NAME=Profile 2
HOME=/home/ryan
KONSOLE_DBUS_SESSION=/Sessions/1
QT_AUTO_SCREEN_SCALE_FACTOR=0
PATH=/home/ryan/bin:/usr/local/bin:/home/ryan/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/ryan/.local/bin
XDG_SESSION_DESKTOP=plasma
KDE_SESSION_UID=1000
CSF_XSMessage=/usr/share/opencascade/resources/XSMessage
CSF_TObjDefaults=/usr/share/opencascade/resources/StdResource
CSF_STEPDefaults=/usr/share/opencascade/resources/XSTEPResource
KONSOLE_DBUS_SERVICE=:1.67
DESKTOP_SESSION=plasma
TMUX=/tmp//tmux-1000/default,1253,0
GDMSESSION=plasma
PETSC_ARCH=linux-c-opt
VISUAL=vim
CSF_MIGRATION_TYPES=/usr/share/opencascade/resources/StdResource/MigrationSheet.txt
CSF_LANGUAGE=us
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
CSF_TObjMessage=/usr/share/opencascade/resources/TObj
XDG_CURRENT_DESKTOP=KDE
GS_LIB=/home/ryan/.fonts
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
MOZ_PLUGIN_PATH=/usr/lib/mozilla/plugins
CSF_ShadersDirectory=/usr/share/opencascade/resources/Shaders
CSF_MDTVTexturesDirectory=/usr/share/opencascade/resources/Textures
WINDOWID=4194311
GTK_MODULES=canberra-gtk-module
CSF_EXCEPTION_PROMPT=1
DESKTOP_AUTOSTART_ID=
GDM_LANG=en_US.UTF-8
DRAWDEFAULT=/usr/share/opencascade/resources/DrawResources/DrawDefault
KONSOLE_VERSION=181202
CSF_DrawPluginDefaults=/usr/share/opencascade/resources/DrawResources
XDG_DATA_DIRS=/usr/share:/usr/share:/usr/local/share
CSF_StandardDefaults=/usr/share/opencascade/resources/StdResource
XDG_SESSION_CLASS=user
COLORTERM=truecolor
MAIL=/var/spool/mail/ryan
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
TMUX_PANE=%8
XDG_SEAT=seat0
TEST resetEnvCompilers from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1645)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1645)
TEST checkEnvCompilers from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1675)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1675)
TEST checkMPICompilerOverride from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1608)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1608)
Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1629)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1629)
OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:444)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:444)
Determine the compiler vendor
Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:454)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:454)
Initialize the compiler and linker flags
Pushing language C
Initialized CFLAGS to -fPIC -fopenmp
Initialized LDFLAGS to
Popping language C
Initialized CUDAFLAGS to
Initialized CXXFLAGS to -fPIC -fopenmp
Initialized CXX_CXXFLAGS to
Pushing language FC
Initialized FFLAGS to -fPIC -fopenmp
Popping language FC
Initialized CPPFLAGS to
Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
Initialized CXXCPPFLAGS to
Initialized CC_LINKER_FLAGS to []
Initialized CXX_LINKER_FLAGS to []
Initialized FC_LINKER_FLAGS to []
Initialized CUDAC_LINKER_FLAGS to []
Initialized sharedLibraryFlags to []
Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:587)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:587)
Locate a functional C compiler
Checking for program /home/ryan/bin/mpicc...not found
Checking for program /usr/local/bin/mpicc...not found
Checking for program /usr/local/sbin/mpicc...not found
Checking for program /usr/bin/mpicc...found
Defined make macro "CC" to "mpicc"
Pushing language C
All intermediate test results are stored in /tmp/petsc-VuReVk
All intermediate test results are stored in /tmp/petsc-VuReVk/config.setCompilers
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Testing executable /tmp/petsc-VuReVk/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.setCompilers/conftest
Popping language C
TEST checkCPreprocessor from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:620)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:620)
Locate a functional C preprocessor
Defined make macro "CPP" to "mpicc -E"
Pushing language C
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers /tmp/petsc-VuReVk/config.setCompilers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.setCompilers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.setCompilers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.setCompilers/conffix.h" 1
# 3 "/tmp/petsc-VuReVk/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/libc-header-start.h" 1 3 4
# 33 "/usr/include/bits/libc-header-start.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 34 "/usr/include/bits/libc-header-start.h" 2 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 328 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef int wchar_t;
# 32 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 40 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 41 "/usr/include/stdlib.h" 2 3 4
# 55 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/floatn.h" 1 3 4
# 119 "/usr/include/bits/floatn.h" 3 4
# 1 "/usr/include/bits/floatn-common.h" 1 3 4
# 24 "/usr/include/bits/floatn-common.h" 3 4
# 25 "/usr/include/bits/floatn-common.h" 2 3 4
# 120 "/usr/include/bits/floatn.h" 2 3 4
# 56 "/usr/include/stdlib.h" 2 3 4
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
__extension__ typedef struct
long long int quot;
long long int rem;
} lldiv_t;
# 97 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
char **__restrict __endptr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern float strtof (const char *__restrict __nptr,
char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
# 176 "/usr/include/stdlib.h" 3 4
extern long int strtol (const char *__restrict __nptr,
char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 385 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef __int8_t __int_least8_t;
typedef __uint8_t __uint_least8_t;
typedef __int16_t __int_least16_t;
typedef __uint16_t __uint_least16_t;
typedef __int32_t __int_least32_t;
typedef __uint32_t __uint_least32_t;
typedef __int64_t __int_least64_t;
typedef __uint64_t __uint_least64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
typedef long int __intmax_t;
typedef unsigned long int __uintmax_t;
# 140 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 141 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef int __sig_atomic_t;
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 59 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 97 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 1 "/usr/include/bits/types/clock_t.h" 1 3 4
typedef __clock_t clock_t;
# 127 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/clockid_t.h" 1 3 4
typedef __clockid_t clockid_t;
# 129 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/time_t.h" 1 3 4
typedef __time_t time_t;
# 130 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/timer_t.h" 1 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/sys/types.h" 2 3 4
# 144 "/usr/include/sys/types.h" 3 4
# 145 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 1 "/usr/include/bits/stdint-intn.h" 1 3 4
# 24 "/usr/include/bits/stdint-intn.h" 3 4
typedef __int8_t int8_t;
typedef __int16_t int16_t;
typedef __int32_t int32_t;
typedef __int64_t int64_t;
# 156 "/usr/include/sys/types.h" 2 3 4
# 177 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 193 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 33 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint16_t
__bswap_16 (__uint16_t __bsx)
return __builtin_bswap16 (__bsx);
static __inline __uint32_t
__bswap_32 (__uint32_t __bsx)
return __builtin_bswap32 (__bsx);
# 69 "/usr/include/bits/byteswap.h" 3 4
__extension__ static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/bits/uintn-identity.h" 1 3 4
# 32 "/usr/include/bits/uintn-identity.h" 3 4
__uint16_identity (__uint16_t __x)
return __x;
__uint32_identity (__uint32_t __x)
return __x;
__uint64_identity (__uint64_t __x)
return __x;
# 62 "/usr/include/endian.h" 2 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/sigset_t.h" 1 3 4
# 1 "/usr/include/bits/types/__sigset_t.h" 1 3 4
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
# 5 "/usr/include/bits/types/sigset_t.h" 2 3 4
typedef __sigset_t sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timeval.h" 1 3 4
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
# 38 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timespec.h" 1 3 4
# 9 "/usr/include/bits/types/struct_timespec.h" 3 4
struct timespec
__time_t tv_sec;
__syscall_slong_t tv_nsec;
# 40 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 59 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
# 91 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
fd_set *__restrict __writefds,
fd_set *__restrict __exceptfds,
struct timeval *__restrict __timeout);
# 113 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
const struct timespec *__restrict __timeout,
const __sigset_t *__restrict __sigmask);
# 126 "/usr/include/sys/select.h" 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 244 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/bits/pthreadtypes.h" 3 4
# 1 "/usr/include/bits/thread-shared-types.h" 1 3 4
# 77 "/usr/include/bits/thread-shared-types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes-arch.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 22 "/usr/include/bits/pthreadtypes-arch.h" 2 3 4
# 65 "/usr/include/bits/pthreadtypes-arch.h" 3 4
struct __pthread_rwlock_arch_t
unsigned int __readers;
unsigned int __writers;
unsigned int __wrphase_futex;
unsigned int __writers_futex;
unsigned int __pad3;
unsigned int __pad4;
int __cur_writer;
int __shared;
signed char __rwelision;
unsigned char __pad1[7];
unsigned long int __pad2;
unsigned int __flags;
# 99 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 78 "/usr/include/bits/thread-shared-types.h" 2 3 4
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
# 118 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_mutex_s
int __lock ;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
short __spins; short __elision;
__pthread_list_t __list;
# 145 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_cond_s
__extension__ union
__extension__ unsigned long long int __wseq;
struct
unsigned int __low;
unsigned int __high;
} __wseq32;
__extension__ union
__extension__ unsigned long long int __g1_start;
struct
unsigned int __low;
} __g1_start32;
unsigned int __g_refs[2] ;
unsigned int __g_size[2];
unsigned int __g1_orig_size;
unsigned int __wrefs;
unsigned int __g_signals[2];
# 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
typedef unsigned long int pthread_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
union pthread_attr_t
char __size[56];
long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef union
struct __pthread_mutex_s __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
struct __pthread_cond_s __data;
char __size[48];
__extension__ long long int __align;
} pthread_cond_t;
typedef union
struct __pthread_rwlock_arch_t __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
# 245 "/usr/include/sys/types.h" 2 3 4
# 395 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
size_t __statelen,
struct random_data *__restrict __buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
__extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
# 563 "/usr/include/stdlib.h" 3 4
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 567 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int at_quick_exit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void quick_exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 644 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 672 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 685 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 707 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 728 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 781 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 797 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 817 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
__attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 837 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
long long int __denom)
# 869 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign, char *__restrict __buf,
size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign,
char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 954 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
char *const *__restrict __tokens,
char **__restrict __valuep)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 1000 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1010 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 1011 "/usr/include/stdlib.h" 2 3 4
# 1020 "/usr/include/stdlib.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Popping language C
TEST checkCUDACompiler from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:661)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:661)
Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:701)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:701)
Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:814)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:814)
Locate a functional Cxx compiler
Checking for program /home/ryan/bin/mpicxx...not found
Checking for program /usr/local/bin/mpicxx...not found
Checking for program /usr/local/sbin/mpicxx...not found
Checking for program /usr/bin/mpicxx...found
Defined make macro "CXX" to "mpicxx"
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language CXX
Popping language CXX
Executing: mpicxx -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
TEST checkCxxPreprocessor from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:852)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:852)
Locate a functional Cxx preprocessor
Defined make macro "CXXCPP" to "mpicxx -E"
Executing: mpicxx -E -I/tmp/petsc-VuReVk/config.setCompilers /tmp/petsc-VuReVk/config.setCompilers/conftest.cc
stdout:
# 1 "/tmp/petsc-VuReVk/config.setCompilers/conftest.cc"
# 1 "<built-in>"
# 1 "<command-line>" 2
# 2 "/tmp/petsc-VuReVk/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/tmp/petsc-VuReVk/config.setCompilers/conftest.cc" 2
# 1 "/usr/include/c++/8.2.1/cstdlib" 1 3
# 39 "/usr/include/c++/8.2.1/cstdlib" 3
# 40 "/usr/include/c++/8.2.1/cstdlib" 3
# 1 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/c++config.h" 1 3
# 236 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/c++config.h" 3
namespace std
typedef long int ptrdiff_t;
typedef decltype(nullptr) nullptr_t;
# 258 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/c++config.h" 3
namespace std
inline namespace __cxx11 __attribute__((__abi_tag__ ("cxx11"))) { }
namespace __gnu_cxx
# 508 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/c++config.h" 3
# 1 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/os_defines.h" 1 3
# 39 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/os_defines.h" 3
# 40 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/os_defines.h" 2 3
# 509 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/c++config.h" 2 3
# 1 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/cpu_defines.h" 1 3
# 512 "/usr/include/c++/8.2.1/x86_64-pc-linux-gnu/bits/c++config.h" 2 3
# 42 "/usr/include/c++/8.2.1/cstdlib" 2 3
# 75 "/usr/include/c++/8.2.1/cstdlib" 3
extern "C" {
# 74 "/usr/include/bits/floatn.h" 3 4
typedef _Complex float __cfloat128 __attribute__ ((__mode__ (__TC__)));
# 86 "/usr/include/bits/floatn.h" 3 4
typedef __float128 _Float128;
# 214 "/usr/include/bits/floatn-common.h" 3 4
typedef float _Float32;
# 251 "/usr/include/bits/floatn-common.h" 3 4
typedef double _Float64;
# 268 "/usr/include/bits/floatn-common.h" 3 4
typedef double _Float32x;
# 285 "/usr/include/bits/floatn-common.h" 3 4
typedef long double _Float64x;
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
long long int quot;
long long int rem;
} lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) throw () ;
throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
throw () __attribute__ ((__nonnull__ (1)));
char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1)));
# 140 "/usr/include/stdlib.h" 3 4
extern _Float32 strtof32 (const char *__restrict __nptr,
extern _Float64 strtof64 (const char *__restrict __nptr,
extern _Float128 strtof128 (const char *__restrict __nptr,
extern _Float32x strtof32x (const char *__restrict __nptr,
extern _Float64x strtof64x (const char *__restrict __nptr,
__extension__
__extension__
__extension__
__extension__
extern int strfromd (char *__dest, size_t __size, const char *__format,
double __f)
throw () __attribute__ ((__nonnull__ (3)));
extern int strfromf (char *__dest, size_t __size, const char *__format,
float __f)
extern int strfroml (char *__dest, size_t __size, const char *__format,
long double __f)
# 232 "/usr/include/stdlib.h" 3 4
extern int strfromf32 (char *__dest, size_t __size, const char * __format,
_Float32 __f)
extern int strfromf64 (char *__dest, size_t __size, const char * __format,
_Float64 __f)
extern int strfromf128 (char *__dest, size_t __size, const char * __format,
_Float128 __f)
extern int strfromf32x (char *__dest, size_t __size, const char * __format,
_Float32x __f)
extern int strfromf64x (char *__dest, size_t __size, const char * __format,
_Float64x __f)
# 272 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/types/locale_t.h" 1 3 4
# 22 "/usr/include/bits/types/locale_t.h" 3 4
# 1 "/usr/include/bits/types/__locale_t.h" 1 3 4
# 28 "/usr/include/bits/types/__locale_t.h" 3 4
struct __locale_struct
struct __locale_data *__locales[13];
const unsigned short int *__ctype_b;
const int *__ctype_tolower;
const int *__ctype_toupper;
const char *__names[13];
typedef struct __locale_struct *__locale_t;
# 23 "/usr/include/bits/types/locale_t.h" 2 3 4
typedef __locale_t locale_t;
# 273 "/usr/include/stdlib.h" 2 3 4
extern long int strtol_l (const char *__restrict __nptr,
char **__restrict __endptr, int __base,
locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4)));
extern unsigned long int strtoul_l (const char *__restrict __nptr,
int __base, locale_t __loc)
__extension__
extern long long int strtoll_l (const char *__restrict __nptr,
locale_t __loc)
__extension__
extern unsigned long long int strtoull_l (const char *__restrict __nptr,
extern double strtod_l (const char *__restrict __nptr,
char **__restrict __endptr, locale_t __loc)
throw () __attribute__ ((__nonnull__ (1, 3)));
extern float strtof_l (const char *__restrict __nptr,
extern long double strtold_l (const char *__restrict __nptr,
locale_t __loc)
# 316 "/usr/include/stdlib.h" 3 4
extern _Float32 strtof32_l (const char *__restrict __nptr,
locale_t __loc)
extern _Float64 strtof64_l (const char *__restrict __nptr,
locale_t __loc)
extern _Float128 strtof128_l (const char *__restrict __nptr,
locale_t __loc)
extern _Float32x strtof32x_l (const char *__restrict __nptr,
locale_t __loc)
extern _Float64x strtof64x_l (const char *__restrict __nptr,
locale_t __loc)
extern char *l64a (long int __n) throw () ;
extern "C" {
typedef __ino64_t ino64_t;
typedef __off64_t off64_t;
typedef __useconds_t useconds_t;
return __x;
return __x;
return __x;
typedef struct
} __sigset_t;
struct timeval
__time_t tv_sec;
struct timespec
__time_t tv_sec;
# 49 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
extern "C" {
# 236 "/usr/include/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
extern long int random (void) throw ();
extern void srandom (unsigned int __seed) throw ();
size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
size_t __statelen,
throw () __attribute__ ((__nonnull__ (2, 4)));
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
extern int rand_r (unsigned int *__seed) throw ();
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) throw ();
extern long int mrand48 (void) throw ();
extern void srand48 (long int __seedval) throw ();
extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
struct drand48_data
double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
throw () __attribute__ ((__warn_unused_result__));
extern void *reallocarray (void *__ptr, size_t __nmemb, size_t __size)
extern void free (void *__ptr) throw ();
extern "C" {
extern void *alloca (size_t __size) throw ();
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
throw () __attribute__ ((__nonnull__ (1))) ;
throw () __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) throw () __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" int at_quick_exit (void (*__func) (void))
throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
# 607 "/usr/include/stdlib.h" 3 4
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
extern char *secure_getenv (const char *__name)
extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern int unsetenv (const char *__name) throw () __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) throw ();
extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1)));
# 695 "/usr/include/stdlib.h" 3 4
extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 717 "/usr/include/stdlib.h" 3 4
extern int mkstemps64 (char *__template, int __suffixlen)
extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 739 "/usr/include/stdlib.h" 3 4
extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 749 "/usr/include/stdlib.h" 3 4
extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 759 "/usr/include/stdlib.h" 3 4
extern int mkostemps (char *__template, int __suffixlen, int __flags)
# 771 "/usr/include/stdlib.h" 3 4
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
extern char *canonicalize_file_name (const char *__name)
char *__restrict __resolved) throw () ;
typedef __compar_fn_t comparison_fn_t;
typedef int (*__compar_d_fn_t) (const void *, const void *, void *);
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
__compar_d_fn_t __compar, void *__arg)
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
throw () __attribute__ ((__nonnull__ (3))) ;
size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
extern int mblen (const char *__s, size_t __n) throw ();
const char *__restrict __s, size_t __n) throw ();
extern int wctomb (char *__s, wchar_t __wchar) throw ();
throw ();
extern int rpmatch (const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
extern int posix_openpt (int __oflag) ;
extern int grantpt (int __fd) throw ();
extern int unlockpt (int __fd) throw ();
extern char *ptsname (int __fd) throw () ;
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
extern int getpt (void);
# 76 "/usr/include/c++/8.2.1/cstdlib" 2 3
# 1 "/usr/include/c++/8.2.1/bits/std_abs.h" 1 3
# 33 "/usr/include/c++/8.2.1/bits/std_abs.h" 3
# 34 "/usr/include/c++/8.2.1/bits/std_abs.h" 3
# 46 "/usr/include/c++/8.2.1/bits/std_abs.h" 3
extern "C++"
namespace std __attribute__ ((__visibility__ ("default")))
using ::abs;
inline long
abs(long __i) { return __builtin_labs(__i); }
inline long long
abs(long long __x) { return __builtin_llabs (__x); }
inline constexpr double
abs(double __x)
{ return __builtin_fabs(__x); }
inline constexpr float
abs(float __x)
{ return __builtin_fabsf(__x); }
inline constexpr long double
abs(long double __x)
{ return __builtin_fabsl(__x); }
inline constexpr __int128
abs(__int128 __x) { return __x >= 0 ? __x : -__x; }
# 100 "/usr/include/c++/8.2.1/bits/std_abs.h" 3
inline constexpr
__float128
abs(__float128 __x)
{ return __x < 0 ? -__x : __x; }
# 78 "/usr/include/c++/8.2.1/cstdlib" 2 3
# 121 "/usr/include/c++/8.2.1/cstdlib" 3
extern "C++"
using ::div_t;
using ::ldiv_t;
using ::abort;
using ::atexit;
using ::at_quick_exit;
using ::atof;
using ::atoi;
using ::atol;
using ::bsearch;
using ::calloc;
using ::div;
using ::exit;
using ::free;
using ::getenv;
using ::labs;
using ::ldiv;
using ::malloc;
using ::mblen;
using ::mbstowcs;
using ::mbtowc;
using ::qsort;
using ::quick_exit;
using ::rand;
using ::realloc;
using ::srand;
using ::strtod;
using ::strtol;
using ::strtoul;
using ::system;
using ::wcstombs;
using ::wctomb;
inline ldiv_t
div(long __i, long __j) { return ldiv(__i, __j); }
# 195 "/usr/include/c++/8.2.1/cstdlib" 3
namespace __gnu_cxx __attribute__ ((__visibility__ ("default")))
using ::lldiv_t;
using ::_Exit;
using ::llabs;
inline lldiv_t
div(long long __n, long long __d)
{ lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
using ::lldiv;
# 227 "/usr/include/c++/8.2.1/cstdlib" 3
using ::atoll;
using ::strtoll;
using ::strtoull;
using ::strtof;
using ::strtold;
namespace std
using ::__gnu_cxx::lldiv_t;
using ::__gnu_cxx::_Exit;
using ::__gnu_cxx::llabs;
using ::__gnu_cxx::div;
using ::__gnu_cxx::lldiv;
using ::__gnu_cxx::atoll;
using ::__gnu_cxx::strtof;
using ::__gnu_cxx::strtoll;
using ::__gnu_cxx::strtoull;
using ::__gnu_cxx::strtold;
TEST checkFortranCompiler from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:970)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:970)
Locate a functional Fortran compiler
Checking for program /home/ryan/bin/mpif90...not found
Checking for program /usr/local/bin/mpif90...not found
Checking for program /usr/local/sbin/mpif90...not found
Checking for program /usr/bin/mpif90...found
Defined make macro "FC" to "mpif90"
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Popping language FC
TEST checkFortranComments from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:991)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:991)
Make sure fortran comment "!" works
Pushing language FC
Successful compile:
Source:
program main
! comment
end
Fortran comments can use ! in column 1
Popping language FC
TEST checkLargeFileIO from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1109)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1109)
TEST checkArchiver from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1208)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1208)
Check that the archiver exists and can make a library usable by the compiler
Pushing language C
Executing: ar -V
stdout:
GNU ar (GNU Binutils) 2.31.1
Copyright (C) 2018 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
return a+1;
Checking for program /home/ryan/bin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/local/sbin/ar...not found
Checking for program /usr/bin/ar...found
Defined make macro "AR" to "/usr/bin/ar"
Checking for program /home/ryan/bin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/local/sbin/ranlib...not found
Checking for program /usr/bin/ranlib...found
Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-VuReVk/config.setCompilers/libconf1.a /tmp/petsc-VuReVk/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-VuReVk/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- 'c'
Ranlib is not functional with your archiver. Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
return a+1;
Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-VuReVk/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
int b = foo(1); if (b);
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -L/tmp/petsc-VuReVk/config.setCompilers -lconf1
Defined make macro "AR_FLAGS" to "cr"
Defined make macro "AR_LIB_SUFFIX" to "a"
Popping language C
TEST checkSharedLinker from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1322)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1322)
Check that the linker can produce shared libraries
Executing: uname -s
stdout: Linux
Checking shared linker mpicc using flags ['-shared']
Defined make macro "LD_SHARED" to "mpicc"
Trying C compiler flag
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -shared -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
void foo(void){
fprintf_ptr(stdout,"hello");
return;
void bar(void){foo();}
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/libconftest.so -shared -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if (ret) {}
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -L/tmp/petsc-VuReVk/config.setCompilers -lconftest
Using shared linker mpicc with flags ['-shared'] and library extension so
Executing: uname -s
stdout: Linux
TEST checkPIC from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1068)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1068)
Determine the PIC option for each compiler
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
#include <stdio.h>
void foo(void){
return;
Pushing language C
Popping language C
Accepted C compiler flag
Popping language C
Trying Cxx compiler flag
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag
Successful compile:
Source:
#include <stdio.h>
void foo(void){
return;
Pushing language C
Pushing language C
Popping language C
Popping language C
Accepted Cxx compiler flag
Pushing language FC
Trying FC compiler flag
Successful compile:
Source:
program main
end
Added FC compiler flag
Successful compile:
Source:
function foo(a)
real:: a,x,bar
common /xx/ x
x=a
foo = bar(x)
end
Pushing language C
Pushing language C
Popping language C
Popping language C
Accepted FC compiler flag
Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1416)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1416)
Determine the shared linker path options
- IRIX: -rpath
- Linux, OSF: -Wl,-rpath,
- Solaris: -R
- FreeBSD: -Wl,-R,
Pushing language C
Executing: uname -s
stdout: Linux
Executing: mpicc -V
Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -Wl,-rpath,/home/ryan/projects/moose/petsc -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Valid C linker flag -Wl,-rpath,/home/ryan/projects/moose/petsc
Popping language C
Executing: uname -s
stdout: Linux
Executing: mpicc -V
Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-VuReVk/config.setCompilers/conftest -Wl,-rpath,/home/ryan/projects/moose/petsc -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Valid Cxx linker flag -Wl,-rpath,/home/ryan/projects/moose/petsc
Pushing language FC
Executing: uname -s
stdout: Linux
Executing: mpicc -V
Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.setCompilers/conftest -Wl,-rpath,/home/ryan/projects/moose/petsc -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o
Valid FC linker flag -Wl,-rpath,/home/ryan/projects/moose/petsc
Popping language FC
TEST checkLibC from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1451)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1451)
Test whether we need to explicitly include libc in shared linking
- Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
Pushing language C
Popping language C
Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1500)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1500)
Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
All intermediate test results are stored in /tmp/petsc-VuReVk/config.headers
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 22 "/usr/include/dlfcn.h" 3 4
# 23 "/usr/include/dlfcn.h" 2 3 4
# 25 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/bits/dlfcn.h" 1 3 4
# 28 "/usr/include/dlfcn.h" 2 3 4
# 52 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (const char *__file, int __mode) __attribute__ ((__nothrow__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 82 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 188 "/usr/include/dlfcn.h" 3 4
Defined "HAVE_DLFCN_H" to "1"
Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
Pushing language C
All intermediate test results are stored in /tmp/petsc-VuReVk/config.libraries
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.libraries/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp /tmp/petsc-VuReVk/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.libraries/conftest.o -ldl
Defined "HAVE_LIBDL" to "1"
Popping language C
Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
Checking dynamic linker mpicc using flags ['-shared']
Defined make macro "DYNAMICLINKER" to "mpicc"
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -shared -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/libconftest.so -shared -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -ldl
Possible ERROR while running compiler:
stderr:
/tmp/petsc-VuReVk/config.setCompilers/conftest.c: In function ���main���:
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:11:3: warning: implicit declaration of function ���printf��� [-Wimplicit-function-declaration]
printf("Could not load symbol\n");
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:11:3: warning: incompatible implicit declaration of built-in function ���printf���
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:11:3: note: include ���<stdio.h>��� or provide a declaration of ���printf���
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:4:1:
+#include <stdio.h>
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:15:3: warning: incompatible implicit declaration of built-in function ���printf���
printf("Invalid return from foo()\n");
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:15:3: note: include ���<stdio.h>��� or provide a declaration of ���printf���
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:19:3: warning: incompatible implicit declaration of built-in function ���printf���
printf("Could not close library\n");
/tmp/petsc-VuReVk/config.setCompilers/conftest.c:19:3: note: include ���<stdio.h>��� or provide a declaration of ���printf���
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/tmp/petsc-VuReVk/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
return -1;
if ((*foo)()) {
return -1;
if (dlclose(handle)) {
return -1;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp /tmp/petsc-VuReVk/config.setCompilers/conftest.o -ldl
Using dynamic linker mpicc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/setCompilers.py:1552)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1552)
Output module data as defines and substitutions
Substituting "CC" with "mpicc"
Substituting "CFLAGS" with "-fPIC -fopenmp "
Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "CPP" with "mpicc -E"
Substituting "CPPFLAGS" with ""
Substituting "CXX" with "mpicxx"
Substituting "CXX_CXXFLAGS" with " "
Substituting "CXXFLAGS" with "-fPIC -fopenmp"
Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
Substituting "CXXCPP" with "mpicxx -E"
Substituting "CXXCPPFLAGS" with ""
Substituting "FC" with "mpif90"
Substituting "FFLAGS" with "-fPIC -fopenmp "
Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "LDFLAGS" with ""
Substituting "LIBS" with "-ldl "
Substituting "SHARED_LIBRARY_FLAG" with "-shared"
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/home/ryan/projects/moose/petsc/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/home/ryan/projects/moose/petsc/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
Checks whether shared libraries should be used, for which you must
- Specify --with-shared-libraries
- Have found a working shared linker
Defines PETSC_USE_SHARED_LIBRARIES if they are used
Executing: uname -s
stdout: Linux
Defined make rule "shared_arch" with dependencies "shared_linux" and code []
Defined make macro "SONAME_FUNCTION" to "$(1).so.$(2)"
Defined make macro "SL_LINKER_FUNCTION" to "-shared -Wl,-soname,$(call SONAME_FUNCTION,$(notdir $(1)),$(2))"
Defined make macro "BUILDSHAREDLIB" to "yes"
Defined "HAVE_SHARED_LIBRARIES" to "1"
Defined "USE_SHARED_LIBRARIES" to "1"
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/home/ryan/projects/moose/petsc/config/PETSc/options/sharedLibraries.py:97)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:97)
Checks whether dynamic loading is available (with dlfcn.h and libdl)
Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/home/ryan/projects/moose/petsc/config/PETSc/options/sharedLibraries.py:103)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:103)
Defines PETSC_SERIALIZE_FUNCTIONS if they are used
Requires shared libraries
TEST configureIndexSize from PETSc.options.indexTypes(/home/ryan/projects/moose/petsc/config/PETSc/options/indexTypes.py:31)
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST configureCompilerFlags from config.compilerFlags(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:72)
Get the default compiler flags
Ignoring default options which were overridden using --CFLAGS -fPIC -fopenmp
Defined make macro "MPICC_SHOW" to "gcc -pthread -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi"
Trying C compiler flag -g
Trying C compiler flag -O
Ignoring default options which were overridden using --CXXFLAGS -fPIC -fopenmp
Defined make macro "MPICXX_SHOW" to "g++ -pthread -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi_cxx -lmpi"
Trying Cxx compiler flag -g
Trying Cxx compiler flag -O
Ignoring default options which were overridden using --FFLAGS -fPIC -fopenmp
Defined make macro "MPIFC_SHOW" to "/usr/bin/gfortran -I/usr/include -pthread -I/usr/lib/openmpi -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi"
Trying FC compiler flag -g
Trying FC compiler flag -O
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -g
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -O
Popping language C
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g /tmp/petsc-VuReVk/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -g
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -O
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g /tmp/petsc-VuReVk/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -g
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Added FC compiler flag -O
Popping language FC
Executing: mpicc --version
stdout:
gcc (GCC) 8.2.1 20181127
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: mpicc gcc (GCC) 8.2.1 20181127
Executing: mpicc -show
stdout: gcc -pthread -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi
Executing: mpicc --help
stdout:
Usage: gcc [options] file...
Options:
-pass-exit-codes Exit with highest error code from a phase.
--help Display this information.
--target-help Display target specific command line options.
--help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...].
Display specific types of command line options.
(Use '-v --help' to display command line options of sub-processes).
--version Display compiler version information.
-dumpspecs Display all of the built in spec strings.
-dumpversion Display the version of the compiler.
-dumpmachine Display the compiler's target processor.
-print-search-dirs Display the directories in the compiler's search path.
-print-libgcc-file-name Display the name of the compiler's companion library.
-print-file-name=<lib> Display the full path to library <lib>.
-print-prog-name=<prog> Display the full path to compiler component <prog>.
-print-multiarch Display the target's normalized GNU triplet, used as
a component in the library path.
-print-multi-directory Display the root directory for versions of libgcc.
-print-multi-lib Display the mapping between command line options and
multiple library search directories.
-print-multi-os-directory Display the relative path to OS libraries.
-print-sysroot Display the target libraries directory.
-print-sysroot-headers-suffix Display the sysroot suffix used to find headers.
-Wa,<options> Pass comma-separated <options> on to the assembler.
-Wp,<options> Pass comma-separated <options> on to the preprocessor.
-Wl,<options> Pass comma-separated <options> on to the linker.
-Xassembler <arg> Pass <arg> on to the assembler.
-Xpreprocessor <arg> Pass <arg> on to the preprocessor.
-Xlinker <arg> Pass <arg> on to the linker.
-save-temps Do not delete intermediate files.
-save-temps=<arg> Do not delete intermediate files.
-no-canonical-prefixes Do not canonicalize paths when building relative
prefixes to other gcc components.
-pipe Use pipes rather than intermediate files.
-time Time the execution of each subprocess.
-specs=<file> Override built-in specs with the contents of <file>.
-std=<standard> Assume that the input sources are for <standard>.
--sysroot=<directory> Use <directory> as the root directory for headers
and libraries.
-B <directory> Add <directory> to the compiler's search paths.
-v Display the programs invoked by the compiler.
-### Like -v but options quoted and commands not executed.
-E Preprocess only; do not compile, assemble or link.
-S Compile only; do not assemble or link.
-c Compile and assemble, but do not link.
-o <file> Place the output into <file>.
-pie Create a dynamically linked position independent
executable.
-shared Create a shared library.
-x <language> Specify the language of the following input files.
Permissible languages include: c c++ assembler none
'none' means revert to the default behavior of
guessing the language based on the file's extension.
Options starting with -g, -f, -m, -O, -W, or --param are automatically
passed on to the various sub-processes invoked by gcc. In order to pass
other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://bugs.archlinux.org/>.
stdout:
Options:
and libraries.
executable.
***** WARNING: Using default optimization C flags -g -O
You might consider manually setting optimal optimization flags for your system with
COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
Executing: mpicxx --version
stdout:
g++ (GCC) 8.2.1 20181127
getCompilerVersion: mpicxx g++ (GCC) 8.2.1 20181127
Executing: mpicxx -show
stdout: g++ -pthread -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi_cxx -lmpi
Executing: mpicxx --help
stdout:
Usage: g++ [options] file...
Options:
and libraries.
executable.
passed on to the various sub-processes invoked by g++. In order to pass
stdout:
Options:
and libraries.
executable.
***** WARNING: Using default C++ optimization flags -g -O
CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
Executing: mpif90 --version
stdout:
GNU Fortran (GCC) 8.2.1 20181127
getCompilerVersion: mpif90 GNU Fortran (GCC) 8.2.1 20181127
Executing: mpif90 -show
stdout: /usr/bin/gfortran -I/usr/include -pthread -I/usr/lib/openmpi -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi
Executing: mpif90 --help
stdout:
Usage: gfortran [options] file...
Options:
and libraries.
executable.
passed on to the various sub-processes invoked by gfortran. In order to pass
***** WARNING: Using default FORTRAN optimization flags -g -O
FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
stdout:
Options:
and libraries.
executable.
TEST checkRestrict from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:139)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:139)
Check for the C/CXX restrict keyword
Executing: mpicc -V
Pushing language C
All intermediate test results are stored in /tmp/petsc-VuReVk/config.compilers
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
float * __restrict x;;
return 0;
compilers: Set C restrict keyword to __restrict
Defined "C_RESTRICT" to "__restrict"
Popping language C
TEST checkCFormatting from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:391)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:391)
Activate format string checking if using the GNU compilers
TEST checkCInline from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:109)
TESTING: checkCInline from config.compilers(config/BuildSystem/config/compilers.py:109)
Check for C inline keyword
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.c
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
return 0;
compilers: Set C Inline keyword to inline
Popping language C
Defined "C_INLINE" to "inline"
TEST checkDynamicLoadFlag from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:402)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:402)
Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o -ldl
Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:203)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:203)
Determines the libraries needed to link with C compiled code
Pushing language C
Successful compile:
Source:
#include <stdio.h>
void asub(void)
{char s[16];printf("testing %s",s);}
Popping language C
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.F90
Successful compile:
Source:
program main
print*,'testing'
stop
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/confc.o -ldl
Popping language FC
C libraries are not needed when using Fortran linker
Pushing language C
Successful compile:
Source:
#include <stdio.h>
void asub(void)
Popping language C
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.cc
Successful compile:
Source:
int main(int argc,char **args)
{return 0;}
Executing: mpicxx -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/confc.o -ldl
C libraries are not needed when using C++ linker
TEST checkDependencyGenerationFlag from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1589)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1589)
Check if -MMD works for dependency generation, and add it if it does
Trying C compiler flag -MMD -MP
Defined make macro "C_DEPFLAGS" to "-MMD -MP"
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O -MMD -MP /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Popping language C
Trying Cxx compiler flag -MMD -MP
Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O -MMD -MP /tmp/petsc-VuReVk/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Trying FC compiler flag -MMD -MP
Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O -MMD -MP /tmp/petsc-VuReVk/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Popping language FC
TEST checkC99Flag from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1635)
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1635)
Check for -std=c99 or equivalent flag
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
#include <float.h>
int main() {
float x[2],y;
y = FLT_ROUNDS;
// c++ comment
int j = 2;
for (int i=0; i<2; i++){
x[i] = i*j*y;
return 0;
Accepted C99 compile flag:
Defined "HAVE_C99" to "1"
Popping language C
stdout:
Options:
and libraries.
executable.
Executing: mpicc -V
Successful compile:
Source:
int main() {
return 0;
compilers: Set Cxx restrict keyword to __restrict
Defined "CXX_RESTRICT" to "__restrict"
TEST checkCxxNamespace from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:442)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:442)
Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
return 0;
compilers: C++ has namespaces
Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:415)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:415)
Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
return 0;
TEST checkCxxInline from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:124)
TESTING: checkCxxInline from config.compilers(config/BuildSystem/config/compilers.py:124)
Check for C++ inline keyword
Successful compile:
Source:
int main() {
foo(1);;
return 0;
compilers: Set Cxx Inline keyword to inline
Defined "CXX_INLINE" to "inline"
TEST checkCxxLibraries from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:500)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:500)
Determines the libraries needed to link with C++
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
{std::vector<int> v;
try { throw 20; } catch (int e) { std::cout << "An exception occurred"; }}
Pushing language C
Successful compile:
Source:
{return 0;}
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/confc.o -ldl
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/confc.o: in function `asub()':
/tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `__cxa_allocate_exception'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `typeinfo for int'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `__cxa_throw'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `__cxa_begin_catch'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `std::cout'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.cc:7: undefined reference to `__cxa_end_catch'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/confc.o: in function `__static_initialization_and_destruction_0':
/usr/include/c++/8.2.1/iostream:74: undefined reference to `std::ios_base::Init::Init()'
/usr/bin/ld: /usr/include/c++/8.2.1/iostream:74: undefined reference to `std::ios_base::Init::~Init()'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/confc.o:(.data.rel.local.DW.ref._ZTIi[DW.ref._ZTIi]+0x0): undefined reference to `typeinfo for int'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/confc.o:(.data.rel.local.DW.ref.__gxx_personality_v0[DW.ref.__gxx_personality_v0]+0x0): undefined reference to `__gxx_personality_v0'
collect2: error: ld returned 1 exit status
Popping language C
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Pushing language C
Successful compile:
Source:
{return 0;}
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/confc.o -lstdc++ -ldl
Popping language C
compilers: C++ requires -lstdc++ to link with C compiler
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Pushing language FC
Successful compile:
Source:
program main
print*,'testing'
stop
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/confc.o -lstdc++ -ldl
Popping language FC
C++ libraries are not needed when using FC linker
TEST checkCxx11 from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:457)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:457)
Determine the option needed to support the C++11 dialect
We auto-detect C++11 if the compiler supports it without options,
otherwise we require with-cxx-dialect=C++11 to try adding flags to
support it.
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.cc
Successful compile:
Source:
#include <random>
template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
std::random_device rd;
std::mt19937 mt(rd());
std::normal_distribution<double> dist(0,1);
const double x = dist(mt);
return 0;
TEST checkFortranTypeSizes from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:713)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:713)
Check whether real*8 is supported and suggest flags which will allow support
Pushing language FC
Successful compile:
Source:
program main
real*8 variable
end
Popping language FC
TEST checkFortranNameMangling from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:773)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:773)
Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
Pushing language C
Successful compile:
Source:
Popping language C
Pushing language FC
Successful compile:
Source:
program main
call d1chk()
end
Pushing language FC
Popping language FC
Popping language FC
compilers: Fortran name mangling is underscore
Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
Pushing language FC
Popping language FC
stdout:
Defined "FORTRAN_CHARLEN_T" to "size_t"
TEST checkFortranNameManglingDouble from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:814)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:814)
Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
Popping language C
Pushing language FC
Successful compile:
Source:
program main
call d1_chk()
end
Pushing language FC
Popping language FC
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.o: in function `MAIN__':
/tmp/petsc-VuReVk/config.compilers/conftest.F90:2: undefined reference to `d1_chk_'
Popping language FC
TEST checkFortranPreprocessor from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:824)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:824)
Determine if Fortran handles preprocessing properly
compilers: Fortran uses CPP preprocessor
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef dummy
fooey
#endif
end
Popping language FC
TEST checkFortranDefineCompilerOption from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:848)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:848)
Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
Defined make macro "FC_DEFINE_FLAG" to "-D"
compilers: Fortran uses -D for defining macro
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.setCompilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fPIC -fopenmp -g -O -DTesting /tmp/petsc-VuReVk/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef Testing
fooey
#endif
end
Popping language FC
TEST checkFortranLibraries from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:868)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:868)
Substitutes for FLIBS the libraries needed to link with Fortran
This macro is intended to be used in those situations when it is
necessary to mix, e.g. C++ and Fortran 77, source code into a single
program or shared library.
For example, if object files from a C++ and Fortran 77 compiler must
be linked together, then the C++ compiler/linker must be used for
linking (since special C++-ish things need to happen at link time
like calling global constructors, instantiating templates, enabling
exception support, etc.).
However, the Fortran 77 intrinsic and run-time libraries must be
linked in as well, but the C++ compiler/linker does not know how to
add these Fortran 77 libraries.
This code was translated from the autoconf macro which was packaged in
its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
However, nearly all of this macro came from the OCTAVE_FLIBS macro in
octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
for writing this extremely useful macro.
Pushing language FC
Successful compile:
Source:
program main
#include <mpif.h>
call MPI_Allreduce()
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o -lstdc++ -ldl
Popping language FC
Pushing language FC
Successful compile:
Source:
subroutine asub()
print*,'testing'
return
end
Popping language FC
Pushing language C
Successful compile:
Source:
{return 0;}
Pushing language C
Popping language C
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/confc.o: in function `asub_':
/tmp/petsc-VuReVk/config.compilers/conftest.F90:2: undefined reference to `_gfortran_st_write'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.F90:2: undefined reference to `_gfortran_transfer_character_write'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.F90:2: undefined reference to `_gfortran_st_write_done'
/usr/bin/ld: /tmp/petsc-VuReVk/config.compilers/conftest.F90:3: undefined reference to `mpi_allreduce_'
Popping language C
Fortran code cannot directly be linked with C linker, therefor will determine needed Fortran libraries
Pushing language FC
Successful compile:
Source:
subroutine asub()
print*,'testing'
return
end
Popping language FC
Successful compile:
Source:
{return 0;}
Executing: mpicxx -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/confc.o -lstdc++ -ldl
stderr:
Fortran code cannot directly be linked with C++ linker, therefor will determine needed Fortran libraries
Pushing language FC
Executing: mpif90 -V
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -v -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o -lstdc++ -ldl
stderr:
Driving: /usr/bin/gfortran -o /tmp/petsc-VuReVk/config.compilers/conftest -v -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o -lstdc++ -ldl -I/usr/include -pthread -I/usr/lib/openmpi -Wl,-rpath -Wl,/usr/lib/openmpi -Wl,--enable-new-dtags -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -l gfortran -l m -shared-libgcc
Using built-in specs.
COLLECT_GCC=/usr/bin/gfortran
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /build/gcc/src/gcc/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++ --enable-shared --enable-threads=posix --enable-libmpx --with-system-zlib --with-isl --enable-__cxa_atexit --disable-libunwind-exceptions --enable-clocale=gnu --disable-libstdcxx-pch --disable-libssp --enable-gnu-unique-object --enable-linker-build-id --enable-lto --enable-plugin --enable-install-libiberty --with-linker-hash-style=gnu --enable-gnu-indirect-function --enable-multilib --disable-werror --enable-checking=release --enable-default-pie --enable-default-ssp --enable-cet=auto
Thread model: posix
gcc version 8.2.1 20181127 (GCC)
Reading specs from /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-VuReVk/config.compilers/conftest' '-v' '-fPIC' '-fopenmp' '-g' '-O' '-I' '/usr/include' '-pthread' '-I' '/usr/lib/openmpi' '-L/usr/lib/openmpi' '-shared-libgcc' '-mtune=generic' '-march=x86-64' '-pthread'
COMPILER_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../:/lib/:/usr/lib/
Reading specs from /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/libgomp.spec
/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/collect2 -plugin /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccqf7wFt.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lquadmath -plugin-opt=-pass-through=-lm -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lpthread -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie -o /tmp/petsc-VuReVk/config.compilers/conftest /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/Scrt1.o /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/crti.o /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/crtbeginS.o -L/usr/lib/openmpi -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../.. /tmp/petsc-VuReVk/config.compilers/conftest.o -lstdc++ -ldl -rpath /usr/lib/openmpi --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgomp -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lpthread -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/crtendS.o /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/crtn.o
Popping language FC
compilers: Checking arg Driving:
compilers: Unknown arg Driving:
compilers: Checking arg /usr/bin/gfortran
compilers: Unknown arg /usr/bin/gfortran
compilers: Checking arg -o
compilers: Unknown arg -o
compilers: Checking arg /tmp/petsc-VuReVk/config.compilers/conftest
compilers: Unknown arg /tmp/petsc-VuReVk/config.compilers/conftest
compilers: Checking arg -v
compilers: Unknown arg -v
compilers: Checking arg -fPIC
compilers: Unknown arg -fPIC
compilers: Checking arg -fopenmp
compilers: Unknown arg -fopenmp
compilers: Checking arg -g
compilers: Unknown arg -g
compilers: Checking arg -O
compilers: Unknown arg -O
compilers: Checking arg /tmp/petsc-VuReVk/config.compilers/conftest.o
compilers: Unknown arg /tmp/petsc-VuReVk/config.compilers/conftest.o
compilers: Checking arg -lstdc++
compilers: Found library: -lstdc++
compilers: Checking arg -ldl
compilers: Found library: -ldl
compilers: Checking arg -I/usr/include
compilers: Found include directory: /usr/include
compilers: Checking arg -pthread
compilers: Unknown arg -pthread
compilers: Checking arg -I/usr/lib/openmpi
compilers: Found include directory: /usr/lib/openmpi
compilers: Checking arg -Wl,-rpath
compilers: Unknown arg -Wl,-rpath
compilers: Checking arg -Wl,/usr/lib/openmpi
compilers: Unknown arg -Wl,/usr/lib/openmpi
compilers: Checking arg -Wl,--enable-new-dtags
compilers: Unknown arg -Wl,--enable-new-dtags
compilers: Checking arg -L/usr/lib/openmpi
compilers: Found library directory: -L/usr/lib/openmpi
compilers: Checking arg -lmpi_usempif08
compilers: Found library: -lmpi_usempif08
compilers: Checking arg -lmpi_usempi_ignore_tkr
compilers: Found library: -lmpi_usempi_ignore_tkr
compilers: Checking arg -lmpi_mpifh
compilers: Found library: -lmpi_mpifh
compilers: Found canonical library: -lgfortran
compilers: Found canonical library: -lm
compilers: Checking arg -shared-libgcc
compilers: Unknown arg -shared-libgcc
compilers: Checking arg Using
compilers: Unknown arg Using
compilers: Checking arg built-in
compilers: Unknown arg built-in
compilers: Checking arg specs.
compilers: Unknown arg specs.
compilers: Checking arg COLLECT_GCC=/usr/bin/gfortran
compilers: Unknown arg COLLECT_GCC=/usr/bin/gfortran
compilers: Checking arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/lto-wrapper
compilers: Unknown arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/lto-wrapper
compilers: Checking arg Target:
compilers: Unknown arg Target:
compilers: Checking arg x86_64-pc-linux-gnu
compilers: Unknown arg x86_64-pc-linux-gnu
compilers: Checking arg Configured
compilers: Unknown arg Configured
compilers: Checking arg with:
compilers: Unknown arg with:
compilers: Checking arg /build/gcc/src/gcc/configure
compilers: Unknown arg /build/gcc/src/gcc/configure
compilers: Checking arg --prefix=/usr
compilers: Unknown arg --prefix=/usr
compilers: Checking arg --libdir=/usr/lib
compilers: Unknown arg --libdir=/usr/lib
compilers: Checking arg --libexecdir=/usr/lib
compilers: Unknown arg --libexecdir=/usr/lib
compilers: Checking arg --mandir=/usr/share/man
compilers: Unknown arg --mandir=/usr/share/man
compilers: Checking arg --infodir=/usr/share/info
compilers: Unknown arg --infodir=/usr/share/info
compilers: Checking arg --with-bugurl=https://bugs.archlinux.org/
compilers: Unknown arg --with-bugurl=https://bugs.archlinux.org/
compilers: Checking arg --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++
compilers: Unknown arg --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++
compilers: Checking arg --enable-shared
compilers: Unknown arg --enable-shared
compilers: Checking arg --enable-threads=posix
compilers: Unknown arg --enable-threads=posix
compilers: Checking arg --enable-libmpx
compilers: Unknown arg --enable-libmpx
compilers: Checking arg --with-system-zlib
compilers: Unknown arg --with-system-zlib
compilers: Checking arg --with-isl
compilers: Unknown arg --with-isl
compilers: Checking arg --enable-__cxa_atexit
compilers: Unknown arg --enable-__cxa_atexit
compilers: Checking arg --disable-libunwind-exceptions
compilers: Unknown arg --disable-libunwind-exceptions
compilers: Checking arg --enable-clocale=gnu
compilers: Unknown arg --enable-clocale=gnu
compilers: Checking arg --disable-libstdcxx-pch
compilers: Unknown arg --disable-libstdcxx-pch
compilers: Checking arg --disable-libssp
compilers: Unknown arg --disable-libssp
compilers: Checking arg --enable-gnu-unique-object
compilers: Unknown arg --enable-gnu-unique-object
compilers: Checking arg --enable-linker-build-id
compilers: Unknown arg --enable-linker-build-id
compilers: Checking arg --enable-lto
compilers: Unknown arg --enable-lto
compilers: Checking arg --enable-plugin
compilers: Unknown arg --enable-plugin
compilers: Checking arg --enable-install-libiberty
compilers: Unknown arg --enable-install-libiberty
compilers: Checking arg --with-linker-hash-style=gnu
compilers: Unknown arg --with-linker-hash-style=gnu
compilers: Checking arg --enable-gnu-indirect-function
compilers: Unknown arg --enable-gnu-indirect-function
compilers: Checking arg --enable-multilib
compilers: Unknown arg --enable-multilib
compilers: Checking arg --disable-werror
compilers: Unknown arg --disable-werror
compilers: Checking arg --enable-checking=release
compilers: Unknown arg --enable-checking=release
compilers: Checking arg --enable-default-pie
compilers: Unknown arg --enable-default-pie
compilers: Checking arg --enable-default-ssp
compilers: Unknown arg --enable-default-ssp
compilers: Checking arg --enable-cet=auto
compilers: Unknown arg --enable-cet=auto
compilers: Checking arg Thread
compilers: Unknown arg Thread
compilers: Checking arg model:
compilers: Unknown arg model:
compilers: Checking arg posix
compilers: Unknown arg posix
compilers: Checking arg gcc
compilers: Unknown arg gcc
compilers: Checking arg version
compilers: Unknown arg version
compilers: Checking arg 8.2.1
compilers: Unknown arg 8.2.1
compilers: Checking arg 20181127
compilers: Unknown arg 20181127
compilers: Checking arg (GCC)
compilers: Unknown arg (GCC)
compilers: Checking arg Reading
compilers: Unknown arg Reading
compilers: Checking arg from
compilers: Unknown arg from
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/libgfortran.spec
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/libgfortran.spec
compilers: Checking arg rename
compilers: Unknown arg rename
compilers: Checking arg lib
compilers: Unknown arg lib
compilers: Checking arg to
compilers: Unknown arg to
compilers: Checking arg liborig
compilers: Unknown arg liborig
compilers: Checking arg COLLECT_GCC_OPTIONS=
compilers: Unknown arg COLLECT_GCC_OPTIONS=
compilers: Checking arg COMPILER_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/
compilers: Skipping arg COMPILER_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/
compilers: Checking arg LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../:/lib/:/usr/lib/
compilers: Skipping arg LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../:/lib/:/usr/lib/
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/libgomp.spec
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/libgomp.spec
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/collect2
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/collect2
compilers: Checking arg -plugin
compilers: Unknown arg -plugin
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/liblto_plugin.so
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/liblto_plugin.so
compilers: Checking arg -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/lto-wrapper
compilers: Unknown arg -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/lto-wrapper
compilers: Checking arg -plugin-opt=-fresolution=/tmp/ccqf7wFt.res
compilers: Unknown arg -plugin-opt=-fresolution=/tmp/ccqf7wFt.res
compilers: Checking arg -plugin-opt=-pass-through=-lgcc_s
compilers: Unknown arg -plugin-opt=-pass-through=-lgcc_s
compilers: Checking arg -plugin-opt=-pass-through=-lquadmath
compilers: Unknown arg -plugin-opt=-pass-through=-lquadmath
compilers: Checking arg -plugin-opt=-pass-through=-lm
compilers: Unknown arg -plugin-opt=-pass-through=-lm
compilers: Checking arg -plugin-opt=-pass-through=-lpthread
compilers: Unknown arg -plugin-opt=-pass-through=-lpthread
compilers: Checking arg -plugin-opt=-pass-through=-lc
compilers: Unknown arg -plugin-opt=-pass-through=-lc
compilers: Checking arg --build-id
compilers: Unknown arg --build-id
compilers: Checking arg --eh-frame-hdr
compilers: Unknown arg --eh-frame-hdr
compilers: Checking arg --hash-style=gnu
compilers: Unknown arg --hash-style=gnu
compilers: Checking arg -m
compilers: Unknown arg -m
compilers: Checking arg elf_x86_64
compilers: Unknown arg elf_x86_64
compilers: Checking arg -dynamic-linker
compilers: Unknown arg -dynamic-linker
compilers: Checking arg /lib64/ld-linux-x86-64.so.2
compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
compilers: Checking arg -pie
compilers: Unknown arg -pie
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/Scrt1.o
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/Scrt1.o
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/crti.o
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/crti.o
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/crtbeginS.o
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/crtbeginS.o
compilers: Already in lflags so skipping: -L/usr/lib/openmpi
compilers: Checking arg -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1
compilers: Found library directory: -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1
compilers: Checking arg -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib
compilers: Checking arg -L/lib/../lib
compilers: Checking arg -L/usr/lib/../lib
compilers: Already in lflags: -lstdc++
compilers: Already in lflags: -ldl
compilers: Checking arg -rpath
compilers: Found -rpath library: /usr/lib/openmpi
compilers: Checking arg --enable-new-dtags
compilers: Unknown arg --enable-new-dtags
compilers: Already in lflags: -lmpi_usempif08
compilers: Already in lflags: -lmpi_usempi_ignore_tkr
compilers: Already in lflags: -lmpi_mpifh
compilers: Checking arg -lgfortran
compilers: Found library: -lgfortran
compilers: Checking arg -lgomp
compilers: Found library: -lgomp
compilers: Checking arg -lgcc_s
compilers: Found library: -lgcc_s
compilers: Found system library therefor skipping: -lgcc
compilers: Checking arg -lquadmath
compilers: Found library: -lquadmath
compilers: Already in lflags: -lgcc_s
compilers: Checking arg -lpthread
compilers: Found library: -lpthread
compilers: Checking arg -lc
compilers: Found system library therefor skipping: -lc
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/crtendS.o
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/crtendS.o
compilers: Checking arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/crtn.o
compilers: Unknown arg /usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/../../../../lib/crtn.o
compilers: Libraries needed to link Fortran code with the C linker: ['-lstdc++', '-ldl', '-Wl,-rpath,/usr/lib/openmpi', '-L/usr/lib/openmpi', '-lmpi_usempif08', '-lmpi_usempi_ignore_tkr', '-lmpi_mpifh', '-lmpi', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1', '-L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1', '-Wl,-rpath,/usr/lib/openmpi', '-lgfortran', '-lm', '-lgomp', '-lgcc_s', '-lquadmath', '-lpthread']
compilers: Libraries needed to link Fortran main with the C linker: []
compilers: Check that Fortran libraries can be used from C
Pushing language C
Popping language C
Pushing language C
Popping language C
Pushing language C
Popping language C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/usr/lib/openmpi -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -Wl,-rpath,/usr/lib/openmpi -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
Successful compile:
Source:
int main() {
return 0;
Executing: mpicc -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/usr/lib/openmpi -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -Wl,-rpath,/usr/lib/openmpi -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread -lstdc++ -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
int main() {
return 0;
Testing executable /tmp/petsc-VuReVk/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.setCompilers/conftest
Popping language C
compilers: Check that Fortran libraries can be used from C++
Pushing language CXX
Popping language CXX
compilers: Fortran libraries can be used from C++
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/usr/lib/openmpi -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -Wl,-rpath,/usr/lib/openmpi -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
Successful compile:
Source:
int main() {
return 0;
Executing: mpicxx -o /tmp/petsc-VuReVk/config.setCompilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.setCompilers/conftest.o -lstdc++ -ldl -Wl,-rpath,/usr/lib/openmpi -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -Wl,-rpath,/usr/lib/openmpi -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread -lstdc++ -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
TEST checkFortranLinkingCxx from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1263)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1263)
Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
Pushing language FC
Successful compile:
Source:
program main
call d1chk()
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/cxxobj.o /tmp/petsc-VuReVk/config.compilers/confc.o -lstdc++ -ldl
Popping language FC
compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1329)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1329)
Determine whether the Fortran compiler handles F90
Pushing language FC
Successful compile:
Source:
program main
INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
INTEGER (KIND=int) :: ierr
ierr = 1
end
Pushing language FC
Popping language FC
Defined "USING_F90" to "1"
Fortran compiler supports F90
Popping language FC
TEST checkFortran90FreeForm from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1342)
TESTING: checkFortran90FreeForm from config.compilers(config/BuildSystem/config/compilers.py:1342)
Determine whether the Fortran compiler handles F90FreeForm
We also require that the compiler handles lines longer than 132 characters
Pushing language FC
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-VuReVk/config.compilers/conftest.F90:2:132:
INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8); INTEGER (KIND=int) :: ierr; ierr = 1
1
Error: Line truncated at (1) [-Werror=line-truncation]
/tmp/petsc-VuReVk/config.compilers/conftest.F90:2:110:
1
Error: Unclassifiable statement at (1)
f951: some warnings being treated as errors
Source:
program main
end
Compile failed inside link
Fortran compiler does not support F90FreeForm
Popping language FC
TEST checkFortran2003 from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1356)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1356)
Determine whether the Fortran compiler handles F2003
Pushing language FC
Successful compile:
Source:
module Base_module
type, public :: base_type
integer :: A
contains
procedure, public :: Print => BasePrint
end type base_type
contains
subroutine BasePrint(this)
class(base_type) :: this
end subroutine BasePrint
end module Base_module
program main
use,intrinsic :: iso_c_binding
Type(C_Ptr),Dimension(:),Pointer :: CArray
character(kind=c_char),pointer :: nullc => null()
character(kind=c_char,len=5),dimension(:),pointer::list1
allocate(list1(5))
CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
end
Pushing language FC
Popping language FC
Defined "USING_F2003" to "1"
Fortran compiler supports F2003
Popping language FC
TEST checkFortran90Array from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1391)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1391)
Check for F90 array interfaces
Executing: uname -s
stdout: Linux
Pushing language C
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
printf("arrays [%p %p %p]\n",a1,a2,a3);
fflush(stdout);
return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
if ((p1 == p3) && (p1 != p2)) {
printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
fflush(stdout);
} else {
printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
fflush(stdout);
exit(111);
return;
Popping language C
Pushing language FC
Successful compile:
Source:
program main
Interface
Subroutine f90ptrtest(p1,p2,p3,i)
integer, pointer :: p1(:,:)
integer, pointer :: p2(:,:)
integer, pointer :: p3(:,:)
integer i
End Subroutine
End Interface
integer, pointer :: ptr1(:,:),ptr2(:,:)
integer, target :: array(6:8,9:21)
integer in
in = 25
ptr1 => array
ptr2 => array
call f90arraytest(ptr1,ptr2,ptr1,in)
call f90ptrtest(ptr1,ptr2,ptr1,in)
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/fooobj.o -lstdc++ -ldl
Testing executable /tmp/petsc-VuReVk/config.compilers/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.compilers/conftest
stdout:
arrays [0x7ffdfd5d4e00 0x7ffdfd5d4e00 0x7ffdfd5d4e00]
arrays [0x7ffdfd5d4d40 0x7ffdfd5d4da0 0x7ffdfd5d4d40]
pointers do not match! [0x7f89c02d8720 (nil)] [0x7f89bfcedf00]
ERROR while running executable: Could not execute "/tmp/petsc-VuReVk/config.compilers/conftest":
Popping language FC
compilers: F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1478)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1478)
Figures out what flag is used to specify the include path for Fortran modules
Pushing language FC
Successful compile:
Source:
module configtest
integer testint
parameter (testint = 42)
end module configtest
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers/confdir -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.F90
Successful compile:
Source:
program main
use configtest
write(*,*) testint
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.compilers/conftest -I/tmp/petsc-VuReVk/config.compilers/confdir -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.o /tmp/petsc-VuReVk/config.compilers/configtest.o -lstdc++ -ldl
compilers: Fortran module include flag -I found
Popping language FC
TEST checkFortranModuleOutput from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1544)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1544)
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -module /tmp/petsc-VuReVk/config.compilers/confdir -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-module���; did you mean ���-mhle���?
Source:
module configtest
integer testint
compilers: Fortran module output flag -module compile failed
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -module:/tmp/petsc-VuReVk/config.compilers/confdir -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-module:/tmp/petsc-VuReVk/config.compilers/confdir���
Source:
module configtest
integer testint
compilers: Fortran module output flag -module: compile failed
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -fmod=/tmp/petsc-VuReVk/config.compilers/confdir -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-fmod=/tmp/petsc-VuReVk/config.compilers/confdir���
Source:
module configtest
integer testint
compilers: Fortran module output flag -fmod= compile failed
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.compilers/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -J/tmp/petsc-VuReVk/config.compilers/confdir -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.compilers/conftest.F90
Successful compile:
Source:
module configtest
integer testint
compilers: Fortran module output flag -J found
Popping language FC
TEST checkFortranTypeStar from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1318)
TESTING: checkFortranTypeStar from config.compilers(config/BuildSystem/config/compilers.py:1318)
Determine whether the Fortran compiler handles type(*)
Pushing language FC
Successful compile:
Source:
program main
interface
subroutine a(b)
type(*) :: b(:)
end subroutine
end interface
end
Defined "HAVE_FORTRAN_TYPE_STAR" to "1"
Fortran compiler supports type(*)
Popping language FC
TEST checkFortranTypeInitialize from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1307)
TESTING: checkFortranTypeInitialize from config.compilers(config/BuildSystem/config/compilers.py:1307)
Determines if PETSc objects in Fortran are initialized by default (doesn't work with common blocks)
Defined "HAVE_FORTRAN_TYPE_INITIALIZE" to "-2"
Defined "FORTRAN_TYPE_INITIALIZE" to " = -2"
Initializing Fortran objects
TEST configureFortranFlush from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1298)
TESTING: configureFortranFlush from config.compilers(config/BuildSystem/config/compilers.py:1298)
Pushing language FC
Successful compile:
Source:
program main
call flush(6)
end
Pushing language FC
Popping language FC
Defined "HAVE_FORTRAN_FLUSH" to "1"
Popping language FC
TEST setupFrameworkCompilers from config.compilers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/compilers.py:1711)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1711)
TEST configureClosure from config.utilities.closure(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
Determine if Apple ^close syntax is supported in C
Pushing language C
All intermediate test results are stored in /tmp/petsc-VuReVk/config.utilities.closure
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.utilities.closure/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.utilities.closure -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.closure/conftest.c
stderr:
/tmp/petsc-VuReVk/config.utilities.closure/conftest.c: In function ���main���:
/tmp/petsc-VuReVk/config.utilities.closure/conftest.c:6:6: error: expected identifier or ���(��� before ���^��� token
int (^closure)(int);;
Source:
#include <stdio.h>
int main() {
return 0;
TEST configureFortranCPP from PETSc.options.fortranCPP(/home/ryan/projects/moose/petsc/config/PETSc/options/fortranCPP.py:21)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:21)
Handle case where Fortran cannot preprocess properly
Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST checkStdC from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.headers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
return 0;
Source:
#include <string.h>
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/usr/include/string.h" 1 3 4
# 26 "/usr/include/string.h" 3 4
# 1 "/usr/include/bits/libc-header-start.h" 1 3 4
# 33 "/usr/include/bits/libc-header-start.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 34 "/usr/include/bits/libc-header-start.h" 2 3 4
# 27 "/usr/include/string.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 34 "/usr/include/string.h" 2 3 4
# 42 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 90 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 121 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 1 "/usr/include/bits/types/locale_t.h" 1 3 4
# 22 "/usr/include/bits/types/locale_t.h" 3 4
# 1 "/usr/include/bits/types/__locale_t.h" 1 3 4
# 28 "/usr/include/bits/types/__locale_t.h" 3 4
struct __locale_struct
struct __locale_data *__locales[13];
const unsigned short int *__ctype_b;
const int *__ctype_tolower;
const int *__ctype_toupper;
const char *__names[13];
typedef struct __locale_struct *__locale_t;
# 23 "/usr/include/bits/types/locale_t.h" 2 3 4
typedef __locale_t locale_t;
# 153 "/usr/include/string.h" 2 3 4
extern int strcoll_l (const char *__s1, const char *__s2, locale_t __l)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 225 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 252 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 272 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 302 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 329 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
const char *__restrict __delim,
char **__restrict __save_ptr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 384 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 409 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 427 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/strings.h" 1 3 4
# 23 "/usr/include/strings.h" 3 4
# 24 "/usr/include/strings.h" 2 3 4
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 68 "/usr/include/strings.h" 3 4
extern char *index (const char *__s, int __c)
# 96 "/usr/include/strings.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int ffsl (long int __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__ extern int ffsll (long long int __ll)
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
extern int strcasecmp_l (const char *__s1, const char *__s2, locale_t __loc)
extern int strncasecmp_l (const char *__s1, const char *__s2,
size_t __n, locale_t __loc)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
# 432 "/usr/include/string.h" 2 3 4
extern void explicit_bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 498 "/usr/include/string.h" 3 4
Source:
#include <stdlib.h>
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 328 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef int wchar_t;
# 32 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 40 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 41 "/usr/include/stdlib.h" 2 3 4
# 55 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/floatn.h" 1 3 4
# 119 "/usr/include/bits/floatn.h" 3 4
# 1 "/usr/include/bits/floatn-common.h" 1 3 4
# 24 "/usr/include/bits/floatn-common.h" 3 4
# 25 "/usr/include/bits/floatn-common.h" 2 3 4
# 120 "/usr/include/bits/floatn.h" 2 3 4
# 56 "/usr/include/stdlib.h" 2 3 4
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
__extension__ typedef struct
long long int quot;
long long int rem;
} lldiv_t;
# 97 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
# 176 "/usr/include/stdlib.h" 3 4
extern long int strtol (const char *__restrict __nptr,
char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 385 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef __int8_t __int_least8_t;
typedef __uint8_t __uint_least8_t;
typedef __int16_t __int_least16_t;
typedef __uint16_t __uint_least16_t;
typedef __int32_t __int_least32_t;
typedef __uint32_t __uint_least32_t;
typedef __int64_t __int_least64_t;
typedef __uint64_t __uint_least64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
typedef long int __intmax_t;
typedef unsigned long int __uintmax_t;
# 140 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 141 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef int __sig_atomic_t;
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 59 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 97 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 1 "/usr/include/bits/types/clock_t.h" 1 3 4
typedef __clock_t clock_t;
# 127 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/clockid_t.h" 1 3 4
typedef __clockid_t clockid_t;
# 129 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/time_t.h" 1 3 4
typedef __time_t time_t;
# 130 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/timer_t.h" 1 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/sys/types.h" 2 3 4
# 144 "/usr/include/sys/types.h" 3 4
# 145 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 1 "/usr/include/bits/stdint-intn.h" 1 3 4
# 24 "/usr/include/bits/stdint-intn.h" 3 4
typedef __int8_t int8_t;
typedef __int16_t int16_t;
typedef __int32_t int32_t;
typedef __int64_t int64_t;
# 156 "/usr/include/sys/types.h" 2 3 4
# 177 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 193 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 33 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint16_t
__bswap_16 (__uint16_t __bsx)
return __builtin_bswap16 (__bsx);
static __inline __uint32_t
__bswap_32 (__uint32_t __bsx)
return __builtin_bswap32 (__bsx);
# 69 "/usr/include/bits/byteswap.h" 3 4
__extension__ static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/bits/uintn-identity.h" 1 3 4
# 32 "/usr/include/bits/uintn-identity.h" 3 4
__uint16_identity (__uint16_t __x)
return __x;
__uint32_identity (__uint32_t __x)
return __x;
__uint64_identity (__uint64_t __x)
return __x;
# 62 "/usr/include/endian.h" 2 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/sigset_t.h" 1 3 4
# 1 "/usr/include/bits/types/__sigset_t.h" 1 3 4
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
# 5 "/usr/include/bits/types/sigset_t.h" 2 3 4
typedef __sigset_t sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timeval.h" 1 3 4
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
# 38 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timespec.h" 1 3 4
# 9 "/usr/include/bits/types/struct_timespec.h" 3 4
struct timespec
__time_t tv_sec;
__syscall_slong_t tv_nsec;
# 40 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 59 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
# 91 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
fd_set *__restrict __writefds,
fd_set *__restrict __exceptfds,
struct timeval *__restrict __timeout);
# 113 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
const struct timespec *__restrict __timeout,
const __sigset_t *__restrict __sigmask);
# 126 "/usr/include/sys/select.h" 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 244 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/bits/pthreadtypes.h" 3 4
# 1 "/usr/include/bits/thread-shared-types.h" 1 3 4
# 77 "/usr/include/bits/thread-shared-types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes-arch.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 22 "/usr/include/bits/pthreadtypes-arch.h" 2 3 4
# 65 "/usr/include/bits/pthreadtypes-arch.h" 3 4
struct __pthread_rwlock_arch_t
unsigned int __readers;
unsigned int __writers;
unsigned int __wrphase_futex;
unsigned int __writers_futex;
unsigned int __pad3;
unsigned int __pad4;
int __cur_writer;
int __shared;
signed char __rwelision;
unsigned char __pad1[7];
unsigned long int __pad2;
unsigned int __flags;
# 99 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 78 "/usr/include/bits/thread-shared-types.h" 2 3 4
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
# 118 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_mutex_s
int __lock ;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
short __spins; short __elision;
__pthread_list_t __list;
# 145 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_cond_s
__extension__ union
__extension__ unsigned long long int __wseq;
struct
unsigned int __low;
unsigned int __high;
} __wseq32;
__extension__ union
__extension__ unsigned long long int __g1_start;
struct
unsigned int __low;
} __g1_start32;
unsigned int __g_refs[2] ;
unsigned int __g_size[2];
unsigned int __g1_orig_size;
unsigned int __wrefs;
unsigned int __g_signals[2];
# 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
typedef unsigned long int pthread_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
union pthread_attr_t
char __size[56];
long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef union
struct __pthread_mutex_s __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
struct __pthread_cond_s __data;
char __size[48];
__extension__ long long int __align;
} pthread_cond_t;
typedef union
struct __pthread_rwlock_arch_t __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
# 245 "/usr/include/sys/types.h" 2 3 4
# 395 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
size_t __statelen,
struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
__extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
# 563 "/usr/include/stdlib.h" 3 4
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 567 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int at_quick_exit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void quick_exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 644 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 672 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 685 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 707 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 728 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 781 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 797 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 817 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
__attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 837 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
long long int __denom)
# 869 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign, char *__restrict __buf,
size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign,
char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 954 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
char *const *__restrict __tokens,
char **__restrict __valuep)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 1000 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1010 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 1011 "/usr/include/stdlib.h" 2 3 4
# 1020 "/usr/include/stdlib.h" 3 4
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
int i;
for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
exit(0);
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.headers/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.headers/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-VuReVk/config.headers/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.headers/conftest
Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
You lose.
# endif
#endif
stdout:
# 1 "<built-in>"
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/bits/types.h" 3 4
return __x;
return __x;
return __x;
typedef struct
} __sigset_t;
struct timeval
__time_t tv_sec;
struct timespec
__time_t tv_sec;
typedef struct
} fd_set;
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
# 5 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/usr/include/sys/stat.h" 1 3 4
# 99 "/usr/include/sys/stat.h" 3 4
# 1 "/usr/include/bits/stat.h" 1 3 4
# 46 "/usr/include/bits/stat.h" 3 4
struct stat
__dev_t st_dev;
__ino_t st_ino;
__nlink_t st_nlink;
__mode_t st_mode;
__uid_t st_uid;
__gid_t st_gid;
int __pad0;
__dev_t st_rdev;
__off_t st_size;
__blksize_t st_blksize;
__blkcnt_t st_blocks;
# 91 "/usr/include/bits/stat.h" 3 4
struct timespec st_atim;
struct timespec st_mtim;
struct timespec st_ctim;
# 106 "/usr/include/bits/stat.h" 3 4
__syscall_slong_t __glibc_reserved[3];
# 115 "/usr/include/bits/stat.h" 3 4
# 102 "/usr/include/sys/stat.h" 2 3 4
# 205 "/usr/include/sys/stat.h" 3 4
extern int stat (const char *__restrict __file,
struct stat *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fstat (int __fd, struct stat *__buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 234 "/usr/include/sys/stat.h" 3 4
extern int fstatat (int __fd, const char *__restrict __file,
struct stat *__restrict __buf, int __flag)
# 259 "/usr/include/sys/stat.h" 3 4
extern int lstat (const char *__restrict __file,
# 280 "/usr/include/sys/stat.h" 3 4
extern int chmod (const char *__file, __mode_t __mode)
extern int lchmod (const char *__file, __mode_t __mode)
extern int fchmod (int __fd, __mode_t __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int fchmodat (int __fd, const char *__file, __mode_t __mode,
int __flag)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
extern __mode_t umask (__mode_t __mask) __attribute__ ((__nothrow__ , __leaf__));
# 317 "/usr/include/sys/stat.h" 3 4
extern int mkdir (const char *__path, __mode_t __mode)
extern int mkdirat (int __fd, const char *__path, __mode_t __mode)
extern int mknod (const char *__path, __mode_t __mode, __dev_t __dev)
extern int mknodat (int __fd, const char *__path, __mode_t __mode,
__dev_t __dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int mkfifo (const char *__path, __mode_t __mode)
extern int mkfifoat (int __fd, const char *__path, __mode_t __mode)
extern int utimensat (int __fd, const char *__path,
const struct timespec __times[2],
int __flags)
extern int futimens (int __fd, const struct timespec __times[2]) __attribute__ ((__nothrow__ , __leaf__));
# 395 "/usr/include/sys/stat.h" 3 4
extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int __xstat (int __ver, const char *__filename,
struct stat *__stat_buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int __lxstat (int __ver, const char *__filename,
extern int __fxstatat (int __ver, int __fildes, const char *__filename,
struct stat *__stat_buf, int __flag)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4)));
# 438 "/usr/include/sys/stat.h" 3 4
extern int __xmknod (int __ver, const char *__path, __mode_t __mode,
__dev_t *__dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int __xmknodat (int __ver, int __fd, const char *__path,
__mode_t __mode, __dev_t *__dev)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 5)));
# 534 "/usr/include/sys/stat.h" 3 4
# 6 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
TEST checkSysWait from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
int s;
wait (&s);
s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
return 0;
Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/time.h" 1 3 4
# 25 "/usr/include/time.h" 3 4
# 26 "/usr/include/time.h" 2 3 4
# 30 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 26 "/usr/include/bits/time.h" 3 4
# 27 "/usr/include/bits/time.h" 2 3 4
# 34 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 39 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/types/struct_tm.h" 1 3 4
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
# 40 "/usr/include/time.h" 2 3 4
struct timespec
__time_t tv_sec;
# 43 "/usr/include/time.h" 2 3 4
# 47 "/usr/include/time.h" 2 3 4
# 48 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/types/struct_itimerspec.h" 1 3 4
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
# 49 "/usr/include/time.h" 2 3 4
struct sigevent;
# 61 "/usr/include/time.h" 2 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
const char *__restrict __format,
const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 104 "/usr/include/time.h" 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
const struct tm *__restrict __tp,
locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 119 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 196 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 211 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
struct sigevent *__restrict __evp,
timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec *__restrict __value,
struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timespec_get (struct timespec *__ts, int __base)
# 307 "/usr/include/time.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/time.h" 1 3 4
# 21 "/usr/include/sys/time.h" 3 4
# 22 "/usr/include/sys/time.h" 2 3 4
# 24 "/usr/include/sys/time.h" 2 3 4
# 25 "/usr/include/sys/time.h" 2 3 4
struct timeval
__time_t tv_sec;
# 26 "/usr/include/sys/time.h" 2 3 4
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
# 49 "/usr/include/sys/select.h" 3 4
typedef struct
} fd_set;
# 33 "/usr/include/sys/time.h" 2 3 4
# 52 "/usr/include/sys/time.h" 3 4
struct timezone
int tz_minuteswest;
int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 68 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
__timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
ITIMER_REAL = 0,
ITIMER_VIRTUAL = 1,
ITIMER_PROF = 2
struct itimerval
struct timeval it_interval;
struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
const struct itimerval *__restrict __new,
struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 186 "/usr/include/sys/time.h" 3 4
Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
return 0;
Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
Checks for the math headers and defines
Checking for header: math.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/math.h" 1 3 4
# 27 "/usr/include/math.h" 3 4
# 28 "/usr/include/math.h" 2 3 4
# 38 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/math-vector.h" 1 3 4
# 25 "/usr/include/bits/math-vector.h" 3 4
# 1 "/usr/include/bits/libm-simd-decl-stubs.h" 1 3 4
# 26 "/usr/include/bits/math-vector.h" 2 3 4
# 41 "/usr/include/math.h" 2 3 4
# 44 "/usr/include/math.h" 2 3 4
# 138 "/usr/include/math.h" 3 4
# 1 "/usr/include/bits/flt-eval-method.h" 1 3 4
# 139 "/usr/include/math.h" 2 3 4
# 149 "/usr/include/math.h" 3 4
typedef float float_t;
typedef double double_t;
# 190 "/usr/include/math.h" 3 4
# 1 "/usr/include/bits/fp-logb.h" 1 3 4
# 191 "/usr/include/math.h" 2 3 4
# 233 "/usr/include/math.h" 3 4
# 1 "/usr/include/bits/fp-fast.h" 1 3 4
# 234 "/usr/include/math.h" 2 3 4
# 289 "/usr/include/math.h" 3 4
# 1 "/usr/include/bits/mathcalls-helper-functions.h" 1 3 4
# 21 "/usr/include/bits/mathcalls-helper-functions.h" 3 4
extern int __fpclassify (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbit (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __iseqsig (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __issignaling (double __value) __attribute__ ((__nothrow__ , __leaf__))
# 290 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/mathcalls.h" 1 3 4
# 53 "/usr/include/bits/mathcalls.h" 3 4
extern double acos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
# 85 "/usr/include/bits/mathcalls.h" 3 4
extern double acosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double log (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log10 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log10 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern double __modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 119 "/usr/include/bits/mathcalls.h" 3 4
extern double expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log1p (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log1p (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double logb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __logb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
# 177 "/usr/include/bits/mathcalls.h" 3 4
extern int isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double significand (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __significand (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nan (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)); extern double __nan (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__));
# 211 "/usr/include/bits/mathcalls.h" 3 4
extern int isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double j0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double j1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double jn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __jn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double y0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double y1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double yn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __yn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double erf (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erf (double) __attribute__ ((__nothrow__ , __leaf__));
extern double erfc (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erfc (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double tgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __tgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double gamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __gamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern double rint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __rint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
# 272 "/usr/include/bits/mathcalls.h" 3 4
extern double remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__));
# 290 "/usr/include/bits/mathcalls.h" 3 4
extern double scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern double nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern double __remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lround (double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llround (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__)); extern double __fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__));
# 396 "/usr/include/bits/mathcalls.h" 3 4
extern double scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__));
# 291 "/usr/include/math.h" 2 3 4
# 306 "/usr/include/math.h" 3 4
extern int __fpclassifyf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __iseqsigf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __issignalingf (float __value) __attribute__ ((__nothrow__ , __leaf__))
# 307 "/usr/include/math.h" 2 3 4
extern float acosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float cosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float coshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __coshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float expf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float logf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log10f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log10f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern float __modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern float expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float logbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern int isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float significandf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __significandf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nanf (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)); extern float __nanf (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__));
extern int isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float j0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float j1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float jnf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __jnf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float y0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float y1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float ynf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __ynf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float erff (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erff (float) __attribute__ ((__nothrow__ , __leaf__));
extern float erfcf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erfcf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float tgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __tgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float gammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __gammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern float rintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __rintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern float remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern float nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern float __remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__));
# 308 "/usr/include/math.h" 2 3 4
# 349 "/usr/include/math.h" 3 4
extern int __fpclassifyl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __iseqsigl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __issignalingl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
# 350 "/usr/include/math.h" 2 3 4
extern long double acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double expl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double logl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern long double __modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern long double expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nanl (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nanl (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__));
extern int isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double j0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double j1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfcl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfcl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double tgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double gammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __gammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern long double rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern long double nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__));
# 351 "/usr/include/math.h" 2 3 4
# 420 "/usr/include/math.h" 3 4
extern int __fpclassifyf128 (_Float128 __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitf128 (_Float128 __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __isinff128 (_Float128 __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitef128 (_Float128 __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanf128 (_Float128 __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __iseqsigf128 (_Float128 __x, _Float128 __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __issignalingf128 (_Float128 __value) __attribute__ ((__nothrow__ , __leaf__))
# 421 "/usr/include/math.h" 2 3 4
# 773 "/usr/include/math.h" 3 4
extern int signgam;
# 853 "/usr/include/math.h" 3 4
enum
FP_NAN =
0,
FP_INFINITE =
1,
FP_ZERO =
2,
FP_SUBNORMAL =
3,
FP_NORMAL =
4
# 1553 "/usr/include/math.h" 3 4
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
Defined "HAVE_MATH_H" to "1"
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.headers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.headers/conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
return 0;
Found math #defines, like M_PI
Successful compile:
Source:
#include <math.h>
int main() {
double f = INFINITY;
if (f);
return 0;
Defined "HAVE_MATH_INFINITY" to "1"
Found math INFINITY
TEST check from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 1 "/usr/include/sys/socket.h" 1 3 4
# 22 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/bits/types/struct_iovec.h" 1 3 4
# 23 "/usr/include/bits/types/struct_iovec.h" 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 24 "/usr/include/bits/types/struct_iovec.h" 2 3 4
struct iovec
void *iov_base;
size_t iov_len;
# 27 "/usr/include/sys/socket.h" 2 3 4
# 29 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/bits/socket.h" 1 3 4
# 27 "/usr/include/bits/socket.h" 3 4
# 28 "/usr/include/bits/socket.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef __int8_t __int_least8_t;
typedef __uint8_t __uint_least8_t;
typedef __int16_t __int_least16_t;
typedef __uint16_t __uint_least16_t;
typedef __int32_t __int_least32_t;
typedef __uint32_t __uint_least32_t;
typedef __int64_t __int_least64_t;
typedef __uint64_t __uint_least64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
typedef long int __intmax_t;
typedef unsigned long int __uintmax_t;
# 140 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 141 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef int __sig_atomic_t;
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 59 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 97 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 1 "/usr/include/bits/types/clock_t.h" 1 3 4
typedef __clock_t clock_t;
# 127 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/clockid_t.h" 1 3 4
typedef __clockid_t clockid_t;
# 129 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/time_t.h" 1 3 4
typedef __time_t time_t;
# 130 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/timer_t.h" 1 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/sys/types.h" 2 3 4
# 144 "/usr/include/sys/types.h" 3 4
# 145 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 1 "/usr/include/bits/stdint-intn.h" 1 3 4
# 24 "/usr/include/bits/stdint-intn.h" 3 4
typedef __int8_t int8_t;
typedef __int16_t int16_t;
typedef __int32_t int32_t;
typedef __int64_t int64_t;
# 156 "/usr/include/sys/types.h" 2 3 4
# 177 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 193 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 33 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint16_t
__bswap_16 (__uint16_t __bsx)
return __builtin_bswap16 (__bsx);
static __inline __uint32_t
__bswap_32 (__uint32_t __bsx)
return __builtin_bswap32 (__bsx);
# 69 "/usr/include/bits/byteswap.h" 3 4
__extension__ static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/bits/uintn-identity.h" 1 3 4
# 32 "/usr/include/bits/uintn-identity.h" 3 4
__uint16_identity (__uint16_t __x)
return __x;
__uint32_identity (__uint32_t __x)
return __x;
__uint64_identity (__uint64_t __x)
return __x;
# 62 "/usr/include/endian.h" 2 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/sigset_t.h" 1 3 4
# 1 "/usr/include/bits/types/__sigset_t.h" 1 3 4
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
# 5 "/usr/include/bits/types/sigset_t.h" 2 3 4
typedef __sigset_t sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timeval.h" 1 3 4
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
# 38 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timespec.h" 1 3 4
# 9 "/usr/include/bits/types/struct_timespec.h" 3 4
struct timespec
__time_t tv_sec;
__syscall_slong_t tv_nsec;
# 40 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 59 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
# 91 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
fd_set *__restrict __writefds,
fd_set *__restrict __exceptfds,
struct timeval *__restrict __timeout);
# 113 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
const struct timespec *__restrict __timeout,
const __sigset_t *__restrict __sigmask);
# 126 "/usr/include/sys/select.h" 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 244 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/bits/pthreadtypes.h" 3 4
# 1 "/usr/include/bits/thread-shared-types.h" 1 3 4
# 77 "/usr/include/bits/thread-shared-types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes-arch.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 22 "/usr/include/bits/pthreadtypes-arch.h" 2 3 4
# 65 "/usr/include/bits/pthreadtypes-arch.h" 3 4
struct __pthread_rwlock_arch_t
unsigned int __readers;
unsigned int __writers;
unsigned int __wrphase_futex;
unsigned int __writers_futex;
unsigned int __pad3;
unsigned int __pad4;
int __cur_writer;
int __shared;
signed char __rwelision;
unsigned char __pad1[7];
unsigned long int __pad2;
unsigned int __flags;
# 99 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 78 "/usr/include/bits/thread-shared-types.h" 2 3 4
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
# 118 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_mutex_s
int __lock ;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
short __spins; short __elision;
__pthread_list_t __list;
# 145 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_cond_s
__extension__ union
__extension__ unsigned long long int __wseq;
struct
unsigned int __low;
unsigned int __high;
} __wseq32;
__extension__ union
__extension__ unsigned long long int __g1_start;
struct
unsigned int __low;
} __g1_start32;
unsigned int __g_refs[2] ;
unsigned int __g_size[2];
unsigned int __g1_orig_size;
unsigned int __wrefs;
unsigned int __g_signals[2];
# 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
typedef unsigned long int pthread_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
union pthread_attr_t
char __size[56];
long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef union
struct __pthread_mutex_s __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
struct __pthread_cond_s __data;
char __size[48];
__extension__ long long int __align;
} pthread_cond_t;
typedef union
struct __pthread_rwlock_arch_t __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
# 245 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
# 1 "/usr/include/bits/socket_type.h" 1 3 4
# 24 "/usr/include/bits/socket_type.h" 3 4
enum __socket_type
SOCK_STREAM = 1,
SOCK_DGRAM = 2,
SOCK_RAW = 3,
SOCK_RDM = 4,
SOCK_SEQPACKET = 5,
SOCK_DCCP = 6,
SOCK_PACKET = 10,
SOCK_CLOEXEC = 02000000,
SOCK_NONBLOCK = 00004000
# 39 "/usr/include/bits/socket.h" 2 3 4
# 172 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/bits/sockaddr.h" 1 3 4
# 28 "/usr/include/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 173 "/usr/include/bits/socket.h" 2 3 4
struct sockaddr
sa_family_t sa_family;
char sa_data[14];
# 188 "/usr/include/bits/socket.h" 3 4
struct sockaddr_storage
sa_family_t ss_family;
char __ss_padding[(128 - (sizeof (unsigned short int)) - sizeof (unsigned long int))];
unsigned long int __ss_align;
enum
MSG_OOB = 0x01,
MSG_PEEK = 0x02,
MSG_DONTROUTE = 0x04,
MSG_CTRUNC = 0x08,
MSG_PROXY = 0x10,
MSG_TRUNC = 0x20,
MSG_DONTWAIT = 0x40,
MSG_EOR = 0x80,
MSG_WAITALL = 0x100,
MSG_FIN = 0x200,
MSG_SYN = 0x400,
MSG_CONFIRM = 0x800,
MSG_RST = 0x1000,
MSG_ERRQUEUE = 0x2000,
MSG_NOSIGNAL = 0x4000,
MSG_MORE = 0x8000,
MSG_WAITFORONE = 0x10000,
MSG_BATCH = 0x40000,
MSG_ZEROCOPY = 0x4000000,
MSG_FASTOPEN = 0x20000000,
MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
void *msg_name;
socklen_t msg_namelen;
struct iovec *msg_iov;
size_t msg_iovlen;
void *msg_control;
size_t msg_controllen;
int msg_flags;
struct cmsghdr
size_t cmsg_len;
int cmsg_level;
int cmsg_type;
__extension__ unsigned char __cmsg_data [];
# 302 "/usr/include/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 329 "/usr/include/bits/socket.h" 3 4
enum
SCM_RIGHTS = 0x01
# 390 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 2 3 4
# 6 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/asm/socket.h" 2 3 4
# 391 "/usr/include/bits/socket.h" 2 3 4
# 444 "/usr/include/bits/socket.h" 3 4
struct linger
int l_onoff;
int l_linger;
# 34 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/bits/types/struct_osockaddr.h" 1 3 4
struct osockaddr
unsigned short int sa_family;
unsigned char sa_data[14];
# 37 "/usr/include/sys/socket.h" 2 3 4
enum
SHUT_RD = 0,
SHUT_WR,
SHUT_RDWR
# 102 "/usr/include/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/sys/socket.h" 3 4
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
int __flags, const struct sockaddr * __addr,
socklen_t __addr_len);
# 163 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
int __flags, struct sockaddr *__restrict __addr,
socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
int __flags);
# 191 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
# 208 "/usr/include/sys/socket.h" 3 4
extern int getsockopt (int __fd, int __level, int __optname,
void *__restrict __optval,
socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 232 "/usr/include/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 250 "/usr/include/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 272 "/usr/include/sys/socket.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
stdout:
# 1 "<built-in>"
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/bits/types.h" 3 4
return __x;
return __x;
return __x;
typedef struct
} __sigset_t;
struct timeval
__time_t tv_sec;
struct timespec
__time_t tv_sec;
typedef struct
} fd_set;
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/malloc.h" 1 3 4
# 22 "/usr/include/malloc.h" 3 4
# 23 "/usr/include/malloc.h" 2 3 4
# 149 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 328 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef int wchar_t;
# 426 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef struct {
long long __max_align_ll __attribute__((__aligned__(__alignof__(long long))));
long double __max_align_ld __attribute__((__aligned__(__alignof__(long double))));
# 437 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
} max_align_t;
# 24 "/usr/include/malloc.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 27 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/libc-header-start.h" 1 3 4
# 28 "/usr/include/stdio.h" 2 3 4
# 34 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 37 "/usr/include/stdio.h" 2 3 4
# 39 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/include/bits/types/__fpos_t.h" 1 3 4
# 1 "/usr/include/bits/types/__mbstate_t.h" 1 3 4
# 13 "/usr/include/bits/types/__mbstate_t.h" 3 4
typedef struct
int __count;
union
unsigned int __wch;
char __wchb[4];
} __value;
} __mbstate_t;
# 6 "/usr/include/bits/types/__fpos_t.h" 2 3 4
typedef struct _G_fpos_t
__off_t __pos;
__mbstate_t __state;
} __fpos_t;
# 40 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/include/bits/types/__fpos64_t.h" 1 3 4
# 10 "/usr/include/bits/types/__fpos64_t.h" 3 4
typedef struct _G_fpos64_t
__off64_t __pos;
} __fpos64_t;
# 41 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/include/bits/types/__FILE.h" 1 3 4
struct _IO_FILE;
typedef struct _IO_FILE __FILE;
# 42 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/include/bits/types/FILE.h" 1 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 43 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/include/bits/types/struct_FILE.h" 1 3 4
# 35 "/usr/include/bits/types/struct_FILE.h" 3 4
struct _IO_FILE;
struct _IO_marker;
struct _IO_codecvt;
struct _IO_wide_data;
typedef void _IO_lock_t;
struct _IO_FILE
int _flags;
char *_IO_read_ptr;
char *_IO_read_end;
char *_IO_read_base;
char *_IO_write_base;
char *_IO_write_ptr;
char *_IO_write_end;
char *_IO_buf_base;
char *_IO_buf_end;
char *_IO_save_base;
char *_IO_backup_base;
char *_IO_save_end;
struct _IO_marker *_markers;
struct _IO_FILE *_chain;
int _fileno;
int _flags2;
__off_t _old_offset;
unsigned short _cur_column;
signed char _vtable_offset;
char _shortbuf[1];
_IO_lock_t *_lock;
__off64_t _offset;
struct _IO_codecvt *_codecvt;
struct _IO_wide_data *_wide_data;
struct _IO_FILE *_freeres_list;
void *_freeres_buf;
size_t __pad5;
int _mode;
char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
# 44 "/usr/include/stdio.h" 2 3 4
# 52 "/usr/include/stdio.h" 3 4
typedef __gnuc_va_list va_list;
# 63 "/usr/include/stdio.h" 3 4
# 77 "/usr/include/stdio.h" 3 4
typedef __fpos_t fpos_t;
# 133 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 134 "/usr/include/stdio.h" 2 3 4
extern FILE *stdin;
extern FILE *stdout;
extern FILE *stderr;
extern int remove (const char *__filename) __attribute__ ((__nothrow__ , __leaf__));
extern int rename (const char *__old, const char *__new) __attribute__ ((__nothrow__ , __leaf__));
extern int renameat (int __oldfd, const char *__old, int __newfd,
# 173 "/usr/include/stdio.h" 3 4
extern FILE *tmpfile (void) ;
# 187 "/usr/include/stdio.h" 3 4
extern char *tmpnam (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
# 204 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 227 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 246 "/usr/include/stdio.h" 3 4
extern FILE *fopen (const char *__restrict __filename,
const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
const char *__restrict __modes,
FILE *__restrict __stream) ;
# 279 "/usr/include/stdio.h" 3 4
extern FILE *fdopen (int __fd, const char *__modes) __attribute__ ((__nothrow__ , __leaf__)) ;
# 292 "/usr/include/stdio.h" 3 4
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
int __modes, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
size_t __size) __attribute__ ((__nothrow__ , __leaf__));
extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int fprintf (FILE *__restrict __stream,
const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
const char *__restrict __format, ...) __attribute__ ((__nothrow__));
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
__gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
__gnuc_va_list __arg) __attribute__ ((__nothrow__));
extern int snprintf (char *__restrict __s, size_t __maxlen,
__attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
__attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
# 379 "/usr/include/stdio.h" 3 4
extern int vdprintf (int __fd, const char *__restrict __fmt,
__attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
__attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
const char *__restrict __format, ...) __attribute__ ((__nothrow__ , __leaf__));
# 409 "/usr/include/stdio.h" 3 4
extern int fscanf (FILE *__restrict __stream, const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
extern int scanf (const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
extern int sscanf (const char *__restrict __s, const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__ , __leaf__))
# 434 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
__attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
__attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
# 457 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
extern int vsscanf (const char *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__ , __leaf__))
# 491 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 516 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
# 527 "/usr/include/stdio.h" 3 4
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 543 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 609 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
size_t __n, FILE *__restrict __s);
# 679 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 713 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 737 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 763 "/usr/include/stdio.h" 3 4
extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
# 788 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
# 806 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 846 "/usr/include/stdio.h" 3 4
extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
# 864 "/usr/include/stdio.h" 3 4
extern int __uflow (FILE *);
extern int __overflow (FILE *, int);
# 879 "/usr/include/stdio.h" 3 4
# 25 "/usr/include/malloc.h" 2 3 4
# 35 "/usr/include/malloc.h" 3 4
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void *reallocarray (void *__ptr, size_t __nmemb, size_t __size)
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void *memalign (size_t __alignment, size_t __size)
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *pvalloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *(*__morecore) (ptrdiff_t __size);
extern void *__default_morecore (ptrdiff_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__));
struct mallinfo
int arena;
int ordblks;
int smblks;
int hblks;
int hblkhd;
int usmblks;
int fsmblks;
int uordblks;
int fordblks;
int keepcost;
extern struct mallinfo mallinfo (void) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/malloc.h" 3 4
extern int mallopt (int __param, int __val) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_trim (size_t __pad) __attribute__ ((__nothrow__ , __leaf__));
extern size_t malloc_usable_size (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void malloc_stats (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_info (int __options, FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern void (*volatile __free_hook) (void *__ptr,
const void *)
__attribute__ ((__deprecated__));
extern void *(*volatile __malloc_hook)(size_t __size,
const void *)
extern void *(*volatile __realloc_hook)(void *__ptr,
size_t __size,
const void *)
extern void *(*volatile __memalign_hook)(size_t __alignment,
size_t __size,
const void *)
extern void (*volatile __after_morecore_hook) (void);
extern void __malloc_check_init (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
Defined "HAVE_MALLOC_H" to "1"
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/time.h" 1 3 4
# 25 "/usr/include/time.h" 3 4
# 26 "/usr/include/time.h" 2 3 4
# 30 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 26 "/usr/include/bits/time.h" 3 4
# 27 "/usr/include/bits/time.h" 2 3 4
# 34 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 39 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/types/struct_tm.h" 1 3 4
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
# 40 "/usr/include/time.h" 2 3 4
struct timespec
__time_t tv_sec;
# 43 "/usr/include/time.h" 2 3 4
# 47 "/usr/include/time.h" 2 3 4
# 48 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/types/struct_itimerspec.h" 1 3 4
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
# 49 "/usr/include/time.h" 2 3 4
struct sigevent;
# 1 "/usr/include/bits/types/locale_t.h" 1 3 4
# 22 "/usr/include/bits/types/locale_t.h" 3 4
# 1 "/usr/include/bits/types/__locale_t.h" 1 3 4
# 28 "/usr/include/bits/types/__locale_t.h" 3 4
struct __locale_struct
struct __locale_data *__locales[13];
const unsigned short int *__ctype_b;
const int *__ctype_tolower;
const int *__ctype_toupper;
const char *__names[13];
typedef struct __locale_struct *__locale_t;
# 23 "/usr/include/bits/types/locale_t.h" 2 3 4
typedef __locale_t locale_t;
# 61 "/usr/include/time.h" 2 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 104 "/usr/include/time.h" 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
const struct tm *__restrict __tp,
locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 119 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 196 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 211 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
struct sigevent *__restrict __evp,
timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec *__restrict __value,
struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timespec_get (struct timespec *__ts, int __base)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 307 "/usr/include/time.h" 3 4
Defined "HAVE_TIME_H" to "1"
Checking for header: Direct.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2stderr:
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory
#include <Direct.h>
compilation terminated.
Source:
#include "confdefs.h"
#include "conffix.h"
#include <Direct.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory
#include <Direct.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory #include <Direct.h> ^~~~~~~~~~compilation terminated.:
Checking for header: Ws2tcpip.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory
#include <Ws2tcpip.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory #include <Ws2tcpip.h> ^~~~~~~~~~~~compilation terminated.:
Checking for header: endian.h
stdout:
# 1 "<built-in>"
# 21 "/usr/include/endian.h" 3 4
# 22 "/usr/include/endian.h" 2 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 2 3 4
return __x;
return __x;
return __x;
Defined "HAVE_ENDIAN_H" to "1"
Checking for header: immintrin.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 1 3 4
# 27 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mmintrin.h" 1 3 4
# 42 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mmintrin.h" 3 4
typedef int __m64 __attribute__ ((__vector_size__ (8), __may_alias__));
typedef int __m64_u __attribute__ ((__vector_size__ (8), __may_alias__, __aligned__ (1)));
typedef int __v2si __attribute__ ((__vector_size__ (8)));
typedef short __v4hi __attribute__ ((__vector_size__ (8)));
typedef char __v8qi __attribute__ ((__vector_size__ (8)));
typedef long long __v1di __attribute__ ((__vector_size__ (8)));
typedef float __v2sf __attribute__ ((__vector_size__ (8)));
extern __inline void __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_empty (void)
__builtin_ia32_emms ();
_m_empty (void)
_mm_empty ();
extern __inline __m64 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_cvtsi32_si64 (int __i)
return (__m64) __builtin_ia32_vec_init_v2si (__i, 0);
_m_from_int (int __i)
return _mm_cvtsi32_si64 (__i);
_m_from_int64 (long long __i)
return (__m64) __i;
_mm_cvtsi64_m64 (long long __i)
return (__m64) __i;
_mm_cvtsi64x_si64 (long long __i)
return (__m64) __i;
_mm_set_pi64x (long long __i)
return (__m64) __i;
extern __inline int __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_cvtsi64_si32 (__m64 __i)
return __builtin_ia32_vec_ext_v2si ((__v2si)__i, 0);
_m_to_int (__m64 __i)
return _mm_cvtsi64_si32 (__i);
extern __inline long long __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_m_to_int64 (__m64 __i)
return (long long)__i;
_mm_cvtm64_si64 (__m64 __i)
_mm_cvtsi64_si64x (__m64 __i)
_mm_packs_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_packsswb ((__v4hi)__m1, (__v4hi)__m2);
_m_packsswb (__m64 __m1, __m64 __m2)
return _mm_packs_pi16 (__m1, __m2);
_mm_packs_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_packssdw ((__v2si)__m1, (__v2si)__m2);
_m_packssdw (__m64 __m1, __m64 __m2)
return _mm_packs_pi32 (__m1, __m2);
_mm_packs_pu16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_packuswb ((__v4hi)__m1, (__v4hi)__m2);
_m_packuswb (__m64 __m1, __m64 __m2)
return _mm_packs_pu16 (__m1, __m2);
_mm_unpackhi_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_punpckhbw ((__v8qi)__m1, (__v8qi)__m2);
_m_punpckhbw (__m64 __m1, __m64 __m2)
return _mm_unpackhi_pi8 (__m1, __m2);
_mm_unpackhi_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_punpckhwd ((__v4hi)__m1, (__v4hi)__m2);
_m_punpckhwd (__m64 __m1, __m64 __m2)
return _mm_unpackhi_pi16 (__m1, __m2);
_mm_unpackhi_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_punpckhdq ((__v2si)__m1, (__v2si)__m2);
_m_punpckhdq (__m64 __m1, __m64 __m2)
return _mm_unpackhi_pi32 (__m1, __m2);
_mm_unpacklo_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_punpcklbw ((__v8qi)__m1, (__v8qi)__m2);
_m_punpcklbw (__m64 __m1, __m64 __m2)
return _mm_unpacklo_pi8 (__m1, __m2);
_mm_unpacklo_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_punpcklwd ((__v4hi)__m1, (__v4hi)__m2);
_m_punpcklwd (__m64 __m1, __m64 __m2)
return _mm_unpacklo_pi16 (__m1, __m2);
_mm_unpacklo_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_punpckldq ((__v2si)__m1, (__v2si)__m2);
_m_punpckldq (__m64 __m1, __m64 __m2)
return _mm_unpacklo_pi32 (__m1, __m2);
_mm_add_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddb ((__v8qi)__m1, (__v8qi)__m2);
_m_paddb (__m64 __m1, __m64 __m2)
return _mm_add_pi8 (__m1, __m2);
_mm_add_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddw ((__v4hi)__m1, (__v4hi)__m2);
_m_paddw (__m64 __m1, __m64 __m2)
return _mm_add_pi16 (__m1, __m2);
_mm_add_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddd ((__v2si)__m1, (__v2si)__m2);
_m_paddd (__m64 __m1, __m64 __m2)
return _mm_add_pi32 (__m1, __m2);
# 322 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mmintrin.h" 3 4
_mm_add_si64 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddq ((__v1di)__m1, (__v1di)__m2);
_mm_adds_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddsb ((__v8qi)__m1, (__v8qi)__m2);
_m_paddsb (__m64 __m1, __m64 __m2)
return _mm_adds_pi8 (__m1, __m2);
_mm_adds_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddsw ((__v4hi)__m1, (__v4hi)__m2);
_m_paddsw (__m64 __m1, __m64 __m2)
return _mm_adds_pi16 (__m1, __m2);
_mm_adds_pu8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddusb ((__v8qi)__m1, (__v8qi)__m2);
_m_paddusb (__m64 __m1, __m64 __m2)
return _mm_adds_pu8 (__m1, __m2);
_mm_adds_pu16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_paddusw ((__v4hi)__m1, (__v4hi)__m2);
_m_paddusw (__m64 __m1, __m64 __m2)
return _mm_adds_pu16 (__m1, __m2);
_mm_sub_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubb ((__v8qi)__m1, (__v8qi)__m2);
_m_psubb (__m64 __m1, __m64 __m2)
return _mm_sub_pi8 (__m1, __m2);
_mm_sub_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubw ((__v4hi)__m1, (__v4hi)__m2);
_m_psubw (__m64 __m1, __m64 __m2)
return _mm_sub_pi16 (__m1, __m2);
_mm_sub_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubd ((__v2si)__m1, (__v2si)__m2);
_m_psubd (__m64 __m1, __m64 __m2)
return _mm_sub_pi32 (__m1, __m2);
# 434 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mmintrin.h" 3 4
_mm_sub_si64 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubq ((__v1di)__m1, (__v1di)__m2);
_mm_subs_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubsb ((__v8qi)__m1, (__v8qi)__m2);
_m_psubsb (__m64 __m1, __m64 __m2)
return _mm_subs_pi8 (__m1, __m2);
_mm_subs_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubsw ((__v4hi)__m1, (__v4hi)__m2);
_m_psubsw (__m64 __m1, __m64 __m2)
return _mm_subs_pi16 (__m1, __m2);
_mm_subs_pu8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubusb ((__v8qi)__m1, (__v8qi)__m2);
_m_psubusb (__m64 __m1, __m64 __m2)
return _mm_subs_pu8 (__m1, __m2);
_mm_subs_pu16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_psubusw ((__v4hi)__m1, (__v4hi)__m2);
_m_psubusw (__m64 __m1, __m64 __m2)
return _mm_subs_pu16 (__m1, __m2);
_mm_madd_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pmaddwd ((__v4hi)__m1, (__v4hi)__m2);
_m_pmaddwd (__m64 __m1, __m64 __m2)
return _mm_madd_pi16 (__m1, __m2);
_mm_mulhi_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pmulhw ((__v4hi)__m1, (__v4hi)__m2);
_m_pmulhw (__m64 __m1, __m64 __m2)
return _mm_mulhi_pi16 (__m1, __m2);
_mm_mullo_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pmullw ((__v4hi)__m1, (__v4hi)__m2);
_m_pmullw (__m64 __m1, __m64 __m2)
return _mm_mullo_pi16 (__m1, __m2);
_mm_sll_pi16 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psllw ((__v4hi)__m, (__v4hi)__count);
_m_psllw (__m64 __m, __m64 __count)
return _mm_sll_pi16 (__m, __count);
_mm_slli_pi16 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psllwi ((__v4hi)__m, __count);
_m_psllwi (__m64 __m, int __count)
return _mm_slli_pi16 (__m, __count);
_mm_sll_pi32 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_pslld ((__v2si)__m, (__v2si)__count);
_m_pslld (__m64 __m, __m64 __count)
return _mm_sll_pi32 (__m, __count);
_mm_slli_pi32 (__m64 __m, int __count)
return (__m64) __builtin_ia32_pslldi ((__v2si)__m, __count);
_m_pslldi (__m64 __m, int __count)
return _mm_slli_pi32 (__m, __count);
_mm_sll_si64 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psllq ((__v1di)__m, (__v1di)__count);
_m_psllq (__m64 __m, __m64 __count)
return _mm_sll_si64 (__m, __count);
_mm_slli_si64 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psllqi ((__v1di)__m, __count);
_m_psllqi (__m64 __m, int __count)
return _mm_slli_si64 (__m, __count);
_mm_sra_pi16 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psraw ((__v4hi)__m, (__v4hi)__count);
_m_psraw (__m64 __m, __m64 __count)
return _mm_sra_pi16 (__m, __count);
_mm_srai_pi16 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psrawi ((__v4hi)__m, __count);
_m_psrawi (__m64 __m, int __count)
return _mm_srai_pi16 (__m, __count);
_mm_sra_pi32 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psrad ((__v2si)__m, (__v2si)__count);
_m_psrad (__m64 __m, __m64 __count)
return _mm_sra_pi32 (__m, __count);
_mm_srai_pi32 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psradi ((__v2si)__m, __count);
_m_psradi (__m64 __m, int __count)
return _mm_srai_pi32 (__m, __count);
_mm_srl_pi16 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psrlw ((__v4hi)__m, (__v4hi)__count);
_m_psrlw (__m64 __m, __m64 __count)
return _mm_srl_pi16 (__m, __count);
_mm_srli_pi16 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psrlwi ((__v4hi)__m, __count);
_m_psrlwi (__m64 __m, int __count)
return _mm_srli_pi16 (__m, __count);
_mm_srl_pi32 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psrld ((__v2si)__m, (__v2si)__count);
_m_psrld (__m64 __m, __m64 __count)
return _mm_srl_pi32 (__m, __count);
_mm_srli_pi32 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psrldi ((__v2si)__m, __count);
_m_psrldi (__m64 __m, int __count)
return _mm_srli_pi32 (__m, __count);
_mm_srl_si64 (__m64 __m, __m64 __count)
return (__m64) __builtin_ia32_psrlq ((__v1di)__m, (__v1di)__count);
_m_psrlq (__m64 __m, __m64 __count)
return _mm_srl_si64 (__m, __count);
_mm_srli_si64 (__m64 __m, int __count)
return (__m64) __builtin_ia32_psrlqi ((__v1di)__m, __count);
_m_psrlqi (__m64 __m, int __count)
return _mm_srli_si64 (__m, __count);
_mm_and_si64 (__m64 __m1, __m64 __m2)
return __builtin_ia32_pand (__m1, __m2);
_m_pand (__m64 __m1, __m64 __m2)
return _mm_and_si64 (__m1, __m2);
_mm_andnot_si64 (__m64 __m1, __m64 __m2)
return __builtin_ia32_pandn (__m1, __m2);
_m_pandn (__m64 __m1, __m64 __m2)
return _mm_andnot_si64 (__m1, __m2);
_mm_or_si64 (__m64 __m1, __m64 __m2)
return __builtin_ia32_por (__m1, __m2);
_m_por (__m64 __m1, __m64 __m2)
return _mm_or_si64 (__m1, __m2);
_mm_xor_si64 (__m64 __m1, __m64 __m2)
return __builtin_ia32_pxor (__m1, __m2);
_m_pxor (__m64 __m1, __m64 __m2)
return _mm_xor_si64 (__m1, __m2);
_mm_cmpeq_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pcmpeqb ((__v8qi)__m1, (__v8qi)__m2);
_m_pcmpeqb (__m64 __m1, __m64 __m2)
return _mm_cmpeq_pi8 (__m1, __m2);
_mm_cmpgt_pi8 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pcmpgtb ((__v8qi)__m1, (__v8qi)__m2);
_m_pcmpgtb (__m64 __m1, __m64 __m2)
return _mm_cmpgt_pi8 (__m1, __m2);
_mm_cmpeq_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pcmpeqw ((__v4hi)__m1, (__v4hi)__m2);
_m_pcmpeqw (__m64 __m1, __m64 __m2)
return _mm_cmpeq_pi16 (__m1, __m2);
_mm_cmpgt_pi16 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pcmpgtw ((__v4hi)__m1, (__v4hi)__m2);
_m_pcmpgtw (__m64 __m1, __m64 __m2)
return _mm_cmpgt_pi16 (__m1, __m2);
_mm_cmpeq_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pcmpeqd ((__v2si)__m1, (__v2si)__m2);
_m_pcmpeqd (__m64 __m1, __m64 __m2)
return _mm_cmpeq_pi32 (__m1, __m2);
_mm_cmpgt_pi32 (__m64 __m1, __m64 __m2)
return (__m64) __builtin_ia32_pcmpgtd ((__v2si)__m1, (__v2si)__m2);
_m_pcmpgtd (__m64 __m1, __m64 __m2)
return _mm_cmpgt_pi32 (__m1, __m2);
_mm_setzero_si64 (void)
return (__m64)0LL;
_mm_set_pi32 (int __i1, int __i0)
return (__m64) __builtin_ia32_vec_init_v2si (__i0, __i1);
_mm_set_pi16 (short __w3, short __w2, short __w1, short __w0)
return (__m64) __builtin_ia32_vec_init_v4hi (__w0, __w1, __w2, __w3);
_mm_set_pi8 (char __b7, char __b6, char __b5, char __b4,
char __b3, char __b2, char __b1, char __b0)
return (__m64) __builtin_ia32_vec_init_v8qi (__b0, __b1, __b2, __b3,
__b4, __b5, __b6, __b7);
_mm_setr_pi32 (int __i0, int __i1)
return _mm_set_pi32 (__i1, __i0);
_mm_setr_pi16 (short __w0, short __w1, short __w2, short __w3)
return _mm_set_pi16 (__w3, __w2, __w1, __w0);
_mm_setr_pi8 (char __b0, char __b1, char __b2, char __b3,
char __b4, char __b5, char __b6, char __b7)
return _mm_set_pi8 (__b7, __b6, __b5, __b4, __b3, __b2, __b1, __b0);
_mm_set1_pi32 (int __i)
return _mm_set_pi32 (__i, __i);
_mm_set1_pi16 (short __w)
return _mm_set_pi16 (__w, __w, __w, __w);
_mm_set1_pi8 (char __b)
return _mm_set_pi8 (__b, __b, __b, __b, __b, __b, __b, __b);
# 28 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mm_malloc.h" 1 3 4
# 27 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mm_malloc.h" 3 4
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 33 "/usr/include/bits/libc-header-start.h" 3 4
# 34 "/usr/include/bits/libc-header-start.h" 2 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 32 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 40 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 41 "/usr/include/stdlib.h" 2 3 4
# 55 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/floatn.h" 1 3 4
# 119 "/usr/include/bits/floatn.h" 3 4
# 1 "/usr/include/bits/floatn-common.h" 1 3 4
# 24 "/usr/include/bits/floatn-common.h" 3 4
# 25 "/usr/include/bits/floatn-common.h" 2 3 4
# 120 "/usr/include/bits/floatn.h" 2 3 4
# 56 "/usr/include/stdlib.h" 2 3 4
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
__extension__ typedef struct
long long int quot;
long long int rem;
} lldiv_t;
# 97 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
# 176 "/usr/include/stdlib.h" 3 4
extern long int strtol (const char *__restrict __nptr,
char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 385 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
return __x;
return __x;
return __x;
typedef struct
} __sigset_t;
struct timeval
__time_t tv_sec;
struct timespec
__time_t tv_sec;
typedef struct
} fd_set;
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
# 395 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
size_t __statelen,
struct random_data *__restrict __buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
__extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
# 563 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 567 "/usr/include/stdlib.h" 2 3 4
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int at_quick_exit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void quick_exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 644 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 672 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 685 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 707 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 728 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 781 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 797 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 817 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
__attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 837 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
long long int __denom)
# 869 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign, char *__restrict __buf,
size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign,
char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 954 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
char *const *__restrict __tokens,
char **__restrict __valuep)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 1000 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1010 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 1011 "/usr/include/stdlib.h" 2 3 4
# 1020 "/usr/include/stdlib.h" 3 4
# 28 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/mm_malloc.h" 2 3 4
extern int posix_memalign (void **, size_t, size_t);
static __inline void *
_mm_malloc (size_t __size, size_t __alignment)
void *__ptr;
if (__alignment == 1)
return malloc (__size);
if (__alignment == 2 || (sizeof (void *) == 8 && __alignment == 4))
__alignment = sizeof (void *);
if (posix_memalign (&__ptr, __alignment, __size) == 0)
return __ptr;
else
return ((void *)0);
_mm_free (void *__ptr)
free (__ptr);
# 35 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 2 3 4
enum _mm_hint
_MM_HINT_ET0 = 7,
_MM_HINT_ET1 = 6,
_MM_HINT_T0 = 3,
_MM_HINT_T1 = 2,
_MM_HINT_T2 = 1,
_MM_HINT_NTA = 0
# 69 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
typedef float __m128 __attribute__ ((__vector_size__ (16), __may_alias__));
typedef float __m128_u __attribute__ ((__vector_size__ (16), __may_alias__, __aligned__ (1)));
typedef float __v4sf __attribute__ ((__vector_size__ (16)));
# 109 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
extern __inline __m128 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_undefined_ps (void)
__m128 __Y = __Y;
return __Y;
_mm_setzero_ps (void)
return __extension__ (__m128){ 0.0f, 0.0f, 0.0f, 0.0f };
_mm_add_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_addss ((__v4sf)__A, (__v4sf)__B);
_mm_sub_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_subss ((__v4sf)__A, (__v4sf)__B);
_mm_mul_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_mulss ((__v4sf)__A, (__v4sf)__B);
_mm_div_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_divss ((__v4sf)__A, (__v4sf)__B);
_mm_sqrt_ss (__m128 __A)
return (__m128) __builtin_ia32_sqrtss ((__v4sf)__A);
_mm_rcp_ss (__m128 __A)
return (__m128) __builtin_ia32_rcpss ((__v4sf)__A);
_mm_rsqrt_ss (__m128 __A)
return (__m128) __builtin_ia32_rsqrtss ((__v4sf)__A);
_mm_min_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_minss ((__v4sf)__A, (__v4sf)__B);
_mm_max_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_maxss ((__v4sf)__A, (__v4sf)__B);
_mm_add_ps (__m128 __A, __m128 __B)
return (__m128) ((__v4sf)__A + (__v4sf)__B);
_mm_sub_ps (__m128 __A, __m128 __B)
return (__m128) ((__v4sf)__A - (__v4sf)__B);
_mm_mul_ps (__m128 __A, __m128 __B)
return (__m128) ((__v4sf)__A * (__v4sf)__B);
_mm_div_ps (__m128 __A, __m128 __B)
return (__m128) ((__v4sf)__A / (__v4sf)__B);
_mm_sqrt_ps (__m128 __A)
return (__m128) __builtin_ia32_sqrtps ((__v4sf)__A);
_mm_rcp_ps (__m128 __A)
return (__m128) __builtin_ia32_rcpps ((__v4sf)__A);
_mm_rsqrt_ps (__m128 __A)
return (__m128) __builtin_ia32_rsqrtps ((__v4sf)__A);
_mm_min_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_minps ((__v4sf)__A, (__v4sf)__B);
_mm_max_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_maxps ((__v4sf)__A, (__v4sf)__B);
_mm_and_ps (__m128 __A, __m128 __B)
return __builtin_ia32_andps (__A, __B);
_mm_andnot_ps (__m128 __A, __m128 __B)
return __builtin_ia32_andnps (__A, __B);
_mm_or_ps (__m128 __A, __m128 __B)
return __builtin_ia32_orps (__A, __B);
_mm_xor_ps (__m128 __A, __m128 __B)
return __builtin_ia32_xorps (__A, __B);
_mm_cmpeq_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpeqss ((__v4sf)__A, (__v4sf)__B);
_mm_cmplt_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpltss ((__v4sf)__A, (__v4sf)__B);
_mm_cmple_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpless ((__v4sf)__A, (__v4sf)__B);
_mm_cmpgt_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_movss ((__v4sf) __A,
(__v4sf)
__builtin_ia32_cmpltss ((__v4sf) __B,
(__v4sf)
__A));
_mm_cmpge_ss (__m128 __A, __m128 __B)
(__v4sf)
__builtin_ia32_cmpless ((__v4sf) __B,
(__v4sf)
__A));
_mm_cmpneq_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpneqss ((__v4sf)__A, (__v4sf)__B);
_mm_cmpnlt_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpnltss ((__v4sf)__A, (__v4sf)__B);
_mm_cmpnle_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpnless ((__v4sf)__A, (__v4sf)__B);
_mm_cmpngt_ss (__m128 __A, __m128 __B)
(__v4sf)
__builtin_ia32_cmpnltss ((__v4sf) __B,
(__v4sf)
__A));
_mm_cmpnge_ss (__m128 __A, __m128 __B)
(__v4sf)
__builtin_ia32_cmpnless ((__v4sf) __B,
(__v4sf)
__A));
_mm_cmpord_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpordss ((__v4sf)__A, (__v4sf)__B);
_mm_cmpunord_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpunordss ((__v4sf)__A, (__v4sf)__B);
_mm_cmpeq_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpeqps ((__v4sf)__A, (__v4sf)__B);
_mm_cmplt_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpltps ((__v4sf)__A, (__v4sf)__B);
_mm_cmple_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpleps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpgt_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpgtps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpge_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpgeps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpneq_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpneqps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpnlt_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpnltps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpnle_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpnleps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpngt_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpngtps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpnge_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpngeps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpord_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpordps ((__v4sf)__A, (__v4sf)__B);
_mm_cmpunord_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_cmpunordps ((__v4sf)__A, (__v4sf)__B);
_mm_comieq_ss (__m128 __A, __m128 __B)
return __builtin_ia32_comieq ((__v4sf)__A, (__v4sf)__B);
_mm_comilt_ss (__m128 __A, __m128 __B)
return __builtin_ia32_comilt ((__v4sf)__A, (__v4sf)__B);
_mm_comile_ss (__m128 __A, __m128 __B)
return __builtin_ia32_comile ((__v4sf)__A, (__v4sf)__B);
_mm_comigt_ss (__m128 __A, __m128 __B)
return __builtin_ia32_comigt ((__v4sf)__A, (__v4sf)__B);
_mm_comige_ss (__m128 __A, __m128 __B)
return __builtin_ia32_comige ((__v4sf)__A, (__v4sf)__B);
_mm_comineq_ss (__m128 __A, __m128 __B)
return __builtin_ia32_comineq ((__v4sf)__A, (__v4sf)__B);
_mm_ucomieq_ss (__m128 __A, __m128 __B)
return __builtin_ia32_ucomieq ((__v4sf)__A, (__v4sf)__B);
_mm_ucomilt_ss (__m128 __A, __m128 __B)
return __builtin_ia32_ucomilt ((__v4sf)__A, (__v4sf)__B);
_mm_ucomile_ss (__m128 __A, __m128 __B)
return __builtin_ia32_ucomile ((__v4sf)__A, (__v4sf)__B);
_mm_ucomigt_ss (__m128 __A, __m128 __B)
return __builtin_ia32_ucomigt ((__v4sf)__A, (__v4sf)__B);
_mm_ucomige_ss (__m128 __A, __m128 __B)
return __builtin_ia32_ucomige ((__v4sf)__A, (__v4sf)__B);
_mm_ucomineq_ss (__m128 __A, __m128 __B)
return __builtin_ia32_ucomineq ((__v4sf)__A, (__v4sf)__B);
_mm_cvtss_si32 (__m128 __A)
return __builtin_ia32_cvtss2si ((__v4sf) __A);
_mm_cvt_ss2si (__m128 __A)
return _mm_cvtss_si32 (__A);
_mm_cvtss_si64 (__m128 __A)
return __builtin_ia32_cvtss2si64 ((__v4sf) __A);
_mm_cvtss_si64x (__m128 __A)
_mm_cvtps_pi32 (__m128 __A)
return (__m64) __builtin_ia32_cvtps2pi ((__v4sf) __A);
_mm_cvt_ps2pi (__m128 __A)
return _mm_cvtps_pi32 (__A);
_mm_cvttss_si32 (__m128 __A)
return __builtin_ia32_cvttss2si ((__v4sf) __A);
_mm_cvtt_ss2si (__m128 __A)
return _mm_cvttss_si32 (__A);
_mm_cvttss_si64 (__m128 __A)
return __builtin_ia32_cvttss2si64 ((__v4sf) __A);
_mm_cvttss_si64x (__m128 __A)
_mm_cvttps_pi32 (__m128 __A)
return (__m64) __builtin_ia32_cvttps2pi ((__v4sf) __A);
_mm_cvtt_ps2pi (__m128 __A)
return _mm_cvttps_pi32 (__A);
_mm_cvtsi32_ss (__m128 __A, int __B)
return (__m128) __builtin_ia32_cvtsi2ss ((__v4sf) __A, __B);
_mm_cvt_si2ss (__m128 __A, int __B)
return _mm_cvtsi32_ss (__A, __B);
_mm_cvtsi64_ss (__m128 __A, long long __B)
return (__m128) __builtin_ia32_cvtsi642ss ((__v4sf) __A, __B);
_mm_cvtsi64x_ss (__m128 __A, long long __B)
_mm_cvtpi32_ps (__m128 __A, __m64 __B)
return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B);
_mm_cvt_pi2ps (__m128 __A, __m64 __B)
return _mm_cvtpi32_ps (__A, __B);
_mm_cvtpi16_ps (__m64 __A)
__v4hi __sign;
__v2si __hisi, __losi;
__v4sf __zero, __ra, __rb;
__sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A);
__losi = (__v2si) __builtin_ia32_punpcklwd ((__v4hi)__A, __sign);
__hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, __sign);
__zero = (__v4sf) _mm_setzero_ps ();
__ra = __builtin_ia32_cvtpi2ps (__zero, __losi);
__rb = __builtin_ia32_cvtpi2ps (__ra, __hisi);
return (__m128) __builtin_ia32_movlhps (__ra, __rb);
_mm_cvtpu16_ps (__m64 __A)
__losi = (__v2si) __builtin_ia32_punpcklwd ((__v4hi)__A, (__v4hi)0LL);
__hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, (__v4hi)0LL);
_mm_cvtpi8_ps (__m64 __A)
__v8qi __sign;
__sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A);
__A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, __sign);
return _mm_cvtpi16_ps(__A);
_mm_cvtpu8_ps(__m64 __A)
__A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, (__v8qi)0LL);
return _mm_cvtpu16_ps(__A);
_mm_cvtpi32x2_ps(__m64 __A, __m64 __B)
__v4sf __zero = (__v4sf) _mm_setzero_ps ();
__v4sf __sfa = __builtin_ia32_cvtpi2ps (__zero, (__v2si)__A);
__v4sf __sfb = __builtin_ia32_cvtpi2ps (__sfa, (__v2si)__B);
return (__m128) __builtin_ia32_movlhps (__sfa, __sfb);
_mm_cvtps_pi16(__m128 __A)
__v4sf __hisf = (__v4sf)__A;
__v4sf __losf = __builtin_ia32_movhlps (__hisf, __hisf);
__v2si __hisi = __builtin_ia32_cvtps2pi (__hisf);
__v2si __losi = __builtin_ia32_cvtps2pi (__losf);
return (__m64) __builtin_ia32_packssdw (__hisi, __losi);
_mm_cvtps_pi8(__m128 __A)
__v4hi __tmp = (__v4hi) _mm_cvtps_pi16 (__A);
return (__m64) __builtin_ia32_packsswb (__tmp, (__v4hi)0LL);
# 755 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
_mm_unpackhi_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_unpckhps ((__v4sf)__A, (__v4sf)__B);
_mm_unpacklo_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_unpcklps ((__v4sf)__A, (__v4sf)__B);
_mm_loadh_pi (__m128 __A, __m64 const *__P)
return (__m128) __builtin_ia32_loadhps ((__v4sf)__A, (const __v2sf *)__P);
_mm_storeh_pi (__m64 *__P, __m128 __A)
__builtin_ia32_storehps ((__v2sf *)__P, (__v4sf)__A);
_mm_movehl_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_movhlps ((__v4sf)__A, (__v4sf)__B);
_mm_movelh_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_movlhps ((__v4sf)__A, (__v4sf)__B);
_mm_loadl_pi (__m128 __A, __m64 const *__P)
return (__m128) __builtin_ia32_loadlps ((__v4sf)__A, (const __v2sf *)__P);
_mm_storel_pi (__m64 *__P, __m128 __A)
__builtin_ia32_storelps ((__v2sf *)__P, (__v4sf)__A);
_mm_movemask_ps (__m128 __A)
return __builtin_ia32_movmskps ((__v4sf)__A);
extern __inline unsigned int __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_getcsr (void)
return __builtin_ia32_stmxcsr ();
_MM_GET_EXCEPTION_STATE (void)
return _mm_getcsr() & 0x003f;
_MM_GET_EXCEPTION_MASK (void)
return _mm_getcsr() & 0x1f80;
_MM_GET_ROUNDING_MODE (void)
return _mm_getcsr() & 0x6000;
_MM_GET_FLUSH_ZERO_MODE (void)
return _mm_getcsr() & 0x8000;
_mm_setcsr (unsigned int __I)
__builtin_ia32_ldmxcsr (__I);
_MM_SET_EXCEPTION_STATE(unsigned int __mask)
_mm_setcsr((_mm_getcsr() & ~0x003f) | __mask);
_MM_SET_EXCEPTION_MASK (unsigned int __mask)
_mm_setcsr((_mm_getcsr() & ~0x1f80) | __mask);
_MM_SET_ROUNDING_MODE (unsigned int __mode)
_mm_setcsr((_mm_getcsr() & ~0x6000) | __mode);
_MM_SET_FLUSH_ZERO_MODE (unsigned int __mode)
_mm_setcsr((_mm_getcsr() & ~0x8000) | __mode);
_mm_set_ss (float __F)
return __extension__ (__m128)(__v4sf){ __F, 0.0f, 0.0f, 0.0f };
_mm_set1_ps (float __F)
return __extension__ (__m128)(__v4sf){ __F, __F, __F, __F };
_mm_set_ps1 (float __F)
return _mm_set1_ps (__F);
_mm_load_ss (float const *__P)
return _mm_set_ss (*__P);
_mm_load1_ps (float const *__P)
return _mm_set1_ps (*__P);
_mm_load_ps1 (float const *__P)
return _mm_load1_ps (__P);
_mm_load_ps (float const *__P)
return *(__m128 *)__P;
_mm_loadu_ps (float const *__P)
return *(__m128_u *)__P;
_mm_loadr_ps (float const *__P)
__v4sf __tmp = *(__v4sf *)__P;
return (__m128) __builtin_ia32_shufps (__tmp, __tmp, (((0) << 6) | ((1) << 4) | ((2) << 2) | (3)));
_mm_set_ps (const float __Z, const float __Y, const float __X, const float __W)
return __extension__ (__m128)(__v4sf){ __W, __X, __Y, __Z };
_mm_setr_ps (float __Z, float __Y, float __X, float __W)
return __extension__ (__m128)(__v4sf){ __Z, __Y, __X, __W };
_mm_store_ss (float *__P, __m128 __A)
*__P = ((__v4sf)__A)[0];
extern __inline float __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_cvtss_f32 (__m128 __A)
return ((__v4sf)__A)[0];
_mm_store_ps (float *__P, __m128 __A)
*(__m128 *)__P = __A;
_mm_storeu_ps (float *__P, __m128 __A)
*(__m128_u *)__P = __A;
_mm_store1_ps (float *__P, __m128 __A)
__v4sf __va = (__v4sf)__A;
__v4sf __tmp = __builtin_ia32_shufps (__va, __va, (((0) << 6) | ((0) << 4) | ((0) << 2) | (0)));
_mm_storeu_ps (__P, __tmp);
_mm_store_ps1 (float *__P, __m128 __A)
_mm_store1_ps (__P, __A);
_mm_storer_ps (float *__P, __m128 __A)
__v4sf __tmp = __builtin_ia32_shufps (__va, __va, (((0) << 6) | ((1) << 4) | ((2) << 2) | (3)));
_mm_store_ps (__P, __tmp);
_mm_move_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_movss ((__v4sf)__A, (__v4sf)__B);
# 1060 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
_mm_max_pi16 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pmaxsw ((__v4hi)__A, (__v4hi)__B);
_m_pmaxsw (__m64 __A, __m64 __B)
return _mm_max_pi16 (__A, __B);
_mm_max_pu8 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pmaxub ((__v8qi)__A, (__v8qi)__B);
_m_pmaxub (__m64 __A, __m64 __B)
return _mm_max_pu8 (__A, __B);
_mm_min_pi16 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pminsw ((__v4hi)__A, (__v4hi)__B);
_m_pminsw (__m64 __A, __m64 __B)
return _mm_min_pi16 (__A, __B);
_mm_min_pu8 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pminub ((__v8qi)__A, (__v8qi)__B);
_m_pminub (__m64 __A, __m64 __B)
return _mm_min_pu8 (__A, __B);
_mm_movemask_pi8 (__m64 __A)
return __builtin_ia32_pmovmskb ((__v8qi)__A);
_m_pmovmskb (__m64 __A)
return _mm_movemask_pi8 (__A);
_mm_mulhi_pu16 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pmulhuw ((__v4hi)__A, (__v4hi)__B);
_m_pmulhuw (__m64 __A, __m64 __B)
return _mm_mulhi_pu16 (__A, __B);
# 1162 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
_mm_maskmove_si64 (__m64 __A, __m64 __N, char *__P)
__builtin_ia32_maskmovq ((__v8qi)__A, (__v8qi)__N, __P);
_m_maskmovq (__m64 __A, __m64 __N, char *__P)
_mm_maskmove_si64 (__A, __N, __P);
_mm_avg_pu8 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pavgb ((__v8qi)__A, (__v8qi)__B);
_m_pavgb (__m64 __A, __m64 __B)
return _mm_avg_pu8 (__A, __B);
_mm_avg_pu16 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_pavgw ((__v4hi)__A, (__v4hi)__B);
_m_pavgw (__m64 __A, __m64 __B)
return _mm_avg_pu16 (__A, __B);
_mm_sad_pu8 (__m64 __A, __m64 __B)
return (__m64) __builtin_ia32_psadbw ((__v8qi)__A, (__v8qi)__B);
_m_psadbw (__m64 __A, __m64 __B)
return _mm_sad_pu8 (__A, __B);
_mm_stream_pi (__m64 *__P, __m64 __A)
__builtin_ia32_movntq ((unsigned long long *)__P, (unsigned long long)__A);
_mm_stream_ps (float *__P, __m128 __A)
__builtin_ia32_movntps (__P, (__v4sf)__A);
_mm_sfence (void)
__builtin_ia32_sfence ();
# 1252 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 1 3 4
# 31 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 2 3 4
# 40 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 3 4
typedef double __v2df __attribute__ ((__vector_size__ (16)));
typedef long long __v2di __attribute__ ((__vector_size__ (16)));
typedef unsigned long long __v2du __attribute__ ((__vector_size__ (16)));
typedef int __v4si __attribute__ ((__vector_size__ (16)));
typedef unsigned int __v4su __attribute__ ((__vector_size__ (16)));
typedef short __v8hi __attribute__ ((__vector_size__ (16)));
typedef unsigned short __v8hu __attribute__ ((__vector_size__ (16)));
typedef char __v16qi __attribute__ ((__vector_size__ (16)));
typedef unsigned char __v16qu __attribute__ ((__vector_size__ (16)));
typedef long long __m128i __attribute__ ((__vector_size__ (16), __may_alias__));
typedef double __m128d __attribute__ ((__vector_size__ (16), __may_alias__));
typedef long long __m128i_u __attribute__ ((__vector_size__ (16), __may_alias__, __aligned__ (1)));
typedef double __m128d_u __attribute__ ((__vector_size__ (16), __may_alias__, __aligned__ (1)));
extern __inline __m128d __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_set_sd (double __F)
return __extension__ (__m128d){ __F, 0.0 };
_mm_set1_pd (double __F)
return __extension__ (__m128d){ __F, __F };
_mm_set_pd1 (double __F)
return _mm_set1_pd (__F);
_mm_set_pd (double __W, double __X)
return __extension__ (__m128d){ __X, __W };
_mm_setr_pd (double __W, double __X)
return __extension__ (__m128d){ __W, __X };
_mm_undefined_pd (void)
__m128d __Y = __Y;
return __Y;
_mm_setzero_pd (void)
return __extension__ (__m128d){ 0.0, 0.0 };
_mm_move_sd (__m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_movsd ((__v2df)__A, (__v2df)__B);
_mm_load_pd (double const *__P)
return *(__m128d *)__P;
_mm_loadu_pd (double const *__P)
return *(__m128d_u *)__P;
_mm_load1_pd (double const *__P)
return _mm_set1_pd (*__P);
_mm_load_sd (double const *__P)
return _mm_set_sd (*__P);
_mm_load_pd1 (double const *__P)
return _mm_load1_pd (__P);
_mm_loadr_pd (double const *__P)
__m128d __tmp = _mm_load_pd (__P);
return __builtin_ia32_shufpd (__tmp, __tmp, (((0) << 1) | (1)));
_mm_store_pd (double *__P, __m128d __A)
*(__m128d *)__P = __A;
_mm_storeu_pd (double *__P, __m128d __A)
*(__m128d_u *)__P = __A;
_mm_store_sd (double *__P, __m128d __A)
*__P = ((__v2df)__A)[0];
extern __inline double __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_cvtsd_f64 (__m128d __A)
return ((__v2df)__A)[0];
_mm_storel_pd (double *__P, __m128d __A)
_mm_store_sd (__P, __A);
_mm_storeh_pd (double *__P, __m128d __A)
*__P = ((__v2df)__A)[1];
_mm_store1_pd (double *__P, __m128d __A)
_mm_store_pd (__P, __builtin_ia32_shufpd (__A, __A, (((0) << 1) | (0))));
_mm_store_pd1 (double *__P, __m128d __A)
_mm_store1_pd (__P, __A);
_mm_storer_pd (double *__P, __m128d __A)
_mm_store_pd (__P, __builtin_ia32_shufpd (__A, __A, (((0) << 1) | (1))));
_mm_cvtsi128_si32 (__m128i __A)
return __builtin_ia32_vec_ext_v4si ((__v4si)__A, 0);
_mm_cvtsi128_si64 (__m128i __A)
return ((__v2di)__A)[0];
_mm_cvtsi128_si64x (__m128i __A)
_mm_add_pd (__m128d __A, __m128d __B)
return (__m128d) ((__v2df)__A + (__v2df)__B);
_mm_add_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_addsd ((__v2df)__A, (__v2df)__B);
_mm_sub_pd (__m128d __A, __m128d __B)
return (__m128d) ((__v2df)__A - (__v2df)__B);
_mm_sub_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_subsd ((__v2df)__A, (__v2df)__B);
_mm_mul_pd (__m128d __A, __m128d __B)
return (__m128d) ((__v2df)__A * (__v2df)__B);
_mm_mul_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_mulsd ((__v2df)__A, (__v2df)__B);
_mm_div_pd (__m128d __A, __m128d __B)
return (__m128d) ((__v2df)__A / (__v2df)__B);
_mm_div_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_divsd ((__v2df)__A, (__v2df)__B);
_mm_sqrt_pd (__m128d __A)
return (__m128d)__builtin_ia32_sqrtpd ((__v2df)__A);
_mm_sqrt_sd (__m128d __A, __m128d __B)
__v2df __tmp = __builtin_ia32_movsd ((__v2df)__A, (__v2df)__B);
return (__m128d)__builtin_ia32_sqrtsd ((__v2df)__tmp);
_mm_min_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_minpd ((__v2df)__A, (__v2df)__B);
_mm_min_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_minsd ((__v2df)__A, (__v2df)__B);
_mm_max_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_maxpd ((__v2df)__A, (__v2df)__B);
_mm_max_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_maxsd ((__v2df)__A, (__v2df)__B);
_mm_and_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_andpd ((__v2df)__A, (__v2df)__B);
_mm_andnot_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_andnpd ((__v2df)__A, (__v2df)__B);
_mm_or_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_orpd ((__v2df)__A, (__v2df)__B);
_mm_xor_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_xorpd ((__v2df)__A, (__v2df)__B);
_mm_cmpeq_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpeqpd ((__v2df)__A, (__v2df)__B);
_mm_cmplt_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpltpd ((__v2df)__A, (__v2df)__B);
_mm_cmple_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmplepd ((__v2df)__A, (__v2df)__B);
_mm_cmpgt_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpgtpd ((__v2df)__A, (__v2df)__B);
_mm_cmpge_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpgepd ((__v2df)__A, (__v2df)__B);
_mm_cmpneq_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpneqpd ((__v2df)__A, (__v2df)__B);
_mm_cmpnlt_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpnltpd ((__v2df)__A, (__v2df)__B);
_mm_cmpnle_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpnlepd ((__v2df)__A, (__v2df)__B);
_mm_cmpngt_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpngtpd ((__v2df)__A, (__v2df)__B);
_mm_cmpnge_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpngepd ((__v2df)__A, (__v2df)__B);
_mm_cmpord_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpordpd ((__v2df)__A, (__v2df)__B);
_mm_cmpunord_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpunordpd ((__v2df)__A, (__v2df)__B);
_mm_cmpeq_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpeqsd ((__v2df)__A, (__v2df)__B);
_mm_cmplt_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpltsd ((__v2df)__A, (__v2df)__B);
_mm_cmple_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmplesd ((__v2df)__A, (__v2df)__B);
_mm_cmpgt_sd (__m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_movsd ((__v2df) __A,
(__v2df)
__builtin_ia32_cmpltsd ((__v2df) __B,
(__v2df)
__A));
_mm_cmpge_sd (__m128d __A, __m128d __B)
(__v2df)
__builtin_ia32_cmplesd ((__v2df) __B,
(__v2df)
__A));
_mm_cmpneq_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpneqsd ((__v2df)__A, (__v2df)__B);
_mm_cmpnlt_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpnltsd ((__v2df)__A, (__v2df)__B);
_mm_cmpnle_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpnlesd ((__v2df)__A, (__v2df)__B);
_mm_cmpngt_sd (__m128d __A, __m128d __B)
(__v2df)
__builtin_ia32_cmpnltsd ((__v2df) __B,
(__v2df)
__A));
_mm_cmpnge_sd (__m128d __A, __m128d __B)
(__v2df)
__builtin_ia32_cmpnlesd ((__v2df) __B,
(__v2df)
__A));
_mm_cmpord_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpordsd ((__v2df)__A, (__v2df)__B);
_mm_cmpunord_sd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_cmpunordsd ((__v2df)__A, (__v2df)__B);
_mm_comieq_sd (__m128d __A, __m128d __B)
return __builtin_ia32_comisdeq ((__v2df)__A, (__v2df)__B);
_mm_comilt_sd (__m128d __A, __m128d __B)
return __builtin_ia32_comisdlt ((__v2df)__A, (__v2df)__B);
_mm_comile_sd (__m128d __A, __m128d __B)
return __builtin_ia32_comisdle ((__v2df)__A, (__v2df)__B);
_mm_comigt_sd (__m128d __A, __m128d __B)
return __builtin_ia32_comisdgt ((__v2df)__A, (__v2df)__B);
_mm_comige_sd (__m128d __A, __m128d __B)
return __builtin_ia32_comisdge ((__v2df)__A, (__v2df)__B);
_mm_comineq_sd (__m128d __A, __m128d __B)
return __builtin_ia32_comisdneq ((__v2df)__A, (__v2df)__B);
_mm_ucomieq_sd (__m128d __A, __m128d __B)
return __builtin_ia32_ucomisdeq ((__v2df)__A, (__v2df)__B);
_mm_ucomilt_sd (__m128d __A, __m128d __B)
return __builtin_ia32_ucomisdlt ((__v2df)__A, (__v2df)__B);
_mm_ucomile_sd (__m128d __A, __m128d __B)
return __builtin_ia32_ucomisdle ((__v2df)__A, (__v2df)__B);
_mm_ucomigt_sd (__m128d __A, __m128d __B)
return __builtin_ia32_ucomisdgt ((__v2df)__A, (__v2df)__B);
_mm_ucomige_sd (__m128d __A, __m128d __B)
return __builtin_ia32_ucomisdge ((__v2df)__A, (__v2df)__B);
_mm_ucomineq_sd (__m128d __A, __m128d __B)
return __builtin_ia32_ucomisdneq ((__v2df)__A, (__v2df)__B);
extern __inline __m128i __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_set_epi64x (long long __q1, long long __q0)
return __extension__ (__m128i)(__v2di){ __q0, __q1 };
_mm_set_epi64 (__m64 __q1, __m64 __q0)
return _mm_set_epi64x ((long long)__q1, (long long)__q0);
_mm_set_epi32 (int __q3, int __q2, int __q1, int __q0)
return __extension__ (__m128i)(__v4si){ __q0, __q1, __q2, __q3 };
_mm_set_epi16 (short __q7, short __q6, short __q5, short __q4,
short __q3, short __q2, short __q1, short __q0)
return __extension__ (__m128i)(__v8hi){
__q0, __q1, __q2, __q3, __q4, __q5, __q6, __q7 };
_mm_set_epi8 (char __q15, char __q14, char __q13, char __q12,
char __q11, char __q10, char __q09, char __q08,
char __q07, char __q06, char __q05, char __q04,
char __q03, char __q02, char __q01, char __q00)
return __extension__ (__m128i)(__v16qi){
__q00, __q01, __q02, __q03, __q04, __q05, __q06, __q07,
__q08, __q09, __q10, __q11, __q12, __q13, __q14, __q15
_mm_set1_epi64x (long long __A)
return _mm_set_epi64x (__A, __A);
_mm_set1_epi64 (__m64 __A)
return _mm_set_epi64 (__A, __A);
_mm_set1_epi32 (int __A)
return _mm_set_epi32 (__A, __A, __A, __A);
_mm_set1_epi16 (short __A)
return _mm_set_epi16 (__A, __A, __A, __A, __A, __A, __A, __A);
_mm_set1_epi8 (char __A)
return _mm_set_epi8 (__A, __A, __A, __A, __A, __A, __A, __A,
_mm_setr_epi64 (__m64 __q0, __m64 __q1)
return _mm_set_epi64 (__q1, __q0);
_mm_setr_epi32 (int __q0, int __q1, int __q2, int __q3)
return _mm_set_epi32 (__q3, __q2, __q1, __q0);
_mm_setr_epi16 (short __q0, short __q1, short __q2, short __q3,
short __q4, short __q5, short __q6, short __q7)
return _mm_set_epi16 (__q7, __q6, __q5, __q4, __q3, __q2, __q1, __q0);
_mm_setr_epi8 (char __q00, char __q01, char __q02, char __q03,
char __q04, char __q05, char __q06, char __q07,
char __q08, char __q09, char __q10, char __q11,
char __q12, char __q13, char __q14, char __q15)
return _mm_set_epi8 (__q15, __q14, __q13, __q12, __q11, __q10, __q09, __q08,
__q07, __q06, __q05, __q04, __q03, __q02, __q01, __q00);
_mm_load_si128 (__m128i const *__P)
return *__P;
_mm_loadu_si128 (__m128i_u const *__P)
return *__P;
_mm_loadl_epi64 (__m128i_u const *__P)
return _mm_set_epi64 ((__m64)0LL, *(__m64_u *)__P);
_mm_store_si128 (__m128i *__P, __m128i __B)
*__P = __B;
_mm_storeu_si128 (__m128i_u *__P, __m128i __B)
*__P = __B;
_mm_storel_epi64 (__m128i_u *__P, __m128i __B)
*(__m64_u *)__P = (__m64) ((__v2di)__B)[0];
_mm_movepi64_pi64 (__m128i __B)
return (__m64) ((__v2di)__B)[0];
_mm_movpi64_epi64 (__m64 __A)
return _mm_set_epi64 ((__m64)0LL, __A);
_mm_move_epi64 (__m128i __A)
return (__m128i)__builtin_ia32_movq128 ((__v2di) __A);
_mm_undefined_si128 (void)
__m128i __Y = __Y;
return __Y;
_mm_setzero_si128 (void)
return __extension__ (__m128i)(__v4si){ 0, 0, 0, 0 };
_mm_cvtepi32_pd (__m128i __A)
return (__m128d)__builtin_ia32_cvtdq2pd ((__v4si) __A);
_mm_cvtepi32_ps (__m128i __A)
return (__m128)__builtin_ia32_cvtdq2ps ((__v4si) __A);
_mm_cvtpd_epi32 (__m128d __A)
return (__m128i)__builtin_ia32_cvtpd2dq ((__v2df) __A);
_mm_cvtpd_pi32 (__m128d __A)
return (__m64)__builtin_ia32_cvtpd2pi ((__v2df) __A);
_mm_cvtpd_ps (__m128d __A)
return (__m128)__builtin_ia32_cvtpd2ps ((__v2df) __A);
_mm_cvttpd_epi32 (__m128d __A)
return (__m128i)__builtin_ia32_cvttpd2dq ((__v2df) __A);
_mm_cvttpd_pi32 (__m128d __A)
return (__m64)__builtin_ia32_cvttpd2pi ((__v2df) __A);
_mm_cvtpi32_pd (__m64 __A)
return (__m128d)__builtin_ia32_cvtpi2pd ((__v2si) __A);
_mm_cvtps_epi32 (__m128 __A)
return (__m128i)__builtin_ia32_cvtps2dq ((__v4sf) __A);
_mm_cvttps_epi32 (__m128 __A)
return (__m128i)__builtin_ia32_cvttps2dq ((__v4sf) __A);
_mm_cvtps_pd (__m128 __A)
return (__m128d)__builtin_ia32_cvtps2pd ((__v4sf) __A);
_mm_cvtsd_si32 (__m128d __A)
return __builtin_ia32_cvtsd2si ((__v2df) __A);
_mm_cvtsd_si64 (__m128d __A)
return __builtin_ia32_cvtsd2si64 ((__v2df) __A);
_mm_cvtsd_si64x (__m128d __A)
_mm_cvttsd_si32 (__m128d __A)
return __builtin_ia32_cvttsd2si ((__v2df) __A);
_mm_cvttsd_si64 (__m128d __A)
return __builtin_ia32_cvttsd2si64 ((__v2df) __A);
_mm_cvttsd_si64x (__m128d __A)
_mm_cvtsd_ss (__m128 __A, __m128d __B)
return (__m128)__builtin_ia32_cvtsd2ss ((__v4sf) __A, (__v2df) __B);
_mm_cvtsi32_sd (__m128d __A, int __B)
return (__m128d)__builtin_ia32_cvtsi2sd ((__v2df) __A, __B);
_mm_cvtsi64_sd (__m128d __A, long long __B)
return (__m128d)__builtin_ia32_cvtsi642sd ((__v2df) __A, __B);
_mm_cvtsi64x_sd (__m128d __A, long long __B)
_mm_cvtss_sd (__m128d __A, __m128 __B)
return (__m128d)__builtin_ia32_cvtss2sd ((__v2df) __A, (__v4sf)__B);
# 918 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 3 4
_mm_unpackhi_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_unpckhpd ((__v2df)__A, (__v2df)__B);
_mm_unpacklo_pd (__m128d __A, __m128d __B)
return (__m128d)__builtin_ia32_unpcklpd ((__v2df)__A, (__v2df)__B);
_mm_loadh_pd (__m128d __A, double const *__B)
return (__m128d)__builtin_ia32_loadhpd ((__v2df)__A, __B);
_mm_loadl_pd (__m128d __A, double const *__B)
return (__m128d)__builtin_ia32_loadlpd ((__v2df)__A, __B);
_mm_movemask_pd (__m128d __A)
return __builtin_ia32_movmskpd ((__v2df)__A);
_mm_packs_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_packsswb128 ((__v8hi)__A, (__v8hi)__B);
_mm_packs_epi32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_packssdw128 ((__v4si)__A, (__v4si)__B);
_mm_packus_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_packuswb128 ((__v8hi)__A, (__v8hi)__B);
_mm_unpackhi_epi8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpckhbw128 ((__v16qi)__A, (__v16qi)__B);
_mm_unpackhi_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpckhwd128 ((__v8hi)__A, (__v8hi)__B);
_mm_unpackhi_epi32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpckhdq128 ((__v4si)__A, (__v4si)__B);
_mm_unpackhi_epi64 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpckhqdq128 ((__v2di)__A, (__v2di)__B);
_mm_unpacklo_epi8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpcklbw128 ((__v16qi)__A, (__v16qi)__B);
_mm_unpacklo_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpcklwd128 ((__v8hi)__A, (__v8hi)__B);
_mm_unpacklo_epi32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpckldq128 ((__v4si)__A, (__v4si)__B);
_mm_unpacklo_epi64 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_punpcklqdq128 ((__v2di)__A, (__v2di)__B);
_mm_add_epi8 (__m128i __A, __m128i __B)
return (__m128i) ((__v16qu)__A + (__v16qu)__B);
_mm_add_epi16 (__m128i __A, __m128i __B)
return (__m128i) ((__v8hu)__A + (__v8hu)__B);
_mm_add_epi32 (__m128i __A, __m128i __B)
return (__m128i) ((__v4su)__A + (__v4su)__B);
_mm_add_epi64 (__m128i __A, __m128i __B)
return (__m128i) ((__v2du)__A + (__v2du)__B);
_mm_adds_epi8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_paddsb128 ((__v16qi)__A, (__v16qi)__B);
_mm_adds_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_paddsw128 ((__v8hi)__A, (__v8hi)__B);
_mm_adds_epu8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_paddusb128 ((__v16qi)__A, (__v16qi)__B);
_mm_adds_epu16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_paddusw128 ((__v8hi)__A, (__v8hi)__B);
_mm_sub_epi8 (__m128i __A, __m128i __B)
return (__m128i) ((__v16qu)__A - (__v16qu)__B);
_mm_sub_epi16 (__m128i __A, __m128i __B)
return (__m128i) ((__v8hu)__A - (__v8hu)__B);
_mm_sub_epi32 (__m128i __A, __m128i __B)
return (__m128i) ((__v4su)__A - (__v4su)__B);
_mm_sub_epi64 (__m128i __A, __m128i __B)
return (__m128i) ((__v2du)__A - (__v2du)__B);
_mm_subs_epi8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psubsb128 ((__v16qi)__A, (__v16qi)__B);
_mm_subs_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psubsw128 ((__v8hi)__A, (__v8hi)__B);
_mm_subs_epu8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psubusb128 ((__v16qi)__A, (__v16qi)__B);
_mm_subs_epu16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psubusw128 ((__v8hi)__A, (__v8hi)__B);
_mm_madd_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pmaddwd128 ((__v8hi)__A, (__v8hi)__B);
_mm_mulhi_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pmulhw128 ((__v8hi)__A, (__v8hi)__B);
_mm_mullo_epi16 (__m128i __A, __m128i __B)
return (__m128i) ((__v8hu)__A * (__v8hu)__B);
_mm_mul_su32 (__m64 __A, __m64 __B)
return (__m64)__builtin_ia32_pmuludq ((__v2si)__A, (__v2si)__B);
_mm_mul_epu32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pmuludq128 ((__v4si)__A, (__v4si)__B);
_mm_slli_epi16 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psllwi128 ((__v8hi)__A, __B);
_mm_slli_epi32 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_pslldi128 ((__v4si)__A, __B);
_mm_slli_epi64 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psllqi128 ((__v2di)__A, __B);
_mm_srai_epi16 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psrawi128 ((__v8hi)__A, __B);
_mm_srai_epi32 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psradi128 ((__v4si)__A, __B);
# 1205 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 3 4
_mm_srli_epi16 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psrlwi128 ((__v8hi)__A, __B);
_mm_srli_epi32 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psrldi128 ((__v4si)__A, __B);
_mm_srli_epi64 (__m128i __A, int __B)
return (__m128i)__builtin_ia32_psrlqi128 ((__v2di)__A, __B);
_mm_sll_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psllw128((__v8hi)__A, (__v8hi)__B);
_mm_sll_epi32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pslld128((__v4si)__A, (__v4si)__B);
_mm_sll_epi64 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psllq128((__v2di)__A, (__v2di)__B);
_mm_sra_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psraw128 ((__v8hi)__A, (__v8hi)__B);
_mm_sra_epi32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psrad128 ((__v4si)__A, (__v4si)__B);
_mm_srl_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psrlw128 ((__v8hi)__A, (__v8hi)__B);
_mm_srl_epi32 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psrld128 ((__v4si)__A, (__v4si)__B);
_mm_srl_epi64 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psrlq128 ((__v2di)__A, (__v2di)__B);
_mm_and_si128 (__m128i __A, __m128i __B)
return (__m128i) ((__v2du)__A & (__v2du)__B);
_mm_andnot_si128 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pandn128 ((__v2di)__A, (__v2di)__B);
_mm_or_si128 (__m128i __A, __m128i __B)
return (__m128i) ((__v2du)__A | (__v2du)__B);
_mm_xor_si128 (__m128i __A, __m128i __B)
return (__m128i) ((__v2du)__A ^ (__v2du)__B);
_mm_cmpeq_epi8 (__m128i __A, __m128i __B)
return (__m128i) ((__v16qi)__A == (__v16qi)__B);
_mm_cmpeq_epi16 (__m128i __A, __m128i __B)
return (__m128i) ((__v8hi)__A == (__v8hi)__B);
_mm_cmpeq_epi32 (__m128i __A, __m128i __B)
return (__m128i) ((__v4si)__A == (__v4si)__B);
_mm_cmplt_epi8 (__m128i __A, __m128i __B)
return (__m128i) ((__v16qi)__A < (__v16qi)__B);
_mm_cmplt_epi16 (__m128i __A, __m128i __B)
return (__m128i) ((__v8hi)__A < (__v8hi)__B);
_mm_cmplt_epi32 (__m128i __A, __m128i __B)
return (__m128i) ((__v4si)__A < (__v4si)__B);
_mm_cmpgt_epi8 (__m128i __A, __m128i __B)
return (__m128i) ((__v16qi)__A > (__v16qi)__B);
_mm_cmpgt_epi16 (__m128i __A, __m128i __B)
return (__m128i) ((__v8hi)__A > (__v8hi)__B);
_mm_cmpgt_epi32 (__m128i __A, __m128i __B)
return (__m128i) ((__v4si)__A > (__v4si)__B);
# 1369 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 3 4
_mm_max_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pmaxsw128 ((__v8hi)__A, (__v8hi)__B);
_mm_max_epu8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pmaxub128 ((__v16qi)__A, (__v16qi)__B);
_mm_min_epi16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pminsw128 ((__v8hi)__A, (__v8hi)__B);
_mm_min_epu8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pminub128 ((__v16qi)__A, (__v16qi)__B);
_mm_movemask_epi8 (__m128i __A)
return __builtin_ia32_pmovmskb128 ((__v16qi)__A);
_mm_mulhi_epu16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pmulhuw128 ((__v8hi)__A, (__v8hi)__B);
# 1432 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/emmintrin.h" 3 4
extern __inline void __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_maskmoveu_si128 (__m128i __A, __m128i __B, char *__C)
__builtin_ia32_maskmovdqu ((__v16qi)__A, (__v16qi)__B, __C);
_mm_avg_epu8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pavgb128 ((__v16qi)__A, (__v16qi)__B);
_mm_avg_epu16 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_pavgw128 ((__v8hi)__A, (__v8hi)__B);
_mm_sad_epu8 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_psadbw128 ((__v16qi)__A, (__v16qi)__B);
_mm_stream_si32 (int *__A, int __B)
__builtin_ia32_movnti (__A, __B);
_mm_stream_si64 (long long int *__A, long long int __B)
__builtin_ia32_movnti64 (__A, __B);
_mm_stream_si128 (__m128i *__A, __m128i __B)
__builtin_ia32_movntdq ((__v2di *)__A, (__v2di)__B);
_mm_stream_pd (double *__A, __m128d __B)
__builtin_ia32_movntpd (__A, (__v2df)__B);
_mm_clflush (void const *__A)
__builtin_ia32_clflush (__A);
_mm_lfence (void)
__builtin_ia32_lfence ();
_mm_mfence (void)
__builtin_ia32_mfence ();
_mm_cvtsi32_si128 (int __A)
return _mm_set_epi32 (0, 0, 0, __A);
_mm_cvtsi64_si128 (long long __A)
return _mm_set_epi64x (0, __A);
_mm_cvtsi64x_si128 (long long __A)
_mm_castpd_ps(__m128d __A)
return (__m128) __A;
_mm_castpd_si128(__m128d __A)
return (__m128i) __A;
_mm_castps_pd(__m128 __A)
return (__m128d) __A;
_mm_castps_si128(__m128 __A)
_mm_castsi128_ps(__m128i __A)
_mm_castsi128_pd(__m128i __A)
# 1253 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 2 3 4
# 1264 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xmmintrin.h" 3 4
_mm_pause (void)
__builtin_ia32_pause ();
# 30 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/pmmintrin.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/pmmintrin.h" 3 4
#pragma GCC push_options
#pragma GCC target("sse3")
# 49 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/pmmintrin.h" 3 4
_mm_addsub_ps (__m128 __X, __m128 __Y)
return (__m128) __builtin_ia32_addsubps ((__v4sf)__X, (__v4sf)__Y);
_mm_hadd_ps (__m128 __X, __m128 __Y)
return (__m128) __builtin_ia32_haddps ((__v4sf)__X, (__v4sf)__Y);
_mm_hsub_ps (__m128 __X, __m128 __Y)
return (__m128) __builtin_ia32_hsubps ((__v4sf)__X, (__v4sf)__Y);
_mm_movehdup_ps (__m128 __X)
return (__m128) __builtin_ia32_movshdup ((__v4sf)__X);
_mm_moveldup_ps (__m128 __X)
return (__m128) __builtin_ia32_movsldup ((__v4sf)__X);
_mm_addsub_pd (__m128d __X, __m128d __Y)
return (__m128d) __builtin_ia32_addsubpd ((__v2df)__X, (__v2df)__Y);
_mm_hadd_pd (__m128d __X, __m128d __Y)
return (__m128d) __builtin_ia32_haddpd ((__v2df)__X, (__v2df)__Y);
_mm_hsub_pd (__m128d __X, __m128d __Y)
return (__m128d) __builtin_ia32_hsubpd ((__v2df)__X, (__v2df)__Y);
_mm_loaddup_pd (double const *__P)
_mm_movedup_pd (__m128d __X)
return ((__m128d)__builtin_ia32_shufpd ((__v2df)(__m128d)(__X), (__v2df)(__m128d)(__X), (int)((((0) << 1) | (0)))));
_mm_lddqu_si128 (__m128i const *__P)
return (__m128i) __builtin_ia32_lddqu ((char const *)__P);
_mm_monitor (void const * __P, unsigned int __E, unsigned int __H)
__builtin_ia32_monitor (__P, __E, __H);
_mm_mwait (unsigned int __E, unsigned int __H)
__builtin_ia32_mwait (__E, __H);
#pragma GCC pop_options
# 34 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/tmmintrin.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/tmmintrin.h" 3 4
#pragma GCC target("ssse3")
_mm_hadd_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_phaddw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_hadd_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_phaddd128 ((__v4si)__X, (__v4si)__Y);
_mm_hadds_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_phaddsw128 ((__v8hi)__X, (__v8hi)__Y);
extern __inline __m64 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_hadd_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_phaddw ((__v4hi)__X, (__v4hi)__Y);
_mm_hadd_pi32 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_phaddd ((__v2si)__X, (__v2si)__Y);
_mm_hadds_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_phaddsw ((__v4hi)__X, (__v4hi)__Y);
_mm_hsub_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_phsubw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_hsub_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_phsubd128 ((__v4si)__X, (__v4si)__Y);
_mm_hsubs_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_phsubsw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_hsub_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_phsubw ((__v4hi)__X, (__v4hi)__Y);
_mm_hsub_pi32 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_phsubd ((__v2si)__X, (__v2si)__Y);
_mm_hsubs_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_phsubsw ((__v4hi)__X, (__v4hi)__Y);
_mm_maddubs_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmaddubsw128 ((__v16qi)__X, (__v16qi)__Y);
_mm_maddubs_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_pmaddubsw ((__v8qi)__X, (__v8qi)__Y);
_mm_mulhrs_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmulhrsw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_mulhrs_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_pmulhrsw ((__v4hi)__X, (__v4hi)__Y);
_mm_shuffle_epi8 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pshufb128 ((__v16qi)__X, (__v16qi)__Y);
_mm_shuffle_pi8 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_pshufb ((__v8qi)__X, (__v8qi)__Y);
_mm_sign_epi8 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psignb128 ((__v16qi)__X, (__v16qi)__Y);
_mm_sign_epi16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psignw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_sign_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psignd128 ((__v4si)__X, (__v4si)__Y);
_mm_sign_pi8 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_psignb ((__v8qi)__X, (__v8qi)__Y);
_mm_sign_pi16 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_psignw ((__v4hi)__X, (__v4hi)__Y);
_mm_sign_pi32 (__m64 __X, __m64 __Y)
return (__m64) __builtin_ia32_psignd ((__v2si)__X, (__v2si)__Y);
# 208 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/tmmintrin.h" 3 4
_mm_abs_epi8 (__m128i __X)
return (__m128i) __builtin_ia32_pabsb128 ((__v16qi)__X);
_mm_abs_epi16 (__m128i __X)
return (__m128i) __builtin_ia32_pabsw128 ((__v8hi)__X);
_mm_abs_epi32 (__m128i __X)
return (__m128i) __builtin_ia32_pabsd128 ((__v4si)__X);
_mm_abs_pi8 (__m64 __X)
return (__m64) __builtin_ia32_pabsb ((__v8qi)__X);
_mm_abs_pi16 (__m64 __X)
return (__m64) __builtin_ia32_pabsw ((__v4hi)__X);
_mm_abs_pi32 (__m64 __X)
return (__m64) __builtin_ia32_pabsd ((__v2si)__X);
# 36 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 1 3 4
# 35 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
#pragma GCC target("sse4.1")
# 66 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
extern __inline int __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_testz_si128 (__m128i __M, __m128i __V)
return __builtin_ia32_ptestz128 ((__v2di)__M, (__v2di)__V);
_mm_testc_si128 (__m128i __M, __m128i __V)
return __builtin_ia32_ptestc128 ((__v2di)__M, (__v2di)__V);
_mm_testnzc_si128 (__m128i __M, __m128i __V)
return __builtin_ia32_ptestnzc128 ((__v2di)__M, (__v2di)__V);
# 178 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_blendv_epi8 (__m128i __X, __m128i __Y, __m128i __M)
return (__m128i) __builtin_ia32_pblendvb128 ((__v16qi)__X,
(__v16qi)__Y,
(__v16qi)__M);
# 203 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_blendv_ps (__m128 __X, __m128 __Y, __m128 __M)
return (__m128) __builtin_ia32_blendvps ((__v4sf)__X,
(__v4sf)__Y,
(__v4sf)__M);
# 228 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_blendv_pd (__m128d __X, __m128d __Y, __m128d __M)
return (__m128d) __builtin_ia32_blendvpd ((__v2df)__X,
(__v2df)__Y,
(__v2df)__M);
# 267 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_cmpeq_epi64 (__m128i __X, __m128i __Y)
return (__m128i) ((__v2di)__X == (__v2di)__Y);
_mm_min_epi8 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pminsb128 ((__v16qi)__X, (__v16qi)__Y);
_mm_max_epi8 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmaxsb128 ((__v16qi)__X, (__v16qi)__Y);
_mm_min_epu16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pminuw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_max_epu16 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmaxuw128 ((__v8hi)__X, (__v8hi)__Y);
_mm_min_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pminsd128 ((__v4si)__X, (__v4si)__Y);
_mm_max_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmaxsd128 ((__v4si)__X, (__v4si)__Y);
_mm_min_epu32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pminud128 ((__v4si)__X, (__v4si)__Y);
_mm_max_epu32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmaxud128 ((__v4si)__X, (__v4si)__Y);
_mm_mullo_epi32 (__m128i __X, __m128i __Y)
return (__m128i) ((__v4su)__X * (__v4su)__Y);
_mm_mul_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_pmuldq128 ((__v4si)__X, (__v4si)__Y);
# 473 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_minpos_epu16 (__m128i __X)
return (__m128i) __builtin_ia32_phminposuw128 ((__v8hi)__X);
_mm_cvtepi8_epi32 (__m128i __X)
return (__m128i) __builtin_ia32_pmovsxbd128 ((__v16qi)__X);
_mm_cvtepi16_epi32 (__m128i __X)
return (__m128i) __builtin_ia32_pmovsxwd128 ((__v8hi)__X);
_mm_cvtepi8_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pmovsxbq128 ((__v16qi)__X);
_mm_cvtepi32_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pmovsxdq128 ((__v4si)__X);
_mm_cvtepi16_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pmovsxwq128 ((__v8hi)__X);
_mm_cvtepi8_epi16 (__m128i __X)
return (__m128i) __builtin_ia32_pmovsxbw128 ((__v16qi)__X);
_mm_cvtepu8_epi32 (__m128i __X)
return (__m128i) __builtin_ia32_pmovzxbd128 ((__v16qi)__X);
_mm_cvtepu16_epi32 (__m128i __X)
return (__m128i) __builtin_ia32_pmovzxwd128 ((__v8hi)__X);
_mm_cvtepu8_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pmovzxbq128 ((__v16qi)__X);
_mm_cvtepu32_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pmovzxdq128 ((__v4si)__X);
_mm_cvtepu16_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pmovzxwq128 ((__v8hi)__X);
_mm_cvtepu8_epi16 (__m128i __X)
return (__m128i) __builtin_ia32_pmovzxbw128 ((__v16qi)__X);
_mm_packus_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_packusdw128 ((__v4si)__X, (__v4si)__Y);
# 581 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_stream_load_si128 (__m128i *__X)
return (__m128i) __builtin_ia32_movntdqa ((__v2di *) __X);
#pragma GCC target("sse4.2")
# 795 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 3 4
_mm_cmpgt_epi64 (__m128i __X, __m128i __Y)
return (__m128i) ((__v2di)__X > (__v2di)__Y);
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/popcntintrin.h" 1 3 4
# 28 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/popcntintrin.h" 3 4
#pragma GCC target("popcnt")
_mm_popcnt_u32 (unsigned int __X)
return __builtin_popcount (__X);
extern __inline long long __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_popcnt_u64 (unsigned long long __X)
return __builtin_popcountll (__X);
# 812 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/smmintrin.h" 2 3 4
_mm_crc32_u8 (unsigned int __C, unsigned char __V)
return __builtin_ia32_crc32qi (__C, __V);
_mm_crc32_u16 (unsigned int __C, unsigned short __V)
return __builtin_ia32_crc32hi (__C, __V);
_mm_crc32_u32 (unsigned int __C, unsigned int __V)
return __builtin_ia32_crc32si (__C, __V);
extern __inline unsigned long long __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_crc32_u64 (unsigned long long __C, unsigned long long __V)
return __builtin_ia32_crc32di (__C, __V);
# 38 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/wmmintrin.h" 1 3 4
# 36 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/wmmintrin.h" 3 4
#pragma GCC target("aes,sse2")
_mm_aesdec_si128 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_aesdec128 ((__v2di)__X, (__v2di)__Y);
_mm_aesdeclast_si128 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_aesdeclast128 ((__v2di)__X,
(__v2di)__Y);
_mm_aesenc_si128 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_aesenc128 ((__v2di)__X, (__v2di)__Y);
_mm_aesenclast_si128 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_aesenclast128 ((__v2di)__X, (__v2di)__Y);
_mm_aesimc_si128 (__m128i __X)
return (__m128i) __builtin_ia32_aesimc128 ((__v2di)__X);
# 99 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/wmmintrin.h" 3 4
#pragma GCC target("pclmul,sse2")
# 129 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/wmmintrin.h" 3 4
# 40 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 1 3 4
# 35 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
#pragma GCC target("avx")
typedef double __v4df __attribute__ ((__vector_size__ (32)));
typedef float __v8sf __attribute__ ((__vector_size__ (32)));
typedef long long __v4di __attribute__ ((__vector_size__ (32)));
typedef unsigned long long __v4du __attribute__ ((__vector_size__ (32)));
typedef int __v8si __attribute__ ((__vector_size__ (32)));
typedef unsigned int __v8su __attribute__ ((__vector_size__ (32)));
typedef short __v16hi __attribute__ ((__vector_size__ (32)));
typedef unsigned short __v16hu __attribute__ ((__vector_size__ (32)));
typedef char __v32qi __attribute__ ((__vector_size__ (32)));
typedef unsigned char __v32qu __attribute__ ((__vector_size__ (32)));
typedef float __m256 __attribute__ ((__vector_size__ (32),
__may_alias__));
typedef long long __m256i __attribute__ ((__vector_size__ (32),
__may_alias__));
typedef double __m256d __attribute__ ((__vector_size__ (32),
__may_alias__));
typedef float __m256_u __attribute__ ((__vector_size__ (32),
__may_alias__,
__aligned__ (1)));
typedef long long __m256i_u __attribute__ ((__vector_size__ (32),
__may_alias__,
__aligned__ (1)));
typedef double __m256d_u __attribute__ ((__vector_size__ (32),
__may_alias__,
__aligned__ (1)));
# 139 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
extern __inline __m256d __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm256_add_pd (__m256d __A, __m256d __B)
return (__m256d) ((__v4df)__A + (__v4df)__B);
extern __inline __m256 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm256_add_ps (__m256 __A, __m256 __B)
return (__m256) ((__v8sf)__A + (__v8sf)__B);
_mm256_addsub_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_addsubpd256 ((__v4df)__A, (__v4df)__B);
_mm256_addsub_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_addsubps256 ((__v8sf)__A, (__v8sf)__B);
_mm256_and_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_andpd256 ((__v4df)__A, (__v4df)__B);
_mm256_and_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_andps256 ((__v8sf)__A, (__v8sf)__B);
_mm256_andnot_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_andnpd256 ((__v4df)__A, (__v4df)__B);
_mm256_andnot_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_andnps256 ((__v8sf)__A, (__v8sf)__B);
# 217 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_blendv_pd (__m256d __X, __m256d __Y, __m256d __M)
return (__m256d) __builtin_ia32_blendvpd256 ((__v4df)__X,
(__v4df)__Y,
(__v4df)__M);
_mm256_blendv_ps (__m256 __X, __m256 __Y, __m256 __M)
return (__m256) __builtin_ia32_blendvps256 ((__v8sf)__X,
(__v8sf)__Y,
(__v8sf)__M);
_mm256_div_pd (__m256d __A, __m256d __B)
return (__m256d) ((__v4df)__A / (__v4df)__B);
_mm256_div_ps (__m256 __A, __m256 __B)
return (__m256) ((__v8sf)__A / (__v8sf)__B);
# 262 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_hadd_pd (__m256d __X, __m256d __Y)
return (__m256d) __builtin_ia32_haddpd256 ((__v4df)__X, (__v4df)__Y);
_mm256_hadd_ps (__m256 __X, __m256 __Y)
return (__m256) __builtin_ia32_haddps256 ((__v8sf)__X, (__v8sf)__Y);
_mm256_hsub_pd (__m256d __X, __m256d __Y)
return (__m256d) __builtin_ia32_hsubpd256 ((__v4df)__X, (__v4df)__Y);
_mm256_hsub_ps (__m256 __X, __m256 __Y)
return (__m256) __builtin_ia32_hsubps256 ((__v8sf)__X, (__v8sf)__Y);
_mm256_max_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_maxpd256 ((__v4df)__A, (__v4df)__B);
_mm256_max_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_maxps256 ((__v8sf)__A, (__v8sf)__B);
_mm256_min_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_minpd256 ((__v4df)__A, (__v4df)__B);
_mm256_min_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_minps256 ((__v8sf)__A, (__v8sf)__B);
_mm256_mul_pd (__m256d __A, __m256d __B)
return (__m256d) ((__v4df)__A * (__v4df)__B);
_mm256_mul_ps (__m256 __A, __m256 __B)
return (__m256) ((__v8sf)__A * (__v8sf)__B);
_mm256_or_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_orpd256 ((__v4df)__A, (__v4df)__B);
_mm256_or_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_orps256 ((__v8sf)__A, (__v8sf)__B);
# 358 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_sub_pd (__m256d __A, __m256d __B)
return (__m256d) ((__v4df)__A - (__v4df)__B);
_mm256_sub_ps (__m256 __A, __m256 __B)
return (__m256) ((__v8sf)__A - (__v8sf)__B);
_mm256_xor_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_xorpd256 ((__v4df)__A, (__v4df)__B);
_mm256_xor_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_xorps256 ((__v8sf)__A, (__v8sf)__B);
# 446 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_cvtepi32_pd (__m128i __A)
return (__m256d)__builtin_ia32_cvtdq2pd256 ((__v4si) __A);
_mm256_cvtepi32_ps (__m256i __A)
return (__m256)__builtin_ia32_cvtdq2ps256 ((__v8si) __A);
_mm256_cvtpd_ps (__m256d __A)
return (__m128)__builtin_ia32_cvtpd2ps256 ((__v4df) __A);
extern __inline __m256i __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm256_cvtps_epi32 (__m256 __A)
return (__m256i)__builtin_ia32_cvtps2dq256 ((__v8sf) __A);
_mm256_cvtps_pd (__m128 __A)
return (__m256d)__builtin_ia32_cvtps2pd256 ((__v4sf) __A);
_mm256_cvttpd_epi32 (__m256d __A)
return (__m128i)__builtin_ia32_cvttpd2dq256 ((__v4df) __A);
_mm256_cvtpd_epi32 (__m256d __A)
return (__m128i)__builtin_ia32_cvtpd2dq256 ((__v4df) __A);
_mm256_cvttps_epi32 (__m256 __A)
return (__m256i)__builtin_ia32_cvttps2dq256 ((__v8sf) __A);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm256_cvtsd_f64 (__m256d __A)
return __A[0];
_mm256_cvtss_f32 (__m256 __A)
return __A[0];
# 600 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_zeroall (void)
__builtin_ia32_vzeroall ();
_mm256_zeroupper (void)
__builtin_ia32_vzeroupper ();
_mm_permutevar_pd (__m128d __A, __m128i __C)
return (__m128d) __builtin_ia32_vpermilvarpd ((__v2df)__A,
(__v2di)__C);
_mm256_permutevar_pd (__m256d __A, __m256i __C)
return (__m256d) __builtin_ia32_vpermilvarpd256 ((__v4df)__A,
(__v4di)__C);
_mm_permutevar_ps (__m128 __A, __m128i __C)
return (__m128) __builtin_ia32_vpermilvarps ((__v4sf)__A,
(__v4si)__C);
_mm256_permutevar_ps (__m256 __A, __m256i __C)
return (__m256) __builtin_ia32_vpermilvarps256 ((__v8sf)__A,
(__v8si)__C);
# 719 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm_broadcast_ss (float const *__X)
return (__m128) __builtin_ia32_vbroadcastss (__X);
_mm256_broadcast_sd (double const *__X)
return (__m256d) __builtin_ia32_vbroadcastsd256 (__X);
_mm256_broadcast_ss (float const *__X)
return (__m256) __builtin_ia32_vbroadcastss256 (__X);
_mm256_broadcast_pd (__m128d const *__X)
return (__m256d) __builtin_ia32_vbroadcastf128_pd256 (__X);
_mm256_broadcast_ps (__m128 const *__X)
return (__m256) __builtin_ia32_vbroadcastf128_ps256 (__X);
# 858 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_load_pd (double const *__P)
return *(__m256d *)__P;
_mm256_store_pd (double *__P, __m256d __A)
*(__m256d *)__P = __A;
_mm256_load_ps (float const *__P)
return *(__m256 *)__P;
_mm256_store_ps (float *__P, __m256 __A)
*(__m256 *)__P = __A;
_mm256_loadu_pd (double const *__P)
return *(__m256d_u *)__P;
_mm256_storeu_pd (double *__P, __m256d __A)
*(__m256d_u *)__P = __A;
_mm256_loadu_ps (float const *__P)
return *(__m256_u *)__P;
_mm256_storeu_ps (float *__P, __m256 __A)
*(__m256_u *)__P = __A;
_mm256_load_si256 (__m256i const *__P)
return *__P;
_mm256_store_si256 (__m256i *__P, __m256i __A)
*__P = __A;
_mm256_loadu_si256 (__m256i_u const *__P)
return *__P;
_mm256_storeu_si256 (__m256i_u *__P, __m256i __A)
*__P = __A;
_mm_maskload_pd (double const *__P, __m128i __M)
return (__m128d) __builtin_ia32_maskloadpd ((const __v2df *)__P,
(__v2di)__M);
_mm_maskstore_pd (double *__P, __m128i __M, __m128d __A)
__builtin_ia32_maskstorepd ((__v2df *)__P, (__v2di)__M, (__v2df)__A);
_mm256_maskload_pd (double const *__P, __m256i __M)
return (__m256d) __builtin_ia32_maskloadpd256 ((const __v4df *)__P,
(__v4di)__M);
_mm256_maskstore_pd (double *__P, __m256i __M, __m256d __A)
__builtin_ia32_maskstorepd256 ((__v4df *)__P, (__v4di)__M, (__v4df)__A);
_mm_maskload_ps (float const *__P, __m128i __M)
return (__m128) __builtin_ia32_maskloadps ((const __v4sf *)__P,
(__v4si)__M);
_mm_maskstore_ps (float *__P, __m128i __M, __m128 __A)
__builtin_ia32_maskstoreps ((__v4sf *)__P, (__v4si)__M, (__v4sf)__A);
_mm256_maskload_ps (float const *__P, __m256i __M)
return (__m256) __builtin_ia32_maskloadps256 ((const __v8sf *)__P,
(__v8si)__M);
_mm256_maskstore_ps (float *__P, __m256i __M, __m256 __A)
__builtin_ia32_maskstoreps256 ((__v8sf *)__P, (__v8si)__M, (__v8sf)__A);
_mm256_movehdup_ps (__m256 __X)
return (__m256) __builtin_ia32_movshdup256 ((__v8sf)__X);
_mm256_moveldup_ps (__m256 __X)
return (__m256) __builtin_ia32_movsldup256 ((__v8sf)__X);
_mm256_movedup_pd (__m256d __X)
return (__m256d) __builtin_ia32_movddup256 ((__v4df)__X);
_mm256_lddqu_si256 (__m256i const *__P)
return (__m256i) __builtin_ia32_lddqu256 ((char const *)__P);
_mm256_stream_si256 (__m256i *__A, __m256i __B)
__builtin_ia32_movntdq256 ((__v4di *)__A, (__v4di)__B);
_mm256_stream_pd (double *__A, __m256d __B)
__builtin_ia32_movntpd256 (__A, (__v4df)__B);
_mm256_stream_ps (float *__P, __m256 __A)
__builtin_ia32_movntps256 (__P, (__v8sf)__A);
_mm256_rcp_ps (__m256 __A)
return (__m256) __builtin_ia32_rcpps256 ((__v8sf)__A);
_mm256_rsqrt_ps (__m256 __A)
return (__m256) __builtin_ia32_rsqrtps256 ((__v8sf)__A);
_mm256_sqrt_pd (__m256d __A)
return (__m256d) __builtin_ia32_sqrtpd256 ((__v4df)__A);
_mm256_sqrt_ps (__m256 __A)
return (__m256) __builtin_ia32_sqrtps256 ((__v8sf)__A);
# 1073 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avxintrin.h" 3 4
_mm256_unpackhi_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_unpckhpd256 ((__v4df)__A, (__v4df)__B);
_mm256_unpacklo_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_unpcklpd256 ((__v4df)__A, (__v4df)__B);
_mm256_unpackhi_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_unpckhps256 ((__v8sf)__A, (__v8sf)__B);
_mm256_unpacklo_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_unpcklps256 ((__v8sf)__A, (__v8sf)__B);
_mm_testz_pd (__m128d __M, __m128d __V)
return __builtin_ia32_vtestzpd ((__v2df)__M, (__v2df)__V);
_mm_testc_pd (__m128d __M, __m128d __V)
return __builtin_ia32_vtestcpd ((__v2df)__M, (__v2df)__V);
_mm_testnzc_pd (__m128d __M, __m128d __V)
return __builtin_ia32_vtestnzcpd ((__v2df)__M, (__v2df)__V);
_mm_testz_ps (__m128 __M, __m128 __V)
return __builtin_ia32_vtestzps ((__v4sf)__M, (__v4sf)__V);
_mm_testc_ps (__m128 __M, __m128 __V)
return __builtin_ia32_vtestcps ((__v4sf)__M, (__v4sf)__V);
_mm_testnzc_ps (__m128 __M, __m128 __V)
return __builtin_ia32_vtestnzcps ((__v4sf)__M, (__v4sf)__V);
_mm256_testz_pd (__m256d __M, __m256d __V)
return __builtin_ia32_vtestzpd256 ((__v4df)__M, (__v4df)__V);
_mm256_testc_pd (__m256d __M, __m256d __V)
return __builtin_ia32_vtestcpd256 ((__v4df)__M, (__v4df)__V);
_mm256_testnzc_pd (__m256d __M, __m256d __V)
return __builtin_ia32_vtestnzcpd256 ((__v4df)__M, (__v4df)__V);
_mm256_testz_ps (__m256 __M, __m256 __V)
return __builtin_ia32_vtestzps256 ((__v8sf)__M, (__v8sf)__V);
_mm256_testc_ps (__m256 __M, __m256 __V)
return __builtin_ia32_vtestcps256 ((__v8sf)__M, (__v8sf)__V);
_mm256_testnzc_ps (__m256 __M, __m256 __V)
return __builtin_ia32_vtestnzcps256 ((__v8sf)__M, (__v8sf)__V);
_mm256_testz_si256 (__m256i __M, __m256i __V)
return __builtin_ia32_ptestz256 ((__v4di)__M, (__v4di)__V);
_mm256_testc_si256 (__m256i __M, __m256i __V)
return __builtin_ia32_ptestc256 ((__v4di)__M, (__v4di)__V);
_mm256_testnzc_si256 (__m256i __M, __m256i __V)
return __builtin_ia32_ptestnzc256 ((__v4di)__M, (__v4di)__V);
_mm256_movemask_pd (__m256d __A)
return __builtin_ia32_movmskpd256 ((__v4df)__A);
_mm256_movemask_ps (__m256 __A)
return __builtin_ia32_movmskps256 ((__v8sf)__A);
_mm256_undefined_pd (void)
__m256d __Y = __Y;
return __Y;
_mm256_undefined_ps (void)
__m256 __Y = __Y;
return __Y;
_mm256_undefined_si256 (void)
__m256i __Y = __Y;
return __Y;
_mm256_setzero_pd (void)
return __extension__ (__m256d){ 0.0, 0.0, 0.0, 0.0 };
_mm256_setzero_ps (void)
return __extension__ (__m256){ 0.0, 0.0, 0.0, 0.0,
_mm256_setzero_si256 (void)
return __extension__ (__m256i)(__v4di){ 0, 0, 0, 0 };
_mm256_set_pd (double __A, double __B, double __C, double __D)
return __extension__ (__m256d){ __D, __C, __B, __A };
_mm256_set_ps (float __A, float __B, float __C, float __D,
float __E, float __F, float __G, float __H)
return __extension__ (__m256){ __H, __G, __F, __E,
_mm256_set_epi32 (int __A, int __B, int __C, int __D,
int __E, int __F, int __G, int __H)
return __extension__ (__m256i)(__v8si){ __H, __G, __F, __E,
_mm256_set_epi16 (short __q15, short __q14, short __q13, short __q12,
short __q11, short __q10, short __q09, short __q08,
short __q07, short __q06, short __q05, short __q04,
short __q03, short __q02, short __q01, short __q00)
return __extension__ (__m256i)(__v16hi){
_mm256_set_epi8 (char __q31, char __q30, char __q29, char __q28,
char __q27, char __q26, char __q25, char __q24,
char __q23, char __q22, char __q21, char __q20,
char __q19, char __q18, char __q17, char __q16,
return __extension__ (__m256i)(__v32qi){
__q08, __q09, __q10, __q11, __q12, __q13, __q14, __q15,
__q16, __q17, __q18, __q19, __q20, __q21, __q22, __q23,
__q24, __q25, __q26, __q27, __q28, __q29, __q30, __q31
_mm256_set_epi64x (long long __A, long long __B, long long __C,
long long __D)
return __extension__ (__m256i)(__v4di){ __D, __C, __B, __A };
_mm256_set1_pd (double __A)
return __extension__ (__m256d){ __A, __A, __A, __A };
_mm256_set1_ps (float __A)
return __extension__ (__m256){ __A, __A, __A, __A,
_mm256_set1_epi32 (int __A)
return __extension__ (__m256i)(__v8si){ __A, __A, __A, __A,
_mm256_set1_epi16 (short __A)
return _mm256_set_epi16 (__A, __A, __A, __A, __A, __A, __A, __A,
_mm256_set1_epi8 (char __A)
return _mm256_set_epi8 (__A, __A, __A, __A, __A, __A, __A, __A,
_mm256_set1_epi64x (long long __A)
return __extension__ (__m256i)(__v4di){ __A, __A, __A, __A };
_mm256_setr_pd (double __A, double __B, double __C, double __D)
return _mm256_set_pd (__D, __C, __B, __A);
_mm256_setr_ps (float __A, float __B, float __C, float __D,
return _mm256_set_ps (__H, __G, __F, __E, __D, __C, __B, __A);
_mm256_setr_epi32 (int __A, int __B, int __C, int __D,
return _mm256_set_epi32 (__H, __G, __F, __E, __D, __C, __B, __A);
_mm256_setr_epi16 (short __q15, short __q14, short __q13, short __q12,
return _mm256_set_epi16 (__q00, __q01, __q02, __q03,
__q12, __q13, __q14, __q15);
_mm256_setr_epi8 (char __q31, char __q30, char __q29, char __q28,
return _mm256_set_epi8 (__q00, __q01, __q02, __q03,
__q28, __q29, __q30, __q31);
_mm256_setr_epi64x (long long __A, long long __B, long long __C,
long long __D)
return _mm256_set_epi64x (__D, __C, __B, __A);
_mm256_castpd_ps (__m256d __A)
return (__m256) __A;
_mm256_castpd_si256 (__m256d __A)
return (__m256i) __A;
_mm256_castps_pd (__m256 __A)
return (__m256d) __A;
_mm256_castps_si256(__m256 __A)
_mm256_castsi256_ps (__m256i __A)
_mm256_castsi256_pd (__m256i __A)
_mm256_castpd256_pd128 (__m256d __A)
return (__m128d) __builtin_ia32_pd_pd256 ((__v4df)__A);
extern __inline __m128 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm256_castps256_ps128 (__m256 __A)
return (__m128) __builtin_ia32_ps_ps256 ((__v8sf)__A);
_mm256_castsi256_si128 (__m256i __A)
return (__m128i) __builtin_ia32_si_si256 ((__v8si)__A);
_mm256_castpd128_pd256 (__m128d __A)
return (__m256d) __builtin_ia32_pd256_pd ((__v2df)__A);
_mm256_castps128_ps256 (__m128 __A)
return (__m256) __builtin_ia32_ps256_ps ((__v4sf)__A);
_mm256_castsi128_si256 (__m128i __A)
return (__m256i) __builtin_ia32_si256_si ((__v4si)__A);
_mm256_set_m128 ( __m128 __H, __m128 __L)
return ((__m256) __builtin_ia32_vinsertf128_ps256 ((__v8sf)(__m256)(_mm256_castps128_ps256 (__L)), (__v4sf)(__m128)(__H), (int)(1)));
_mm256_set_m128d (__m128d __H, __m128d __L)
return ((__m256d) __builtin_ia32_vinsertf128_pd256 ((__v4df)(__m256d)(_mm256_castpd128_pd256 (__L)), (__v2df)(__m128d)(__H), (int)(1)));
_mm256_set_m128i (__m128i __H, __m128i __L)
return ((__m256i) __builtin_ia32_vinsertf128_si256 ((__v8si)(__m256i)(_mm256_castsi128_si256 (__L)), (__v4si)(__m128i)(__H), (int)(1)));
_mm256_setr_m128 (__m128 __L, __m128 __H)
return _mm256_set_m128 (__H, __L);
_mm256_setr_m128d (__m128d __L, __m128d __H)
return _mm256_set_m128d (__H, __L);
_mm256_setr_m128i (__m128i __L, __m128i __H)
return _mm256_set_m128i (__H, __L);
# 42 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
#pragma GCC target("avx2")
# 54 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_abs_epi8 (__m256i __A)
return (__m256i)__builtin_ia32_pabsb256 ((__v32qi)__A);
_mm256_abs_epi16 (__m256i __A)
return (__m256i)__builtin_ia32_pabsw256 ((__v16hi)__A);
_mm256_abs_epi32 (__m256i __A)
return (__m256i)__builtin_ia32_pabsd256 ((__v8si)__A);
_mm256_packs_epi32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_packssdw256 ((__v8si)__A, (__v8si)__B);
_mm256_packs_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_packsswb256 ((__v16hi)__A, (__v16hi)__B);
_mm256_packus_epi32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_packusdw256 ((__v8si)__A, (__v8si)__B);
_mm256_packus_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_packuswb256 ((__v16hi)__A, (__v16hi)__B);
_mm256_add_epi8 (__m256i __A, __m256i __B)
return (__m256i) ((__v32qu)__A + (__v32qu)__B);
_mm256_add_epi16 (__m256i __A, __m256i __B)
return (__m256i) ((__v16hu)__A + (__v16hu)__B);
_mm256_add_epi32 (__m256i __A, __m256i __B)
return (__m256i) ((__v8su)__A + (__v8su)__B);
_mm256_add_epi64 (__m256i __A, __m256i __B)
return (__m256i) ((__v4du)__A + (__v4du)__B);
_mm256_adds_epi8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_paddsb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_adds_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_paddsw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_adds_epu8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_paddusb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_adds_epu16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_paddusw256 ((__v16hi)__A, (__v16hi)__B);
# 177 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_and_si256 (__m256i __A, __m256i __B)
return (__m256i) ((__v4du)__A & (__v4du)__B);
_mm256_andnot_si256 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_andnotsi256 ((__v4di)__A, (__v4di)__B);
_mm256_avg_epu8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pavgb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_avg_epu16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pavgw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_blendv_epi8 (__m256i __X, __m256i __Y, __m256i __M)
return (__m256i) __builtin_ia32_pblendvb256 ((__v32qi)__X,
(__v32qi)__Y,
(__v32qi)__M);
# 229 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_cmpeq_epi8 (__m256i __A, __m256i __B)
return (__m256i) ((__v32qi)__A == (__v32qi)__B);
_mm256_cmpeq_epi16 (__m256i __A, __m256i __B)
return (__m256i) ((__v16hi)__A == (__v16hi)__B);
_mm256_cmpeq_epi32 (__m256i __A, __m256i __B)
return (__m256i) ((__v8si)__A == (__v8si)__B);
_mm256_cmpeq_epi64 (__m256i __A, __m256i __B)
return (__m256i) ((__v4di)__A == (__v4di)__B);
_mm256_cmpgt_epi8 (__m256i __A, __m256i __B)
return (__m256i) ((__v32qi)__A > (__v32qi)__B);
_mm256_cmpgt_epi16 (__m256i __A, __m256i __B)
return (__m256i) ((__v16hi)__A > (__v16hi)__B);
_mm256_cmpgt_epi32 (__m256i __A, __m256i __B)
return (__m256i) ((__v8si)__A > (__v8si)__B);
_mm256_cmpgt_epi64 (__m256i __A, __m256i __B)
return (__m256i) ((__v4di)__A > (__v4di)__B);
_mm256_hadd_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_phaddw256 ((__v16hi)__X,
(__v16hi)__Y);
_mm256_hadd_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_phaddd256 ((__v8si)__X, (__v8si)__Y);
_mm256_hadds_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_phaddsw256 ((__v16hi)__X,
(__v16hi)__Y);
_mm256_hsub_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_phsubw256 ((__v16hi)__X,
(__v16hi)__Y);
_mm256_hsub_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_phsubd256 ((__v8si)__X, (__v8si)__Y);
_mm256_hsubs_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_phsubsw256 ((__v16hi)__X,
(__v16hi)__Y);
_mm256_maddubs_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_pmaddubsw256 ((__v32qi)__X,
(__v32qi)__Y);
_mm256_madd_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaddwd256 ((__v16hi)__A,
(__v16hi)__B);
_mm256_max_epi8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaxsb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_max_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaxsw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_max_epi32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaxsd256 ((__v8si)__A, (__v8si)__B);
_mm256_max_epu8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaxub256 ((__v32qi)__A, (__v32qi)__B);
_mm256_max_epu16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaxuw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_max_epu32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmaxud256 ((__v8si)__A, (__v8si)__B);
_mm256_min_epi8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pminsb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_min_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pminsw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_min_epi32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pminsd256 ((__v8si)__A, (__v8si)__B);
_mm256_min_epu8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pminub256 ((__v32qi)__A, (__v32qi)__B);
_mm256_min_epu16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pminuw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_min_epu32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pminud256 ((__v8si)__A, (__v8si)__B);
extern __inline int
_mm256_movemask_epi8 (__m256i __A)
return __builtin_ia32_pmovmskb256 ((__v32qi)__A);
_mm256_cvtepi8_epi16 (__m128i __X)
return (__m256i) __builtin_ia32_pmovsxbw256 ((__v16qi)__X);
_mm256_cvtepi8_epi32 (__m128i __X)
return (__m256i) __builtin_ia32_pmovsxbd256 ((__v16qi)__X);
_mm256_cvtepi8_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pmovsxbq256 ((__v16qi)__X);
_mm256_cvtepi16_epi32 (__m128i __X)
return (__m256i) __builtin_ia32_pmovsxwd256 ((__v8hi)__X);
_mm256_cvtepi16_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pmovsxwq256 ((__v8hi)__X);
_mm256_cvtepi32_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pmovsxdq256 ((__v4si)__X);
_mm256_cvtepu8_epi16 (__m128i __X)
return (__m256i) __builtin_ia32_pmovzxbw256 ((__v16qi)__X);
_mm256_cvtepu8_epi32 (__m128i __X)
return (__m256i) __builtin_ia32_pmovzxbd256 ((__v16qi)__X);
_mm256_cvtepu8_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pmovzxbq256 ((__v16qi)__X);
_mm256_cvtepu16_epi32 (__m128i __X)
return (__m256i) __builtin_ia32_pmovzxwd256 ((__v8hi)__X);
_mm256_cvtepu16_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pmovzxwq256 ((__v8hi)__X);
_mm256_cvtepu32_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pmovzxdq256 ((__v4si)__X);
_mm256_mul_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_pmuldq256 ((__v8si)__X, (__v8si)__Y);
_mm256_mulhrs_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_pmulhrsw256 ((__v16hi)__X,
(__v16hi)__Y);
_mm256_mulhi_epu16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmulhuw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_mulhi_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmulhw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_mullo_epi16 (__m256i __A, __m256i __B)
return (__m256i) ((__v16hu)__A * (__v16hu)__B);
_mm256_mullo_epi32 (__m256i __A, __m256i __B)
return (__m256i) ((__v8su)__A * (__v8su)__B);
_mm256_mul_epu32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_pmuludq256 ((__v8si)__A, (__v8si)__B);
_mm256_or_si256 (__m256i __A, __m256i __B)
return (__m256i) ((__v4du)__A | (__v4du)__B);
_mm256_sad_epu8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_psadbw256 ((__v32qi)__A, (__v32qi)__B);
_mm256_shuffle_epi8 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_pshufb256 ((__v32qi)__X,
(__v32qi)__Y);
# 624 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_sign_epi8 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psignb256 ((__v32qi)__X, (__v32qi)__Y);
_mm256_sign_epi16 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psignw256 ((__v16hi)__X, (__v16hi)__Y);
_mm256_sign_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psignd256 ((__v8si)__X, (__v8si)__Y);
# 666 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_slli_epi16 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psllwi256 ((__v16hi)__A, __B);
_mm256_sll_epi16 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psllw256((__v16hi)__A, (__v8hi)__B);
_mm256_slli_epi32 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_pslldi256 ((__v8si)__A, __B);
_mm256_sll_epi32 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_pslld256((__v8si)__A, (__v4si)__B);
_mm256_slli_epi64 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psllqi256 ((__v4di)__A, __B);
_mm256_sll_epi64 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psllq256((__v4di)__A, (__v2di)__B);
_mm256_srai_epi16 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psrawi256 ((__v16hi)__A, __B);
_mm256_sra_epi16 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psraw256 ((__v16hi)__A, (__v8hi)__B);
_mm256_srai_epi32 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psradi256 ((__v8si)__A, __B);
_mm256_sra_epi32 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psrad256 ((__v8si)__A, (__v4si)__B);
# 757 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_srli_epi16 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psrlwi256 ((__v16hi)__A, __B);
_mm256_srl_epi16 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psrlw256((__v16hi)__A, (__v8hi)__B);
_mm256_srli_epi32 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psrldi256 ((__v8si)__A, __B);
_mm256_srl_epi32 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psrld256((__v8si)__A, (__v4si)__B);
_mm256_srli_epi64 (__m256i __A, int __B)
return (__m256i)__builtin_ia32_psrlqi256 ((__v4di)__A, __B);
_mm256_srl_epi64 (__m256i __A, __m128i __B)
return (__m256i)__builtin_ia32_psrlq256((__v4di)__A, (__v2di)__B);
_mm256_sub_epi8 (__m256i __A, __m256i __B)
return (__m256i) ((__v32qu)__A - (__v32qu)__B);
_mm256_sub_epi16 (__m256i __A, __m256i __B)
return (__m256i) ((__v16hu)__A - (__v16hu)__B);
_mm256_sub_epi32 (__m256i __A, __m256i __B)
return (__m256i) ((__v8su)__A - (__v8su)__B);
_mm256_sub_epi64 (__m256i __A, __m256i __B)
return (__m256i) ((__v4du)__A - (__v4du)__B);
_mm256_subs_epi8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_psubsb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_subs_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_psubsw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_subs_epu8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_psubusb256 ((__v32qi)__A, (__v32qi)__B);
_mm256_subs_epu16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_psubusw256 ((__v16hi)__A, (__v16hi)__B);
_mm256_unpackhi_epi8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpckhbw256 ((__v32qi)__A, (__v32qi)__B);
_mm256_unpackhi_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpckhwd256 ((__v16hi)__A, (__v16hi)__B);
_mm256_unpackhi_epi32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpckhdq256 ((__v8si)__A, (__v8si)__B);
_mm256_unpackhi_epi64 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpckhqdq256 ((__v4di)__A, (__v4di)__B);
_mm256_unpacklo_epi8 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpcklbw256 ((__v32qi)__A, (__v32qi)__B);
_mm256_unpacklo_epi16 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpcklwd256 ((__v16hi)__A, (__v16hi)__B);
_mm256_unpacklo_epi32 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpckldq256 ((__v8si)__A, (__v8si)__B);
_mm256_unpacklo_epi64 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_punpcklqdq256 ((__v4di)__A, (__v4di)__B);
_mm256_xor_si256 (__m256i __A, __m256i __B)
return (__m256i) ((__v4du)__A ^ (__v4du)__B);
_mm256_stream_load_si256 (__m256i const *__X)
return (__m256i) __builtin_ia32_movntdqa256 ((__v4di *) __X);
_mm_broadcastss_ps (__m128 __X)
return (__m128) __builtin_ia32_vbroadcastss_ps ((__v4sf)__X);
_mm256_broadcastss_ps (__m128 __X)
return (__m256) __builtin_ia32_vbroadcastss_ps256 ((__v4sf)__X);
_mm256_broadcastsd_pd (__m128d __X)
return (__m256d) __builtin_ia32_vbroadcastsd_pd256 ((__v2df)__X);
_mm256_broadcastsi128_si256 (__m128i __X)
return (__m256i) __builtin_ia32_vbroadcastsi256 ((__v2di)__X);
# 983 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_broadcastb_epi8 (__m128i __X)
return (__m256i) __builtin_ia32_pbroadcastb256 ((__v16qi)__X);
_mm256_broadcastw_epi16 (__m128i __X)
return (__m256i) __builtin_ia32_pbroadcastw256 ((__v8hi)__X);
_mm256_broadcastd_epi32 (__m128i __X)
return (__m256i) __builtin_ia32_pbroadcastd256 ((__v4si)__X);
_mm256_broadcastq_epi64 (__m128i __X)
return (__m256i) __builtin_ia32_pbroadcastq256 ((__v2di)__X);
_mm_broadcastb_epi8 (__m128i __X)
return (__m128i) __builtin_ia32_pbroadcastb128 ((__v16qi)__X);
_mm_broadcastw_epi16 (__m128i __X)
return (__m128i) __builtin_ia32_pbroadcastw128 ((__v8hi)__X);
_mm_broadcastd_epi32 (__m128i __X)
return (__m128i) __builtin_ia32_pbroadcastd128 ((__v4si)__X);
_mm_broadcastq_epi64 (__m128i __X)
return (__m128i) __builtin_ia32_pbroadcastq128 ((__v2di)__X);
_mm256_permutevar8x32_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_permvarsi256 ((__v8si)__X, (__v8si)__Y);
# 1058 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_permutevar8x32_ps (__m256 __X, __m256i __Y)
return (__m256) __builtin_ia32_permvarsf256 ((__v8sf)__X, (__v8si)__Y);
# 1116 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
_mm256_maskload_epi32 (int const *__X, __m256i __M )
return (__m256i) __builtin_ia32_maskloadd256 ((const __v8si *)__X,
(__v8si)__M);
_mm256_maskload_epi64 (long long const *__X, __m256i __M )
return (__m256i) __builtin_ia32_maskloadq256 ((const __v4di *)__X,
(__v4di)__M);
_mm_maskload_epi32 (int const *__X, __m128i __M )
return (__m128i) __builtin_ia32_maskloadd ((const __v4si *)__X,
(__v4si)__M);
_mm_maskload_epi64 (long long const *__X, __m128i __M )
return (__m128i) __builtin_ia32_maskloadq ((const __v2di *)__X,
(__v2di)__M);
_mm256_maskstore_epi32 (int *__X, __m256i __M, __m256i __Y )
__builtin_ia32_maskstored256 ((__v8si *)__X, (__v8si)__M, (__v8si)__Y);
_mm256_maskstore_epi64 (long long *__X, __m256i __M, __m256i __Y )
__builtin_ia32_maskstoreq256 ((__v4di *)__X, (__v4di)__M, (__v4di)__Y);
_mm_maskstore_epi32 (int *__X, __m128i __M, __m128i __Y )
__builtin_ia32_maskstored ((__v4si *)__X, (__v4si)__M, (__v4si)__Y);
_mm_maskstore_epi64 (long long *__X, __m128i __M, __m128i __Y )
__builtin_ia32_maskstoreq (( __v2di *)__X, (__v2di)__M, (__v2di)__Y);
_mm256_sllv_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psllv8si ((__v8si)__X, (__v8si)__Y);
_mm_sllv_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psllv4si ((__v4si)__X, (__v4si)__Y);
_mm256_sllv_epi64 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psllv4di ((__v4di)__X, (__v4di)__Y);
_mm_sllv_epi64 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psllv2di ((__v2di)__X, (__v2di)__Y);
_mm256_srav_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psrav8si ((__v8si)__X, (__v8si)__Y);
_mm_srav_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psrav4si ((__v4si)__X, (__v4si)__Y);
_mm256_srlv_epi32 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psrlv8si ((__v8si)__X, (__v8si)__Y);
_mm_srlv_epi32 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psrlv4si ((__v4si)__X, (__v4si)__Y);
_mm256_srlv_epi64 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psrlv4di ((__v4di)__X, (__v4di)__Y);
_mm_srlv_epi64 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psrlv2di ((__v2di)__X, (__v2di)__Y);
# 1905 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx2intrin.h" 3 4
# 44 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
#pragma GCC target("avx512f")
typedef double __v8df __attribute__ ((__vector_size__ (64)));
typedef float __v16sf __attribute__ ((__vector_size__ (64)));
typedef long long __v8di __attribute__ ((__vector_size__ (64)));
typedef unsigned long long __v8du __attribute__ ((__vector_size__ (64)));
typedef int __v16si __attribute__ ((__vector_size__ (64)));
typedef unsigned int __v16su __attribute__ ((__vector_size__ (64)));
typedef short __v32hi __attribute__ ((__vector_size__ (64)));
typedef unsigned short __v32hu __attribute__ ((__vector_size__ (64)));
typedef char __v64qi __attribute__ ((__vector_size__ (64)));
typedef unsigned char __v64qu __attribute__ ((__vector_size__ (64)));
typedef float __m512 __attribute__ ((__vector_size__ (64), __may_alias__));
typedef long long __m512i __attribute__ ((__vector_size__ (64), __may_alias__));
typedef double __m512d __attribute__ ((__vector_size__ (64), __may_alias__));
typedef float __m512_u __attribute__ ((__vector_size__ (64), __may_alias__, __aligned__ (1)));
typedef long long __m512i_u __attribute__ ((__vector_size__ (64), __may_alias__, __aligned__ (1)));
typedef double __m512d_u __attribute__ ((__vector_size__ (64), __may_alias__, __aligned__ (1)));
typedef unsigned char __mmask8;
typedef unsigned short __mmask16;
extern __inline __mmask16
_mm512_int2mask (int __M)
return (__mmask16) __M;
extern __inline int
_mm512_mask2int (__mmask16 __M)
return (int) __M;
extern __inline __m512i
_mm512_set_epi64 (long long __A, long long __B, long long __C,
long long __D, long long __E, long long __F,
long long __G, long long __H)
return __extension__ (__m512i) (__v8di)
{ __H, __G, __F, __E, __D, __C, __B, __A };
_mm512_set_epi32 (int __A, int __B, int __C, int __D,
int __E, int __F, int __G, int __H,
int __I, int __J, int __K, int __L,
int __M, int __N, int __O, int __P)
return __extension__ (__m512i)(__v16si)
{ __P, __O, __N, __M, __L, __K, __J, __I,
extern __inline __m512d
_mm512_set_pd (double __A, double __B, double __C, double __D,
double __E, double __F, double __G, double __H)
return __extension__ (__m512d)
_mm512_set_ps (float __A, float __B, float __C, float __D,
float __E, float __F, float __G, float __H,
float __I, float __J, float __K, float __L,
float __M, float __N, float __O, float __P)
return __extension__ (__m512)
# 134 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_undefined_ps (void)
__m512 __Y = __Y;
return __Y;
_mm512_undefined_pd (void)
__m512d __Y = __Y;
return __Y;
_mm512_undefined_epi32 (void)
__m512i __Y = __Y;
return __Y;
_mm512_set1_epi8 (char __A)
return __extension__ (__m512i)(__v64qi)
{ __A, __A, __A, __A, __A, __A, __A, __A,
__A, __A, __A, __A, __A, __A, __A, __A };
_mm512_set1_epi16 (short __A)
return __extension__ (__m512i)(__v32hi)
_mm512_set1_pd (double __A)
return (__m512d) __builtin_ia32_broadcastsd512 (__extension__
(__v2df) { __A, },
(__v8df)
_mm512_undefined_pd (),
(__mmask8) -1);
_mm512_set1_ps (float __A)
return (__m512) __builtin_ia32_broadcastss512 (__extension__
(__v4sf) { __A, },
(__v16sf)
_mm512_undefined_ps (),
(__mmask16) -1);
_mm512_set4_epi32 (int __A, int __B, int __C, int __D)
{ __D, __C, __B, __A, __D, __C, __B, __A,
__D, __C, __B, __A, __D, __C, __B, __A };
_mm512_set4_epi64 (long long __A, long long __B, long long __C,
long long __D)
{ __D, __C, __B, __A, __D, __C, __B, __A };
_mm512_set4_pd (double __A, double __B, double __C, double __D)
_mm512_set4_ps (float __A, float __B, float __C, float __D)
# 258 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_setzero_ps (void)
return __extension__ (__m512){ 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 };
_mm512_setzero_pd (void)
return __extension__ (__m512d) { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 };
_mm512_setzero_epi32 (void)
return __extension__ (__m512i)(__v8di){ 0, 0, 0, 0, 0, 0, 0, 0 };
_mm512_setzero_si512 (void)
_mm512_mask_mov_pd (__m512d __W, __mmask8 __U, __m512d __A)
return (__m512d) __builtin_ia32_movapd512_mask ((__v8df) __A,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_mov_pd (__mmask8 __U, __m512d __A)
(__v8df)
_mm512_setzero_pd (),
(__mmask8) __U);
_mm512_mask_mov_ps (__m512 __W, __mmask16 __U, __m512 __A)
return (__m512) __builtin_ia32_movaps512_mask ((__v16sf) __A,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_mov_ps (__mmask16 __U, __m512 __A)
(__v16sf)
_mm512_setzero_ps (),
(__mmask16) __U);
_mm512_load_pd (void const *__P)
return *(__m512d *) __P;
_mm512_mask_load_pd (__m512d __W, __mmask8 __U, void const *__P)
return (__m512d) __builtin_ia32_loadapd512_mask ((const __v8df *) __P,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_load_pd (__mmask8 __U, void const *__P)
(__v8df)
(__mmask8) __U);
_mm512_store_pd (void *__P, __m512d __A)
*(__m512d *) __P = __A;
_mm512_mask_store_pd (void *__P, __mmask8 __U, __m512d __A)
__builtin_ia32_storeapd512_mask ((__v8df *) __P, (__v8df) __A,
(__mmask8) __U);
_mm512_load_ps (void const *__P)
return *(__m512 *) __P;
_mm512_mask_load_ps (__m512 __W, __mmask16 __U, void const *__P)
return (__m512) __builtin_ia32_loadaps512_mask ((const __v16sf *) __P,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_load_ps (__mmask16 __U, void const *__P)
(__v16sf)
(__mmask16) __U);
_mm512_store_ps (void *__P, __m512 __A)
*(__m512 *) __P = __A;
_mm512_mask_store_ps (void *__P, __mmask16 __U, __m512 __A)
__builtin_ia32_storeaps512_mask ((__v16sf *) __P, (__v16sf) __A,
(__mmask16) __U);
_mm512_mask_mov_epi64 (__m512i __W, __mmask8 __U, __m512i __A)
return (__m512i) __builtin_ia32_movdqa64_512_mask ((__v8di) __A,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_mov_epi64 (__mmask8 __U, __m512i __A)
(__v8di)
_mm512_setzero_si512 (),
(__mmask8) __U);
_mm512_load_epi64 (void const *__P)
return *(__m512i *) __P;
_mm512_mask_load_epi64 (__m512i __W, __mmask8 __U, void const *__P)
return (__m512i) __builtin_ia32_movdqa64load512_mask ((const __v8di *) __P,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_load_epi64 (__mmask8 __U, void const *__P)
(__v8di)
(__mmask8) __U);
_mm512_store_epi64 (void *__P, __m512i __A)
*(__m512i *) __P = __A;
_mm512_mask_store_epi64 (void *__P, __mmask8 __U, __m512i __A)
__builtin_ia32_movdqa64store512_mask ((__v8di *) __P, (__v8di) __A,
(__mmask8) __U);
_mm512_mask_mov_epi32 (__m512i __W, __mmask16 __U, __m512i __A)
return (__m512i) __builtin_ia32_movdqa32_512_mask ((__v16si) __A,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_mov_epi32 (__mmask16 __U, __m512i __A)
(__v16si)
(__mmask16) __U);
_mm512_load_si512 (void const *__P)
_mm512_load_epi32 (void const *__P)
_mm512_mask_load_epi32 (__m512i __W, __mmask16 __U, void const *__P)
return (__m512i) __builtin_ia32_movdqa32load512_mask ((const __v16si *) __P,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_load_epi32 (__mmask16 __U, void const *__P)
(__v16si)
(__mmask16) __U);
_mm512_store_si512 (void *__P, __m512i __A)
_mm512_store_epi32 (void *__P, __m512i __A)
_mm512_mask_store_epi32 (void *__P, __mmask16 __U, __m512i __A)
__builtin_ia32_movdqa32store512_mask ((__v16si *) __P, (__v16si) __A,
(__mmask16) __U);
_mm512_mullo_epi32 (__m512i __A, __m512i __B)
return (__m512i) ((__v16su) __A * (__v16su) __B);
_mm512_maskz_mullo_epi32 (__mmask16 __M, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmulld512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
__M);
_mm512_mask_mullo_epi32 (__m512i __W, __mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si) __W, __M);
_mm512_sllv_epi32 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_psllv16si_mask ((__v16si) __X,
(__v16si) __Y,
(__v16si)
_mm512_undefined_epi32 (),
(__mmask16) -1);
_mm512_mask_sllv_epi32 (__m512i __W, __mmask16 __U, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_sllv_epi32 (__mmask16 __U, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v16si)
(__mmask16) __U);
_mm512_srav_epi32 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_psrav16si_mask ((__v16si) __X,
(__v16si) __Y,
(__v16si)
(__mmask16) -1);
_mm512_mask_srav_epi32 (__m512i __W, __mmask16 __U, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_srav_epi32 (__mmask16 __U, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v16si)
(__mmask16) __U);
_mm512_srlv_epi32 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_psrlv16si_mask ((__v16si) __X,
(__v16si) __Y,
(__v16si)
(__mmask16) -1);
_mm512_mask_srlv_epi32 (__m512i __W, __mmask16 __U, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_srlv_epi32 (__mmask16 __U, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v16si)
(__mmask16) __U);
_mm512_add_epi64 (__m512i __A, __m512i __B)
return (__m512i) ((__v8du) __A + (__v8du) __B);
_mm512_mask_add_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_paddq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_add_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
_mm512_sub_epi64 (__m512i __A, __m512i __B)
return (__m512i) ((__v8du) __A - (__v8du) __B);
_mm512_mask_sub_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psubq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_sub_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
_mm512_sllv_epi64 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_psllv8di_mask ((__v8di) __X,
(__v8di) __Y,
(__v8di)
(__mmask8) -1);
_mm512_mask_sllv_epi64 (__m512i __W, __mmask8 __U, __m512i __X, __m512i __Y)
(__v8di) __Y,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_sllv_epi64 (__mmask8 __U, __m512i __X, __m512i __Y)
(__v8di) __Y,
(__v8di)
(__mmask8) __U);
_mm512_srav_epi64 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_psrav8di_mask ((__v8di) __X,
(__v8di) __Y,
(__v8di)
(__mmask8) -1);
_mm512_mask_srav_epi64 (__m512i __W, __mmask8 __U, __m512i __X, __m512i __Y)
(__v8di) __Y,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_srav_epi64 (__mmask8 __U, __m512i __X, __m512i __Y)
(__v8di) __Y,
(__v8di)
(__mmask8) __U);
_mm512_srlv_epi64 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_psrlv8di_mask ((__v8di) __X,
(__v8di) __Y,
(__v8di)
(__mmask8) -1);
_mm512_mask_srlv_epi64 (__m512i __W, __mmask8 __U, __m512i __X, __m512i __Y)
(__v8di) __Y,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_srlv_epi64 (__mmask8 __U, __m512i __X, __m512i __Y)
(__v8di) __Y,
(__v8di)
(__mmask8) __U);
_mm512_add_epi32 (__m512i __A, __m512i __B)
return (__m512i) ((__v16su) __A + (__v16su) __B);
_mm512_mask_add_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_paddd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_add_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_mul_epi32 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_pmuldq512_mask ((__v16si) __X,
(__v16si) __Y,
(__v8di)
(__mmask8) -1);
_mm512_mask_mul_epi32 (__m512i __W, __mmask8 __M, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v8di) __W, __M);
_mm512_maskz_mul_epi32 (__mmask8 __M, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v8di)
__M);
_mm512_sub_epi32 (__m512i __A, __m512i __B)
return (__m512i) ((__v16su) __A - (__v16su) __B);
_mm512_mask_sub_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psubd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_sub_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_mul_epu32 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_pmuludq512_mask ((__v16si) __X,
(__v16si) __Y,
(__v8di)
(__mmask8) -1);
_mm512_mask_mul_epu32 (__m512i __W, __mmask8 __M, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v8di) __W, __M);
_mm512_maskz_mul_epu32 (__mmask8 __M, __m512i __X, __m512i __Y)
(__v16si) __Y,
(__v8di)
__M);
# 981 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_sll_epi64 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psllq512_mask ((__v8di) __A,
(__v2di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_sll_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m128i __B)
(__v2di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_sll_epi64 (__mmask8 __U, __m512i __A, __m128i __B)
(__v2di) __B,
(__v8di)
(__mmask8) __U);
# 1060 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_srl_epi64 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psrlq512_mask ((__v8di) __A,
(__v2di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_srl_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m128i __B)
(__v2di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_srl_epi64 (__mmask8 __U, __m512i __A, __m128i __B)
(__v2di) __B,
(__v8di)
(__mmask8) __U);
# 1139 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_sra_epi64 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psraq512_mask ((__v8di) __A,
(__v2di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_sra_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m128i __B)
(__v2di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_sra_epi64 (__mmask8 __U, __m512i __A, __m128i __B)
(__v2di) __B,
(__v8di)
(__mmask8) __U);
# 1218 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_sll_epi32 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_pslld512_mask ((__v16si) __A,
(__v4si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_sll_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m128i __B)
(__v4si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_sll_epi32 (__mmask16 __U, __m512i __A, __m128i __B)
(__v4si) __B,
(__v16si)
(__mmask16) __U);
# 1297 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_srl_epi32 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psrld512_mask ((__v16si) __A,
(__v4si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_srl_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m128i __B)
(__v4si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_srl_epi32 (__mmask16 __U, __m512i __A, __m128i __B)
(__v4si) __B,
(__v16si)
(__mmask16) __U);
# 1376 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_sra_epi32 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psrad512_mask ((__v16si) __A,
(__v4si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_sra_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m128i __B)
(__v4si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_sra_epi32 (__mmask16 __U, __m512i __A, __m128i __B)
(__v4si) __B,
(__v16si)
(__mmask16) __U);
# 1666 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_rcp14_pd (__m512d __A)
return (__m512d) __builtin_ia32_rcp14pd512_mask ((__v8df) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_rcp14_pd (__m512d __W, __mmask8 __U, __m512d __A)
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_rcp14_pd (__mmask8 __U, __m512d __A)
(__v8df)
(__mmask8) __U);
_mm512_rcp14_ps (__m512 __A)
return (__m512) __builtin_ia32_rcp14ps512_mask ((__v16sf) __A,
(__v16sf)
(__mmask16) -1);
_mm512_mask_rcp14_ps (__m512 __W, __mmask16 __U, __m512 __A)
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_rcp14_ps (__mmask16 __U, __m512 __A)
(__v16sf)
(__mmask16) __U);
extern __inline __m128d
_mm_rcp14_sd (__m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_rcp14sd ((__v2df) __B,
(__v2df) __A);
_mm_mask_rcp14_sd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_rcp14sd_mask ((__v2df) __B,
(__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_rcp14_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __A,
(__v2df) _mm_setzero_ps (),
(__mmask8) __U);
_mm_rcp14_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_rcp14ss ((__v4sf) __B,
(__v4sf) __A);
_mm_mask_rcp14_ss (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_rcp14ss_mask ((__v4sf) __B,
(__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_rcp14_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __A,
(__v4sf) _mm_setzero_ps (),
(__mmask8) __U);
_mm512_rsqrt14_pd (__m512d __A)
return (__m512d) __builtin_ia32_rsqrt14pd512_mask ((__v8df) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_rsqrt14_pd (__m512d __W, __mmask8 __U, __m512d __A)
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_rsqrt14_pd (__mmask8 __U, __m512d __A)
(__v8df)
(__mmask8) __U);
_mm512_rsqrt14_ps (__m512 __A)
return (__m512) __builtin_ia32_rsqrt14ps512_mask ((__v16sf) __A,
(__v16sf)
(__mmask16) -1);
_mm512_mask_rsqrt14_ps (__m512 __W, __mmask16 __U, __m512 __A)
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_rsqrt14_ps (__mmask16 __U, __m512 __A)
(__v16sf)
(__mmask16) __U);
_mm_rsqrt14_sd (__m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_rsqrt14sd ((__v2df) __B,
(__v2df) __A);
_mm_mask_rsqrt14_sd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_rsqrt14sd_mask ((__v2df) __B,
(__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_rsqrt14_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __A,
(__v2df) _mm_setzero_pd (),
(__mmask8) __U);
_mm_rsqrt14_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_rsqrt14ss ((__v4sf) __B,
(__v4sf) __A);
_mm_mask_rsqrt14_ss (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_rsqrt14ss_mask ((__v4sf) __B,
(__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_rsqrt14_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __A,
(__mmask8) __U);
# 2061 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_cvtepi8_epi32 (__m128i __A)
return (__m512i) __builtin_ia32_pmovsxbd512_mask ((__v16qi) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_cvtepi8_epi32 (__m512i __W, __mmask16 __U, __m128i __A)
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_cvtepi8_epi32 (__mmask16 __U, __m128i __A)
(__v16si)
(__mmask16) __U);
_mm512_cvtepi8_epi64 (__m128i __A)
return (__m512i) __builtin_ia32_pmovsxbq512_mask ((__v16qi) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_cvtepi8_epi64 (__m512i __W, __mmask8 __U, __m128i __A)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_cvtepi8_epi64 (__mmask8 __U, __m128i __A)
(__v8di)
(__mmask8) __U);
_mm512_cvtepi16_epi32 (__m256i __A)
return (__m512i) __builtin_ia32_pmovsxwd512_mask ((__v16hi) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_cvtepi16_epi32 (__m512i __W, __mmask16 __U, __m256i __A)
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_cvtepi16_epi32 (__mmask16 __U, __m256i __A)
(__v16si)
(__mmask16) __U);
_mm512_cvtepi16_epi64 (__m128i __A)
return (__m512i) __builtin_ia32_pmovsxwq512_mask ((__v8hi) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_cvtepi16_epi64 (__m512i __W, __mmask8 __U, __m128i __A)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_cvtepi16_epi64 (__mmask8 __U, __m128i __A)
(__v8di)
(__mmask8) __U);
_mm512_cvtepi32_epi64 (__m256i __X)
return (__m512i) __builtin_ia32_pmovsxdq512_mask ((__v8si) __X,
(__v8di)
(__mmask8) -1);
_mm512_mask_cvtepi32_epi64 (__m512i __W, __mmask8 __U, __m256i __X)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_cvtepi32_epi64 (__mmask8 __U, __m256i __X)
(__v8di)
(__mmask8) __U);
_mm512_cvtepu8_epi32 (__m128i __A)
return (__m512i) __builtin_ia32_pmovzxbd512_mask ((__v16qi) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_cvtepu8_epi32 (__m512i __W, __mmask16 __U, __m128i __A)
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_cvtepu8_epi32 (__mmask16 __U, __m128i __A)
(__v16si)
(__mmask16) __U);
_mm512_cvtepu8_epi64 (__m128i __A)
return (__m512i) __builtin_ia32_pmovzxbq512_mask ((__v16qi) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_cvtepu8_epi64 (__m512i __W, __mmask8 __U, __m128i __A)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_cvtepu8_epi64 (__mmask8 __U, __m128i __A)
(__v8di)
(__mmask8) __U);
_mm512_cvtepu16_epi32 (__m256i __A)
return (__m512i) __builtin_ia32_pmovzxwd512_mask ((__v16hi) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_cvtepu16_epi32 (__m512i __W, __mmask16 __U, __m256i __A)
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_cvtepu16_epi32 (__mmask16 __U, __m256i __A)
(__v16si)
(__mmask16) __U);
_mm512_cvtepu16_epi64 (__m128i __A)
return (__m512i) __builtin_ia32_pmovzxwq512_mask ((__v8hi) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_cvtepu16_epi64 (__m512i __W, __mmask8 __U, __m128i __A)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_cvtepu16_epi64 (__mmask8 __U, __m128i __A)
(__v8di)
(__mmask8) __U);
_mm512_cvtepu32_epi64 (__m256i __X)
return (__m512i) __builtin_ia32_pmovzxdq512_mask ((__v8si) __X,
(__v8di)
(__mmask8) -1);
_mm512_mask_cvtepu32_epi64 (__m512i __W, __mmask8 __U, __m256i __X)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_cvtepu32_epi64 (__mmask8 __U, __m256i __X)
(__v8di)
(__mmask8) __U);
# 3858 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_abs_epi64 (__m512i __A)
return (__m512i) __builtin_ia32_pabsq512_mask ((__v8di) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_abs_epi64 (__m512i __W, __mmask8 __U, __m512i __A)
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_abs_epi64 (__mmask8 __U, __m512i __A)
(__v8di)
(__mmask8) __U);
_mm512_abs_epi32 (__m512i __A)
return (__m512i) __builtin_ia32_pabsd512_mask ((__v16si) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_abs_epi32 (__m512i __W, __mmask16 __U, __m512i __A)
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_abs_epi32 (__mmask16 __U, __m512i __A)
(__v16si)
(__mmask16) __U);
_mm512_broadcastss_ps (__m128 __A)
return (__m512) __builtin_ia32_broadcastss512 ((__v4sf) __A,
(__v16sf)
(__mmask16) -1);
_mm512_mask_broadcastss_ps (__m512 __O, __mmask16 __M, __m128 __A)
(__v16sf) __O, __M);
_mm512_maskz_broadcastss_ps (__mmask16 __M, __m128 __A)
(__v16sf)
__M);
_mm512_broadcastsd_pd (__m128d __A)
return (__m512d) __builtin_ia32_broadcastsd512 ((__v2df) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_broadcastsd_pd (__m512d __O, __mmask8 __M, __m128d __A)
(__v8df) __O, __M);
_mm512_maskz_broadcastsd_pd (__mmask8 __M, __m128d __A)
(__v8df)
__M);
_mm512_broadcastd_epi32 (__m128i __A)
return (__m512i) __builtin_ia32_pbroadcastd512 ((__v4si) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_broadcastd_epi32 (__m512i __O, __mmask16 __M, __m128i __A)
(__v16si) __O, __M);
_mm512_maskz_broadcastd_epi32 (__mmask16 __M, __m128i __A)
(__v16si)
__M);
_mm512_set1_epi32 (int __A)
return (__m512i) __builtin_ia32_pbroadcastd512_gpr_mask (__A,
(__v16si)
(__mmask16)(-1));
_mm512_mask_set1_epi32 (__m512i __O, __mmask16 __M, int __A)
return (__m512i) __builtin_ia32_pbroadcastd512_gpr_mask (__A, (__v16si) __O,
__M);
_mm512_maskz_set1_epi32 (__mmask16 __M, int __A)
return (__m512i)
(__v16si) _mm512_setzero_si512 (),
__M);
_mm512_broadcastq_epi64 (__m128i __A)
return (__m512i) __builtin_ia32_pbroadcastq512 ((__v2di) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_broadcastq_epi64 (__m512i __O, __mmask8 __M, __m128i __A)
(__v8di) __O, __M);
_mm512_maskz_broadcastq_epi64 (__mmask8 __M, __m128i __A)
(__v8di)
__M);
_mm512_set1_epi64 (long long __A)
return (__m512i) __builtin_ia32_pbroadcastq512_gpr_mask (__A,
(__v8di)
(__mmask8)(-1));
_mm512_mask_set1_epi64 (__m512i __O, __mmask8 __M, long long __A)
return (__m512i) __builtin_ia32_pbroadcastq512_gpr_mask (__A, (__v8di) __O,
__M);
_mm512_maskz_set1_epi64 (__mmask8 __M, long long __A)
return (__m512i)
(__v8di) _mm512_setzero_si512 (),
__M);
_mm512_broadcast_f32x4 (__m128 __A)
return (__m512) __builtin_ia32_broadcastf32x4_512 ((__v4sf) __A,
(__v16sf)
(__mmask16) -1);
_mm512_mask_broadcast_f32x4 (__m512 __O, __mmask16 __M, __m128 __A)
(__v16sf) __O,
__M);
_mm512_maskz_broadcast_f32x4 (__mmask16 __M, __m128 __A)
(__v16sf)
__M);
_mm512_broadcast_i32x4 (__m128i __A)
return (__m512i) __builtin_ia32_broadcasti32x4_512 ((__v4si) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_broadcast_i32x4 (__m512i __O, __mmask16 __M, __m128i __A)
(__v16si) __O,
__M);
_mm512_maskz_broadcast_i32x4 (__mmask16 __M, __m128i __A)
(__v16si)
__M);
_mm512_broadcast_f64x4 (__m256d __A)
return (__m512d) __builtin_ia32_broadcastf64x4_512 ((__v4df) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_broadcast_f64x4 (__m512d __O, __mmask8 __M, __m256d __A)
(__v8df) __O,
__M);
_mm512_maskz_broadcast_f64x4 (__mmask8 __M, __m256d __A)
(__v8df)
__M);
_mm512_broadcast_i64x4 (__m256i __A)
return (__m512i) __builtin_ia32_broadcasti64x4_512 ((__v4di) __A,
(__v8di)
(__mmask8) -1);
_mm512_mask_broadcast_i64x4 (__m512i __O, __mmask8 __M, __m256i __A)
(__v8di) __O,
__M);
_mm512_maskz_broadcast_i64x4 (__mmask8 __M, __m256i __A)
(__v8di)
__M);
typedef enum
_MM_PERM_AAAA = 0x00, _MM_PERM_AAAB = 0x01, _MM_PERM_AAAC = 0x02,
_MM_PERM_AAAD = 0x03, _MM_PERM_AABA = 0x04, _MM_PERM_AABB = 0x05,
_MM_PERM_AABC = 0x06, _MM_PERM_AABD = 0x07, _MM_PERM_AACA = 0x08,
_MM_PERM_AACB = 0x09, _MM_PERM_AACC = 0x0A, _MM_PERM_AACD = 0x0B,
_MM_PERM_AADA = 0x0C, _MM_PERM_AADB = 0x0D, _MM_PERM_AADC = 0x0E,
_MM_PERM_AADD = 0x0F, _MM_PERM_ABAA = 0x10, _MM_PERM_ABAB = 0x11,
_MM_PERM_ABAC = 0x12, _MM_PERM_ABAD = 0x13, _MM_PERM_ABBA = 0x14,
_MM_PERM_ABBB = 0x15, _MM_PERM_ABBC = 0x16, _MM_PERM_ABBD = 0x17,
_MM_PERM_ABCA = 0x18, _MM_PERM_ABCB = 0x19, _MM_PERM_ABCC = 0x1A,
_MM_PERM_ABCD = 0x1B, _MM_PERM_ABDA = 0x1C, _MM_PERM_ABDB = 0x1D,
_MM_PERM_ABDC = 0x1E, _MM_PERM_ABDD = 0x1F, _MM_PERM_ACAA = 0x20,
_MM_PERM_ACAB = 0x21, _MM_PERM_ACAC = 0x22, _MM_PERM_ACAD = 0x23,
_MM_PERM_ACBA = 0x24, _MM_PERM_ACBB = 0x25, _MM_PERM_ACBC = 0x26,
_MM_PERM_ACBD = 0x27, _MM_PERM_ACCA = 0x28, _MM_PERM_ACCB = 0x29,
_MM_PERM_ACCC = 0x2A, _MM_PERM_ACCD = 0x2B, _MM_PERM_ACDA = 0x2C,
_MM_PERM_ACDB = 0x2D, _MM_PERM_ACDC = 0x2E, _MM_PERM_ACDD = 0x2F,
_MM_PERM_ADAA = 0x30, _MM_PERM_ADAB = 0x31, _MM_PERM_ADAC = 0x32,
_MM_PERM_ADAD = 0x33, _MM_PERM_ADBA = 0x34, _MM_PERM_ADBB = 0x35,
_MM_PERM_ADBC = 0x36, _MM_PERM_ADBD = 0x37, _MM_PERM_ADCA = 0x38,
_MM_PERM_ADCB = 0x39, _MM_PERM_ADCC = 0x3A, _MM_PERM_ADCD = 0x3B,
_MM_PERM_ADDA = 0x3C, _MM_PERM_ADDB = 0x3D, _MM_PERM_ADDC = 0x3E,
_MM_PERM_ADDD = 0x3F, _MM_PERM_BAAA = 0x40, _MM_PERM_BAAB = 0x41,
_MM_PERM_BAAC = 0x42, _MM_PERM_BAAD = 0x43, _MM_PERM_BABA = 0x44,
_MM_PERM_BABB = 0x45, _MM_PERM_BABC = 0x46, _MM_PERM_BABD = 0x47,
_MM_PERM_BACA = 0x48, _MM_PERM_BACB = 0x49, _MM_PERM_BACC = 0x4A,
_MM_PERM_BACD = 0x4B, _MM_PERM_BADA = 0x4C, _MM_PERM_BADB = 0x4D,
_MM_PERM_BADC = 0x4E, _MM_PERM_BADD = 0x4F, _MM_PERM_BBAA = 0x50,
_MM_PERM_BBAB = 0x51, _MM_PERM_BBAC = 0x52, _MM_PERM_BBAD = 0x53,
_MM_PERM_BBBA = 0x54, _MM_PERM_BBBB = 0x55, _MM_PERM_BBBC = 0x56,
_MM_PERM_BBBD = 0x57, _MM_PERM_BBCA = 0x58, _MM_PERM_BBCB = 0x59,
_MM_PERM_BBCC = 0x5A, _MM_PERM_BBCD = 0x5B, _MM_PERM_BBDA = 0x5C,
_MM_PERM_BBDB = 0x5D, _MM_PERM_BBDC = 0x5E, _MM_PERM_BBDD = 0x5F,
_MM_PERM_BCAA = 0x60, _MM_PERM_BCAB = 0x61, _MM_PERM_BCAC = 0x62,
_MM_PERM_BCAD = 0x63, _MM_PERM_BCBA = 0x64, _MM_PERM_BCBB = 0x65,
_MM_PERM_BCBC = 0x66, _MM_PERM_BCBD = 0x67, _MM_PERM_BCCA = 0x68,
_MM_PERM_BCCB = 0x69, _MM_PERM_BCCC = 0x6A, _MM_PERM_BCCD = 0x6B,
_MM_PERM_BCDA = 0x6C, _MM_PERM_BCDB = 0x6D, _MM_PERM_BCDC = 0x6E,
_MM_PERM_BCDD = 0x6F, _MM_PERM_BDAA = 0x70, _MM_PERM_BDAB = 0x71,
_MM_PERM_BDAC = 0x72, _MM_PERM_BDAD = 0x73, _MM_PERM_BDBA = 0x74,
_MM_PERM_BDBB = 0x75, _MM_PERM_BDBC = 0x76, _MM_PERM_BDBD = 0x77,
_MM_PERM_BDCA = 0x78, _MM_PERM_BDCB = 0x79, _MM_PERM_BDCC = 0x7A,
_MM_PERM_BDCD = 0x7B, _MM_PERM_BDDA = 0x7C, _MM_PERM_BDDB = 0x7D,
_MM_PERM_BDDC = 0x7E, _MM_PERM_BDDD = 0x7F, _MM_PERM_CAAA = 0x80,
_MM_PERM_CAAB = 0x81, _MM_PERM_CAAC = 0x82, _MM_PERM_CAAD = 0x83,
_MM_PERM_CABA = 0x84, _MM_PERM_CABB = 0x85, _MM_PERM_CABC = 0x86,
_MM_PERM_CABD = 0x87, _MM_PERM_CACA = 0x88, _MM_PERM_CACB = 0x89,
_MM_PERM_CACC = 0x8A, _MM_PERM_CACD = 0x8B, _MM_PERM_CADA = 0x8C,
_MM_PERM_CADB = 0x8D, _MM_PERM_CADC = 0x8E, _MM_PERM_CADD = 0x8F,
_MM_PERM_CBAA = 0x90, _MM_PERM_CBAB = 0x91, _MM_PERM_CBAC = 0x92,
_MM_PERM_CBAD = 0x93, _MM_PERM_CBBA = 0x94, _MM_PERM_CBBB = 0x95,
_MM_PERM_CBBC = 0x96, _MM_PERM_CBBD = 0x97, _MM_PERM_CBCA = 0x98,
_MM_PERM_CBCB = 0x99, _MM_PERM_CBCC = 0x9A, _MM_PERM_CBCD = 0x9B,
_MM_PERM_CBDA = 0x9C, _MM_PERM_CBDB = 0x9D, _MM_PERM_CBDC = 0x9E,
_MM_PERM_CBDD = 0x9F, _MM_PERM_CCAA = 0xA0, _MM_PERM_CCAB = 0xA1,
_MM_PERM_CCAC = 0xA2, _MM_PERM_CCAD = 0xA3, _MM_PERM_CCBA = 0xA4,
_MM_PERM_CCBB = 0xA5, _MM_PERM_CCBC = 0xA6, _MM_PERM_CCBD = 0xA7,
_MM_PERM_CCCA = 0xA8, _MM_PERM_CCCB = 0xA9, _MM_PERM_CCCC = 0xAA,
_MM_PERM_CCCD = 0xAB, _MM_PERM_CCDA = 0xAC, _MM_PERM_CCDB = 0xAD,
_MM_PERM_CCDC = 0xAE, _MM_PERM_CCDD = 0xAF, _MM_PERM_CDAA = 0xB0,
_MM_PERM_CDAB = 0xB1, _MM_PERM_CDAC = 0xB2, _MM_PERM_CDAD = 0xB3,
_MM_PERM_CDBA = 0xB4, _MM_PERM_CDBB = 0xB5, _MM_PERM_CDBC = 0xB6,
_MM_PERM_CDBD = 0xB7, _MM_PERM_CDCA = 0xB8, _MM_PERM_CDCB = 0xB9,
_MM_PERM_CDCC = 0xBA, _MM_PERM_CDCD = 0xBB, _MM_PERM_CDDA = 0xBC,
_MM_PERM_CDDB = 0xBD, _MM_PERM_CDDC = 0xBE, _MM_PERM_CDDD = 0xBF,
_MM_PERM_DAAA = 0xC0, _MM_PERM_DAAB = 0xC1, _MM_PERM_DAAC = 0xC2,
_MM_PERM_DAAD = 0xC3, _MM_PERM_DABA = 0xC4, _MM_PERM_DABB = 0xC5,
_MM_PERM_DABC = 0xC6, _MM_PERM_DABD = 0xC7, _MM_PERM_DACA = 0xC8,
_MM_PERM_DACB = 0xC9, _MM_PERM_DACC = 0xCA, _MM_PERM_DACD = 0xCB,
_MM_PERM_DADA = 0xCC, _MM_PERM_DADB = 0xCD, _MM_PERM_DADC = 0xCE,
_MM_PERM_DADD = 0xCF, _MM_PERM_DBAA = 0xD0, _MM_PERM_DBAB = 0xD1,
_MM_PERM_DBAC = 0xD2, _MM_PERM_DBAD = 0xD3, _MM_PERM_DBBA = 0xD4,
_MM_PERM_DBBB = 0xD5, _MM_PERM_DBBC = 0xD6, _MM_PERM_DBBD = 0xD7,
_MM_PERM_DBCA = 0xD8, _MM_PERM_DBCB = 0xD9, _MM_PERM_DBCC = 0xDA,
_MM_PERM_DBCD = 0xDB, _MM_PERM_DBDA = 0xDC, _MM_PERM_DBDB = 0xDD,
_MM_PERM_DBDC = 0xDE, _MM_PERM_DBDD = 0xDF, _MM_PERM_DCAA = 0xE0,
_MM_PERM_DCAB = 0xE1, _MM_PERM_DCAC = 0xE2, _MM_PERM_DCAD = 0xE3,
_MM_PERM_DCBA = 0xE4, _MM_PERM_DCBB = 0xE5, _MM_PERM_DCBC = 0xE6,
_MM_PERM_DCBD = 0xE7, _MM_PERM_DCCA = 0xE8, _MM_PERM_DCCB = 0xE9,
_MM_PERM_DCCC = 0xEA, _MM_PERM_DCCD = 0xEB, _MM_PERM_DCDA = 0xEC,
_MM_PERM_DCDB = 0xED, _MM_PERM_DCDC = 0xEE, _MM_PERM_DCDD = 0xEF,
_MM_PERM_DDAA = 0xF0, _MM_PERM_DDAB = 0xF1, _MM_PERM_DDAC = 0xF2,
_MM_PERM_DDAD = 0xF3, _MM_PERM_DDBA = 0xF4, _MM_PERM_DDBB = 0xF5,
_MM_PERM_DDBC = 0xF6, _MM_PERM_DDBD = 0xF7, _MM_PERM_DDCA = 0xF8,
_MM_PERM_DDCB = 0xF9, _MM_PERM_DDCC = 0xFA, _MM_PERM_DDCD = 0xFB,
_MM_PERM_DDDA = 0xFC, _MM_PERM_DDDB = 0xFD, _MM_PERM_DDDC = 0xFE,
_MM_PERM_DDDD = 0xFF
} _MM_PERM_ENUM;
# 4552 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_rolv_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_prolvd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_rolv_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_rolv_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_rorv_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_prorvd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_rorv_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_rorv_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_rolv_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_prolvq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_rolv_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_rolv_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
_mm512_rorv_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_prorvq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_rorv_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_rorv_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
# 5000 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm_cvtu32_sd (__m128d __A, unsigned __B)
return (__m128d) __builtin_ia32_cvtusi2sd32 ((__v2df) __A, __B);
# 5109 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
extern __inline __m128i
_mm512_cvtepi32_epi8 (__m512i __A)
return (__m128i) __builtin_ia32_pmovdb512_mask ((__v16si) __A,
(__v16qi)
_mm_undefined_si128 (),
(__mmask16) -1);
extern __inline void
_mm512_mask_cvtepi32_storeu_epi8 (void * __P, __mmask16 __M, __m512i __A)
__builtin_ia32_pmovdb512mem_mask ((__v16qi *) __P, (__v16si) __A, __M);
_mm512_mask_cvtepi32_epi8 (__m128i __O, __mmask16 __M, __m512i __A)
(__v16qi) __O, __M);
_mm512_maskz_cvtepi32_epi8 (__mmask16 __M, __m512i __A)
(__v16qi)
_mm_setzero_si128 (),
__M);
_mm512_cvtsepi32_epi8 (__m512i __A)
return (__m128i) __builtin_ia32_pmovsdb512_mask ((__v16si) __A,
(__v16qi)
(__mmask16) -1);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm512_mask_cvtsepi32_storeu_epi8 (void * __P, __mmask16 __M, __m512i __A)
__builtin_ia32_pmovsdb512mem_mask ((__v16qi *) __P, (__v16si) __A, __M);
_mm512_mask_cvtsepi32_epi8 (__m128i __O, __mmask16 __M, __m512i __A)
_mm512_maskz_cvtsepi32_epi8 (__mmask16 __M, __m512i __A)
(__v16qi)
__M);
_mm512_cvtusepi32_epi8 (__m512i __A)
return (__m128i) __builtin_ia32_pmovusdb512_mask ((__v16si) __A,
(__v16qi)
(__mmask16) -1);
_mm512_mask_cvtusepi32_storeu_epi8 (void * __P, __mmask16 __M, __m512i __A)
__builtin_ia32_pmovusdb512mem_mask ((__v16qi *) __P, (__v16si) __A, __M);
_mm512_mask_cvtusepi32_epi8 (__m128i __O, __mmask16 __M, __m512i __A)
(__v16qi) __O,
__M);
_mm512_maskz_cvtusepi32_epi8 (__mmask16 __M, __m512i __A)
(__v16qi)
__M);
extern __inline __m256i
_mm512_cvtepi32_epi16 (__m512i __A)
return (__m256i) __builtin_ia32_pmovdw512_mask ((__v16si) __A,
(__v16hi)
_mm256_undefined_si256 (),
(__mmask16) -1);
_mm512_mask_cvtepi32_storeu_epi16 (void * __P, __mmask16 __M, __m512i __A)
__builtin_ia32_pmovdw512mem_mask ((__v16hi *) __P, (__v16si) __A, __M);
_mm512_mask_cvtepi32_epi16 (__m256i __O, __mmask16 __M, __m512i __A)
(__v16hi) __O, __M);
_mm512_maskz_cvtepi32_epi16 (__mmask16 __M, __m512i __A)
(__v16hi)
_mm256_setzero_si256 (),
__M);
_mm512_cvtsepi32_epi16 (__m512i __A)
return (__m256i) __builtin_ia32_pmovsdw512_mask ((__v16si) __A,
(__v16hi)
(__mmask16) -1);
_mm512_mask_cvtsepi32_storeu_epi16 (void *__P, __mmask16 __M, __m512i __A)
__builtin_ia32_pmovsdw512mem_mask ((__v16hi*) __P, (__v16si) __A, __M);
_mm512_mask_cvtsepi32_epi16 (__m256i __O, __mmask16 __M, __m512i __A)
_mm512_maskz_cvtsepi32_epi16 (__mmask16 __M, __m512i __A)
(__v16hi)
__M);
_mm512_cvtusepi32_epi16 (__m512i __A)
return (__m256i) __builtin_ia32_pmovusdw512_mask ((__v16si) __A,
(__v16hi)
(__mmask16) -1);
_mm512_mask_cvtusepi32_storeu_epi16 (void *__P, __mmask16 __M, __m512i __A)
__builtin_ia32_pmovusdw512mem_mask ((__v16hi*) __P, (__v16si) __A, __M);
_mm512_mask_cvtusepi32_epi16 (__m256i __O, __mmask16 __M, __m512i __A)
(__v16hi) __O,
__M);
_mm512_maskz_cvtusepi32_epi16 (__mmask16 __M, __m512i __A)
(__v16hi)
__M);
_mm512_cvtepi64_epi32 (__m512i __A)
return (__m256i) __builtin_ia32_pmovqd512_mask ((__v8di) __A,
(__v8si)
(__mmask8) -1);
_mm512_mask_cvtepi64_storeu_epi32 (void* __P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovqd512mem_mask ((__v8si *) __P, (__v8di) __A, __M);
_mm512_mask_cvtepi64_epi32 (__m256i __O, __mmask8 __M, __m512i __A)
(__v8si) __O, __M);
_mm512_maskz_cvtepi64_epi32 (__mmask8 __M, __m512i __A)
(__v8si)
__M);
_mm512_cvtsepi64_epi32 (__m512i __A)
return (__m256i) __builtin_ia32_pmovsqd512_mask ((__v8di) __A,
(__v8si)
(__mmask8) -1);
_mm512_mask_cvtsepi64_storeu_epi32 (void *__P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovsqd512mem_mask ((__v8si *) __P, (__v8di) __A, __M);
_mm512_mask_cvtsepi64_epi32 (__m256i __O, __mmask8 __M, __m512i __A)
(__v8si) __O, __M);
_mm512_maskz_cvtsepi64_epi32 (__mmask8 __M, __m512i __A)
(__v8si)
__M);
_mm512_cvtusepi64_epi32 (__m512i __A)
return (__m256i) __builtin_ia32_pmovusqd512_mask ((__v8di) __A,
(__v8si)
(__mmask8) -1);
_mm512_mask_cvtusepi64_storeu_epi32 (void* __P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovusqd512mem_mask ((__v8si*) __P, (__v8di) __A, __M);
_mm512_mask_cvtusepi64_epi32 (__m256i __O, __mmask8 __M, __m512i __A)
(__v8si) __O, __M);
_mm512_maskz_cvtusepi64_epi32 (__mmask8 __M, __m512i __A)
(__v8si)
__M);
_mm512_cvtepi64_epi16 (__m512i __A)
return (__m128i) __builtin_ia32_pmovqw512_mask ((__v8di) __A,
(__v8hi)
(__mmask8) -1);
_mm512_mask_cvtepi64_storeu_epi16 (void *__P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovqw512mem_mask ((__v8hi *) __P, (__v8di) __A, __M);
_mm512_mask_cvtepi64_epi16 (__m128i __O, __mmask8 __M, __m512i __A)
(__v8hi) __O, __M);
_mm512_maskz_cvtepi64_epi16 (__mmask8 __M, __m512i __A)
(__v8hi)
__M);
_mm512_cvtsepi64_epi16 (__m512i __A)
return (__m128i) __builtin_ia32_pmovsqw512_mask ((__v8di) __A,
(__v8hi)
(__mmask8) -1);
_mm512_mask_cvtsepi64_storeu_epi16 (void * __P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovsqw512mem_mask ((__v8hi *) __P, (__v8di) __A, __M);
_mm512_mask_cvtsepi64_epi16 (__m128i __O, __mmask8 __M, __m512i __A)
(__v8hi) __O, __M);
_mm512_maskz_cvtsepi64_epi16 (__mmask8 __M, __m512i __A)
(__v8hi)
__M);
_mm512_cvtusepi64_epi16 (__m512i __A)
return (__m128i) __builtin_ia32_pmovusqw512_mask ((__v8di) __A,
(__v8hi)
(__mmask8) -1);
_mm512_mask_cvtusepi64_storeu_epi16 (void *__P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovusqw512mem_mask ((__v8hi*) __P, (__v8di) __A, __M);
_mm512_mask_cvtusepi64_epi16 (__m128i __O, __mmask8 __M, __m512i __A)
(__v8hi) __O, __M);
_mm512_maskz_cvtusepi64_epi16 (__mmask8 __M, __m512i __A)
(__v8hi)
__M);
_mm512_cvtepi64_epi8 (__m512i __A)
return (__m128i) __builtin_ia32_pmovqb512_mask ((__v8di) __A,
(__v16qi)
(__mmask8) -1);
_mm512_mask_cvtepi64_storeu_epi8 (void * __P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovqb512mem_mask ((__v16qi *) __P, (__v8di) __A, __M);
_mm512_mask_cvtepi64_epi8 (__m128i __O, __mmask8 __M, __m512i __A)
_mm512_maskz_cvtepi64_epi8 (__mmask8 __M, __m512i __A)
(__v16qi)
__M);
_mm512_cvtsepi64_epi8 (__m512i __A)
return (__m128i) __builtin_ia32_pmovsqb512_mask ((__v8di) __A,
(__v16qi)
(__mmask8) -1);
_mm512_mask_cvtsepi64_storeu_epi8 (void * __P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovsqb512mem_mask ((__v16qi *) __P, (__v8di) __A, __M);
_mm512_mask_cvtsepi64_epi8 (__m128i __O, __mmask8 __M, __m512i __A)
_mm512_maskz_cvtsepi64_epi8 (__mmask8 __M, __m512i __A)
(__v16qi)
__M);
_mm512_cvtusepi64_epi8 (__m512i __A)
return (__m128i) __builtin_ia32_pmovusqb512_mask ((__v8di) __A,
(__v16qi)
(__mmask8) -1);
_mm512_mask_cvtusepi64_storeu_epi8 (void * __P, __mmask8 __M, __m512i __A)
__builtin_ia32_pmovusqb512mem_mask ((__v16qi *) __P, (__v8di) __A, __M);
_mm512_mask_cvtusepi64_epi8 (__m128i __O, __mmask8 __M, __m512i __A)
(__v16qi) __O,
__M);
_mm512_maskz_cvtusepi64_epi8 (__mmask8 __M, __m512i __A)
(__v16qi)
__M);
_mm512_cvtepi32_pd (__m256i __A)
return (__m512d) __builtin_ia32_cvtdq2pd512_mask ((__v8si) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_cvtepi32_pd (__m512d __W, __mmask8 __U, __m256i __A)
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_cvtepi32_pd (__mmask8 __U, __m256i __A)
(__v8df)
(__mmask8) __U);
_mm512_cvtepu32_pd (__m256i __A)
return (__m512d) __builtin_ia32_cvtudq2pd512_mask ((__v8si) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_cvtepu32_pd (__m512d __W, __mmask8 __U, __m256i __A)
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_cvtepu32_pd (__mmask8 __U, __m256i __A)
(__v8df)
(__mmask8) __U);
# 6123 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_loadu_pd (void const *__P)
return *(__m512d_u *)__P;
_mm512_mask_loadu_pd (__m512d __W, __mmask8 __U, void const *__P)
return (__m512d) __builtin_ia32_loadupd512_mask ((const double *) __P,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_loadu_pd (__mmask8 __U, void const *__P)
(__v8df)
(__mmask8) __U);
_mm512_storeu_pd (void *__P, __m512d __A)
*(__m512d_u *)__P = __A;
_mm512_mask_storeu_pd (void *__P, __mmask8 __U, __m512d __A)
__builtin_ia32_storeupd512_mask ((double *) __P, (__v8df) __A,
(__mmask8) __U);
_mm512_loadu_ps (void const *__P)
return *(__m512_u *)__P;
_mm512_mask_loadu_ps (__m512 __W, __mmask16 __U, void const *__P)
return (__m512) __builtin_ia32_loadups512_mask ((const float *) __P,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_loadu_ps (__mmask16 __U, void const *__P)
(__v16sf)
(__mmask16) __U);
_mm512_storeu_ps (void *__P, __m512 __A)
*(__m512_u *)__P = __A;
_mm512_mask_storeu_ps (void *__P, __mmask16 __U, __m512 __A)
__builtin_ia32_storeups512_mask ((float *) __P, (__v16sf) __A,
(__mmask16) __U);
_mm512_mask_loadu_epi64 (__m512i __W, __mmask8 __U, void const *__P)
return (__m512i) __builtin_ia32_loaddqudi512_mask ((const long long *) __P,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_loadu_epi64 (__mmask8 __U, void const *__P)
(__v8di)
(__mmask8) __U);
_mm512_mask_storeu_epi64 (void *__P, __mmask8 __U, __m512i __A)
__builtin_ia32_storedqudi512_mask ((long long *) __P, (__v8di) __A,
(__mmask8) __U);
_mm512_loadu_si512 (void const *__P)
return *(__m512i_u *)__P;
_mm512_mask_loadu_epi32 (__m512i __W, __mmask16 __U, void const *__P)
return (__m512i) __builtin_ia32_loaddqusi512_mask ((const int *) __P,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_loadu_epi32 (__mmask16 __U, void const *__P)
(__v16si)
(__mmask16) __U);
_mm512_storeu_si512 (void *__P, __m512i __A)
*(__m512i_u *)__P = __A;
_mm512_mask_storeu_epi32 (void *__P, __mmask16 __U, __m512i __A)
__builtin_ia32_storedqusi512_mask ((int *) __P, (__v16si) __A,
(__mmask16) __U);
_mm512_permutevar_pd (__m512d __A, __m512i __C)
return (__m512d) __builtin_ia32_vpermilvarpd512_mask ((__v8df) __A,
(__v8di) __C,
(__v8df)
(__mmask8) -1);
_mm512_mask_permutevar_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512i __C)
(__v8di) __C,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_permutevar_pd (__mmask8 __U, __m512d __A, __m512i __C)
(__v8di) __C,
(__v8df)
(__mmask8) __U);
_mm512_permutevar_ps (__m512 __A, __m512i __C)
return (__m512) __builtin_ia32_vpermilvarps512_mask ((__v16sf) __A,
(__v16si) __C,
(__v16sf)
(__mmask16) -1);
_mm512_mask_permutevar_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512i __C)
(__v16si) __C,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_permutevar_ps (__mmask16 __U, __m512 __A, __m512i __C)
(__v16si) __C,
(__v16sf)
(__mmask16) __U);
_mm512_permutex2var_epi64 (__m512i __A, __m512i __I, __m512i __B)
return (__m512i) __builtin_ia32_vpermt2varq512_mask ((__v8di) __I
(__v8di) __A,
(__v8di) __B,
(__mmask8) -1);
_mm512_mask_permutex2var_epi64 (__m512i __A, __mmask8 __U, __m512i __I,
__m512i __B)
(__v8di) __A,
(__v8di) __B,
(__mmask8) __U);
_mm512_mask2_permutex2var_epi64 (__m512i __A, __m512i __I,
__mmask8 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpermi2varq512_mask ((__v8di) __A,
(__v8di) __I
(__v8di) __B,
(__mmask8) __U);
_mm512_maskz_permutex2var_epi64 (__mmask8 __U, __m512i __A,
return (__m512i) __builtin_ia32_vpermt2varq512_maskz ((__v8di) __I
(__v8di) __A,
(__v8di) __B,
(__mmask8) __U);
_mm512_permutex2var_epi32 (__m512i __A, __m512i __I, __m512i __B)
return (__m512i) __builtin_ia32_vpermt2vard512_mask ((__v16si) __I
(__v16si) __A,
(__v16si) __B,
(__mmask16) -1);
_mm512_mask_permutex2var_epi32 (__m512i __A, __mmask16 __U,
(__v16si) __A,
(__v16si) __B,
(__mmask16) __U);
_mm512_mask2_permutex2var_epi32 (__m512i __A, __m512i __I,
__mmask16 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpermi2vard512_mask ((__v16si) __A,
(__v16si) __I
(__v16si) __B,
(__mmask16) __U);
_mm512_maskz_permutex2var_epi32 (__mmask16 __U, __m512i __A,
return (__m512i) __builtin_ia32_vpermt2vard512_maskz ((__v16si) __I
(__v16si) __A,
(__v16si) __B,
(__mmask16) __U);
_mm512_permutex2var_pd (__m512d __A, __m512i __I, __m512d __B)
return (__m512d) __builtin_ia32_vpermt2varpd512_mask ((__v8di) __I
(__v8df) __A,
(__v8df) __B,
(__mmask8) -1);
_mm512_mask_permutex2var_pd (__m512d __A, __mmask8 __U, __m512i __I,
__m512d __B)
(__v8df) __A,
(__v8df) __B,
(__mmask8) __U);
_mm512_mask2_permutex2var_pd (__m512d __A, __m512i __I, __mmask8 __U,
__m512d __B)
return (__m512d) __builtin_ia32_vpermi2varpd512_mask ((__v8df) __A,
(__v8di) __I
(__v8df) __B,
(__mmask8) __U);
_mm512_maskz_permutex2var_pd (__mmask8 __U, __m512d __A, __m512i __I,
__m512d __B)
return (__m512d) __builtin_ia32_vpermt2varpd512_maskz ((__v8di) __I
(__v8df) __A,
(__v8df) __B,
(__mmask8) __U);
_mm512_permutex2var_ps (__m512 __A, __m512i __I, __m512 __B)
return (__m512) __builtin_ia32_vpermt2varps512_mask ((__v16si) __I
(__v16sf) __A,
(__v16sf) __B,
(__mmask16) -1);
_mm512_mask_permutex2var_ps (__m512 __A, __mmask16 __U, __m512i __I, __m512 __B)
(__v16sf) __A,
(__v16sf) __B,
(__mmask16) __U);
_mm512_mask2_permutex2var_ps (__m512 __A, __m512i __I, __mmask16 __U,
__m512 __B)
return (__m512) __builtin_ia32_vpermi2varps512_mask ((__v16sf) __A,
(__v16si) __I
(__v16sf) __B,
(__mmask16) __U);
_mm512_maskz_permutex2var_ps (__mmask16 __U, __m512 __A, __m512i __I,
__m512 __B)
return (__m512) __builtin_ia32_vpermt2varps512_maskz ((__v16si) __I
(__v16sf) __A,
(__v16sf) __B,
(__mmask16) __U);
# 6709 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_maskz_permutexvar_epi64 (__mmask8 __M, __m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_permvardi512_mask ((__v8di) __Y,
(__v8di) __X,
(__v8di)
__M);
_mm512_permutexvar_epi64 (__m512i __X, __m512i __Y)
(__v8di) __X,
(__v8di)
(__mmask8) -1);
_mm512_mask_permutexvar_epi64 (__m512i __W, __mmask8 __M, __m512i __X,
__m512i __Y)
(__v8di) __X,
(__v8di) __W,
__M);
_mm512_maskz_permutexvar_epi32 (__mmask16 __M, __m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_permvarsi512_mask ((__v16si) __Y,
(__v16si) __X,
(__v16si)
__M);
_mm512_permutexvar_epi32 (__m512i __X, __m512i __Y)
(__v16si) __X,
(__v16si)
(__mmask16) -1);
_mm512_mask_permutexvar_epi32 (__m512i __W, __mmask16 __M, __m512i __X,
__m512i __Y)
(__v16si) __X,
(__v16si) __W,
__M);
_mm512_permutexvar_pd (__m512i __X, __m512d __Y)
return (__m512d) __builtin_ia32_permvardf512_mask ((__v8df) __Y,
(__v8di) __X,
(__v8df)
(__mmask8) -1);
_mm512_mask_permutexvar_pd (__m512d __W, __mmask8 __U, __m512i __X, __m512d __Y)
(__v8di) __X,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_permutexvar_pd (__mmask8 __U, __m512i __X, __m512d __Y)
(__v8di) __X,
(__v8df)
(__mmask8) __U);
_mm512_permutexvar_ps (__m512i __X, __m512 __Y)
return (__m512) __builtin_ia32_permvarsf512_mask ((__v16sf) __Y,
(__v16si) __X,
(__v16sf)
(__mmask16) -1);
_mm512_mask_permutexvar_ps (__m512 __W, __mmask16 __U, __m512i __X, __m512 __Y)
(__v16si) __X,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_permutexvar_ps (__mmask16 __U, __m512i __X, __m512 __Y)
(__v16si) __X,
(__v16sf)
(__mmask16) __U);
# 7144 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_movehdup_ps (__m512 __A)
return (__m512) __builtin_ia32_movshdup512_mask ((__v16sf) __A,
(__v16sf)
(__mmask16) -1);
_mm512_mask_movehdup_ps (__m512 __W, __mmask16 __U, __m512 __A)
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_movehdup_ps (__mmask16 __U, __m512 __A)
(__v16sf)
(__mmask16) __U);
_mm512_moveldup_ps (__m512 __A)
return (__m512) __builtin_ia32_movsldup512_mask ((__v16sf) __A,
(__v16sf)
(__mmask16) -1);
_mm512_mask_moveldup_ps (__m512 __W, __mmask16 __U, __m512 __A)
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_moveldup_ps (__mmask16 __U, __m512 __A)
(__v16sf)
(__mmask16) __U);
_mm512_or_si512 (__m512i __A, __m512i __B)
return (__m512i) ((__v16su) __A | (__v16su) __B);
_mm512_or_epi32 (__m512i __A, __m512i __B)
_mm512_mask_or_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pord512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_or_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_or_epi64 (__m512i __A, __m512i __B)
return (__m512i) ((__v8du) __A | (__v8du) __B);
_mm512_mask_or_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_porq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_or_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
_mm512_xor_si512 (__m512i __A, __m512i __B)
return (__m512i) ((__v16su) __A ^ (__v16su) __B);
_mm512_xor_epi32 (__m512i __A, __m512i __B)
_mm512_mask_xor_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pxord512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_xor_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_xor_epi64 (__m512i __A, __m512i __B)
return (__m512i) ((__v8du) __A ^ (__v8du) __B);
_mm512_mask_xor_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pxorq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_xor_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
# 7509 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_and_si512 (__m512i __A, __m512i __B)
return (__m512i) ((__v16su) __A & (__v16su) __B);
_mm512_and_epi32 (__m512i __A, __m512i __B)
_mm512_mask_and_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pandd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_and_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_and_epi64 (__m512i __A, __m512i __B)
return (__m512i) ((__v8du) __A & (__v8du) __B);
_mm512_mask_and_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pandq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di) __W, __U);
_mm512_maskz_and_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
__U);
_mm512_andnot_si512 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pandnd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_andnot_epi32 (__m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_andnot_epi32 (__m512i __W, __mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_andnot_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_andnot_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pandnq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_andnot_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W, __U);
_mm512_maskz_andnot_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
__U);
_mm512_test_epi32_mask (__m512i __A, __m512i __B)
return (__mmask16) __builtin_ia32_ptestmd512 ((__v16si) __A,
(__v16si) __B,
(__mmask16) -1);
_mm512_mask_test_epi32_mask (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B, __U);
extern __inline __mmask8
_mm512_test_epi64_mask (__m512i __A, __m512i __B)
return (__mmask8) __builtin_ia32_ptestmq512 ((__v8di) __A,
(__v8di) __B,
(__mmask8) -1);
_mm512_mask_test_epi64_mask (__mmask8 __U, __m512i __A, __m512i __B)
return (__mmask8) __builtin_ia32_ptestmq512 ((__v8di) __A, (__v8di) __B, __U);
_mm512_testn_epi32_mask (__m512i __A, __m512i __B)
return (__mmask16) __builtin_ia32_ptestnmd512 ((__v16si) __A,
(__v16si) __B,
(__mmask16) -1);
_mm512_mask_testn_epi32_mask (__mmask16 __U, __m512i __A, __m512i __B)
_mm512_testn_epi64_mask (__m512i __A, __m512i __B)
return (__mmask8) __builtin_ia32_ptestnmq512 ((__v8di) __A,
(__v8di) __B,
(__mmask8) -1);
_mm512_mask_testn_epi64_mask (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B, __U);
_mm512_abs_ps (__m512 __A)
return (__m512) _mm512_and_epi32 ((__m512i) __A,
_mm512_set1_epi32 (0x7fffffff));
_mm512_mask_abs_ps (__m512 __W, __mmask16 __U, __m512 __A)
return (__m512) _mm512_mask_and_epi32 ((__m512i) __W, __U, (__m512i) __A,
_mm512_abs_pd (__m512d __A)
return (__m512d) _mm512_and_epi64 ((__m512i) __A,
_mm512_set1_epi64 (0x7fffffffffffffffLL));
_mm512_mask_abs_pd (__m512d __W, __mmask8 __U, __m512d __A)
return (__m512d)
_mm512_mask_and_epi64 ((__m512i) __W, __U, (__m512i) __A,
_mm512_unpackhi_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpckhdq512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_unpackhi_epi32 (__m512i __W, __mmask16 __U, __m512i __A,
__m512i __B)
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_unpackhi_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_unpackhi_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpckhqdq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_unpackhi_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_unpackhi_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
_mm512_unpacklo_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpckldq512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_unpacklo_epi32 (__m512i __W, __mmask16 __U, __m512i __A,
__m512i __B)
(__v16si) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_unpacklo_epi32 (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
(__mmask16) __U);
_mm512_unpacklo_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpcklqdq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_unpacklo_epi64 (__m512i __W, __mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_unpacklo_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
# 8127 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_movedup_pd (__m512d __A)
return (__m512d) __builtin_ia32_movddup512_mask ((__v8df) __A,
(__v8df)
(__mmask8) -1);
_mm512_mask_movedup_pd (__m512d __W, __mmask8 __U, __m512d __A)
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_movedup_pd (__mmask8 __U, __m512d __A)
(__v8df)
(__mmask8) __U);
_mm512_unpacklo_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_unpcklpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1);
_mm512_mask_unpacklo_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_unpacklo_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U);
_mm512_unpackhi_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_unpckhpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1);
_mm512_mask_unpackhi_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_unpackhi_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U);
_mm512_unpackhi_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_unpckhps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1);
_mm512_mask_unpackhi_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_unpackhi_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U);
# 8481 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_stream_si512 (__m512i * __P, __m512i __A)
__builtin_ia32_movntdq512 ((__v8di *) __P, (__v8di) __A);
_mm512_stream_ps (float *__P, __m512 __A)
__builtin_ia32_movntps512 (__P, (__v16sf) __A);
_mm512_stream_pd (double *__P, __m512d __A)
__builtin_ia32_movntpd512 (__P, (__v8df) __A);
_mm512_stream_load_si512 (void *__P)
return __builtin_ia32_movntdqa512 ((__v8di *)__P);
typedef enum
_MM_MANT_NORM_1_2,
_MM_MANT_NORM_p5_2,
_MM_MANT_NORM_p5_1,
_MM_MANT_NORM_p75_1p5
} _MM_MANTISSA_NORM_ENUM;
typedef enum
_MM_MANT_SIGN_src,
_MM_MANT_SIGN_zero,
_MM_MANT_SIGN_nan
} _MM_MANTISSA_SIGN_ENUM;
# 9046 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_floor_ps (__m512 __A)
return (__m512) __builtin_ia32_rndscaleps_mask ((__v16sf) __A,
(0x01 | 0x00),
(__v16sf) __A, -1,
0x04);
_mm512_floor_pd (__m512d __A)
return (__m512d) __builtin_ia32_rndscalepd_mask ((__v8df) __A,
(0x01 | 0x00),
(__v8df) __A, -1,
0x04);
_mm512_ceil_ps (__m512 __A)
(0x02 | 0x00),
(__v16sf) __A, -1,
0x04);
_mm512_ceil_pd (__m512d __A)
(0x02 | 0x00),
(__v8df) __A, -1,
0x04);
_mm512_mask_floor_ps (__m512 __W, __mmask16 __U, __m512 __A)
(0x01 | 0x00),
(__v16sf) __W, __U,
0x04);
_mm512_mask_floor_pd (__m512d __W, __mmask8 __U, __m512d __A)
(0x01 | 0x00),
(__v8df) __W, __U,
0x04);
_mm512_mask_ceil_ps (__m512 __W, __mmask16 __U, __m512 __A)
(0x02 | 0x00),
(__v16sf) __W, __U,
0x04);
_mm512_mask_ceil_pd (__m512d __W, __mmask8 __U, __m512d __A)
(0x02 | 0x00),
(__v8df) __W, __U,
0x04);
# 9225 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_cmpeq_epi32_mask (__m512i __A, __m512i __B)
return (__mmask16) __builtin_ia32_pcmpeqd512_mask ((__v16si) __A,
(__v16si) __B,
(__mmask16) -1);
_mm512_mask_cmpeq_epi32_mask (__mmask16 __U, __m512i __A, __m512i __B)
_mm512_mask_cmpeq_epi64_mask (__mmask8 __U, __m512i __A, __m512i __B)
return (__mmask8) __builtin_ia32_pcmpeqq512_mask ((__v8di) __A,
(__v8di) __B, __U);
_mm512_cmpeq_epi64_mask (__m512i __A, __m512i __B)
(__v8di) __B,
(__mmask8) -1);
_mm512_cmpgt_epi32_mask (__m512i __A, __m512i __B)
return (__mmask16) __builtin_ia32_pcmpgtd512_mask ((__v16si) __A,
(__v16si) __B,
(__mmask16) -1);
_mm512_mask_cmpgt_epi32_mask (__mmask16 __U, __m512i __A, __m512i __B)
_mm512_mask_cmpgt_epi64_mask (__mmask8 __U, __m512i __A, __m512i __B)
return (__mmask8) __builtin_ia32_pcmpgtq512_mask ((__v8di) __A,
(__v8di) __B, __U);
_mm512_cmpgt_epi64_mask (__m512i __A, __m512i __B)
(__v8di) __B,
(__mmask8) -1);
_mm512_cmpge_epi32_mask (__m512i __X, __m512i __Y)
return (__mmask16) __builtin_ia32_cmpd512_mask ((__v16si) __X,
(__v16si) __Y, 5,
(__mmask16) -1);
_mm512_mask_cmpge_epi32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 5,
(__mmask16) __M);
_mm512_mask_cmpge_epu32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
return (__mmask16) __builtin_ia32_ucmpd512_mask ((__v16si) __X,
(__v16si) __Y, 5,
(__mmask16) __M);
_mm512_cmpge_epu32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 5,
(__mmask16) -1);
_mm512_mask_cmpge_epi64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
return (__mmask8) __builtin_ia32_cmpq512_mask ((__v8di) __X,
(__v8di) __Y, 5,
(__mmask8) __M);
_mm512_cmpge_epi64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 5,
(__mmask8) -1);
_mm512_mask_cmpge_epu64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
return (__mmask8) __builtin_ia32_ucmpq512_mask ((__v8di) __X,
(__v8di) __Y, 5,
(__mmask8) __M);
_mm512_cmpge_epu64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 5,
(__mmask8) -1);
_mm512_mask_cmple_epi32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 2,
(__mmask16) __M);
_mm512_cmple_epi32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 2,
(__mmask16) -1);
_mm512_mask_cmple_epu32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 2,
(__mmask16) __M);
_mm512_cmple_epu32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 2,
(__mmask16) -1);
_mm512_mask_cmple_epi64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
(__v8di) __Y, 2,
(__mmask8) __M);
_mm512_cmple_epi64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 2,
(__mmask8) -1);
_mm512_mask_cmple_epu64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
(__v8di) __Y, 2,
(__mmask8) __M);
_mm512_cmple_epu64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 2,
(__mmask8) -1);
_mm512_mask_cmplt_epi32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 1,
(__mmask16) __M);
_mm512_cmplt_epi32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 1,
(__mmask16) -1);
_mm512_mask_cmplt_epu32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 1,
(__mmask16) __M);
_mm512_cmplt_epu32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 1,
(__mmask16) -1);
_mm512_mask_cmplt_epi64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
(__v8di) __Y, 1,
(__mmask8) __M);
_mm512_cmplt_epi64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 1,
(__mmask8) -1);
_mm512_mask_cmplt_epu64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
(__v8di) __Y, 1,
(__mmask8) __M);
_mm512_cmplt_epu64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 1,
(__mmask8) -1);
_mm512_cmpneq_epi32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 4,
(__mmask16) -1);
_mm512_mask_cmpneq_epi32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 4,
(__mmask16) __M);
_mm512_mask_cmpneq_epu32_mask (__mmask16 __M, __m512i __X, __m512i __Y)
(__v16si) __Y, 4,
(__mmask16) __M);
_mm512_cmpneq_epu32_mask (__m512i __X, __m512i __Y)
(__v16si) __Y, 4,
(__mmask16) -1);
_mm512_mask_cmpneq_epi64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
(__v8di) __Y, 4,
(__mmask8) __M);
_mm512_cmpneq_epi64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 4,
(__mmask8) -1);
_mm512_mask_cmpneq_epu64_mask (__mmask8 __M, __m512i __X, __m512i __Y)
(__v8di) __Y, 4,
(__mmask8) __M);
_mm512_cmpneq_epu64_mask (__m512i __X, __m512i __Y)
(__v8di) __Y, 4,
(__mmask8) -1);
# 10363 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_mask_compress_pd (__m512d __W, __mmask8 __U, __m512d __A)
return (__m512d) __builtin_ia32_compressdf512_mask ((__v8df) __A,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_compress_pd (__mmask8 __U, __m512d __A)
(__v8df)
(__mmask8) __U);
_mm512_mask_compressstoreu_pd (void *__P, __mmask8 __U, __m512d __A)
__builtin_ia32_compressstoredf512_mask ((__v8df *) __P, (__v8df) __A,
(__mmask8) __U);
_mm512_mask_compress_ps (__m512 __W, __mmask16 __U, __m512 __A)
return (__m512) __builtin_ia32_compresssf512_mask ((__v16sf) __A,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_compress_ps (__mmask16 __U, __m512 __A)
(__v16sf)
(__mmask16) __U);
_mm512_mask_compressstoreu_ps (void *__P, __mmask16 __U, __m512 __A)
__builtin_ia32_compressstoresf512_mask ((__v16sf *) __P, (__v16sf) __A,
(__mmask16) __U);
extern __inline __m512i
_mm512_mask_compress_epi64 (__m512i __W, __mmask8 __U, __m512i __A)
return (__m512i) __builtin_ia32_compressdi512_mask ((__v8di) __A,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_compress_epi64 (__mmask8 __U, __m512i __A)
(__v8di)
(__mmask8) __U);
_mm512_mask_compressstoreu_epi64 (void *__P, __mmask8 __U, __m512i __A)
__builtin_ia32_compressstoredi512_mask ((__v8di *) __P, (__v8di) __A,
(__mmask8) __U);
_mm512_mask_compress_epi32 (__m512i __W, __mmask16 __U, __m512i __A)
return (__m512i) __builtin_ia32_compresssi512_mask ((__v16si) __A,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_compress_epi32 (__mmask16 __U, __m512i __A)
(__v16si)
(__mmask16) __U);
_mm512_mask_compressstoreu_epi32 (void *__P, __mmask16 __U, __m512i __A)
__builtin_ia32_compressstoresi512_mask ((__v16si *) __P, (__v16si) __A,
(__mmask16) __U);
extern __inline __m512d
_mm512_mask_expand_pd (__m512d __W, __mmask8 __U, __m512d __A)
return (__m512d) __builtin_ia32_expanddf512_mask ((__v8df) __A,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_expand_pd (__mmask8 __U, __m512d __A)
return (__m512d) __builtin_ia32_expanddf512_maskz ((__v8df) __A,
(__v8df)
(__mmask8) __U);
_mm512_mask_expandloadu_pd (__m512d __W, __mmask8 __U, void const *__P)
return (__m512d) __builtin_ia32_expandloaddf512_mask ((const __v8df *) __P,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_expandloadu_pd (__mmask8 __U, void const *__P)
return (__m512d) __builtin_ia32_expandloaddf512_maskz ((const __v8df *) __P,
(__v8df)
(__mmask8) __U);
_mm512_mask_expand_ps (__m512 __W, __mmask16 __U, __m512 __A)
return (__m512) __builtin_ia32_expandsf512_mask ((__v16sf) __A,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_expand_ps (__mmask16 __U, __m512 __A)
return (__m512) __builtin_ia32_expandsf512_maskz ((__v16sf) __A,
(__v16sf)
(__mmask16) __U);
_mm512_mask_expandloadu_ps (__m512 __W, __mmask16 __U, void const *__P)
return (__m512) __builtin_ia32_expandloadsf512_mask ((const __v16sf *) __P,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_expandloadu_ps (__mmask16 __U, void const *__P)
return (__m512) __builtin_ia32_expandloadsf512_maskz ((const __v16sf *) __P,
(__v16sf)
(__mmask16) __U);
_mm512_mask_expand_epi64 (__m512i __W, __mmask8 __U, __m512i __A)
return (__m512i) __builtin_ia32_expanddi512_mask ((__v8di) __A,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_expand_epi64 (__mmask8 __U, __m512i __A)
return (__m512i) __builtin_ia32_expanddi512_maskz ((__v8di) __A,
(__v8di)
(__mmask8) __U);
_mm512_mask_expandloadu_epi64 (__m512i __W, __mmask8 __U, void const *__P)
return (__m512i) __builtin_ia32_expandloaddi512_mask ((const __v8di *) __P,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_expandloadu_epi64 (__mmask8 __U, void const *__P)
return (__m512i)
__builtin_ia32_expandloaddi512_maskz ((const __v8di *) __P,
(__v8di)
(__mmask8) __U);
_mm512_mask_expand_epi32 (__m512i __W, __mmask16 __U, __m512i __A)
return (__m512i) __builtin_ia32_expandsi512_mask ((__v16si) __A,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_expand_epi32 (__mmask16 __U, __m512i __A)
return (__m512i) __builtin_ia32_expandsi512_maskz ((__v16si) __A,
(__v16si)
(__mmask16) __U);
_mm512_mask_expandloadu_epi32 (__m512i __W, __mmask16 __U, void const *__P)
return (__m512i) __builtin_ia32_expandloadsi512_mask ((const __v16si *) __P,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_expandloadu_epi32 (__mmask16 __U, void const *__P)
return (__m512i) __builtin_ia32_expandloadsi512_maskz ((const __v16si *) __P,
(__v16si)
(), (__mmask16) __U);
# 10632 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
extern __inline unsigned char
_kortest_mask16_u8 (__mmask16 __A, __mmask16 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_kortestchi (__A, __B);
return (unsigned char) __builtin_ia32_kortestzhi (__A, __B);
_kortestz_mask16_u8 (__mmask16 __A, __mmask16 __B)
return (unsigned char) __builtin_ia32_kortestzhi ((__mmask16) __A,
(__mmask16) __B);
_kortestc_mask16_u8 (__mmask16 __A, __mmask16 __B)
return (unsigned char) __builtin_ia32_kortestchi ((__mmask16) __A,
(__mmask16) __B);
extern __inline unsigned int
_cvtmask16_u32 (__mmask16 __A)
return (unsigned int) __builtin_ia32_kmovw ((__mmask16 ) __A);
extern __inline __mmask16
_cvtu32_mask16 (unsigned int __A)
return (__mmask16) __builtin_ia32_kmovw ((__mmask16 ) __A);
_load_mask16 (__mmask16 *__A)
return (__mmask16) __builtin_ia32_kmovw (*(__mmask16 *) __A);
_store_mask16 (__mmask16 *__A, __mmask16 __B)
*(__mmask16 *) __A = __builtin_ia32_kmovw (__B);
_mm512_kand (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kandhi ((__mmask16) __A, (__mmask16) __B);
_mm512_kandn (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kandnhi ((__mmask16) __A,
(__mmask16) __B);
_mm512_kor (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_korhi ((__mmask16) __A, (__mmask16) __B);
extern __inline int
_mm512_kortestz (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kortestzhi ((__mmask16) __A,
(__mmask16) __B);
extern __inline int
_mm512_kortestc (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kortestchi ((__mmask16) __A,
(__mmask16) __B);
_mm512_kxnor (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kxnorhi ((__mmask16) __A, (__mmask16) __B);
_mm512_kxor (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kxorhi ((__mmask16) __A, (__mmask16) __B);
_mm512_knot (__mmask16 __A)
return (__mmask16) __builtin_ia32_knothi ((__mmask16) __A);
_mm512_kunpackb (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kunpckhi ((__mmask16) __A, (__mmask16) __B);
_kunpackb_mask16 (__mmask8 __A, __mmask8 __B)
# 10827 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_max_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxsq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_maskz_max_epi64 (__mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
__M);
_mm512_mask_max_epi64 (__m512i __W, __mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W, __M);
_mm512_min_epi64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminsq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
_mm512_undefined_epi32 (),
(__mmask8) -1);
_mm512_mask_min_epi64 (__m512i __W, __mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W, __M);
_mm512_maskz_min_epi64 (__mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
__M);
_mm512_max_epu64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxuq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_maskz_max_epu64 (__mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
__M);
_mm512_mask_max_epu64 (__m512i __W, __mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W, __M);
_mm512_min_epu64 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminuq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di)
(__mmask8) -1);
_mm512_mask_min_epu64 (__m512i __W, __mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di) __W, __M);
_mm512_maskz_min_epu64 (__mmask8 __M, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
__M);
_mm512_max_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxsd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_maskz_max_epi32 (__mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
__M);
_mm512_mask_max_epi32 (__m512i __W, __mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si) __W, __M);
_mm512_min_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminsd512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_maskz_min_epi32 (__mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
__M);
_mm512_mask_min_epi32 (__m512i __W, __mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
_mm512_max_epu32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxud512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_maskz_max_epu32 (__mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
__M);
_mm512_mask_max_epu32 (__m512i __W, __mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
_mm512_min_epu32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminud512_mask ((__v16si) __A,
(__v16si) __B,
(__v16si)
(__mmask16) -1);
_mm512_maskz_min_epu32 (__mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v16si)
__M);
_mm512_mask_min_epu32 (__m512i __W, __mmask16 __M, __m512i __A, __m512i __B)
(__v16si) __B,
_mm512_unpacklo_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_unpcklps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
_mm512_undefined_ps (),
(__mmask16) -1);
_mm512_mask_unpacklo_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_unpacklo_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
_mm512_setzero_ps (),
(__mmask16) __U);
# 11275 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_mask_blend_pd (__mmask8 __U, __m512d __A, __m512d __W)
return (__m512d) __builtin_ia32_blendmpd_512_mask ((__v8df) __A,
(__v8df) __W,
(__mmask8) __U);
_mm512_mask_blend_ps (__mmask16 __U, __m512 __A, __m512 __W)
return (__m512) __builtin_ia32_blendmps_512_mask ((__v16sf) __A,
(__v16sf) __W,
(__mmask16) __U);
_mm512_mask_blend_epi64 (__mmask8 __U, __m512i __A, __m512i __W)
return (__m512i) __builtin_ia32_blendmq_512_mask ((__v8di) __A,
(__v8di) __W,
(__mmask8) __U);
_mm512_mask_blend_epi32 (__mmask16 __U, __m512i __A, __m512i __W)
return (__m512i) __builtin_ia32_blendmd_512_mask ((__v16si) __A,
(__v16si) __W,
(__mmask16) __U);
# 11438 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_sqrt_pd (__m512d __A)
return (__m512d) __builtin_ia32_sqrtpd512_mask ((__v8df) __A,
(__v8df)
_mm512_undefined_pd (),
(__mmask8) -1,
0x04);
_mm512_mask_sqrt_pd (__m512d __W, __mmask8 __U, __m512d __A)
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_sqrt_pd (__mmask8 __U, __m512d __A)
(__v8df)
_mm512_setzero_pd (),
(__mmask8) __U,
0x04);
_mm512_sqrt_ps (__m512 __A)
return (__m512) __builtin_ia32_sqrtps512_mask ((__v16sf) __A,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_sqrt_ps (__m512 __W, __mmask16 __U, __m512 __A)
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_sqrt_ps (__mmask16 __U, __m512 __A)
(__v16sf)
(__mmask16) __U,
0x04);
_mm512_add_pd (__m512d __A, __m512d __B)
return (__m512d) ((__v8df)__A + (__v8df)__B);
_mm512_mask_add_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_addpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_add_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_add_ps (__m512 __A, __m512 __B)
return (__m512) ((__v16sf)__A + (__v16sf)__B);
_mm512_mask_add_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
return (__m512) __builtin_ia32_addps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_add_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
_mm_mask_add_sd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_addsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U,
0x04);
_mm_maskz_add_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U,
0x04);
_mm_mask_add_ss (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_addss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U,
0x04);
_mm_maskz_add_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U,
0x04);
_mm512_sub_pd (__m512d __A, __m512d __B)
return (__m512d) ((__v8df)__A - (__v8df)__B);
_mm512_mask_sub_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_subpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_sub_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_sub_ps (__m512 __A, __m512 __B)
return (__m512) ((__v16sf)__A - (__v16sf)__B);
_mm512_mask_sub_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
return (__m512) __builtin_ia32_subps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_sub_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
_mm_mask_sub_sd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_subsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U,
0x04);
_mm_maskz_sub_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U,
0x04);
_mm_mask_sub_ss (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_subss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U,
0x04);
_mm_maskz_sub_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U,
0x04);
_mm512_mul_pd (__m512d __A, __m512d __B)
return (__m512d) ((__v8df)__A * (__v8df)__B);
_mm512_mask_mul_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_mulpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_mul_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_mul_ps (__m512 __A, __m512 __B)
return (__m512) ((__v16sf)__A * (__v16sf)__B);
_mm512_mask_mul_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
return (__m512) __builtin_ia32_mulps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_mul_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
extern __inline __m128d
_mm_mask_mul_sd (__m128d __W, __mmask8 __U, __m128d __A,
__m128d __B)
return (__m128d) __builtin_ia32_mulsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U,
0x04);
_mm_maskz_mul_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U,
0x04);
_mm_mask_mul_ss (__m128 __W, __mmask8 __U, __m128 __A,
__m128 __B)
return (__m128) __builtin_ia32_mulss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U,
0x04);
_mm_maskz_mul_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U,
0x04);
_mm512_div_pd (__m512d __M, __m512d __V)
return (__m512d) ((__v8df)__M / (__v8df)__V);
_mm512_mask_div_pd (__m512d __W, __mmask8 __U, __m512d __M, __m512d __V)
return (__m512d) __builtin_ia32_divpd512_mask ((__v8df) __M,
(__v8df) __V,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_div_pd (__mmask8 __U, __m512d __M, __m512d __V)
(__v8df) __V,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_div_ps (__m512 __A, __m512 __B)
return (__m512) ((__v16sf)__A / (__v16sf)__B);
_mm512_mask_div_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
return (__m512) __builtin_ia32_divps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_div_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
_mm_mask_div_sd (__m128d __W, __mmask8 __U, __m128d __A,
__m128d __B)
return (__m128d) __builtin_ia32_divsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U,
0x04);
_mm_maskz_div_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U,
0x04);
_mm_mask_div_ss (__m128 __W, __mmask8 __U, __m128 __A,
__m128 __B)
return (__m128) __builtin_ia32_divss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U,
0x04);
_mm_maskz_div_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U,
0x04);
_mm512_max_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_maxpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1,
0x04);
_mm512_mask_max_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_max_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_max_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_maxps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_max_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_max_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
_mm_mask_max_sd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_maxsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U,
0x04);
_mm_maskz_max_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U,
0x04);
_mm_mask_max_ss (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_maxss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U,
0x04);
_mm_maskz_max_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U,
0x04);
_mm512_min_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_minpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1,
0x04);
_mm512_mask_min_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_min_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_min_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_minps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_min_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_min_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
_mm_mask_min_sd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_minsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U,
0x04);
_mm_maskz_min_sd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U,
0x04);
_mm_mask_min_ss (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_minss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U,
0x04);
_mm_maskz_min_ss (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U,
0x04);
_mm512_scalef_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_scalefpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1,
0x04);
_mm512_mask_scalef_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_scalef_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U,
0x04);
_mm512_scalef_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_scalefps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_scalef_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_scalef_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U,
0x04);
_mm_scalef_sd (__m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_scalefsd_mask_round ((__v2df) __A,
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1,
0x04);
_mm_scalef_ss (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_scalefss_mask_round ((__v4sf) __A,
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1,
0x04);
_mm512_fmadd_pd (__m512d __A, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfmaddpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) -1,
0x04);
_mm512_mask_fmadd_pd (__m512d __A, __mmask8 __U, __m512d __B, __m512d __C)
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_mask3_fmadd_pd (__m512d __A, __m512d __B, __m512d __C, __mmask8 __U)
return (__m512d) __builtin_ia32_vfmaddpd512_mask3 ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_maskz_fmadd_pd (__mmask8 __U, __m512d __A, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfmaddpd512_maskz ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_fmadd_ps (__m512 __A, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfmaddps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) -1,
0x04);
_mm512_mask_fmadd_ps (__m512 __A, __mmask16 __U, __m512 __B, __m512 __C)
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_mask3_fmadd_ps (__m512 __A, __m512 __B, __m512 __C, __mmask16 __U)
return (__m512) __builtin_ia32_vfmaddps512_mask3 ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_maskz_fmadd_ps (__mmask16 __U, __m512 __A, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfmaddps512_maskz ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_fmsub_pd (__m512d __A, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) -1,
0x04);
_mm512_mask_fmsub_pd (__m512d __A, __mmask8 __U, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_mask3_fmsub_pd (__m512d __A, __m512d __B, __m512d __C, __mmask8 __U)
return (__m512d) __builtin_ia32_vfmsubpd512_mask3 ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_maskz_fmsub_pd (__mmask8 __U, __m512d __A, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_fmsub_ps (__m512 __A, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) -1,
0x04);
_mm512_mask_fmsub_ps (__m512 __A, __mmask16 __U, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_mask3_fmsub_ps (__m512 __A, __m512 __B, __m512 __C, __mmask16 __U)
return (__m512) __builtin_ia32_vfmsubps512_mask3 ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_maskz_fmsub_ps (__mmask16 __U, __m512 __A, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_fmaddsub_pd (__m512d __A, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfmaddsubpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) -1,
0x04);
_mm512_mask_fmaddsub_pd (__m512d __A, __mmask8 __U, __m512d __B, __m512d __C)
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_mask3_fmaddsub_pd (__m512d __A, __m512d __B, __m512d __C, __mmask8 __U)
return (__m512d) __builtin_ia32_vfmaddsubpd512_mask3 ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_maskz_fmaddsub_pd (__mmask8 __U, __m512d __A, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfmaddsubpd512_maskz ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_fmaddsub_ps (__m512 __A, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfmaddsubps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) -1,
0x04);
_mm512_mask_fmaddsub_ps (__m512 __A, __mmask16 __U, __m512 __B, __m512 __C)
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_mask3_fmaddsub_ps (__m512 __A, __m512 __B, __m512 __C, __mmask16 __U)
return (__m512) __builtin_ia32_vfmaddsubps512_mask3 ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_maskz_fmaddsub_ps (__mmask16 __U, __m512 __A, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfmaddsubps512_maskz ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_fmsubadd_pd (__m512d __A, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) -1,
0x04);
_mm512_mask_fmsubadd_pd (__m512d __A, __mmask8 __U, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_mask3_fmsubadd_pd (__m512d __A, __m512d __B, __m512d __C, __mmask8 __U)
return (__m512d) __builtin_ia32_vfmsubaddpd512_mask3 ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_maskz_fmsubadd_pd (__mmask8 __U, __m512d __A, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_fmsubadd_ps (__m512 __A, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) -1,
0x04);
_mm512_mask_fmsubadd_ps (__m512 __A, __mmask16 __U, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_mask3_fmsubadd_ps (__m512 __A, __m512 __B, __m512 __C, __mmask16 __U)
return (__m512) __builtin_ia32_vfmsubaddps512_mask3 ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_maskz_fmsubadd_ps (__mmask16 __U, __m512 __A, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_fnmadd_pd (__m512d __A, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfmaddpd512_mask (-(__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) -1,
0x04);
_mm512_mask_fnmadd_pd (__m512d __A, __mmask8 __U, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfnmaddpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_mask3_fnmadd_pd (__m512d __A, __m512d __B, __m512d __C, __mmask8 __U)
return (__m512d) __builtin_ia32_vfmaddpd512_mask3 (-(__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_maskz_fnmadd_pd (__mmask8 __U, __m512d __A, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfmaddpd512_maskz (-(__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_fnmadd_ps (__m512 __A, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfmaddps512_mask (-(__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) -1,
0x04);
_mm512_mask_fnmadd_ps (__m512 __A, __mmask16 __U, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfnmaddps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_mask3_fnmadd_ps (__m512 __A, __m512 __B, __m512 __C, __mmask16 __U)
return (__m512) __builtin_ia32_vfmaddps512_mask3 (-(__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_maskz_fnmadd_ps (__mmask16 __U, __m512 __A, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfmaddps512_maskz (-(__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_fnmsub_pd (__m512d __A, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) -1,
0x04);
_mm512_mask_fnmsub_pd (__m512d __A, __mmask8 __U, __m512d __B, __m512d __C)
return (__m512d) __builtin_ia32_vfnmsubpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_mask3_fnmsub_pd (__m512d __A, __m512d __B, __m512d __C, __mmask8 __U)
return (__m512d) __builtin_ia32_vfnmsubpd512_mask3 ((__v8df) __A,
(__v8df) __B,
(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_maskz_fnmsub_pd (__mmask8 __U, __m512d __A, __m512d __B, __m512d __C)
(__v8df) __B,
-(__v8df) __C,
(__mmask8) __U,
0x04);
_mm512_fnmsub_ps (__m512 __A, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) -1,
0x04);
_mm512_mask_fnmsub_ps (__m512 __A, __mmask16 __U, __m512 __B, __m512 __C)
return (__m512) __builtin_ia32_vfnmsubps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_mask3_fnmsub_ps (__m512 __A, __m512 __B, __m512 __C, __mmask16 __U)
return (__m512) __builtin_ia32_vfnmsubps512_mask3 ((__v16sf) __A,
(__v16sf) __B,
(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_maskz_fnmsub_ps (__mmask16 __U, __m512 __A, __m512 __B, __m512 __C)
(__v16sf) __B,
-(__v16sf) __C,
(__mmask16) __U,
0x04);
_mm512_cvttpd_epi32 (__m512d __A)
return (__m256i) __builtin_ia32_cvttpd2dq512_mask ((__v8df) __A,
(__v8si)
(__mmask8) -1,
0x04);
_mm512_mask_cvttpd_epi32 (__m256i __W, __mmask8 __U, __m512d __A)
(__v8si) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvttpd_epi32 (__mmask8 __U, __m512d __A)
(__v8si)
(__mmask8) __U,
0x04);
_mm512_cvttpd_epu32 (__m512d __A)
return (__m256i) __builtin_ia32_cvttpd2udq512_mask ((__v8df) __A,
(__v8si)
(__mmask8) -1,
0x04);
_mm512_mask_cvttpd_epu32 (__m256i __W, __mmask8 __U, __m512d __A)
(__v8si) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvttpd_epu32 (__mmask8 __U, __m512d __A)
(__v8si)
(__mmask8) __U,
0x04);
_mm512_cvtpd_epi32 (__m512d __A)
return (__m256i) __builtin_ia32_cvtpd2dq512_mask ((__v8df) __A,
(__v8si)
(__mmask8) -1,
0x04);
_mm512_mask_cvtpd_epi32 (__m256i __W, __mmask8 __U, __m512d __A)
(__v8si) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtpd_epi32 (__mmask8 __U, __m512d __A)
(__v8si)
(__mmask8) __U,
0x04);
_mm512_cvtpd_epu32 (__m512d __A)
return (__m256i) __builtin_ia32_cvtpd2udq512_mask ((__v8df) __A,
(__v8si)
(__mmask8) -1,
0x04);
_mm512_mask_cvtpd_epu32 (__m256i __W, __mmask8 __U, __m512d __A)
(__v8si) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtpd_epu32 (__mmask8 __U, __m512d __A)
(__v8si)
(__mmask8) __U,
0x04);
_mm512_cvttps_epi32 (__m512 __A)
return (__m512i) __builtin_ia32_cvttps2dq512_mask ((__v16sf) __A,
(__v16si)
(__mmask16) -1,
0x04);
_mm512_mask_cvttps_epi32 (__m512i __W, __mmask16 __U, __m512 __A)
(__v16si) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvttps_epi32 (__mmask16 __U, __m512 __A)
(__v16si)
_mm512_setzero_si512 (),
(__mmask16) __U,
0x04);
_mm512_cvttps_epu32 (__m512 __A)
return (__m512i) __builtin_ia32_cvttps2udq512_mask ((__v16sf) __A,
(__v16si)
(__mmask16) -1,
0x04);
_mm512_mask_cvttps_epu32 (__m512i __W, __mmask16 __U, __m512 __A)
(__v16si) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvttps_epu32 (__mmask16 __U, __m512 __A)
(__v16si)
(__mmask16) __U,
0x04);
_mm512_cvtps_epi32 (__m512 __A)
return (__m512i) __builtin_ia32_cvtps2dq512_mask ((__v16sf) __A,
(__v16si)
(__mmask16) -1,
0x04);
_mm512_mask_cvtps_epi32 (__m512i __W, __mmask16 __U, __m512 __A)
(__v16si) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvtps_epi32 (__mmask16 __U, __m512 __A)
(__v16si)
(__mmask16) __U,
0x04);
_mm512_cvtps_epu32 (__m512 __A)
return (__m512i) __builtin_ia32_cvtps2udq512_mask ((__v16sf) __A,
(__v16si)
(__mmask16) -1,
0x04);
_mm512_mask_cvtps_epu32 (__m512i __W, __mmask16 __U, __m512 __A)
(__v16si) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvtps_epu32 (__mmask16 __U, __m512 __A)
(__v16si)
(__mmask16) __U,
0x04);
extern __inline double
_mm512_cvtsd_f64 (__m512d __A)
return __A[0];
extern __inline float
_mm512_cvtss_f32 (__m512 __A)
return __A[0];
_mm_cvtu64_ss (__m128 __A, unsigned long long __B)
return (__m128) __builtin_ia32_cvtusi2ss64 ((__v4sf) __A, __B,
0x04);
_mm_cvtu64_sd (__m128d __A, unsigned long long __B)
return (__m128d) __builtin_ia32_cvtusi2sd64 ((__v2df) __A, __B,
0x04);
_mm_cvtu32_ss (__m128 __A, unsigned __B)
return (__m128) __builtin_ia32_cvtusi2ss32 ((__v4sf) __A, __B,
0x04);
_mm512_cvtepi32_ps (__m512i __A)
return (__m512) __builtin_ia32_cvtdq2ps512_mask ((__v16si) __A,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_cvtepi32_ps (__m512 __W, __mmask16 __U, __m512i __A)
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvtepi32_ps (__mmask16 __U, __m512i __A)
(__v16sf)
(__mmask16) __U,
0x04);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm512_cvtepu32_ps (__m512i __A)
return (__m512) __builtin_ia32_cvtudq2ps512_mask ((__v16si) __A,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_cvtepu32_ps (__m512 __W, __mmask16 __U, __m512i __A)
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvtepu32_ps (__mmask16 __U, __m512i __A)
(__v16sf)
(__mmask16) __U,
0x04);
# 13354 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
extern __inline unsigned long long
_mm_cvtss_u64 (__m128 __A)
return (unsigned long long) __builtin_ia32_vcvtss2usi64 ((__v4sf)
__A,
0x04);
_mm_cvttss_u64 (__m128 __A)
return (unsigned long long) __builtin_ia32_vcvttss2usi64 ((__v4sf)
__A,
0x04);
extern __inline long long
_mm_cvttss_i64 (__m128 __A)
return (long long) __builtin_ia32_vcvttss2si64 ((__v4sf) __A,
0x04);
_mm_cvtss_u32 (__m128 __A)
return (unsigned) __builtin_ia32_vcvtss2usi32 ((__v4sf) __A,
0x04);
_mm_cvttss_u32 (__m128 __A)
return (unsigned) __builtin_ia32_vcvttss2usi32 ((__v4sf) __A,
0x04);
extern __inline int
_mm_cvttss_i32 (__m128 __A)
return (int) __builtin_ia32_vcvttss2si32 ((__v4sf) __A,
0x04);
_mm_cvtsd_u64 (__m128d __A)
return (unsigned long long) __builtin_ia32_vcvtsd2usi64 ((__v2df)
__A,
0x04);
_mm_cvttsd_u64 (__m128d __A)
return (unsigned long long) __builtin_ia32_vcvttsd2usi64 ((__v2df)
__A,
0x04);
_mm_cvttsd_i64 (__m128d __A)
return (long long) __builtin_ia32_vcvttsd2si64 ((__v2df) __A,
0x04);
_mm_cvtsd_u32 (__m128d __A)
return (unsigned) __builtin_ia32_vcvtsd2usi32 ((__v2df) __A,
0x04);
_mm_cvttsd_u32 (__m128d __A)
return (unsigned) __builtin_ia32_vcvttsd2usi32 ((__v2df) __A,
0x04);
extern __inline int
_mm_cvttsd_i32 (__m128d __A)
return (int) __builtin_ia32_vcvttsd2si32 ((__v2df) __A,
0x04);
_mm512_cvtps_pd (__m256 __A)
return (__m512d) __builtin_ia32_cvtps2pd512_mask ((__v8sf) __A,
(__v8df)
(__mmask8) -1,
0x04);
_mm512_mask_cvtps_pd (__m512d __W, __mmask8 __U, __m256 __A)
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtps_pd (__mmask8 __U, __m256 __A)
(__v8df)
(__mmask8) __U,
0x04);
_mm512_cvtph_ps (__m256i __A)
return (__m512) __builtin_ia32_vcvtph2ps512_mask ((__v16hi) __A,
(__v16sf)
(__mmask16) -1,
0x04);
_mm512_mask_cvtph_ps (__m512 __W, __mmask16 __U, __m256i __A)
(__v16sf) __W,
(__mmask16) __U,
0x04);
_mm512_maskz_cvtph_ps (__mmask16 __U, __m256i __A)
(__v16sf)
(__mmask16) __U,
0x04);
extern __inline __m256
_mm512_cvtpd_ps (__m512d __A)
return (__m256) __builtin_ia32_cvtpd2ps512_mask ((__v8df) __A,
(__v8sf)
_mm256_undefined_ps (),
(__mmask8) -1,
0x04);
_mm512_mask_cvtpd_ps (__m256 __W, __mmask8 __U, __m512d __A)
(__v8sf) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtpd_ps (__mmask8 __U, __m512d __A)
(__v8sf)
_mm256_setzero_ps (),
(__mmask8) __U,
0x04);
# 14529 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_kmov (__mmask16 __A)
return __builtin_ia32_kmovw (__A);
_mm512_castpd_ps (__m512d __A)
return (__m512) (__A);
_mm512_castpd_si512 (__m512d __A)
return (__m512i) (__A);
_mm512_castps_pd (__m512 __A)
return (__m512d) (__A);
_mm512_castps_si512 (__m512 __A)
_mm512_castsi512_ps (__m512i __A)
_mm512_castsi512_pd (__m512i __A)
_mm512_castpd512_pd128 (__m512d __A)
return (__m128d)((__m128) __builtin_ia32_extractf32x4_mask ((__v16sf)(__m512) ((__m512)__A), (int) (0), (__v4sf)(__m128)_mm_undefined_ps(), (__mmask8)-1));
_mm512_castps512_ps128 (__m512 __A)
return ((__m128) __builtin_ia32_extractf32x4_mask ((__v16sf)(__m512) (__A), (int) (0), (__v4sf)(__m128)_mm_undefined_ps(), (__mmask8)-1));
extern __inline __m128i
_mm512_castsi512_si128 (__m512i __A)
return (__m128i)((__m128i) __builtin_ia32_extracti32x4_mask ((__v16si)(__m512i) ((__m512i)__A), (int) (0), (__v4si)(__m128i)_mm_undefined_si128 (), (__mmask8)-1));
extern __inline __m256d
_mm512_castpd512_pd256 (__m512d __A)
return ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1));
_mm512_castps512_ps256 (__m512 __A)
return (__m256)((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d)__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1));
extern __inline __m256i
_mm512_castsi512_si256 (__m512i __A)
return (__m256i)((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d)__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1));
_mm512_castpd128_pd512 (__m128d __A)
return (__m512d) __builtin_ia32_pd512_pd((__m128d)__A);
_mm512_castps128_ps512 (__m128 __A)
return (__m512) __builtin_ia32_ps512_ps((__m128)__A);
_mm512_castsi128_si512 (__m128i __A)
return (__m512i) __builtin_ia32_si512_si((__v4si)__A);
_mm512_castpd256_pd512 (__m256d __A)
return __builtin_ia32_pd512_256pd (__A);
_mm512_castps256_ps512 (__m256 __A)
return __builtin_ia32_ps512_256ps (__A);
_mm512_castsi256_si512 (__m256i __A)
return (__m512i)__builtin_ia32_si512_256si ((__v8si)__A);
_mm512_cmpeq_epu32_mask (__m512i __A, __m512i __B)
return (__mmask16) __builtin_ia32_ucmpd512_mask ((__v16si) __A,
(__v16si) __B, 0,
(__mmask16) -1);
_mm512_mask_cmpeq_epu32_mask (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B, 0, __U);
_mm512_mask_cmpeq_epu64_mask (__mmask8 __U, __m512i __A, __m512i __B)
return (__mmask8) __builtin_ia32_ucmpq512_mask ((__v8di) __A,
(__v8di) __B, 0, __U);
_mm512_cmpeq_epu64_mask (__m512i __A, __m512i __B)
(__v8di) __B, 0,
(__mmask8) -1);
_mm512_cmpgt_epu32_mask (__m512i __A, __m512i __B)
(__v16si) __B, 6,
(__mmask16) -1);
_mm512_mask_cmpgt_epu32_mask (__mmask16 __U, __m512i __A, __m512i __B)
(__v16si) __B, 6, __U);
_mm512_mask_cmpgt_epu64_mask (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B, 6, __U);
_mm512_cmpgt_epu64_mask (__m512i __A, __m512i __B)
(__v8di) __B, 6,
(__mmask8) -1);
# 14742 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
extern __inline int
_mm512_reduce_add_epi32 (__m512i __A)
__v8si __T1 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v8si __T2 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 + __T2); __v4si __T4 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v4si __T5 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v4si __T6 = __T4 + __T5; __v4si __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __v4si __T8 = __T6 + __T7; return __T8[0] + __T8[1];
extern __inline int
_mm512_reduce_mul_epi32 (__m512i __A)
__v8si __T1 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v8si __T2 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 * __T2); __v4si __T4 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v4si __T5 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v4si __T6 = __T4 * __T5; __v4si __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __v4si __T8 = __T6 * __T7; return __T8[0] * __T8[1];
extern __inline int
_mm512_reduce_and_epi32 (__m512i __A)
__v8si __T1 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v8si __T2 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 & __T2); __v4si __T4 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v4si __T5 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v4si __T6 = __T4 & __T5; __v4si __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __v4si __T8 = __T6 & __T7; return __T8[0] & __T8[1];
extern __inline int
_mm512_reduce_or_epi32 (__m512i __A)
__v8si __T1 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v8si __T2 = (__v8si) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 | __T2); __v4si __T4 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v4si __T5 = (__v4si) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v4si __T6 = __T4 | __T5; __v4si __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __v4si __T8 = __T6 | __T7; return __T8[0] | __T8[1];
extern __inline int
_mm512_mask_reduce_add_epi32 (__mmask16 __U, __m512i __A)
__A = _mm512_maskz_mov_epi32 (__U, __A);
extern __inline int
_mm512_mask_reduce_mul_epi32 (__mmask16 __U, __m512i __A)
__A = _mm512_mask_mov_epi32 (_mm512_set1_epi32 (1), __U, __A);
extern __inline int
_mm512_mask_reduce_and_epi32 (__mmask16 __U, __m512i __A)
__A = _mm512_mask_mov_epi32 (_mm512_set1_epi32 (~0), __U, __A);
extern __inline int
_mm512_mask_reduce_or_epi32 (__mmask16 __U, __m512i __A)
# 14818 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
extern __inline int
_mm512_reduce_min_epi32 (__m512i __A)
__m256i __T1 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T2 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = _mm256_min_epi32 (__T1, __T2); __m128i __T4 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __m128i __T5 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __m128i __T6 = _mm_min_epi32 (__T4, __T5); __m128i __T7 = (__m128i) __builtin_shuffle ((__v4si) __T6, (__v4si) { 2, 3, 0, 1 }); __m128i __T8 = _mm_min_epi32 (__T6, __T7); __m128i __T9 = (__m128i) __builtin_shuffle ((__v4si) __T8, (__v4si) { 1, 0, 1, 0 }); __v4si __T10 = (__v4si) _mm_min_epi32 (__T8, __T9); return __T10[0];
extern __inline int
_mm512_reduce_max_epi32 (__m512i __A)
__m256i __T1 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T2 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = _mm256_max_epi32 (__T1, __T2); __m128i __T4 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __m128i __T5 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __m128i __T6 = _mm_max_epi32 (__T4, __T5); __m128i __T7 = (__m128i) __builtin_shuffle ((__v4si) __T6, (__v4si) { 2, 3, 0, 1 }); __m128i __T8 = _mm_max_epi32 (__T6, __T7); __m128i __T9 = (__m128i) __builtin_shuffle ((__v4si) __T8, (__v4si) { 1, 0, 1, 0 }); __v4si __T10 = (__v4si) _mm_max_epi32 (__T8, __T9); return __T10[0];
_mm512_reduce_min_epu32 (__m512i __A)
__m256i __T1 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T2 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = _mm256_min_epu32 (__T1, __T2); __m128i __T4 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __m128i __T5 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __m128i __T6 = _mm_min_epu32 (__T4, __T5); __m128i __T7 = (__m128i) __builtin_shuffle ((__v4si) __T6, (__v4si) { 2, 3, 0, 1 }); __m128i __T8 = _mm_min_epu32 (__T6, __T7); __m128i __T9 = (__m128i) __builtin_shuffle ((__v4si) __T8, (__v4si) { 1, 0, 1, 0 }); __v4si __T10 = (__v4si) _mm_min_epu32 (__T8, __T9); return __T10[0];
_mm512_reduce_max_epu32 (__m512i __A)
__m256i __T1 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T2 = (__m256i) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = _mm256_max_epu32 (__T1, __T2); __m128i __T4 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __m128i __T5 = (__m128i) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __m128i __T6 = _mm_max_epu32 (__T4, __T5); __m128i __T7 = (__m128i) __builtin_shuffle ((__v4si) __T6, (__v4si) { 2, 3, 0, 1 }); __m128i __T8 = _mm_max_epu32 (__T6, __T7); __m128i __T9 = (__m128i) __builtin_shuffle ((__v4si) __T8, (__v4si) { 1, 0, 1, 0 }); __v4si __T10 = (__v4si) _mm_max_epu32 (__T8, __T9); return __T10[0];
extern __inline int
_mm512_mask_reduce_min_epi32 (__mmask16 __U, __m512i __A)
__A = _mm512_mask_mov_epi32 (_mm512_set1_epi32 (0x7fffffff), __U, __A);
extern __inline int
_mm512_mask_reduce_max_epi32 (__mmask16 __U, __m512i __A)
__A = _mm512_mask_mov_epi32 (_mm512_set1_epi32 (-0x7fffffff - 1), __U, __A);
_mm512_mask_reduce_min_epu32 (__mmask16 __U, __m512i __A)
_mm512_mask_reduce_max_epu32 (__mmask16 __U, __m512i __A)
# 14890 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_reduce_add_ps (__m512 __A)
__m256 __T1 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T2 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T3 = __T1 + __T2; __m128 __T4 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(1))); __m128 __T5 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(0))); __m128 __T6 = __T4 + __T5; __m128 __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __m128 __T8 = __T6 + __T7; return __T8[0] + __T8[1];
_mm512_reduce_mul_ps (__m512 __A)
__m256 __T1 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T2 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T3 = __T1 * __T2; __m128 __T4 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(1))); __m128 __T5 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(0))); __m128 __T6 = __T4 * __T5; __m128 __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __m128 __T8 = __T6 * __T7; return __T8[0] * __T8[1];
_mm512_mask_reduce_add_ps (__mmask16 __U, __m512 __A)
__A = _mm512_maskz_mov_ps (__U, __A);
_mm512_mask_reduce_mul_ps (__mmask16 __U, __m512 __A)
__A = _mm512_mask_mov_ps (_mm512_set1_ps (1.0f), __U, __A);
# 14934 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_reduce_min_ps (__m512 __A)
__m256 __T1 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T2 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T3 = _mm256_min_ps (__T1, __T2); __m128 __T4 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(1))); __m128 __T5 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(0))); __m128 __T6 = _mm_min_ps (__T4, __T5); __m128 __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __m128 __T8 = _mm_min_ps (__T6, __T7); __m128 __T9 = __builtin_shuffle (__T8, (__v4si) { 1, 0, 1, 0 }); __m128 __T10 = _mm_min_ps (__T8, __T9); return __T10[0];
_mm512_reduce_max_ps (__m512 __A)
__m256 __T1 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T2 = (__m256) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) ((__m512d) __A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256 __T3 = _mm256_max_ps (__T1, __T2); __m128 __T4 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(1))); __m128 __T5 = ((__m128) __builtin_ia32_vextractf128_ps256 ((__v8sf)(__m256)(__T3), (int)(0))); __m128 __T6 = _mm_max_ps (__T4, __T5); __m128 __T7 = __builtin_shuffle (__T6, (__v4si) { 2, 3, 0, 1 }); __m128 __T8 = _mm_max_ps (__T6, __T7); __m128 __T9 = __builtin_shuffle (__T8, (__v4si) { 1, 0, 1, 0 }); __m128 __T10 = _mm_max_ps (__T8, __T9); return __T10[0];
_mm512_mask_reduce_min_ps (__mmask16 __U, __m512 __A)
__A = _mm512_mask_mov_ps (_mm512_set1_ps (__builtin_inff ()), __U, __A);
_mm512_mask_reduce_max_ps (__mmask16 __U, __m512 __A)
__A = _mm512_mask_mov_ps (_mm512_set1_ps (-__builtin_inff ()), __U, __A);
# 14974 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_reduce_add_epi64 (__m512i __A)
__v4di __T1 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v4di __T2 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 + __T2); __v2di __T4 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v2di __T5 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v2di __T6 = __T4 + __T5; return __T6[0] + __T6[1];
_mm512_reduce_mul_epi64 (__m512i __A)
__v4di __T1 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v4di __T2 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 * __T2); __v2di __T4 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v2di __T5 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v2di __T6 = __T4 * __T5; return __T6[0] * __T6[1];
_mm512_reduce_and_epi64 (__m512i __A)
__v4di __T1 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v4di __T2 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 & __T2); __v2di __T4 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v2di __T5 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v2di __T6 = __T4 & __T5; return __T6[0] & __T6[1];
_mm512_reduce_or_epi64 (__m512i __A)
__v4di __T1 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (1), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __v4di __T2 = (__v4di) ((__m256i) __builtin_ia32_extracti64x4_mask ((__v8di)(__m512i) (__A), (int) (0), (__v4di)(__m256i)_mm256_undefined_si256 (), (__mmask8)-1)); __m256i __T3 = (__m256i) (__T1 | __T2); __v2di __T4 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(1))); __v2di __T5 = (__v2di) ((__m128i) __builtin_ia32_extract128i256 ((__v4di)(__m256i)(__T3), (int)(0))); __v2di __T6 = __T4 | __T5; return __T6[0] | __T6[1];
_mm512_mask_reduce_add_epi64 (__mmask8 __U, __m512i __A)
__A = _mm512_maskz_mov_epi64 (__U, __A);
_mm512_mask_reduce_mul_epi64 (__mmask8 __U, __m512i __A)
__A = _mm512_mask_mov_epi64 (_mm512_set1_epi64 (1LL), __U, __A);
_mm512_mask_reduce_and_epi64 (__mmask8 __U, __m512i __A)
__A = _mm512_mask_mov_epi64 (_mm512_set1_epi64 (~0LL), __U, __A);
_mm512_mask_reduce_or_epi64 (__mmask8 __U, __m512i __A)
# 15048 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_reduce_min_epi64 (__m512i __A)
__m512i __T1 = ((__m512i) __builtin_ia32_shuf_i64x2_mask ((__v8di)(__m512i)(__A), (__v8di)(__m512i)(__A), (int)(0x4e), (__v8di)(__m512i)_mm512_undefined_epi32 (), (__mmask8)-1)); __m512i __T2 = _mm512_min_epi64 (__A, __T1); __m512i __T3 = (__m512i) __builtin_shuffle ((__v8di) __T2, (__v8di) { 2, 3, 0, 1, 6, 7, 4, 5 }); __m512i __T4 = _mm512_min_epi64 (__T2, __T3); __m512i __T5 = (__m512i) __builtin_shuffle ((__v8di) __T4, (__v8di) { 1, 0, 3, 2, 5, 4, 7, 6 }); __v8di __T6 = (__v8di) _mm512_min_epi64 (__T4, __T5); return __T6[0];
_mm512_reduce_max_epi64 (__m512i __A)
__m512i __T1 = ((__m512i) __builtin_ia32_shuf_i64x2_mask ((__v8di)(__m512i)(__A), (__v8di)(__m512i)(__A), (int)(0x4e), (__v8di)(__m512i)_mm512_undefined_epi32 (), (__mmask8)-1)); __m512i __T2 = _mm512_max_epi64 (__A, __T1); __m512i __T3 = (__m512i) __builtin_shuffle ((__v8di) __T2, (__v8di) { 2, 3, 0, 1, 6, 7, 4, 5 }); __m512i __T4 = _mm512_max_epi64 (__T2, __T3); __m512i __T5 = (__m512i) __builtin_shuffle ((__v8di) __T4, (__v8di) { 1, 0, 3, 2, 5, 4, 7, 6 }); __v8di __T6 = (__v8di) _mm512_max_epi64 (__T4, __T5); return __T6[0];
_mm512_mask_reduce_min_epi64 (__mmask8 __U, __m512i __A)
__A = _mm512_mask_mov_epi64 (_mm512_set1_epi64 (0x7fffffffffffffffLL),
__U, __A);
_mm512_mask_reduce_max_epi64 (__mmask8 __U, __m512i __A)
__A = _mm512_mask_mov_epi64 (_mm512_set1_epi64 (-0x7fffffffffffffffLL - 1),
__U, __A);
_mm512_reduce_min_epu64 (__m512i __A)
__m512i __T1 = ((__m512i) __builtin_ia32_shuf_i64x2_mask ((__v8di)(__m512i)(__A), (__v8di)(__m512i)(__A), (int)(0x4e), (__v8di)(__m512i)_mm512_undefined_epi32 (), (__mmask8)-1)); __m512i __T2 = _mm512_min_epu64 (__A, __T1); __m512i __T3 = (__m512i) __builtin_shuffle ((__v8di) __T2, (__v8di) { 2, 3, 0, 1, 6, 7, 4, 5 }); __m512i __T4 = _mm512_min_epu64 (__T2, __T3); __m512i __T5 = (__m512i) __builtin_shuffle ((__v8di) __T4, (__v8di) { 1, 0, 3, 2, 5, 4, 7, 6 }); __v8di __T6 = (__v8di) _mm512_min_epu64 (__T4, __T5); return __T6[0];
_mm512_reduce_max_epu64 (__m512i __A)
__m512i __T1 = ((__m512i) __builtin_ia32_shuf_i64x2_mask ((__v8di)(__m512i)(__A), (__v8di)(__m512i)(__A), (int)(0x4e), (__v8di)(__m512i)_mm512_undefined_epi32 (), (__mmask8)-1)); __m512i __T2 = _mm512_max_epu64 (__A, __T1); __m512i __T3 = (__m512i) __builtin_shuffle ((__v8di) __T2, (__v8di) { 2, 3, 0, 1, 6, 7, 4, 5 }); __m512i __T4 = _mm512_max_epu64 (__T2, __T3); __m512i __T5 = (__m512i) __builtin_shuffle ((__v8di) __T4, (__v8di) { 1, 0, 3, 2, 5, 4, 7, 6 }); __v8di __T6 = (__v8di) _mm512_max_epu64 (__T4, __T5); return __T6[0];
_mm512_mask_reduce_min_epu64 (__mmask8 __U, __m512i __A)
_mm512_mask_reduce_max_epu64 (__mmask8 __U, __m512i __A)
# 15120 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_reduce_add_pd (__m512d __A)
__m256d __T1 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T2 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T3 = __T1 + __T2; __m128d __T4 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(1))); __m128d __T5 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(0))); __m128d __T6 = __T4 + __T5; return __T6[0] + __T6[1];
_mm512_reduce_mul_pd (__m512d __A)
__m256d __T1 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T2 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T3 = __T1 * __T2; __m128d __T4 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(1))); __m128d __T5 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(0))); __m128d __T6 = __T4 * __T5; return __T6[0] * __T6[1];
_mm512_mask_reduce_add_pd (__mmask8 __U, __m512d __A)
__A = _mm512_maskz_mov_pd (__U, __A);
_mm512_mask_reduce_mul_pd (__mmask8 __U, __m512d __A)
__A = _mm512_mask_mov_pd (_mm512_set1_pd (1.0), __U, __A);
# 15162 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512fintrin.h" 3 4
_mm512_reduce_min_pd (__m512d __A)
__m256d __T1 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T2 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T3 = _mm256_min_pd (__T1, __T2); __m128d __T4 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(1))); __m128d __T5 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(0))); __m128d __T6 = _mm_min_pd (__T4, __T5); __m128d __T7 = (__m128d) __builtin_shuffle (__T6, (__v2di) { 1, 0 }); __m128d __T8 = _mm_min_pd (__T6, __T7); return __T8[0];
_mm512_reduce_max_pd (__m512d __A)
__m256d __T1 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (1), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T2 = (__m256d) ((__m256d) __builtin_ia32_extractf64x4_mask ((__v8df)(__m512d) (__A), (int) (0), (__v4df)(__m256d)_mm256_undefined_pd(), (__mmask8)-1)); __m256d __T3 = _mm256_max_pd (__T1, __T2); __m128d __T4 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(1))); __m128d __T5 = ((__m128d) __builtin_ia32_vextractf128_pd256 ((__v4df)(__m256d)(__T3), (int)(0))); __m128d __T6 = _mm_max_pd (__T4, __T5); __m128d __T7 = (__m128d) __builtin_shuffle (__T6, (__v2di) { 1, 0 }); __m128d __T8 = _mm_max_pd (__T6, __T7); return __T8[0];
_mm512_mask_reduce_min_pd (__mmask8 __U, __m512d __A)
__A = _mm512_mask_mov_pd (_mm512_set1_pd (__builtin_inf ()), __U, __A);
_mm512_mask_reduce_max_pd (__mmask8 __U, __m512d __A)
__A = _mm512_mask_mov_pd (_mm512_set1_pd (-__builtin_inf ()), __U, __A);
#pragma GCC pop_options
# 46 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512erintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512erintrin.h" 3 4
#pragma GCC push_options
#pragma GCC target("avx512er")
typedef double __v8df __attribute__ ((__vector_size__ (64)));
typedef float __v16sf __attribute__ ((__vector_size__ (64)));
typedef float __m512 __attribute__ ((__vector_size__ (64), __may_alias__));
typedef double __m512d __attribute__ ((__vector_size__ (64), __may_alias__));
typedef unsigned char __mmask8;
typedef unsigned short __mmask16;
# 391 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512erintrin.h" 3 4
# 48 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512pfintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512pfintrin.h" 3 4
#pragma GCC target("avx512pf")
typedef long long __v8di __attribute__ ((__vector_size__ (64)));
typedef int __v16si __attribute__ ((__vector_size__ (64)));
typedef long long __m512i __attribute__ ((__vector_size__ (64), __may_alias__));
# 261 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512pfintrin.h" 3 4
# 50 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512cdintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512cdintrin.h" 3 4
#pragma GCC target("avx512cd")
_mm512_conflict_epi32 (__m512i __A)
return (__m512i)
__builtin_ia32_vpconflictsi_512_mask ((__v16si) __A,
(__v16si) _mm512_setzero_si512 (),
(__mmask16) -1);
_mm512_mask_conflict_epi32 (__m512i __W, __mmask16 __U, __m512i __A)
return (__m512i) __builtin_ia32_vpconflictsi_512_mask ((__v16si) __A,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_conflict_epi32 (__mmask16 __U, __m512i __A)
return (__m512i)
(__mmask16) __U);
_mm512_conflict_epi64 (__m512i __A)
return (__m512i)
__builtin_ia32_vpconflictdi_512_mask ((__v8di) __A,
(__v8di) _mm512_setzero_si512 (),
(__mmask8) -1);
_mm512_mask_conflict_epi64 (__m512i __W, __mmask8 __U, __m512i __A)
return (__m512i) __builtin_ia32_vpconflictdi_512_mask ((__v8di) __A,
(__v8di) __W,
(__mmask8) __U);
extern __inline __m512i
_mm512_maskz_conflict_epi64 (__mmask8 __U, __m512i __A)
return (__m512i)
(__mmask8) __U);
_mm512_lzcnt_epi64 (__m512i __A)
return (__m512i)
__builtin_ia32_vplzcntq_512_mask ((__v8di) __A,
(__mmask8) -1);
_mm512_mask_lzcnt_epi64 (__m512i __W, __mmask8 __U, __m512i __A)
return (__m512i) __builtin_ia32_vplzcntq_512_mask ((__v8di) __A,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_lzcnt_epi64 (__mmask8 __U, __m512i __A)
return (__m512i)
(__mmask8) __U);
_mm512_lzcnt_epi32 (__m512i __A)
return (__m512i)
__builtin_ia32_vplzcntd_512_mask ((__v16si) __A,
(__mmask16) -1);
_mm512_mask_lzcnt_epi32 (__m512i __W, __mmask16 __U, __m512i __A)
return (__m512i) __builtin_ia32_vplzcntd_512_mask ((__v16si) __A,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_lzcnt_epi32 (__mmask16 __U, __m512i __A)
return (__m512i)
(__mmask16) __U);
_mm512_broadcastmb_epi64 (__mmask8 __A)
return (__m512i) __builtin_ia32_broadcastmb512 (__A);
_mm512_broadcastmw_epi32 (__mmask16 __A)
return (__m512i) __builtin_ia32_broadcastmw512 (__A);
# 52 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vlintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vlintrin.h" 3 4
#pragma GCC target("avx512vl")
typedef unsigned int __mmask32;
_mm256_mask_mov_pd (__m256d __W, __mmask8 __U, __m256d __A)
return (__m256d) __builtin_ia32_movapd256_mask ((__v4df) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_mov_pd (__mmask8 __U, __m256d __A)
(__v4df)
_mm256_setzero_pd (),
(__mmask8) __U);
_mm_mask_mov_pd (__m128d __W, __mmask8 __U, __m128d __A)
return (__m128d) __builtin_ia32_movapd128_mask ((__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_mov_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_load_pd (__m256d __W, __mmask8 __U, void const *__P)
return (__m256d) __builtin_ia32_loadapd256_mask ((__v4df *) __P,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_load_pd (__mmask8 __U, void const *__P)
(__v4df)
(__mmask8) __U);
_mm_mask_load_pd (__m128d __W, __mmask8 __U, void const *__P)
return (__m128d) __builtin_ia32_loadapd128_mask ((__v2df *) __P,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_load_pd (__mmask8 __U, void const *__P)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
extern __inline void
_mm256_mask_store_pd (void *__P, __mmask8 __U, __m256d __A)
__builtin_ia32_storeapd256_mask ((__v4df *) __P,
(__v4df) __A,
(__mmask8) __U);
_mm_mask_store_pd (void *__P, __mmask8 __U, __m128d __A)
__builtin_ia32_storeapd128_mask ((__v2df *) __P,
(__v2df) __A,
(__mmask8) __U);
_mm256_mask_mov_ps (__m256 __W, __mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_movaps256_mask ((__v8sf) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_mov_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm_mask_mov_ps (__m128 __W, __mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_movaps128_mask ((__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_mov_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_load_ps (__m256 __W, __mmask8 __U, void const *__P)
return (__m256) __builtin_ia32_loadaps256_mask ((__v8sf *) __P,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_load_ps (__mmask8 __U, void const *__P)
(__v8sf)
(__mmask8) __U);
_mm_mask_load_ps (__m128 __W, __mmask8 __U, void const *__P)
return (__m128) __builtin_ia32_loadaps128_mask ((__v4sf *) __P,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_load_ps (__mmask8 __U, void const *__P)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_store_ps (void *__P, __mmask8 __U, __m256 __A)
__builtin_ia32_storeaps256_mask ((__v8sf *) __P,
(__v8sf) __A,
(__mmask8) __U);
_mm_mask_store_ps (void *__P, __mmask8 __U, __m128 __A)
__builtin_ia32_storeaps128_mask ((__v4sf *) __P,
(__v4sf) __A,
(__mmask8) __U);
_mm256_mask_mov_epi64 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_movdqa64_256_mask ((__v4di) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_mov_epi64 (__mmask8 __U, __m256i __A)
(__v4di)
_mm256_setzero_si256 (),
(__mmask8) __U);
_mm_mask_mov_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_movdqa64_128_mask ((__v2di) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_mov_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
_mm_setzero_si128 (),
(__mmask8) __U);
_mm256_mask_load_epi64 (__m256i __W, __mmask8 __U, void const *__P)
return (__m256i) __builtin_ia32_movdqa64load256_mask ((__v4di *) __P,
(__v4di) __W,
(__mmask8)
__U);
_mm256_maskz_load_epi64 (__mmask8 __U, void const *__P)
(__v4di)
(__mmask8)
__U);
_mm_mask_load_epi64 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_movdqa64load128_mask ((__v2di *) __P,
(__v2di) __W,
(__mmask8)
__U);
_mm_maskz_load_epi64 (__mmask8 __U, void const *__P)
(__v2di)
(__mmask8)
__U);
_mm256_mask_store_epi64 (void *__P, __mmask8 __U, __m256i __A)
__builtin_ia32_movdqa64store256_mask ((__v4di *) __P,
(__v4di) __A,
(__mmask8) __U);
_mm_mask_store_epi64 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_movdqa64store128_mask ((__v2di *) __P,
(__v2di) __A,
(__mmask8) __U);
_mm256_mask_mov_epi32 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_movdqa32_256_mask ((__v8si) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_mov_epi32 (__mmask8 __U, __m256i __A)
(__v8si)
(__mmask8) __U);
_mm_mask_mov_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_movdqa32_128_mask ((__v4si) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_mov_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_load_epi32 (__m256i __W, __mmask8 __U, void const *__P)
return (__m256i) __builtin_ia32_movdqa32load256_mask ((__v8si *) __P,
(__v8si) __W,
(__mmask8)
__U);
_mm256_maskz_load_epi32 (__mmask8 __U, void const *__P)
(__v8si)
(__mmask8)
__U);
_mm_mask_load_epi32 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_movdqa32load128_mask ((__v4si *) __P,
(__v4si) __W,
(__mmask8)
__U);
_mm_maskz_load_epi32 (__mmask8 __U, void const *__P)
(__v4si)
(__mmask8)
__U);
_mm256_mask_store_epi32 (void *__P, __mmask8 __U, __m256i __A)
__builtin_ia32_movdqa32store256_mask ((__v8si *) __P,
(__v8si) __A,
(__mmask8) __U);
_mm_mask_store_epi32 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_movdqa32store128_mask ((__v4si *) __P,
(__v4si) __A,
(__mmask8) __U);
_mm_mask_add_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_addpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_add_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_add_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_addpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_add_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_add_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_addps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_add_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_add_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_addps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_add_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_mask_sub_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_subpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_sub_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_sub_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_subpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_sub_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_sub_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_subps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_sub_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_sub_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_subps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_sub_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm256_store_epi64 (void *__P, __m256i __A)
*(__m256i *) __P = __A;
_mm_store_epi64 (void *__P, __m128i __A)
*(__m128i *) __P = __A;
_mm256_mask_loadu_pd (__m256d __W, __mmask8 __U, void const *__P)
return (__m256d) __builtin_ia32_loadupd256_mask ((const double *) __P,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_loadu_pd (__mmask8 __U, void const *__P)
(__v4df)
(__mmask8) __U);
_mm_mask_loadu_pd (__m128d __W, __mmask8 __U, void const *__P)
return (__m128d) __builtin_ia32_loadupd128_mask ((const double *) __P,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_loadu_pd (__mmask8 __U, void const *__P)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_storeu_pd (void *__P, __mmask8 __U, __m256d __A)
__builtin_ia32_storeupd256_mask ((double *) __P,
(__v4df) __A,
(__mmask8) __U);
_mm_mask_storeu_pd (void *__P, __mmask8 __U, __m128d __A)
__builtin_ia32_storeupd128_mask ((double *) __P,
(__v2df) __A,
(__mmask8) __U);
_mm256_mask_loadu_ps (__m256 __W, __mmask8 __U, void const *__P)
return (__m256) __builtin_ia32_loadups256_mask ((const float *) __P,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_loadu_ps (__mmask8 __U, void const *__P)
(__v8sf)
(__mmask8) __U);
_mm_mask_loadu_ps (__m128 __W, __mmask8 __U, void const *__P)
return (__m128) __builtin_ia32_loadups128_mask ((const float *) __P,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_loadu_ps (__mmask8 __U, void const *__P)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_storeu_ps (void *__P, __mmask8 __U, __m256 __A)
__builtin_ia32_storeups256_mask ((float *) __P,
(__v8sf) __A,
(__mmask8) __U);
_mm_mask_storeu_ps (void *__P, __mmask8 __U, __m128 __A)
__builtin_ia32_storeups128_mask ((float *) __P,
(__v4sf) __A,
(__mmask8) __U);
_mm256_mask_loadu_epi64 (__m256i __W, __mmask8 __U, void const *__P)
return (__m256i) __builtin_ia32_loaddqudi256_mask ((const long long *) __P,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_loadu_epi64 (__mmask8 __U, void const *__P)
(__v4di)
(__mmask8) __U);
_mm_mask_loadu_epi64 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_loaddqudi128_mask ((const long long *) __P,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_loadu_epi64 (__mmask8 __U, void const *__P)
(__v2di)
(__mmask8) __U);
_mm256_mask_storeu_epi64 (void *__P, __mmask8 __U, __m256i __A)
__builtin_ia32_storedqudi256_mask ((long long *) __P,
(__v4di) __A,
(__mmask8) __U);
_mm_mask_storeu_epi64 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_storedqudi128_mask ((long long *) __P,
(__v2di) __A,
(__mmask8) __U);
_mm256_mask_loadu_epi32 (__m256i __W, __mmask8 __U, void const *__P)
return (__m256i) __builtin_ia32_loaddqusi256_mask ((const int *) __P,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_loadu_epi32 (__mmask8 __U, void const *__P)
(__v8si)
(__mmask8) __U);
_mm_mask_loadu_epi32 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_loaddqusi128_mask ((const int *) __P,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_loadu_epi32 (__mmask8 __U, void const *__P)
(__v4si)
(__mmask8) __U);
_mm256_mask_storeu_epi32 (void *__P, __mmask8 __U, __m256i __A)
__builtin_ia32_storedqusi256_mask ((int *) __P,
(__v8si) __A,
(__mmask8) __U);
_mm_mask_storeu_epi32 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_storedqusi128_mask ((int *) __P,
(__v4si) __A,
(__mmask8) __U);
_mm256_mask_abs_epi32 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_pabsd256_mask ((__v8si) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_abs_epi32 (__mmask8 __U, __m256i __A)
(__v8si)
(__mmask8) __U);
_mm_mask_abs_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pabsd128_mask ((__v4si) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_abs_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm256_abs_epi64 (__m256i __A)
return (__m256i) __builtin_ia32_pabsq256_mask ((__v4di) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_abs_epi64 (__m256i __W, __mmask8 __U, __m256i __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_abs_epi64 (__mmask8 __U, __m256i __A)
(__v4di)
(__mmask8) __U);
_mm_abs_epi64 (__m128i __A)
return (__m128i) __builtin_ia32_pabsq128_mask ((__v2di) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_abs_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_abs_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm256_cvtpd_epu32 (__m256d __A)
return (__m128i) __builtin_ia32_cvtpd2udq256_mask ((__v4df) __A,
(__v4si)
(__mmask8) -1);
_mm256_mask_cvtpd_epu32 (__m128i __W, __mmask8 __U, __m256d __A)
(__v4si) __W,
(__mmask8) __U);
_mm256_maskz_cvtpd_epu32 (__mmask8 __U, __m256d __A)
(__v4si)
(__mmask8) __U);
_mm_cvtpd_epu32 (__m128d __A)
return (__m128i) __builtin_ia32_cvtpd2udq128_mask ((__v2df) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvtpd_epu32 (__m128i __W, __mmask8 __U, __m128d __A)
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtpd_epu32 (__mmask8 __U, __m128d __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvttps_epi32 (__m256i __W, __mmask8 __U, __m256 __A)
return (__m256i) __builtin_ia32_cvttps2dq256_mask ((__v8sf) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvttps_epi32 (__mmask8 __U, __m256 __A)
(__v8si)
(__mmask8) __U);
_mm_mask_cvttps_epi32 (__m128i __W, __mmask8 __U, __m128 __A)
return (__m128i) __builtin_ia32_cvttps2dq128_mask ((__v4sf) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvttps_epi32 (__mmask8 __U, __m128 __A)
(__v4si)
(__mmask8) __U);
_mm256_cvttps_epu32 (__m256 __A)
return (__m256i) __builtin_ia32_cvttps2udq256_mask ((__v8sf) __A,
(__v8si)
(__mmask8) -1);
_mm256_mask_cvttps_epu32 (__m256i __W, __mmask8 __U, __m256 __A)
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvttps_epu32 (__mmask8 __U, __m256 __A)
(__v8si)
(__mmask8) __U);
_mm_cvttps_epu32 (__m128 __A)
return (__m128i) __builtin_ia32_cvttps2udq128_mask ((__v4sf) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvttps_epu32 (__m128i __W, __mmask8 __U, __m128 __A)
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvttps_epu32 (__mmask8 __U, __m128 __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvttpd_epi32 (__m128i __W, __mmask8 __U, __m256d __A)
return (__m128i) __builtin_ia32_cvttpd2dq256_mask ((__v4df) __A,
(__v4si) __W,
(__mmask8) __U);
_mm256_maskz_cvttpd_epi32 (__mmask8 __U, __m256d __A)
(__v4si)
(__mmask8) __U);
_mm_mask_cvttpd_epi32 (__m128i __W, __mmask8 __U, __m128d __A)
return (__m128i) __builtin_ia32_cvttpd2dq128_mask ((__v2df) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvttpd_epi32 (__mmask8 __U, __m128d __A)
(__v4si)
(__mmask8) __U);
_mm256_cvttpd_epu32 (__m256d __A)
return (__m128i) __builtin_ia32_cvttpd2udq256_mask ((__v4df) __A,
(__v4si)
(__mmask8) -1);
_mm256_mask_cvttpd_epu32 (__m128i __W, __mmask8 __U, __m256d __A)
(__v4si) __W,
(__mmask8) __U);
_mm256_maskz_cvttpd_epu32 (__mmask8 __U, __m256d __A)
(__v4si)
(__mmask8) __U);
_mm_cvttpd_epu32 (__m128d __A)
return (__m128i) __builtin_ia32_cvttpd2udq128_mask ((__v2df) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvttpd_epu32 (__m128i __W, __mmask8 __U, __m128d __A)
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvttpd_epu32 (__mmask8 __U, __m128d __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvtpd_epi32 (__m128i __W, __mmask8 __U, __m256d __A)
return (__m128i) __builtin_ia32_cvtpd2dq256_mask ((__v4df) __A,
(__v4si) __W,
(__mmask8) __U);
_mm256_maskz_cvtpd_epi32 (__mmask8 __U, __m256d __A)
(__v4si)
(__mmask8) __U);
_mm_mask_cvtpd_epi32 (__m128i __W, __mmask8 __U, __m128d __A)
return (__m128i) __builtin_ia32_cvtpd2dq128_mask ((__v2df) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtpd_epi32 (__mmask8 __U, __m128d __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvtepi32_pd (__m256d __W, __mmask8 __U, __m128i __A)
return (__m256d) __builtin_ia32_cvtdq2pd256_mask ((__v4si) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi32_pd (__mmask8 __U, __m128i __A)
(__v4df)
(__mmask8) __U);
extern __inline __m128d
_mm_mask_cvtepi32_pd (__m128d __W, __mmask8 __U, __m128i __A)
return (__m128d) __builtin_ia32_cvtdq2pd128_mask ((__v4si) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_cvtepi32_pd (__mmask8 __U, __m128i __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_cvtepu32_pd (__m128i __A)
return (__m256d) __builtin_ia32_cvtudq2pd256_mask ((__v4si) __A,
(__v4df)
(__mmask8) -1);
_mm256_mask_cvtepu32_pd (__m256d __W, __mmask8 __U, __m128i __A)
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu32_pd (__mmask8 __U, __m128i __A)
(__v4df)
(__mmask8) __U);
_mm_cvtepu32_pd (__m128i __A)
return (__m128d) __builtin_ia32_cvtudq2pd128_mask ((__v4si) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_cvtepu32_pd (__m128d __W, __mmask8 __U, __m128i __A)
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_cvtepu32_pd (__mmask8 __U, __m128i __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_cvtepi32_ps (__m256 __W, __mmask8 __U, __m256i __A)
return (__m256) __builtin_ia32_cvtdq2ps256_mask ((__v8si) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi32_ps (__mmask8 __U, __m256i __A)
(__v8sf)
(__mmask8) __U);
_mm_mask_cvtepi32_ps (__m128 __W, __mmask8 __U, __m128i __A)
return (__m128) __builtin_ia32_cvtdq2ps128_mask ((__v4si) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_cvtepi32_ps (__mmask8 __U, __m128i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_cvtepu32_ps (__m256i __A)
return (__m256) __builtin_ia32_cvtudq2ps256_mask ((__v8si) __A,
(__v8sf)
(__mmask8) -1);
_mm256_mask_cvtepu32_ps (__m256 __W, __mmask8 __U, __m256i __A)
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu32_ps (__mmask8 __U, __m256i __A)
(__v8sf)
(__mmask8) __U);
_mm_cvtepu32_ps (__m128i __A)
return (__m128) __builtin_ia32_cvtudq2ps128_mask ((__v4si) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_cvtepu32_ps (__m128 __W, __mmask8 __U, __m128i __A)
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_cvtepu32_ps (__mmask8 __U, __m128i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_cvtps_pd (__m256d __W, __mmask8 __U, __m128 __A)
return (__m256d) __builtin_ia32_cvtps2pd256_mask ((__v4sf) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_cvtps_pd (__mmask8 __U, __m128 __A)
(__v4df)
(__mmask8) __U);
_mm_mask_cvtps_pd (__m128d __W, __mmask8 __U, __m128 __A)
return (__m128d) __builtin_ia32_cvtps2pd128_mask ((__v4sf) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_cvtps_pd (__mmask8 __U, __m128 __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_cvtepi32_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovdb128_mask ((__v4si) __A,
(__v16qi)
(__mmask8) -1);
_mm_mask_cvtepi32_storeu_epi8 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovdb128mem_mask ((__v16qi *) __P, (__v4si) __A, __M);
_mm_mask_cvtepi32_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
(__v16qi) __O, __M);
_mm_maskz_cvtepi32_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtepi32_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovdb256_mask ((__v8si) __A,
(__v16qi)
(__mmask8) -1);
_mm256_mask_cvtepi32_epi8 (__m128i __O, __mmask8 __M, __m256i __A)
_mm256_mask_cvtepi32_storeu_epi8 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovdb256mem_mask ((__v16qi *) __P, (__v8si) __A, __M);
_mm256_maskz_cvtepi32_epi8 (__mmask8 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtsepi32_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovsdb128_mask ((__v4si) __A,
(__v16qi)
(__mmask8) -1);
_mm_mask_cvtsepi32_storeu_epi8 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovsdb128mem_mask ((__v16qi *) __P, (__v4si) __A, __M);
_mm_mask_cvtsepi32_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
_mm_maskz_cvtsepi32_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtsepi32_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovsdb256_mask ((__v8si) __A,
(__v16qi)
(__mmask8) -1);
_mm256_mask_cvtsepi32_storeu_epi8 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovsdb256mem_mask ((__v16qi *) __P, (__v8si) __A, __M);
_mm256_mask_cvtsepi32_epi8 (__m128i __O, __mmask8 __M, __m256i __A)
_mm256_maskz_cvtsepi32_epi8 (__mmask8 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtusepi32_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovusdb128_mask ((__v4si) __A,
(__v16qi)
(__mmask8) -1);
_mm_mask_cvtusepi32_storeu_epi8 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovusdb128mem_mask ((__v16qi *) __P, (__v4si) __A, __M);
_mm_mask_cvtusepi32_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
(__v16qi) __O,
__M);
_mm_maskz_cvtusepi32_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtusepi32_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovusdb256_mask ((__v8si) __A,
(__v16qi)
(__mmask8) -1);
_mm256_mask_cvtusepi32_storeu_epi8 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovusdb256mem_mask ((__v16qi*) __P, (__v8si) __A, __M);
_mm256_mask_cvtusepi32_epi8 (__m128i __O, __mmask8 __M, __m256i __A)
(__v16qi) __O,
__M);
_mm256_maskz_cvtusepi32_epi8 (__mmask8 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtepi32_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_pmovdw128_mask ((__v4si) __A,
(__v8hi)
(__mmask8) -1);
_mm_mask_cvtepi32_storeu_epi16 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovdw128mem_mask ((__v8hi *) __P, (__v4si) __A, __M);
_mm_mask_cvtepi32_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
(__v8hi) __O, __M);
_mm_maskz_cvtepi32_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm256_cvtepi32_epi16 (__m256i __A)
return (__m128i) __builtin_ia32_pmovdw256_mask ((__v8si) __A,
(__v8hi)
(__mmask8) -1);
_mm256_mask_cvtepi32_storeu_epi16 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovdw256mem_mask ((__v8hi *) __P, (__v8si) __A, __M);
_mm256_mask_cvtepi32_epi16 (__m128i __O, __mmask8 __M, __m256i __A)
(__v8hi) __O, __M);
_mm256_maskz_cvtepi32_epi16 (__mmask8 __M, __m256i __A)
(__v8hi)
__M);
_mm_cvtsepi32_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_pmovsdw128_mask ((__v4si) __A,
(__v8hi)
(__mmask8) -1);
_mm_mask_cvtsepi32_storeu_epi16 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovsdw128mem_mask ((__v8hi *) __P, (__v4si) __A, __M);
_mm_mask_cvtsepi32_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
(__v8hi)__O,
__M);
_mm_maskz_cvtsepi32_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm256_cvtsepi32_epi16 (__m256i __A)
return (__m128i) __builtin_ia32_pmovsdw256_mask ((__v8si) __A,
(__v8hi)
(__mmask8) -1);
_mm256_mask_cvtsepi32_storeu_epi16 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovsdw256mem_mask ((__v8hi *) __P, (__v8si) __A, __M);
_mm256_mask_cvtsepi32_epi16 (__m128i __O, __mmask8 __M, __m256i __A)
(__v8hi) __O, __M);
_mm256_maskz_cvtsepi32_epi16 (__mmask8 __M, __m256i __A)
(__v8hi)
__M);
_mm_cvtusepi32_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_pmovusdw128_mask ((__v4si) __A,
(__v8hi)
(__mmask8) -1);
_mm_mask_cvtusepi32_storeu_epi16 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovusdw128mem_mask ((__v8hi *) __P, (__v4si) __A, __M);
_mm_mask_cvtusepi32_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
(__v8hi) __O, __M);
_mm_maskz_cvtusepi32_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm256_cvtusepi32_epi16 (__m256i __A)
return (__m128i) __builtin_ia32_pmovusdw256_mask ((__v8si) __A,
(__v8hi)
(__mmask8) -1);
_mm256_mask_cvtusepi32_storeu_epi16 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovusdw256mem_mask ((__v8hi *) __P, (__v8si) __A, __M);
_mm256_mask_cvtusepi32_epi16 (__m128i __O, __mmask8 __M, __m256i __A)
(__v8hi) __O, __M);
_mm256_maskz_cvtusepi32_epi16 (__mmask8 __M, __m256i __A)
(__v8hi)
__M);
_mm_cvtepi64_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovqb128_mask ((__v2di) __A,
(__v16qi)
(__mmask8) -1);
_mm_mask_cvtepi64_storeu_epi8 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovqb128mem_mask ((__v16qi *) __P, (__v2di) __A, __M);
_mm_mask_cvtepi64_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
_mm_maskz_cvtepi64_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtepi64_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovqb256_mask ((__v4di) __A,
(__v16qi)
(__mmask8) -1);
_mm256_mask_cvtepi64_storeu_epi8 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovqb256mem_mask ((__v16qi *) __P, (__v4di) __A, __M);
_mm256_mask_cvtepi64_epi8 (__m128i __O, __mmask8 __M, __m256i __A)
_mm256_maskz_cvtepi64_epi8 (__mmask8 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtsepi64_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovsqb128_mask ((__v2di) __A,
(__v16qi)
(__mmask8) -1);
_mm_mask_cvtsepi64_storeu_epi8 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovsqb128mem_mask ((__v16qi *) __P, (__v2di) __A, __M);
_mm_mask_cvtsepi64_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
_mm_maskz_cvtsepi64_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtsepi64_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovsqb256_mask ((__v4di) __A,
(__v16qi)
(__mmask8) -1);
_mm256_mask_cvtsepi64_storeu_epi8 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovsqb256mem_mask ((__v16qi *) __P, (__v4di) __A, __M);
_mm256_mask_cvtsepi64_epi8 (__m128i __O, __mmask8 __M, __m256i __A)
_mm256_maskz_cvtsepi64_epi8 (__mmask8 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtusepi64_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovusqb128_mask ((__v2di) __A,
(__v16qi)
(__mmask8) -1);
_mm_mask_cvtusepi64_storeu_epi8 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovusqb128mem_mask ((__v16qi *) __P, (__v2di) __A, __M);
_mm_mask_cvtusepi64_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
(__v16qi) __O,
__M);
_mm_maskz_cvtusepi64_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtusepi64_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovusqb256_mask ((__v4di) __A,
(__v16qi)
(__mmask8) -1);
_mm256_mask_cvtusepi64_storeu_epi8 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovusqb256mem_mask ((__v16qi *) __P, (__v4di) __A, __M);
_mm256_mask_cvtusepi64_epi8 (__m128i __O, __mmask8 __M, __m256i __A)
(__v16qi) __O,
__M);
_mm256_maskz_cvtusepi64_epi8 (__mmask8 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtepi64_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_pmovqw128_mask ((__v2di) __A,
(__v8hi)
(__mmask8) -1);
_mm_mask_cvtepi64_storeu_epi16 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovqw128mem_mask ((__v8hi *) __P, (__v2di) __A, __M);
_mm_mask_cvtepi64_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
(__v8hi)__O,
__M);
_mm_maskz_cvtepi64_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm256_cvtepi64_epi16 (__m256i __A)
return (__m128i) __builtin_ia32_pmovqw256_mask ((__v4di) __A,
(__v8hi)
(__mmask8) -1);
_mm256_mask_cvtepi64_storeu_epi16 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovqw256mem_mask ((__v8hi *) __P, (__v4di) __A, __M);
_mm256_mask_cvtepi64_epi16 (__m128i __O, __mmask8 __M, __m256i __A)
(__v8hi) __O, __M);
_mm256_maskz_cvtepi64_epi16 (__mmask8 __M, __m256i __A)
(__v8hi)
__M);
_mm_cvtsepi64_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_pmovsqw128_mask ((__v2di) __A,
(__v8hi)
(__mmask8) -1);
_mm_mask_cvtsepi64_storeu_epi16 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovsqw128mem_mask ((__v8hi *) __P, (__v2di) __A, __M);
_mm_mask_cvtsepi64_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
(__v8hi) __O, __M);
_mm_maskz_cvtsepi64_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm256_cvtsepi64_epi16 (__m256i __A)
return (__m128i) __builtin_ia32_pmovsqw256_mask ((__v4di) __A,
(__v8hi)
(__mmask8) -1);
_mm256_mask_cvtsepi64_storeu_epi16 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovsqw256mem_mask ((__v8hi *) __P, (__v4di) __A, __M);
_mm256_mask_cvtsepi64_epi16 (__m128i __O, __mmask8 __M, __m256i __A)
(__v8hi) __O, __M);
_mm256_maskz_cvtsepi64_epi16 (__mmask8 __M, __m256i __A)
(__v8hi)
__M);
_mm_cvtusepi64_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_pmovusqw128_mask ((__v2di) __A,
(__v8hi)
(__mmask8) -1);
_mm_mask_cvtusepi64_storeu_epi16 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovusqw128mem_mask ((__v8hi *) __P, (__v2di) __A, __M);
_mm_mask_cvtusepi64_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
(__v8hi) __O, __M);
_mm_maskz_cvtusepi64_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm256_cvtusepi64_epi16 (__m256i __A)
return (__m128i) __builtin_ia32_pmovusqw256_mask ((__v4di) __A,
(__v8hi)
(__mmask8) -1);
_mm256_mask_cvtusepi64_storeu_epi16 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovusqw256mem_mask ((__v8hi *) __P, (__v4di) __A, __M);
_mm256_mask_cvtusepi64_epi16 (__m128i __O, __mmask8 __M, __m256i __A)
(__v8hi) __O, __M);
_mm256_maskz_cvtusepi64_epi16 (__mmask8 __M, __m256i __A)
(__v8hi)
__M);
_mm_cvtepi64_epi32 (__m128i __A)
return (__m128i) __builtin_ia32_pmovqd128_mask ((__v2di) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvtepi64_storeu_epi32 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovqd128mem_mask ((__v4si *) __P, (__v2di) __A, __M);
_mm_mask_cvtepi64_epi32 (__m128i __O, __mmask8 __M, __m128i __A)
(__v4si) __O, __M);
_mm_maskz_cvtepi64_epi32 (__mmask8 __M, __m128i __A)
(__v4si)
__M);
_mm256_cvtepi64_epi32 (__m256i __A)
return (__m128i) __builtin_ia32_pmovqd256_mask ((__v4di) __A,
(__v4si)
(__mmask8) -1);
_mm256_mask_cvtepi64_storeu_epi32 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovqd256mem_mask ((__v4si *) __P, (__v4di) __A, __M);
_mm256_mask_cvtepi64_epi32 (__m128i __O, __mmask8 __M, __m256i __A)
(__v4si) __O, __M);
_mm256_maskz_cvtepi64_epi32 (__mmask8 __M, __m256i __A)
(__v4si)
__M);
_mm_cvtsepi64_epi32 (__m128i __A)
return (__m128i) __builtin_ia32_pmovsqd128_mask ((__v2di) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvtsepi64_storeu_epi32 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovsqd128mem_mask ((__v4si *) __P, (__v2di) __A, __M);
_mm_mask_cvtsepi64_epi32 (__m128i __O, __mmask8 __M, __m128i __A)
(__v4si) __O, __M);
_mm_maskz_cvtsepi64_epi32 (__mmask8 __M, __m128i __A)
(__v4si)
__M);
_mm256_cvtsepi64_epi32 (__m256i __A)
return (__m128i) __builtin_ia32_pmovsqd256_mask ((__v4di) __A,
(__v4si)
(__mmask8) -1);
_mm256_mask_cvtsepi64_storeu_epi32 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovsqd256mem_mask ((__v4si *) __P, (__v4di) __A, __M);
_mm256_mask_cvtsepi64_epi32 (__m128i __O, __mmask8 __M, __m256i __A)
(__v4si)__O,
__M);
_mm256_maskz_cvtsepi64_epi32 (__mmask8 __M, __m256i __A)
(__v4si)
__M);
_mm_cvtusepi64_epi32 (__m128i __A)
return (__m128i) __builtin_ia32_pmovusqd128_mask ((__v2di) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvtusepi64_storeu_epi32 (void * __P, __mmask8 __M, __m128i __A)
__builtin_ia32_pmovusqd128mem_mask ((__v4si *) __P, (__v2di) __A, __M);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm_mask_cvtusepi64_epi32 (__m128i __O, __mmask8 __M, __m128i __A)
(__v4si) __O, __M);
_mm_maskz_cvtusepi64_epi32 (__mmask8 __M, __m128i __A)
(__v4si)
__M);
_mm256_cvtusepi64_epi32 (__m256i __A)
return (__m128i) __builtin_ia32_pmovusqd256_mask ((__v4di) __A,
(__v4si)
(__mmask8) -1);
_mm256_mask_cvtusepi64_storeu_epi32 (void * __P, __mmask8 __M, __m256i __A)
__builtin_ia32_pmovusqd256mem_mask ((__v4si *) __P, (__v4di) __A, __M);
_mm256_mask_cvtusepi64_epi32 (__m128i __O, __mmask8 __M, __m256i __A)
(__v4si) __O, __M);
_mm256_maskz_cvtusepi64_epi32 (__mmask8 __M, __m256i __A)
(__v4si)
__M);
_mm256_mask_broadcastss_ps (__m256 __O, __mmask8 __M, __m128 __A)
return (__m256) __builtin_ia32_broadcastss256_mask ((__v4sf) __A,
(__v8sf) __O,
__M);
_mm256_maskz_broadcastss_ps (__mmask8 __M, __m128 __A)
(__v8sf)
__M);
_mm_mask_broadcastss_ps (__m128 __O, __mmask8 __M, __m128 __A)
return (__m128) __builtin_ia32_broadcastss128_mask ((__v4sf) __A,
(__v4sf) __O,
__M);
_mm_maskz_broadcastss_ps (__mmask8 __M, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
__M);
_mm256_mask_broadcastsd_pd (__m256d __O, __mmask8 __M, __m128d __A)
return (__m256d) __builtin_ia32_broadcastsd256_mask ((__v2df) __A,
(__v4df) __O,
__M);
_mm256_maskz_broadcastsd_pd (__mmask8 __M, __m128d __A)
(__v4df)
__M);
_mm256_mask_broadcastd_epi32 (__m256i __O, __mmask8 __M, __m128i __A)
return (__m256i) __builtin_ia32_pbroadcastd256_mask ((__v4si) __A,
(__v8si) __O,
__M);
_mm256_maskz_broadcastd_epi32 (__mmask8 __M, __m128i __A)
(__v8si)
__M);
_mm256_mask_set1_epi32 (__m256i __O, __mmask8 __M, int __A)
return (__m256i) __builtin_ia32_pbroadcastd256_gpr_mask (__A, (__v8si) __O,
__M);
_mm256_maskz_set1_epi32 (__mmask8 __M, int __A)
(__v8si)
__M);
_mm_mask_broadcastd_epi32 (__m128i __O, __mmask8 __M, __m128i __A)
return (__m128i) __builtin_ia32_pbroadcastd128_mask ((__v4si) __A,
(__v4si) __O,
__M);
_mm_maskz_broadcastd_epi32 (__mmask8 __M, __m128i __A)
(__v4si)
__M);
_mm_mask_set1_epi32 (__m128i __O, __mmask8 __M, int __A)
return (__m128i) __builtin_ia32_pbroadcastd128_gpr_mask (__A, (__v4si) __O,
__M);
_mm_maskz_set1_epi32 (__mmask8 __M, int __A)
return (__m128i)
(__v4si) _mm_setzero_si128 (),
__M);
_mm256_mask_broadcastq_epi64 (__m256i __O, __mmask8 __M, __m128i __A)
return (__m256i) __builtin_ia32_pbroadcastq256_mask ((__v2di) __A,
(__v4di) __O,
__M);
_mm256_maskz_broadcastq_epi64 (__mmask8 __M, __m128i __A)
(__v4di)
__M);
_mm256_mask_set1_epi64 (__m256i __O, __mmask8 __M, long long __A)
return (__m256i) __builtin_ia32_pbroadcastq256_gpr_mask (__A, (__v4di) __O,
__M);
_mm256_maskz_set1_epi64 (__mmask8 __M, long long __A)
(__v4di)
__M);
_mm_mask_broadcastq_epi64 (__m128i __O, __mmask8 __M, __m128i __A)
return (__m128i) __builtin_ia32_pbroadcastq128_mask ((__v2di) __A,
(__v2di) __O,
__M);
_mm_maskz_broadcastq_epi64 (__mmask8 __M, __m128i __A)
(__v2di)
__M);
_mm_mask_set1_epi64 (__m128i __O, __mmask8 __M, long long __A)
return (__m128i) __builtin_ia32_pbroadcastq128_gpr_mask (__A, (__v2di) __O,
__M);
_mm_maskz_set1_epi64 (__mmask8 __M, long long __A)
return (__m128i)
(__v2di) _mm_setzero_si128 (),
__M);
_mm256_broadcast_f32x4 (__m128 __A)
return (__m256) __builtin_ia32_broadcastf32x4_256_mask ((__v4sf) __A,
(__v8sf)_mm256_undefined_pd (),
(__mmask8) -1);
_mm256_mask_broadcast_f32x4 (__m256 __O, __mmask8 __M, __m128 __A)
(__v8sf) __O,
__M);
_mm256_maskz_broadcast_f32x4 (__mmask8 __M, __m128 __A)
(__v8sf)
_mm256_setzero_ps (),
__M);
_mm256_broadcast_i32x4 (__m128i __A)
return (__m256i) __builtin_ia32_broadcasti32x4_256_mask ((__v4si)
__A,
(__v8si)_mm256_undefined_si256 (),
(__mmask8) -1);
_mm256_mask_broadcast_i32x4 (__m256i __O, __mmask8 __M, __m128i __A)
__A,
(__v8si)
__O, __M);
_mm256_maskz_broadcast_i32x4 (__mmask8 __M, __m128i __A)
__A,
(__v8si)
__M);
_mm256_mask_cvtepi8_epi32 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovsxbd256_mask ((__v16qi) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi8_epi32 (__mmask8 __U, __m128i __A)
(__v8si)
(__mmask8) __U);
extern __inline __m128i
_mm_mask_cvtepi8_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovsxbd128_mask ((__v16qi) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtepi8_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
extern __inline __m256i
_mm256_mask_cvtepi8_epi64 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovsxbq256_mask ((__v16qi) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi8_epi64 (__mmask8 __U, __m128i __A)
(__v4di)
(__mmask8) __U);
_mm_mask_cvtepi8_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovsxbq128_mask ((__v16qi) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtepi8_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm256_mask_cvtepi16_epi32 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovsxwd256_mask ((__v8hi) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi16_epi32 (__mmask8 __U, __m128i __A)
(__v8si)
(__mmask8) __U);
_mm_mask_cvtepi16_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovsxwd128_mask ((__v8hi) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtepi16_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvtepi16_epi64 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovsxwq256_mask ((__v8hi) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi16_epi64 (__mmask8 __U, __m128i __A)
(__v4di)
(__mmask8) __U);
_mm_mask_cvtepi16_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovsxwq128_mask ((__v8hi) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtepi16_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm256_mask_cvtepi32_epi64 (__m256i __W, __mmask8 __U, __m128i __X)
return (__m256i) __builtin_ia32_pmovsxdq256_mask ((__v4si) __X,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi32_epi64 (__mmask8 __U, __m128i __X)
(__v4di)
(__mmask8) __U);
_mm_mask_cvtepi32_epi64 (__m128i __W, __mmask8 __U, __m128i __X)
return (__m128i) __builtin_ia32_pmovsxdq128_mask ((__v4si) __X,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtepi32_epi64 (__mmask8 __U, __m128i __X)
(__v2di)
(__mmask8) __U);
_mm256_mask_cvtepu8_epi32 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovzxbd256_mask ((__v16qi) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu8_epi32 (__mmask8 __U, __m128i __A)
(__v8si)
(__mmask8) __U);
_mm_mask_cvtepu8_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovzxbd128_mask ((__v16qi) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtepu8_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvtepu8_epi64 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovzxbq256_mask ((__v16qi) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu8_epi64 (__mmask8 __U, __m128i __A)
(__v4di)
(__mmask8) __U);
_mm_mask_cvtepu8_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovzxbq128_mask ((__v16qi) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtepu8_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm256_mask_cvtepu16_epi32 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovzxwd256_mask ((__v8hi) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu16_epi32 (__mmask8 __U, __m128i __A)
(__v8si)
(__mmask8) __U);
_mm_mask_cvtepu16_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovzxwd128_mask ((__v8hi) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtepu16_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_cvtepu16_epi64 (__m256i __W, __mmask8 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovzxwq256_mask ((__v8hi) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu16_epi64 (__mmask8 __U, __m128i __A)
(__v4di)
(__mmask8) __U);
_mm_mask_cvtepu16_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovzxwq128_mask ((__v8hi) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtepu16_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm256_mask_cvtepu32_epi64 (__m256i __W, __mmask8 __U, __m128i __X)
return (__m256i) __builtin_ia32_pmovzxdq256_mask ((__v4si) __X,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu32_epi64 (__mmask8 __U, __m128i __X)
(__v4di)
(__mmask8) __U);
_mm_mask_cvtepu32_epi64 (__m128i __W, __mmask8 __U, __m128i __X)
return (__m128i) __builtin_ia32_pmovzxdq128_mask ((__v4si) __X,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtepu32_epi64 (__mmask8 __U, __m128i __X)
(__v2di)
(__mmask8) __U);
extern __inline __m256d
_mm256_rcp14_pd (__m256d __A)
return (__m256d) __builtin_ia32_rcp14pd256_mask ((__v4df) __A,
(__v4df)
(__mmask8) -1);
_mm256_mask_rcp14_pd (__m256d __W, __mmask8 __U, __m256d __A)
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_rcp14_pd (__mmask8 __U, __m256d __A)
(__v4df)
(__mmask8) __U);
_mm_rcp14_pd (__m128d __A)
return (__m128d) __builtin_ia32_rcp14pd128_mask ((__v2df) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_rcp14_pd (__m128d __W, __mmask8 __U, __m128d __A)
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_rcp14_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_rcp14_ps (__m256 __A)
return (__m256) __builtin_ia32_rcp14ps256_mask ((__v8sf) __A,
(__v8sf)
(__mmask8) -1);
_mm256_mask_rcp14_ps (__m256 __W, __mmask8 __U, __m256 __A)
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_rcp14_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm_rcp14_ps (__m128 __A)
return (__m128) __builtin_ia32_rcp14ps128_mask ((__v4sf) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_rcp14_ps (__m128 __W, __mmask8 __U, __m128 __A)
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_rcp14_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_rsqrt14_pd (__m256d __A)
return (__m256d) __builtin_ia32_rsqrt14pd256_mask ((__v4df) __A,
(__v4df)
(__mmask8) -1);
_mm256_mask_rsqrt14_pd (__m256d __W, __mmask8 __U, __m256d __A)
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_rsqrt14_pd (__mmask8 __U, __m256d __A)
(__v4df)
(__mmask8) __U);
_mm_rsqrt14_pd (__m128d __A)
return (__m128d) __builtin_ia32_rsqrt14pd128_mask ((__v2df) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_rsqrt14_pd (__m128d __W, __mmask8 __U, __m128d __A)
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_rsqrt14_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_rsqrt14_ps (__m256 __A)
return (__m256) __builtin_ia32_rsqrt14ps256_mask ((__v8sf) __A,
(__v8sf)
(__mmask8) -1);
_mm256_mask_rsqrt14_ps (__m256 __W, __mmask8 __U, __m256 __A)
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_rsqrt14_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm_rsqrt14_ps (__m128 __A)
return (__m128) __builtin_ia32_rsqrt14ps128_mask ((__v4sf) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_rsqrt14_ps (__m128 __W, __mmask8 __U, __m128 __A)
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_rsqrt14_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_sqrt_pd (__m256d __W, __mmask8 __U, __m256d __A)
return (__m256d) __builtin_ia32_sqrtpd256_mask ((__v4df) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_sqrt_pd (__mmask8 __U, __m256d __A)
(__v4df)
(__mmask8) __U);
_mm_mask_sqrt_pd (__m128d __W, __mmask8 __U, __m128d __A)
return (__m128d) __builtin_ia32_sqrtpd128_mask ((__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_sqrt_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_sqrt_ps (__m256 __W, __mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_sqrtps256_mask ((__v8sf) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_sqrt_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm_mask_sqrt_ps (__m128 __W, __mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_sqrtps128_mask ((__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_sqrt_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_add_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_add_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm256_mask_add_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_add_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm256_mask_sub_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_sub_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm256_mask_sub_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_sub_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_mask_add_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_add_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm_mask_add_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_add_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm_mask_sub_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_sub_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm_mask_sub_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_sub_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_getexp_ps (__m256 __A)
return (__m256) __builtin_ia32_getexpps256_mask ((__v8sf) __A,
(__v8sf)
(__mmask8) -1);
_mm256_mask_getexp_ps (__m256 __W, __mmask8 __U, __m256 __A)
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_getexp_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm256_getexp_pd (__m256d __A)
return (__m256d) __builtin_ia32_getexppd256_mask ((__v4df) __A,
(__v4df)
(__mmask8) -1);
_mm256_mask_getexp_pd (__m256d __W, __mmask8 __U, __m256d __A)
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_getexp_pd (__mmask8 __U, __m256d __A)
(__v4df)
(__mmask8) __U);
_mm_getexp_ps (__m128 __A)
return (__m128) __builtin_ia32_getexpps128_mask ((__v4sf) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_getexp_ps (__m128 __W, __mmask8 __U, __m128 __A)
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_getexp_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_getexp_pd (__m128d __A)
return (__m128d) __builtin_ia32_getexppd128_mask ((__v2df) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_getexp_pd (__m128d __W, __mmask8 __U, __m128d __A)
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_getexp_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_srl_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psrld256_mask ((__v8si) __A,
(__v4si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_srl_epi32 (__mmask8 __U, __m256i __A, __m128i __B)
(__v4si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_srl_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psrld128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_srl_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_mask_srl_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psrlq256_mask ((__v4di) __A,
(__v2di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_srl_epi64 (__mmask8 __U, __m256i __A, __m128i __B)
(__v2di) __B,
(__v4di)
(__mmask8) __U);
_mm_mask_srl_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psrlq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_srl_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_and_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pandd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_and_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm256_scalef_pd (__m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_scalefpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df)
(__mmask8) -1);
_mm256_mask_scalef_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_scalef_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm256_scalef_ps (__m256 __A, __m256 __B)
return (__m256) __builtin_ia32_scalefps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf)
(__mmask8) -1);
_mm256_mask_scalef_ps (__m256 __W, __mmask8 __U, __m256 __A,
__m256 __B)
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_scalef_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_scalef_pd (__m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_scalefpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_scalef_pd (__m128d __W, __mmask8 __U, __m128d __A,
__m128d __B)
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_scalef_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_scalef_ps (__m128 __A, __m128 __B)
return (__m128) __builtin_ia32_scalefps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_scalef_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_scalef_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_fmadd_pd (__m256d __A, __mmask8 __U, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfmaddpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_mask3_fmadd_pd (__m256d __A, __m256d __B, __m256d __C,
__mmask8 __U)
return (__m256d) __builtin_ia32_vfmaddpd256_mask3 ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_maskz_fmadd_pd (__mmask8 __U, __m256d __A, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfmaddpd256_maskz ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm_mask_fmadd_pd (__m128d __A, __mmask8 __U, __m128d __B, __m128d __C)
return (__m128d) __builtin_ia32_vfmaddpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_mask3_fmadd_pd (__m128d __A, __m128d __B, __m128d __C,
__mmask8 __U)
return (__m128d) __builtin_ia32_vfmaddpd128_mask3 ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_maskz_fmadd_pd (__mmask8 __U, __m128d __A, __m128d __B,
__m128d __C)
return (__m128d) __builtin_ia32_vfmaddpd128_maskz ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm256_mask_fmadd_ps (__m256 __A, __mmask8 __U, __m256 __B, __m256 __C)
return (__m256) __builtin_ia32_vfmaddps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_mask3_fmadd_ps (__m256 __A, __m256 __B, __m256 __C,
__mmask8 __U)
return (__m256) __builtin_ia32_vfmaddps256_mask3 ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_maskz_fmadd_ps (__mmask8 __U, __m256 __A, __m256 __B,
__m256 __C)
return (__m256) __builtin_ia32_vfmaddps256_maskz ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm_mask_fmadd_ps (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfmaddps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_mask3_fmadd_ps (__m128 __A, __m128 __B, __m128 __C, __mmask8 __U)
return (__m128) __builtin_ia32_vfmaddps128_mask3 ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_maskz_fmadd_ps (__mmask8 __U, __m128 __A, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfmaddps128_maskz ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm256_mask_fmsub_pd (__m256d __A, __mmask8 __U, __m256d __B,
__m256d __C)
(__v4df) __B,
-(__v4df) __C,
(__mmask8) __U);
_mm256_mask3_fmsub_pd (__m256d __A, __m256d __B, __m256d __C,
__mmask8 __U)
return (__m256d) __builtin_ia32_vfmsubpd256_mask3 ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_maskz_fmsub_pd (__mmask8 __U, __m256d __A, __m256d __B,
__m256d __C)
(__v4df) __B,
-(__v4df) __C,
(__mmask8) __U);
_mm_mask_fmsub_pd (__m128d __A, __mmask8 __U, __m128d __B, __m128d __C)
(__v2df) __B,
-(__v2df) __C,
(__mmask8) __U);
_mm_mask3_fmsub_pd (__m128d __A, __m128d __B, __m128d __C,
__mmask8 __U)
return (__m128d) __builtin_ia32_vfmsubpd128_mask3 ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_maskz_fmsub_pd (__mmask8 __U, __m128d __A, __m128d __B,
__m128d __C)
(__v2df) __B,
-(__v2df) __C,
(__mmask8) __U);
_mm256_mask_fmsub_ps (__m256 __A, __mmask8 __U, __m256 __B, __m256 __C)
(__v8sf) __B,
-(__v8sf) __C,
(__mmask8) __U);
_mm256_mask3_fmsub_ps (__m256 __A, __m256 __B, __m256 __C,
__mmask8 __U)
return (__m256) __builtin_ia32_vfmsubps256_mask3 ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_maskz_fmsub_ps (__mmask8 __U, __m256 __A, __m256 __B,
__m256 __C)
(__v8sf) __B,
-(__v8sf) __C,
(__mmask8) __U);
_mm_mask_fmsub_ps (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C)
(__v4sf) __B,
-(__v4sf) __C,
(__mmask8) __U);
_mm_mask3_fmsub_ps (__m128 __A, __m128 __B, __m128 __C, __mmask8 __U)
return (__m128) __builtin_ia32_vfmsubps128_mask3 ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_maskz_fmsub_ps (__mmask8 __U, __m128 __A, __m128 __B, __m128 __C)
(__v4sf) __B,
-(__v4sf) __C,
(__mmask8) __U);
_mm256_mask_fmaddsub_pd (__m256d __A, __mmask8 __U, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfmaddsubpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_mask3_fmaddsub_pd (__m256d __A, __m256d __B, __m256d __C,
__mmask8 __U)
return (__m256d) __builtin_ia32_vfmaddsubpd256_mask3 ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8)
__U);
_mm256_maskz_fmaddsub_pd (__mmask8 __U, __m256d __A, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfmaddsubpd256_maskz ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8)
__U);
_mm_mask_fmaddsub_pd (__m128d __A, __mmask8 __U, __m128d __B,
__m128d __C)
return (__m128d) __builtin_ia32_vfmaddsubpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_mask3_fmaddsub_pd (__m128d __A, __m128d __B, __m128d __C,
__mmask8 __U)
return (__m128d) __builtin_ia32_vfmaddsubpd128_mask3 ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8)
__U);
_mm_maskz_fmaddsub_pd (__mmask8 __U, __m128d __A, __m128d __B,
__m128d __C)
return (__m128d) __builtin_ia32_vfmaddsubpd128_maskz ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8)
__U);
_mm256_mask_fmaddsub_ps (__m256 __A, __mmask8 __U, __m256 __B,
__m256 __C)
return (__m256) __builtin_ia32_vfmaddsubps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_mask3_fmaddsub_ps (__m256 __A, __m256 __B, __m256 __C,
__mmask8 __U)
return (__m256) __builtin_ia32_vfmaddsubps256_mask3 ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_maskz_fmaddsub_ps (__mmask8 __U, __m256 __A, __m256 __B,
__m256 __C)
return (__m256) __builtin_ia32_vfmaddsubps256_maskz ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm_mask_fmaddsub_ps (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfmaddsubps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_mask3_fmaddsub_ps (__m128 __A, __m128 __B, __m128 __C,
__mmask8 __U)
return (__m128) __builtin_ia32_vfmaddsubps128_mask3 ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_maskz_fmaddsub_ps (__mmask8 __U, __m128 __A, __m128 __B,
__m128 __C)
return (__m128) __builtin_ia32_vfmaddsubps128_maskz ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm256_mask_fmsubadd_pd (__m256d __A, __mmask8 __U, __m256d __B,
__m256d __C)
(__v4df) __B,
-(__v4df) __C,
(__mmask8) __U);
_mm256_mask3_fmsubadd_pd (__m256d __A, __m256d __B, __m256d __C,
__mmask8 __U)
return (__m256d) __builtin_ia32_vfmsubaddpd256_mask3 ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8)
__U);
_mm256_maskz_fmsubadd_pd (__mmask8 __U, __m256d __A, __m256d __B,
__m256d __C)
(__v4df) __B,
-(__v4df) __C,
(__mmask8)
__U);
_mm_mask_fmsubadd_pd (__m128d __A, __mmask8 __U, __m128d __B,
__m128d __C)
(__v2df) __B,
-(__v2df) __C,
(__mmask8) __U);
_mm_mask3_fmsubadd_pd (__m128d __A, __m128d __B, __m128d __C,
__mmask8 __U)
return (__m128d) __builtin_ia32_vfmsubaddpd128_mask3 ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8)
__U);
_mm_maskz_fmsubadd_pd (__mmask8 __U, __m128d __A, __m128d __B,
__m128d __C)
(__v2df) __B,
-(__v2df) __C,
(__mmask8)
__U);
_mm256_mask_fmsubadd_ps (__m256 __A, __mmask8 __U, __m256 __B,
__m256 __C)
(__v8sf) __B,
-(__v8sf) __C,
(__mmask8) __U);
_mm256_mask3_fmsubadd_ps (__m256 __A, __m256 __B, __m256 __C,
__mmask8 __U)
return (__m256) __builtin_ia32_vfmsubaddps256_mask3 ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_maskz_fmsubadd_ps (__mmask8 __U, __m256 __A, __m256 __B,
__m256 __C)
(__v8sf) __B,
-(__v8sf) __C,
(__mmask8) __U);
_mm_mask_fmsubadd_ps (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C)
(__v4sf) __B,
-(__v4sf) __C,
(__mmask8) __U);
_mm_mask3_fmsubadd_ps (__m128 __A, __m128 __B, __m128 __C,
__mmask8 __U)
return (__m128) __builtin_ia32_vfmsubaddps128_mask3 ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_maskz_fmsubadd_ps (__mmask8 __U, __m128 __A, __m128 __B,
__m128 __C)
(__v4sf) __B,
-(__v4sf) __C,
(__mmask8) __U);
_mm256_mask_fnmadd_pd (__m256d __A, __mmask8 __U, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfnmaddpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_mask3_fnmadd_pd (__m256d __A, __m256d __B, __m256d __C,
__mmask8 __U)
return (__m256d) __builtin_ia32_vfmaddpd256_mask3 (-(__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_maskz_fnmadd_pd (__mmask8 __U, __m256d __A, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfmaddpd256_maskz (-(__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm_mask_fnmadd_pd (__m128d __A, __mmask8 __U, __m128d __B,
__m128d __C)
return (__m128d) __builtin_ia32_vfnmaddpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_mask3_fnmadd_pd (__m128d __A, __m128d __B, __m128d __C,
__mmask8 __U)
return (__m128d) __builtin_ia32_vfmaddpd128_mask3 (-(__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_maskz_fnmadd_pd (__mmask8 __U, __m128d __A, __m128d __B,
__m128d __C)
return (__m128d) __builtin_ia32_vfmaddpd128_maskz (-(__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm256_mask_fnmadd_ps (__m256 __A, __mmask8 __U, __m256 __B,
__m256 __C)
return (__m256) __builtin_ia32_vfnmaddps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_mask3_fnmadd_ps (__m256 __A, __m256 __B, __m256 __C,
__mmask8 __U)
return (__m256) __builtin_ia32_vfmaddps256_mask3 (-(__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_maskz_fnmadd_ps (__mmask8 __U, __m256 __A, __m256 __B,
__m256 __C)
return (__m256) __builtin_ia32_vfmaddps256_maskz (-(__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm_mask_fnmadd_ps (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfnmaddps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_mask3_fnmadd_ps (__m128 __A, __m128 __B, __m128 __C, __mmask8 __U)
return (__m128) __builtin_ia32_vfmaddps128_mask3 (-(__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_maskz_fnmadd_ps (__mmask8 __U, __m128 __A, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfmaddps128_maskz (-(__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm256_mask_fnmsub_pd (__m256d __A, __mmask8 __U, __m256d __B,
__m256d __C)
return (__m256d) __builtin_ia32_vfnmsubpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_mask3_fnmsub_pd (__m256d __A, __m256d __B, __m256d __C,
__mmask8 __U)
return (__m256d) __builtin_ia32_vfnmsubpd256_mask3 ((__v4df) __A,
(__v4df) __B,
(__v4df) __C,
(__mmask8) __U);
_mm256_maskz_fnmsub_pd (__mmask8 __U, __m256d __A, __m256d __B,
__m256d __C)
(__v4df) __B,
-(__v4df) __C,
(__mmask8) __U);
_mm_mask_fnmsub_pd (__m128d __A, __mmask8 __U, __m128d __B,
__m128d __C)
return (__m128d) __builtin_ia32_vfnmsubpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_mask3_fnmsub_pd (__m128d __A, __m128d __B, __m128d __C,
__mmask8 __U)
return (__m128d) __builtin_ia32_vfnmsubpd128_mask3 ((__v2df) __A,
(__v2df) __B,
(__v2df) __C,
(__mmask8) __U);
_mm_maskz_fnmsub_pd (__mmask8 __U, __m128d __A, __m128d __B,
__m128d __C)
(__v2df) __B,
-(__v2df) __C,
(__mmask8) __U);
_mm256_mask_fnmsub_ps (__m256 __A, __mmask8 __U, __m256 __B,
__m256 __C)
return (__m256) __builtin_ia32_vfnmsubps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_mask3_fnmsub_ps (__m256 __A, __m256 __B, __m256 __C,
__mmask8 __U)
return (__m256) __builtin_ia32_vfnmsubps256_mask3 ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __C,
(__mmask8) __U);
_mm256_maskz_fnmsub_ps (__mmask8 __U, __m256 __A, __m256 __B,
__m256 __C)
(__v8sf) __B,
-(__v8sf) __C,
(__mmask8) __U);
_mm_mask_fnmsub_ps (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfnmsubps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_mask3_fnmsub_ps (__m128 __A, __m128 __B, __m128 __C, __mmask8 __U)
return (__m128) __builtin_ia32_vfnmsubps128_mask3 ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __C,
(__mmask8) __U);
_mm_maskz_fnmsub_ps (__mmask8 __U, __m128 __A, __m128 __B, __m128 __C)
(__v4sf) __B,
-(__v4sf) __C,
(__mmask8) __U);
_mm_mask_and_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pandd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_and_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_mask_andnot_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pandnd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_andnot_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_andnot_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pandnd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_andnot_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_mask_or_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pord256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_or_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_or_epi32 (__m128i __W, __mmask8 __U, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pord128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_or_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_mask_xor_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pxord256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_xor_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_xor_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pxord128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_xor_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm_mask_cvtpd_ps (__m128 __W, __mmask8 __U, __m128d __A)
return (__m128) __builtin_ia32_cvtpd2ps_mask ((__v2df) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_cvtpd_ps (__mmask8 __U, __m128d __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_cvtpd_ps (__m128 __W, __mmask8 __U, __m256d __A)
return (__m128) __builtin_ia32_cvtpd2ps256_mask ((__v4df) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm256_maskz_cvtpd_ps (__mmask8 __U, __m256d __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_cvtps_epi32 (__m256i __W, __mmask8 __U, __m256 __A)
return (__m256i) __builtin_ia32_cvtps2dq256_mask ((__v8sf) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvtps_epi32 (__mmask8 __U, __m256 __A)
(__v8si)
_mm256_setzero_si256 (),
(__mmask8) __U);
_mm_mask_cvtps_epi32 (__m128i __W, __mmask8 __U, __m128 __A)
return (__m128i) __builtin_ia32_cvtps2dq128_mask ((__v4sf) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtps_epi32 (__mmask8 __U, __m128 __A)
(__v4si)
(__mmask8) __U);
_mm256_cvtps_epu32 (__m256 __A)
return (__m256i) __builtin_ia32_cvtps2udq256_mask ((__v8sf) __A,
(__v8si)
(__mmask8) -1);
_mm256_mask_cvtps_epu32 (__m256i __W, __mmask8 __U, __m256 __A)
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_cvtps_epu32 (__mmask8 __U, __m256 __A)
(__v8si)
(__mmask8) __U);
_mm_cvtps_epu32 (__m128 __A)
return (__m128i) __builtin_ia32_cvtps2udq128_mask ((__v4sf) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_cvtps_epu32 (__m128i __W, __mmask8 __U, __m128 __A)
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_cvtps_epu32 (__mmask8 __U, __m128 __A)
(__v4si)
(__mmask8) __U);
_mm256_mask_movedup_pd (__m256d __W, __mmask8 __U, __m256d __A)
return (__m256d) __builtin_ia32_movddup256_mask ((__v4df) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_movedup_pd (__mmask8 __U, __m256d __A)
(__v4df)
_mm256_setzero_pd (),
(__mmask8) __U);
_mm_mask_movedup_pd (__m128d __W, __mmask8 __U, __m128d __A)
return (__m128d) __builtin_ia32_movddup128_mask ((__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_movedup_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_movehdup_ps (__m256 __W, __mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_movshdup256_mask ((__v8sf) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_movehdup_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm_mask_movehdup_ps (__m128 __W, __mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_movshdup128_mask ((__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_movehdup_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_moveldup_ps (__m256 __W, __mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_movsldup256_mask ((__v8sf) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_moveldup_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm_mask_moveldup_ps (__m128 __W, __mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_movsldup128_mask ((__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_moveldup_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_unpackhi_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpckhdq128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_unpackhi_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_mask_unpackhi_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpckhdq256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_unpackhi_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_unpackhi_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpckhqdq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_unpackhi_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_unpackhi_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpckhqdq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_unpackhi_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_mask_unpacklo_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpckldq128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_unpacklo_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_mask_unpacklo_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpckldq256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_unpacklo_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_unpacklo_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpcklqdq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_unpacklo_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_unpacklo_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpcklqdq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_unpacklo_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
extern __inline __mmask8
_mm_cmpeq_epu32_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ucmpd128_mask ((__v4si) __A,
(__v4si) __B, 0,
(__mmask8) -1);
_mm_cmpeq_epi32_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_pcmpeqd128_mask ((__v4si) __A,
(__v4si) __B,
(__mmask8) -1);
_mm_mask_cmpeq_epu32_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B, 0, __U);
_mm_mask_cmpeq_epi32_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B, __U);
_mm256_cmpeq_epu32_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_ucmpd256_mask ((__v8si) __A,
(__v8si) __B, 0,
(__mmask8) -1);
_mm256_cmpeq_epi32_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_pcmpeqd256_mask ((__v8si) __A,
(__v8si) __B,
(__mmask8) -1);
_mm256_mask_cmpeq_epu32_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B, 0, __U);
_mm256_mask_cmpeq_epi32_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B, __U);
_mm_cmpeq_epu64_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ucmpq128_mask ((__v2di) __A,
(__v2di) __B, 0,
(__mmask8) -1);
_mm_cmpeq_epi64_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_pcmpeqq128_mask ((__v2di) __A,
(__v2di) __B,
(__mmask8) -1);
_mm_mask_cmpeq_epu64_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B, 0, __U);
_mm_mask_cmpeq_epi64_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B, __U);
_mm256_cmpeq_epu64_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_ucmpq256_mask ((__v4di) __A,
(__v4di) __B, 0,
(__mmask8) -1);
_mm256_cmpeq_epi64_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_pcmpeqq256_mask ((__v4di) __A,
(__v4di) __B,
(__mmask8) -1);
_mm256_mask_cmpeq_epu64_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B, 0, __U);
_mm256_mask_cmpeq_epi64_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B, __U);
_mm_cmpgt_epu32_mask (__m128i __A, __m128i __B)
(__v4si) __B, 6,
(__mmask8) -1);
_mm_cmpgt_epi32_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_pcmpgtd128_mask ((__v4si) __A,
(__v4si) __B,
(__mmask8) -1);
_mm_mask_cmpgt_epu32_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B, 6, __U);
_mm_mask_cmpgt_epi32_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B, __U);
_mm256_cmpgt_epu32_mask (__m256i __A, __m256i __B)
(__v8si) __B, 6,
(__mmask8) -1);
_mm256_cmpgt_epi32_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_pcmpgtd256_mask ((__v8si) __A,
(__v8si) __B,
(__mmask8) -1);
_mm256_mask_cmpgt_epu32_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B, 6, __U);
_mm256_mask_cmpgt_epi32_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B, __U);
_mm_cmpgt_epu64_mask (__m128i __A, __m128i __B)
(__v2di) __B, 6,
(__mmask8) -1);
_mm_cmpgt_epi64_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_pcmpgtq128_mask ((__v2di) __A,
(__v2di) __B,
(__mmask8) -1);
_mm_mask_cmpgt_epu64_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B, 6, __U);
_mm_mask_cmpgt_epi64_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B, __U);
_mm256_cmpgt_epu64_mask (__m256i __A, __m256i __B)
(__v4di) __B, 6,
(__mmask8) -1);
_mm256_cmpgt_epi64_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_pcmpgtq256_mask ((__v4di) __A,
(__v4di) __B,
(__mmask8) -1);
_mm256_mask_cmpgt_epu64_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B, 6, __U);
_mm256_mask_cmpgt_epi64_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B, __U);
_mm_test_epi32_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ptestmd128 ((__v4si) __A,
(__v4si) __B,
(__mmask8) -1);
_mm_mask_test_epi32_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B, __U);
_mm256_test_epi32_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_ptestmd256 ((__v8si) __A,
(__v8si) __B,
(__mmask8) -1);
_mm256_mask_test_epi32_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B, __U);
_mm_test_epi64_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ptestmq128 ((__v2di) __A,
(__v2di) __B,
(__mmask8) -1);
_mm_mask_test_epi64_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B, __U);
_mm256_test_epi64_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_ptestmq256 ((__v4di) __A,
(__v4di) __B,
(__mmask8) -1);
_mm256_mask_test_epi64_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B, __U);
_mm_testn_epi32_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ptestnmd128 ((__v4si) __A,
(__v4si) __B,
(__mmask8) -1);
_mm_mask_testn_epi32_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B, __U);
_mm256_testn_epi32_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_ptestnmd256 ((__v8si) __A,
(__v8si) __B,
(__mmask8) -1);
_mm256_mask_testn_epi32_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B, __U);
_mm_testn_epi64_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ptestnmq128 ((__v2di) __A,
(__v2di) __B,
(__mmask8) -1);
_mm_mask_testn_epi64_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B, __U);
_mm256_testn_epi64_mask (__m256i __A, __m256i __B)
return (__mmask8) __builtin_ia32_ptestnmq256 ((__v4di) __A,
(__v4di) __B,
(__mmask8) -1);
_mm256_mask_testn_epi64_mask (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B, __U);
_mm256_mask_compress_pd (__m256d __W, __mmask8 __U, __m256d __A)
return (__m256d) __builtin_ia32_compressdf256_mask ((__v4df) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_compress_pd (__mmask8 __U, __m256d __A)
(__v4df)
(__mmask8) __U);
extern __inline void
_mm256_mask_compressstoreu_pd (void *__P, __mmask8 __U, __m256d __A)
__builtin_ia32_compressstoredf256_mask ((__v4df *) __P,
(__v4df) __A,
(__mmask8) __U);
_mm_mask_compress_pd (__m128d __W, __mmask8 __U, __m128d __A)
return (__m128d) __builtin_ia32_compressdf128_mask ((__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_compress_pd (__mmask8 __U, __m128d __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_mask_compressstoreu_pd (void *__P, __mmask8 __U, __m128d __A)
__builtin_ia32_compressstoredf128_mask ((__v2df *) __P,
(__v2df) __A,
(__mmask8) __U);
_mm256_mask_compress_ps (__m256 __W, __mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_compresssf256_mask ((__v8sf) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_compress_ps (__mmask8 __U, __m256 __A)
(__v8sf)
(__mmask8) __U);
_mm256_mask_compressstoreu_ps (void *__P, __mmask8 __U, __m256 __A)
__builtin_ia32_compressstoresf256_mask ((__v8sf *) __P,
(__v8sf) __A,
(__mmask8) __U);
_mm_mask_compress_ps (__m128 __W, __mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_compresssf128_mask ((__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_compress_ps (__mmask8 __U, __m128 __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_compressstoreu_ps (void *__P, __mmask8 __U, __m128 __A)
__builtin_ia32_compressstoresf128_mask ((__v4sf *) __P,
(__v4sf) __A,
(__mmask8) __U);
_mm256_mask_compress_epi64 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_compressdi256_mask ((__v4di) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_compress_epi64 (__mmask8 __U, __m256i __A)
(__v4di)
(__mmask8) __U);
_mm256_mask_compressstoreu_epi64 (void *__P, __mmask8 __U, __m256i __A)
__builtin_ia32_compressstoredi256_mask ((__v4di *) __P,
(__v4di) __A,
(__mmask8) __U);
_mm_mask_compress_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_compressdi128_mask ((__v2di) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_compress_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm_mask_compressstoreu_epi64 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_compressstoredi128_mask ((__v2di *) __P,
(__v2di) __A,
(__mmask8) __U);
_mm256_mask_compress_epi32 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_compresssi256_mask ((__v8si) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_compress_epi32 (__mmask8 __U, __m256i __A)
(__v8si)
(__mmask8) __U);
_mm256_mask_compressstoreu_epi32 (void *__P, __mmask8 __U, __m256i __A)
__builtin_ia32_compressstoresi256_mask ((__v8si *) __P,
(__v8si) __A,
(__mmask8) __U);
_mm_mask_compress_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_compresssi128_mask ((__v4si) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_compress_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm_mask_compressstoreu_epi32 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_compressstoresi128_mask ((__v4si *) __P,
(__v4si) __A,
(__mmask8) __U);
_mm256_mask_expand_pd (__m256d __W, __mmask8 __U, __m256d __A)
return (__m256d) __builtin_ia32_expanddf256_mask ((__v4df) __A,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_expand_pd (__mmask8 __U, __m256d __A)
return (__m256d) __builtin_ia32_expanddf256_maskz ((__v4df) __A,
(__v4df)
(__mmask8) __U);
_mm256_mask_expandloadu_pd (__m256d __W, __mmask8 __U, void const *__P)
return (__m256d) __builtin_ia32_expandloaddf256_mask ((__v4df *) __P,
(__v4df) __W,
(__mmask8)
__U);
_mm256_maskz_expandloadu_pd (__mmask8 __U, void const *__P)
return (__m256d) __builtin_ia32_expandloaddf256_maskz ((__v4df *) __P,
(__v4df)
(__mmask8)
__U);
extern __inline __m128d
_mm_mask_expand_pd (__m128d __W, __mmask8 __U, __m128d __A)
return (__m128d) __builtin_ia32_expanddf128_mask ((__v2df) __A,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_expand_pd (__mmask8 __U, __m128d __A)
return (__m128d) __builtin_ia32_expanddf128_maskz ((__v2df) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_mask_expandloadu_pd (__m128d __W, __mmask8 __U, void const *__P)
return (__m128d) __builtin_ia32_expandloaddf128_mask ((__v2df *) __P,
(__v2df) __W,
(__mmask8)
__U);
_mm_maskz_expandloadu_pd (__mmask8 __U, void const *__P)
return (__m128d) __builtin_ia32_expandloaddf128_maskz ((__v2df *) __P,
(__v2df)
_mm_setzero_pd (),
(__mmask8)
__U);
_mm256_mask_expand_ps (__m256 __W, __mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_expandsf256_mask ((__v8sf) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_expand_ps (__mmask8 __U, __m256 __A)
return (__m256) __builtin_ia32_expandsf256_maskz ((__v8sf) __A,
(__v8sf)
(__mmask8) __U);
_mm256_mask_expandloadu_ps (__m256 __W, __mmask8 __U, void const *__P)
return (__m256) __builtin_ia32_expandloadsf256_mask ((__v8sf *) __P,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_expandloadu_ps (__mmask8 __U, void const *__P)
return (__m256) __builtin_ia32_expandloadsf256_maskz ((__v8sf *) __P,
(__v8sf)
(__mmask8)
__U);
_mm_mask_expand_ps (__m128 __W, __mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_expandsf128_mask ((__v4sf) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_expand_ps (__mmask8 __U, __m128 __A)
return (__m128) __builtin_ia32_expandsf128_maskz ((__v4sf) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_expandloadu_ps (__m128 __W, __mmask8 __U, void const *__P)
return (__m128) __builtin_ia32_expandloadsf128_mask ((__v4sf *) __P,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_expandloadu_ps (__mmask8 __U, void const *__P)
return (__m128) __builtin_ia32_expandloadsf128_maskz ((__v4sf *) __P,
(__v4sf)
_mm_setzero_ps (),
(__mmask8)
__U);
_mm256_mask_expand_epi64 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_expanddi256_mask ((__v4di) __A,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_expand_epi64 (__mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_expanddi256_maskz ((__v4di) __A,
(__v4di)
(__mmask8) __U);
_mm256_mask_expandloadu_epi64 (__m256i __W, __mmask8 __U,
void const *__P)
return (__m256i) __builtin_ia32_expandloaddi256_mask ((__v4di *) __P,
(__v4di) __W,
(__mmask8)
__U);
_mm256_maskz_expandloadu_epi64 (__mmask8 __U, void const *__P)
return (__m256i) __builtin_ia32_expandloaddi256_maskz ((__v4di *) __P,
(__v4di)
(__mmask8)
__U);
_mm_mask_expand_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_expanddi128_mask ((__v2di) __A,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_expand_epi64 (__mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_expanddi128_maskz ((__v2di) __A,
(__v2di)
(__mmask8) __U);
_mm_mask_expandloadu_epi64 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_expandloaddi128_mask ((__v2di *) __P,
(__v2di) __W,
(__mmask8)
__U);
_mm_maskz_expandloadu_epi64 (__mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_expandloaddi128_maskz ((__v2di *) __P,
(__v2di)
(__mmask8)
__U);
_mm256_mask_expand_epi32 (__m256i __W, __mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_expandsi256_mask ((__v8si) __A,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_expand_epi32 (__mmask8 __U, __m256i __A)
return (__m256i) __builtin_ia32_expandsi256_maskz ((__v8si) __A,
(__v8si)
(__mmask8) __U);
_mm256_mask_expandloadu_epi32 (__m256i __W, __mmask8 __U,
void const *__P)
return (__m256i) __builtin_ia32_expandloadsi256_mask ((__v8si *) __P,
(__v8si) __W,
(__mmask8)
__U);
_mm256_maskz_expandloadu_epi32 (__mmask8 __U, void const *__P)
return (__m256i) __builtin_ia32_expandloadsi256_maskz ((__v8si *) __P,
(__v8si)
(__mmask8)
__U);
_mm_mask_expand_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_expandsi128_mask ((__v4si) __A,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_expand_epi32 (__mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_expandsi128_maskz ((__v4si) __A,
(__v4si)
(__mmask8) __U);
_mm_mask_expandloadu_epi32 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_expandloadsi128_mask ((__v4si *) __P,
(__v4si) __W,
(__mmask8)
__U);
_mm_maskz_expandloadu_epi32 (__mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_expandloadsi128_maskz ((__v4si *) __P,
(__v4si)
(__mmask8)
__U);
_mm256_permutex2var_pd (__m256d __A, __m256i __I, __m256d __B)
return (__m256d) __builtin_ia32_vpermt2varpd256_mask ((__v4di) __I
(__v4df) __A,
(__v4df) __B,
(__mmask8) -1);
_mm256_mask_permutex2var_pd (__m256d __A, __mmask8 __U, __m256i __I,
__m256d __B)
(__v4df) __A,
(__v4df) __B,
(__mmask8)
__U);
_mm256_mask2_permutex2var_pd (__m256d __A, __m256i __I, __mmask8 __U,
__m256d __B)
return (__m256d) __builtin_ia32_vpermi2varpd256_mask ((__v4df) __A,
(__v4di) __I
(__v4df) __B,
(__mmask8)
__U);
_mm256_maskz_permutex2var_pd (__mmask8 __U, __m256d __A, __m256i __I,
__m256d __B)
return (__m256d) __builtin_ia32_vpermt2varpd256_maskz ((__v4di) __I
(__v4df) __A,
(__v4df) __B,
(__mmask8)
__U);
_mm256_permutex2var_ps (__m256 __A, __m256i __I, __m256 __B)
return (__m256) __builtin_ia32_vpermt2varps256_mask ((__v8si) __I
(__v8sf) __A,
(__v8sf) __B,
(__mmask8) -1);
_mm256_mask_permutex2var_ps (__m256 __A, __mmask8 __U, __m256i __I,
__m256 __B)
(__v8sf) __A,
(__v8sf) __B,
(__mmask8) __U);
_mm256_mask2_permutex2var_ps (__m256 __A, __m256i __I, __mmask8 __U,
__m256 __B)
return (__m256) __builtin_ia32_vpermi2varps256_mask ((__v8sf) __A,
(__v8si) __I
(__v8sf) __B,
(__mmask8) __U);
_mm256_maskz_permutex2var_ps (__mmask8 __U, __m256 __A, __m256i __I,
__m256 __B)
return (__m256) __builtin_ia32_vpermt2varps256_maskz ((__v8si) __I
(__v8sf) __A,
(__v8sf) __B,
(__mmask8)
__U);
_mm_permutex2var_epi64 (__m128i __A, __m128i __I, __m128i __B)
return (__m128i) __builtin_ia32_vpermt2varq128_mask ((__v2di) __I
(__v2di) __A,
(__v2di) __B,
(__mmask8) -1);
_mm_mask_permutex2var_epi64 (__m128i __A, __mmask8 __U, __m128i __I,
__m128i __B)
(__v2di) __A,
(__v2di) __B,
(__mmask8) __U);
_mm_mask2_permutex2var_epi64 (__m128i __A, __m128i __I, __mmask8 __U,
__m128i __B)
return (__m128i) __builtin_ia32_vpermi2varq128_mask ((__v2di) __A,
(__v2di) __I
(__v2di) __B,
(__mmask8) __U);
_mm_maskz_permutex2var_epi64 (__mmask8 __U, __m128i __A, __m128i __I,
__m128i __B)
return (__m128i) __builtin_ia32_vpermt2varq128_maskz ((__v2di) __I
(__v2di) __A,
(__v2di) __B,
(__mmask8)
__U);
_mm_permutex2var_epi32 (__m128i __A, __m128i __I, __m128i __B)
return (__m128i) __builtin_ia32_vpermt2vard128_mask ((__v4si) __I
(__v4si) __A,
(__v4si) __B,
(__mmask8) -1);
_mm_mask_permutex2var_epi32 (__m128i __A, __mmask8 __U, __m128i __I,
__m128i __B)
(__v4si) __A,
(__v4si) __B,
(__mmask8) __U);
_mm_mask2_permutex2var_epi32 (__m128i __A, __m128i __I, __mmask8 __U,
__m128i __B)
return (__m128i) __builtin_ia32_vpermi2vard128_mask ((__v4si) __A,
(__v4si) __I
(__v4si) __B,
(__mmask8) __U);
_mm_maskz_permutex2var_epi32 (__mmask8 __U, __m128i __A, __m128i __I,
__m128i __B)
return (__m128i) __builtin_ia32_vpermt2vard128_maskz ((__v4si) __I
(__v4si) __A,
(__v4si) __B,
(__mmask8)
__U);
_mm256_permutex2var_epi64 (__m256i __A, __m256i __I, __m256i __B)
return (__m256i) __builtin_ia32_vpermt2varq256_mask ((__v4di) __I
(__v4di) __A,
(__v4di) __B,
(__mmask8) -1);
_mm256_mask_permutex2var_epi64 (__m256i __A, __mmask8 __U, __m256i __I,
__m256i __B)
(__v4di) __A,
(__v4di) __B,
(__mmask8) __U);
_mm256_mask2_permutex2var_epi64 (__m256i __A, __m256i __I,
__mmask8 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpermi2varq256_mask ((__v4di) __A,
(__v4di) __I
(__v4di) __B,
(__mmask8) __U);
_mm256_maskz_permutex2var_epi64 (__mmask8 __U, __m256i __A,
return (__m256i) __builtin_ia32_vpermt2varq256_maskz ((__v4di) __I
(__v4di) __A,
(__v4di) __B,
(__mmask8)
__U);
_mm256_permutex2var_epi32 (__m256i __A, __m256i __I, __m256i __B)
return (__m256i) __builtin_ia32_vpermt2vard256_mask ((__v8si) __I
(__v8si) __A,
(__v8si) __B,
(__mmask8) -1);
_mm256_mask_permutex2var_epi32 (__m256i __A, __mmask8 __U, __m256i __I,
__m256i __B)
(__v8si) __A,
(__v8si) __B,
(__mmask8) __U);
_mm256_mask2_permutex2var_epi32 (__m256i __A, __m256i __I,
return (__m256i) __builtin_ia32_vpermi2vard256_mask ((__v8si) __A,
(__v8si) __I
(__v8si) __B,
(__mmask8) __U);
_mm256_maskz_permutex2var_epi32 (__mmask8 __U, __m256i __A,
return (__m256i) __builtin_ia32_vpermt2vard256_maskz ((__v8si) __I
(__v8si) __A,
(__v8si) __B,
(__mmask8)
__U);
_mm_permutex2var_pd (__m128d __A, __m128i __I, __m128d __B)
return (__m128d) __builtin_ia32_vpermt2varpd128_mask ((__v2di) __I
(__v2df) __A,
(__v2df) __B,
(__mmask8) -1);
_mm_mask_permutex2var_pd (__m128d __A, __mmask8 __U, __m128i __I,
__m128d __B)
(__v2df) __A,
(__v2df) __B,
(__mmask8)
__U);
_mm_mask2_permutex2var_pd (__m128d __A, __m128i __I, __mmask8 __U,
__m128d __B)
return (__m128d) __builtin_ia32_vpermi2varpd128_mask ((__v2df) __A,
(__v2di) __I
(__v2df) __B,
(__mmask8)
__U);
_mm_maskz_permutex2var_pd (__mmask8 __U, __m128d __A, __m128i __I,
__m128d __B)
return (__m128d) __builtin_ia32_vpermt2varpd128_maskz ((__v2di) __I
(__v2df) __A,
(__v2df) __B,
(__mmask8)
__U);
_mm_permutex2var_ps (__m128 __A, __m128i __I, __m128 __B)
return (__m128) __builtin_ia32_vpermt2varps128_mask ((__v4si) __I
(__v4sf) __A,
(__v4sf) __B,
(__mmask8) -1);
_mm_mask_permutex2var_ps (__m128 __A, __mmask8 __U, __m128i __I,
__m128 __B)
(__v4sf) __A,
(__v4sf) __B,
(__mmask8) __U);
_mm_mask2_permutex2var_ps (__m128 __A, __m128i __I, __mmask8 __U,
__m128 __B)
return (__m128) __builtin_ia32_vpermi2varps128_mask ((__v4sf) __A,
(__v4si) __I
(__v4sf) __B,
(__mmask8) __U);
_mm_maskz_permutex2var_ps (__mmask8 __U, __m128 __A, __m128i __I,
__m128 __B)
return (__m128) __builtin_ia32_vpermt2varps128_maskz ((__v4si) __I
(__v4sf) __A,
(__v4sf) __B,
(__mmask8)
__U);
_mm_srav_epi64 (__m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_psravq128_mask ((__v2di) __X,
(__v2di) __Y,
(__v2di)
(__mmask8) -1);
_mm_mask_srav_epi64 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
(__v2di) __Y,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_srav_epi64 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v2di) __Y,
(__v2di)
(__mmask8) __U);
_mm256_mask_sllv_epi32 (__m256i __W, __mmask8 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_psllv8si_mask ((__v8si) __X,
(__v8si) __Y,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_sllv_epi32 (__mmask8 __U, __m256i __X, __m256i __Y)
(__v8si) __Y,
(__v8si)
(__mmask8) __U);
_mm_mask_sllv_epi32 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_psllv4si_mask ((__v4si) __X,
(__v4si) __Y,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_sllv_epi32 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v4si) __Y,
(__v4si)
(__mmask8) __U);
_mm256_mask_sllv_epi64 (__m256i __W, __mmask8 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_psllv4di_mask ((__v4di) __X,
(__v4di) __Y,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_sllv_epi64 (__mmask8 __U, __m256i __X, __m256i __Y)
(__v4di) __Y,
(__v4di)
(__mmask8) __U);
_mm_mask_sllv_epi64 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_psllv2di_mask ((__v2di) __X,
(__v2di) __Y,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_sllv_epi64 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v2di) __Y,
(__v2di)
(__mmask8) __U);
_mm256_mask_srav_epi32 (__m256i __W, __mmask8 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_psrav8si_mask ((__v8si) __X,
(__v8si) __Y,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_srav_epi32 (__mmask8 __U, __m256i __X, __m256i __Y)
(__v8si) __Y,
(__v8si)
(__mmask8) __U);
_mm_mask_srav_epi32 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_psrav4si_mask ((__v4si) __X,
(__v4si) __Y,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_srav_epi32 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v4si) __Y,
(__v4si)
(__mmask8) __U);
_mm256_mask_srlv_epi32 (__m256i __W, __mmask8 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_psrlv8si_mask ((__v8si) __X,
(__v8si) __Y,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_srlv_epi32 (__mmask8 __U, __m256i __X, __m256i __Y)
(__v8si) __Y,
(__v8si)
(__mmask8) __U);
_mm_mask_srlv_epi32 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_psrlv4si_mask ((__v4si) __X,
(__v4si) __Y,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_srlv_epi32 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v4si) __Y,
(__v4si)
(__mmask8) __U);
_mm256_mask_srlv_epi64 (__m256i __W, __mmask8 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_psrlv4di_mask ((__v4di) __X,
(__v4di) __Y,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_srlv_epi64 (__mmask8 __U, __m256i __X, __m256i __Y)
(__v4di) __Y,
(__v4di)
(__mmask8) __U);
_mm_mask_srlv_epi64 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_psrlv2di_mask ((__v2di) __X,
(__v2di) __Y,
(__v2di) __W,
(__mmask8) __U);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm_maskz_srlv_epi64 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v2di) __Y,
(__v2di)
(__mmask8) __U);
_mm256_rolv_epi32 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_prolvd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
(__mmask8) -1);
_mm256_mask_rolv_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_rolv_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_rolv_epi32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_prolvd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
(__mmask8) -1);
_mm_mask_rolv_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_rolv_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_rorv_epi32 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_prorvd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
(__mmask8) -1);
_mm256_mask_rorv_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_rorv_epi32 (__mmask8 __U, __m256i __A, __m256i __B)
(__v8si) __B,
(__v8si)
(__mmask8) __U);
_mm_rorv_epi32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_prorvd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
(__mmask8) -1);
_mm_mask_rorv_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_rorv_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_rolv_epi64 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_prolvq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di)
(__mmask8) -1);
_mm256_mask_rolv_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_rolv_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_rolv_epi64 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_prolvq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_mask_rolv_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_rolv_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_rorv_epi64 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_prorvq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di)
(__mmask8) -1);
_mm256_mask_rorv_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_rorv_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_rorv_epi64 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_prorvq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_mask_rorv_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_rorv_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
_mm_setzero_si128 (),
(__mmask8) __U);
_mm256_srav_epi64 (__m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_psravq256_mask ((__v4di) __X,
(__v4di) __Y,
(__v4di)
(__mmask8) -1);
_mm256_mask_srav_epi64 (__m256i __W, __mmask8 __U, __m256i __X,
__m256i __Y)
(__v4di) __Y,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_srav_epi64 (__mmask8 __U, __m256i __X, __m256i __Y)
(__v4di) __Y,
(__v4di)
(__mmask8) __U);
_mm256_mask_and_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pandq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W, __U);
_mm256_maskz_and_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
__U);
_mm_mask_and_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pandq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W, __U);
extern __inline __m128i
_mm_maskz_and_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
_mm_setzero_pd (),
__U);
_mm256_mask_andnot_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pandnq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W, __U);
extern __inline __m256i
_mm256_maskz_andnot_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
__U);
_mm_mask_andnot_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pandnq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W, __U);
_mm_maskz_andnot_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
_mm_setzero_pd (),
__U);
_mm256_mask_or_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_porq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_or_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_mask_or_epi64 (__m128i __W, __mmask8 __U, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_porq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_or_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_xor_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pxorq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_xor_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_mask_xor_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pxorq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_xor_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_max_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_maxpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_max_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm256_mask_max_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_maxps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_max_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
_mm256_setzero_ps (),
(__mmask8) __U);
_mm_mask_div_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_divps_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_div_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_div_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_divpd_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_div_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_min_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_minpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_mask_div_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_divpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_min_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm256_mask_min_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_minps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_div_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm256_mask_div_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_divps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_min_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm256_maskz_div_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_mask_min_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_minps_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_mask_mul_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_mulps_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_min_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_maskz_mul_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_max_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_maxps_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_max_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_min_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_minpd_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_min_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_mask_max_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_maxpd_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_max_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_mask_mul_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_mulpd_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_mul_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_mul_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_mulps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_mul_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
extern __inline __m256d
_mm256_mask_mul_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_mulpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_mul_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm256_maskz_max_epi64 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxsq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di)
__M);
_mm256_mask_max_epi64 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v4di) __B,
(__v4di) __W, __M);
_mm256_min_epi64 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminsq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di)
(__mmask8) -1);
_mm256_mask_min_epi64 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v4di) __B,
(__v4di) __W, __M);
_mm256_maskz_min_epi64 (__mmask8 __M, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
__M);
_mm256_maskz_max_epu64 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxuq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di)
__M);
_mm256_max_epi64 (__m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) -1);
_mm256_max_epu64 (__m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) -1);
_mm256_mask_max_epu64 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v4di) __B,
(__v4di) __W, __M);
_mm256_min_epu64 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminuq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di)
(__mmask8) -1);
_mm256_mask_min_epu64 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v4di) __B,
(__v4di) __W, __M);
_mm256_maskz_min_epu64 (__mmask8 __M, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
__M);
_mm256_maskz_max_epi32 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxsd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
__M);
_mm256_mask_max_epi32 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W, __M);
_mm256_maskz_min_epi32 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminsd256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
__M);
_mm256_mask_min_epi32 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W, __M);
_mm256_maskz_max_epu32 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxud256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
__M);
_mm256_mask_max_epu32 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W, __M);
_mm256_maskz_min_epu32 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminud256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
__M);
_mm256_mask_min_epu32 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W, __M);
_mm_maskz_max_epi64 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxsq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
__M);
_mm_mask_max_epi64 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W, __M);
_mm_min_epi64 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminsq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_mask_min_epi64 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W, __M);
_mm_maskz_min_epi64 (__mmask8 __M, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
__M);
_mm_maskz_max_epu64 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxuq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
__M);
_mm_max_epi64 (__m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_max_epu64 (__m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_mask_max_epu64 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W, __M);
_mm_min_epu64 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminuq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_mask_min_epu64 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W, __M);
_mm_maskz_min_epu64 (__mmask8 __M, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
__M);
_mm_maskz_max_epi32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxsd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
__M);
_mm_mask_max_epi32 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W, __M);
_mm_maskz_min_epi32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminsd128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
__M);
_mm_mask_min_epi32 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W, __M);
_mm_maskz_max_epu32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxud128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
__M);
_mm_mask_max_epu32 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W, __M);
_mm_maskz_min_epu32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminud128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
__M);
_mm_mask_min_epu32 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W, __M);
#pragma GCC push_options
#pragma GCC target("avx512vl,avx512cd")
_mm_broadcastmb_epi64 (__mmask8 __A)
return (__m128i) __builtin_ia32_broadcastmb128 (__A);
_mm256_broadcastmb_epi64 (__mmask8 __A)
return (__m256i) __builtin_ia32_broadcastmb256 (__A);
_mm_broadcastmw_epi32 (__mmask16 __A)
return (__m128i) __builtin_ia32_broadcastmw128 (__A);
_mm256_broadcastmw_epi32 (__mmask16 __A)
return (__m256i) __builtin_ia32_broadcastmw256 (__A);
_mm256_lzcnt_epi32 (__m256i __A)
return (__m256i) __builtin_ia32_vplzcntd_256_mask ((__v8si) __A,
(__v8si)
(__mmask8) -1);
_mm256_mask_lzcnt_epi32 (__m256i __W, __mmask8 __U, __m256i __A)
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_lzcnt_epi32 (__mmask8 __U, __m256i __A)
(__v8si)
(__mmask8) __U);
_mm256_lzcnt_epi64 (__m256i __A)
return (__m256i) __builtin_ia32_vplzcntq_256_mask ((__v4di) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_lzcnt_epi64 (__m256i __W, __mmask8 __U, __m256i __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_lzcnt_epi64 (__mmask8 __U, __m256i __A)
(__v4di)
(__mmask8) __U);
_mm256_conflict_epi64 (__m256i __A)
return (__m256i) __builtin_ia32_vpconflictdi_256_mask ((__v4di) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_conflict_epi64 (__m256i __W, __mmask8 __U, __m256i __A)
(__v4di) __W,
(__mmask8)
__U);
_mm256_maskz_conflict_epi64 (__mmask8 __U, __m256i __A)
(__v4di)
(__mmask8)
__U);
_mm256_conflict_epi32 (__m256i __A)
return (__m256i) __builtin_ia32_vpconflictsi_256_mask ((__v8si) __A,
(__v8si)
(__mmask8) -1);
_mm256_mask_conflict_epi32 (__m256i __W, __mmask8 __U, __m256i __A)
(__v8si) __W,
(__mmask8)
__U);
_mm256_maskz_conflict_epi32 (__mmask8 __U, __m256i __A)
(__v8si)
(__mmask8)
__U);
_mm_lzcnt_epi32 (__m128i __A)
return (__m128i) __builtin_ia32_vplzcntd_128_mask ((__v4si) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_lzcnt_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_lzcnt_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8) __U);
_mm_lzcnt_epi64 (__m128i __A)
return (__m128i) __builtin_ia32_vplzcntq_128_mask ((__v2di) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_lzcnt_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_lzcnt_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm_conflict_epi64 (__m128i __A)
return (__m128i) __builtin_ia32_vpconflictdi_128_mask ((__v2di) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_conflict_epi64 (__m128i __W, __mmask8 __U, __m128i __A)
(__v2di) __W,
(__mmask8)
__U);
_mm_maskz_conflict_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8)
__U);
_mm_conflict_epi32 (__m128i __A)
return (__m128i) __builtin_ia32_vpconflictsi_128_mask ((__v4si) __A,
(__v4si)
(__mmask8) -1);
_mm_mask_conflict_epi32 (__m128i __W, __mmask8 __U, __m128i __A)
(__v4si) __W,
(__mmask8)
__U);
_mm_maskz_conflict_epi32 (__mmask8 __U, __m128i __A)
(__v4si)
(__mmask8)
__U);
#pragma GCC pop_options
_mm256_mask_unpacklo_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_unpcklpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_unpacklo_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_unpacklo_pd (__m128d __W, __mmask8 __U, __m128d __A,
__m128d __B)
return (__m128d) __builtin_ia32_unpcklpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_unpacklo_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_unpacklo_ps (__m256 __W, __mmask8 __U, __m256 __A,
__m256 __B)
return (__m256) __builtin_ia32_unpcklps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_mask_unpackhi_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_unpckhpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_unpackhi_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_unpackhi_pd (__m128d __W, __mmask8 __U, __m128d __A,
__m128d __B)
return (__m128d) __builtin_ia32_unpckhpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_unpackhi_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_unpackhi_ps (__m256 __W, __mmask8 __U, __m256 __A,
__m256 __B)
return (__m256) __builtin_ia32_unpckhps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_unpackhi_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_mask_unpackhi_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_unpckhps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_unpackhi_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_mask_cvtph_ps (__m128 __W, __mmask8 __U, __m128i __A)
return (__m128) __builtin_ia32_vcvtph2ps_mask ((__v8hi) __A,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_cvtph_ps (__mmask8 __U, __m128i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_maskz_unpacklo_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm256_mask_cvtph_ps (__m256 __W, __mmask8 __U, __m128i __A)
return (__m256) __builtin_ia32_vcvtph2ps256_mask ((__v8hi) __A,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_cvtph_ps (__mmask8 __U, __m128i __A)
(__v8sf)
(__mmask8) __U);
_mm_mask_unpacklo_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_unpcklps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_unpacklo_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_sra_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psrad256_mask ((__v8si) __A,
(__v4si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_sra_epi32 (__mmask8 __U, __m256i __A, __m128i __B)
(__v4si) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_sra_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psrad128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_sra_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm256_sra_epi64 (__m256i __A, __m128i __B)
return (__m256i) __builtin_ia32_psraq256_mask ((__v4di) __A,
(__v2di) __B,
(__v4di)
(__mmask8) -1);
_mm256_mask_sra_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m128i __B)
(__v2di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_sra_epi64 (__mmask8 __U, __m256i __A, __m128i __B)
(__v2di) __B,
(__v4di)
(__mmask8) __U);
_mm_sra_epi64 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_psraq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di)
(__mmask8) -1);
_mm_mask_sra_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_sra_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm_mask_sll_epi32 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pslld128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_sll_epi32 (__mmask8 __U, __m128i __A, __m128i __B)
(__v4si) __B,
(__v4si)
(__mmask8) __U);
_mm_mask_sll_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psllq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_sll_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_sll_epi32 (__m256i __W, __mmask8 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_pslld256_mask ((__v8si) __A,
(__v4si) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_sll_epi32 (__mmask8 __U, __m256i __A, __m128i __B)
(__v4si) __B,
(__v8si)
(__mmask8) __U);
_mm256_mask_sll_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psllq256_mask ((__v4di) __A,
(__v2di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_sll_epi64 (__mmask8 __U, __m256i __A, __m128i __B)
(__v2di) __B,
(__v4di)
(__mmask8) __U);
_mm256_mask_permutexvar_ps (__m256 __W, __mmask8 __U, __m256i __X,
__m256 __Y)
return (__m256) __builtin_ia32_permvarsf256_mask ((__v8sf) __Y,
(__v8si) __X,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_permutexvar_ps (__mmask8 __U, __m256i __X, __m256 __Y)
(__v8si) __X,
(__v8sf)
(__mmask8) __U);
_mm256_permutexvar_pd (__m256i __X, __m256d __Y)
return (__m256d) __builtin_ia32_permvardf256_mask ((__v4df) __Y,
(__v4di) __X,
(__v4df)
(__mmask8) -1);
_mm256_mask_permutexvar_pd (__m256d __W, __mmask8 __U, __m256i __X,
__m256d __Y)
(__v4di) __X,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_permutexvar_pd (__mmask8 __U, __m256i __X, __m256d __Y)
(__v4di) __X,
(__v4df)
(__mmask8) __U);
_mm256_mask_permutevar_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256i __C)
return (__m256d) __builtin_ia32_vpermilvarpd256_mask ((__v4df) __A,
(__v4di) __C,
(__v4df) __W,
(__mmask8)
__U);
_mm256_maskz_permutevar_pd (__mmask8 __U, __m256d __A, __m256i __C)
(__v4di) __C,
(__v4df)
(__mmask8)
__U);
_mm256_mask_permutevar_ps (__m256 __W, __mmask8 __U, __m256 __A,
__m256i __C)
return (__m256) __builtin_ia32_vpermilvarps256_mask ((__v8sf) __A,
(__v8si) __C,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_permutevar_ps (__mmask8 __U, __m256 __A, __m256i __C)
(__v8si) __C,
(__v8sf)
(__mmask8) __U);
_mm_mask_permutevar_pd (__m128d __W, __mmask8 __U, __m128d __A,
__m128i __C)
return (__m128d) __builtin_ia32_vpermilvarpd_mask ((__v2df) __A,
(__v2di) __C,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_permutevar_pd (__mmask8 __U, __m128d __A, __m128i __C)
(__v2di) __C,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm_mask_permutevar_ps (__m128 __W, __mmask8 __U, __m128 __A,
__m128i __C)
return (__m128) __builtin_ia32_vpermilvarps_mask ((__v4sf) __A,
(__v4si) __C,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_permutevar_ps (__mmask8 __U, __m128 __A, __m128i __C)
(__v4si) __C,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_maskz_mullo_epi32 (__mmask8 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmulld256_mask ((__v8si) __A,
(__v8si) __B,
(__v8si)
__M);
_mm256_maskz_permutexvar_epi64 (__mmask8 __M, __m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_permvardi256_mask ((__v4di) __Y,
(__v4di) __X,
(__v4di)
__M);
_mm256_mask_mullo_epi32 (__m256i __W, __mmask8 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v8si) __W, __M);
_mm_maskz_mullo_epi32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmulld128_mask ((__v4si) __A,
(__v4si) __B,
(__v4si)
__M);
_mm_mask_mullo_epi32 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v4si) __W, __M);
_mm256_mask_mul_epi32 (__m256i __W, __mmask8 __M, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_pmuldq256_mask ((__v8si) __X,
(__v8si) __Y,
(__v4di) __W, __M);
_mm256_maskz_mul_epi32 (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y,
(__v4di)
__M);
_mm_mask_mul_epi32 (__m128i __W, __mmask8 __M, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_pmuldq128_mask ((__v4si) __X,
(__v4si) __Y,
(__v2di) __W, __M);
_mm_maskz_mul_epi32 (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y,
(__v2di)
__M);
_mm256_permutexvar_epi64 (__m256i __X, __m256i __Y)
(__v4di) __X,
(__v4di)
(__mmask8) -1);
_mm256_mask_permutexvar_epi64 (__m256i __W, __mmask8 __M, __m256i __X,
__m256i __Y)
(__v4di) __X,
(__v4di) __W,
__M);
_mm256_mask_mul_epu32 (__m256i __W, __mmask8 __M, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_pmuludq256_mask ((__v8si) __X,
(__v8si) __Y,
(__v4di) __W, __M);
_mm256_maskz_permutexvar_epi32 (__mmask8 __M, __m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_permvarsi256_mask ((__v8si) __Y,
(__v8si) __X,
(__v8si)
__M);
_mm256_maskz_mul_epu32 (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y,
(__v4di)
__M);
_mm_mask_mul_epu32 (__m128i __W, __mmask8 __M, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_pmuludq128_mask ((__v4si) __X,
(__v4si) __Y,
(__v2di) __W, __M);
_mm_maskz_mul_epu32 (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y,
(__v2di)
__M);
_mm256_permutexvar_epi32 (__m256i __X, __m256i __Y)
(__v8si) __X,
(__v8si)
(__mmask8) -1);
_mm256_mask_permutexvar_epi32 (__m256i __W, __mmask8 __M, __m256i __X,
__m256i __Y)
(__v8si) __X,
(__v8si) __W,
__M);
_mm256_mask_cmpneq_epu32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
return (__mmask8) __builtin_ia32_ucmpd256_mask ((__v8si) __X,
(__v8si) __Y, 4,
(__mmask8) __M);
_mm256_cmpneq_epu32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 4,
(__mmask8) -1);
_mm256_mask_cmplt_epu32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y, 1,
(__mmask8) __M);
_mm256_cmplt_epu32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 1,
(__mmask8) -1);
_mm256_mask_cmpge_epu32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y, 5,
(__mmask8) __M);
_mm256_cmpge_epu32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 5,
(__mmask8) -1);
_mm256_mask_cmple_epu32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y, 2,
(__mmask8) __M);
_mm256_cmple_epu32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 2,
(__mmask8) -1);
_mm256_mask_cmpneq_epu64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
return (__mmask8) __builtin_ia32_ucmpq256_mask ((__v4di) __X,
(__v4di) __Y, 4,
(__mmask8) __M);
_mm256_cmpneq_epu64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 4,
(__mmask8) -1);
_mm256_mask_cmplt_epu64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v4di) __Y, 1,
(__mmask8) __M);
_mm256_cmplt_epu64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 1,
(__mmask8) -1);
_mm256_mask_cmpge_epu64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v4di) __Y, 5,
(__mmask8) __M);
_mm256_cmpge_epu64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 5,
(__mmask8) -1);
_mm256_mask_cmple_epu64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v4di) __Y, 2,
(__mmask8) __M);
_mm256_cmple_epu64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 2,
(__mmask8) -1);
_mm256_mask_cmpneq_epi32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
return (__mmask8) __builtin_ia32_cmpd256_mask ((__v8si) __X,
(__v8si) __Y, 4,
(__mmask8) __M);
_mm256_cmpneq_epi32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 4,
(__mmask8) -1);
_mm256_mask_cmplt_epi32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y, 1,
(__mmask8) __M);
_mm256_cmplt_epi32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 1,
(__mmask8) -1);
_mm256_mask_cmpge_epi32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y, 5,
(__mmask8) __M);
_mm256_cmpge_epi32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 5,
(__mmask8) -1);
_mm256_mask_cmple_epi32_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v8si) __Y, 2,
(__mmask8) __M);
_mm256_cmple_epi32_mask (__m256i __X, __m256i __Y)
(__v8si) __Y, 2,
(__mmask8) -1);
_mm256_mask_cmpneq_epi64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
return (__mmask8) __builtin_ia32_cmpq256_mask ((__v4di) __X,
(__v4di) __Y, 4,
(__mmask8) __M);
_mm256_cmpneq_epi64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 4,
(__mmask8) -1);
_mm256_mask_cmplt_epi64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v4di) __Y, 1,
(__mmask8) __M);
_mm256_cmplt_epi64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 1,
(__mmask8) -1);
_mm256_mask_cmpge_epi64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v4di) __Y, 5,
(__mmask8) __M);
_mm256_cmpge_epi64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 5,
(__mmask8) -1);
_mm256_mask_cmple_epi64_mask (__mmask8 __M, __m256i __X, __m256i __Y)
(__v4di) __Y, 2,
(__mmask8) __M);
_mm256_cmple_epi64_mask (__m256i __X, __m256i __Y)
(__v4di) __Y, 2,
(__mmask8) -1);
_mm_mask_cmpneq_epu32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
return (__mmask8) __builtin_ia32_ucmpd128_mask ((__v4si) __X,
(__v4si) __Y, 4,
(__mmask8) __M);
_mm_cmpneq_epu32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 4,
(__mmask8) -1);
_mm_mask_cmplt_epu32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y, 1,
(__mmask8) __M);
_mm_cmplt_epu32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 1,
(__mmask8) -1);
_mm_mask_cmpge_epu32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y, 5,
(__mmask8) __M);
_mm_cmpge_epu32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 5,
(__mmask8) -1);
_mm_mask_cmple_epu32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y, 2,
(__mmask8) __M);
_mm_cmple_epu32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 2,
(__mmask8) -1);
_mm_mask_cmpneq_epu64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
return (__mmask8) __builtin_ia32_ucmpq128_mask ((__v2di) __X,
(__v2di) __Y, 4,
(__mmask8) __M);
_mm_cmpneq_epu64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 4,
(__mmask8) -1);
_mm_mask_cmplt_epu64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v2di) __Y, 1,
(__mmask8) __M);
_mm_cmplt_epu64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 1,
(__mmask8) -1);
_mm_mask_cmpge_epu64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v2di) __Y, 5,
(__mmask8) __M);
_mm_cmpge_epu64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 5,
(__mmask8) -1);
_mm_mask_cmple_epu64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v2di) __Y, 2,
(__mmask8) __M);
_mm_cmple_epu64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 2,
(__mmask8) -1);
_mm_mask_cmpneq_epi32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
return (__mmask8) __builtin_ia32_cmpd128_mask ((__v4si) __X,
(__v4si) __Y, 4,
(__mmask8) __M);
_mm_cmpneq_epi32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 4,
(__mmask8) -1);
_mm_mask_cmplt_epi32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y, 1,
(__mmask8) __M);
_mm_cmplt_epi32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 1,
(__mmask8) -1);
_mm_mask_cmpge_epi32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y, 5,
(__mmask8) __M);
_mm_cmpge_epi32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 5,
(__mmask8) -1);
_mm_mask_cmple_epi32_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v4si) __Y, 2,
(__mmask8) __M);
_mm_cmple_epi32_mask (__m128i __X, __m128i __Y)
(__v4si) __Y, 2,
(__mmask8) -1);
_mm_mask_cmpneq_epi64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
return (__mmask8) __builtin_ia32_cmpq128_mask ((__v2di) __X,
(__v2di) __Y, 4,
(__mmask8) __M);
_mm_cmpneq_epi64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 4,
(__mmask8) -1);
_mm_mask_cmplt_epi64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v2di) __Y, 1,
(__mmask8) __M);
_mm_cmplt_epi64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 1,
(__mmask8) -1);
_mm_mask_cmpge_epi64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v2di) __Y, 5,
(__mmask8) __M);
_mm_cmpge_epi64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 5,
(__mmask8) -1);
_mm_mask_cmple_epi64_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v2di) __Y, 2,
(__mmask8) __M);
_mm_cmple_epi64_mask (__m128i __X, __m128i __Y)
(__v2di) __Y, 2,
(__mmask8) -1);
# 13643 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vlintrin.h" 3 4
# 54 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512bwintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512bwintrin.h" 3 4
#pragma GCC target("avx512bw")
typedef short __v32hi __attribute__ ((__vector_size__ (64)));
typedef char __v64qi __attribute__ ((__vector_size__ (64)));
typedef unsigned long long __mmask64;
extern __inline unsigned char
_ktest_mask32_u8 (__mmask32 __A, __mmask32 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_ktestcsi (__A, __B);
return (unsigned char) __builtin_ia32_ktestzsi (__A, __B);
_ktest_mask64_u8 (__mmask64 __A, __mmask64 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_ktestcdi (__A, __B);
return (unsigned char) __builtin_ia32_ktestzdi (__A, __B);
_ktestz_mask32_u8 (__mmask32 __A, __mmask32 __B)
_ktestz_mask64_u8 (__mmask64 __A, __mmask64 __B)
_ktestc_mask32_u8 (__mmask32 __A, __mmask32 __B)
return (unsigned char) __builtin_ia32_ktestcsi (__A, __B);
_ktestc_mask64_u8 (__mmask64 __A, __mmask64 __B)
return (unsigned char) __builtin_ia32_ktestcdi (__A, __B);
_kortest_mask32_u8 (__mmask32 __A, __mmask32 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_kortestcsi (__A, __B);
return (unsigned char) __builtin_ia32_kortestzsi (__A, __B);
_kortest_mask64_u8 (__mmask64 __A, __mmask64 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_kortestcdi (__A, __B);
return (unsigned char) __builtin_ia32_kortestzdi (__A, __B);
_kortestz_mask32_u8 (__mmask32 __A, __mmask32 __B)
_kortestz_mask64_u8 (__mmask64 __A, __mmask64 __B)
_kortestc_mask32_u8 (__mmask32 __A, __mmask32 __B)
return (unsigned char) __builtin_ia32_kortestcsi (__A, __B);
_kortestc_mask64_u8 (__mmask64 __A, __mmask64 __B)
return (unsigned char) __builtin_ia32_kortestcdi (__A, __B);
extern __inline __mmask32
_kadd_mask32 (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_kaddsi ((__mmask32) __A, (__mmask32) __B);
extern __inline __mmask64
_kadd_mask64 (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kadddi ((__mmask64) __A, (__mmask64) __B);
extern __inline unsigned int
_cvtmask32_u32 (__mmask32 __A)
return (unsigned int) __builtin_ia32_kmovd ((__mmask32) __A);
extern __inline unsigned long long
_cvtmask64_u64 (__mmask64 __A)
return (unsigned long long) __builtin_ia32_kmovq ((__mmask64) __A);
_cvtu32_mask32 (unsigned int __A)
return (__mmask32) __builtin_ia32_kmovd ((__mmask32) __A);
_cvtu64_mask64 (unsigned long long __A)
return (__mmask64) __builtin_ia32_kmovq ((__mmask64) __A);
_load_mask32 (__mmask32 *__A)
return (__mmask32) __builtin_ia32_kmovd (*__A);
_load_mask64 (__mmask64 *__A)
return (__mmask64) __builtin_ia32_kmovq (*(__mmask64 *) __A);
_store_mask32 (__mmask32 *__A, __mmask32 __B)
*(__mmask32 *) __A = __builtin_ia32_kmovd (__B);
_store_mask64 (__mmask64 *__A, __mmask64 __B)
*(__mmask64 *) __A = __builtin_ia32_kmovq (__B);
_knot_mask32 (__mmask32 __A)
return (__mmask32) __builtin_ia32_knotsi ((__mmask32) __A);
_knot_mask64 (__mmask64 __A)
return (__mmask64) __builtin_ia32_knotdi ((__mmask64) __A);
_kor_mask32 (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_korsi ((__mmask32) __A, (__mmask32) __B);
_kor_mask64 (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kordi ((__mmask64) __A, (__mmask64) __B);
_kxnor_mask32 (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_kxnorsi ((__mmask32) __A, (__mmask32) __B);
_kxnor_mask64 (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kxnordi ((__mmask64) __A, (__mmask64) __B);
_kxor_mask32 (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_kxorsi ((__mmask32) __A, (__mmask32) __B);
_kxor_mask64 (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kxordi ((__mmask64) __A, (__mmask64) __B);
_kand_mask32 (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_kandsi ((__mmask32) __A, (__mmask32) __B);
_kand_mask64 (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kanddi ((__mmask64) __A, (__mmask64) __B);
_kandn_mask32 (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_kandnsi ((__mmask32) __A, (__mmask32) __B);
_kandn_mask64 (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kandndi ((__mmask64) __A, (__mmask64) __B);
extern __inline __m512i
_mm512_mask_mov_epi16 (__m512i __W, __mmask32 __U, __m512i __A)
return (__m512i) __builtin_ia32_movdquhi512_mask ((__v32hi) __A,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_mov_epi16 (__mmask32 __U, __m512i __A)
(__v32hi)
_mm512_setzero_si512 (),
(__mmask32) __U);
_mm512_mask_loadu_epi16 (__m512i __W, __mmask32 __U, void const *__P)
return (__m512i) __builtin_ia32_loaddquhi512_mask ((const short *) __P,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_loadu_epi16 (__mmask32 __U, void const *__P)
(__v32hi)
(__mmask32) __U);
_mm512_mask_storeu_epi16 (void *__P, __mmask32 __U, __m512i __A)
__builtin_ia32_storedquhi512_mask ((short *) __P,
(__v32hi) __A,
(__mmask32) __U);
_mm512_mask_mov_epi8 (__m512i __W, __mmask64 __U, __m512i __A)
return (__m512i) __builtin_ia32_movdquqi512_mask ((__v64qi) __A,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_mov_epi8 (__mmask64 __U, __m512i __A)
(__v64qi)
(__mmask64) __U);
_mm512_kunpackw (__mmask32 __A, __mmask32 __B)
return (__mmask32) __builtin_ia32_kunpcksi ((__mmask32) __A,
(__mmask32) __B);
_kunpackw_mask32 (__mmask16 __A, __mmask16 __B)
(__mmask32) __B);
_mm512_kunpackd (__mmask64 __A, __mmask64 __B)
return (__mmask64) __builtin_ia32_kunpckdi ((__mmask64) __A,
(__mmask64) __B);
_kunpackd_mask64 (__mmask32 __A, __mmask32 __B)
(__mmask64) __B);
_mm512_mask_loadu_epi8 (__m512i __W, __mmask64 __U, void const *__P)
return (__m512i) __builtin_ia32_loaddquqi512_mask ((const char *) __P,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_loadu_epi8 (__mmask64 __U, void const *__P)
(__v64qi)
(__mmask64) __U);
_mm512_mask_storeu_epi8 (void *__P, __mmask64 __U, __m512i __A)
__builtin_ia32_storedquqi512_mask ((char *) __P,
(__v64qi) __A,
(__mmask64) __U);
_mm512_sad_epu8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psadbw512 ((__v64qi) __A,
(__v64qi) __B);
_mm512_cvtepi16_epi8 (__m512i __A)
return (__m256i) __builtin_ia32_pmovwb512_mask ((__v32hi) __A,
(__v32qi) _mm256_undefined_si256(),
(__mmask32) -1);
_mm512_mask_cvtepi16_storeu_epi8 (void * __P, __mmask32 __M, __m512i __A)
__builtin_ia32_pmovwb512mem_mask ((__v32qi *) __P, (__v32hi) __A, __M);
_mm512_mask_cvtepi16_epi8 (__m256i __O, __mmask32 __M, __m512i __A)
(__v32qi) __O, __M);
_mm512_maskz_cvtepi16_epi8 (__mmask32 __M, __m512i __A)
(__v32qi)
_mm256_setzero_si256 (),
__M);
_mm512_cvtsepi16_epi8 (__m512i __A)
return (__m256i) __builtin_ia32_pmovswb512_mask ((__v32hi) __A,
(__v32qi)_mm256_undefined_si256(),
(__mmask32) -1);
_mm512_mask_cvtsepi16_storeu_epi8 (void * __P, __mmask32 __M, __m512i __A)
__builtin_ia32_pmovswb512mem_mask ((__v32qi *) __P, (__v32hi) __A, __M);
_mm512_mask_cvtsepi16_epi8 (__m256i __O, __mmask32 __M, __m512i __A)
(__v32qi)__O,
__M);
_mm512_maskz_cvtsepi16_epi8 (__mmask32 __M, __m512i __A)
(__v32qi)
__M);
_mm512_cvtusepi16_epi8 (__m512i __A)
return (__m256i) __builtin_ia32_pmovuswb512_mask ((__v32hi) __A,
(__mmask32) -1);
_mm512_mask_cvtusepi16_epi8 (__m256i __O, __mmask32 __M, __m512i __A)
(__v32qi) __O,
__M);
_mm512_mask_cvtusepi16_storeu_epi8 (void * __P, __mmask32 __M, __m512i __A)
__builtin_ia32_pmovuswb512mem_mask ((__v32qi *) __P, (__v32hi) __A, __M);
_mm512_maskz_cvtusepi16_epi8 (__mmask32 __M, __m512i __A)
(__v32qi)
__M);
_mm512_broadcastb_epi8 (__m128i __A)
return (__m512i) __builtin_ia32_pbroadcastb512_mask ((__v16qi) __A,
(__v64qi)_mm512_undefined_epi32(),
(__mmask64) -1);
_mm512_mask_broadcastb_epi8 (__m512i __O, __mmask64 __M, __m128i __A)
(__v64qi) __O,
__M);
_mm512_maskz_broadcastb_epi8 (__mmask64 __M, __m128i __A)
(__v64qi)
__M);
_mm512_mask_set1_epi8 (__m512i __O, __mmask64 __M, char __A)
return (__m512i) __builtin_ia32_pbroadcastb512_gpr_mask (__A,
(__v64qi) __O,
__M);
_mm512_maskz_set1_epi8 (__mmask64 __M, char __A)
return (__m512i)
(__v64qi)
__M);
_mm512_broadcastw_epi16 (__m128i __A)
return (__m512i) __builtin_ia32_pbroadcastw512_mask ((__v8hi) __A,
(__v32hi)_mm512_undefined_epi32(),
(__mmask32) -1);
_mm512_mask_broadcastw_epi16 (__m512i __O, __mmask32 __M, __m128i __A)
(__v32hi) __O,
__M);
_mm512_maskz_broadcastw_epi16 (__mmask32 __M, __m128i __A)
(__v32hi)
__M);
_mm512_mask_set1_epi16 (__m512i __O, __mmask32 __M, short __A)
return (__m512i) __builtin_ia32_pbroadcastw512_gpr_mask (__A,
(__v32hi) __O,
__M);
_mm512_maskz_set1_epi16 (__mmask32 __M, short __A)
return (__m512i)
(__v32hi)
__M);
_mm512_mulhrs_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmulhrsw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_mulhrs_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_mulhrs_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_mulhi_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmulhw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_mulhi_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_mulhi_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_mulhi_epu16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmulhuw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_mulhi_epu16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_mulhi_epu16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_mullo_epi16 (__m512i __A, __m512i __B)
return (__m512i) ((__v32hu) __A * (__v32hu) __B);
_mm512_mask_mullo_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
return (__m512i) __builtin_ia32_pmullw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_mullo_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_cvtepi8_epi16 (__m256i __A)
return (__m512i) __builtin_ia32_pmovsxbw512_mask ((__v32qi) __A,
(__v32hi)
(__mmask32) -1);
_mm512_mask_cvtepi8_epi16 (__m512i __W, __mmask32 __U, __m256i __A)
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_cvtepi8_epi16 (__mmask32 __U, __m256i __A)
(__v32hi)
(__mmask32) __U);
_mm512_cvtepu8_epi16 (__m256i __A)
return (__m512i) __builtin_ia32_pmovzxbw512_mask ((__v32qi) __A,
(__v32hi)
(__mmask32) -1);
_mm512_mask_cvtepu8_epi16 (__m512i __W, __mmask32 __U, __m256i __A)
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_cvtepu8_epi16 (__mmask32 __U, __m256i __A)
(__v32hi)
(__mmask32) __U);
_mm512_permutexvar_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_permvarhi512_mask ((__v32hi) __B,
(__v32hi) __A,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_permutexvar_epi16 (__mmask32 __M, __m512i __A,
__m512i __B)
(__v32hi) __A,
(__v32hi)
(__mmask32) __M);
_mm512_mask_permutexvar_epi16 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v32hi) __A,
(__v32hi) __W,
(__mmask32) __M);
_mm512_permutex2var_epi16 (__m512i __A, __m512i __I, __m512i __B)
return (__m512i) __builtin_ia32_vpermt2varhi512_mask ((__v32hi) __I
(__v32hi) __A,
(__v32hi) __B,
(__mmask32) -1);
_mm512_mask_permutex2var_epi16 (__m512i __A, __mmask32 __U,
(__v32hi) __A,
(__v32hi) __B,
(__mmask32)
__U);
_mm512_mask2_permutex2var_epi16 (__m512i __A, __m512i __I,
__mmask32 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpermi2varhi512_mask ((__v32hi) __A,
(__v32hi) __I
(__v32hi) __B,
(__mmask32)
__U);
_mm512_maskz_permutex2var_epi16 (__mmask32 __U, __m512i __A,
return (__m512i) __builtin_ia32_vpermt2varhi512_maskz ((__v32hi) __I
(__v32hi) __A,
(__v32hi) __B,
(__mmask32)
__U);
_mm512_avg_epu8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pavgb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_avg_epu8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_avg_epu8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_add_epi8 (__m512i __A, __m512i __B)
return (__m512i) ((__v64qu) __A + (__v64qu) __B);
_mm512_mask_add_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
return (__m512i) __builtin_ia32_paddb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_add_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_sub_epi8 (__m512i __A, __m512i __B)
return (__m512i) ((__v64qu) __A - (__v64qu) __B);
_mm512_mask_sub_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
return (__m512i) __builtin_ia32_psubb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_sub_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_avg_epu16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pavgw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_avg_epu16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_avg_epu16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_subs_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psubsb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_subs_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_subs_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_subs_epu8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psubusb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_subs_epu8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_subs_epu8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_adds_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_paddsb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_adds_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_adds_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_adds_epu8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_paddusb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_adds_epu8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_adds_epu8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_sub_epi16 (__m512i __A, __m512i __B)
return (__m512i) ((__v32hu) __A - (__v32hu) __B);
_mm512_mask_sub_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
return (__m512i) __builtin_ia32_psubw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_sub_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_subs_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psubsw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_subs_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_subs_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_subs_epu16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psubusw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_subs_epu16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_subs_epu16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_add_epi16 (__m512i __A, __m512i __B)
return (__m512i) ((__v32hu) __A + (__v32hu) __B);
_mm512_mask_add_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
return (__m512i) __builtin_ia32_paddw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_add_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_adds_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_paddsw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_adds_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_adds_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_adds_epu16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_paddusw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_adds_epu16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_adds_epu16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_srl_epi16 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psrlw512_mask ((__v32hi) __A,
(__v8hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_srl_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m128i __B)
(__v8hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_srl_epi16 (__mmask32 __U, __m512i __A, __m128i __B)
(__v8hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_packs_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_packsswb512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_sll_epi16 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psllw512_mask ((__v32hi) __A,
(__v8hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_sll_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m128i __B)
(__v8hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_sll_epi16 (__mmask32 __U, __m512i __A, __m128i __B)
(__v8hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_maddubs_epi16 (__m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_pmaddubsw512_mask ((__v64qi) __X,
(__v64qi) __Y,
(__v32hi)
(__mmask32) -1);
_mm512_mask_maddubs_epi16 (__m512i __W, __mmask32 __U, __m512i __X,
__m512i __Y)
(__v64qi) __Y,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_maddubs_epi16 (__mmask32 __U, __m512i __X, __m512i __Y)
(__v64qi) __Y,
(__v32hi)
(__mmask32) __U);
_mm512_madd_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaddwd512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v16si)
(__mmask16) -1);
_mm512_mask_madd_epi16 (__m512i __W, __mmask16 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v16si) __W,
(__mmask16) __U);
_mm512_maskz_madd_epi16 (__mmask16 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v16si)
(__mmask16) __U);
_mm512_unpackhi_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpckhbw512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_unpackhi_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_unpackhi_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_unpackhi_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpckhwd512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_unpackhi_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_unpackhi_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_unpacklo_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpcklbw512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_unpacklo_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_unpacklo_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_unpacklo_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_punpcklwd512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_unpacklo_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_unpacklo_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_cmpeq_epu8_mask (__m512i __A, __m512i __B)
return (__mmask64) __builtin_ia32_ucmpb512_mask ((__v64qi) __A,
(__v64qi) __B, 0,
(__mmask64) -1);
_mm512_cmpeq_epi8_mask (__m512i __A, __m512i __B)
return (__mmask64) __builtin_ia32_pcmpeqb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__mmask64) -1);
_mm512_mask_cmpeq_epu8_mask (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B, 0,
__U);
_mm512_mask_cmpeq_epi8_mask (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
__U);
_mm512_cmpeq_epu16_mask (__m512i __A, __m512i __B)
return (__mmask32) __builtin_ia32_ucmpw512_mask ((__v32hi) __A,
(__v32hi) __B, 0,
(__mmask32) -1);
_mm512_cmpeq_epi16_mask (__m512i __A, __m512i __B)
return (__mmask32) __builtin_ia32_pcmpeqw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__mmask32) -1);
_mm512_mask_cmpeq_epu16_mask (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B, 0,
__U);
_mm512_mask_cmpeq_epi16_mask (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
__U);
_mm512_cmpgt_epu8_mask (__m512i __A, __m512i __B)
(__v64qi) __B, 6,
(__mmask64) -1);
_mm512_cmpgt_epi8_mask (__m512i __A, __m512i __B)
return (__mmask64) __builtin_ia32_pcmpgtb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__mmask64) -1);
_mm512_mask_cmpgt_epu8_mask (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B, 6,
__U);
_mm512_mask_cmpgt_epi8_mask (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
__U);
_mm512_cmpgt_epu16_mask (__m512i __A, __m512i __B)
(__v32hi) __B, 6,
(__mmask32) -1);
_mm512_cmpgt_epi16_mask (__m512i __A, __m512i __B)
return (__mmask32) __builtin_ia32_pcmpgtw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__mmask32) -1);
_mm512_mask_cmpgt_epu16_mask (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B, 6,
__U);
_mm512_mask_cmpgt_epi16_mask (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
__U);
_mm512_movepi8_mask (__m512i __A)
return (__mmask64) __builtin_ia32_cvtb2mask512 ((__v64qi) __A);
_mm512_movepi16_mask (__m512i __A)
return (__mmask32) __builtin_ia32_cvtw2mask512 ((__v32hi) __A);
_mm512_movm_epi8 (__mmask64 __A)
return (__m512i) __builtin_ia32_cvtmask2b512 (__A);
_mm512_movm_epi16 (__mmask32 __A)
return (__m512i) __builtin_ia32_cvtmask2w512 (__A);
_mm512_test_epi8_mask (__m512i __A, __m512i __B)
return (__mmask64) __builtin_ia32_ptestmb512 ((__v64qi) __A,
(__v64qi) __B,
(__mmask64) -1);
_mm512_mask_test_epi8_mask (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B, __U);
_mm512_test_epi16_mask (__m512i __A, __m512i __B)
return (__mmask32) __builtin_ia32_ptestmw512 ((__v32hi) __A,
(__v32hi) __B,
(__mmask32) -1);
_mm512_mask_test_epi16_mask (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B, __U);
_mm512_testn_epi8_mask (__m512i __A, __m512i __B)
return (__mmask64) __builtin_ia32_ptestnmb512 ((__v64qi) __A,
(__v64qi) __B,
(__mmask64) -1);
_mm512_mask_testn_epi8_mask (__mmask64 __U, __m512i __A, __m512i __B)
_mm512_testn_epi16_mask (__m512i __A, __m512i __B)
return (__mmask32) __builtin_ia32_ptestnmw512 ((__v32hi) __A,
(__v32hi) __B,
(__mmask32) -1);
_mm512_mask_testn_epi16_mask (__mmask32 __U, __m512i __A, __m512i __B)
_mm512_shuffle_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pshufb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_shuffle_epi8 (__m512i __W, __mmask64 __U, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_shuffle_epi8 (__mmask64 __U, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __U);
_mm512_min_epu16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminuw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_min_epu16 (__mmask32 __M, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __M);
_mm512_mask_min_epu16 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __M);
_mm512_min_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminsw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_min_epi16 (__mmask32 __M, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __M);
_mm512_mask_min_epi16 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __M);
_mm512_max_epu8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxub512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_maskz_max_epu8 (__mmask64 __M, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __M);
_mm512_mask_max_epu8 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __M);
_mm512_max_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxsb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_maskz_max_epi8 (__mmask64 __M, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __M);
_mm512_mask_max_epi8 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __M);
_mm512_min_epu8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminub512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_maskz_min_epu8 (__mmask64 __M, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __M);
_mm512_mask_min_epu8 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __M);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm512_min_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pminsb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_maskz_min_epi8 (__mmask64 __M, __m512i __A, __m512i __B)
(__v64qi) __B,
(__v64qi)
(__mmask64) __M);
_mm512_mask_min_epi8 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v64qi) __B,
(__v64qi) __W,
(__mmask64) __M);
_mm512_max_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxsw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_max_epi16 (__mmask32 __M, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __M);
_mm512_mask_max_epi16 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __M);
_mm512_max_epu16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_pmaxuw512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_max_epu16 (__mmask32 __M, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __M);
_mm512_mask_max_epu16 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __M);
_mm512_sra_epi16 (__m512i __A, __m128i __B)
return (__m512i) __builtin_ia32_psraw512_mask ((__v32hi) __A,
(__v8hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_sra_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m128i __B)
(__v8hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_sra_epi16 (__mmask32 __U, __m512i __A, __m128i __B)
(__v8hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_srav_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psrav32hi_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_srav_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_srav_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_srlv_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psrlv32hi_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_srlv_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_srlv_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_sllv_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_psllv32hi_mask ((__v32hi) __A,
(__v32hi) __B,
(__v32hi)
(__mmask32) -1);
_mm512_mask_sllv_epi16 (__m512i __W, __mmask32 __U, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_sllv_epi16 (__mmask32 __U, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v32hi)
(__mmask32) __U);
_mm512_mask_packs_epi16 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v64qi) __W,
(__mmask64) __M);
_mm512_maskz_packs_epi16 (__mmask64 __M, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v64qi)
__M);
_mm512_packus_epi16 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_packuswb512_mask ((__v32hi) __A,
(__v32hi) __B,
(__v64qi)
(__mmask64) -1);
_mm512_mask_packus_epi16 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v32hi) __B,
(__v64qi) __W,
(__mmask64) __M);
_mm512_maskz_packus_epi16 (__mmask64 __M, __m512i __A, __m512i __B)
(__v32hi) __B,
(__v64qi)
(__mmask64) __M);
_mm512_abs_epi8 (__m512i __A)
return (__m512i) __builtin_ia32_pabsb512_mask ((__v64qi) __A,
(__v64qi)
(__mmask64) -1);
_mm512_mask_abs_epi8 (__m512i __W, __mmask64 __U, __m512i __A)
(__v64qi) __W,
(__mmask64) __U);
_mm512_maskz_abs_epi8 (__mmask64 __U, __m512i __A)
(__v64qi)
(__mmask64) __U);
_mm512_abs_epi16 (__m512i __A)
return (__m512i) __builtin_ia32_pabsw512_mask ((__v32hi) __A,
(__v32hi)
(__mmask32) -1);
_mm512_mask_abs_epi16 (__m512i __W, __mmask32 __U, __m512i __A)
(__v32hi) __W,
(__mmask32) __U);
_mm512_maskz_abs_epi16 (__mmask32 __U, __m512i __A)
(__v32hi)
(__mmask32) __U);
_mm512_mask_cmpneq_epu8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
return (__mmask64) __builtin_ia32_ucmpb512_mask ((__v64qi) __X,
(__v64qi) __Y, 4,
(__mmask64) __M);
_mm512_mask_cmplt_epu8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y, 1,
(__mmask64) __M);
_mm512_mask_cmpge_epu8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y, 5,
(__mmask64) __M);
_mm512_mask_cmple_epu8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y, 2,
(__mmask64) __M);
_mm512_mask_cmpneq_epu16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
return (__mmask32) __builtin_ia32_ucmpw512_mask ((__v32hi) __X,
(__v32hi) __Y, 4,
(__mmask32) __M);
_mm512_mask_cmplt_epu16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
(__v32hi) __Y, 1,
(__mmask32) __M);
_mm512_mask_cmpge_epu16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
(__v32hi) __Y, 5,
(__mmask32) __M);
_mm512_mask_cmple_epu16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
(__v32hi) __Y, 2,
(__mmask32) __M);
_mm512_mask_cmpneq_epi8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
return (__mmask64) __builtin_ia32_cmpb512_mask ((__v64qi) __X,
(__v64qi) __Y, 4,
(__mmask64) __M);
_mm512_mask_cmplt_epi8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y, 1,
(__mmask64) __M);
_mm512_mask_cmpge_epi8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y, 5,
(__mmask64) __M);
_mm512_mask_cmple_epi8_mask (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y, 2,
(__mmask64) __M);
_mm512_mask_cmpneq_epi16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
return (__mmask32) __builtin_ia32_cmpw512_mask ((__v32hi) __X,
(__v32hi) __Y, 4,
(__mmask32) __M);
_mm512_mask_cmplt_epi16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
(__v32hi) __Y, 1,
(__mmask32) __M);
_mm512_mask_cmpge_epi16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
(__v32hi) __Y, 5,
(__mmask32) __M);
_mm512_mask_cmple_epi16_mask (__mmask32 __M, __m512i __X, __m512i __Y)
(__v32hi) __Y, 2,
(__mmask32) __M);
_mm512_cmpneq_epu8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 4,
(__mmask64) -1);
_mm512_cmplt_epu8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 1,
(__mmask64) -1);
_mm512_cmpge_epu8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 5,
(__mmask64) -1);
_mm512_cmple_epu8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 2,
(__mmask64) -1);
_mm512_cmpneq_epu16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 4,
(__mmask32) -1);
_mm512_cmplt_epu16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 1,
(__mmask32) -1);
_mm512_cmpge_epu16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 5,
(__mmask32) -1);
_mm512_cmple_epu16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 2,
(__mmask32) -1);
_mm512_cmpneq_epi8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 4,
(__mmask64) -1);
_mm512_cmplt_epi8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 1,
(__mmask64) -1);
_mm512_cmpge_epi8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 5,
(__mmask64) -1);
_mm512_cmple_epi8_mask (__m512i __X, __m512i __Y)
(__v64qi) __Y, 2,
(__mmask64) -1);
_mm512_cmpneq_epi16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 4,
(__mmask32) -1);
_mm512_cmplt_epi16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 1,
(__mmask32) -1);
_mm512_cmpge_epi16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 5,
(__mmask32) -1);
_mm512_cmple_epi16_mask (__m512i __X, __m512i __Y)
(__v32hi) __Y, 2,
(__mmask32) -1);
_mm512_packs_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_packssdw512_mask ((__v16si) __A,
(__v16si) __B,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_packs_epi32 (__mmask32 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v32hi)
__M);
_mm512_mask_packs_epi32 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v16si) __B,
(__v32hi) __W,
__M);
_mm512_packus_epi32 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_packusdw512_mask ((__v16si) __A,
(__v16si) __B,
(__v32hi)
(__mmask32) -1);
_mm512_maskz_packus_epi32 (__mmask32 __M, __m512i __A, __m512i __B)
(__v16si) __B,
(__v32hi)
__M);
_mm512_mask_packus_epi32 (__m512i __W, __mmask32 __M, __m512i __A,
__m512i __B)
(__v16si) __B,
(__v32hi) __W,
__M);
# 3298 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512bwintrin.h" 3 4
# 56 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512dqintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512dqintrin.h" 3 4
#pragma GCC target("avx512dq")
_ktest_mask8_u8 (__mmask8 __A, __mmask8 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_ktestcqi (__A, __B);
return (unsigned char) __builtin_ia32_ktestzqi (__A, __B);
_ktestz_mask8_u8 (__mmask8 __A, __mmask8 __B)
_ktestc_mask8_u8 (__mmask8 __A, __mmask8 __B)
return (unsigned char) __builtin_ia32_ktestcqi (__A, __B);
_ktest_mask16_u8 (__mmask16 __A, __mmask16 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_ktestchi (__A, __B);
return (unsigned char) __builtin_ia32_ktestzhi (__A, __B);
_ktestz_mask16_u8 (__mmask16 __A, __mmask16 __B)
_ktestc_mask16_u8 (__mmask16 __A, __mmask16 __B)
return (unsigned char) __builtin_ia32_ktestchi (__A, __B);
_kortest_mask8_u8 (__mmask8 __A, __mmask8 __B, unsigned char *__CF)
*__CF = (unsigned char) __builtin_ia32_kortestcqi (__A, __B);
return (unsigned char) __builtin_ia32_kortestzqi (__A, __B);
_kortestz_mask8_u8 (__mmask8 __A, __mmask8 __B)
_kortestc_mask8_u8 (__mmask8 __A, __mmask8 __B)
return (unsigned char) __builtin_ia32_kortestcqi (__A, __B);
extern __inline __mmask8
_kadd_mask8 (__mmask8 __A, __mmask8 __B)
return (__mmask8) __builtin_ia32_kaddqi ((__mmask8) __A, (__mmask8) __B);
extern __inline __mmask16
_kadd_mask16 (__mmask16 __A, __mmask16 __B)
return (__mmask16) __builtin_ia32_kaddhi ((__mmask16) __A, (__mmask16) __B);
_cvtmask8_u32 (__mmask8 __A)
return (unsigned int) __builtin_ia32_kmovb ((__mmask8 ) __A);
_cvtu32_mask8 (unsigned int __A)
return (__mmask8) __builtin_ia32_kmovb ((__mmask8) __A);
_load_mask8 (__mmask8 *__A)
return (__mmask8) __builtin_ia32_kmovb (*(__mmask8 *) __A);
extern __inline void
_store_mask8 (__mmask8 *__A, __mmask8 __B)
*(__mmask8 *) __A = __builtin_ia32_kmovb (__B);
_knot_mask8 (__mmask8 __A)
return (__mmask8) __builtin_ia32_knotqi ((__mmask8) __A);
_kor_mask8 (__mmask8 __A, __mmask8 __B)
return (__mmask8) __builtin_ia32_korqi ((__mmask8) __A, (__mmask8) __B);
_kxnor_mask8 (__mmask8 __A, __mmask8 __B)
return (__mmask8) __builtin_ia32_kxnorqi ((__mmask8) __A, (__mmask8) __B);
_kxor_mask8 (__mmask8 __A, __mmask8 __B)
return (__mmask8) __builtin_ia32_kxorqi ((__mmask8) __A, (__mmask8) __B);
_kand_mask8 (__mmask8 __A, __mmask8 __B)
return (__mmask8) __builtin_ia32_kandqi ((__mmask8) __A, (__mmask8) __B);
_kandn_mask8 (__mmask8 __A, __mmask8 __B)
return (__mmask8) __builtin_ia32_kandnqi ((__mmask8) __A, (__mmask8) __B);
extern __inline __m512d
_mm512_broadcast_f64x2 (__m128d __A)
return (__m512d)
__builtin_ia32_broadcastf64x2_512_mask ((__v2df) __A,
_mm512_undefined_pd (),
(__mmask8) -1);
_mm512_mask_broadcast_f64x2 (__m512d __O, __mmask8 __M, __m128d __A)
return (__m512d) __builtin_ia32_broadcastf64x2_512_mask ((__v2df)
__A,
(__v8df)
__O, __M);
_mm512_maskz_broadcast_f64x2 (__mmask8 __M, __m128d __A)
__A,
(__v8df)
_mm512_setzero_ps (),
__M);
_mm512_broadcast_i64x2 (__m128i __A)
return (__m512i)
__builtin_ia32_broadcasti64x2_512_mask ((__v2di) __A,
_mm512_undefined_epi32 (),
(__mmask8) -1);
_mm512_mask_broadcast_i64x2 (__m512i __O, __mmask8 __M, __m128i __A)
return (__m512i) __builtin_ia32_broadcasti64x2_512_mask ((__v2di)
__A,
(__v8di)
__O, __M);
_mm512_maskz_broadcast_i64x2 (__mmask8 __M, __m128i __A)
__A,
(__v8di)
__M);
_mm512_broadcast_f32x2 (__m128 __A)
return (__m512)
__builtin_ia32_broadcastf32x2_512_mask ((__v4sf) __A,
(__v16sf)_mm512_undefined_ps (),
(__mmask16) -1);
_mm512_mask_broadcast_f32x2 (__m512 __O, __mmask16 __M, __m128 __A)
return (__m512) __builtin_ia32_broadcastf32x2_512_mask ((__v4sf) __A,
(__v16sf)
__O, __M);
_mm512_maskz_broadcast_f32x2 (__mmask16 __M, __m128 __A)
(__v16sf)
__M);
_mm512_broadcast_i32x2 (__m128i __A)
return (__m512i)
__builtin_ia32_broadcasti32x2_512_mask ((__v4si) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_broadcast_i32x2 (__m512i __O, __mmask16 __M, __m128i __A)
return (__m512i) __builtin_ia32_broadcasti32x2_512_mask ((__v4si)
__A,
(__v16si)
__O, __M);
_mm512_maskz_broadcast_i32x2 (__mmask16 __M, __m128i __A)
__A,
(__v16si)
__M);
_mm512_broadcast_f32x8 (__m256 __A)
return (__m512)
__builtin_ia32_broadcastf32x8_512_mask ((__v8sf) __A,
(__mmask16) -1);
_mm512_mask_broadcast_f32x8 (__m512 __O, __mmask16 __M, __m256 __A)
return (__m512) __builtin_ia32_broadcastf32x8_512_mask ((__v8sf) __A,
(__v16sf)__O,
__M);
_mm512_maskz_broadcast_f32x8 (__mmask16 __M, __m256 __A)
(__v16sf)
__M);
_mm512_broadcast_i32x8 (__m256i __A)
return (__m512i)
__builtin_ia32_broadcasti32x8_512_mask ((__v8si) __A,
(__v16si)
(__mmask16) -1);
_mm512_mask_broadcast_i32x8 (__m512i __O, __mmask16 __M, __m256i __A)
return (__m512i) __builtin_ia32_broadcasti32x8_512_mask ((__v8si)
__A,
(__v16si)__O,
__M);
_mm512_maskz_broadcast_i32x8 (__mmask16 __M, __m256i __A)
__A,
(__v16si)
__M);
_mm512_mullo_epi64 (__m512i __A, __m512i __B)
return (__m512i) ((__v8du) __A * (__v8du) __B);
_mm512_mask_mullo_epi64 (__m512i __W, __mmask8 __U, __m512i __A,
__m512i __B)
return (__m512i) __builtin_ia32_pmullq512_mask ((__v8di) __A,
(__v8di) __B,
(__v8di) __W,
(__mmask8) __U);
_mm512_maskz_mullo_epi64 (__mmask8 __U, __m512i __A, __m512i __B)
(__v8di) __B,
(__v8di)
(__mmask8) __U);
_mm512_xor_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_xorpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
_mm512_setzero_pd (),
(__mmask8) -1);
_mm512_mask_xor_pd (__m512d __W, __mmask8 __U, __m512d __A,
__m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_xor_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U);
_mm512_xor_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_xorps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1);
_mm512_mask_xor_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_xor_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U);
_mm512_or_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_orpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1);
_mm512_mask_or_pd (__m512d __W, __mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_or_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U);
_mm512_or_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_orps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1);
_mm512_mask_or_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_or_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U);
_mm512_and_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_andpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1);
_mm512_mask_and_pd (__m512d __W, __mmask8 __U, __m512d __A,
__m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_and_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U);
_mm512_and_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_andps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1);
_mm512_mask_and_ps (__m512 __W, __mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_and_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U);
_mm512_andnot_pd (__m512d __A, __m512d __B)
return (__m512d) __builtin_ia32_andnpd512_mask ((__v8df) __A,
(__v8df) __B,
(__v8df)
(__mmask8) -1);
_mm512_mask_andnot_pd (__m512d __W, __mmask8 __U, __m512d __A,
__m512d __B)
(__v8df) __B,
(__v8df) __W,
(__mmask8) __U);
_mm512_maskz_andnot_pd (__mmask8 __U, __m512d __A, __m512d __B)
(__v8df) __B,
(__v8df)
(__mmask8) __U);
_mm512_andnot_ps (__m512 __A, __m512 __B)
return (__m512) __builtin_ia32_andnps512_mask ((__v16sf) __A,
(__v16sf) __B,
(__v16sf)
(__mmask16) -1);
_mm512_mask_andnot_ps (__m512 __W, __mmask16 __U, __m512 __A,
__m512 __B)
(__v16sf) __B,
(__v16sf) __W,
(__mmask16) __U);
_mm512_maskz_andnot_ps (__mmask16 __U, __m512 __A, __m512 __B)
(__v16sf) __B,
(__v16sf)
(__mmask16) __U);
_mm512_movepi32_mask (__m512i __A)
return (__mmask16) __builtin_ia32_cvtd2mask512 ((__v16si) __A);
_mm512_movepi64_mask (__m512i __A)
return (__mmask8) __builtin_ia32_cvtq2mask512 ((__v8di) __A);
_mm512_movm_epi32 (__mmask16 __A)
return (__m512i) __builtin_ia32_cvtmask2d512 (__A);
_mm512_movm_epi64 (__mmask8 __A)
return (__m512i) __builtin_ia32_cvtmask2q512 (__A);
_mm512_cvttpd_epi64 (__m512d __A)
return (__m512i) __builtin_ia32_cvttpd2qq512_mask ((__v8df) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvttpd_epi64 (__m512i __W, __mmask8 __U, __m512d __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvttpd_epi64 (__mmask8 __U, __m512d __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvttpd_epu64 (__m512d __A)
return (__m512i) __builtin_ia32_cvttpd2uqq512_mask ((__v8df) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvttpd_epu64 (__m512i __W, __mmask8 __U, __m512d __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvttpd_epu64 (__mmask8 __U, __m512d __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvttps_epi64 (__m256 __A)
return (__m512i) __builtin_ia32_cvttps2qq512_mask ((__v8sf) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvttps_epi64 (__m512i __W, __mmask8 __U, __m256 __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvttps_epi64 (__mmask8 __U, __m256 __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvttps_epu64 (__m256 __A)
return (__m512i) __builtin_ia32_cvttps2uqq512_mask ((__v8sf) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvttps_epu64 (__m512i __W, __mmask8 __U, __m256 __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvttps_epu64 (__mmask8 __U, __m256 __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvtpd_epi64 (__m512d __A)
return (__m512i) __builtin_ia32_cvtpd2qq512_mask ((__v8df) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvtpd_epi64 (__m512i __W, __mmask8 __U, __m512d __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtpd_epi64 (__mmask8 __U, __m512d __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvtpd_epu64 (__m512d __A)
return (__m512i) __builtin_ia32_cvtpd2uqq512_mask ((__v8df) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvtpd_epu64 (__m512i __W, __mmask8 __U, __m512d __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtpd_epu64 (__mmask8 __U, __m512d __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvtps_epi64 (__m256 __A)
return (__m512i) __builtin_ia32_cvtps2qq512_mask ((__v8sf) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvtps_epi64 (__m512i __W, __mmask8 __U, __m256 __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtps_epi64 (__mmask8 __U, __m256 __A)
(__v8di)
(__mmask8) __U,
0x04);
_mm512_cvtps_epu64 (__m256 __A)
return (__m512i) __builtin_ia32_cvtps2uqq512_mask ((__v8sf) __A,
(__v8di)
(__mmask8) -1,
0x04);
_mm512_mask_cvtps_epu64 (__m512i __W, __mmask8 __U, __m256 __A)
(__v8di) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtps_epu64 (__mmask8 __U, __m256 __A)
(__v8di)
(__mmask8) __U,
0x04);
extern __inline __m256
_mm512_cvtepi64_ps (__m512i __A)
return (__m256) __builtin_ia32_cvtqq2ps512_mask ((__v8di) __A,
(__v8sf)
_mm256_setzero_ps (),
(__mmask8) -1,
0x04);
_mm512_mask_cvtepi64_ps (__m256 __W, __mmask8 __U, __m512i __A)
(__v8sf) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtepi64_ps (__mmask8 __U, __m512i __A)
(__v8sf)
(__mmask8) __U,
0x04);
_mm512_cvtepu64_ps (__m512i __A)
return (__m256) __builtin_ia32_cvtuqq2ps512_mask ((__v8di) __A,
(__v8sf)
(__mmask8) -1,
0x04);
_mm512_mask_cvtepu64_ps (__m256 __W, __mmask8 __U, __m512i __A)
(__v8sf) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtepu64_ps (__mmask8 __U, __m512i __A)
(__v8sf)
(__mmask8) __U,
0x04);
_mm512_cvtepi64_pd (__m512i __A)
return (__m512d) __builtin_ia32_cvtqq2pd512_mask ((__v8di) __A,
(__v8df)
(__mmask8) -1,
0x04);
_mm512_mask_cvtepi64_pd (__m512d __W, __mmask8 __U, __m512i __A)
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtepi64_pd (__mmask8 __U, __m512i __A)
(__v8df)
(__mmask8) __U,
0x04);
_mm512_cvtepu64_pd (__m512i __A)
return (__m512d) __builtin_ia32_cvtuqq2pd512_mask ((__v8di) __A,
(__v8df)
(__mmask8) -1,
0x04);
_mm512_mask_cvtepu64_pd (__m512d __W, __mmask8 __U, __m512i __A)
(__v8df) __W,
(__mmask8) __U,
0x04);
_mm512_maskz_cvtepu64_pd (__mmask8 __U, __m512i __A)
(__v8df)
(__mmask8) __U,
0x04);
# 2676 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512dqintrin.h" 3 4
#pragma GCC pop_options
# 58 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vlbwintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vlbwintrin.h" 3 4
#pragma GCC push_options
#pragma GCC target("avx512vl,avx512bw")
extern __inline __m256i
_mm256_mask_mov_epi8 (__m256i __W, __mmask32 __U, __m256i __A)
return (__m256i) __builtin_ia32_movdquqi256_mask ((__v32qi) __A,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_mov_epi8 (__mmask32 __U, __m256i __A)
(__v32qi)
(__mmask32) __U);
extern __inline __m128i
_mm_mask_mov_epi8 (__m128i __W, __mmask16 __U, __m128i __A)
return (__m128i) __builtin_ia32_movdquqi128_mask ((__v16qi) __A,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_mov_epi8 (__mmask16 __U, __m128i __A)
(__v16qi)
_mm_setzero_si128 (),
(__mmask16) __U);
_mm256_mask_storeu_epi8 (void *__P, __mmask32 __U, __m256i __A)
__builtin_ia32_storedquqi256_mask ((char *) __P,
(__v32qi) __A,
(__mmask32) __U);
_mm_mask_storeu_epi8 (void *__P, __mmask16 __U, __m128i __A)
__builtin_ia32_storedquqi128_mask ((char *) __P,
(__v16qi) __A,
(__mmask16) __U);
_mm256_mask_loadu_epi16 (__m256i __W, __mmask16 __U, void const *__P)
return (__m256i) __builtin_ia32_loaddquhi256_mask ((const short *) __P,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_loadu_epi16 (__mmask16 __U, void const *__P)
(__v16hi)
(__mmask16) __U);
_mm_mask_loadu_epi16 (__m128i __W, __mmask8 __U, void const *__P)
return (__m128i) __builtin_ia32_loaddquhi128_mask ((const short *) __P,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_loadu_epi16 (__mmask8 __U, void const *__P)
(__v8hi)
(__mmask8) __U);
_mm256_mask_mov_epi16 (__m256i __W, __mmask16 __U, __m256i __A)
return (__m256i) __builtin_ia32_movdquhi256_mask ((__v16hi) __A,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_mov_epi16 (__mmask16 __U, __m256i __A)
(__v16hi)
(__mmask16) __U);
_mm_mask_mov_epi16 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_movdquhi128_mask ((__v8hi) __A,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_mov_epi16 (__mmask8 __U, __m128i __A)
(__v8hi)
(__mmask8) __U);
_mm256_mask_loadu_epi8 (__m256i __W, __mmask32 __U, void const *__P)
return (__m256i) __builtin_ia32_loaddquqi256_mask ((const char *) __P,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_loadu_epi8 (__mmask32 __U, void const *__P)
(__v32qi)
(__mmask32) __U);
_mm_mask_loadu_epi8 (__m128i __W, __mmask16 __U, void const *__P)
return (__m128i) __builtin_ia32_loaddquqi128_mask ((const char *) __P,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_loadu_epi8 (__mmask16 __U, void const *__P)
(__v16qi)
(__mmask16) __U);
_mm256_cvtepi16_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovwb256_mask ((__v16hi) __A,
(__v16qi)_mm_undefined_si128(),
(__mmask16) -1);
_mm256_mask_cvtepi16_storeu_epi8 (void * __P, __mmask16 __M,__m256i __A)
__builtin_ia32_pmovwb256mem_mask ((__v16qi *) __P , (__v16hi) __A, __M);
_mm256_mask_cvtepi16_epi8 (__m128i __O, __mmask16 __M, __m256i __A)
(__v16qi) __O, __M);
_mm256_maskz_cvtepi16_epi8 (__mmask16 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtsepi16_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovswb128_mask ((__v8hi) __A,
(__mmask8) -1);
_mm_mask_cvtsepi16_storeu_epi8 (void * __P, __mmask8 __M,__m128i __A)
__builtin_ia32_pmovswb128mem_mask ((__v8qi *) __P , (__v8hi) __A, __M);
_mm_mask_cvtsepi16_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
_mm_maskz_cvtsepi16_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtsepi16_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovswb256_mask ((__v16hi) __A,
(__mmask16) -1);
_mm256_mask_cvtsepi16_storeu_epi8 (void * __P, __mmask16 __M,__m256i __A)
__builtin_ia32_pmovswb256mem_mask ((__v16qi *) __P , (__v16hi) __A, __M);
_mm256_mask_cvtsepi16_epi8 (__m128i __O, __mmask16 __M, __m256i __A)
_mm256_maskz_cvtsepi16_epi8 (__mmask16 __M, __m256i __A)
(__v16qi)
__M);
_mm_cvtusepi16_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovuswb128_mask ((__v8hi) __A,
(__mmask8) -1);
_mm_mask_cvtusepi16_storeu_epi8 (void * __P, __mmask8 __M,__m128i __A)
__builtin_ia32_pmovuswb128mem_mask ((__v8qi *) __P , (__v8hi) __A, __M);
_mm_mask_cvtusepi16_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
(__v16qi) __O,
__M);
_mm_maskz_cvtusepi16_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_cvtusepi16_epi8 (__m256i __A)
return (__m128i) __builtin_ia32_pmovuswb256_mask ((__v16hi) __A,
(__mmask16) -1);
_mm256_mask_cvtusepi16_storeu_epi8 (void * __P, __mmask16 __M,__m256i __A)
__builtin_ia32_pmovuswb256mem_mask ((__v16qi *) __P , (__v16hi) __A, __M);
_mm256_mask_cvtusepi16_epi8 (__m128i __O, __mmask16 __M, __m256i __A)
(__v16qi) __O,
__M);
_mm256_maskz_cvtusepi16_epi8 (__mmask16 __M, __m256i __A)
(__v16qi)
__M);
_mm256_mask_broadcastb_epi8 (__m256i __O, __mmask32 __M, __m128i __A)
return (__m256i) __builtin_ia32_pbroadcastb256_mask ((__v16qi) __A,
(__v32qi) __O,
__M);
_mm256_maskz_broadcastb_epi8 (__mmask32 __M, __m128i __A)
(__v32qi)
__M);
_mm256_mask_set1_epi8 (__m256i __O, __mmask32 __M, char __A)
return (__m256i) __builtin_ia32_pbroadcastb256_gpr_mask (__A,
(__v32qi) __O,
__M);
_mm256_maskz_set1_epi8 (__mmask32 __M, char __A)
(__v32qi)
__M);
_mm_mask_broadcastb_epi8 (__m128i __O, __mmask16 __M, __m128i __A)
return (__m128i) __builtin_ia32_pbroadcastb128_mask ((__v16qi) __A,
(__v16qi) __O,
__M);
_mm_maskz_broadcastb_epi8 (__mmask16 __M, __m128i __A)
(__v16qi)
__M);
_mm_mask_set1_epi8 (__m128i __O, __mmask16 __M, char __A)
return (__m128i) __builtin_ia32_pbroadcastb128_gpr_mask (__A,
(__v16qi) __O,
__M);
_mm_maskz_set1_epi8 (__mmask16 __M, char __A)
(__v16qi)
__M);
_mm256_mask_broadcastw_epi16 (__m256i __O, __mmask16 __M, __m128i __A)
return (__m256i) __builtin_ia32_pbroadcastw256_mask ((__v8hi) __A,
(__v16hi) __O,
__M);
_mm256_maskz_broadcastw_epi16 (__mmask16 __M, __m128i __A)
(__v16hi)
__M);
_mm256_mask_set1_epi16 (__m256i __O, __mmask16 __M, short __A)
return (__m256i) __builtin_ia32_pbroadcastw256_gpr_mask (__A,
(__v16hi) __O,
__M);
_mm256_maskz_set1_epi16 (__mmask16 __M, short __A)
(__v16hi)
__M);
_mm_mask_broadcastw_epi16 (__m128i __O, __mmask8 __M, __m128i __A)
return (__m128i) __builtin_ia32_pbroadcastw128_mask ((__v8hi) __A,
(__v8hi) __O,
__M);
_mm_maskz_broadcastw_epi16 (__mmask8 __M, __m128i __A)
(__v8hi)
__M);
_mm_mask_set1_epi16 (__m128i __O, __mmask8 __M, short __A)
return (__m128i) __builtin_ia32_pbroadcastw128_gpr_mask (__A,
(__v8hi) __O,
__M);
_mm_maskz_set1_epi16 (__mmask8 __M, short __A)
(__v8hi)
__M);
_mm256_permutexvar_epi16 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_permvarhi256_mask ((__v16hi) __B,
(__v16hi) __A,
(__v16hi)
(__mmask16) -1);
_mm256_maskz_permutexvar_epi16 (__mmask16 __M, __m256i __A,
__m256i __B)
(__v16hi) __A,
(__v16hi)
(__mmask16) __M);
_mm256_mask_permutexvar_epi16 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v16hi) __A,
(__v16hi) __W,
(__mmask16) __M);
_mm_permutexvar_epi16 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_permvarhi128_mask ((__v8hi) __B,
(__v8hi) __A,
(__v8hi)
(__mmask8) -1);
_mm_maskz_permutexvar_epi16 (__mmask8 __M, __m128i __A, __m128i __B)
(__v8hi) __A,
(__v8hi)
(__mmask8) __M);
_mm_mask_permutexvar_epi16 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v8hi) __A,
(__v8hi) __W,
(__mmask8) __M);
_mm256_permutex2var_epi16 (__m256i __A, __m256i __I, __m256i __B)
return (__m256i) __builtin_ia32_vpermt2varhi256_mask ((__v16hi) __I
(__v16hi) __A,
(__v16hi) __B,
(__mmask16) -1);
_mm256_mask_permutex2var_epi16 (__m256i __A, __mmask16 __U,
(__v16hi) __A,
(__v16hi) __B,
(__mmask16)
__U);
_mm256_mask2_permutex2var_epi16 (__m256i __A, __m256i __I,
__mmask16 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpermi2varhi256_mask ((__v16hi) __A,
(__v16hi) __I
(__v16hi) __B,
(__mmask16)
__U);
_mm256_maskz_permutex2var_epi16 (__mmask16 __U, __m256i __A,
return (__m256i) __builtin_ia32_vpermt2varhi256_maskz ((__v16hi) __I
(__v16hi) __A,
(__v16hi) __B,
(__mmask16)
__U);
_mm_permutex2var_epi16 (__m128i __A, __m128i __I, __m128i __B)
return (__m128i) __builtin_ia32_vpermt2varhi128_mask ((__v8hi) __I
(__v8hi) __A,
(__v8hi) __B,
(__mmask8) -1);
_mm_mask_permutex2var_epi16 (__m128i __A, __mmask8 __U, __m128i __I,
__m128i __B)
(__v8hi) __A,
(__v8hi) __B,
(__mmask8)
__U);
_mm_mask2_permutex2var_epi16 (__m128i __A, __m128i __I, __mmask8 __U,
__m128i __B)
return (__m128i) __builtin_ia32_vpermi2varhi128_mask ((__v8hi) __A,
(__v8hi) __I
(__v8hi) __B,
(__mmask8)
__U);
_mm_maskz_permutex2var_epi16 (__mmask8 __U, __m128i __A, __m128i __I,
__m128i __B)
return (__m128i) __builtin_ia32_vpermt2varhi128_maskz ((__v8hi) __I
(__v8hi) __A,
(__v8hi) __B,
(__mmask8)
__U);
_mm256_mask_maddubs_epi16 (__m256i __W, __mmask16 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_pmaddubsw256_mask ((__v32qi) __X,
(__v32qi) __Y,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_maddubs_epi16 (__mmask16 __U, __m256i __X, __m256i __Y)
(__v32qi) __Y,
(__v16hi)
(__mmask16) __U);
_mm_mask_maddubs_epi16 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_pmaddubsw128_mask ((__v16qi) __X,
(__v16qi) __Y,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_maddubs_epi16 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v16qi) __Y,
(__v8hi)
(__mmask8) __U);
_mm256_mask_madd_epi16 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pmaddwd256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v8si) __W,
(__mmask8) __U);
_mm256_maskz_madd_epi16 (__mmask8 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v8si)
(__mmask8) __U);
_mm_mask_madd_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pmaddwd128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v4si) __W,
(__mmask8) __U);
_mm_maskz_madd_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v4si)
(__mmask8) __U);
_mm_movepi8_mask (__m128i __A)
return (__mmask16) __builtin_ia32_cvtb2mask128 ((__v16qi) __A);
_mm256_movepi8_mask (__m256i __A)
return (__mmask32) __builtin_ia32_cvtb2mask256 ((__v32qi) __A);
_mm_movepi16_mask (__m128i __A)
return (__mmask8) __builtin_ia32_cvtw2mask128 ((__v8hi) __A);
_mm256_movepi16_mask (__m256i __A)
return (__mmask16) __builtin_ia32_cvtw2mask256 ((__v16hi) __A);
_mm_movm_epi8 (__mmask16 __A)
return (__m128i) __builtin_ia32_cvtmask2b128 (__A);
_mm256_movm_epi8 (__mmask32 __A)
return (__m256i) __builtin_ia32_cvtmask2b256 (__A);
_mm_movm_epi16 (__mmask8 __A)
return (__m128i) __builtin_ia32_cvtmask2w128 (__A);
_mm256_movm_epi16 (__mmask16 __A)
return (__m256i) __builtin_ia32_cvtmask2w256 (__A);
_mm_test_epi8_mask (__m128i __A, __m128i __B)
return (__mmask16) __builtin_ia32_ptestmb128 ((__v16qi) __A,
(__v16qi) __B,
(__mmask16) -1);
_mm_mask_test_epi8_mask (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B, __U);
_mm256_test_epi8_mask (__m256i __A, __m256i __B)
return (__mmask32) __builtin_ia32_ptestmb256 ((__v32qi) __A,
(__v32qi) __B,
(__mmask32) -1);
_mm256_mask_test_epi8_mask (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B, __U);
_mm_test_epi16_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ptestmw128 ((__v8hi) __A,
(__v8hi) __B,
(__mmask8) -1);
_mm_mask_test_epi16_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B, __U);
_mm256_test_epi16_mask (__m256i __A, __m256i __B)
return (__mmask16) __builtin_ia32_ptestmw256 ((__v16hi) __A,
(__v16hi) __B,
(__mmask16) -1);
_mm256_mask_test_epi16_mask (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B, __U);
_mm256_maskz_min_epu16 (__mmask16 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminuw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) __M);
_mm256_mask_min_epu16 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __M);
_mm_maskz_min_epu16 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminuw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) __M);
_mm_mask_min_epu16 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __M);
_mm256_maskz_min_epi16 (__mmask16 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminsw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) __M);
_mm256_mask_min_epi16 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __M);
_mm256_maskz_max_epu8 (__mmask32 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxub256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi)
(__mmask32) __M);
_mm256_mask_max_epu8 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __M);
_mm_maskz_max_epu8 (__mmask16 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxub128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi)
(__mmask16) __M);
_mm_mask_max_epu8 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __M);
_mm256_maskz_max_epi8 (__mmask32 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxsb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi)
(__mmask32) __M);
_mm256_mask_max_epi8 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __M);
_mm_maskz_max_epi8 (__mmask16 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxsb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi)
(__mmask16) __M);
_mm_mask_max_epi8 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __M);
_mm256_maskz_min_epu8 (__mmask32 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminub256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi)
(__mmask32) __M);
_mm256_mask_min_epu8 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __M);
_mm_maskz_min_epu8 (__mmask16 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminub128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi)
(__mmask16) __M);
_mm_mask_min_epu8 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __M);
_mm256_maskz_min_epi8 (__mmask32 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pminsb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi)
(__mmask32) __M);
_mm256_mask_min_epi8 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __M);
_mm_maskz_min_epi8 (__mmask16 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminsb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi)
(__mmask16) __M);
_mm_mask_min_epi8 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __M);
_mm256_maskz_max_epi16 (__mmask16 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxsw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) __M);
_mm256_mask_max_epi16 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __M);
_mm_maskz_max_epi16 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxsw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) __M);
_mm_mask_max_epi16 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __M);
_mm256_maskz_max_epu16 (__mmask16 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_pmaxuw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) __M);
_mm256_mask_max_epu16 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __M);
_mm_maskz_max_epu16 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pmaxuw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) __M);
_mm_mask_max_epu16 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __M);
_mm_maskz_min_epi16 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_pminsw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) __M);
_mm_mask_min_epi16 (__m128i __W, __mmask8 __M, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __M);
# 2039 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vlbwintrin.h" 3 4
extern __inline __mmask32
_mm256_cmpneq_epi8_mask (__m256i __X, __m256i __Y)
return (__mmask32) __builtin_ia32_cmpb256_mask ((__v32qi) __X,
(__v32qi) __Y, 4,
(__mmask32) -1);
_mm256_cmplt_epi8_mask (__m256i __X, __m256i __Y)
(__v32qi) __Y, 1,
(__mmask32) -1);
_mm256_cmpge_epi8_mask (__m256i __X, __m256i __Y)
(__v32qi) __Y, 5,
(__mmask32) -1);
_mm256_cmple_epi8_mask (__m256i __X, __m256i __Y)
(__v32qi) __Y, 2,
(__mmask32) -1);
_mm256_cmpneq_epi16_mask (__m256i __X, __m256i __Y)
return (__mmask16) __builtin_ia32_cmpw256_mask ((__v16hi) __X,
(__v16hi) __Y, 4,
(__mmask16) -1);
_mm256_cmplt_epi16_mask (__m256i __X, __m256i __Y)
(__v16hi) __Y, 1,
(__mmask16) -1);
_mm256_cmpge_epi16_mask (__m256i __X, __m256i __Y)
(__v16hi) __Y, 5,
(__mmask16) -1);
_mm256_cmple_epi16_mask (__m256i __X, __m256i __Y)
(__v16hi) __Y, 2,
(__mmask16) -1);
_mm_cmpneq_epu8_mask (__m128i __X, __m128i __Y)
return (__mmask16) __builtin_ia32_ucmpb128_mask ((__v16qi) __X,
(__v16qi) __Y, 4,
(__mmask16) -1);
_mm_cmplt_epu8_mask (__m128i __X, __m128i __Y)
(__v16qi) __Y, 1,
(__mmask16) -1);
_mm_cmpge_epu8_mask (__m128i __X, __m128i __Y)
(__v16qi) __Y, 5,
(__mmask16) -1);
_mm_cmple_epu8_mask (__m128i __X, __m128i __Y)
(__v16qi) __Y, 2,
(__mmask16) -1);
_mm_cmpneq_epu16_mask (__m128i __X, __m128i __Y)
return (__mmask8) __builtin_ia32_ucmpw128_mask ((__v8hi) __X,
(__v8hi) __Y, 4,
(__mmask8) -1);
_mm_cmplt_epu16_mask (__m128i __X, __m128i __Y)
(__v8hi) __Y, 1,
(__mmask8) -1);
_mm_cmpge_epu16_mask (__m128i __X, __m128i __Y)
(__v8hi) __Y, 5,
(__mmask8) -1);
_mm_cmple_epu16_mask (__m128i __X, __m128i __Y)
(__v8hi) __Y, 2,
(__mmask8) -1);
_mm_cmpneq_epi8_mask (__m128i __X, __m128i __Y)
return (__mmask16) __builtin_ia32_cmpb128_mask ((__v16qi) __X,
(__v16qi) __Y, 4,
(__mmask16) -1);
_mm_cmplt_epi8_mask (__m128i __X, __m128i __Y)
(__v16qi) __Y, 1,
(__mmask16) -1);
_mm_cmpge_epi8_mask (__m128i __X, __m128i __Y)
(__v16qi) __Y, 5,
(__mmask16) -1);
_mm_cmple_epi8_mask (__m128i __X, __m128i __Y)
(__v16qi) __Y, 2,
(__mmask16) -1);
_mm_cmpneq_epi16_mask (__m128i __X, __m128i __Y)
return (__mmask8) __builtin_ia32_cmpw128_mask ((__v8hi) __X,
(__v8hi) __Y, 4,
(__mmask8) -1);
_mm_cmplt_epi16_mask (__m128i __X, __m128i __Y)
(__v8hi) __Y, 1,
(__mmask8) -1);
_mm_cmpge_epi16_mask (__m128i __X, __m128i __Y)
(__v8hi) __Y, 5,
(__mmask8) -1);
_mm_cmple_epi16_mask (__m128i __X, __m128i __Y)
(__v8hi) __Y, 2,
(__mmask8) -1);
_mm256_mask_mulhrs_epi16 (__m256i __W, __mmask16 __U, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_pmulhrsw256_mask ((__v16hi) __X,
(__v16hi) __Y,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_mulhrs_epi16 (__mmask16 __U, __m256i __X, __m256i __Y)
(__v16hi) __Y,
(__v16hi)
(__mmask16) __U);
_mm256_mask_mulhi_epu16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pmulhuw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_mulhi_epu16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_mask_mulhi_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pmulhw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_mulhi_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_mulhi_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pmulhw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_mulhi_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_mulhi_epu16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pmulhuw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_mulhi_epu16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_mulhrs_epi16 (__m128i __W, __mmask8 __U, __m128i __X,
__m128i __Y)
return (__m128i) __builtin_ia32_pmulhrsw128_mask ((__v8hi) __X,
(__v8hi) __Y,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_mulhrs_epi16 (__mmask8 __U, __m128i __X, __m128i __Y)
(__v8hi) __Y,
(__v8hi)
(__mmask8) __U);
_mm256_mask_mullo_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pmullw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_mullo_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
_mm256_setzero_si256 (),
(__mmask16) __U);
_mm_mask_mullo_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pmullw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_mullo_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_cvtepi8_epi16 (__m256i __W, __mmask16 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovsxbw256_mask ((__v16qi) __A,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_cvtepi8_epi16 (__mmask16 __U, __m128i __A)
(__v16hi)
(__mmask16) __U);
_mm_mask_cvtepi8_epi16 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovsxbw128_mask ((__v16qi) __A,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_cvtepi8_epi16 (__mmask8 __U, __m128i __A)
(__v8hi)
(__mmask8) __U);
_mm256_mask_cvtepu8_epi16 (__m256i __W, __mmask16 __U, __m128i __A)
return (__m256i) __builtin_ia32_pmovzxbw256_mask ((__v16qi) __A,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_cvtepu8_epi16 (__mmask16 __U, __m128i __A)
(__v16hi)
(__mmask16) __U);
_mm_mask_cvtepu8_epi16 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pmovzxbw128_mask ((__v16qi) __A,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_cvtepu8_epi16 (__mmask8 __U, __m128i __A)
(__v8hi)
(__mmask8) __U);
_mm256_mask_avg_epu8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pavgb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_avg_epu8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm_mask_avg_epu8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pavgb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_avg_epu8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm256_mask_avg_epu16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pavgw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_avg_epu16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_avg_epu16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pavgw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_avg_epu16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_add_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_add_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm256_mask_add_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_add_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_mask_adds_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddsb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_adds_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm256_mask_adds_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddsw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_adds_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_mask_adds_epu8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddusb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_adds_epu8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm256_mask_adds_epu16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_paddusw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_adds_epu16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_mask_sub_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_sub_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm256_mask_sub_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_sub_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_mask_subs_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubsb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_subs_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm256_mask_subs_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubsw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_subs_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_mask_subs_epu8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubusb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_subs_epu8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm256_mask_subs_epu16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_psubusw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_subs_epu16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_add_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_add_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm_mask_add_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_add_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_unpackhi_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpckhbw256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_unpackhi_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm_mask_unpackhi_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpckhbw128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_unpackhi_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm256_mask_unpackhi_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpckhwd256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_unpackhi_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_unpackhi_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpckhwd128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_unpackhi_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_unpacklo_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpcklbw256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_unpacklo_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm_mask_unpacklo_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpcklbw128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_unpacklo_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm256_mask_unpacklo_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_punpcklwd256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_unpacklo_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_unpacklo_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_punpcklwd128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_unpacklo_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_cmpeq_epi8_mask (__m128i __A, __m128i __B)
return (__mmask16) __builtin_ia32_pcmpeqb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__mmask16) -1);
_mm_cmpeq_epu8_mask (__m128i __A, __m128i __B)
return (__mmask16) __builtin_ia32_ucmpb128_mask ((__v16qi) __A,
(__v16qi) __B, 0,
(__mmask16) -1);
_mm_mask_cmpeq_epu8_mask (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B, 0,
__U);
_mm_mask_cmpeq_epi8_mask (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
__U);
_mm256_cmpeq_epu8_mask (__m256i __A, __m256i __B)
return (__mmask32) __builtin_ia32_ucmpb256_mask ((__v32qi) __A,
(__v32qi) __B, 0,
(__mmask32) -1);
_mm256_cmpeq_epi8_mask (__m256i __A, __m256i __B)
return (__mmask32) __builtin_ia32_pcmpeqb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__mmask32) -1);
_mm256_mask_cmpeq_epu8_mask (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B, 0,
__U);
_mm256_mask_cmpeq_epi8_mask (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
__U);
_mm_cmpeq_epu16_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ucmpw128_mask ((__v8hi) __A,
(__v8hi) __B, 0,
(__mmask8) -1);
_mm_cmpeq_epi16_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_pcmpeqw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__mmask8) -1);
_mm_mask_cmpeq_epu16_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B, 0, __U);
_mm_mask_cmpeq_epi16_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B, __U);
_mm256_cmpeq_epu16_mask (__m256i __A, __m256i __B)
return (__mmask16) __builtin_ia32_ucmpw256_mask ((__v16hi) __A,
(__v16hi) __B, 0,
(__mmask16) -1);
_mm256_cmpeq_epi16_mask (__m256i __A, __m256i __B)
return (__mmask16) __builtin_ia32_pcmpeqw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__mmask16) -1);
_mm256_mask_cmpeq_epu16_mask (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B, 0,
__U);
_mm256_mask_cmpeq_epi16_mask (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
__U);
_mm_cmpgt_epu8_mask (__m128i __A, __m128i __B)
(__v16qi) __B, 6,
(__mmask16) -1);
_mm_cmpgt_epi8_mask (__m128i __A, __m128i __B)
return (__mmask16) __builtin_ia32_pcmpgtb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__mmask16) -1);
_mm_mask_cmpgt_epu8_mask (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B, 6,
__U);
_mm_mask_cmpgt_epi8_mask (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
__U);
_mm256_cmpgt_epu8_mask (__m256i __A, __m256i __B)
(__v32qi) __B, 6,
(__mmask32) -1);
_mm256_cmpgt_epi8_mask (__m256i __A, __m256i __B)
return (__mmask32) __builtin_ia32_pcmpgtb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__mmask32) -1);
_mm256_mask_cmpgt_epu8_mask (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B, 6,
__U);
_mm256_mask_cmpgt_epi8_mask (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
__U);
_mm_cmpgt_epu16_mask (__m128i __A, __m128i __B)
(__v8hi) __B, 6,
(__mmask8) -1);
_mm_cmpgt_epi16_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_pcmpgtw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__mmask8) -1);
_mm_mask_cmpgt_epu16_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B, 6, __U);
_mm_mask_cmpgt_epi16_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B, __U);
_mm256_cmpgt_epu16_mask (__m256i __A, __m256i __B)
(__v16hi) __B, 6,
(__mmask16) -1);
_mm256_cmpgt_epi16_mask (__m256i __A, __m256i __B)
return (__mmask16) __builtin_ia32_pcmpgtw256_mask ((__v16hi) __A,
(__v16hi) __B,
(__mmask16) -1);
_mm256_mask_cmpgt_epu16_mask (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B, 6,
__U);
_mm256_mask_cmpgt_epi16_mask (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
__U);
_mm_testn_epi8_mask (__m128i __A, __m128i __B)
return (__mmask16) __builtin_ia32_ptestnmb128 ((__v16qi) __A,
(__v16qi) __B,
(__mmask16) -1);
_mm_mask_testn_epi8_mask (__mmask16 __U, __m128i __A, __m128i __B)
_mm256_testn_epi8_mask (__m256i __A, __m256i __B)
return (__mmask32) __builtin_ia32_ptestnmb256 ((__v32qi) __A,
(__v32qi) __B,
(__mmask32) -1);
_mm256_mask_testn_epi8_mask (__mmask32 __U, __m256i __A, __m256i __B)
_mm_testn_epi16_mask (__m128i __A, __m128i __B)
return (__mmask8) __builtin_ia32_ptestnmw128 ((__v8hi) __A,
(__v8hi) __B,
(__mmask8) -1);
_mm_mask_testn_epi16_mask (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B, __U);
_mm256_testn_epi16_mask (__m256i __A, __m256i __B)
return (__mmask16) __builtin_ia32_ptestnmw256 ((__v16hi) __A,
(__v16hi) __B,
(__mmask16) -1);
_mm256_mask_testn_epi16_mask (__mmask16 __U, __m256i __A, __m256i __B)
_mm256_mask_shuffle_epi8 (__m256i __W, __mmask32 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pshufb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_shuffle_epi8 (__mmask32 __U, __m256i __A, __m256i __B)
(__v32qi) __B,
(__v32qi)
(__mmask32) __U);
_mm_mask_shuffle_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pshufb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_shuffle_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm256_maskz_packs_epi16 (__mmask32 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_packsswb256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v32qi)
__M);
_mm256_mask_packs_epi16 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v32qi) __W,
__M);
_mm_maskz_packs_epi16 (__mmask16 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_packsswb128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v16qi)
__M);
_mm_mask_packs_epi16 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v16qi) __W,
__M);
_mm256_maskz_packus_epi16 (__mmask32 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_packuswb256_mask ((__v16hi) __A,
(__v16hi) __B,
(__v32qi)
__M);
_mm256_mask_packus_epi16 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v32qi) __W,
__M);
_mm_maskz_packus_epi16 (__mmask16 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_packuswb128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v16qi)
__M);
_mm_mask_packus_epi16 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v16qi) __W,
__M);
_mm256_mask_abs_epi8 (__m256i __W, __mmask32 __U, __m256i __A)
return (__m256i) __builtin_ia32_pabsb256_mask ((__v32qi) __A,
(__v32qi) __W,
(__mmask32) __U);
_mm256_maskz_abs_epi8 (__mmask32 __U, __m256i __A)
(__v32qi)
(__mmask32) __U);
_mm_mask_abs_epi8 (__m128i __W, __mmask16 __U, __m128i __A)
return (__m128i) __builtin_ia32_pabsb128_mask ((__v16qi) __A,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_abs_epi8 (__mmask16 __U, __m128i __A)
(__v16qi)
(__mmask16) __U);
_mm256_mask_abs_epi16 (__m256i __W, __mmask16 __U, __m256i __A)
return (__m256i) __builtin_ia32_pabsw256_mask ((__v16hi) __A,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_abs_epi16 (__mmask16 __U, __m256i __A)
(__v16hi)
(__mmask16) __U);
_mm_mask_abs_epi16 (__m128i __W, __mmask8 __U, __m128i __A)
return (__m128i) __builtin_ia32_pabsw128_mask ((__v8hi) __A,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_abs_epi16 (__mmask8 __U, __m128i __A)
(__v8hi)
(__mmask8) __U);
_mm256_cmpneq_epu8_mask (__m256i __X, __m256i __Y)
return (__mmask32) __builtin_ia32_ucmpb256_mask ((__v32qi) __X,
(__v32qi) __Y, 4,
(__mmask32) -1);
_mm256_cmplt_epu8_mask (__m256i __X, __m256i __Y)
(__v32qi) __Y, 1,
(__mmask32) -1);
_mm256_cmpge_epu8_mask (__m256i __X, __m256i __Y)
(__v32qi) __Y, 5,
(__mmask32) -1);
_mm256_cmple_epu8_mask (__m256i __X, __m256i __Y)
(__v32qi) __Y, 2,
(__mmask32) -1);
_mm256_cmpneq_epu16_mask (__m256i __X, __m256i __Y)
return (__mmask16) __builtin_ia32_ucmpw256_mask ((__v16hi) __X,
(__v16hi) __Y, 4,
(__mmask16) -1);
_mm256_cmplt_epu16_mask (__m256i __X, __m256i __Y)
(__v16hi) __Y, 1,
(__mmask16) -1);
_mm256_cmpge_epu16_mask (__m256i __X, __m256i __Y)
(__v16hi) __Y, 5,
(__mmask16) -1);
_mm256_cmple_epu16_mask (__m256i __X, __m256i __Y)
(__v16hi) __Y, 2,
(__mmask16) -1);
_mm256_mask_storeu_epi16 (void *__P, __mmask16 __U, __m256i __A)
__builtin_ia32_storedquhi256_mask ((short *) __P,
(__v16hi) __A,
(__mmask16) __U);
_mm_mask_storeu_epi16 (void *__P, __mmask8 __U, __m128i __A)
__builtin_ia32_storedquhi128_mask ((short *) __P,
(__v8hi) __A,
(__mmask8) __U);
_mm_mask_adds_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddsw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_mask_subs_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubsb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_subs_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm_mask_subs_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubsw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_subs_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_subs_epu8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubusb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_subs_epu8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm_mask_subs_epu16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubusw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_subs_epu16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_srl_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psrlw256_mask ((__v16hi) __A,
(__v8hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_srl_epi16 (__mmask16 __U, __m256i __A, __m128i __B)
(__v8hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_srl_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psrlw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm_maskz_srl_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_sra_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psraw256_mask ((__v16hi) __A,
(__v8hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_sra_epi16 (__mmask16 __U, __m256i __A, __m128i __B)
(__v8hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_mask_sra_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psraw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_sra_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_maskz_adds_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_adds_epu8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddusb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_adds_epu8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm_mask_adds_epu16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddusw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_adds_epu16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_sub_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_sub_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm_mask_sub_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psubw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_sub_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_adds_epi8 (__m128i __W, __mmask16 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_paddsb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__v16qi) __W,
(__mmask16) __U);
_mm_maskz_adds_epi8 (__mmask16 __U, __m128i __A, __m128i __B)
(__v16qi) __B,
(__v16qi)
(__mmask16) __U);
_mm_cvtepi16_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_pmovwb128_mask ((__v8hi) __A,
(__mmask8) -1);
_mm_mask_cvtepi16_storeu_epi8 (void * __P, __mmask8 __M,__m128i __A)
__builtin_ia32_pmovwb128mem_mask ((__v8qi *) __P , (__v8hi) __A, __M);
_mm_mask_cvtepi16_epi8 (__m128i __O, __mmask8 __M, __m128i __A)
_mm_maskz_cvtepi16_epi8 (__mmask8 __M, __m128i __A)
(__v16qi)
__M);
_mm256_srav_epi16 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_psrav16hi_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) -1);
_mm256_mask_srav_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_srav_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_srav_epi16 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_psrav8hi_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) -1);
_mm_mask_srav_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_srav_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_srlv_epi16 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_psrlv16hi_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) -1);
_mm256_mask_srlv_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_srlv_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_srlv_epi16 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_psrlv8hi_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) -1);
_mm_mask_srlv_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_srlv_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_sllv_epi16 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_psllv16hi_mask ((__v16hi) __A,
(__v16hi) __B,
(__v16hi)
(__mmask16) -1);
_mm256_mask_sllv_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m256i __B)
(__v16hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_sllv_epi16 (__mmask16 __U, __m256i __A, __m256i __B)
(__v16hi) __B,
(__v16hi)
(__mmask16) __U);
_mm_sllv_epi16 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_psllv8hi_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi)
(__mmask8) -1);
_mm_mask_sllv_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_sllv_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm_mask_sll_epi16 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_psllw128_mask ((__v8hi) __A,
(__v8hi) __B,
(__v8hi) __W,
(__mmask8) __U);
_mm_maskz_sll_epi16 (__mmask8 __U, __m128i __A, __m128i __B)
(__v8hi) __B,
(__v8hi)
(__mmask8) __U);
_mm256_mask_sll_epi16 (__m256i __W, __mmask16 __U, __m256i __A,
__m128i __B)
return (__m256i) __builtin_ia32_psllw256_mask ((__v16hi) __A,
(__v8hi) __B,
(__v16hi) __W,
(__mmask16) __U);
_mm256_maskz_sll_epi16 (__mmask16 __U, __m256i __A, __m128i __B)
(__v8hi) __B,
(__v16hi)
(__mmask16) __U);
_mm256_maskz_packus_epi32 (__mmask16 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_packusdw256_mask ((__v8si) __A,
(__v8si) __B,
(__v16hi)
__M);
_mm256_mask_packus_epi32 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v16hi) __W,
__M);
_mm_maskz_packus_epi32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_packusdw128_mask ((__v4si) __A,
(__v4si) __B,
(__v8hi)
__M);
_mm_mask_packus_epi32 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v8hi) __W, __M);
_mm256_maskz_packs_epi32 (__mmask16 __M, __m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_packssdw256_mask ((__v8si) __A,
(__v8si) __B,
(__v16hi)
__M);
_mm256_mask_packs_epi32 (__m256i __W, __mmask16 __M, __m256i __A,
__m256i __B)
(__v8si) __B,
(__v16hi) __W,
__M);
_mm_maskz_packs_epi32 (__mmask8 __M, __m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_packssdw128_mask ((__v4si) __A,
(__v4si) __B,
(__v8hi)
__M);
_mm_mask_packs_epi32 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v4si) __B,
(__v8hi) __W, __M);
_mm_mask_cmpneq_epu8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 4,
(__mmask16) __M);
_mm_mask_cmplt_epu8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 1,
(__mmask16) __M);
_mm_mask_cmpge_epu8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 5,
(__mmask16) __M);
_mm_mask_cmple_epu8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 2,
(__mmask16) __M);
_mm_mask_cmpneq_epu16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 4,
(__mmask8) __M);
_mm_mask_cmplt_epu16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 1,
(__mmask8) __M);
_mm_mask_cmpge_epu16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 5,
(__mmask8) __M);
_mm_mask_cmple_epu16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 2,
(__mmask8) __M);
_mm_mask_cmpneq_epi8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 4,
(__mmask16) __M);
_mm_mask_cmplt_epi8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 1,
(__mmask16) __M);
_mm_mask_cmpge_epi8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 5,
(__mmask16) __M);
_mm_mask_cmple_epi8_mask (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y, 2,
(__mmask16) __M);
_mm_mask_cmpneq_epi16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 4,
(__mmask8) __M);
_mm_mask_cmplt_epi16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 1,
(__mmask8) __M);
_mm_mask_cmpge_epi16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 5,
(__mmask8) __M);
_mm_mask_cmple_epi16_mask (__mmask8 __M, __m128i __X, __m128i __Y)
(__v8hi) __Y, 2,
(__mmask8) __M);
_mm256_mask_cmpneq_epu8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 4,
(__mmask32) __M);
_mm256_mask_cmplt_epu8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 1,
(__mmask32) __M);
_mm256_mask_cmpge_epu8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 5,
(__mmask32) __M);
_mm256_mask_cmple_epu8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 2,
(__mmask32) __M);
_mm256_mask_cmpneq_epu16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 4,
(__mmask16) __M);
_mm256_mask_cmplt_epu16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 1,
(__mmask16) __M);
_mm256_mask_cmpge_epu16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 5,
(__mmask16) __M);
_mm256_mask_cmple_epu16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 2,
(__mmask16) __M);
_mm256_mask_cmpneq_epi8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 4,
(__mmask32) __M);
_mm256_mask_cmplt_epi8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 1,
(__mmask32) __M);
_mm256_mask_cmpge_epi8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 5,
(__mmask32) __M);
_mm256_mask_cmple_epi8_mask (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y, 2,
(__mmask32) __M);
extern __inline __mmask16
_mm256_mask_cmpneq_epi16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 4,
(__mmask16) __M);
_mm256_mask_cmplt_epi16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 1,
(__mmask16) __M);
_mm256_mask_cmpge_epi16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 5,
(__mmask16) __M);
_mm256_mask_cmple_epi16_mask (__mmask16 __M, __m256i __X, __m256i __Y)
(__v16hi) __Y, 2,
(__mmask16) __M);
# 60 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vldqintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vldqintrin.h" 3 4
#pragma GCC target("avx512vl,avx512dq")
_mm256_cvttpd_epi64 (__m256d __A)
return (__m256i) __builtin_ia32_cvttpd2qq256_mask ((__v4df) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvttpd_epi64 (__m256i __W, __mmask8 __U, __m256d __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvttpd_epi64 (__mmask8 __U, __m256d __A)
(__v4di)
(__mmask8) __U);
_mm_cvttpd_epi64 (__m128d __A)
return (__m128i) __builtin_ia32_cvttpd2qq128_mask ((__v2df) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvttpd_epi64 (__m128i __W, __mmask8 __U, __m128d __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvttpd_epi64 (__mmask8 __U, __m128d __A)
(__v2di)
(__mmask8) __U);
_mm256_cvttpd_epu64 (__m256d __A)
return (__m256i) __builtin_ia32_cvttpd2uqq256_mask ((__v4df) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvttpd_epu64 (__m256i __W, __mmask8 __U, __m256d __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvttpd_epu64 (__mmask8 __U, __m256d __A)
(__v4di)
(__mmask8) __U);
_mm_cvttpd_epu64 (__m128d __A)
return (__m128i) __builtin_ia32_cvttpd2uqq128_mask ((__v2df) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvttpd_epu64 (__m128i __W, __mmask8 __U, __m128d __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvttpd_epu64 (__mmask8 __U, __m128d __A)
(__v2di)
(__mmask8) __U);
_mm256_cvtpd_epi64 (__m256d __A)
return (__m256i) __builtin_ia32_cvtpd2qq256_mask ((__v4df) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvtpd_epi64 (__m256i __W, __mmask8 __U, __m256d __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtpd_epi64 (__mmask8 __U, __m256d __A)
(__v4di)
(__mmask8) __U);
_mm_cvtpd_epi64 (__m128d __A)
return (__m128i) __builtin_ia32_cvtpd2qq128_mask ((__v2df) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvtpd_epi64 (__m128i __W, __mmask8 __U, __m128d __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtpd_epi64 (__mmask8 __U, __m128d __A)
(__v2di)
(__mmask8) __U);
_mm256_cvtpd_epu64 (__m256d __A)
return (__m256i) __builtin_ia32_cvtpd2uqq256_mask ((__v4df) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvtpd_epu64 (__m256i __W, __mmask8 __U, __m256d __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtpd_epu64 (__mmask8 __U, __m256d __A)
(__v4di)
(__mmask8) __U);
_mm_cvtpd_epu64 (__m128d __A)
return (__m128i) __builtin_ia32_cvtpd2uqq128_mask ((__v2df) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvtpd_epu64 (__m128i __W, __mmask8 __U, __m128d __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtpd_epu64 (__mmask8 __U, __m128d __A)
(__v2di)
(__mmask8) __U);
_mm256_cvttps_epi64 (__m128 __A)
return (__m256i) __builtin_ia32_cvttps2qq256_mask ((__v4sf) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvttps_epi64 (__m256i __W, __mmask8 __U, __m128 __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvttps_epi64 (__mmask8 __U, __m128 __A)
(__v4di)
(__mmask8) __U);
_mm_cvttps_epi64 (__m128 __A)
return (__m128i) __builtin_ia32_cvttps2qq128_mask ((__v4sf) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvttps_epi64 (__m128i __W, __mmask8 __U, __m128 __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvttps_epi64 (__mmask8 __U, __m128 __A)
(__v2di)
(__mmask8) __U);
_mm256_cvttps_epu64 (__m128 __A)
return (__m256i) __builtin_ia32_cvttps2uqq256_mask ((__v4sf) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvttps_epu64 (__m256i __W, __mmask8 __U, __m128 __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvttps_epu64 (__mmask8 __U, __m128 __A)
(__v4di)
(__mmask8) __U);
_mm_cvttps_epu64 (__m128 __A)
return (__m128i) __builtin_ia32_cvttps2uqq128_mask ((__v4sf) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvttps_epu64 (__m128i __W, __mmask8 __U, __m128 __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvttps_epu64 (__mmask8 __U, __m128 __A)
(__v2di)
(__mmask8) __U);
extern __inline __m256d
_mm256_broadcast_f64x2 (__m128d __A)
return (__m256d) __builtin_ia32_broadcastf64x2_256_mask ((__v2df)
__A,
(__v4df)_mm256_undefined_pd(),
(__mmask8) -1);
_mm256_mask_broadcast_f64x2 (__m256d __O, __mmask8 __M, __m128d __A)
__A,
(__v4df)
__O, __M);
_mm256_maskz_broadcast_f64x2 (__mmask8 __M, __m128d __A)
__A,
(__v4df)
__M);
_mm256_broadcast_i64x2 (__m128i __A)
return (__m256i) __builtin_ia32_broadcasti64x2_256_mask ((__v2di)
__A,
(__v4di)_mm256_undefined_si256(),
(__mmask8) -1);
_mm256_mask_broadcast_i64x2 (__m256i __O, __mmask8 __M, __m128i __A)
__A,
(__v4di)
__O, __M);
_mm256_maskz_broadcast_i64x2 (__mmask8 __M, __m128i __A)
__A,
(__v4di)
__M);
_mm256_broadcast_f32x2 (__m128 __A)
return (__m256) __builtin_ia32_broadcastf32x2_256_mask ((__v4sf) __A,
(__v8sf)_mm256_undefined_ps(),
(__mmask8) -1);
_mm256_mask_broadcast_f32x2 (__m256 __O, __mmask8 __M, __m128 __A)
(__v8sf) __O,
__M);
_mm256_maskz_broadcast_f32x2 (__mmask8 __M, __m128 __A)
(__v8sf)
__M);
_mm256_broadcast_i32x2 (__m128i __A)
return (__m256i) __builtin_ia32_broadcasti32x2_256_mask ((__v4si)
__A,
(__v8si)_mm256_undefined_si256(),
(__mmask8) -1);
_mm256_mask_broadcast_i32x2 (__m256i __O, __mmask8 __M, __m128i __A)
__A,
(__v8si)
__O, __M);
_mm256_maskz_broadcast_i32x2 (__mmask8 __M, __m128i __A)
__A,
(__v8si)
__M);
_mm_broadcast_i32x2 (__m128i __A)
return (__m128i) __builtin_ia32_broadcasti32x2_128_mask ((__v4si)
__A,
(__v4si)_mm_undefined_si128(),
(__mmask8) -1);
_mm_mask_broadcast_i32x2 (__m128i __O, __mmask8 __M, __m128i __A)
__A,
(__v4si)
__O, __M);
_mm_maskz_broadcast_i32x2 (__mmask8 __M, __m128i __A)
__A,
(__v4si)
__M);
_mm256_mullo_epi64 (__m256i __A, __m256i __B)
return (__m256i) ((__v4du) __A * (__v4du) __B);
_mm256_mask_mullo_epi64 (__m256i __W, __mmask8 __U, __m256i __A,
__m256i __B)
return (__m256i) __builtin_ia32_pmullq256_mask ((__v4di) __A,
(__v4di) __B,
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_mullo_epi64 (__mmask8 __U, __m256i __A, __m256i __B)
(__v4di) __B,
(__v4di)
(__mmask8) __U);
_mm_mullo_epi64 (__m128i __A, __m128i __B)
return (__m128i) ((__v2du) __A * (__v2du) __B);
_mm_mask_mullo_epi64 (__m128i __W, __mmask8 __U, __m128i __A,
__m128i __B)
return (__m128i) __builtin_ia32_pmullq128_mask ((__v2di) __A,
(__v2di) __B,
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_mullo_epi64 (__mmask8 __U, __m128i __A, __m128i __B)
(__v2di) __B,
(__v2di)
(__mmask8) __U);
_mm256_mask_andnot_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_andnpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_andnot_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
_mm256_setzero_pd (),
(__mmask8) __U);
extern __inline __m128d
_mm_mask_andnot_pd (__m128d __W, __mmask8 __U, __m128d __A,
__m128d __B)
return (__m128d) __builtin_ia32_andnpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_andnot_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_andnot_ps (__m256 __W, __mmask8 __U, __m256 __A,
__m256 __B)
return (__m256) __builtin_ia32_andnps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_andnot_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_mask_andnot_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_andnps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_andnot_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_cvtps_epi64 (__m128 __A)
return (__m256i) __builtin_ia32_cvtps2qq256_mask ((__v4sf) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvtps_epi64 (__m256i __W, __mmask8 __U, __m128 __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtps_epi64 (__mmask8 __U, __m128 __A)
(__v4di)
(__mmask8) __U);
_mm_cvtps_epi64 (__m128 __A)
return (__m128i) __builtin_ia32_cvtps2qq128_mask ((__v4sf) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvtps_epi64 (__m128i __W, __mmask8 __U, __m128 __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtps_epi64 (__mmask8 __U, __m128 __A)
(__v2di)
(__mmask8) __U);
_mm256_cvtps_epu64 (__m128 __A)
return (__m256i) __builtin_ia32_cvtps2uqq256_mask ((__v4sf) __A,
(__v4di)
(__mmask8) -1);
_mm256_mask_cvtps_epu64 (__m256i __W, __mmask8 __U, __m128 __A)
(__v4di) __W,
(__mmask8) __U);
_mm256_maskz_cvtps_epu64 (__mmask8 __U, __m128 __A)
(__v4di)
(__mmask8) __U);
_mm_cvtps_epu64 (__m128 __A)
return (__m128i) __builtin_ia32_cvtps2uqq128_mask ((__v4sf) __A,
(__v2di)
(__mmask8) -1);
_mm_mask_cvtps_epu64 (__m128i __W, __mmask8 __U, __m128 __A)
(__v2di) __W,
(__mmask8) __U);
_mm_maskz_cvtps_epu64 (__mmask8 __U, __m128 __A)
(__v2di)
(__mmask8) __U);
_mm256_cvtepi64_ps (__m256i __A)
return (__m128) __builtin_ia32_cvtqq2ps256_mask ((__v4di) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm256_mask_cvtepi64_ps (__m128 __W, __mmask8 __U, __m256i __A)
(__v4sf) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi64_ps (__mmask8 __U, __m256i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_cvtepi64_ps (__m128i __A)
return (__m128) __builtin_ia32_cvtqq2ps128_mask ((__v2di) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_cvtepi64_ps (__m128 __W, __mmask8 __U, __m128i __A)
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_cvtepi64_ps (__mmask8 __U, __m128i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_cvtepu64_ps (__m256i __A)
return (__m128) __builtin_ia32_cvtuqq2ps256_mask ((__v4di) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm256_mask_cvtepu64_ps (__m128 __W, __mmask8 __U, __m256i __A)
(__v4sf) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu64_ps (__mmask8 __U, __m256i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_cvtepu64_ps (__m128i __A)
return (__m128) __builtin_ia32_cvtuqq2ps128_mask ((__v2di) __A,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) -1);
_mm_mask_cvtepu64_ps (__m128 __W, __mmask8 __U, __m128i __A)
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_cvtepu64_ps (__mmask8 __U, __m128i __A)
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_cvtepi64_pd (__m256i __A)
return (__m256d) __builtin_ia32_cvtqq2pd256_mask ((__v4di) __A,
(__v4df)
(__mmask8) -1);
_mm256_mask_cvtepi64_pd (__m256d __W, __mmask8 __U, __m256i __A)
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_cvtepi64_pd (__mmask8 __U, __m256i __A)
(__v4df)
(__mmask8) __U);
_mm_cvtepi64_pd (__m128i __A)
return (__m128d) __builtin_ia32_cvtqq2pd128_mask ((__v2di) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_cvtepi64_pd (__m128d __W, __mmask8 __U, __m128i __A)
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_cvtepi64_pd (__mmask8 __U, __m128i __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_cvtepu64_pd (__m256i __A)
return (__m256d) __builtin_ia32_cvtuqq2pd256_mask ((__v4di) __A,
(__v4df)
(__mmask8) -1);
_mm256_mask_cvtepu64_pd (__m256d __W, __mmask8 __U, __m256i __A)
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_cvtepu64_pd (__mmask8 __U, __m256i __A)
(__v4df)
(__mmask8) __U);
_mm256_mask_and_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_andpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_and_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_and_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_andpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_and_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_and_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_andps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_and_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
_mm256_setzero_ps (),
(__mmask8) __U);
_mm_mask_and_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_andps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_and_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm_cvtepu64_pd (__m128i __A)
return (__m128d) __builtin_ia32_cvtuqq2pd128_mask ((__v2di) __A,
(__v2df)
_mm_setzero_pd (),
(__mmask8) -1);
_mm_mask_cvtepu64_pd (__m128d __W, __mmask8 __U, __m128i __A)
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_cvtepu64_pd (__mmask8 __U, __m128i __A)
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_xor_pd (__m256d __W, __mmask8 __U, __m256d __A,
__m256d __B)
return (__m256d) __builtin_ia32_xorpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_xor_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_xor_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_xorpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_xor_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_xor_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_xorps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_xor_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_mask_xor_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_xorps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_xor_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
_mm256_mask_or_pd (__m256d __W, __mmask8 __U, __m256d __A, __m256d __B)
return (__m256d) __builtin_ia32_orpd256_mask ((__v4df) __A,
(__v4df) __B,
(__v4df) __W,
(__mmask8) __U);
_mm256_maskz_or_pd (__mmask8 __U, __m256d __A, __m256d __B)
(__v4df) __B,
(__v4df)
(__mmask8) __U);
_mm_mask_or_pd (__m128d __W, __mmask8 __U, __m128d __A, __m128d __B)
return (__m128d) __builtin_ia32_orpd128_mask ((__v2df) __A,
(__v2df) __B,
(__v2df) __W,
(__mmask8) __U);
_mm_maskz_or_pd (__mmask8 __U, __m128d __A, __m128d __B)
(__v2df) __B,
(__v2df)
_mm_setzero_pd (),
(__mmask8) __U);
_mm256_mask_or_ps (__m256 __W, __mmask8 __U, __m256 __A, __m256 __B)
return (__m256) __builtin_ia32_orps256_mask ((__v8sf) __A,
(__v8sf) __B,
(__v8sf) __W,
(__mmask8) __U);
_mm256_maskz_or_ps (__mmask8 __U, __m256 __A, __m256 __B)
(__v8sf) __B,
(__v8sf)
(__mmask8) __U);
_mm_mask_or_ps (__m128 __W, __mmask8 __U, __m128 __A, __m128 __B)
return (__m128) __builtin_ia32_orps128_mask ((__v4sf) __A,
(__v4sf) __B,
(__v4sf) __W,
(__mmask8) __U);
_mm_maskz_or_ps (__mmask8 __U, __m128 __A, __m128 __B)
(__v4sf) __B,
(__v4sf)
_mm_setzero_ps (),
(__mmask8) __U);
extern __inline __m128i
_mm_movm_epi32 (__mmask8 __A)
return (__m128i) __builtin_ia32_cvtmask2d128 (__A);
extern __inline __m256i
_mm256_movm_epi32 (__mmask8 __A)
return (__m256i) __builtin_ia32_cvtmask2d256 (__A);
_mm_movm_epi64 (__mmask8 __A)
return (__m128i) __builtin_ia32_cvtmask2q128 (__A);
_mm256_movm_epi64 (__mmask8 __A)
return (__m256i) __builtin_ia32_cvtmask2q256 (__A);
extern __inline __mmask8
_mm_movepi32_mask (__m128i __A)
return (__mmask8) __builtin_ia32_cvtd2mask128 ((__v4si) __A);
_mm256_movepi32_mask (__m256i __A)
return (__mmask8) __builtin_ia32_cvtd2mask256 ((__v8si) __A);
_mm_movepi64_mask (__m128i __A)
return (__mmask8) __builtin_ia32_cvtq2mask128 ((__v2di) __A);
_mm256_movepi64_mask (__m256i __A)
return (__mmask8) __builtin_ia32_cvtq2mask256 ((__v4di) __A);
# 2013 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vldqintrin.h" 3 4
#pragma GCC pop_options
# 62 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512ifmaintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512ifmaintrin.h" 3 4
#pragma GCC push_options
#pragma GCC target("avx512ifma")
extern __inline __m512i
_mm512_madd52lo_epu64 (__m512i __X, __m512i __Y, __m512i __Z)
return (__m512i) __builtin_ia32_vpmadd52luq512_mask ((__v8di) __X,
(__v8di) __Y,
(__v8di) __Z,
(__mmask8) -1);
_mm512_madd52hi_epu64 (__m512i __X, __m512i __Y, __m512i __Z)
return (__m512i) __builtin_ia32_vpmadd52huq512_mask ((__v8di) __X,
(__v8di) __Y,
(__v8di) __Z,
(__mmask8) -1);
_mm512_mask_madd52lo_epu64 (__m512i __W, __mmask8 __M, __m512i __X,
__m512i __Y)
return (__m512i) __builtin_ia32_vpmadd52luq512_mask ((__v8di) __W,
(__v8di) __X,
(__v8di) __Y,
(__mmask8) __M);
_mm512_mask_madd52hi_epu64 (__m512i __W, __mmask8 __M, __m512i __X,
__m512i __Y)
return (__m512i) __builtin_ia32_vpmadd52huq512_mask ((__v8di) __W,
(__v8di) __X,
(__v8di) __Y,
(__mmask8) __M);
_mm512_maskz_madd52lo_epu64 (__mmask8 __M, __m512i __X, __m512i __Y, __m512i __Z)
return (__m512i) __builtin_ia32_vpmadd52luq512_maskz ((__v8di) __X,
(__v8di) __Y,
(__v8di) __Z,
(__mmask8) __M);
_mm512_maskz_madd52hi_epu64 (__mmask8 __M, __m512i __X, __m512i __Y, __m512i __Z)
return (__m512i) __builtin_ia32_vpmadd52huq512_maskz ((__v8di) __X,
(__v8di) __Y,
(__v8di) __Z,
(__mmask8) __M);
# 64 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512ifmavlintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512ifmavlintrin.h" 3 4
#pragma GCC target("avx512ifma,avx512vl")
_mm_madd52lo_epu64 (__m128i __X, __m128i __Y, __m128i __Z)
return (__m128i) __builtin_ia32_vpmadd52luq128_mask ((__v2di) __X,
(__v2di) __Y,
(__v2di) __Z,
(__mmask8) -1);
_mm_madd52hi_epu64 (__m128i __X, __m128i __Y, __m128i __Z)
return (__m128i) __builtin_ia32_vpmadd52huq128_mask ((__v2di) __X,
(__v2di) __Y,
(__v2di) __Z,
(__mmask8) -1);
_mm256_madd52lo_epu64 (__m256i __X, __m256i __Y, __m256i __Z)
return (__m256i) __builtin_ia32_vpmadd52luq256_mask ((__v4di) __X,
(__v4di) __Y,
(__v4di) __Z,
(__mmask8) -1);
_mm256_madd52hi_epu64 (__m256i __X, __m256i __Y, __m256i __Z)
return (__m256i) __builtin_ia32_vpmadd52huq256_mask ((__v4di) __X,
(__v4di) __Y,
(__v4di) __Z,
(__mmask8) -1);
_mm_mask_madd52lo_epu64 (__m128i __W, __mmask8 __M, __m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_vpmadd52luq128_mask ((__v2di) __W,
(__v2di) __X,
(__v2di) __Y,
(__mmask8) __M);
_mm_mask_madd52hi_epu64 (__m128i __W, __mmask8 __M, __m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_vpmadd52huq128_mask ((__v2di) __W,
(__v2di) __X,
(__v2di) __Y,
(__mmask8) __M);
_mm256_mask_madd52lo_epu64 (__m256i __W, __mmask8 __M, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_vpmadd52luq256_mask ((__v4di) __W,
(__v4di) __X,
(__v4di) __Y,
(__mmask8) __M);
_mm256_mask_madd52hi_epu64 (__m256i __W, __mmask8 __M, __m256i __X,
__m256i __Y)
return (__m256i) __builtin_ia32_vpmadd52huq256_mask ((__v4di) __W,
(__v4di) __X,
(__v4di) __Y,
(__mmask8) __M);
_mm_maskz_madd52lo_epu64 (__mmask8 __M, __m128i __X, __m128i __Y, __m128i __Z)
return (__m128i) __builtin_ia32_vpmadd52luq128_maskz ((__v2di) __X,
(__v2di) __Y,
(__v2di) __Z,
(__mmask8) __M);
_mm_maskz_madd52hi_epu64 (__mmask8 __M, __m128i __X, __m128i __Y, __m128i __Z)
return (__m128i) __builtin_ia32_vpmadd52huq128_maskz ((__v2di) __X,
(__v2di) __Y,
(__v2di) __Z,
(__mmask8) __M);
_mm256_maskz_madd52lo_epu64 (__mmask8 __M, __m256i __X, __m256i __Y, __m256i __Z)
return (__m256i) __builtin_ia32_vpmadd52luq256_maskz ((__v4di) __X,
(__v4di) __Y,
(__v4di) __Z,
(__mmask8) __M);
_mm256_maskz_madd52hi_epu64 (__mmask8 __M, __m256i __X, __m256i __Y, __m256i __Z)
return (__m256i) __builtin_ia32_vpmadd52huq256_maskz ((__v4di) __X,
(__v4di) __Y,
(__v4di) __Z,
(__mmask8) __M);
# 66 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmiintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmiintrin.h" 3 4
#pragma GCC target("avx512vbmi")
_mm512_mask_multishift_epi64_epi8 (__m512i __W, __mmask64 __M, __m512i __X, __m512i __Y)
return (__m512i) __builtin_ia32_vpmultishiftqb512_mask ((__v64qi) __X,
(__v64qi) __Y,
(__v64qi) __W,
(__mmask64) __M);
_mm512_maskz_multishift_epi64_epi8 (__mmask64 __M, __m512i __X, __m512i __Y)
(__v64qi) __Y,
(__v64qi)
_mm512_setzero_si512 (),
(__mmask64) __M);
_mm512_multishift_epi64_epi8 (__m512i __X, __m512i __Y)
(__v64qi) __Y,
(__v64qi)
_mm512_undefined_epi32 (),
(__mmask64) -1);
_mm512_permutexvar_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_permvarqi512_mask ((__v64qi) __B,
(__v64qi) __A,
(__v64qi)
(__mmask64) -1);
_mm512_maskz_permutexvar_epi8 (__mmask64 __M, __m512i __A,
__m512i __B)
(__v64qi) __A,
(__v64qi)
_mm512_setzero_si512(),
(__mmask64) __M);
_mm512_mask_permutexvar_epi8 (__m512i __W, __mmask64 __M, __m512i __A,
__m512i __B)
(__v64qi) __A,
(__v64qi) __W,
(__mmask64) __M);
_mm512_permutex2var_epi8 (__m512i __A, __m512i __I, __m512i __B)
return (__m512i) __builtin_ia32_vpermt2varqi512_mask ((__v64qi) __I
(__v64qi) __A,
(__v64qi) __B,
(__mmask64) -1);
_mm512_mask_permutex2var_epi8 (__m512i __A, __mmask64 __U,
(__v64qi) __A,
(__v64qi) __B,
(__mmask64)
__U);
_mm512_mask2_permutex2var_epi8 (__m512i __A, __m512i __I,
__mmask64 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpermi2varqi512_mask ((__v64qi) __A,
(__v64qi) __I
(__v64qi) __B,
(__mmask64)
__U);
_mm512_maskz_permutex2var_epi8 (__mmask64 __U, __m512i __A,
return (__m512i) __builtin_ia32_vpermt2varqi512_maskz ((__v64qi) __I
(__v64qi) __A,
(__v64qi) __B,
(__mmask64)
__U);
# 68 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmivlintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmivlintrin.h" 3 4
#pragma GCC target("avx512vbmi,avx512vl")
_mm256_mask_multishift_epi64_epi8 (__m256i __W, __mmask32 __M, __m256i __X, __m256i __Y)
return (__m256i) __builtin_ia32_vpmultishiftqb256_mask ((__v32qi) __X,
(__v32qi) __Y,
(__v32qi) __W,
(__mmask32) __M);
_mm256_maskz_multishift_epi64_epi8 (__mmask32 __M, __m256i __X, __m256i __Y)
(__v32qi) __Y,
(__v32qi)
(__mmask32) __M);
_mm256_multishift_epi64_epi8 (__m256i __X, __m256i __Y)
(__v32qi) __Y,
(__v32qi)
_mm256_undefined_si256 (),
(__mmask32) -1);
_mm_mask_multishift_epi64_epi8 (__m128i __W, __mmask16 __M, __m128i __X, __m128i __Y)
return (__m128i) __builtin_ia32_vpmultishiftqb128_mask ((__v16qi) __X,
(__v16qi) __Y,
(__v16qi) __W,
(__mmask16) __M);
_mm_maskz_multishift_epi64_epi8 (__mmask16 __M, __m128i __X, __m128i __Y)
(__v16qi) __Y,
(__v16qi)
_mm_setzero_si128 (),
(__mmask16) __M);
_mm_multishift_epi64_epi8 (__m128i __X, __m128i __Y)
(__v16qi) __Y,
(__v16qi)
_mm_undefined_si128 (),
(__mmask16) -1);
_mm256_permutexvar_epi8 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_permvarqi256_mask ((__v32qi) __B,
(__v32qi) __A,
(__v32qi)
(__mmask32) -1);
_mm256_maskz_permutexvar_epi8 (__mmask32 __M, __m256i __A,
__m256i __B)
(__v32qi) __A,
(__v32qi)
(__mmask32) __M);
_mm256_mask_permutexvar_epi8 (__m256i __W, __mmask32 __M, __m256i __A,
__m256i __B)
(__v32qi) __A,
(__v32qi) __W,
(__mmask32) __M);
_mm_permutexvar_epi8 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_permvarqi128_mask ((__v16qi) __B,
(__v16qi) __A,
(__v16qi)
(__mmask16) -1);
_mm_maskz_permutexvar_epi8 (__mmask16 __M, __m128i __A, __m128i __B)
(__v16qi) __A,
(__v16qi)
(__mmask16) __M);
_mm_mask_permutexvar_epi8 (__m128i __W, __mmask16 __M, __m128i __A,
__m128i __B)
(__v16qi) __A,
(__v16qi) __W,
(__mmask16) __M);
_mm256_permutex2var_epi8 (__m256i __A, __m256i __I, __m256i __B)
return (__m256i) __builtin_ia32_vpermt2varqi256_mask ((__v32qi) __I
(__v32qi) __A,
(__v32qi) __B,
(__mmask32) -1);
_mm256_mask_permutex2var_epi8 (__m256i __A, __mmask32 __U,
(__v32qi) __A,
(__v32qi) __B,
(__mmask32)
__U);
_mm256_mask2_permutex2var_epi8 (__m256i __A, __m256i __I,
__mmask32 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpermi2varqi256_mask ((__v32qi) __A,
(__v32qi) __I
(__v32qi) __B,
(__mmask32)
__U);
_mm256_maskz_permutex2var_epi8 (__mmask32 __U, __m256i __A,
return (__m256i) __builtin_ia32_vpermt2varqi256_maskz ((__v32qi) __I
(__v32qi) __A,
(__v32qi) __B,
(__mmask32)
__U);
_mm_permutex2var_epi8 (__m128i __A, __m128i __I, __m128i __B)
return (__m128i) __builtin_ia32_vpermt2varqi128_mask ((__v16qi) __I
(__v16qi) __A,
(__v16qi) __B,
(__mmask16) -1);
_mm_mask_permutex2var_epi8 (__m128i __A, __mmask16 __U, __m128i __I,
__m128i __B)
(__v16qi) __A,
(__v16qi) __B,
(__mmask16)
__U);
_mm_mask2_permutex2var_epi8 (__m128i __A, __m128i __I, __mmask16 __U,
__m128i __B)
return (__m128i) __builtin_ia32_vpermi2varqi128_mask ((__v16qi) __A,
(__v16qi) __I
(__v16qi) __B,
(__mmask16)
__U);
_mm_maskz_permutex2var_epi8 (__mmask16 __U, __m128i __A, __m128i __I,
__m128i __B)
return (__m128i) __builtin_ia32_vpermt2varqi128_maskz ((__v16qi) __I
(__v16qi) __A,
(__v16qi) __B,
(__mmask16)
__U);
# 70 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx5124fmapsintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx5124fmapsintrin.h" 3 4
#pragma GCC target("avx5124fmaps")
__attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm512_4fmadd_ps (__m512 __A, __m512 __B, __m512 __C,
__m512 __D, __m512 __E, __m128 *__F)
return (__m512) __builtin_ia32_4fmaddps ((__v16sf) __B,
(__v16sf) __C,
(__v16sf) __D,
(__v16sf) __E,
(__v16sf) __A,
(const __v4sf *) __F);
_mm512_mask_4fmadd_ps (__m512 __A, __mmask16 __U, __m512 __B,
__m512 __C, __m512 __D, __m512 __E, __m128 *__F)
return (__m512) __builtin_ia32_4fmaddps_mask ((__v16sf) __B,
(__v16sf) __C,
(__v16sf) __D,
(__v16sf) __E,
(__v16sf) __A,
(const __v4sf *) __F,
(__v16sf) __A,
(__mmask16) __U);
_mm512_maskz_4fmadd_ps (__mmask16 __U,
(__v16sf) __C,
(__v16sf) __D,
(__v16sf) __E,
(__v16sf) __A,
(__v16sf) _mm512_setzero_ps (),
(__mmask16) __U);
_mm_4fmadd_ss (__m128 __A, __m128 __B, __m128 __C,
__m128 __D, __m128 __E, __m128 *__F)
return (__m128) __builtin_ia32_4fmaddss ((__v4sf) __B,
(__v4sf) __C,
(__v4sf) __D,
(__v4sf) __E,
(__v4sf) __A,
_mm_mask_4fmadd_ss (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C,
return (__m128) __builtin_ia32_4fmaddss_mask ((__v4sf) __B,
(__v4sf) __C,
(__v4sf) __D,
(__v4sf) __E,
(__v4sf) __A,
(__v4sf) __A,
(__mmask8) __U);
_mm_maskz_4fmadd_ss (__mmask8 __U, __m128 __A, __m128 __B, __m128 __C,
(__v4sf) __C,
(__v4sf) __D,
(__v4sf) __E,
(__v4sf) __A,
(__v4sf) _mm_setzero_ps (),
(__mmask8) __U);
_mm512_4fnmadd_ps (__m512 __A, __m512 __B, __m512 __C,
return (__m512) __builtin_ia32_4fnmaddps ((__v16sf) __B,
(__v16sf) __C,
(__v16sf) __D,
(__v16sf) __E,
(__v16sf) __A,
_mm512_mask_4fnmadd_ps (__m512 __A, __mmask16 __U, __m512 __B,
return (__m512) __builtin_ia32_4fnmaddps_mask ((__v16sf) __B,
(__v16sf) __C,
(__v16sf) __D,
(__v16sf) __E,
(__v16sf) __A,
(__v16sf) __A,
(__mmask16) __U);
_mm512_maskz_4fnmadd_ps (__mmask16 __U,
(__v16sf) __C,
(__v16sf) __D,
(__v16sf) __E,
(__v16sf) __A,
(__mmask16) __U);
_mm_4fnmadd_ss (__m128 __A, __m128 __B, __m128 __C,
return (__m128) __builtin_ia32_4fnmaddss ((__v4sf) __B,
(__v4sf) __C,
(__v4sf) __D,
(__v4sf) __E,
(__v4sf) __A,
_mm_mask_4fnmadd_ss (__m128 __A, __mmask8 __U, __m128 __B, __m128 __C,
return (__m128) __builtin_ia32_4fnmaddss_mask ((__v4sf) __B,
(__v4sf) __C,
(__v4sf) __D,
(__v4sf) __E,
(__v4sf) __A,
(__v4sf) __A,
(__mmask8) __U);
_mm_maskz_4fnmadd_ss (__mmask8 __U, __m128 __A, __m128 __B, __m128 __C,
(__v4sf) __C,
(__v4sf) __D,
(__v4sf) __E,
(__v4sf) __A,
(__mmask8) __U);
# 72 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx5124vnniwintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx5124vnniwintrin.h" 3 4
#pragma GCC target("avx5124vnniw")
_mm512_4dpwssd_epi32 (__m512i __A, __m512i __B, __m512i __C,
__m512i __D, __m512i __E, __m128i *__F)
return (__m512i) __builtin_ia32_vp4dpwssd ((__v16si) __B,
(__v16si) __C,
(__v16si) __D,
(__v16si) __E,
(__v16si) __A,
(const __v4si *) __F);
_mm512_mask_4dpwssd_epi32 (__m512i __A, __mmask16 __U, __m512i __B,
__m512i __C, __m512i __D, __m512i __E,
__m128i *__F)
return (__m512i) __builtin_ia32_vp4dpwssd_mask ((__v16si) __B,
(__v16si) __C,
(__v16si) __D,
(__v16si) __E,
(__v16si) __A,
(const __v4si *) __F,
(__v16si) __A,
(__mmask16) __U);
_mm512_maskz_4dpwssd_epi32 (__mmask16 __U, __m512i __A, __m512i __B,
__m128i *__F)
(__v16si) __C,
(__v16si) __D,
(__v16si) __E,
(__v16si) __A,
(__v16si) _mm512_setzero_ps (),
(__mmask16) __U);
_mm512_4dpwssds_epi32 (__m512i __A, __m512i __B, __m512i __C,
return (__m512i) __builtin_ia32_vp4dpwssds ((__v16si) __B,
(__v16si) __C,
(__v16si) __D,
(__v16si) __E,
(__v16si) __A,
_mm512_mask_4dpwssds_epi32 (__m512i __A, __mmask16 __U, __m512i __B,
__m128i *__F)
return (__m512i) __builtin_ia32_vp4dpwssds_mask ((__v16si) __B,
(__v16si) __C,
(__v16si) __D,
(__v16si) __E,
(__v16si) __A,
(__v16si) __A,
(__mmask16) __U);
_mm512_maskz_4dpwssds_epi32 (__mmask16 __U, __m512i __A, __m512i __B,
__m128i *__F)
(__v16si) __C,
(__v16si) __D,
(__v16si) __E,
(__v16si) __A,
(__mmask16) __U);
# 74 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vpopcntdqintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vpopcntdqintrin.h" 3 4
#pragma GCC target("avx512vpopcntdq")
_mm512_popcnt_epi32 (__m512i __A)
return (__m512i) __builtin_ia32_vpopcountd_v16si ((__v16si) __A);
_mm512_mask_popcnt_epi32 (__m512i __A, __mmask16 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpopcountd_v16si_mask ((__v16si) __A,
(__v16si) __B,
(__mmask16) __U);
_mm512_maskz_popcnt_epi32 (__mmask16 __U, __m512i __A)
(__v16si)
(__mmask16) __U);
_mm512_popcnt_epi64 (__m512i __A)
return (__m512i) __builtin_ia32_vpopcountq_v8di ((__v8di) __A);
_mm512_mask_popcnt_epi64 (__m512i __A, __mmask8 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpopcountq_v8di_mask ((__v8di) __A,
(__v8di) __B,
(__mmask8) __U);
_mm512_maskz_popcnt_epi64 (__mmask8 __U, __m512i __A)
(__v8di)
(__mmask8) __U);
# 76 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2intrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2intrin.h" 3 4
#pragma GCC target("avx512vbmi2")
# 200 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2intrin.h" 3 4
_mm512_shrdv_epi16 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpshrdv_v32hi ((__v32hi)__A, (__v32hi) __B,
(__v32hi) __C);
_mm512_shrdv_epi32 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpshrdv_v16si ((__v16si)__A, (__v16si) __B,
(__v16si) __C);
_mm512_mask_shrdv_epi32 (__m512i __A, __mmask16 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshrdv_v16si_mask ((__v16si)__A,
(__v16si) __C, (__v16si) __D, (__mmask16)__B);
_mm512_maskz_shrdv_epi32 (__mmask16 __A, __m512i __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshrdv_v16si_maskz ((__v16si)__B,
(__v16si) __C, (__v16si) __D, (__mmask16)__A);
_mm512_shrdv_epi64 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpshrdv_v8di ((__v8di)__A, (__v8di) __B,
(__v8di) __C);
_mm512_mask_shrdv_epi64 (__m512i __A, __mmask8 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshrdv_v8di_mask ((__v8di)__A, (__v8di) __C,
(__v8di) __D, (__mmask8)__B);
_mm512_maskz_shrdv_epi64 (__mmask8 __A, __m512i __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshrdv_v8di_maskz ((__v8di)__B, (__v8di) __C,
(__v8di) __D, (__mmask8)__A);
_mm512_shldv_epi16 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpshldv_v32hi ((__v32hi)__A, (__v32hi) __B,
(__v32hi) __C);
_mm512_shldv_epi32 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpshldv_v16si ((__v16si)__A, (__v16si) __B,
(__v16si) __C);
_mm512_mask_shldv_epi32 (__m512i __A, __mmask16 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshldv_v16si_mask ((__v16si)__A,
_mm512_maskz_shldv_epi32 (__mmask16 __A, __m512i __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshldv_v16si_maskz ((__v16si)__B,
_mm512_shldv_epi64 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpshldv_v8di ((__v8di)__A, (__v8di) __B,
(__v8di) __C);
_mm512_mask_shldv_epi64 (__m512i __A, __mmask8 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshldv_v8di_mask ((__v8di)__A, (__v8di) __C,
_mm512_maskz_shldv_epi64 (__mmask8 __A, __m512i __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshldv_v8di_maskz ((__v8di)__B, (__v8di) __C,
#pragma GCC target("avx512vbmi2,avx512bw")
_mm512_mask_compress_epi8 (__m512i __A, __mmask64 __B, __m512i __C)
return (__m512i) __builtin_ia32_compressqi512_mask ((__v64qi)__C,
(__v64qi)__A, (__mmask64)__B);
_mm512_maskz_compress_epi8 (__mmask64 __A, __m512i __B)
return (__m512i) __builtin_ia32_compressqi512_mask ((__v64qi)__B,
(__v64qi)_mm512_setzero_si512 (), (__mmask64)__A);
extern __inline void
_mm512_mask_compressstoreu_epi8 (void * __A, __mmask64 __B, __m512i __C)
__builtin_ia32_compressstoreuqi512_mask ((__v64qi *) __A, (__v64qi) __C,
(__mmask64) __B);
_mm512_mask_compress_epi16 (__m512i __A, __mmask32 __B, __m512i __C)
return (__m512i) __builtin_ia32_compresshi512_mask ((__v32hi)__C,
(__v32hi)__A, (__mmask32)__B);
_mm512_maskz_compress_epi16 (__mmask32 __A, __m512i __B)
return (__m512i) __builtin_ia32_compresshi512_mask ((__v32hi)__B,
(__v32hi)_mm512_setzero_si512 (), (__mmask32)__A);
_mm512_mask_compressstoreu_epi16 (void * __A, __mmask32 __B, __m512i __C)
__builtin_ia32_compressstoreuhi512_mask ((__v32hi *) __A, (__v32hi) __C,
(__mmask32) __B);
_mm512_mask_expand_epi8 (__m512i __A, __mmask64 __B, __m512i __C)
return (__m512i) __builtin_ia32_expandqi512_mask ((__v64qi) __C,
(__v64qi) __A,
(__mmask64) __B);
_mm512_maskz_expand_epi8 (__mmask64 __A, __m512i __B)
return (__m512i) __builtin_ia32_expandqi512_maskz ((__v64qi) __B,
(__v64qi) _mm512_setzero_si512 (), (__mmask64) __A);
_mm512_mask_expandloadu_epi8 (__m512i __A, __mmask64 __B, const void * __C)
return (__m512i) __builtin_ia32_expandloadqi512_mask ((const __v64qi *) __C,
(__v64qi) __A, (__mmask64) __B);
_mm512_maskz_expandloadu_epi8 (__mmask64 __A, const void * __B)
return (__m512i) __builtin_ia32_expandloadqi512_maskz ((const __v64qi *) __B,
_mm512_mask_expand_epi16 (__m512i __A, __mmask32 __B, __m512i __C)
return (__m512i) __builtin_ia32_expandhi512_mask ((__v32hi) __C,
(__v32hi) __A,
(__mmask32) __B);
_mm512_maskz_expand_epi16 (__mmask32 __A, __m512i __B)
return (__m512i) __builtin_ia32_expandhi512_maskz ((__v32hi) __B,
(__v32hi) _mm512_setzero_si512 (), (__mmask32) __A);
_mm512_mask_expandloadu_epi16 (__m512i __A, __mmask32 __B, const void * __C)
return (__m512i) __builtin_ia32_expandloadhi512_mask ((const __v32hi *) __C,
(__v32hi) __A, (__mmask32) __B);
_mm512_maskz_expandloadu_epi16 (__mmask32 __A, const void * __B)
return (__m512i) __builtin_ia32_expandloadhi512_maskz ((const __v32hi *) __B,
# 491 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2intrin.h" 3 4
_mm512_mask_shrdv_epi16 (__m512i __A, __mmask32 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshrdv_v32hi_mask ((__v32hi)__A,
(__v32hi) __C, (__v32hi) __D, (__mmask32)__B);
_mm512_maskz_shrdv_epi16 (__mmask32 __A, __m512i __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshrdv_v32hi_maskz ((__v32hi)__B,
(__v32hi) __C, (__v32hi) __D, (__mmask32)__A);
_mm512_mask_shldv_epi16 (__m512i __A, __mmask32 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshldv_v32hi_mask ((__v32hi)__A,
_mm512_maskz_shldv_epi16 (__mmask32 __A, __m512i __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpshldv_v32hi_maskz ((__v32hi)__B,
# 78 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2vlintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2vlintrin.h" 3 4
#pragma GCC target("avx512vbmi2,avx512vl")
_mm_mask_compress_epi8 (__m128i __A, __mmask16 __B, __m128i __C)
return (__m128i) __builtin_ia32_compressqi128_mask ((__v16qi)__C,
(__v16qi)__A, (__mmask16)__B);
_mm_maskz_compress_epi8 (__mmask16 __A, __m128i __B)
return (__m128i) __builtin_ia32_compressqi128_mask ((__v16qi) __B,
(__v16qi) _mm_setzero_si128 (), (__mmask16) __A);
_mm256_mask_compressstoreu_epi16 (void * __A, __mmask16 __B, __m256i __C)
__builtin_ia32_compressstoreuhi256_mask ((__v16hi *) __A, (__v16hi) __C,
(__mmask16) __B);
_mm_mask_compress_epi16 (__m128i __A, __mmask8 __B, __m128i __C)
return (__m128i) __builtin_ia32_compresshi128_mask ((__v8hi)__C, (__v8hi)__A,
(__mmask8)__B);
_mm_maskz_compress_epi16 (__mmask8 __A, __m128i __B)
return (__m128i) __builtin_ia32_compresshi128_mask ((__v8hi) __B,
(__v8hi) _mm_setzero_si128 (), (__mmask8) __A);
_mm256_mask_compress_epi16 (__m256i __A, __mmask16 __B, __m256i __C)
return (__m256i) __builtin_ia32_compresshi256_mask ((__v16hi)__C,
(__v16hi)__A, (__mmask16)__B);
_mm256_maskz_compress_epi16 (__mmask16 __A, __m256i __B)
return (__m256i) __builtin_ia32_compresshi256_mask ((__v16hi) __B,
(__v16hi) _mm256_setzero_si256 (), (__mmask16) __A);
_mm_mask_compressstoreu_epi8 (void * __A, __mmask16 __B, __m128i __C)
__builtin_ia32_compressstoreuqi128_mask ((__v16qi *) __A, (__v16qi) __C,
(__mmask16) __B);
_mm_mask_compressstoreu_epi16 (void * __A, __mmask8 __B, __m128i __C)
__builtin_ia32_compressstoreuhi128_mask ((__v8hi *) __A, (__v8hi) __C,
(__mmask8) __B);
_mm_mask_expand_epi8 (__m128i __A, __mmask16 __B, __m128i __C)
return (__m128i) __builtin_ia32_expandqi128_mask ((__v16qi) __C,
(__v16qi) __A,
(__mmask16) __B);
_mm_maskz_expand_epi8 (__mmask16 __A, __m128i __B)
return (__m128i) __builtin_ia32_expandqi128_maskz ((__v16qi) __B,
_mm_mask_expandloadu_epi8 (__m128i __A, __mmask16 __B, const void * __C)
return (__m128i) __builtin_ia32_expandloadqi128_mask ((const __v16qi *) __C,
(__v16qi) __A, (__mmask16) __B);
_mm_maskz_expandloadu_epi8 (__mmask16 __A, const void * __B)
return (__m128i) __builtin_ia32_expandloadqi128_maskz ((const __v16qi *) __B,
_mm_mask_expand_epi16 (__m128i __A, __mmask8 __B, __m128i __C)
return (__m128i) __builtin_ia32_expandhi128_mask ((__v8hi) __C,
(__v8hi) __A,
(__mmask8) __B);
_mm_maskz_expand_epi16 (__mmask8 __A, __m128i __B)
return (__m128i) __builtin_ia32_expandhi128_maskz ((__v8hi) __B,
_mm_mask_expandloadu_epi16 (__m128i __A, __mmask8 __B, const void * __C)
return (__m128i) __builtin_ia32_expandloadhi128_mask ((const __v8hi *) __C,
(__v8hi) __A, (__mmask8) __B);
_mm_maskz_expandloadu_epi16 (__mmask8 __A, const void * __B)
return (__m128i) __builtin_ia32_expandloadhi128_maskz ((const __v8hi *) __B,
_mm256_mask_expand_epi16 (__m256i __A, __mmask16 __B, __m256i __C)
return (__m256i) __builtin_ia32_expandhi256_mask ((__v16hi) __C,
(__v16hi) __A,
(__mmask16) __B);
_mm256_maskz_expand_epi16 (__mmask16 __A, __m256i __B)
return (__m256i) __builtin_ia32_expandhi256_maskz ((__v16hi) __B,
_mm256_mask_expandloadu_epi16 (__m256i __A, __mmask16 __B, const void * __C)
return (__m256i) __builtin_ia32_expandloadhi256_mask ((const __v16hi *) __C,
(__v16hi) __A, (__mmask16) __B);
_mm256_maskz_expandloadu_epi16 (__mmask16 __A, const void * __B)
return (__m256i) __builtin_ia32_expandloadhi256_maskz ((const __v16hi *) __B,
# 621 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vbmi2vlintrin.h" 3 4
_mm256_shrdv_epi16 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpshrdv_v16hi ((__v16hi)__A, (__v16hi) __B,
(__v16hi) __C);
_mm256_mask_shrdv_epi16 (__m256i __A, __mmask16 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshrdv_v16hi_mask ((__v16hi)__A,
(__v16hi) __C, (__v16hi) __D, (__mmask16)__B);
_mm256_maskz_shrdv_epi16 (__mmask16 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshrdv_v16hi_maskz ((__v16hi)__B,
(__v16hi) __C, (__v16hi) __D, (__mmask16)__A);
_mm256_shrdv_epi32 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpshrdv_v8si ((__v8si)__A, (__v8si) __B,
(__v8si) __C);
_mm256_mask_shrdv_epi32 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshrdv_v8si_mask ((__v8si)__A, (__v8si) __C,
(__v8si) __D, (__mmask8)__B);
_mm256_maskz_shrdv_epi32 (__mmask8 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshrdv_v8si_maskz ((__v8si)__B, (__v8si) __C,
(__v8si) __D, (__mmask8)__A);
_mm256_shrdv_epi64 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpshrdv_v4di ((__v4di)__A, (__v4di) __B,
(__v4di) __C);
_mm256_mask_shrdv_epi64 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshrdv_v4di_mask ((__v4di)__A, (__v4di) __C,
(__v4di) __D, (__mmask8)__B);
_mm256_maskz_shrdv_epi64 (__mmask8 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshrdv_v4di_maskz ((__v4di)__B, (__v4di) __C,
(__v4di) __D, (__mmask8)__A);
_mm_shrdv_epi16 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpshrdv_v8hi ((__v8hi)__A, (__v8hi) __B,
(__v8hi) __C);
_mm_mask_shrdv_epi16 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshrdv_v8hi_mask ((__v8hi)__A, (__v8hi) __C,
(__v8hi) __D, (__mmask8)__B);
_mm_maskz_shrdv_epi16 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshrdv_v8hi_maskz ((__v8hi)__B, (__v8hi) __C,
(__v8hi) __D, (__mmask8)__A);
_mm_shrdv_epi32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpshrdv_v4si ((__v4si)__A, (__v4si) __B,
(__v4si) __C);
_mm_mask_shrdv_epi32 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshrdv_v4si_mask ((__v4si)__A, (__v4si) __C,
(__v4si) __D, (__mmask8)__B);
_mm_maskz_shrdv_epi32 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshrdv_v4si_maskz ((__v4si)__B, (__v4si) __C,
(__v4si) __D, (__mmask8)__A);
_mm_shrdv_epi64 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpshrdv_v2di ((__v2di)__A, (__v2di) __B,
(__v2di) __C);
_mm_mask_shrdv_epi64 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshrdv_v2di_mask ((__v2di)__A, (__v2di) __C,
(__v2di) __D, (__mmask8)__B);
_mm_maskz_shrdv_epi64 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshrdv_v2di_maskz ((__v2di)__B, (__v2di) __C,
(__v2di) __D, (__mmask8)__A);
_mm256_shldv_epi16 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpshldv_v16hi ((__v16hi)__A, (__v16hi) __B,
(__v16hi) __C);
_mm256_mask_shldv_epi16 (__m256i __A, __mmask16 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshldv_v16hi_mask ((__v16hi)__A,
_mm256_maskz_shldv_epi16 (__mmask16 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshldv_v16hi_maskz ((__v16hi)__B,
_mm256_shldv_epi32 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpshldv_v8si ((__v8si)__A, (__v8si) __B,
(__v8si) __C);
_mm256_mask_shldv_epi32 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshldv_v8si_mask ((__v8si)__A, (__v8si) __C,
(__v8si) __D, (__mmask8)__B) ;
_mm256_maskz_shldv_epi32 (__mmask8 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshldv_v8si_maskz ((__v8si)__B, (__v8si) __C,
_mm256_shldv_epi64 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpshldv_v4di ((__v4di)__A, (__v4di) __B,
(__v4di) __C);
_mm256_mask_shldv_epi64 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshldv_v4di_mask ((__v4di)__A, (__v4di) __C,
_mm256_maskz_shldv_epi64 (__mmask8 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpshldv_v4di_maskz ((__v4di)__B, (__v4di) __C,
_mm_shldv_epi16 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpshldv_v8hi ((__v8hi)__A, (__v8hi) __B,
(__v8hi) __C);
_mm_mask_shldv_epi16 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshldv_v8hi_mask ((__v8hi)__A, (__v8hi) __C,
_mm_maskz_shldv_epi16 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshldv_v8hi_maskz ((__v8hi)__B, (__v8hi) __C,
_mm_shldv_epi32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpshldv_v4si ((__v4si)__A, (__v4si) __B,
(__v4si) __C);
_mm_mask_shldv_epi32 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshldv_v4si_mask ((__v4si)__A, (__v4si) __C,
_mm_maskz_shldv_epi32 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshldv_v4si_maskz ((__v4si)__B, (__v4si) __C,
_mm_shldv_epi64 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpshldv_v2di ((__v2di)__A, (__v2di) __B,
(__v2di) __C);
_mm_mask_shldv_epi64 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshldv_v2di_mask ((__v2di)__A, (__v2di) __C,
_mm_maskz_shldv_epi64 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpshldv_v2di_maskz ((__v2di)__B, (__v2di) __C,
#pragma GCC target("avx512vbmi2,avx512vl,avx512bw")
_mm256_mask_compress_epi8 (__m256i __A, __mmask32 __B, __m256i __C)
return (__m256i) __builtin_ia32_compressqi256_mask ((__v32qi)__C,
(__v32qi)__A, (__mmask32)__B);
_mm256_maskz_compress_epi8 (__mmask32 __A, __m256i __B)
return (__m256i) __builtin_ia32_compressqi256_mask ((__v32qi) __B,
(__v32qi) _mm256_setzero_si256 (), (__mmask32) __A);
_mm256_mask_compressstoreu_epi8 (void * __A, __mmask32 __B, __m256i __C)
__builtin_ia32_compressstoreuqi256_mask ((__v32qi *) __A, (__v32qi) __C,
(__mmask32) __B);
_mm256_mask_expand_epi8 (__m256i __A, __mmask32 __B, __m256i __C)
return (__m256i) __builtin_ia32_expandqi256_mask ((__v32qi) __C,
(__v32qi) __A,
(__mmask32) __B);
_mm256_maskz_expand_epi8 (__mmask32 __A, __m256i __B)
return (__m256i) __builtin_ia32_expandqi256_maskz ((__v32qi) __B,
_mm256_mask_expandloadu_epi8 (__m256i __A, __mmask32 __B, const void * __C)
return (__m256i) __builtin_ia32_expandloadqi256_mask ((const __v32qi *) __C,
(__v32qi) __A, (__mmask32) __B);
_mm256_maskz_expandloadu_epi8 (__mmask32 __A, const void * __B)
return (__m256i) __builtin_ia32_expandloadqi256_maskz ((const __v32qi *) __B,
# 80 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vnniintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vnniintrin.h" 3 4
#pragma GCC target("avx512vnni")
_mm512_dpbusd_epi32 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpdpbusd_v16si ((__v16si)__A, (__v16si) __B,
(__v16si) __C);
_mm512_mask_dpbusd_epi32 (__m512i __A, __mmask16 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpdpbusd_v16si_mask ((__v16si)__A,
_mm512_maskz_dpbusd_epi32 (__mmask16 __A, __m512i __B, __m512i __C,
__m512i __D)
return (__m512i)__builtin_ia32_vpdpbusd_v16si_maskz ((__v16si)__B,
_mm512_dpbusds_epi32 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpdpbusds_v16si ((__v16si)__A, (__v16si) __B,
(__v16si) __C);
_mm512_mask_dpbusds_epi32 (__m512i __A, __mmask16 __B, __m512i __C,
__m512i __D)
return (__m512i)__builtin_ia32_vpdpbusds_v16si_mask ((__v16si)__A,
_mm512_maskz_dpbusds_epi32 (__mmask16 __A, __m512i __B, __m512i __C,
__m512i __D)
return (__m512i)__builtin_ia32_vpdpbusds_v16si_maskz ((__v16si)__B,
_mm512_dpwssd_epi32 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpdpwssd_v16si ((__v16si)__A, (__v16si) __B,
(__v16si) __C);
_mm512_mask_dpwssd_epi32 (__m512i __A, __mmask16 __B, __m512i __C, __m512i __D)
return (__m512i)__builtin_ia32_vpdpwssd_v16si_mask ((__v16si)__A,
_mm512_maskz_dpwssd_epi32 (__mmask16 __A, __m512i __B, __m512i __C,
__m512i __D)
return (__m512i)__builtin_ia32_vpdpwssd_v16si_maskz ((__v16si)__B,
_mm512_dpwssds_epi32 (__m512i __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vpdpwssds_v16si ((__v16si)__A, (__v16si) __B,
(__v16si) __C);
_mm512_mask_dpwssds_epi32 (__m512i __A, __mmask16 __B, __m512i __C,
__m512i __D)
return (__m512i)__builtin_ia32_vpdpwssds_v16si_mask ((__v16si)__A,
_mm512_maskz_dpwssds_epi32 (__mmask16 __A, __m512i __B, __m512i __C,
__m512i __D)
return (__m512i)__builtin_ia32_vpdpwssds_v16si_maskz ((__v16si)__B,
# 82 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vnnivlintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vnnivlintrin.h" 3 4
#pragma GCC target("avx512vnni,avx512vl")
_mm256_dpbusd_epi32 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpdpbusd_v8si ((__v8si)__A, (__v8si) __B,
(__v8si) __C);
_mm256_mask_dpbusd_epi32 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpdpbusd_v8si_mask ((__v8si)__A, (__v8si) __C,
_mm256_maskz_dpbusd_epi32 (__mmask8 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpdpbusd_v8si_maskz ((__v8si)__B,
(__v8si) __C, (__v8si) __D, (__mmask8)__A);
_mm_dpbusd_epi32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpdpbusd_v4si ((__v4si)__A, (__v4si) __B,
(__v4si) __C);
_mm_mask_dpbusd_epi32 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpbusd_v4si_mask ((__v4si)__A, (__v4si) __C,
_mm_maskz_dpbusd_epi32 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpbusd_v4si_maskz ((__v4si)__B,
(__v4si) __C, (__v4si) __D, (__mmask8)__A);
_mm256_dpbusds_epi32 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpdpbusds_v8si ((__v8si)__A, (__v8si) __B,
(__v8si) __C);
_mm256_mask_dpbusds_epi32 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpdpbusds_v8si_mask ((__v8si)__A,
(__v8si) __C, (__v8si) __D, (__mmask8)__B);
_mm256_maskz_dpbusds_epi32 (__mmask8 __A, __m256i __B, __m256i __C,
__m256i __D)
return (__m256i)__builtin_ia32_vpdpbusds_v8si_maskz ((__v8si)__B,
_mm_dpbusds_epi32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpdpbusds_v4si ((__v4si)__A, (__v4si) __B,
(__v4si) __C);
_mm_mask_dpbusds_epi32 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpbusds_v4si_mask ((__v4si)__A,
(__v4si) __C, (__v4si) __D, (__mmask8)__B);
_mm_maskz_dpbusds_epi32 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpbusds_v4si_maskz ((__v4si)__B,
_mm256_dpwssd_epi32 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpdpwssd_v8si ((__v8si)__A, (__v8si) __B,
(__v8si) __C);
_mm256_mask_dpwssd_epi32 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpdpwssd_v8si_mask ((__v8si)__A, (__v8si) __C,
_mm256_maskz_dpwssd_epi32 (__mmask8 __A, __m256i __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpdpwssd_v8si_maskz ((__v8si)__B,
_mm_dpwssd_epi32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpdpwssd_v4si ((__v4si)__A, (__v4si) __B,
(__v4si) __C);
_mm_mask_dpwssd_epi32 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpwssd_v4si_mask ((__v4si)__A, (__v4si) __C,
_mm_maskz_dpwssd_epi32 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpwssd_v4si_maskz ((__v4si)__B,
_mm256_dpwssds_epi32 (__m256i __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vpdpwssds_v8si ((__v8si)__A, (__v8si) __B,
(__v8si) __C);
_mm256_mask_dpwssds_epi32 (__m256i __A, __mmask8 __B, __m256i __C, __m256i __D)
return (__m256i)__builtin_ia32_vpdpwssds_v8si_mask ((__v8si)__A,
_mm256_maskz_dpwssds_epi32 (__mmask8 __A, __m256i __B, __m256i __C,
__m256i __D)
return (__m256i)__builtin_ia32_vpdpwssds_v8si_maskz ((__v8si)__B,
_mm_dpwssds_epi32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vpdpwssds_v4si ((__v4si)__A, (__v4si) __B,
(__v4si) __C);
_mm_mask_dpwssds_epi32 (__m128i __A, __mmask8 __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpwssds_v4si_mask ((__v4si)__A,
_mm_maskz_dpwssds_epi32 (__mmask8 __A, __m128i __B, __m128i __C, __m128i __D)
return (__m128i)__builtin_ia32_vpdpwssds_v4si_maskz ((__v4si)__B,
# 84 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vpopcntdqvlintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512vpopcntdqvlintrin.h" 3 4
#pragma GCC target("avx512vpopcntdq,avx512vl")
_mm_popcnt_epi32 (__m128i __A)
return (__m128i) __builtin_ia32_vpopcountd_v4si ((__v4si) __A);
_mm_mask_popcnt_epi32 (__m128i __A, __mmask16 __U, __m128i __B)
return (__m128i) __builtin_ia32_vpopcountd_v4si_mask ((__v4si) __A,
(__v4si) __B,
(__mmask16) __U);
_mm_maskz_popcnt_epi32 (__mmask16 __U, __m128i __A)
(__v4si)
(__mmask16) __U);
_mm256_popcnt_epi32 (__m256i __A)
return (__m256i) __builtin_ia32_vpopcountd_v8si ((__v8si) __A);
_mm256_mask_popcnt_epi32 (__m256i __A, __mmask16 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpopcountd_v8si_mask ((__v8si) __A,
(__v8si) __B,
(__mmask16) __U);
_mm256_maskz_popcnt_epi32 (__mmask16 __U, __m256i __A)
(__v8si)
(__mmask16) __U);
_mm_popcnt_epi64 (__m128i __A)
return (__m128i) __builtin_ia32_vpopcountq_v2di ((__v2di) __A);
_mm_mask_popcnt_epi64 (__m128i __A, __mmask8 __U, __m128i __B)
return (__m128i) __builtin_ia32_vpopcountq_v2di_mask ((__v2di) __A,
(__v2di) __B,
(__mmask8) __U);
_mm_maskz_popcnt_epi64 (__mmask8 __U, __m128i __A)
(__v2di)
(__mmask8) __U);
_mm256_popcnt_epi64 (__m256i __A)
return (__m256i) __builtin_ia32_vpopcountq_v4di ((__v4di) __A);
_mm256_mask_popcnt_epi64 (__m256i __A, __mmask8 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpopcountq_v4di_mask ((__v4di) __A,
(__v4di) __B,
(__mmask8) __U);
_mm256_maskz_popcnt_epi64 (__mmask8 __U, __m256i __A)
(__v4di)
(__mmask8) __U);
# 86 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512bitalgintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/avx512bitalgintrin.h" 3 4
#pragma GCC target("avx512bitalg")
_mm512_popcnt_epi8 (__m512i __A)
return (__m512i) __builtin_ia32_vpopcountb_v64qi ((__v64qi) __A);
_mm512_popcnt_epi16 (__m512i __A)
return (__m512i) __builtin_ia32_vpopcountw_v32hi ((__v32hi) __A);
#pragma GCC target("avx512bitalg,avx512bw")
_mm512_mask_popcnt_epi8 (__m512i __A, __mmask64 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpopcountb_v64qi_mask ((__v64qi) __A,
(__v64qi) __B,
(__mmask64) __U);
_mm512_maskz_popcnt_epi8 (__mmask64 __U, __m512i __A)
(__v64qi)
(__mmask64) __U);
_mm512_mask_popcnt_epi16 (__m512i __A, __mmask32 __U, __m512i __B)
return (__m512i) __builtin_ia32_vpopcountw_v32hi_mask ((__v32hi) __A,
(__v32hi) __B,
(__mmask32) __U);
_mm512_maskz_popcnt_epi16 (__mmask32 __U, __m512i __A)
(__v32hi)
(__mmask32) __U);
extern __inline __mmask64
_mm512_bitshuffle_epi64_mask (__m512i __A, __m512i __B)
return (__mmask64) __builtin_ia32_vpshufbitqmb512_mask ((__v64qi) __A,
(__v64qi) __B,
(__mmask64) -1);
_mm512_mask_bitshuffle_epi64_mask (__mmask64 __M, __m512i __A, __m512i __B)
(__v64qi) __B,
(__mmask64) __M);
#pragma GCC target("avx512bitalg,avx512vl,avx512bw")
_mm256_mask_popcnt_epi8 (__m256i __A, __mmask32 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpopcountb_v32qi_mask ((__v32qi) __A,
(__v32qi) __B,
(__mmask32) __U);
_mm256_maskz_popcnt_epi8 (__mmask32 __U, __m256i __A)
(__v32qi)
(__mmask32) __U);
extern __inline __mmask32
_mm256_bitshuffle_epi64_mask (__m256i __A, __m256i __B)
return (__mmask32) __builtin_ia32_vpshufbitqmb256_mask ((__v32qi) __A,
(__v32qi) __B,
(__mmask32) -1);
_mm256_mask_bitshuffle_epi64_mask (__mmask32 __M, __m256i __A, __m256i __B)
(__v32qi) __B,
(__mmask32) __M);
#pragma GCC target("avx512bitalg,avx512vl")
_mm_bitshuffle_epi64_mask (__m128i __A, __m128i __B)
return (__mmask16) __builtin_ia32_vpshufbitqmb128_mask ((__v16qi) __A,
(__v16qi) __B,
(__mmask16) -1);
_mm_mask_bitshuffle_epi64_mask (__mmask16 __M, __m128i __A, __m128i __B)
(__v16qi) __B,
(__mmask16) __M);
_mm256_popcnt_epi8 (__m256i __A)
return (__m256i) __builtin_ia32_vpopcountb_v32qi ((__v32qi) __A);
_mm256_popcnt_epi16 (__m256i __A)
return (__m256i) __builtin_ia32_vpopcountw_v16hi ((__v16hi) __A);
_mm_popcnt_epi8 (__m128i __A)
return (__m128i) __builtin_ia32_vpopcountb_v16qi ((__v16qi) __A);
_mm_popcnt_epi16 (__m128i __A)
return (__m128i) __builtin_ia32_vpopcountw_v8hi ((__v8hi) __A);
_mm256_mask_popcnt_epi16 (__m256i __A, __mmask16 __U, __m256i __B)
return (__m256i) __builtin_ia32_vpopcountw_v16hi_mask ((__v16hi) __A,
(__v16hi) __B,
(__mmask16) __U);
_mm256_maskz_popcnt_epi16 (__mmask16 __U, __m256i __A)
(__v16hi)
(__mmask16) __U);
_mm_mask_popcnt_epi8 (__m128i __A, __mmask16 __U, __m128i __B)
return (__m128i) __builtin_ia32_vpopcountb_v16qi_mask ((__v16qi) __A,
(__v16qi) __B,
(__mmask16) __U);
_mm_maskz_popcnt_epi8 (__mmask16 __U, __m128i __A)
(__v16qi)
(__mmask16) __U);
_mm_mask_popcnt_epi16 (__m128i __A, __mmask8 __U, __m128i __B)
return (__m128i) __builtin_ia32_vpopcountw_v8hi_mask ((__v8hi) __A,
(__v8hi) __B,
(__mmask8) __U);
_mm_maskz_popcnt_epi16 (__mmask8 __U, __m128i __A)
(__v8hi)
(__mmask8) __U);
# 88 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/shaintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/shaintrin.h" 3 4
#pragma GCC target("sha")
__attribute__ ((__gnu_inline__, __always_inline__, __artificial__))
_mm_sha1msg1_epu32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_sha1msg1 ((__v4si) __A, (__v4si) __B);
_mm_sha1msg2_epu32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_sha1msg2 ((__v4si) __A, (__v4si) __B);
_mm_sha1nexte_epu32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_sha1nexte ((__v4si) __A, (__v4si) __B);
# 71 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/shaintrin.h" 3 4
_mm_sha256msg1_epu32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_sha256msg1 ((__v4si) __A, (__v4si) __B);
_mm_sha256msg2_epu32 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_sha256msg2 ((__v4si) __A, (__v4si) __B);
_mm_sha256rnds2_epu32 (__m128i __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_sha256rnds2 ((__v4si) __A, (__v4si) __B,
(__v4si) __C);
# 90 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/lzcntintrin.h" 1 3 4
# 33 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/lzcntintrin.h" 3 4
#pragma GCC target("lzcnt")
extern __inline unsigned short __attribute__((__gnu_inline__, __always_inline__, __artificial__))
__lzcnt16 (unsigned short __X)
return __builtin_ia32_lzcnt_u16 (__X);
extern __inline unsigned int __attribute__((__gnu_inline__, __always_inline__, __artificial__))
__lzcnt32 (unsigned int __X)
return __builtin_ia32_lzcnt_u32 (__X);
_lzcnt_u32 (unsigned int __X)
extern __inline unsigned long long __attribute__((__gnu_inline__, __always_inline__, __artificial__))
__lzcnt64 (unsigned long long __X)
return __builtin_ia32_lzcnt_u64 (__X);
_lzcnt_u64 (unsigned long long __X)
# 92 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/bmiintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/bmiintrin.h" 3 4
#pragma GCC target("bmi")
__tzcnt_u16 (unsigned short __X)
return __builtin_ia32_tzcnt_u16 (__X);
__andn_u32 (unsigned int __X, unsigned int __Y)
return ~__X & __Y;
__bextr_u32 (unsigned int __X, unsigned int __Y)
return __builtin_ia32_bextr_u32 (__X, __Y);
_bextr_u32 (unsigned int __X, unsigned int __Y, unsigned __Z)
return __builtin_ia32_bextr_u32 (__X, ((__Y & 0xff) | ((__Z & 0xff) << 8)));
__blsi_u32 (unsigned int __X)
return __X & -__X;
return __blsi_u32 (__X);
__blsmsk_u32 (unsigned int __X)
return __X ^ (__X - 1);
return __blsmsk_u32 (__X);
__blsr_u32 (unsigned int __X)
return __X & (__X - 1);
return __blsr_u32 (__X);
__tzcnt_u32 (unsigned int __X)
return __builtin_ia32_tzcnt_u32 (__X);
__andn_u64 (unsigned long long __X, unsigned long long __Y)
return ~__X & __Y;
__bextr_u64 (unsigned long long __X, unsigned long long __Y)
return __builtin_ia32_bextr_u64 (__X, __Y);
_bextr_u64 (unsigned long long __X, unsigned int __Y, unsigned int __Z)
return __builtin_ia32_bextr_u64 (__X, ((__Y & 0xff) | ((__Z & 0xff) << 8)));
__blsi_u64 (unsigned long long __X)
return __X & -__X;
return __blsi_u64 (__X);
__blsmsk_u64 (unsigned long long __X)
return __blsmsk_u64 (__X);
__blsr_u64 (unsigned long long __X)
return __blsr_u64 (__X);
__tzcnt_u64 (unsigned long long __X)
return __builtin_ia32_tzcnt_u64 (__X);
# 94 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/bmi2intrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/bmi2intrin.h" 3 4
#pragma GCC target("bmi2")
_bzhi_u32 (unsigned int __X, unsigned int __Y)
return __builtin_ia32_bzhi_si (__X, __Y);
_pdep_u32 (unsigned int __X, unsigned int __Y)
return __builtin_ia32_pdep_si (__X, __Y);
_pext_u32 (unsigned int __X, unsigned int __Y)
return __builtin_ia32_pext_si (__X, __Y);
_bzhi_u64 (unsigned long long __X, unsigned long long __Y)
return __builtin_ia32_bzhi_di (__X, __Y);
_pdep_u64 (unsigned long long __X, unsigned long long __Y)
return __builtin_ia32_pdep_di (__X, __Y);
_pext_u64 (unsigned long long __X, unsigned long long __Y)
return __builtin_ia32_pext_di (__X, __Y);
_mulx_u64 (unsigned long long __X, unsigned long long __Y,
unsigned long long *__P)
unsigned __int128 __res = (unsigned __int128) __X * __Y;
*__P = (unsigned long long) (__res >> 64);
return (unsigned long long) __res;
# 106 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/bmi2intrin.h" 3 4
# 96 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/fmaintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/fmaintrin.h" 3 4
#pragma GCC target("fma")
_mm_fmadd_pd (__m128d __A, __m128d __B, __m128d __C)
return (__m128d)__builtin_ia32_vfmaddpd ((__v2df)__A, (__v2df)__B,
(__v2df)__C);
_mm256_fmadd_pd (__m256d __A, __m256d __B, __m256d __C)
return (__m256d)__builtin_ia32_vfmaddpd256 ((__v4df)__A, (__v4df)__B,
(__v4df)__C);
_mm_fmadd_ps (__m128 __A, __m128 __B, __m128 __C)
return (__m128)__builtin_ia32_vfmaddps ((__v4sf)__A, (__v4sf)__B,
(__v4sf)__C);
_mm256_fmadd_ps (__m256 __A, __m256 __B, __m256 __C)
return (__m256)__builtin_ia32_vfmaddps256 ((__v8sf)__A, (__v8sf)__B,
(__v8sf)__C);
_mm_fmadd_sd (__m128d __A, __m128d __B, __m128d __C)
return (__m128d) __builtin_ia32_vfmaddsd3 ((__v2df)__A, (__v2df)__B,
(__v2df)__C);
_mm_fmadd_ss (__m128 __A, __m128 __B, __m128 __C)
return (__m128) __builtin_ia32_vfmaddss3 ((__v4sf)__A, (__v4sf)__B,
(__v4sf)__C);
_mm_fmsub_pd (__m128d __A, __m128d __B, __m128d __C)
-(__v2df)__C);
_mm256_fmsub_pd (__m256d __A, __m256d __B, __m256d __C)
-(__v4df)__C);
_mm_fmsub_ps (__m128 __A, __m128 __B, __m128 __C)
-(__v4sf)__C);
_mm256_fmsub_ps (__m256 __A, __m256 __B, __m256 __C)
-(__v8sf)__C);
_mm_fmsub_sd (__m128d __A, __m128d __B, __m128d __C)
return (__m128d)__builtin_ia32_vfmaddsd3 ((__v2df)__A, (__v2df)__B,
-(__v2df)__C);
_mm_fmsub_ss (__m128 __A, __m128 __B, __m128 __C)
return (__m128)__builtin_ia32_vfmaddss3 ((__v4sf)__A, (__v4sf)__B,
-(__v4sf)__C);
_mm_fnmadd_pd (__m128d __A, __m128d __B, __m128d __C)
return (__m128d)__builtin_ia32_vfmaddpd (-(__v2df)__A, (__v2df)__B,
(__v2df)__C);
_mm256_fnmadd_pd (__m256d __A, __m256d __B, __m256d __C)
return (__m256d)__builtin_ia32_vfmaddpd256 (-(__v4df)__A, (__v4df)__B,
(__v4df)__C);
_mm_fnmadd_ps (__m128 __A, __m128 __B, __m128 __C)
return (__m128)__builtin_ia32_vfmaddps (-(__v4sf)__A, (__v4sf)__B,
(__v4sf)__C);
_mm256_fnmadd_ps (__m256 __A, __m256 __B, __m256 __C)
return (__m256)__builtin_ia32_vfmaddps256 (-(__v8sf)__A, (__v8sf)__B,
(__v8sf)__C);
_mm_fnmadd_sd (__m128d __A, __m128d __B, __m128d __C)
return (__m128d)__builtin_ia32_vfmaddsd3 ((__v2df)__A, -(__v2df)__B,
(__v2df)__C);
_mm_fnmadd_ss (__m128 __A, __m128 __B, __m128 __C)
return (__m128)__builtin_ia32_vfmaddss3 ((__v4sf)__A, -(__v4sf)__B,
(__v4sf)__C);
_mm_fnmsub_pd (__m128d __A, __m128d __B, __m128d __C)
-(__v2df)__C);
extern __inline __m256d
_mm256_fnmsub_pd (__m256d __A, __m256d __B, __m256d __C)
-(__v4df)__C);
_mm_fnmsub_ps (__m128 __A, __m128 __B, __m128 __C)
-(__v4sf)__C);
_mm256_fnmsub_ps (__m256 __A, __m256 __B, __m256 __C)
-(__v8sf)__C);
_mm_fnmsub_sd (__m128d __A, __m128d __B, __m128d __C)
-(__v2df)__C);
_mm_fnmsub_ss (__m128 __A, __m128 __B, __m128 __C)
-(__v4sf)__C);
_mm_fmaddsub_pd (__m128d __A, __m128d __B, __m128d __C)
return (__m128d)__builtin_ia32_vfmaddsubpd ((__v2df)__A, (__v2df)__B,
(__v2df)__C);
_mm256_fmaddsub_pd (__m256d __A, __m256d __B, __m256d __C)
return (__m256d)__builtin_ia32_vfmaddsubpd256 ((__v4df)__A,
(__v4df)__B,
(__v4df)__C);
_mm_fmaddsub_ps (__m128 __A, __m128 __B, __m128 __C)
return (__m128)__builtin_ia32_vfmaddsubps ((__v4sf)__A, (__v4sf)__B,
(__v4sf)__C);
_mm256_fmaddsub_ps (__m256 __A, __m256 __B, __m256 __C)
return (__m256)__builtin_ia32_vfmaddsubps256 ((__v8sf)__A,
(__v8sf)__B,
(__v8sf)__C);
_mm_fmsubadd_pd (__m128d __A, __m128d __B, __m128d __C)
-(__v2df)__C);
_mm256_fmsubadd_pd (__m256d __A, __m256d __B, __m256d __C)
(__v4df)__B,
-(__v4df)__C);
_mm_fmsubadd_ps (__m128 __A, __m128 __B, __m128 __C)
-(__v4sf)__C);
_mm256_fmsubadd_ps (__m256 __A, __m256 __B, __m256 __C)
(__v8sf)__B,
-(__v8sf)__C);
# 98 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/f16cintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/f16cintrin.h" 3 4
#pragma GCC target("f16c")
extern __inline float __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_cvtsh_ss (unsigned short __S)
__v8hi __H = __extension__ (__v8hi){ (short) __S, 0, 0, 0, 0, 0, 0, 0 };
__v4sf __A = __builtin_ia32_vcvtph2ps (__H);
return __builtin_ia32_vec_ext_v4sf (__A, 0);
extern __inline __m128 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm_cvtph_ps (__m128i __A)
return (__m128) __builtin_ia32_vcvtph2ps ((__v8hi) __A);
extern __inline __m256 __attribute__((__gnu_inline__, __always_inline__, __artificial__))
_mm256_cvtph_ps (__m128i __A)
return (__m256) __builtin_ia32_vcvtph2ps256 ((__v8hi) __A);
# 95 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/f16cintrin.h" 3 4
# 100 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/rtmintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/rtmintrin.h" 3 4
#pragma GCC target("rtm")
# 48 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/rtmintrin.h" 3 4
_xbegin (void)
return __builtin_ia32_xbegin ();
_xend (void)
__builtin_ia32_xend ();
# 81 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/rtmintrin.h" 3 4
# 102 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xtestintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/xtestintrin.h" 3 4
extern __inline int
_xtest (void)
return __builtin_ia32_xtest ();
# 104 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/cetintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/cetintrin.h" 3 4
#pragma GCC target ("shstk")
_get_ssp (void)
return __builtin_ia32_rdsspq ();
# 53 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/cetintrin.h" 3 4
_inc_ssp (unsigned int __B)
__builtin_ia32_incsspq ((unsigned long long) __B);
_saveprevssp (void)
__builtin_ia32_saveprevssp ();
_rstorssp (void *__B)
__builtin_ia32_rstorssp (__B);
_wrssd (unsigned int __B, void *__C)
__builtin_ia32_wrssd (__B, __C);
_wrssq (unsigned long long __B, void *__C)
__builtin_ia32_wrssq (__B, __C);
_wrussd (unsigned int __B, void *__C)
__builtin_ia32_wrussd (__B, __C);
_wrussq (unsigned long long __B, void *__C)
__builtin_ia32_wrussq (__B, __C);
_setssbsy (void)
__builtin_ia32_setssbsy ();
_clrssbsy (void *__B)
__builtin_ia32_clrssbsy (__B);
# 106 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 3 4
#pragma GCC target("gfni,sse2")
_mm_gf2p8mul_epi8 (__m128i __A, __m128i __B)
return (__m128i) __builtin_ia32_vgf2p8mulb_v16qi((__v16qi) __A,
(__v16qi) __B);
# 73 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 3 4
#pragma GCC target("gfni,avx")
_mm256_gf2p8mul_epi8 (__m256i __A, __m256i __B)
return (__m256i) __builtin_ia32_vgf2p8mulb_v32qi ((__v32qi) __A,
(__v32qi) __B);
# 119 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 3 4
#pragma GCC target("gfni,avx512vl")
_mm_mask_gf2p8mul_epi8 (__m128i __A, __mmask16 __B, __m128i __C, __m128i __D)
return (__m128i) __builtin_ia32_vgf2p8mulb_v16qi_mask ((__v16qi) __C,
(__v16qi) __D,
(__v16qi)__A, __B);
_mm_maskz_gf2p8mul_epi8 (__mmask16 __A, __m128i __B, __m128i __C)
return (__m128i) __builtin_ia32_vgf2p8mulb_v16qi_mask ((__v16qi) __B,
(__v16qi) __C, (__v16qi) _mm_setzero_si128 (), __A);
# 207 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 3 4
#pragma GCC target("gfni,avx512vl,avx512bw")
_mm256_mask_gf2p8mul_epi8 (__m256i __A, __mmask32 __B, __m256i __C,
__m256i __D)
return (__m256i) __builtin_ia32_vgf2p8mulb_v32qi_mask ((__v32qi) __C,
(__v32qi) __D,
(__v32qi)__A, __B);
_mm256_maskz_gf2p8mul_epi8 (__mmask32 __A, __m256i __B, __m256i __C)
return (__m256i) __builtin_ia32_vgf2p8mulb_v32qi_mask ((__v32qi) __B,
(__v32qi) __C, (__v32qi) _mm256_setzero_si256 (), __A);
# 297 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 3 4
#pragma GCC target("gfni,avx512f,avx512bw")
_mm512_mask_gf2p8mul_epi8 (__m512i __A, __mmask64 __B, __m512i __C,
__m512i __D)
return (__m512i) __builtin_ia32_vgf2p8mulb_v64qi_mask ((__v64qi) __C,
(__v64qi) __D, (__v64qi)__A, __B);
_mm512_maskz_gf2p8mul_epi8 (__mmask64 __A, __m512i __B, __m512i __C)
return (__m512i) __builtin_ia32_vgf2p8mulb_v64qi_mask ((__v64qi) __B,
(__v64qi) __C, (__v64qi) _mm512_setzero_si512 (), __A);
_mm512_gf2p8mul_epi8 (__m512i __A, __m512i __B)
return (__m512i) __builtin_ia32_vgf2p8mulb_v64qi ((__v64qi) __A,
(__v64qi) __B);
# 411 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/gfniintrin.h" 3 4
# 108 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vaesintrin.h" 1 3 4
# 28 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vaesintrin.h" 3 4
#pragma GCC target("vaes,avx")
_mm256_aesdec_epi128 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_vaesdec_v32qi ((__v32qi) __A, (__v32qi) __B);
_mm256_aesdeclast_epi128 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_vaesdeclast_v32qi ((__v32qi) __A,
(__v32qi) __B);
_mm256_aesenc_epi128 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_vaesenc_v32qi ((__v32qi) __A, (__v32qi) __B);
_mm256_aesenclast_epi128 (__m256i __A, __m256i __B)
return (__m256i)__builtin_ia32_vaesenclast_v32qi ((__v32qi) __A,
(__v32qi) __B);
#pragma GCC target("vaes,avx512f")
_mm512_aesdec_epi128 (__m512i __A, __m512i __B)
return (__m512i)__builtin_ia32_vaesdec_v64qi ((__v64qi) __A, (__v64qi) __B);
_mm512_aesdeclast_epi128 (__m512i __A, __m512i __B)
return (__m512i)__builtin_ia32_vaesdeclast_v64qi ((__v64qi) __A,
(__v64qi) __B);
_mm512_aesenc_epi128 (__m512i __A, __m512i __B)
return (__m512i)__builtin_ia32_vaesenc_v64qi ((__v64qi) __A, (__v64qi) __B);
_mm512_aesenclast_epi128 (__m512i __A, __m512i __B)
return (__m512i)__builtin_ia32_vaesenclast_v64qi ((__v64qi) __A,
(__v64qi) __B);
#pragma GCC target("vaes,avx512vl")
_mm_aesdec_epi128 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_vaesdec_v16qi ((__v16qi) __A, (__v16qi) __B);
_mm_aesdeclast_epi128 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_vaesdeclast_v16qi ((__v16qi) __A,
(__v16qi) __B);
_mm_aesenc_epi128 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_vaesenc_v16qi ((__v16qi) __A, (__v16qi) __B);
_mm_aesenclast_epi128 (__m128i __A, __m128i __B)
return (__m128i)__builtin_ia32_vaesenclast_v16qi ((__v16qi) __A,
(__v16qi) __B);
# 110 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vpclmulqdqintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vpclmulqdqintrin.h" 3 4
#pragma GCC target("vpclmulqdq,avx512f")
# 53 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vpclmulqdqintrin.h" 3 4
#pragma GCC target("vpclmulqdq,avx512vl")
# 78 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vpclmulqdqintrin.h" 3 4
# 103 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/vpclmulqdqintrin.h" 3 4
# 112 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/movdirintrin.h" 1 3 4
# 32 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/movdirintrin.h" 3 4
#pragma GCC target ("movdiri")
_directstoreu_u32 (void * __P, unsigned int __A)
__builtin_ia32_directstoreu_u32 ((unsigned int *)__P, __A);
_directstoreu_u64 (void * __P, unsigned long long __A)
__builtin_ia32_directstoreu_u64 ((unsigned long long *)__P, __A);
#pragma GCC target ("movdir64b")
_movdir64b (void * __P, const void * __Q)
__builtin_ia32_movdir64b (__P, __Q);
# 114 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/immintrin.h" 2 3 4
_wbinvd (void)
__builtin_ia32_wbinvd ();
#pragma GCC target("rdrnd")
extern __inline int
_rdrand16_step (unsigned short *__P)
return __builtin_ia32_rdrand16_step (__P);
extern __inline int
_rdrand32_step (unsigned int *__P)
return __builtin_ia32_rdrand32_step (__P);
#pragma GCC target("rdpid")
_rdpid_u32 (void)
return __builtin_ia32_rdpid ();
#pragma GCC target("fsgsbase")
_readfsbase_u32 (void)
return __builtin_ia32_rdfsbase32 ();
_readfsbase_u64 (void)
return __builtin_ia32_rdfsbase64 ();
_readgsbase_u32 (void)
return __builtin_ia32_rdgsbase32 ();
_readgsbase_u64 (void)
return __builtin_ia32_rdgsbase64 ();
_writefsbase_u32 (unsigned int __B)
__builtin_ia32_wrfsbase32 (__B);
_writefsbase_u64 (unsigned long long __B)
__builtin_ia32_wrfsbase64 (__B);
_writegsbase_u32 (unsigned int __B)
__builtin_ia32_wrgsbase32 (__B);
_writegsbase_u64 (unsigned long long __B)
__builtin_ia32_wrgsbase64 (__B);
extern __inline int
_rdrand64_step (unsigned long long *__P)
return __builtin_ia32_rdrand64_step (__P);
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_IMMINTRIN_H" to "1"
TEST check from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: ieeefp.h
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2stderr:
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory
#include <ieeefp.h>
compilation terminated.
Source:
#include "confdefs.h"
#include "conffix.h"
#include <ieeefp.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory
#include <ieeefp.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory #include <ieeefp.h> ^~~~~~~~~~compilation terminated.:
Checking for header: strings.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/strings.h" 1 3 4
# 21 "/usr/include/strings.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 22 "/usr/include/strings.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 24 "/usr/include/strings.h" 2 3 4
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 68 "/usr/include/strings.h" 3 4
extern char *index (const char *__s, int __c)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 96 "/usr/include/strings.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int ffsl (long int __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__ extern int ffsll (long long int __ll)
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
# 1 "/usr/include/bits/types/locale_t.h" 1 3 4
# 22 "/usr/include/bits/types/locale_t.h" 3 4
# 1 "/usr/include/bits/types/__locale_t.h" 1 3 4
# 28 "/usr/include/bits/types/__locale_t.h" 3 4
struct __locale_struct
struct __locale_data *__locales[13];
const unsigned short int *__ctype_b;
const int *__ctype_tolower;
const int *__ctype_toupper;
const char *__names[13];
typedef struct __locale_struct *__locale_t;
# 23 "/usr/include/bits/types/locale_t.h" 2 3 4
typedef __locale_t locale_t;
# 126 "/usr/include/strings.h" 2 3 4
extern int strcasecmp_l (const char *__s1, const char *__s2, locale_t __loc)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int strncasecmp_l (const char *__s1, const char *__s2,
size_t __n, locale_t __loc)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
Defined "HAVE_STRINGS_H" to "1"
Checking for header: inttypes.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/inttypes.h" 1 3 4
# 25 "/usr/include/inttypes.h" 3 4
# 26 "/usr/include/inttypes.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 26 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/bits/libc-header-start.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
# 30 "/usr/include/bits/types.h" 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef __int8_t __int_least8_t;
typedef __uint8_t __uint_least8_t;
typedef __int16_t __int_least16_t;
typedef __uint16_t __uint_least16_t;
typedef __int32_t __int_least32_t;
typedef __uint32_t __uint_least32_t;
typedef __int64_t __int_least64_t;
typedef __uint64_t __uint_least64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
typedef long int __intmax_t;
typedef unsigned long int __uintmax_t;
# 140 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 141 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef int __sig_atomic_t;
# 28 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 29 "/usr/include/stdint.h" 2 3 4
# 30 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/stdint-intn.h" 1 3 4
# 24 "/usr/include/bits/stdint-intn.h" 3 4
typedef __int8_t int8_t;
typedef __int16_t int16_t;
typedef __int32_t int32_t;
typedef __int64_t int64_t;
# 35 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/stdint-uintn.h" 1 3 4
# 24 "/usr/include/bits/stdint-uintn.h" 3 4
typedef __uint8_t uint8_t;
typedef __uint16_t uint16_t;
typedef __uint32_t uint32_t;
typedef __uint64_t uint64_t;
# 38 "/usr/include/stdint.h" 2 3 4
typedef __int_least8_t int_least8_t;
typedef __int_least16_t int_least16_t;
typedef __int_least32_t int_least32_t;
typedef __int_least64_t int_least64_t;
typedef __uint_least8_t uint_least8_t;
typedef __uint_least16_t uint_least16_t;
typedef __uint_least32_t uint_least32_t;
typedef __uint_least64_t uint_least64_t;
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 71 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 87 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 101 "/usr/include/stdint.h" 3 4
typedef __intmax_t intmax_t;
typedef __uintmax_t uintmax_t;
# 10 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdint.h" 2 3 4
# 28 "/usr/include/inttypes.h" 2 3 4
typedef int __gwchar_t;
# 266 "/usr/include/inttypes.h" 3 4
typedef struct
long int quot;
long int rem;
} imaxdiv_t;
# 290 "/usr/include/inttypes.h" 3 4
extern intmax_t imaxabs (intmax_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
extern intmax_t strtoimax (const char *__restrict __nptr,
char **__restrict __endptr, int __base) __attribute__ ((__nothrow__ , __leaf__));
extern uintmax_t strtoumax (const char *__restrict __nptr,
char ** __restrict __endptr, int __base) __attribute__ ((__nothrow__ , __leaf__));
extern intmax_t wcstoimax (const __gwchar_t *__restrict __nptr,
__gwchar_t **__restrict __endptr, int __base)
extern uintmax_t wcstoumax (const __gwchar_t *__restrict __nptr,
__gwchar_t ** __restrict __endptr, int __base)
# 432 "/usr/include/inttypes.h" 3 4
Defined "HAVE_INTTYPES_H" to "1"
Checking for header: sched.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sched.h" 1 3 4
# 22 "/usr/include/sched.h" 3 4
# 23 "/usr/include/sched.h" 2 3 4
# 26 "/usr/include/sched.h" 2 3 4
# 30 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/bits/types/time_t.h" 1 3 4
typedef __time_t time_t;
# 32 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timespec.h" 1 3 4
# 9 "/usr/include/bits/types/struct_timespec.h" 3 4
struct timespec
__time_t tv_sec;
__syscall_slong_t tv_nsec;
# 33 "/usr/include/sched.h" 2 3 4
typedef __pid_t pid_t;
# 1 "/usr/include/bits/sched.h" 1 3 4
# 74 "/usr/include/bits/sched.h" 3 4
# 1 "/usr/include/bits/types/struct_sched_param.h" 1 3 4
# 23 "/usr/include/bits/types/struct_sched_param.h" 3 4
struct sched_param
int sched_priority;
# 75 "/usr/include/bits/sched.h" 2 3 4
# 93 "/usr/include/bits/sched.h" 3 4
# 44 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/bits/cpu-set.h" 1 3 4
# 32 "/usr/include/bits/cpu-set.h" 3 4
typedef unsigned long int __cpu_mask;
typedef struct
__cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
# 115 "/usr/include/bits/cpu-set.h" 3 4
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void __sched_cpufree (cpu_set_t *__set) __attribute__ ((__nothrow__ , __leaf__));
# 45 "/usr/include/sched.h" 2 3 4
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_setscheduler (__pid_t __pid, int __policy,
const struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_getscheduler (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_yield (void) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_max (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_min (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) __attribute__ ((__nothrow__ , __leaf__));
# 129 "/usr/include/sched.h" 3 4
Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: cxxabi.h: No such file or directory
#include <cxxabi.h>
Source:
#include <cxxabi.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: cxxabi.h: No such file or directory
#include <cxxabi.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: cxxabi.h: No such file or directory #include <cxxabi.h> ^~~~~~~~~~compilation terminated.:
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
#include <sys/systeminfo.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory #include <sys/systeminfo.h> ^~~~~~~~~~~~~~~~~~compilation terminated.:
Checking for header: dos.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory
#include <dos.h>
Source:
#include <dos.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory
#include <dos.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory #include <dos.h> ^~~~~~~compilation terminated.:
Checking for header: WindowsX.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory
#include <WindowsX.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory #include <WindowsX.h> ^~~~~~~~~~~~compilation terminated.:
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/sysinfo.h" 1 3 4
# 21 "/usr/include/sys/sysinfo.h" 3 4
# 22 "/usr/include/sys/sysinfo.h" 2 3 4
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 1 "/usr/include/linux/sysinfo.h" 1 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 1 "/usr/include/asm/types.h" 1 3 4
# 1 "/usr/include/asm-generic/types.h" 1 3 4
# 1 "/usr/include/asm-generic/int-ll64.h" 1 3 4
# 12 "/usr/include/asm-generic/int-ll64.h" 3 4
# 1 "/usr/include/asm/bitsperlong.h" 1 3 4
# 11 "/usr/include/asm/bitsperlong.h" 3 4
# 1 "/usr/include/asm-generic/bitsperlong.h" 1 3 4
# 12 "/usr/include/asm/bitsperlong.h" 2 3 4
# 13 "/usr/include/asm-generic/int-ll64.h" 2 3 4
# 20 "/usr/include/asm-generic/int-ll64.h" 3 4
typedef __signed__ char __s8;
typedef unsigned char __u8;
typedef __signed__ short __s16;
typedef unsigned short __u16;
typedef __signed__ int __s32;
typedef unsigned int __u32;
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
# 8 "/usr/include/asm-generic/types.h" 2 3 4
# 6 "/usr/include/asm/types.h" 2 3 4
# 6 "/usr/include/linux/types.h" 2 3 4
# 1 "/usr/include/linux/posix_types.h" 1 3 4
# 1 "/usr/include/linux/stddef.h" 1 3 4
# 6 "/usr/include/linux/posix_types.h" 2 3 4
# 25 "/usr/include/linux/posix_types.h" 3 4
typedef struct {
unsigned long fds_bits[1024 / (8 * sizeof(long))];
} __kernel_fd_set;
typedef void (*__kernel_sighandler_t)(int);
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
# 1 "/usr/include/asm/posix_types.h" 1 3 4
# 1 "/usr/include/asm/posix_types_64.h" 1 3 4
# 11 "/usr/include/asm/posix_types_64.h" 3 4
typedef unsigned short __kernel_old_uid_t;
typedef unsigned short __kernel_old_gid_t;
typedef unsigned long __kernel_old_dev_t;
# 1 "/usr/include/asm-generic/posix_types.h" 1 3 4
# 15 "/usr/include/asm-generic/posix_types.h" 3 4
typedef long __kernel_long_t;
typedef unsigned long __kernel_ulong_t;
typedef __kernel_ulong_t __kernel_ino_t;
typedef unsigned int __kernel_mode_t;
typedef int __kernel_pid_t;
typedef int __kernel_ipc_pid_t;
typedef unsigned int __kernel_uid_t;
typedef unsigned int __kernel_gid_t;
typedef __kernel_long_t __kernel_suseconds_t;
typedef int __kernel_daddr_t;
typedef unsigned int __kernel_uid32_t;
typedef unsigned int __kernel_gid32_t;
# 72 "/usr/include/asm-generic/posix_types.h" 3 4
typedef __kernel_ulong_t __kernel_size_t;
typedef __kernel_long_t __kernel_ssize_t;
typedef __kernel_long_t __kernel_ptrdiff_t;
typedef struct {
int val[2];
} __kernel_fsid_t;
typedef __kernel_long_t __kernel_off_t;
typedef long long __kernel_loff_t;
typedef __kernel_long_t __kernel_time_t;
typedef __kernel_long_t __kernel_clock_t;
typedef int __kernel_timer_t;
typedef int __kernel_clockid_t;
typedef char * __kernel_caddr_t;
typedef unsigned short __kernel_uid16_t;
typedef unsigned short __kernel_gid16_t;
# 19 "/usr/include/asm/posix_types_64.h" 2 3 4
# 8 "/usr/include/asm/posix_types.h" 2 3 4
# 37 "/usr/include/linux/posix_types.h" 2 3 4
# 10 "/usr/include/linux/types.h" 2 3 4
# 24 "/usr/include/linux/types.h" 3 4
typedef __u16 __le16;
typedef __u16 __be16;
typedef __u32 __le32;
typedef __u32 __be32;
typedef __u64 __le64;
typedef __u64 __be64;
typedef __u16 __sum16;
typedef __u32 __wsum;
# 50 "/usr/include/linux/types.h" 3 4
typedef unsigned __poll_t;
# 6 "/usr/include/linux/sysinfo.h" 2 3 4
struct sysinfo {
__kernel_long_t uptime;
__kernel_ulong_t loads[3];
__kernel_ulong_t totalram;
__kernel_ulong_t freeram;
__kernel_ulong_t sharedram;
__kernel_ulong_t bufferram;
__kernel_ulong_t totalswap;
__kernel_ulong_t freeswap;
__u16 procs;
__u16 pad;
__kernel_ulong_t totalhigh;
__kernel_ulong_t freehigh;
__u32 mem_unit;
char _f[20-2*sizeof(__kernel_ulong_t)-sizeof(__u32)];
# 6 "/usr/include/linux/kernel.h" 2 3 4
# 25 "/usr/include/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: zmmintrin.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory
#include <zmmintrin.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory #include <zmmintrin.h> ^~~~~~~~~~~~~compilation terminated.:
Checking for header: sys/wait.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/wait.h" 1 3 4
# 25 "/usr/include/sys/wait.h" 3 4
# 26 "/usr/include/sys/wait.h" 2 3 4
# 30 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 27 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/signum.h" 1 3 4
# 26 "/usr/include/bits/signum.h" 3 4
# 1 "/usr/include/bits/signum-generic.h" 1 3 4
# 27 "/usr/include/bits/signum.h" 2 3 4
# 31 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sig_atomic_t.h" 1 3 4
typedef __sig_atomic_t sig_atomic_t;
# 33 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sigset_t.h" 1 3 4
# 1 "/usr/include/bits/types/__sigset_t.h" 1 3 4
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
# 5 "/usr/include/bits/types/sigset_t.h" 2 3 4
typedef __sigset_t sigset_t;
# 36 "/usr/include/signal.h" 2 3 4
# 46 "/usr/include/signal.h" 3 4
typedef __uid_t uid_t;
struct timespec
__time_t tv_sec;
# 54 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/siginfo_t.h" 1 3 4
# 5 "/usr/include/bits/types/siginfo_t.h" 2 3 4
# 1 "/usr/include/bits/types/__sigval_t.h" 1 3 4
# 24 "/usr/include/bits/types/__sigval_t.h" 3 4
union sigval
int sival_int;
void *sival_ptr;
typedef union sigval __sigval_t;
# 7 "/usr/include/bits/types/siginfo_t.h" 2 3 4
# 16 "/usr/include/bits/types/siginfo_t.h" 3 4
# 1 "/usr/include/bits/siginfo-arch.h" 1 3 4
# 17 "/usr/include/bits/types/siginfo_t.h" 2 3 4
# 36 "/usr/include/bits/types/siginfo_t.h" 3 4
typedef struct
int si_signo;
int si_errno;
int si_code;
int __pad0;
union
int _pad[((128 / sizeof (int)) - 4)];
struct
__pid_t si_pid;
__uid_t si_uid;
} _kill;
struct
int si_tid;
int si_overrun;
__sigval_t si_sigval;
} _timer;
struct
__pid_t si_pid;
__uid_t si_uid;
} _rt;
struct
__pid_t si_pid;
__uid_t si_uid;
int si_status;
__clock_t si_utime;
__clock_t si_stime;
} _sigchld;
struct
void *si_addr;
short int si_addr_lsb;
union
struct
void *_lower;
void *_upper;
} _addr_bnd;
__uint32_t _pkey;
} _bounds;
} _sigfault;
struct
long int si_band;
int si_fd;
} _sigpoll;
struct
void *_call_addr;
int _syscall;
unsigned int _arch;
} _sigsys;
} _sifields;
} siginfo_t ;
# 58 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/siginfo-consts.h" 1 3 4
# 35 "/usr/include/bits/siginfo-consts.h" 3 4
enum
SI_ASYNCNL = -60,
SI_TKILL = -6,
SI_SIGIO,
SI_ASYNCIO,
SI_MESGQ,
SI_TIMER,
SI_QUEUE,
SI_USER,
SI_KERNEL = 0x80
# 63 "/usr/include/bits/siginfo-consts.h" 3 4
enum
ILL_ILLOPC = 1,
ILL_ILLOPN,
ILL_ILLADR,
ILL_ILLTRP,
ILL_PRVOPC,
ILL_PRVREG,
ILL_COPROC,
ILL_BADSTK
enum
FPE_INTDIV = 1,
FPE_INTOVF,
FPE_FLTDIV,
FPE_FLTOVF,
FPE_FLTUND,
FPE_FLTRES,
FPE_FLTINV,
FPE_FLTSUB
enum
SEGV_MAPERR = 1,
SEGV_ACCERR,
SEGV_BNDERR,
SEGV_PKUERR
enum
BUS_ADRALN = 1,
BUS_ADRERR,
BUS_OBJERR,
BUS_MCEERR_AR,
BUS_MCEERR_AO
# 151 "/usr/include/bits/siginfo-consts.h" 3 4
enum
CLD_EXITED = 1,
CLD_KILLED,
CLD_DUMPED,
CLD_TRAPPED,
CLD_STOPPED,
CLD_CONTINUED
enum
POLL_IN = 1,
POLL_OUT,
POLL_MSG,
POLL_ERR,
POLL_PRI,
POLL_HUP
# 59 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sigval_t.h" 1 3 4
# 16 "/usr/include/bits/types/sigval_t.h" 3 4
typedef __sigval_t sigval_t;
# 63 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sigevent_t.h" 1 3 4
# 5 "/usr/include/bits/types/sigevent_t.h" 2 3 4
# 17 "/usr/include/bits/types/sigevent_t.h" 3 4
typedef union pthread_attr_t pthread_attr_t;
typedef struct sigevent
__sigval_t sigev_value;
int sigev_signo;
int sigev_notify;
union
int _pad[((64 / sizeof (int)) - 4)];
__pid_t _tid;
struct
void (*_function) (__sigval_t);
pthread_attr_t *_attribute;
} _sigev_thread;
} _sigev_un;
} sigevent_t;
# 67 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/sigevent-consts.h" 1 3 4
# 27 "/usr/include/bits/sigevent-consts.h" 3 4
enum
SIGEV_SIGNAL = 0,
SIGEV_NONE,
SIGEV_THREAD,
SIGEV_THREAD_ID = 4
# 68 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 88 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 112 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, const char *__s);
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
# 170 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 190 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (const sigset_t *__set, int __signo)
# 226 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigaction.h" 1 3 4
# 27 "/usr/include/bits/sigaction.h" 3 4
struct sigaction
union
__sighandler_t sa_handler;
void (*sa_sigaction) (int, siginfo_t *, void *);
__sigaction_handler;
__sigset_t sa_mask;
int sa_flags;
void (*sa_restorer) (void);
# 227 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
extern int sigwaitinfo (const sigset_t *__restrict __set,
siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (const sigset_t *__restrict __set,
siginfo_t *__restrict __info,
const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
# 286 "/usr/include/signal.h" 3 4
extern const char *const _sys_siglist[(64 + 1)];
extern const char *const sys_siglist[(64 + 1)];
# 1 "/usr/include/bits/sigcontext.h" 1 3 4
# 31 "/usr/include/bits/sigcontext.h" 3 4
struct _fpx_sw_bytes
__uint32_t magic1;
__uint32_t extended_size;
__uint64_t xstate_bv;
__uint32_t xstate_size;
__uint32_t __glibc_reserved1[7];
struct _fpreg
unsigned short significand[4];
unsigned short exponent;
struct _fpxreg
unsigned short __glibc_reserved1[3];
struct _xmmreg
__uint32_t element[4];
# 123 "/usr/include/bits/sigcontext.h" 3 4
struct _fpstate
__uint16_t cwd;
__uint16_t swd;
__uint16_t ftw;
__uint16_t fop;
__uint64_t rip;
__uint64_t rdp;
__uint32_t mxcsr;
__uint32_t mxcr_mask;
struct _fpxreg _st[8];
struct _xmmreg _xmm[16];
__uint32_t __glibc_reserved1[24];
struct sigcontext
__uint64_t r8;
__uint64_t r9;
__uint64_t r10;
__uint64_t r11;
__uint64_t r12;
__uint64_t r13;
__uint64_t r14;
__uint64_t r15;
__uint64_t rdi;
__uint64_t rsi;
__uint64_t rbp;
__uint64_t rbx;
__uint64_t rdx;
__uint64_t rax;
__uint64_t rcx;
__uint64_t rsp;
__uint64_t rip;
__uint64_t eflags;
unsigned short cs;
unsigned short gs;
unsigned short fs;
unsigned short __pad0;
__uint64_t err;
__uint64_t trapno;
__uint64_t oldmask;
__uint64_t cr2;
__extension__ union
struct _fpstate * fpstate;
__uint64_t __fpstate_word;
__uint64_t __reserved1 [8];
struct _xsave_hdr
__uint64_t __glibc_reserved1[2];
__uint64_t __glibc_reserved2[5];
struct _ymmh_state
__uint32_t ymmh_space[64];
struct _xstate
struct _fpstate fpstate;
struct _xsave_hdr xstate_hdr;
struct _ymmh_state ymmh;
# 292 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 302 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/stack_t.h" 1 3 4
# 23 "/usr/include/bits/types/stack_t.h" 3 4
# 24 "/usr/include/bits/types/stack_t.h" 2 3 4
typedef struct
void *ss_sp;
int ss_flags;
size_t ss_size;
} stack_t;
# 304 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/sys/ucontext.h" 1 3 4
# 37 "/usr/include/sys/ucontext.h" 3 4
__extension__ typedef long long int greg_t;
# 46 "/usr/include/sys/ucontext.h" 3 4
typedef greg_t gregset_t[23];
# 101 "/usr/include/sys/ucontext.h" 3 4
struct _libc_fpxreg
unsigned short int significand[4];
unsigned short int exponent;
unsigned short int __glibc_reserved1[3];
struct _libc_xmmreg
struct _libc_fpstate
__uint16_t cwd;
__uint16_t swd;
__uint16_t ftw;
__uint16_t fop;
__uint64_t rip;
__uint64_t rdp;
__uint32_t mxcsr;
struct _libc_fpxreg _st[8];
struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
gregset_t gregs;
fpregset_t fpregs;
__extension__ unsigned long long __reserved1 [8];
} mcontext_t;
typedef struct ucontext_t
unsigned long int uc_flags;
struct ucontext_t *uc_link;
stack_t uc_stack;
mcontext_t uc_mcontext;
sigset_t uc_sigmask;
struct _libc_fpstate __fpregs_mem;
__extension__ unsigned long long int __ssp[4];
} ucontext_t;
# 307 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigstack.h" 1 3 4
# 317 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/ss_flags.h" 1 3 4
# 27 "/usr/include/bits/ss_flags.h" 3 4
enum
SS_ONSTACK = 1,
SS_DISABLE
# 318 "/usr/include/signal.h" 2 3 4
extern int sigaltstack (const stack_t *__restrict __ss,
stack_t *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/types/struct_sigstack.h" 1 3 4
# 23 "/usr/include/bits/types/struct_sigstack.h" 3 4
struct sigstack
void *ss_sp;
int ss_onstack;
# 328 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
# 358 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/bits/pthreadtypes.h" 3 4
# 1 "/usr/include/bits/thread-shared-types.h" 1 3 4
# 77 "/usr/include/bits/thread-shared-types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes-arch.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 22 "/usr/include/bits/pthreadtypes-arch.h" 2 3 4
# 65 "/usr/include/bits/pthreadtypes-arch.h" 3 4
struct __pthread_rwlock_arch_t
unsigned int __readers;
unsigned int __writers;
unsigned int __wrphase_futex;
unsigned int __writers_futex;
unsigned int __pad3;
unsigned int __pad4;
int __cur_writer;
int __shared;
signed char __rwelision;
unsigned char __pad1[7];
unsigned long int __pad2;
unsigned int __flags;
# 99 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 78 "/usr/include/bits/thread-shared-types.h" 2 3 4
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
# 118 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_mutex_s
int __lock ;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
short __spins; short __elision;
__pthread_list_t __list;
# 145 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_cond_s
__extension__ union
__extension__ unsigned long long int __wseq;
struct
unsigned int __low;
unsigned int __high;
} __wseq32;
__extension__ union
__extension__ unsigned long long int __g1_start;
struct
unsigned int __low;
} __g1_start32;
unsigned int __g_refs[2] ;
unsigned int __g_size[2];
unsigned int __g1_orig_size;
unsigned int __wrefs;
unsigned int __g_signals[2];
# 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
typedef unsigned long int pthread_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
char __size[56];
long int __align;
typedef union
struct __pthread_mutex_s __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
struct __pthread_cond_s __data;
char __size[48];
__extension__ long long int __align;
} pthread_cond_t;
typedef union
struct __pthread_rwlock_arch_t __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
# 359 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/sigthread.h" 1 3 4
# 31 "/usr/include/bits/sigthread.h" 3 4
extern int pthread_sigmask (int __how,
const __sigset_t *__restrict __newmask,
__sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__ , __leaf__));
extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__ , __leaf__));
# 360 "/usr/include/signal.h" 2 3 4
extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__ , __leaf__));
extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__ , __leaf__));
# 37 "/usr/include/sys/wait.h" 2 3 4
# 49 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 50 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 53 "/usr/include/sys/wait.h" 2 3 4
# 74 "/usr/include/sys/wait.h" 3 4
typedef enum
P_ALL,
P_PID,
P_PGID
} idtype_t;
# 88 "/usr/include/sys/wait.h" 3 4
extern __pid_t wait (int *__stat_loc);
# 111 "/usr/include/sys/wait.h" 3 4
extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
typedef __id_t id_t;
# 132 "/usr/include/sys/wait.h" 3 4
extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
int __options);
struct rusage;
extern __pid_t wait3 (int *__stat_loc, int __options,
struct rusage * __usage) __attribute__ ((__nothrow__));
extern __pid_t wait4 (__pid_t __pid, int *__stat_loc, int __options,
struct rusage *__usage) __attribute__ ((__nothrow__));
Defined "HAVE_SYS_WAIT_H" to "1"
Checking for header: stdlib.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 33 "/usr/include/bits/libc-header-start.h" 3 4
# 34 "/usr/include/bits/libc-header-start.h" 2 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 328 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef int wchar_t;
# 32 "/usr/include/stdlib.h" 2 3 4
# 40 "/usr/include/stdlib.h" 2 3 4
# 41 "/usr/include/stdlib.h" 2 3 4
# 55 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/floatn.h" 1 3 4
# 119 "/usr/include/bits/floatn.h" 3 4
# 1 "/usr/include/bits/floatn-common.h" 1 3 4
# 24 "/usr/include/bits/floatn-common.h" 3 4
# 25 "/usr/include/bits/floatn-common.h" 2 3 4
# 120 "/usr/include/bits/floatn.h" 2 3 4
# 56 "/usr/include/stdlib.h" 2 3 4
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
__extension__ typedef struct
long long int quot;
long long int rem;
} lldiv_t;
# 97 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
# 176 "/usr/include/stdlib.h" 3 4
extern long int strtol (const char *__restrict __nptr,
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 385 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 59 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __off_t off_t;
# 97 "/usr/include/sys/types.h" 3 4
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 1 "/usr/include/bits/types/clock_t.h" 1 3 4
typedef __clock_t clock_t;
# 127 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/clockid_t.h" 1 3 4
typedef __clockid_t clockid_t;
# 129 "/usr/include/sys/types.h" 2 3 4
# 130 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/timer_t.h" 1 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/sys/types.h" 2 3 4
# 144 "/usr/include/sys/types.h" 3 4
# 145 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 156 "/usr/include/sys/types.h" 2 3 4
# 177 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 193 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 33 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint16_t
__bswap_16 (__uint16_t __bsx)
return __builtin_bswap16 (__bsx);
static __inline __uint32_t
__bswap_32 (__uint32_t __bsx)
return __builtin_bswap32 (__bsx);
# 69 "/usr/include/bits/byteswap.h" 3 4
__extension__ static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/bits/uintn-identity.h" 1 3 4
# 32 "/usr/include/bits/uintn-identity.h" 3 4
__uint16_identity (__uint16_t __x)
return __x;
__uint32_identity (__uint32_t __x)
return __x;
__uint64_identity (__uint64_t __x)
return __x;
# 62 "/usr/include/endian.h" 2 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
typedef struct
} __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timeval.h" 1 3 4
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
# 38 "/usr/include/sys/select.h" 2 3 4
struct timespec
__time_t tv_sec;
# 40 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 59 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
# 91 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
fd_set *__restrict __writefds,
fd_set *__restrict __exceptfds,
struct timeval *__restrict __timeout);
# 113 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
const struct timespec *__restrict __timeout,
const __sigset_t *__restrict __sigmask);
# 126 "/usr/include/sys/select.h" 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 244 "/usr/include/sys/types.h" 3 4
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
# 245 "/usr/include/sys/types.h" 2 3 4
# 395 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
size_t __statelen,
struct random_data *__restrict __buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
__extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
# 563 "/usr/include/stdlib.h" 3 4
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 567 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int at_quick_exit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void quick_exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 644 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 672 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 685 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 707 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 728 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 781 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 797 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 817 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
__attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 837 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
long long int __denom)
# 869 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
int *__restrict __sign, char *__restrict __buf,
size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
int *__restrict __decpt, int *__restrict __sign,
char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 954 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
char *const *__restrict __tokens,
char **__restrict __valuep)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 1000 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1010 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 1011 "/usr/include/stdlib.h" 2 3 4
# 1020 "/usr/include/stdlib.h" 3 4
Defined "HAVE_STDLIB_H" to "1"
Checking for header: pthread.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/pthread.h" 1 3 4
# 21 "/usr/include/pthread.h" 3 4
# 22 "/usr/include/pthread.h" 2 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 2 3 4
return __x;
return __x;
return __x;
# 23 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/sched.h" 3 4
struct timespec
__time_t tv_sec;
struct sched_param
int sched_priority;
typedef struct
} cpu_set_t;
# 24 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 29 "/usr/include/time.h" 3 4
# 30 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 34 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/types/struct_tm.h" 1 3 4
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
# 40 "/usr/include/time.h" 2 3 4
# 47 "/usr/include/time.h" 2 3 4
# 48 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/types/struct_itimerspec.h" 1 3 4
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
# 49 "/usr/include/time.h" 2 3 4
struct sigevent;
# 60 "/usr/include/time.h" 3 4
# 61 "/usr/include/time.h" 2 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
const char *__restrict __format,
const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 104 "/usr/include/time.h" 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
const struct tm *__restrict __tp,
locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 119 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 196 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 211 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
struct sigevent *__restrict __evp,
timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec *__restrict __value,
struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timespec_get (struct timespec *__ts, int __base)
# 307 "/usr/include/time.h" 3 4
# 25 "/usr/include/pthread.h" 2 3 4
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
# 27 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/setjmp.h" 1 3 4
# 26 "/usr/include/bits/setjmp.h" 3 4
# 27 "/usr/include/bits/setjmp.h" 2 3 4
typedef long int __jmp_buf[8];
# 28 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/pthread.h" 2 3 4
enum
PTHREAD_CREATE_JOINABLE,
PTHREAD_CREATE_DETACHED
enum
PTHREAD_MUTEX_TIMED_NP,
PTHREAD_MUTEX_RECURSIVE_NP,
PTHREAD_MUTEX_ERRORCHECK_NP,
PTHREAD_MUTEX_ADAPTIVE_NP
PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
enum
PTHREAD_MUTEX_STALLED,
PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
PTHREAD_MUTEX_ROBUST,
PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
enum
PTHREAD_PRIO_NONE,
PTHREAD_PRIO_INHERIT,
PTHREAD_PRIO_PROTECT
# 115 "/usr/include/pthread.h" 3 4
enum
PTHREAD_RWLOCK_PREFER_READER_NP,
PTHREAD_RWLOCK_PREFER_WRITER_NP,
PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
# 156 "/usr/include/pthread.h" 3 4
enum
PTHREAD_INHERIT_SCHED,
PTHREAD_EXPLICIT_SCHED
enum
PTHREAD_SCOPE_SYSTEM,
PTHREAD_SCOPE_PROCESS
enum
PTHREAD_PROCESS_PRIVATE,
PTHREAD_PROCESS_SHARED
# 191 "/usr/include/pthread.h" 3 4
struct _pthread_cleanup_buffer
void (*__routine) (void *);
void *__arg;
int __canceltype;
struct _pthread_cleanup_buffer *__prev;
enum
PTHREAD_CANCEL_ENABLE,
PTHREAD_CANCEL_DISABLE
enum
PTHREAD_CANCEL_DEFERRED,
PTHREAD_CANCEL_ASYNCHRONOUS
# 229 "/usr/include/pthread.h" 3 4
extern int pthread_create (pthread_t *__restrict __newthread,
const pthread_attr_t *__restrict __attr,
void *(*__start_routine) (void *),
void *__restrict __arg) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3)));
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
extern int pthread_join (pthread_t __th, void **__thread_return);
# 272 "/usr/include/pthread.h" 3 4
extern int pthread_detach (pthread_t __th) __attribute__ ((__nothrow__ , __leaf__));
extern pthread_t pthread_self (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2)
extern int pthread_attr_init (pthread_attr_t *__attr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict __attr,
struct sched_param *__restrict __param)
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
const struct sched_param *__restrict
__param) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
__attr, int *__restrict __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
__attr, int *__restrict __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
int *__restrict __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
__attr, void **__restrict __stackaddr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
void *__stackaddr)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
__attr, size_t *__restrict __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
void **__restrict __stackaddr,
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
size_t __stacksize) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 430 "/usr/include/pthread.h" 3 4
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int pthread_getschedparam (pthread_t __target_thread,
int *__restrict __policy,
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
# 495 "/usr/include/pthread.h" 3 4
extern int pthread_once (pthread_once_t *__once_control,
void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
# 507 "/usr/include/pthread.h" 3 4
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
struct
__jmp_buf __cancel_jmp_buf;
int __mask_was_saved;
} __cancel_jmp_buf[1];
void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
# 541 "/usr/include/pthread.h" 3 4
struct __pthread_cleanup_frame
void (*__cancel_routine) (void *);
void *__cancel_arg;
int __do_it;
int __cancel_type;
# 681 "/usr/include/pthread.h" 3 4
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
# 693 "/usr/include/pthread.h" 3 4
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
# 734 "/usr/include/pthread.h" 3 4
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
__attribute__ ((__weak__))
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) __attribute__ ((__nothrow__));
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
__attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
__abstime) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
__restrict __mutex,
int *__restrict __prioceiling)
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
int __prioceiling,
int *__restrict __old_ceiling)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3)));
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
# 807 "/usr/include/pthread.h" 3 4
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
__restrict __attr,
int *__restrict __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
int __pshared)
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
__attr, int *__restrict __kind)
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
__restrict __attr,
int *__restrict __protocol)
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
int __protocol)
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
__restrict __attr,
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
int __prioceiling)
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
int *__robustness)
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
int __robustness)
# 889 "/usr/include/pthread.h" 3 4
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
const pthread_rwlockattr_t *__restrict
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
__restrict __attr,
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
__restrict __attr,
int *__restrict __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
int __pref) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
const pthread_condattr_t *__restrict __cond_attr)
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
pthread_mutex_t *__restrict __mutex)
# 1001 "/usr/include/pthread.h" 3 4
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
const struct timespec *__restrict __abstime)
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
__restrict __attr,
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
int __pshared) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_condattr_getclock (const pthread_condattr_t *
__restrict __attr,
__clockid_t *__restrict __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
__clockid_t __clock_id)
# 1045 "/usr/include/pthread.h" 3 4
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
const pthread_barrierattr_t *__restrict
__attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
__restrict __attr,
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
int __pshared)
# 1112 "/usr/include/pthread.h" 3 4
extern int pthread_key_create (pthread_key_t *__key,
void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern void *pthread_getspecific (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_setspecific (pthread_key_t __key,
const void *__pointer) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
__clockid_t *__clock_id)
# 1146 "/usr/include/pthread.h" 3 4
extern int pthread_atfork (void (*__prepare) (void),
void (*__parent) (void),
void (*__child) (void)) __attribute__ ((__nothrow__ , __leaf__));
# 1160 "/usr/include/pthread.h" 3 4
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_PTHREAD_H" to "1"
TEST check from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: setjmp.h
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 1 "/usr/include/setjmp.h" 1 3 4
# 25 "/usr/include/setjmp.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/setjmp.h" 2 3 4
# 31 "/usr/include/bits/setjmp.h" 3 4
# 30 "/usr/include/setjmp.h" 2 3 4
typedef struct
} __sigset_t;
# 31 "/usr/include/setjmp.h" 2 3 4
__jmp_buf __jmpbuf;
__sigset_t __saved_mask;
typedef struct __jmp_buf_tag jmp_buf[1];
extern int setjmp (jmp_buf __env) __attribute__ ((__nothrow__));
extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) __attribute__ ((__nothrow__));
extern int _setjmp (struct __jmp_buf_tag __env[1]) __attribute__ ((__nothrow__));
# 67 "/usr/include/setjmp.h" 3 4
extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
__attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
typedef struct __jmp_buf_tag sigjmp_buf[1];
# 93 "/usr/include/setjmp.h" 3 4
extern void siglongjmp (sigjmp_buf __env, int __val)
# 103 "/usr/include/setjmp.h" 3 4
Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/utsname.h" 1 3 4
# 25 "/usr/include/sys/utsname.h" 3 4
# 26 "/usr/include/sys/utsname.h" 2 3 4
# 1 "/usr/include/bits/utsname.h" 1 3 4
# 30 "/usr/include/sys/utsname.h" 2 3 4
# 48 "/usr/include/sys/utsname.h" 3 4
struct utsname
char sysname[65];
char nodename[65];
char release[65];
char version[65];
char machine[65];
char __domainname[65];
# 81 "/usr/include/sys/utsname.h" 3 4
extern int uname (struct utsname *__name) __attribute__ ((__nothrow__ , __leaf__));
Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: machine/endian.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2stderr:
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory
#include <machine/endian.h>
Source:
#include "confdefs.h"
#include "conffix.h"
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory #include <machine/endian.h> ^~~~~~~~~~~~~~~~~~compilation terminated.:
Checking for header: limits.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/syslimits.h" 1 3 4
# 194 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 26 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/libc-header-start.h" 1 3 4
# 27 "/usr/include/limits.h" 2 3 4
# 183 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/posix1_lim.h" 1 3 4
# 27 "/usr/include/bits/posix1_lim.h" 3 4
# 28 "/usr/include/bits/posix1_lim.h" 2 3 4
# 161 "/usr/include/bits/posix1_lim.h" 3 4
# 1 "/usr/include/bits/local_lim.h" 1 3 4
# 38 "/usr/include/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 39 "/usr/include/bits/local_lim.h" 2 3 4
# 162 "/usr/include/bits/posix1_lim.h" 2 3 4
# 184 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/posix2_lim.h" 1 3 4
# 188 "/usr/include/limits.h" 2 3 4
# 195 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include-fixed/limits.h" 2 3 4
Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/fcntl.h" 1 3 4
# 25 "/usr/include/fcntl.h" 3 4
# 26 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
# 30 "/usr/include/bits/types.h" 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef __int8_t __int_least8_t;
typedef __uint8_t __uint_least8_t;
typedef __int16_t __int_least16_t;
typedef __uint16_t __uint_least16_t;
typedef __int32_t __int_least32_t;
typedef __uint32_t __uint_least32_t;
typedef __int64_t __int_least64_t;
typedef __uint64_t __uint_least64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
typedef long int __intmax_t;
typedef unsigned long int __uintmax_t;
# 140 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 141 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef int __sig_atomic_t;
# 32 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/fcntl.h" 1 3 4
# 35 "/usr/include/bits/fcntl.h" 3 4
struct flock
short int l_type;
short int l_whence;
__off_t l_start;
__off_t l_len;
__pid_t l_pid;
# 61 "/usr/include/bits/fcntl.h" 3 4
# 1 "/usr/include/bits/fcntl-linux.h" 1 3 4
# 362 "/usr/include/bits/fcntl-linux.h" 3 4
# 436 "/usr/include/bits/fcntl-linux.h" 3 4
# 61 "/usr/include/bits/fcntl.h" 2 3 4
# 36 "/usr/include/fcntl.h" 2 3 4
# 50 "/usr/include/fcntl.h" 3 4
# 69 "/usr/include/fcntl.h" 3 4
typedef __pid_t pid_t;
# 1 "/usr/include/bits/types/struct_timespec.h" 1 3 4
# 9 "/usr/include/bits/types/struct_timespec.h" 3 4
struct timespec
__time_t tv_sec;
__syscall_slong_t tv_nsec;
# 76 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/stat.h" 1 3 4
# 46 "/usr/include/bits/stat.h" 3 4
struct stat
__dev_t st_dev;
__ino_t st_ino;
__nlink_t st_nlink;
__mode_t st_mode;
__uid_t st_uid;
__gid_t st_gid;
int __pad0;
__dev_t st_rdev;
__off_t st_size;
__blksize_t st_blksize;
__blkcnt_t st_blocks;
# 91 "/usr/include/bits/stat.h" 3 4
struct timespec st_atim;
struct timespec st_mtim;
struct timespec st_ctim;
# 106 "/usr/include/bits/stat.h" 3 4
__syscall_slong_t __glibc_reserved[3];
# 115 "/usr/include/bits/stat.h" 3 4
# 79 "/usr/include/fcntl.h" 2 3 4
# 175 "/usr/include/fcntl.h" 3 4
extern int fcntl (int __fd, int __cmd, ...);
# 195 "/usr/include/fcntl.h" 3 4
extern int open (const char *__file, int __oflag, ...) __attribute__ ((__nonnull__ (1)));
# 219 "/usr/include/fcntl.h" 3 4
extern int openat (int __fd, const char *__file, int __oflag, ...)
# 241 "/usr/include/fcntl.h" 3 4
extern int creat (const char *__file, mode_t __mode) __attribute__ ((__nonnull__ (1)));
# 270 "/usr/include/fcntl.h" 3 4
extern int lockf (int __fd, int __cmd, off_t __len);
# 287 "/usr/include/fcntl.h" 3 4
extern int posix_fadvise (int __fd, off_t __offset, off_t __len,
int __advise) __attribute__ ((__nothrow__ , __leaf__));
# 309 "/usr/include/fcntl.h" 3 4
extern int posix_fallocate (int __fd, off_t __offset, off_t __len);
# 331 "/usr/include/fcntl.h" 3 4
Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/string.h" 1 3 4
# 26 "/usr/include/string.h" 3 4
# 27 "/usr/include/string.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 34 "/usr/include/string.h" 2 3 4
# 42 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 90 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 121 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
# 1 "/usr/include/bits/types/locale_t.h" 1 3 4
# 22 "/usr/include/bits/types/locale_t.h" 3 4
# 1 "/usr/include/bits/types/__locale_t.h" 1 3 4
# 28 "/usr/include/bits/types/__locale_t.h" 3 4
struct __locale_struct
struct __locale_data *__locales[13];
const unsigned short int *__ctype_b;
const int *__ctype_tolower;
const int *__ctype_toupper;
const char *__names[13];
typedef struct __locale_struct *__locale_t;
# 23 "/usr/include/bits/types/locale_t.h" 2 3 4
typedef __locale_t locale_t;
# 153 "/usr/include/string.h" 2 3 4
extern int strcoll_l (const char *__s1, const char *__s2, locale_t __l)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 225 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 252 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 272 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 302 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 329 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
const char *__restrict __delim,
char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 384 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 409 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 427 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/strings.h" 1 3 4
# 23 "/usr/include/strings.h" 3 4
# 24 "/usr/include/strings.h" 2 3 4
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 68 "/usr/include/strings.h" 3 4
extern char *index (const char *__s, int __c)
# 96 "/usr/include/strings.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int ffsl (long int __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__ extern int ffsll (long long int __ll)
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
extern int strcasecmp_l (const char *__s1, const char *__s2, locale_t __loc)
extern int strncasecmp_l (const char *__s1, const char *__s2,
size_t __n, locale_t __loc)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
# 432 "/usr/include/string.h" 2 3 4
extern void explicit_bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 498 "/usr/include/string.h" 3 4
Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/times.h" 1 3 4
# 25 "/usr/include/sys/times.h" 3 4
# 26 "/usr/include/sys/times.h" 2 3 4
# 5 "/usr/include/bits/types/clock_t.h" 2 3 4
# 28 "/usr/include/sys/times.h" 2 3 4
struct tms
clock_t tms_utime;
clock_t tms_stime;
clock_t tms_cutime;
clock_t tms_cstime;
extern clock_t times (struct tms *__buffer) __attribute__ ((__nothrow__ , __leaf__));
Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory
#include <io.h>
Source:
#include <io.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory
#include <io.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory #include <io.h> ^~~~~~compilation terminated.:
Checking for header: stdint.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 26 "/usr/include/stdint.h" 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 29 "/usr/include/stdint.h" 2 3 4
# 30 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/stdint-intn.h" 1 3 4
# 24 "/usr/include/bits/stdint-intn.h" 3 4
typedef __int8_t int8_t;
typedef __int16_t int16_t;
typedef __int32_t int32_t;
typedef __int64_t int64_t;
# 35 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/stdint-uintn.h" 1 3 4
# 24 "/usr/include/bits/stdint-uintn.h" 3 4
typedef __uint8_t uint8_t;
typedef __uint16_t uint16_t;
typedef __uint32_t uint32_t;
typedef __uint64_t uint64_t;
# 38 "/usr/include/stdint.h" 2 3 4
typedef __int_least8_t int_least8_t;
typedef __int_least16_t int_least16_t;
typedef __int_least32_t int_least32_t;
typedef __int_least64_t int_least64_t;
typedef __uint_least8_t uint_least8_t;
typedef __uint_least16_t uint_least16_t;
typedef __uint_least32_t uint_least32_t;
typedef __uint_least64_t uint_least64_t;
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 71 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 87 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 101 "/usr/include/stdint.h" 3 4
typedef __intmax_t intmax_t;
typedef __uintmax_t uintmax_t;
# 10 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stdint.h" 2 3 4
Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/pwd.h" 1 3 4
# 25 "/usr/include/pwd.h" 3 4
# 26 "/usr/include/pwd.h" 2 3 4
# 30 "/usr/include/pwd.h" 2 3 4
# 33 "/usr/include/pwd.h" 2 3 4
typedef __uid_t uid_t;
struct passwd
char *pw_name;
char *pw_passwd;
__uid_t pw_uid;
__gid_t pw_gid;
char *pw_gecos;
char *pw_dir;
char *pw_shell;
# 1 "/usr/include/bits/types/FILE.h" 1 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/pwd.h" 2 3 4
# 72 "/usr/include/pwd.h" 3 4
extern void setpwent (void);
extern void endpwent (void);
extern struct passwd *getpwent (void);
# 94 "/usr/include/pwd.h" 3 4
extern struct passwd *fgetpwent (FILE *__stream) __attribute__ ((__nonnull__ (1)));
extern int putpwent (const struct passwd *__restrict __p,
FILE *__restrict __f);
extern struct passwd *getpwuid (__uid_t __uid);
extern struct passwd *getpwnam (const char *__name) __attribute__ ((__nonnull__ (1)));
# 139 "/usr/include/pwd.h" 3 4
extern int getpwent_r (struct passwd *__restrict __resultbuf,
char *__restrict __buffer, size_t __buflen,
struct passwd **__restrict __result)
extern int getpwuid_r (__uid_t __uid,
__attribute__ ((__nonnull__ (2, 3, 5)));
extern int getpwnam_r (const char *__restrict __name,
__attribute__ ((__nonnull__ (1, 2, 3, 5)));
# 166 "/usr/include/pwd.h" 3 4
extern int fgetpwent_r (FILE *__restrict __stream,
# 187 "/usr/include/pwd.h" 3 4
Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/float.h" 1 3 4
Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/param.h" 1 3 4
# 23 "/usr/include/sys/param.h" 3 4
# 24 "/usr/include/sys/param.h" 2 3 4
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/time_t.h" 1 3 4
typedef __time_t time_t;
return __x;
return __x;
return __x;
# 1 "/usr/include/bits/types/sigset_t.h" 1 3 4
# 1 "/usr/include/bits/types/__sigset_t.h" 1 3 4
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
# 5 "/usr/include/bits/types/sigset_t.h" 2 3 4
typedef __sigset_t sigset_t;
struct timeval
__time_t tv_sec;
struct timespec
__time_t tv_sec;
typedef struct
} fd_set;
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
union pthread_attr_t
char __size[56];
long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
# 26 "/usr/include/sys/param.h" 2 3 4
# 27 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 27 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/signum.h" 1 3 4
# 26 "/usr/include/bits/signum.h" 3 4
# 1 "/usr/include/bits/signum-generic.h" 1 3 4
# 27 "/usr/include/bits/signum.h" 2 3 4
# 31 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sig_atomic_t.h" 1 3 4
typedef __sig_atomic_t sig_atomic_t;
# 33 "/usr/include/signal.h" 2 3 4
# 57 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/types/siginfo_t.h" 1 3 4
# 5 "/usr/include/bits/types/siginfo_t.h" 2 3 4
# 1 "/usr/include/bits/types/__sigval_t.h" 1 3 4
# 24 "/usr/include/bits/types/__sigval_t.h" 3 4
union sigval
int sival_int;
void *sival_ptr;
typedef union sigval __sigval_t;
# 7 "/usr/include/bits/types/siginfo_t.h" 2 3 4
# 16 "/usr/include/bits/types/siginfo_t.h" 3 4
# 1 "/usr/include/bits/siginfo-arch.h" 1 3 4
# 17 "/usr/include/bits/types/siginfo_t.h" 2 3 4
# 36 "/usr/include/bits/types/siginfo_t.h" 3 4
typedef struct
int si_signo;
int si_errno;
int si_code;
int __pad0;
union
int _pad[((128 / sizeof (int)) - 4)];
struct
__pid_t si_pid;
__uid_t si_uid;
} _kill;
struct
int si_tid;
int si_overrun;
__sigval_t si_sigval;
} _timer;
struct
__pid_t si_pid;
__uid_t si_uid;
} _rt;
struct
__pid_t si_pid;
__uid_t si_uid;
int si_status;
__clock_t si_utime;
__clock_t si_stime;
} _sigchld;
struct
void *si_addr;
short int si_addr_lsb;
union
struct
void *_lower;
void *_upper;
} _addr_bnd;
__uint32_t _pkey;
} _bounds;
} _sigfault;
struct
long int si_band;
int si_fd;
} _sigpoll;
struct
void *_call_addr;
int _syscall;
unsigned int _arch;
} _sigsys;
} _sifields;
} siginfo_t ;
# 58 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/siginfo-consts.h" 1 3 4
# 35 "/usr/include/bits/siginfo-consts.h" 3 4
enum
SI_ASYNCNL = -60,
SI_TKILL = -6,
SI_SIGIO,
SI_ASYNCIO,
SI_MESGQ,
SI_TIMER,
SI_QUEUE,
SI_USER,
SI_KERNEL = 0x80
# 63 "/usr/include/bits/siginfo-consts.h" 3 4
enum
ILL_ILLOPC = 1,
ILL_ILLOPN,
ILL_ILLADR,
ILL_ILLTRP,
ILL_PRVOPC,
ILL_PRVREG,
ILL_COPROC,
ILL_BADSTK
enum
FPE_INTDIV = 1,
FPE_INTOVF,
FPE_FLTDIV,
FPE_FLTOVF,
FPE_FLTUND,
FPE_FLTRES,
FPE_FLTINV,
FPE_FLTSUB
enum
SEGV_MAPERR = 1,
SEGV_ACCERR,
SEGV_BNDERR,
SEGV_PKUERR
enum
BUS_ADRALN = 1,
BUS_ADRERR,
BUS_OBJERR,
BUS_MCEERR_AR,
BUS_MCEERR_AO
# 151 "/usr/include/bits/siginfo-consts.h" 3 4
enum
CLD_EXITED = 1,
CLD_KILLED,
CLD_DUMPED,
CLD_TRAPPED,
CLD_STOPPED,
CLD_CONTINUED
enum
POLL_IN = 1,
POLL_OUT,
POLL_MSG,
POLL_ERR,
POLL_PRI,
POLL_HUP
# 59 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sigval_t.h" 1 3 4
# 16 "/usr/include/bits/types/sigval_t.h" 3 4
typedef __sigval_t sigval_t;
# 63 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/sigevent_t.h" 1 3 4
# 5 "/usr/include/bits/types/sigevent_t.h" 2 3 4
# 22 "/usr/include/bits/types/sigevent_t.h" 3 4
typedef struct sigevent
__sigval_t sigev_value;
int sigev_signo;
int sigev_notify;
union
int _pad[((64 / sizeof (int)) - 4)];
__pid_t _tid;
struct
void (*_function) (__sigval_t);
pthread_attr_t *_attribute;
} _sigev_thread;
} _sigev_un;
} sigevent_t;
# 67 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/sigevent-consts.h" 1 3 4
# 27 "/usr/include/bits/sigevent-consts.h" 3 4
enum
SIGEV_SIGNAL = 0,
SIGEV_NONE,
SIGEV_THREAD,
SIGEV_THREAD_ID = 4
# 68 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 88 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 112 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, const char *__s);
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
# 170 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 190 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (const sigset_t *__set, int __signo)
# 226 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigaction.h" 1 3 4
# 27 "/usr/include/bits/sigaction.h" 3 4
struct sigaction
union
__sighandler_t sa_handler;
void (*sa_sigaction) (int, siginfo_t *, void *);
__sigaction_handler;
__sigset_t sa_mask;
int sa_flags;
void (*sa_restorer) (void);
# 227 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
extern int sigwaitinfo (const sigset_t *__restrict __set,
siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (const sigset_t *__restrict __set,
siginfo_t *__restrict __info,
const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
# 286 "/usr/include/signal.h" 3 4
extern const char *const _sys_siglist[(64 + 1)];
extern const char *const sys_siglist[(64 + 1)];
# 1 "/usr/include/bits/sigcontext.h" 1 3 4
# 31 "/usr/include/bits/sigcontext.h" 3 4
struct _fpx_sw_bytes
__uint32_t magic1;
__uint32_t extended_size;
__uint64_t xstate_bv;
__uint32_t xstate_size;
__uint32_t __glibc_reserved1[7];
struct _fpreg
unsigned short significand[4];
unsigned short exponent;
struct _fpxreg
unsigned short __glibc_reserved1[3];
struct _xmmreg
__uint32_t element[4];
# 123 "/usr/include/bits/sigcontext.h" 3 4
struct _fpstate
__uint16_t cwd;
__uint16_t swd;
__uint16_t ftw;
__uint16_t fop;
__uint64_t rip;
__uint64_t rdp;
__uint32_t mxcsr;
__uint32_t mxcr_mask;
struct _fpxreg _st[8];
struct _xmmreg _xmm[16];
__uint32_t __glibc_reserved1[24];
struct sigcontext
__uint64_t r8;
__uint64_t r9;
__uint64_t r10;
__uint64_t r11;
__uint64_t r12;
__uint64_t r13;
__uint64_t r14;
__uint64_t r15;
__uint64_t rdi;
__uint64_t rsi;
__uint64_t rbp;
__uint64_t rbx;
__uint64_t rdx;
__uint64_t rax;
__uint64_t rcx;
__uint64_t rsp;
__uint64_t rip;
__uint64_t eflags;
unsigned short cs;
unsigned short gs;
unsigned short fs;
unsigned short __pad0;
__uint64_t err;
__uint64_t trapno;
__uint64_t oldmask;
__uint64_t cr2;
__extension__ union
struct _fpstate * fpstate;
__uint64_t __fpstate_word;
__uint64_t __reserved1 [8];
struct _xsave_hdr
__uint64_t __glibc_reserved1[2];
__uint64_t __glibc_reserved2[5];
struct _ymmh_state
__uint32_t ymmh_space[64];
struct _xstate
struct _fpstate fpstate;
struct _xsave_hdr xstate_hdr;
struct _ymmh_state ymmh;
# 292 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 302 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/types/stack_t.h" 1 3 4
# 23 "/usr/include/bits/types/stack_t.h" 3 4
# 24 "/usr/include/bits/types/stack_t.h" 2 3 4
typedef struct
void *ss_sp;
int ss_flags;
size_t ss_size;
} stack_t;
# 304 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/sys/ucontext.h" 1 3 4
# 37 "/usr/include/sys/ucontext.h" 3 4
__extension__ typedef long long int greg_t;
# 46 "/usr/include/sys/ucontext.h" 3 4
typedef greg_t gregset_t[23];
# 101 "/usr/include/sys/ucontext.h" 3 4
struct _libc_fpxreg
unsigned short int significand[4];
unsigned short int exponent;
unsigned short int __glibc_reserved1[3];
struct _libc_xmmreg
struct _libc_fpstate
__uint16_t cwd;
__uint16_t swd;
__uint16_t ftw;
__uint16_t fop;
__uint64_t rip;
__uint64_t rdp;
__uint32_t mxcsr;
struct _libc_fpxreg _st[8];
struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
gregset_t gregs;
fpregset_t fpregs;
__extension__ unsigned long long __reserved1 [8];
} mcontext_t;
typedef struct ucontext_t
unsigned long int uc_flags;
struct ucontext_t *uc_link;
stack_t uc_stack;
mcontext_t uc_mcontext;
sigset_t uc_sigmask;
struct _libc_fpstate __fpregs_mem;
__extension__ unsigned long long int __ssp[4];
} ucontext_t;
# 307 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigstack.h" 1 3 4
# 317 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/ss_flags.h" 1 3 4
# 27 "/usr/include/bits/ss_flags.h" 3 4
enum
SS_ONSTACK = 1,
SS_DISABLE
# 318 "/usr/include/signal.h" 2 3 4
extern int sigaltstack (const stack_t *__restrict __ss,
stack_t *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/types/struct_sigstack.h" 1 3 4
# 23 "/usr/include/bits/types/struct_sigstack.h" 3 4
struct sigstack
void *ss_sp;
int ss_onstack;
# 328 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
# 359 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigthread.h" 1 3 4
# 31 "/usr/include/bits/sigthread.h" 3 4
extern int pthread_sigmask (int __how,
const __sigset_t *__restrict __newmask,
__sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__ , __leaf__));
extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__ , __leaf__));
# 360 "/usr/include/signal.h" 2 3 4
extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__ , __leaf__));
extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__ , __leaf__));
# 29 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/bits/param.h" 1 3 4
# 28 "/usr/include/bits/param.h" 3 4
# 1 "/usr/include/linux/param.h" 1 3 4
# 1 "/usr/include/asm/param.h" 1 3 4
# 1 "/usr/include/asm-generic/param.h" 1 3 4
# 1 "/usr/include/asm/param.h" 2 3 4
# 6 "/usr/include/linux/param.h" 2 3 4
# 29 "/usr/include/bits/param.h" 2 3 4
# 32 "/usr/include/sys/param.h" 2 3 4
Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/netdb.h" 1 3 4
# 25 "/usr/include/netdb.h" 3 4
# 26 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/netinet/in.h" 1 3 4
# 22 "/usr/include/netinet/in.h" 3 4
# 22 "/usr/include/bits/stdint-uintn.h" 3 4
# 23 "/usr/include/bits/stdint-uintn.h" 2 3 4
# 23 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/sys/socket.h" 1 3 4
# 24 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/bits/types/struct_iovec.h" 1 3 4
# 23 "/usr/include/bits/types/struct_iovec.h" 3 4
# 24 "/usr/include/bits/types/struct_iovec.h" 2 3 4
struct iovec
void *iov_base;
size_t iov_len;
# 27 "/usr/include/sys/socket.h" 2 3 4
# 29 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/bits/socket.h" 1 3 4
# 27 "/usr/include/bits/socket.h" 3 4
# 28 "/usr/include/bits/socket.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 59 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __off_t off_t;
# 97 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 1 "/usr/include/bits/types/clock_t.h" 1 3 4
typedef __clock_t clock_t;
# 127 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/clockid_t.h" 1 3 4
typedef __clockid_t clockid_t;
# 129 "/usr/include/sys/types.h" 2 3 4
# 130 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/timer_t.h" 1 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/sys/types.h" 2 3 4
# 144 "/usr/include/sys/types.h" 3 4
# 145 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 156 "/usr/include/sys/types.h" 2 3 4
# 177 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 193 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 33 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint16_t
__bswap_16 (__uint16_t __bsx)
return __builtin_bswap16 (__bsx);
static __inline __uint32_t
__bswap_32 (__uint32_t __bsx)
return __builtin_bswap32 (__bsx);
# 69 "/usr/include/bits/byteswap.h" 3 4
__extension__ static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/bits/uintn-identity.h" 1 3 4
# 32 "/usr/include/bits/uintn-identity.h" 3 4
__uint16_identity (__uint16_t __x)
return __x;
__uint32_identity (__uint32_t __x)
return __x;
__uint64_identity (__uint64_t __x)
return __x;
# 62 "/usr/include/endian.h" 2 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
typedef struct
} __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timeval.h" 1 3 4
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
# 38 "/usr/include/sys/select.h" 2 3 4
struct timespec
__time_t tv_sec;
# 40 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 59 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
# 91 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
fd_set *__restrict __writefds,
fd_set *__restrict __exceptfds,
struct timeval *__restrict __timeout);
# 113 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
const struct timespec *__restrict __timeout,
const __sigset_t *__restrict __sigmask);
# 126 "/usr/include/sys/select.h" 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 244 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/bits/pthreadtypes.h" 3 4
# 1 "/usr/include/bits/thread-shared-types.h" 1 3 4
# 77 "/usr/include/bits/thread-shared-types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes-arch.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 22 "/usr/include/bits/pthreadtypes-arch.h" 2 3 4
# 65 "/usr/include/bits/pthreadtypes-arch.h" 3 4
struct __pthread_rwlock_arch_t
unsigned int __readers;
unsigned int __writers;
unsigned int __wrphase_futex;
unsigned int __writers_futex;
unsigned int __pad3;
unsigned int __pad4;
int __cur_writer;
int __shared;
signed char __rwelision;
unsigned char __pad1[7];
unsigned long int __pad2;
unsigned int __flags;
# 99 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 78 "/usr/include/bits/thread-shared-types.h" 2 3 4
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
# 118 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_mutex_s
int __lock ;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
short __spins; short __elision;
__pthread_list_t __list;
# 145 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_cond_s
__extension__ union
__extension__ unsigned long long int __wseq;
struct
unsigned int __low;
unsigned int __high;
} __wseq32;
__extension__ union
__extension__ unsigned long long int __g1_start;
struct
unsigned int __low;
} __g1_start32;
unsigned int __g_refs[2] ;
unsigned int __g_size[2];
unsigned int __g1_orig_size;
unsigned int __wrefs;
unsigned int __g_signals[2];
# 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
typedef unsigned long int pthread_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
char __size[56];
long int __align;
typedef union
struct __pthread_mutex_s __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
struct __pthread_cond_s __data;
char __size[48];
__extension__ long long int __align;
} pthread_cond_t;
typedef union
struct __pthread_rwlock_arch_t __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
# 245 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
# 1 "/usr/include/bits/socket_type.h" 1 3 4
# 24 "/usr/include/bits/socket_type.h" 3 4
enum __socket_type
SOCK_STREAM = 1,
SOCK_DGRAM = 2,
SOCK_RAW = 3,
SOCK_RDM = 4,
SOCK_SEQPACKET = 5,
SOCK_DCCP = 6,
SOCK_PACKET = 10,
SOCK_CLOEXEC = 02000000,
SOCK_NONBLOCK = 00004000
# 39 "/usr/include/bits/socket.h" 2 3 4
# 172 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/bits/sockaddr.h" 1 3 4
# 28 "/usr/include/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 173 "/usr/include/bits/socket.h" 2 3 4
struct sockaddr
sa_family_t sa_family;
char sa_data[14];
# 188 "/usr/include/bits/socket.h" 3 4
struct sockaddr_storage
sa_family_t ss_family;
char __ss_padding[(128 - (sizeof (unsigned short int)) - sizeof (unsigned long int))];
unsigned long int __ss_align;
enum
MSG_OOB = 0x01,
MSG_PEEK = 0x02,
MSG_DONTROUTE = 0x04,
MSG_CTRUNC = 0x08,
MSG_PROXY = 0x10,
MSG_TRUNC = 0x20,
MSG_DONTWAIT = 0x40,
MSG_EOR = 0x80,
MSG_WAITALL = 0x100,
MSG_FIN = 0x200,
MSG_SYN = 0x400,
MSG_CONFIRM = 0x800,
MSG_RST = 0x1000,
MSG_ERRQUEUE = 0x2000,
MSG_NOSIGNAL = 0x4000,
MSG_MORE = 0x8000,
MSG_WAITFORONE = 0x10000,
MSG_BATCH = 0x40000,
MSG_ZEROCOPY = 0x4000000,
MSG_FASTOPEN = 0x20000000,
MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
void *msg_name;
socklen_t msg_namelen;
struct iovec *msg_iov;
size_t msg_iovlen;
void *msg_control;
size_t msg_controllen;
int msg_flags;
struct cmsghdr
size_t cmsg_len;
int cmsg_level;
int cmsg_type;
__extension__ unsigned char __cmsg_data [];
# 302 "/usr/include/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 329 "/usr/include/bits/socket.h" 3 4
enum
SCM_RIGHTS = 0x01
# 390 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 2 3 4
# 6 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/asm/socket.h" 2 3 4
# 391 "/usr/include/bits/socket.h" 2 3 4
# 444 "/usr/include/bits/socket.h" 3 4
struct linger
int l_onoff;
int l_linger;
# 34 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/bits/types/struct_osockaddr.h" 1 3 4
struct osockaddr
unsigned short int sa_family;
unsigned char sa_data[14];
# 37 "/usr/include/sys/socket.h" 2 3 4
enum
SHUT_RD = 0,
SHUT_WR,
SHUT_RDWR
# 102 "/usr/include/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/sys/socket.h" 3 4
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
int __flags, const struct sockaddr * __addr,
socklen_t __addr_len);
# 163 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
int __flags, struct sockaddr *__restrict __addr,
socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
int __flags);
# 191 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
# 208 "/usr/include/sys/socket.h" 3 4
extern int getsockopt (int __fd, int __level, int __optname,
void *__restrict __optval,
socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 232 "/usr/include/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 250 "/usr/include/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 272 "/usr/include/sys/socket.h" 3 4
# 24 "/usr/include/netinet/in.h" 2 3 4
typedef uint32_t in_addr_t;
struct in_addr
in_addr_t s_addr;
# 1 "/usr/include/bits/in.h" 1 3 4
# 142 "/usr/include/bits/in.h" 3 4
struct ip_opts
struct in_addr ip_dst;
char ip_opts[40];
struct ip_mreqn
struct in_addr imr_multiaddr;
struct in_addr imr_address;
int imr_ifindex;
struct in_pktinfo
int ipi_ifindex;
struct in_addr ipi_spec_dst;
struct in_addr ipi_addr;
# 38 "/usr/include/netinet/in.h" 2 3 4
enum
IPPROTO_IP = 0,
IPPROTO_ICMP = 1,
IPPROTO_IGMP = 2,
IPPROTO_IPIP = 4,
IPPROTO_TCP = 6,
IPPROTO_EGP = 8,
IPPROTO_PUP = 12,
IPPROTO_UDP = 17,
IPPROTO_IDP = 22,
IPPROTO_TP = 29,
IPPROTO_DCCP = 33,
IPPROTO_IPV6 = 41,
IPPROTO_RSVP = 46,
IPPROTO_GRE = 47,
IPPROTO_ESP = 50,
IPPROTO_AH = 51,
IPPROTO_MTP = 92,
IPPROTO_BEETPH = 94,
IPPROTO_ENCAP = 98,
IPPROTO_PIM = 103,
IPPROTO_COMP = 108,
IPPROTO_SCTP = 132,
IPPROTO_UDPLITE = 136,
IPPROTO_MPLS = 137,
IPPROTO_RAW = 255,
IPPROTO_MAX
enum
IPPROTO_HOPOPTS = 0,
IPPROTO_ROUTING = 43,
IPPROTO_FRAGMENT = 44,
IPPROTO_ICMPV6 = 58,
IPPROTO_NONE = 59,
IPPROTO_DSTOPTS = 60,
IPPROTO_MH = 135
typedef uint16_t in_port_t;
enum
IPPORT_ECHO = 7,
IPPORT_DISCARD = 9,
IPPORT_SYSTAT = 11,
IPPORT_DAYTIME = 13,
IPPORT_NETSTAT = 15,
IPPORT_FTP = 21,
IPPORT_TELNET = 23,
IPPORT_SMTP = 25,
IPPORT_TIMESERVER = 37,
IPPORT_NAMESERVER = 42,
IPPORT_WHOIS = 43,
IPPORT_MTP = 57,
IPPORT_TFTP = 69,
IPPORT_RJE = 77,
IPPORT_FINGER = 79,
IPPORT_TTYLINK = 87,
IPPORT_SUPDUP = 95,
IPPORT_EXECSERVER = 512,
IPPORT_LOGINSERVER = 513,
IPPORT_CMDSERVER = 514,
IPPORT_EFSSERVER = 520,
IPPORT_BIFFUDP = 512,
IPPORT_WHOSERVER = 513,
IPPORT_ROUTESERVER = 520,
IPPORT_RESERVED = 1024,
IPPORT_USERRESERVED = 5000
# 211 "/usr/include/netinet/in.h" 3 4
struct in6_addr
union
uint8_t __u6_addr8[16];
uint16_t __u6_addr16[8];
uint32_t __u6_addr32[4];
} __in6_u;
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
# 237 "/usr/include/netinet/in.h" 3 4
struct sockaddr_in
sa_family_t sin_family;
in_port_t sin_port;
struct in_addr sin_addr;
unsigned char sin_zero[sizeof (struct sockaddr) -
sizeof (in_port_t) -
sizeof (struct in_addr)];
struct sockaddr_in6
sa_family_t sin6_family;
in_port_t sin6_port;
uint32_t sin6_flowinfo;
struct in6_addr sin6_addr;
uint32_t sin6_scope_id;
struct ip_mreq
struct in_addr imr_interface;
struct ip_mreq_source
struct in_addr imr_sourceaddr;
struct ipv6_mreq
struct in6_addr ipv6mr_multiaddr;
unsigned int ipv6mr_interface;
struct group_req
uint32_t gr_interface;
struct sockaddr_storage gr_group;
struct group_source_req
uint32_t gsr_interface;
struct sockaddr_storage gsr_group;
struct sockaddr_storage gsr_source;
struct ip_msfilter
struct in_addr imsf_multiaddr;
struct in_addr imsf_interface;
uint32_t imsf_fmode;
uint32_t imsf_numsrc;
struct in_addr imsf_slist[1];
struct group_filter
uint32_t gf_interface;
struct sockaddr_storage gf_group;
uint32_t gf_fmode;
uint32_t gf_numsrc;
struct sockaddr_storage gf_slist[1];
# 374 "/usr/include/netinet/in.h" 3 4
extern uint32_t ntohl (uint32_t __netlong) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern uint16_t ntohs (uint16_t __netshort)
extern uint32_t htonl (uint32_t __hostlong)
extern uint16_t htons (uint16_t __hostshort)
# 386 "/usr/include/netinet/in.h" 2 3 4
# 387 "/usr/include/netinet/in.h" 2 3 4
# 502 "/usr/include/netinet/in.h" 3 4
extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) __attribute__ ((__nothrow__ , __leaf__));
extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
# 630 "/usr/include/netinet/in.h" 3 4
# 28 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/rpc/netdb.h" 1 3 4
# 42 "/usr/include/rpc/netdb.h" 3 4
# 43 "/usr/include/rpc/netdb.h" 2 3 4
struct rpcent
char *r_name;
char **r_aliases;
int r_number;
extern void setrpcent (int __stayopen) __attribute__ ((__nothrow__ , __leaf__));
extern void endrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbyname (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbynumber (int __number) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbyname_r (const char *__name, struct rpcent *__result_buf,
char *__buffer, size_t __buflen,
struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
size_t __buflen, struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
# 33 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/bits/netdb.h" 1 3 4
# 26 "/usr/include/bits/netdb.h" 3 4
struct netent
char *n_name;
char **n_aliases;
int n_addrtype;
uint32_t n_net;
# 41 "/usr/include/netdb.h" 2 3 4
# 51 "/usr/include/netdb.h" 3 4
extern int *__h_errno_location (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 90 "/usr/include/netdb.h" 3 4
extern void herror (const char *__str) __attribute__ ((__nothrow__ , __leaf__));
extern const char *hstrerror (int __err_num) __attribute__ ((__nothrow__ , __leaf__));
struct hostent
char *h_name;
char **h_aliases;
int h_addrtype;
int h_length;
char **h_addr_list;
extern void sethostent (int __stay_open);
extern void endhostent (void);
extern struct hostent *gethostent (void);
extern struct hostent *gethostbyaddr (const void *__addr, __socklen_t __len,
int __type);
extern struct hostent *gethostbyname (const char *__name);
# 153 "/usr/include/netdb.h" 3 4
extern struct hostent *gethostbyname2 (const char *__name, int __af);
# 165 "/usr/include/netdb.h" 3 4
extern int gethostent_r (struct hostent *__restrict __result_buf,
char *__restrict __buf, size_t __buflen,
struct hostent **__restrict __result,
int *__restrict __h_errnop);
extern int gethostbyaddr_r (const void *__restrict __addr, __socklen_t __len,
int __type,
extern int gethostbyname_r (const char *__restrict __name,
extern int gethostbyname2_r (const char *__restrict __name, int __af,
# 196 "/usr/include/netdb.h" 3 4
extern void setnetent (int __stay_open);
extern void endnetent (void);
extern struct netent *getnetent (void);
extern struct netent *getnetbyaddr (uint32_t __net, int __type);
extern struct netent *getnetbyname (const char *__name);
# 235 "/usr/include/netdb.h" 3 4
extern int getnetent_r (struct netent *__restrict __result_buf,
struct netent **__restrict __result,
extern int getnetbyaddr_r (uint32_t __net, int __type,
extern int getnetbyname_r (const char *__restrict __name,
struct servent
char *s_name;
char **s_aliases;
int s_port;
char *s_proto;
extern void setservent (int __stay_open);
extern void endservent (void);
extern struct servent *getservent (void);
extern struct servent *getservbyname (const char *__name, const char *__proto);
extern struct servent *getservbyport (int __port, const char *__proto);
# 306 "/usr/include/netdb.h" 3 4
extern int getservent_r (struct servent *__restrict __result_buf,
struct servent **__restrict __result);
extern int getservbyname_r (const char *__restrict __name,
const char *__restrict __proto,
extern int getservbyport_r (int __port, const char *__restrict __proto,
struct protoent
char *p_name;
char **p_aliases;
int p_proto;
extern void setprotoent (int __stay_open);
extern void endprotoent (void);
extern struct protoent *getprotoent (void);
extern struct protoent *getprotobyname (const char *__name);
extern struct protoent *getprotobynumber (int __proto);
# 372 "/usr/include/netdb.h" 3 4
extern int getprotoent_r (struct protoent *__restrict __result_buf,
struct protoent **__restrict __result);
extern int getprotobyname_r (const char *__restrict __name,
extern int getprotobynumber_r (int __proto,
# 393 "/usr/include/netdb.h" 3 4
extern int setnetgrent (const char *__netgroup);
extern void endnetgrent (void);
# 410 "/usr/include/netdb.h" 3 4
extern int getnetgrent (char **__restrict __hostp,
char **__restrict __userp,
char **__restrict __domainp);
# 421 "/usr/include/netdb.h" 3 4
extern int innetgr (const char *__netgroup, const char *__host,
const char *__user, const char *__domain);
extern int getnetgrent_r (char **__restrict __hostp,
char **__restrict __domainp,
char *__restrict __buffer, size_t __buflen);
# 449 "/usr/include/netdb.h" 3 4
extern int rcmd (char **__restrict __ahost, unsigned short int __rport,
const char *__restrict __locuser,
const char *__restrict __remuser,
const char *__restrict __cmd, int *__restrict __fd2p);
# 461 "/usr/include/netdb.h" 3 4
extern int rcmd_af (char **__restrict __ahost, unsigned short int __rport,
const char *__restrict __cmd, int *__restrict __fd2p,
sa_family_t __af);
# 477 "/usr/include/netdb.h" 3 4
extern int rexec (char **__restrict __ahost, int __rport,
const char *__restrict __pass,
# 489 "/usr/include/netdb.h" 3 4
extern int rexec_af (char **__restrict __ahost, int __rport,
sa_family_t __af);
# 503 "/usr/include/netdb.h" 3 4
extern int ruserok (const char *__rhost, int __suser,
const char *__remuser, const char *__locuser);
# 513 "/usr/include/netdb.h" 3 4
extern int ruserok_af (const char *__rhost, int __suser,
const char *__remuser, const char *__locuser,
sa_family_t __af);
# 526 "/usr/include/netdb.h" 3 4
extern int iruserok (uint32_t __raddr, int __suser,
# 537 "/usr/include/netdb.h" 3 4
extern int iruserok_af (const void *__raddr, int __suser,
sa_family_t __af);
# 549 "/usr/include/netdb.h" 3 4
extern int rresvport (int *__alport);
# 558 "/usr/include/netdb.h" 3 4
extern int rresvport_af (int *__alport, sa_family_t __af);
struct addrinfo
int ai_flags;
int ai_family;
int ai_socktype;
int ai_protocol;
socklen_t ai_addrlen;
struct sockaddr *ai_addr;
char *ai_canonname;
struct addrinfo *ai_next;
# 660 "/usr/include/netdb.h" 3 4
extern int getaddrinfo (const char *__restrict __name,
const char *__restrict __service,
const struct addrinfo *__restrict __req,
struct addrinfo **__restrict __pai);
extern void freeaddrinfo (struct addrinfo *__ai) __attribute__ ((__nothrow__ , __leaf__));
extern const char *gai_strerror (int __ecode) __attribute__ ((__nothrow__ , __leaf__));
extern int getnameinfo (const struct sockaddr *__restrict __sa,
socklen_t __salen, char *__restrict __host,
socklen_t __hostlen, char *__restrict __serv,
socklen_t __servlen, int __flags);
# 711 "/usr/include/netdb.h" 3 4
Defined "HAVE_NETDB_H" to "1"
Checking for header: search.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/search.h" 1 3 4
# 22 "/usr/include/search.h" 3 4
# 23 "/usr/include/search.h" 2 3 4
# 26 "/usr/include/search.h" 2 3 4
# 44 "/usr/include/search.h" 3 4
extern void insque (void *__elem, void *__prev) __attribute__ ((__nothrow__ , __leaf__));
extern void remque (void *__elem) __attribute__ ((__nothrow__ , __leaf__));
typedef int (*__compar_fn_t) (const void *, const void *);
typedef enum
FIND,
ENTER
ACTION;
typedef struct entry
char *key;
void *data;
ENTRY;
struct _ENTRY;
# 87 "/usr/include/search.h" 3 4
extern ENTRY *hsearch (ENTRY __item, ACTION __action) __attribute__ ((__nothrow__ , __leaf__));
extern int hcreate (size_t __nel) __attribute__ ((__nothrow__ , __leaf__));
extern void hdestroy (void) __attribute__ ((__nothrow__ , __leaf__));
# 118 "/usr/include/search.h" 3 4
typedef enum
preorder,
postorder,
endorder,
leaf
VISIT;
extern void *tsearch (const void *__key, void **__rootp,
__compar_fn_t __compar);
extern void *tfind (const void *__key, void *const *__rootp,
extern void *tdelete (const void *__restrict __key,
void **__restrict __rootp,
typedef void (*__action_fn_t) (const void *__nodep, VISIT __value,
int __level);
extern void twalk (const void *__root, __action_fn_t __action);
# 164 "/usr/include/search.h" 3 4
extern void *lfind (const void *__key, const void *__base,
size_t *__nmemb, size_t __size, __compar_fn_t __compar);
extern void *lsearch (const void *__key, void *__base,
Defined "HAVE_SEARCH_H" to "1"
Checking for header: sys/procfs.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/procfs.h" 1 3 4
# 30 "/usr/include/sys/procfs.h" 3 4
# 31 "/usr/include/sys/procfs.h" 2 3 4
# 1 "/usr/include/sys/time.h" 1 3 4
# 23 "/usr/include/sys/time.h" 3 4
# 24 "/usr/include/sys/time.h" 2 3 4
# 25 "/usr/include/sys/time.h" 2 3 4
struct timeval
__time_t tv_sec;
# 26 "/usr/include/sys/time.h" 2 3 4
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
# 49 "/usr/include/sys/select.h" 3 4
typedef struct
} fd_set;
# 33 "/usr/include/sys/time.h" 2 3 4
# 52 "/usr/include/sys/time.h" 3 4
struct timezone
int tz_minuteswest;
int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 68 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
__timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
ITIMER_REAL = 0,
ITIMER_VIRTUAL = 1,
ITIMER_PROF = 2
struct itimerval
struct timeval it_interval;
struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
const struct itimerval *__restrict __new,
struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 186 "/usr/include/sys/time.h" 3 4
# 32 "/usr/include/sys/procfs.h" 2 3 4
return __x;
return __x;
return __x;
# 202 "/usr/include/sys/types.h" 3 4
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
char __size[56];
long int __align;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
# 33 "/usr/include/sys/procfs.h" 2 3 4
# 1 "/usr/include/sys/user.h" 1 3 4
# 27 "/usr/include/sys/user.h" 3 4
struct user_fpregs_struct
unsigned short int cwd;
unsigned short int swd;
unsigned short int ftw;
unsigned short int fop;
__extension__ unsigned long long int rip;
__extension__ unsigned long long int rdp;
unsigned int mxcsr;
unsigned int mxcr_mask;
unsigned int st_space[32];
unsigned int xmm_space[64];
unsigned int padding[24];
struct user_regs_struct
__extension__ unsigned long long int r15;
__extension__ unsigned long long int r14;
__extension__ unsigned long long int r13;
__extension__ unsigned long long int r12;
__extension__ unsigned long long int rbp;
__extension__ unsigned long long int rbx;
__extension__ unsigned long long int r11;
__extension__ unsigned long long int r10;
__extension__ unsigned long long int r9;
__extension__ unsigned long long int r8;
__extension__ unsigned long long int rax;
__extension__ unsigned long long int rcx;
__extension__ unsigned long long int rdx;
__extension__ unsigned long long int rsi;
__extension__ unsigned long long int rdi;
__extension__ unsigned long long int orig_rax;
__extension__ unsigned long long int cs;
__extension__ unsigned long long int eflags;
__extension__ unsigned long long int rsp;
__extension__ unsigned long long int ss;
__extension__ unsigned long long int fs_base;
__extension__ unsigned long long int gs_base;
__extension__ unsigned long long int ds;
__extension__ unsigned long long int es;
__extension__ unsigned long long int fs;
__extension__ unsigned long long int gs;
struct user
struct user_regs_struct regs;
int u_fpvalid;
struct user_fpregs_struct i387;
__extension__ unsigned long long int u_tsize;
__extension__ unsigned long long int u_dsize;
__extension__ unsigned long long int u_ssize;
__extension__ unsigned long long int start_code;
__extension__ unsigned long long int start_stack;
__extension__ long long int signal;
int reserved;
__extension__ union
struct user_regs_struct* u_ar0;
__extension__ unsigned long long int __u_ar0_word;
__extension__ union
struct user_fpregs_struct* u_fpstate;
__extension__ unsigned long long int __u_fpstate_word;
__extension__ unsigned long long int magic;
char u_comm [32];
__extension__ unsigned long long int u_debugreg [8];
# 34 "/usr/include/sys/procfs.h" 2 3 4
__extension__ typedef unsigned long long elf_greg_t;
# 49 "/usr/include/sys/procfs.h" 3 4
typedef elf_greg_t elf_gregset_t[(sizeof (struct user_regs_struct) / sizeof(elf_greg_t))];
# 63 "/usr/include/sys/procfs.h" 3 4
typedef struct user_fpregs_struct elf_fpregset_t;
struct elf_siginfo
int si_signo;
int si_code;
int si_errno;
# 82 "/usr/include/sys/procfs.h" 3 4
struct elf_prstatus
struct elf_siginfo pr_info;
short int pr_cursig;
unsigned long int pr_sigpend;
unsigned long int pr_sighold;
__pid_t pr_pid;
__pid_t pr_ppid;
__pid_t pr_pgrp;
__pid_t pr_sid;
struct timeval pr_utime;
struct timeval pr_stime;
struct timeval pr_cutime;
struct timeval pr_cstime;
elf_gregset_t pr_reg;
int pr_fpvalid;
struct elf_prpsinfo
char pr_state;
char pr_sname;
char pr_zomb;
char pr_nice;
unsigned long int pr_flag;
unsigned int pr_uid;
unsigned int pr_gid;
int pr_pid, pr_ppid, pr_pgrp, pr_sid;
char pr_fname[16];
char pr_psargs[(80)];
typedef void *psaddr_t;
typedef elf_gregset_t prgregset_t;
typedef elf_fpregset_t prfpregset_t;
typedef __pid_t lwpid_t;
typedef struct elf_prstatus prstatus_t;
typedef struct elf_prpsinfo prpsinfo_t;
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_SYS_PROCFS_H" to "1"
TEST check from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/resource.h
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 1 "/usr/include/sys/resource.h" 1 3 4
# 21 "/usr/include/sys/resource.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 22 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/bits/resource.h" 1 3 4
# 23 "/usr/include/bits/resource.h" 3 4
# 24 "/usr/include/bits/resource.h" 2 3 4
enum __rlimit_resource
RLIMIT_CPU = 0,
RLIMIT_FSIZE = 1,
RLIMIT_DATA = 2,
RLIMIT_STACK = 3,
RLIMIT_CORE = 4,
__RLIMIT_RSS = 5,
RLIMIT_NOFILE = 7,
__RLIMIT_OFILE = RLIMIT_NOFILE,
RLIMIT_AS = 9,
__RLIMIT_NPROC = 6,
__RLIMIT_MEMLOCK = 8,
__RLIMIT_LOCKS = 10,
__RLIMIT_SIGPENDING = 11,
__RLIMIT_MSGQUEUE = 12,
__RLIMIT_NICE = 13,
__RLIMIT_RTPRIO = 14,
__RLIMIT_RTTIME = 15,
__RLIMIT_NLIMITS = 16,
__RLIM_NLIMITS = __RLIMIT_NLIMITS
# 131 "/usr/include/bits/resource.h" 3 4
typedef __rlim_t rlim_t;
struct rlimit
rlim_t rlim_cur;
rlim_t rlim_max;
# 158 "/usr/include/bits/resource.h" 3 4
enum __rusage_who
RUSAGE_SELF = 0,
RUSAGE_CHILDREN = -1
# 176 "/usr/include/bits/resource.h" 3 4
struct timeval
__time_t tv_sec;
# 179 "/usr/include/bits/resource.h" 2 3 4
# 1 "/usr/include/bits/types/struct_rusage.h" 1 3 4
# 31 "/usr/include/bits/types/struct_rusage.h" 3 4
struct rusage
struct timeval ru_utime;
struct timeval ru_stime;
__extension__ union
long int ru_maxrss;
__syscall_slong_t __ru_maxrss_word;
__extension__ union
long int ru_ixrss;
__syscall_slong_t __ru_ixrss_word;
__extension__ union
long int ru_idrss;
__syscall_slong_t __ru_idrss_word;
__extension__ union
long int ru_isrss;
__syscall_slong_t __ru_isrss_word;
__extension__ union
long int ru_minflt;
__syscall_slong_t __ru_minflt_word;
__extension__ union
long int ru_majflt;
__syscall_slong_t __ru_majflt_word;
__extension__ union
long int ru_nswap;
__syscall_slong_t __ru_nswap_word;
__extension__ union
long int ru_inblock;
__syscall_slong_t __ru_inblock_word;
__extension__ union
long int ru_oublock;
__syscall_slong_t __ru_oublock_word;
__extension__ union
long int ru_msgsnd;
__syscall_slong_t __ru_msgsnd_word;
__extension__ union
long int ru_msgrcv;
__syscall_slong_t __ru_msgrcv_word;
__extension__ union
long int ru_nsignals;
__syscall_slong_t __ru_nsignals_word;
__extension__ union
long int ru_nvcsw;
__syscall_slong_t __ru_nvcsw_word;
__extension__ union
long int ru_nivcsw;
__syscall_slong_t __ru_nivcsw_word;
# 180 "/usr/include/bits/resource.h" 2 3 4
enum __priority_which
PRIO_PROCESS = 0,
PRIO_PGRP = 1,
PRIO_USER = 2
# 223 "/usr/include/bits/resource.h" 3 4
# 25 "/usr/include/sys/resource.h" 2 3 4
# 42 "/usr/include/sys/resource.h" 3 4
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 69 "/usr/include/sys/resource.h" 3 4
extern int setrlimit (__rlimit_resource_t __resource,
const struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 87 "/usr/include/sys/resource.h" 3 4
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__ , __leaf__));
extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__ , __leaf__));
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/unistd.h" 1 3 4
# 25 "/usr/include/unistd.h" 3 4
# 26 "/usr/include/unistd.h" 2 3 4
# 202 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/bits/posix_opt.h" 1 3 4
# 203 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/bits/environments.h" 1 3 4
# 22 "/usr/include/bits/environments.h" 3 4
# 23 "/usr/include/bits/environments.h" 2 3 4
# 207 "/usr/include/unistd.h" 2 3 4
# 217 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
# 30 "/usr/include/bits/types.h" 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef __int8_t __int_least8_t;
typedef __uint8_t __uint_least8_t;
typedef __int16_t __int_least16_t;
typedef __uint16_t __uint_least16_t;
typedef __int32_t __int_least32_t;
typedef __uint32_t __uint_least32_t;
typedef __int64_t __int_least64_t;
typedef __uint64_t __uint_least64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
typedef long int __intmax_t;
typedef unsigned long int __uintmax_t;
# 140 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 141 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef int __sig_atomic_t;
# 218 "/usr/include/unistd.h" 2 3 4
# 227 "/usr/include/unistd.h" 2 3 4
# 255 "/usr/include/unistd.h" 3 4
typedef __useconds_t useconds_t;
typedef __pid_t pid_t;
typedef __intptr_t intptr_t;
# 287 "/usr/include/unistd.h" 3 4
extern int access (const char *__name, int __type) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 304 "/usr/include/unistd.h" 3 4
extern int faccessat (int __fd, const char *__file, int __type, int __flag)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
# 334 "/usr/include/unistd.h" 3 4
extern __off_t lseek (int __fd, __off_t __offset, int __whence) __attribute__ ((__nothrow__ , __leaf__));
# 353 "/usr/include/unistd.h" 3 4
extern int close (int __fd);
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
extern ssize_t write (int __fd, const void *__buf, size_t __n) ;
# 376 "/usr/include/unistd.h" 3 4
extern ssize_t pread (int __fd, void *__buf, size_t __nbytes,
__off_t __offset) ;
extern ssize_t pwrite (int __fd, const void *__buf, size_t __n,
__off_t __offset) ;
# 417 "/usr/include/unistd.h" 3 4
extern int pipe (int __pipedes[2]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 432 "/usr/include/unistd.h" 3 4
extern unsigned int alarm (unsigned int __seconds) __attribute__ ((__nothrow__ , __leaf__));
# 444 "/usr/include/unistd.h" 3 4
extern unsigned int sleep (unsigned int __seconds);
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
extern int usleep (__useconds_t __useconds);
# 469 "/usr/include/unistd.h" 3 4
extern int pause (void);
extern int chown (const char *__file, __uid_t __owner, __gid_t __group)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchown (int __fd, __uid_t __owner, __gid_t __group) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int lchown (const char *__file, __uid_t __owner, __gid_t __group)
extern int fchownat (int __fd, const char *__file, __uid_t __owner,
__gid_t __group, int __flag)
extern int chdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchdir (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
# 511 "/usr/include/unistd.h" 3 4
extern char *getcwd (char *__buf, size_t __size) __attribute__ ((__nothrow__ , __leaf__)) ;
# 525 "/usr/include/unistd.h" 3 4
extern char *getwd (char *__buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__)) ;
extern int dup (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int dup2 (int __fd, int __fd2) __attribute__ ((__nothrow__ , __leaf__));
# 543 "/usr/include/unistd.h" 3 4
extern char **__environ;
extern int execve (const char *__path, char *const __argv[],
char *const __envp[]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fexecve (int __fd, char *const __argv[], char *const __envp[])
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int execv (const char *__path, char *const __argv[])
extern int execle (const char *__path, const char *__arg, ...)
extern int execl (const char *__path, const char *__arg, ...)
extern int execvp (const char *__file, char *const __argv[])
extern int execlp (const char *__file, const char *__arg, ...)
# 598 "/usr/include/unistd.h" 3 4
extern int nice (int __inc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void _exit (int __status) __attribute__ ((__noreturn__));
# 1 "/usr/include/bits/confname.h" 1 3 4
# 24 "/usr/include/bits/confname.h" 3 4
enum
_PC_LINK_MAX,
_PC_MAX_CANON,
_PC_MAX_INPUT,
_PC_NAME_MAX,
_PC_PATH_MAX,
_PC_PIPE_BUF,
_PC_CHOWN_RESTRICTED,
_PC_NO_TRUNC,
_PC_VDISABLE,
_PC_SYNC_IO,
_PC_ASYNC_IO,
_PC_PRIO_IO,
_PC_SOCK_MAXBUF,
_PC_FILESIZEBITS,
_PC_REC_INCR_XFER_SIZE,
_PC_REC_MAX_XFER_SIZE,
_PC_REC_MIN_XFER_SIZE,
_PC_REC_XFER_ALIGN,
_PC_ALLOC_SIZE_MIN,
_PC_SYMLINK_MAX,
_PC_2_SYMLINKS
enum
_SC_ARG_MAX,
_SC_CHILD_MAX,
_SC_CLK_TCK,
_SC_NGROUPS_MAX,
_SC_OPEN_MAX,
_SC_STREAM_MAX,
_SC_TZNAME_MAX,
_SC_JOB_CONTROL,
_SC_SAVED_IDS,
_SC_REALTIME_SIGNALS,
_SC_PRIORITY_SCHEDULING,
_SC_TIMERS,
_SC_ASYNCHRONOUS_IO,
_SC_PRIORITIZED_IO,
_SC_SYNCHRONIZED_IO,
_SC_FSYNC,
_SC_MAPPED_FILES,
_SC_MEMLOCK,
_SC_MEMLOCK_RANGE,
_SC_MEMORY_PROTECTION,
_SC_MESSAGE_PASSING,
_SC_SEMAPHORES,
_SC_SHARED_MEMORY_OBJECTS,
_SC_AIO_LISTIO_MAX,
_SC_AIO_MAX,
_SC_AIO_PRIO_DELTA_MAX,
_SC_DELAYTIMER_MAX,
_SC_MQ_OPEN_MAX,
_SC_MQ_PRIO_MAX,
_SC_VERSION,
_SC_PAGESIZE,
_SC_RTSIG_MAX,
_SC_SEM_NSEMS_MAX,
_SC_SEM_VALUE_MAX,
_SC_SIGQUEUE_MAX,
_SC_TIMER_MAX,
_SC_BC_BASE_MAX,
_SC_BC_DIM_MAX,
_SC_BC_SCALE_MAX,
_SC_BC_STRING_MAX,
_SC_COLL_WEIGHTS_MAX,
_SC_EQUIV_CLASS_MAX,
_SC_EXPR_NEST_MAX,
_SC_LINE_MAX,
_SC_RE_DUP_MAX,
_SC_CHARCLASS_NAME_MAX,
_SC_2_VERSION,
_SC_2_C_BIND,
_SC_2_C_DEV,
_SC_2_FORT_DEV,
_SC_2_FORT_RUN,
_SC_2_SW_DEV,
_SC_2_LOCALEDEF,
_SC_PII,
_SC_PII_XTI,
_SC_PII_SOCKET,
_SC_PII_INTERNET,
_SC_PII_OSI,
_SC_POLL,
_SC_SELECT,
_SC_UIO_MAXIOV,
_SC_IOV_MAX = _SC_UIO_MAXIOV,
_SC_PII_INTERNET_STREAM,
_SC_PII_INTERNET_DGRAM,
_SC_PII_OSI_COTS,
_SC_PII_OSI_CLTS,
_SC_PII_OSI_M,
_SC_T_IOV_MAX,
_SC_THREADS,
_SC_THREAD_SAFE_FUNCTIONS,
_SC_GETGR_R_SIZE_MAX,
_SC_GETPW_R_SIZE_MAX,
_SC_LOGIN_NAME_MAX,
_SC_TTY_NAME_MAX,
_SC_THREAD_DESTRUCTOR_ITERATIONS,
_SC_THREAD_KEYS_MAX,
_SC_THREAD_STACK_MIN,
_SC_THREAD_THREADS_MAX,
_SC_THREAD_ATTR_STACKADDR,
_SC_THREAD_ATTR_STACKSIZE,
_SC_THREAD_PRIORITY_SCHEDULING,
_SC_THREAD_PRIO_INHERIT,
_SC_THREAD_PRIO_PROTECT,
_SC_THREAD_PROCESS_SHARED,
_SC_NPROCESSORS_CONF,
_SC_NPROCESSORS_ONLN,
_SC_PHYS_PAGES,
_SC_AVPHYS_PAGES,
_SC_ATEXIT_MAX,
_SC_PASS_MAX,
_SC_XOPEN_VERSION,
_SC_XOPEN_XCU_VERSION,
_SC_XOPEN_UNIX,
_SC_XOPEN_CRYPT,
_SC_XOPEN_ENH_I18N,
_SC_XOPEN_SHM,
_SC_2_CHAR_TERM,
_SC_2_C_VERSION,
_SC_2_UPE,
_SC_XOPEN_XPG2,
_SC_XOPEN_XPG3,
_SC_XOPEN_XPG4,
_SC_CHAR_BIT,
_SC_CHAR_MAX,
_SC_CHAR_MIN,
_SC_INT_MAX,
_SC_INT_MIN,
_SC_LONG_BIT,
_SC_WORD_BIT,
_SC_MB_LEN_MAX,
_SC_NZERO,
_SC_SSIZE_MAX,
_SC_SCHAR_MAX,
_SC_SCHAR_MIN,
_SC_SHRT_MAX,
_SC_SHRT_MIN,
_SC_UCHAR_MAX,
_SC_UINT_MAX,
_SC_ULONG_MAX,
_SC_USHRT_MAX,
_SC_NL_ARGMAX,
_SC_NL_LANGMAX,
_SC_NL_MSGMAX,
_SC_NL_NMAX,
_SC_NL_SETMAX,
_SC_NL_TEXTMAX,
_SC_XBS5_ILP32_OFF32,
_SC_XBS5_ILP32_OFFBIG,
_SC_XBS5_LP64_OFF64,
_SC_XBS5_LPBIG_OFFBIG,
_SC_XOPEN_LEGACY,
_SC_XOPEN_REALTIME,
_SC_XOPEN_REALTIME_THREADS,
_SC_ADVISORY_INFO,
_SC_BARRIERS,
_SC_BASE,
_SC_C_LANG_SUPPORT,
_SC_C_LANG_SUPPORT_R,
_SC_CLOCK_SELECTION,
_SC_CPUTIME,
_SC_THREAD_CPUTIME,
_SC_DEVICE_IO,
_SC_DEVICE_SPECIFIC,
_SC_DEVICE_SPECIFIC_R,
_SC_FD_MGMT,
_SC_FIFO,
_SC_PIPE,
_SC_FILE_ATTRIBUTES,
_SC_FILE_LOCKING,
_SC_FILE_SYSTEM,
_SC_MONOTONIC_CLOCK,
_SC_MULTI_PROCESS,
_SC_SINGLE_PROCESS,
_SC_NETWORKING,
_SC_READER_WRITER_LOCKS,
_SC_SPIN_LOCKS,
_SC_REGEXP,
_SC_REGEX_VERSION,
_SC_SHELL,
_SC_SIGNALS,
_SC_SPAWN,
_SC_SPORADIC_SERVER,
_SC_THREAD_SPORADIC_SERVER,
_SC_SYSTEM_DATABASE,
_SC_SYSTEM_DATABASE_R,
_SC_TIMEOUTS,
_SC_TYPED_MEMORY_OBJECTS,
_SC_USER_GROUPS,
_SC_USER_GROUPS_R,
_SC_2_PBS,
_SC_2_PBS_ACCOUNTING,
_SC_2_PBS_LOCATE,
_SC_2_PBS_MESSAGE,
_SC_2_PBS_TRACK,
_SC_SYMLOOP_MAX,
_SC_STREAMS,
_SC_2_PBS_CHECKPOINT,
_SC_V6_ILP32_OFF32,
_SC_V6_ILP32_OFFBIG,
_SC_V6_LP64_OFF64,
_SC_V6_LPBIG_OFFBIG,
_SC_HOST_NAME_MAX,
_SC_TRACE,
_SC_TRACE_EVENT_FILTER,
_SC_TRACE_INHERIT,
_SC_TRACE_LOG,
_SC_LEVEL1_ICACHE_SIZE,
_SC_LEVEL1_ICACHE_ASSOC,
_SC_LEVEL1_ICACHE_LINESIZE,
_SC_LEVEL1_DCACHE_SIZE,
_SC_LEVEL1_DCACHE_ASSOC,
_SC_LEVEL1_DCACHE_LINESIZE,
_SC_LEVEL2_CACHE_SIZE,
_SC_LEVEL2_CACHE_ASSOC,
_SC_LEVEL2_CACHE_LINESIZE,
_SC_LEVEL3_CACHE_SIZE,
_SC_LEVEL3_CACHE_ASSOC,
_SC_LEVEL3_CACHE_LINESIZE,
_SC_LEVEL4_CACHE_SIZE,
_SC_LEVEL4_CACHE_ASSOC,
_SC_LEVEL4_CACHE_LINESIZE,
_SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
_SC_RAW_SOCKETS,
_SC_V7_ILP32_OFF32,
_SC_V7_ILP32_OFFBIG,
_SC_V7_LP64_OFF64,
_SC_V7_LPBIG_OFFBIG,
_SC_SS_REPL_MAX,
_SC_TRACE_EVENT_NAME_MAX,
_SC_TRACE_NAME_MAX,
_SC_TRACE_SYS_MAX,
_SC_TRACE_USER_EVENT_MAX,
_SC_XOPEN_STREAMS,
_SC_THREAD_ROBUST_PRIO_INHERIT,
_SC_THREAD_ROBUST_PRIO_PROTECT
enum
_CS_PATH,
_CS_V6_WIDTH_RESTRICTED_ENVS,
_CS_GNU_LIBC_VERSION,
_CS_GNU_LIBPTHREAD_VERSION,
_CS_V5_WIDTH_RESTRICTED_ENVS,
_CS_V7_WIDTH_RESTRICTED_ENVS,
_CS_LFS_CFLAGS = 1000,
_CS_LFS_LDFLAGS,
_CS_LFS_LIBS,
_CS_LFS_LINTFLAGS,
_CS_LFS64_CFLAGS,
_CS_LFS64_LDFLAGS,
_CS_LFS64_LIBS,
_CS_LFS64_LINTFLAGS,
_CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
_CS_XBS5_ILP32_OFF32_LDFLAGS,
_CS_XBS5_ILP32_OFF32_LIBS,
_CS_XBS5_ILP32_OFF32_LINTFLAGS,
_CS_XBS5_ILP32_OFFBIG_CFLAGS,
_CS_XBS5_ILP32_OFFBIG_LDFLAGS,
_CS_XBS5_ILP32_OFFBIG_LIBS,
_CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
_CS_XBS5_LP64_OFF64_CFLAGS,
_CS_XBS5_LP64_OFF64_LDFLAGS,
_CS_XBS5_LP64_OFF64_LIBS,
_CS_XBS5_LP64_OFF64_LINTFLAGS,
_CS_XBS5_LPBIG_OFFBIG_CFLAGS,
_CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
_CS_XBS5_LPBIG_OFFBIG_LIBS,
_CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
_CS_POSIX_V6_ILP32_OFF32_CFLAGS,
_CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
_CS_POSIX_V6_ILP32_OFF32_LIBS,
_CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
_CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
_CS_POSIX_V6_ILP32_OFFBIG_LIBS,
_CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
_CS_POSIX_V6_LP64_OFF64_CFLAGS,
_CS_POSIX_V6_LP64_OFF64_LDFLAGS,
_CS_POSIX_V6_LP64_OFF64_LIBS,
_CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
_CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
_CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
_CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
_CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
_CS_POSIX_V7_ILP32_OFF32_CFLAGS,
_CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
_CS_POSIX_V7_ILP32_OFF32_LIBS,
_CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
_CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
_CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
_CS_POSIX_V7_ILP32_OFFBIG_LIBS,
_CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
_CS_POSIX_V7_LP64_OFF64_CFLAGS,
_CS_POSIX_V7_LP64_OFF64_LDFLAGS,
_CS_POSIX_V7_LP64_OFF64_LIBS,
_CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
_CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
_CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
_CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
_CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS,
_CS_V6_ENV,
_CS_V7_ENV
# 610 "/usr/include/unistd.h" 2 3 4
extern long int pathconf (const char *__path, int __name)
extern long int fpathconf (int __fd, int __name) __attribute__ ((__nothrow__ , __leaf__));
extern long int sysconf (int __name) __attribute__ ((__nothrow__ , __leaf__));
extern size_t confstr (int __name, char *__buf, size_t __len) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getppid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t __getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int setpgid (__pid_t __pid, __pid_t __pgid) __attribute__ ((__nothrow__ , __leaf__));
# 660 "/usr/include/unistd.h" 3 4
extern int setpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t setsid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getsid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t getuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t geteuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getgid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getegid (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getgroups (int __size, __gid_t __list[]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 700 "/usr/include/unistd.h" 3 4
extern int setuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setreuid (__uid_t __ruid, __uid_t __euid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int seteuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setgid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setregid (__gid_t __rgid, __gid_t __egid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setegid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
# 756 "/usr/include/unistd.h" 3 4
extern __pid_t fork (void) __attribute__ ((__nothrow__));
extern __pid_t vfork (void) __attribute__ ((__nothrow__ , __leaf__));
extern char *ttyname (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
extern int isatty (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyslot (void) __attribute__ ((__nothrow__ , __leaf__));
extern int link (const char *__from, const char *__to)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) ;
extern int linkat (int __fromfd, const char *__from, int __tofd,
const char *__to, int __flags)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4))) ;
extern int symlink (const char *__from, const char *__to)
extern ssize_t readlink (const char *__restrict __path,
char *__restrict __buf, size_t __len)
extern int symlinkat (const char *__from, int __tofd,
const char *__to) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3))) ;
extern ssize_t readlinkat (int __fd, const char *__restrict __path,
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3))) ;
extern int unlink (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int unlinkat (int __fd, const char *__name, int __flag)
extern int rmdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern __pid_t tcgetpgrp (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) __attribute__ ((__nothrow__ , __leaf__));
extern char *getlogin (void);
extern int getlogin_r (char *__name, size_t __name_len) __attribute__ ((__nonnull__ (1)));
extern int setlogin (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 1 "/usr/include/bits/getopt_posix.h" 1 3 4
# 27 "/usr/include/bits/getopt_posix.h" 3 4
# 1 "/usr/include/bits/getopt_core.h" 1 3 4
# 28 "/usr/include/bits/getopt_core.h" 3 4
extern char *optarg;
# 50 "/usr/include/bits/getopt_core.h" 3 4
extern int optind;
extern int opterr;
extern int optopt;
# 91 "/usr/include/bits/getopt_core.h" 3 4
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
# 28 "/usr/include/bits/getopt_posix.h" 2 3 4
# 49 "/usr/include/bits/getopt_posix.h" 3 4
# 870 "/usr/include/unistd.h" 2 3 4
extern int gethostname (char *__name, size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sethostname (const char *__name, size_t __len)
extern int sethostid (long int __id) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (const char *__name, size_t __len)
extern int vhangup (void) __attribute__ ((__nothrow__ , __leaf__));
extern int revoke (const char *__file) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int profil (unsigned short int *__sample_buffer, size_t __size,
size_t __offset, unsigned int __scale)
extern int acct (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern char *getusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void endusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void setusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daemon (int __nochdir, int __noclose) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int chroot (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *getpass (const char *__prompt) __attribute__ ((__nonnull__ (1)));
extern int fsync (int __fd);
# 967 "/usr/include/unistd.h" 3 4
extern long int gethostid (void);
extern void sync (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getpagesize (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int getdtablesize (void) __attribute__ ((__nothrow__ , __leaf__));
# 991 "/usr/include/unistd.h" 3 4
extern int truncate (const char *__file, __off_t __length)
# 1014 "/usr/include/unistd.h" 3 4
extern int ftruncate (int __fd, __off_t __length) __attribute__ ((__nothrow__ , __leaf__)) ;
# 1035 "/usr/include/unistd.h" 3 4
extern int brk (void *__addr) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void *sbrk (intptr_t __delta) __attribute__ ((__nothrow__ , __leaf__));
# 1056 "/usr/include/unistd.h" 3 4
extern long int syscall (long int __sysno, ...) __attribute__ ((__nothrow__ , __leaf__));
# 1079 "/usr/include/unistd.h" 3 4
extern int lockf (int __fd, int __cmd, __off_t __len) ;
# 1115 "/usr/include/unistd.h" 3 4
extern int fdatasync (int __fildes);
# 1124 "/usr/include/unistd.h" 3 4
extern char *crypt (const char *__key, const char *__salt)
# 1161 "/usr/include/unistd.h" 3 4
int getentropy (void *__buffer, size_t __length) ;
Defined "HAVE_UNISTD_H" to "1"
Checking for header: netinet/in.h
stdout:
# 1 "<built-in>"
# 21 "/usr/include/netinet/in.h" 3 4
# 22 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/bits/stdint-uintn.h" 1 3 4
typedef __uint8_t uint8_t;
typedef __uint16_t uint16_t;
typedef __uint32_t uint32_t;
typedef __uint64_t uint64_t;
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
struct iovec
void *iov_base;
size_t iov_len;
typedef __uid_t uid_t;
# 1 "/usr/include/bits/types/time_t.h" 1 3 4
typedef __time_t time_t;
# 1 "/usr/include/bits/stdint-intn.h" 1 3 4
# 24 "/usr/include/bits/stdint-intn.h" 3 4
typedef __int8_t int8_t;
typedef __int16_t int16_t;
typedef __int32_t int32_t;
typedef __int64_t int64_t;
return __x;
return __x;
return __x;
# 1 "/usr/include/bits/types/sigset_t.h" 1 3 4
# 1 "/usr/include/bits/types/__sigset_t.h" 1 3 4
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
# 5 "/usr/include/bits/types/sigset_t.h" 2 3 4
typedef __sigset_t sigset_t;
struct timeval
__time_t tv_sec;
# 1 "/usr/include/bits/types/struct_timespec.h" 1 3 4
# 9 "/usr/include/bits/types/struct_timespec.h" 3 4
struct timespec
__time_t tv_sec;
__syscall_slong_t tv_nsec;
typedef struct
} fd_set;
int __cur_writer;
int __shared;
} __pthread_list_t;
int __lock ;
int __owner;
int __kind;
__extension__ union
struct
unsigned int __low;
} __wseq32;
__extension__ union
struct
unsigned int __low;
} __g1_start32;
typedef union
char __size[4];
int __align;
typedef union
char __size[4];
int __align;
union pthread_attr_t
char __size[56];
long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef union
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[48];
} pthread_cond_t;
typedef union
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
enum __socket_type
SOCK_STREAM = 1,
SOCK_DGRAM = 2,
SOCK_RAW = 3,
SOCK_RDM = 4,
SOCK_SEQPACKET = 5,
SOCK_DCCP = 6,
SOCK_PACKET = 10,
struct sockaddr
char sa_data[14];
enum
MSG_OOB = 0x01,
MSG_PEEK = 0x02,
MSG_CTRUNC = 0x08,
MSG_PROXY = 0x10,
MSG_TRUNC = 0x20,
MSG_EOR = 0x80,
MSG_FIN = 0x200,
MSG_SYN = 0x400,
MSG_RST = 0x1000,
MSG_MORE = 0x8000,
struct msghdr
void *msg_name;
size_t msg_iovlen;
void *msg_control;
int msg_flags;
struct cmsghdr
size_t cmsg_len;
int cmsg_level;
int cmsg_type;
enum
SCM_RIGHTS = 0x01
struct linger
int l_onoff;
int l_linger;
struct osockaddr
enum
SHUT_RD = 0,
SHUT_WR,
SHUT_RDWR
int __flags);
struct in_addr
in_addr_t s_addr;
struct ip_opts
char ip_opts[40];
struct ip_mreqn
int imr_ifindex;
struct in_pktinfo
int ipi_ifindex;
enum
IPPROTO_IP = 0,
IPPROTO_ICMP = 1,
IPPROTO_IGMP = 2,
IPPROTO_IPIP = 4,
IPPROTO_TCP = 6,
IPPROTO_EGP = 8,
IPPROTO_PUP = 12,
IPPROTO_UDP = 17,
IPPROTO_IDP = 22,
IPPROTO_TP = 29,
IPPROTO_DCCP = 33,
IPPROTO_IPV6 = 41,
IPPROTO_RSVP = 46,
IPPROTO_GRE = 47,
IPPROTO_ESP = 50,
IPPROTO_AH = 51,
IPPROTO_MTP = 92,
IPPROTO_ENCAP = 98,
IPPROTO_PIM = 103,
IPPROTO_COMP = 108,
IPPROTO_SCTP = 132,
IPPROTO_MPLS = 137,
IPPROTO_RAW = 255,
IPPROTO_MAX
enum
IPPROTO_NONE = 59,
IPPROTO_MH = 135
enum
IPPORT_ECHO = 7,
IPPORT_DISCARD = 9,
IPPORT_SYSTAT = 11,
IPPORT_FTP = 21,
IPPORT_TELNET = 23,
IPPORT_SMTP = 25,
IPPORT_WHOIS = 43,
IPPORT_MTP = 57,
IPPORT_TFTP = 69,
IPPORT_RJE = 77,
IPPORT_FINGER = 79,
IPPORT_SUPDUP = 95,
struct in6_addr
union
} __in6_u;
struct sockaddr_in
in_port_t sin_port;
struct sockaddr_in6
struct ip_mreq
struct ipv6_mreq
struct group_req
struct ip_msfilter
struct group_filter
uint32_t gf_fmode;
uint32_t gf_numsrc;
Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:223)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:223)
Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.headers/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
Try to determine the size and associativity of the cache.
Pushing language C
All intermediate test results are stored in /tmp/petsc-VuReVk/config.utilities.cacheDetails
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.headers -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
return 0;
Popping language C
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.utilities.cacheDetails/conftest
Popping language C
Defined "LEVEL1_DCACHE_SIZE" to "32768"
Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "LEVEL1_DCACHE_LINESIZE" to "64"
Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val = sysconf(_SC_LEVEL1_DCACHE_ASSOC); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "LEVEL1_DCACHE_ASSOC" to "8"
TEST check_siginfo_t from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
All intermediate test results are stored in /tmp/petsc-VuReVk/config.types
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.types/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.types/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
return 0;
siginfo_t found
Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.types/conftest.o -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.types/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-VuReVk/config.types/conftest.c: In function ���main���:
/tmp/petsc-VuReVk/config.types/conftest.c:13:1: error: unknown type name ���__int64���; did you mean ���__int64_t���?
__int64 a;;
__int64_t
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
return 0;
__int64 found
TEST checkSizeTypes from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
Checks for types associated with sizes, such as size_t.
Checking for type: size_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
return 0;
size_t found
TEST checkFileTypes from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
return 0;
mode_t found
Checking for type: off_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
return 0;
off_t found
TEST checkIntegerTypes from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
return 0;
int32_t found
TEST checkPID from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
Checks for pid_t, and defines it if necessary
Checking for type: pid_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
return 0;
pid_t found
TEST checkUID from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.types/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.types/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-VuReVk/config.types/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.types/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.types/conffix.h" 1
# 3 "/tmp/petsc-VuReVk/config.types/conftest.c" 2
# 1 "/usr/include/sys/types.h" 1 3 4
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 59 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __off_t off_t;
# 97 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 1 "/usr/include/bits/types/clock_t.h" 1 3 4
typedef __clock_t clock_t;
# 127 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/clockid_t.h" 1 3 4
typedef __clockid_t clockid_t;
# 129 "/usr/include/sys/types.h" 2 3 4
# 130 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/bits/types/timer_t.h" 1 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/sys/types.h" 2 3 4
# 144 "/usr/include/sys/types.h" 3 4
# 145 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 156 "/usr/include/sys/types.h" 2 3 4
# 177 "/usr/include/sys/types.h" 3 4
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 193 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 33 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint16_t
__bswap_16 (__uint16_t __bsx)
return __builtin_bswap16 (__bsx);
static __inline __uint32_t
__bswap_32 (__uint32_t __bsx)
return __builtin_bswap32 (__bsx);
# 69 "/usr/include/bits/byteswap.h" 3 4
__extension__ static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/bits/uintn-identity.h" 1 3 4
# 32 "/usr/include/bits/uintn-identity.h" 3 4
__uint16_identity (__uint16_t __x)
return __x;
__uint32_identity (__uint32_t __x)
return __x;
__uint64_identity (__uint64_t __x)
return __x;
# 62 "/usr/include/endian.h" 2 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
typedef struct
} __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/types/struct_timeval.h" 1 3 4
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
# 38 "/usr/include/sys/select.h" 2 3 4
struct timespec
__time_t tv_sec;
# 40 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 59 "/usr/include/sys/select.h" 3 4
typedef struct
__fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
# 91 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
fd_set *__restrict __writefds,
fd_set *__restrict __exceptfds,
struct timeval *__restrict __timeout);
# 113 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
const struct timespec *__restrict __timeout,
const __sigset_t *__restrict __sigmask);
# 126 "/usr/include/sys/select.h" 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 244 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/bits/pthreadtypes.h" 3 4
# 1 "/usr/include/bits/thread-shared-types.h" 1 3 4
# 77 "/usr/include/bits/thread-shared-types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes-arch.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 22 "/usr/include/bits/pthreadtypes-arch.h" 2 3 4
# 65 "/usr/include/bits/pthreadtypes-arch.h" 3 4
struct __pthread_rwlock_arch_t
unsigned int __readers;
unsigned int __writers;
unsigned int __wrphase_futex;
unsigned int __writers_futex;
unsigned int __pad3;
unsigned int __pad4;
int __cur_writer;
int __shared;
signed char __rwelision;
unsigned char __pad1[7];
unsigned long int __pad2;
unsigned int __flags;
# 99 "/usr/include/bits/pthreadtypes-arch.h" 3 4
# 78 "/usr/include/bits/thread-shared-types.h" 2 3 4
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
# 118 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_mutex_s
int __lock ;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
short __spins; short __elision;
__pthread_list_t __list;
# 145 "/usr/include/bits/thread-shared-types.h" 3 4
struct __pthread_cond_s
__extension__ union
__extension__ unsigned long long int __wseq;
struct
unsigned int __low;
unsigned int __high;
} __wseq32;
__extension__ union
__extension__ unsigned long long int __g1_start;
struct
unsigned int __low;
} __g1_start32;
unsigned int __g_refs[2] ;
unsigned int __g_size[2];
unsigned int __g1_orig_size;
unsigned int __wrefs;
unsigned int __g_signals[2];
# 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
typedef unsigned long int pthread_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
char __size[56];
long int __align;
typedef union
struct __pthread_mutex_s __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
struct __pthread_cond_s __data;
char __size[48];
__extension__ long long int __align;
} pthread_cond_t;
typedef union
struct __pthread_rwlock_arch_t __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
# 245 "/usr/include/sys/types.h" 2 3 4
TEST checkSignal from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
return 0;
Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
Check for complex numbers in in C99 std
Note that since PETSc source code uses _Complex we test specifically for that, not complex
Successful compile:
Source:
#include <complex.h>
int main() {
double _Complex x;
x = I;
return 0;
Successful compile:
Source:
int main() {
double _Complex x;
x = I;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.types/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.types/conftest.o -lstdc++ -ldl
Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
Check for complex numbers in namespace std
Pushing language Cxx
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.types/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
return 0;
Pushing language CXX
Popping language CXX
Executing: mpicxx -o /tmp/petsc-VuReVk/config.types/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.types/conftest.o -lstdc++ -ldl
Defined "HAVE_CXX_COMPLEX" to "1"
Popping language Cxx
TEST checkFortranKind from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
Checks whether selected_int_kind etc work USE_FORTRANKIND
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.types/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.types/conftest.F90
Successful compile:
Source:
program main
integer(kind=selected_int_kind(10)) i
real(kind=selected_real_kind(10)) d
end
Defined "USE_FORTRANKIND" to "1"
Popping language FC
TEST checkConst from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
Checks for working const, and if not found defines it to empty string
Successful compile:
Source:
int main() {
/* Ultrix mips cc rejects this. */
typedef int charset[2]; const charset x;
/* SunOS 4.1.1 cc rejects this. */
char const *const *ccp;
char **p;
/* NEC SVR4.0.2 mips cc rejects this. */
struct point {int x, y;};
static struct point const zero = {0,0};
/* AIX XL C 1.02.0.0 rejects this.
It does not let you subtract one const X* pointer from another in an arm
of an if-expression whose if-part is not a constant expression */
const char *g = "string";
ccp = &g + (g ? g-g : 0);
/* HPUX 7.0 cc rejects these. */
++ccp;
p = (char**) ccp;
ccp = (char const *const *) p;
/* This section avoids unused variable warnings */
if (zero.x);
if (x[0]);
{ /* SCO 3.2v4 cc rejects this. */
char *t;
char const *s = 0 ? (char *) 0 : (char const *) 0;
*t++ = 0;
if (*s);
{ /* Someone thinks the Sun supposedly-ANSI compiler will reject this. */
int x[] = {25, 17};
const int *foo = &x[0];
++foo;
{ /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
typedef const int *iptr;
iptr p = 0;
++p;
{ /* AIX XL C 1.02.0.0 rejects this saying
"k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
struct s { int j; const int *ap[3]; };
struct s *b; b->j = 5;
{ /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
const int foo = 10;
/* Get rid of unused variable warning */
if (foo);
return 0;
TEST checkEndian from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
#include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
bogus endian macros
#endif
return 0;
stderr:
/tmp/petsc-VuReVk/config.types/conftest.c:11:3: error: unknown type name ���not���; did you mean ���ino_t���?
not big endian
ino_t
/tmp/petsc-VuReVk/config.types/conftest.c:11:11: error: expected ���=���, ���,���, ���;���, ���asm��� or ���__attribute__��� before ���endian���
not big endian
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
not big endian
#endif
return 0;
TEST checkSizeof from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
return 0;
Pushing language C
Popping language C
Testing executable /tmp/petsc-VuReVk/config.types/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.types/conftest
Popping language C
Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_INT" to "4"
Checking for size of type: long
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
char val[2];
int i = 0;
if (!f) exit(1);
val[0]='\1';
val[1]='\0';
while(val[0]) {val[0] <<= 1; i++;}
fprintf(f, "%d\n", i);
return 0;
Pushing language C
Popping language C
Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/home/ryan/projects/moose/petsc/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
Pushing language C
Successful compile:
Source:
int main() {
__attribute__((visibility ("default"))) int foo(void);;
return 0;
Defined "USE_VISIBILITY_C" to "1"
Popping language C
Successful compile:
Source:
int main() {
return 0;
Defined "USE_VISIBILITY_CXX" to "1"
TEST configureMemAlign from PETSc.options.memAlign(/home/ryan/projects/moose/petsc/config/PETSc/options/memAlign.py:30)
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
Choose alignment
Defined "MEMALIGN" to "16"
Memory alignment is 16
TEST check from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:158)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:158)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [socket] in library ['socket', 'nsl'] []
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.libraries/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -lsocket -lnsl -lstdc++ -ldl
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lsocket
collect2: error: ld returned 1 exit status
Popping language C
Checking for functions [handle_sigfpes] in library ['fpe'] []
Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -lfpe -lstdc++ -ldl
stderr:
/usr/bin/ld: cannot find -lfpe
Popping language C
Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
return 0;
Pushing language C
Popping language C
stderr:
Popping language C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
stderr:
Popping language C
TEST checkMath from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:265)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:265)
Check for sin() in libm, the math library
Checking for functions [sin floor log10 pow] in library [''] []
Pushing language C
Successful compile:
Source:
#include <stdio.h>
double sin(double);
static void _check_sin() { double x,y; scanf("%lf",&x); y = sin(x); printf("%f",y);
#include <stdio.h>
double floor(double);
static void _check_floor() { double x,y; scanf("%lf",&x); y = floor(x); printf("%f",y);
#include <stdio.h>
double log10(double);
static void _check_log10() { double x,y; scanf("%lf",&x); y = log10(x); printf("%f",y);
#include <stdio.h>
double pow(double, double);
static void _check_pow() { double x,y; scanf("%lf",&x); y = pow(x,x); printf("%f",y);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -lstdc++ -ldl
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.libraries/conftest.o: undefined reference to symbol 'log10@@GLIBC_2.2.5'
/usr/bin/ld: /usr/lib/libm.so.6: error adding symbols: DSO missing from command line
Popping language C
Checking for functions [sin floor log10 pow] in library ['m'] []
Pushing language C
Successful compile:
Source:
#include <stdio.h>
double sin(double);
#include <stdio.h>
#include <stdio.h>
#include <stdio.h>
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -lm -lstdc++ -ldl
Defined "HAVE_LIBM" to "1"
Popping language C
CheckMath: using math library ['libm.a']
TEST checkMathErf from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:284)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:284)
Check for erf() in libm, the math library
Checking for functions [erf] in library ['libm.a'] []
Pushing language C
Successful compile:
Source:
#include <math.h>
static void _check_erf() { double (*checkErf)(double) = erf;double x = 0,y; y = (*checkErf)(x); }
int main() {
_check_erf();;
return 0;
Pushing language C
Popping language C
Popping language C
erf() found
Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:293)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:293)
Check for tgamma() in libm, the math library
Checking for functions [tgamma] in library ['libm.a'] []
Pushing language C
Successful compile:
Source:
#include <math.h>
static void _check_tgamma() { double (*checkTgamma)(double) = tgamma;double x = 0,y; y = (*checkTgamma)(x); }
int main() {
_check_tgamma();;
return 0;
Pushing language C
Popping language C
Popping language C
tgamma() found
Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:302)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:302)
Checks if <fenv.h> can be used with FE_DFL_ENV
Checking for functions [fesetenv] in library ['libm.a'] []
Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "HAVE_FENV_H" to "1"
TEST checkMathLog2 from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:310)
TESTING: checkMathLog2 from config.libraries(config/BuildSystem/config/libraries.py:310)
Check for log2() in libm, the math library
Checking for functions [log2] in library ['libm.a'] []
Pushing language C
Successful compile:
Source:
#include <math.h>
static void _check_log2() { double (*checkLog2)(double) = log2; double x = 2.5, y = (*checkLog2)(x); }
int main() {
_check_log2();;
return 0;
Pushing language C
Popping language C
Popping language C
log2() found
Defined "HAVE_LOG2" to "1"
TEST checkRealtime from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:319)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:319)
Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
Checking for functions [clock_gettime] in library [''] []
Pushing language C
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
return 0;
Pushing language C
Popping language C
Popping language C
realtime functions are linked in by default
TEST checkDynamic from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:335)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:335)
Check for the header and libraries necessary for dynamic library manipulation
Checking for functions [dlopen] in library ['dl'] []
Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -ldl -lstdc++ -ldl
Defined "HAVE_LIBDL" to "1"
Popping language C
Checking for header: dlfcn.h
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.headers /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 1 "/usr/include/dlfcn.h" 1 3 4
# 22 "/usr/include/dlfcn.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 428 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 442 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 443 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/bits/long-double.h" 1 3 4
# 444 "/usr/include/sys/cdefs.h" 2 3 4
# 429 "/usr/include/features.h" 2 3 4
# 452 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 453 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/dlfcn.h" 2 3 4
# 25 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/bits/dlfcn.h" 1 3 4
# 28 "/usr/include/dlfcn.h" 2 3 4
# 52 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (const char *__file, int __mode) __attribute__ ((__nothrow__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 82 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 188 "/usr/include/dlfcn.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_DLFCN_H" to "1"
TEST configureLibraryOptions from PETSc.options.libraryOptions(/home/ryan/projects/moose/petsc/config/PETSc/options/libraryOptions.py:38)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:38)
Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE, PETSC_USE_FORTRAN_KERNELS, and PETSC_USE_AVX512_KERNELS
Defined "USE_LOG" to "1"
Executing: mpicc -qversion
Defined "USE_MALLOC_COALESCED" to "1"
Defined "USE_INFO" to "1"
Defined "USE_CTABLE" to "1"
Defined "USE_BACKWARD_LOOP" to "1"
**********Checking if running on BGL/IBM detected
Checking for functions [bgl_perfctr_void] in library [''] []
Pushing language C
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
return 0;
Pushing language C
Popping language C
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.libraries/conftest.o: in function `_check_bgl_perfctr_void':
/tmp/petsc-VuReVk/config.libraries/conftest.c:5: undefined reference to `bgl_perfctr_void'
Popping language C
Checking for functions [ADIOI_BGL_Open] in library [''] []
Pushing language C
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
return 0;
Pushing language C
Popping language C
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.libraries/conftest.o: in function `_check_ADIOI_BGL_Open':
/tmp/petsc-VuReVk/config.libraries/conftest.c:5: undefined reference to `ADIOI_BGL_Open'
Popping language C
*********BGL/IBM test failure
Defined "Alignx(a,b)" to " "
TEST configureISColorValueType from PETSc.options.libraryOptions(/home/ryan/projects/moose/petsc/config/PETSc/options/libraryOptions.py:96)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:96)
Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
Defined "IS_COLORING_MAX" to "65535"
Defined "IS_COLOR_VALUE_TYPE" to "short"
Defined "IS_COLOR_VALUE_TYPE_F" to "integer2"
TEST configureCPURelax from config.atomics(/home/ryan/projects/moose/petsc/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
Definitions for cpu relax assembly instructions
All intermediate test results are stored in /tmp/petsc-VuReVk/config.atomics
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.atomics/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.atomics/conftest.c
Successful compile:
Source:
int main() {
__asm__ __volatile__("rep; nop" ::: "memory");;
return 0;
Defined "CPU_RELAX()" to "__asm__ __volatile__("rep; nop" ::: "memory")"
TEST configureMemoryBarriers from config.atomics(/home/ryan/projects/moose/petsc/config/BuildSystem/config/atomics.py:38)
TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:38)
Definitions for memory barrier instructions
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.atomics/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.atomics -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.atomics/conftest.c
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("mfence":::"memory");
return 0;
Defined "MEMORY_BARRIER()" to "__asm__ __volatile__ ("mfence":::"memory")"
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("lfence":::"memory");
return 0;
Defined "READ_MEMORY_BARRIER()" to "__asm__ __volatile__ ("lfence":::"memory")"
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("sfence":::"memory");
return 0;
Defined "WRITE_MEMORY_BARRIER()" to "__asm__ __volatile__ ("sfence":::"memory")"
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c: Assembler messages:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `sync'
Source:
int main() {
__asm__ __volatile__ ("sync":::"memory");
return 0;
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `lwsync'
Source:
int main() {
__asm__ __volatile__ ("lwsync":::"memory");
return 0;
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `eieio'
Source:
int main() {
__asm__ __volatile__ ("eieio":::"memory");
return 0;
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `dmb'
Source:
int main() {
__asm__ __volatile__ ("dmb":::"memory");
return 0;
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `dmb ish'
Source:
int main() {
__asm__ __volatile__ ("dmb ish":::"memory");
return 0;
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `dmb ishld'
Source:
int main() {
__asm__ __volatile__ ("dmb ishld":::"memory");
return 0;
stderr:
/tmp/petsc-VuReVk/config.atomics/conftest.c:5: Error: no such instruction: `dmb ishst'
Source:
int main() {
__asm__ __volatile__ ("dmb ishst":::"memory");
return 0;
TEST checkMemcmp from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:110)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:110)
Check for 8-bit clean memcmp
Making executable to test memcmp()
All intermediate test results are stored in /tmp/petsc-VuReVk/config.functions
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.functions/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.functions/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.functions/conftest.o -lstdc++ -ldl
Testing executable /tmp/petsc-VuReVk/config.functions/conftest to see if it can be run
Executing: /tmp/petsc-VuReVk/config.functions/conftest
TEST checkSysinfo from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:135)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:135)
Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_SYSINFO" to "1"
Checking for header: linux/kernel.h
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 1 "/usr/include/linux/sysinfo.h" 1 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 1 "/usr/include/asm/types.h" 1 3 4
# 1 "/usr/include/asm-generic/types.h" 1 3 4
# 1 "/usr/include/asm-generic/int-ll64.h" 1 3 4
# 12 "/usr/include/asm-generic/int-ll64.h" 3 4
# 1 "/usr/include/asm/bitsperlong.h" 1 3 4
# 11 "/usr/include/asm/bitsperlong.h" 3 4
# 1 "/usr/include/asm-generic/bitsperlong.h" 1 3 4
# 12 "/usr/include/asm/bitsperlong.h" 2 3 4
# 13 "/usr/include/asm-generic/int-ll64.h" 2 3 4
# 20 "/usr/include/asm-generic/int-ll64.h" 3 4
typedef __signed__ char __s8;
typedef unsigned char __u8;
typedef __signed__ short __s16;
typedef unsigned short __u16;
typedef __signed__ int __s32;
typedef unsigned int __u32;
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
# 8 "/usr/include/asm-generic/types.h" 2 3 4
# 6 "/usr/include/asm/types.h" 2 3 4
# 6 "/usr/include/linux/types.h" 2 3 4
# 1 "/usr/include/linux/posix_types.h" 1 3 4
# 1 "/usr/include/linux/stddef.h" 1 3 4
# 6 "/usr/include/linux/posix_types.h" 2 3 4
# 25 "/usr/include/linux/posix_types.h" 3 4
typedef struct {
unsigned long fds_bits[1024 / (8 * sizeof(long))];
} __kernel_fd_set;
typedef void (*__kernel_sighandler_t)(int);
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
# 1 "/usr/include/asm/posix_types.h" 1 3 4
# 1 "/usr/include/asm/posix_types_64.h" 1 3 4
# 11 "/usr/include/asm/posix_types_64.h" 3 4
typedef unsigned short __kernel_old_uid_t;
typedef unsigned short __kernel_old_gid_t;
typedef unsigned long __kernel_old_dev_t;
# 1 "/usr/include/asm-generic/posix_types.h" 1 3 4
# 15 "/usr/include/asm-generic/posix_types.h" 3 4
typedef long __kernel_long_t;
typedef unsigned long __kernel_ulong_t;
typedef __kernel_ulong_t __kernel_ino_t;
typedef unsigned int __kernel_mode_t;
typedef int __kernel_pid_t;
typedef int __kernel_ipc_pid_t;
typedef unsigned int __kernel_uid_t;
typedef unsigned int __kernel_gid_t;
typedef __kernel_long_t __kernel_suseconds_t;
typedef int __kernel_daddr_t;
typedef unsigned int __kernel_uid32_t;
typedef unsigned int __kernel_gid32_t;
# 72 "/usr/include/asm-generic/posix_types.h" 3 4
typedef __kernel_ulong_t __kernel_size_t;
typedef __kernel_long_t __kernel_ssize_t;
typedef __kernel_long_t __kernel_ptrdiff_t;
typedef struct {
int val[2];
} __kernel_fsid_t;
typedef __kernel_long_t __kernel_off_t;
typedef long long __kernel_loff_t;
typedef __kernel_long_t __kernel_time_t;
typedef __kernel_long_t __kernel_clock_t;
typedef int __kernel_timer_t;
typedef int __kernel_clockid_t;
typedef char * __kernel_caddr_t;
typedef unsigned short __kernel_uid16_t;
typedef unsigned short __kernel_gid16_t;
# 19 "/usr/include/asm/posix_types_64.h" 2 3 4
# 8 "/usr/include/asm/posix_types.h" 2 3 4
# 37 "/usr/include/linux/posix_types.h" 2 3 4
# 10 "/usr/include/linux/types.h" 2 3 4
# 24 "/usr/include/linux/types.h" 3 4
typedef __u16 __le16;
typedef __u16 __be16;
typedef __u32 __le32;
typedef __u32 __be32;
typedef __u64 __le64;
typedef __u64 __be64;
typedef __u16 __sum16;
typedef __u32 __wsum;
# 50 "/usr/include/linux/types.h" 3 4
typedef unsigned __poll_t;
# 6 "/usr/include/linux/sysinfo.h" 2 3 4
struct sysinfo {
__kernel_long_t uptime;
__kernel_ulong_t loads[3];
__kernel_ulong_t totalram;
__kernel_ulong_t freeram;
__kernel_ulong_t sharedram;
__kernel_ulong_t bufferram;
__kernel_ulong_t totalswap;
__kernel_ulong_t freeswap;
__u16 procs;
__u16 pad;
__kernel_ulong_t totalhigh;
__kernel_ulong_t freehigh;
__u32 mem_unit;
char _f[20-2*sizeof(__kernel_ulong_t)-sizeof(__u32)];
# 6 "/usr/include/linux/kernel.h" 2 3 4
Defined "HAVE_LINUX_KERNEL_H" to "1"
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/sysinfo.h" 1 3 4
# 21 "/usr/include/sys/sysinfo.h" 3 4
# 22 "/usr/include/sys/sysinfo.h" 2 3 4
typedef struct {
} __kernel_fd_set;
typedef struct {
int val[2];
} __kernel_fsid_t;
struct sysinfo {
__u16 procs;
__u16 pad;
__u32 mem_unit;
# 25 "/usr/include/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2stderr:
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
#include <sys/systeminfo.h>
compilation terminated.
Source:
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory #include <sys/systeminfo.h> ^~~~~~~~~~~~~~~~~~compilation terminated.:
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:13:4: error: #error "Cannot check sysinfo without special headers"
# error "Cannot check sysinfo without special headers"
/tmp/petsc-VuReVk/config.functions/conftest.c: In function ���main���:
/tmp/petsc-VuReVk/config.functions/conftest.c:17:30: warning: implicit declaration of function ���sysinfo��� [-Wimplicit-function-declaration]
char buf[10]; long count=10; sysinfo(1, buf, count);
Source:
#ifdef HAVE_LINUX_KERNEL_H
# include <linux/kernel.h>
# include <linux/sys.h>
# ifdef HAVE_SYS_SYSINFO_H
# include <sys/sysinfo.h>
# endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
# include <sys/systeminfo.h>
#else
#endif
int main() {
return 0;
Compile failed inside link
TEST checkVPrintf from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:158)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:158)
Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���vprintf��� [-Wbuiltin-declaration-mismatch]
char vprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
return 0;
Pushing language C
Popping language C
TEST checkVFPrintf from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:165)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:165)
Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���vfprintf��� [-Wbuiltin-declaration-mismatch]
char vfprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
return 0;
Pushing language C
Popping language C
TEST checkVSNPrintf from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:172)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:172)
Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
return 0;
Pushing language C
Popping language C
Defined "HAVE_VSNPRINTF" to "1"
TEST checkNanosleep from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:202)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:202)
Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
tp.tv_sec = 0;
tp.tv_nsec = (long)(1e9);
nanosleep(&tp,0);
return 0;
Pushing language C
Popping language C
Defined "HAVE_NANOSLEEP" to "1"
TEST checkMemmove from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:208)
TESTING: checkMemmove from config.functions(config/BuildSystem/config/functions.py:208)
Check for functional memmove() - as MS VC requires correct includes to for this test
Successful compile:
Source:
#include <string.h>
int main() {
char c1[1], c2[1] = "c";
size_t n=1;
memmove(c1,c2,n);
return 0;
Pushing language C
Popping language C
Defined "HAVE_MEMMOVE" to "1"
TEST checkSignalHandlerType from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:178)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:178)
Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.functions/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.functions -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
return 0;
Executing: mpicxx -o /tmp/petsc-VuReVk/config.functions/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.functions/conftest.o -lstdc++ -ldl
Defined "SIGNAL_CAST" to " "
TEST checkFreeReturnType from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:188)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:188)
Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
int ierr; void *p; ierr = free(p); return 0;
Source:
#include <stdlib.h>
int main() {
return 0;
TEST checkVariableArgumentLists from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:194)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:194)
Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
va_list l1, l2;
va_copy(l1, l2);
return 0;
return 0;
Pushing language C
Popping language C
Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:89)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:89)
Recursive decompose to rapidly classify functions as found or missing
To confirm that a function is missing, we require a compile/link
failure with only that function in a compilation unit. In contrast,
we can confirm that many functions are present by compiling them all
together in a large compilation unit. We optimistically compile
everything together, then trim all functions that were named in the
error message and bisect the result. The trimming is only an
optimization to increase the likelihood of a big-batch compile
succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket signal popen getrusage times _mkdir time sysctlbyname stricmp]
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:16:6: warning: conflicting types for built-in function ���snprintf��� [-Wbuiltin-declaration-mismatch]
char snprintf();
/tmp/petsc-VuReVk/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ���bzero��� [-Wbuiltin-declaration-mismatch]
char bzero();
/tmp/petsc-VuReVk/config.functions/conftest.c:36:6: warning: conflicting types for built-in function ���fork��� [-Wbuiltin-declaration-mismatch]
char fork();
/tmp/petsc-VuReVk/config.functions/conftest.c:48:6: warning: conflicting types for built-in function ���strcasecmp��� [-Wbuiltin-declaration-mismatch]
char strcasecmp();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char _set_output_format();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char signal();
char popen();
char getrusage();
char times();
char _mkdir();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
snprintf_will_always_fail_with_ENOSYS();
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub__mkdir) || defined (__stub____mkdir)
_mkdir_will_always_fail_with_ENOSYS();
#else
_mkdir();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.o: in function `main':
/tmp/petsc-VuReVk/config.functions/conftest.c:118: warning: the `getwd' function is dangerous and should not be used.
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:82: undefined reference to `_sleep'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:112: undefined reference to `_getcwd'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:130: undefined reference to `_lseek'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:142: undefined reference to `_access'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:190: undefined reference to `_snprintf'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:220: undefined reference to `sbreak'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:262: undefined reference to `_set_output_format'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:268: undefined reference to `PXFGETARG'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:328: undefined reference to `_mkdir'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:340: undefined reference to `sysctlbyname'
/usr/bin/ld: /tmp/petsc-VuReVk/config.functions/conftest.c:346: undefined reference to `stricmp'
Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork getpagesize]
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:17:6: warning: conflicting types for built-in function ���bzero��� [-Wbuiltin-declaration-mismatch]
char bzero();
/tmp/petsc-VuReVk/config.functions/conftest.c:26:6: warning: conflicting types for built-in function ���fork��� [-Wbuiltin-declaration-mismatch]
char fork();
Source:
#include "confdefs.h"
#include "conffix.h"
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
get_nprocs();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
#else
getpagesize();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_RAND" to "1"
Defined "HAVE_GETDOMAINNAME" to "1"
Defined "HAVE_REALPATH" to "1"
Defined "HAVE_DLSYM" to "1"
Defined "HAVE_BZERO" to "1"
Defined "HAVE_UNAME" to "1"
Defined "HAVE_USLEEP" to "1"
Defined "HAVE_DLCLOSE" to "1"
Defined "HAVE_GETHOSTNAME" to "1"
Defined "HAVE_CLOCK" to "1"
Defined "HAVE_GET_NPROCS" to "1"
Defined "HAVE_DLERROR" to "1"
Defined "HAVE_MKSTEMP" to "1"
Defined "HAVE_FORK" to "1"
Defined "HAVE_GETPAGESIZE" to "1"
Checking for functions [memalign sigset gethostbyname gettimeofday readlink sigaction strcasecmp dlopen drand48 socket signal popen getrusage times time]
Possible ERROR while running compiler:
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ���strcasecmp��� [-Wbuiltin-declaration-mismatch]
char strcasecmp();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char signal();
char popen();
char getrusage();
char times();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
#else
time();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_MEMALIGN" to "1"
Defined "HAVE_SIGSET" to "1"
Defined "HAVE_GETHOSTBYNAME" to "1"
Defined "HAVE_GETTIMEOFDAY" to "1"
Defined "HAVE_READLINK" to "1"
Defined "HAVE_SIGACTION" to "1"
Defined "HAVE_STRCASECMP" to "1"
Defined "HAVE_DLOPEN" to "1"
Defined "HAVE_DRAND48" to "1"
Defined "HAVE_SOCKET" to "1"
Defined "HAVE_SIGNAL" to "1"
Defined "HAVE_POPEN" to "1"
Defined "HAVE_GETRUSAGE" to "1"
Defined "HAVE_TIMES" to "1"
Defined "HAVE_TIME" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_sleep'
Checking for functions [snprintf]
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���snprintf��� [-Wbuiltin-declaration-mismatch]
char snprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_getcwd'
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: warning: the `getwd' function is dangerous and should not be used.
Defined "HAVE_GETWD" to "1"
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_access'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_set_output_format'
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `PXFGETARG'
Checking for functions [_mkdir]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `_mkdir'
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `sysctlbyname'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `stricmp'
TEST checkMmap from config.functions(/home/ryan/projects/moose/petsc/config/BuildSystem/config/functions.py:214)
TESTING: checkMmap from config.functions(config/BuildSystem/config/functions.py:214)
Check for functional mmap() to allocate shared memory and define HAVE_MMAP
Successful compile:
Source:
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
int main() {
int fd;
fd=open("/tmp/file",O_RDWR);
mmap((void*)0,100,PROT_READ|PROT_WRITE,MAP_SHARED,fd,0);
return 0;
Pushing language C
Popping language C
Defined "HAVE_MMAP" to "1"
TEST configureMemorySize from config.utilities.getResidentSetSize(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
Try to determine how to measure the memory usage
Defined "USE_PROC_FOR_SIZE" to "1"
Using /proc for PetscMemoryGetCurrentUsage()
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
Check for the mechanism to retrieve command line arguments in Fortran
Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
Pushing language FC
Checking for functions [] in library [''] []
Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-VuReVk/config.libraries/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.F90
Successful compile:
Source:
program main
integer i
character*(80) arg
i = command_argument_count()
call get_command_argument(i,arg)
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -lstdc++ -ldl
Popping language FC
Popping language FC
Pushing language C
Defined "HAVE_GFORTRAN_IARGC" to "1"
Popping language C
Checking for functions [get_command_argument_] in library [''] ['-lstdc++', '-ldl', '-Wl,-rpath,/usr/lib/openmpi', '-L/usr/lib/openmpi', '-lmpi_usempif08', '-lmpi_usempi_ignore_tkr', '-lmpi_mpifh', '-lmpi', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1', '-L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1', '-Wl,-rpath,/usr/lib/openmpi', '-lgfortran', '-lm', '-lgomp', '-lgcc_s', '-lquadmath', '-lpthread']
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.libraries/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/config.libraries/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.o -lstdc++ -ldl -Wl,-rpath,/usr/lib/openmpi -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -Wl,-rpath,/usr/lib/openmpi -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.libraries/conftest.o: in function `_check_get_command_argument_':
/tmp/petsc-VuReVk/config.libraries/conftest.c:5: undefined reference to `get_command_argument_'
Popping language C
Checking for functions [getarg_] in library [''] ['-lstdc++', '-ldl', '-Wl,-rpath,/usr/lib/openmpi', '-L/usr/lib/openmpi', '-lmpi_usempif08', '-lmpi_usempi_ignore_tkr', '-lmpi_mpifh', '-lmpi', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1', '-L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1', '-Wl,-rpath,/usr/lib/openmpi', '-lgfortran', '-lm', '-lgomp', '-lgcc_s', '-lquadmath', '-lpthread']
Pushing language C
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
return 0;
Pushing language C
Popping language C
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/config.libraries/conftest.o: in function `_check_getarg_':
/tmp/petsc-VuReVk/config.libraries/conftest.c:5: undefined reference to `getarg_'
Popping language C
Pushing language C
Popping language C
Pushing language C
Popping language C
Pushing language C
Popping language C
Pushing language C
Popping language C
Pushing language C
Popping language C
Checking for functions [ipxfargc_]
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.functions/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.functions/conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
return 0;
Executing: mpicc -o /tmp/petsc-VuReVk/config.functions/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.functions/conftest.o -lstdc++ -ldl -lstdc++ -ldl -Wl,-rpath,/usr/lib/openmpi -L/usr/lib/openmpi -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1 -Wl,-rpath,/usr/lib/openmpi -lgfortran -lm -lgomp -lgcc_s -lquadmath -lpthread
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
return 0;
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
return 0;
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
return 0;
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:24: undefined reference to `iargc_'
Checking for functions [GETARG at 16]
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-VuReVk/config.functions/conftest.c:13:12: error: stray ���@��� in program
char GETARG at 16();
/tmp/petsc-VuReVk/config.functions/conftest.c:13:13: error: expected ���=���, ���,���, ���;���, ���asm��� or ���__attribute__��� before numeric constant
/tmp/petsc-VuReVk/config.functions/conftest.c:21:27: error: missing ')' after "defined"
#if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
/tmp/petsc-VuReVk/config.functions/conftest.c:21:28: error: missing binary operator before token "16"
/tmp/petsc-VuReVk/config.functions/conftest.c:24:7: error: stray ���@��� in program
GETARG at 16();
/tmp/petsc-VuReVk/config.functions/conftest.c:24:1: error: ���GETARG��� undeclared (first use in this function)
GETARG at 16();
/tmp/petsc-VuReVk/config.functions/conftest.c:24:1: note: each undeclared identifier is reported only once for each function it appears in
/tmp/petsc-VuReVk/config.functions/conftest.c:24:7: error: expected ���;��� before numeric constant
GETARG at 16();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
return 0;
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
return 0;
Defined "HAVE__GFORTRAN_IARGC" to "1"
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
Checks if certain feature test macros are support
All intermediate test results are stored in /tmp/petsc-VuReVk/config.utilities.featureTestMacros
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.utilities.featureTestMacros -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.featureTestMacros/conftest.c
stderr:
/tmp/petsc-VuReVk/config.utilities.featureTestMacros/conftest.c:4:10: fatal error: sysctl.h: No such file or directory
#include <sysctl.h>
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
return 0;
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.utilities.featureTestMacros -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.featureTestMacros/conftest.c
stderr:
In file included from /usr/include/bits/libc-header-start.h:33,
from /usr/include/stdlib.h:25,
from /tmp/petsc-VuReVk/config.utilities.featureTestMacros/conftest.c:4:
/usr/include/features.h:184:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
# warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
return 0;
Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
return 0;
Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
return 0;
Defined "_GNU_SOURCE" to "1"
TEST configureMissingDefines from config.utilities.missing(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/missing.py:57)
TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
Checks for limits
All intermediate test results are stored in /tmp/petsc-VuReVk/config.utilities.missing
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.utilities.missing/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.utilities.featureTestMacros -I/tmp/petsc-VuReVk/config.utilities.missing -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
#include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
return 0;
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
#include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/missing.py:67)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:67)
Checks if u_short is undefined
Successful compile:
Source:
int main() {
u_short foo;
return 0;
TEST configureMissingFunctions from config.utilities.missing(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/missing.py:73)
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:73)
Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/missing.py:93)
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:93)
Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/missing.py:110)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:110)
Successful compile:
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#if !defined(_GNU_SOURCE)
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
return 0;
Pushing language Cxx
Executing: mpicxx -c -o /tmp/petsc-VuReVk/config.utilities.missing/conftest.o -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.utilities.missing -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.missing/conftest.cc
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
return 0;
Pushing language CXX
Popping language CXX
Executing: mpicxx -o /tmp/petsc-VuReVk/config.utilities.missing/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.utilities.missing/conftest.o -lstdc++ -ldl
Popping language Cxx
TEST configureMissingSrandPrototype from config.utilities.missing(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/missing.py:135)
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:135)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
return 0;
TEST configureFPTrap from config.utilities.FPTrap(/home/ryan/projects/moose/petsc/config/BuildSystem/config/utilities/FPTrap.py:28)
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:28)
Checking the handling of floating point traps
Checking for header: sigfpe.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory
#include <sigfpe.h>
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory
#include <sigfpe.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory #include <sigfpe.h> ^~~~~~~~~~compilation terminated.:
Checking for header: fpxcp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory
#include <fpxcp.h>
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory
#include <fpxcp.h>
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory #include <fpxcp.h> ^~~~~~~~~compilation terminated.:
Checking for header: floatingpoint.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory
#include <floatingpoint.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-VuReVk/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory #include <floatingpoint.h> ^~~~~~~~~~~~~~~~~compilation terminated.:
TEST configureScalarType from PETSc.options.scalarTypes(/home/ryan/projects/moose/petsc/config/PETSc/options/scalarTypes.py:37)
TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:37)
Choose between real and complex numbers
Defined "USE_SCALAR_REAL" to "1"
Scalar type is real
Pushing language C
All intermediate test results are stored in /tmp/petsc-VuReVk/PETSc.options.scalarTypes
Executing: mpicc -c -o /tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.libraries -I/tmp/petsc-VuReVk/config.utilities.featureTestMacros -I/tmp/petsc-VuReVk/config.utilities.missing -I/tmp/petsc-VuReVk/PETSc.options.scalarTypes -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnormal(b);
return 0;
Pushing language C
Popping language C
Executing: mpicc -o /tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.o -lstdc++ -ldl
Defined "HAVE_ISNORMAL" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnan(b);
return 0;
Pushing language C
Popping language C
Defined "HAVE_ISNAN" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isinf(b);
return 0;
Pushing language C
Popping language C
Defined "HAVE_ISINF" to "1"
stderr:
/tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.c: In function ���main���:
/tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.c:6:24: warning: implicit declaration of function ���_isnan��� [-Wimplicit-function-declaration]
double b = 2.0;int a = _isnan(b);
Source:
#include <float.h>
int main() {
return 0;
Pushing language C
Popping language C
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: /tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.o: in function `main':
/tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_isnan'
collect2: error: ld returned 1 exit status
stderr:
/tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.c:6:24: warning: implicit declaration of function ���_finite��� [-Wimplicit-function-declaration]
double b = 2.0;int a = _finite(b);
Source:
#include <float.h>
int main() {
return 0;
Pushing language C
Popping language C
stderr:
/tmp/petsc-VuReVk/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_finite'
Popping language C
TEST configurePrecision from PETSc.options.scalarTypes(/home/ryan/projects/moose/petsc/config/PETSc/options/scalarTypes.py:79)
TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:79)
Set the default real number precision for PETSc objects
Defined "USE_REAL_DOUBLE" to "1"
Defined make macro "PETSC_SCALAR_SIZE" to "64"
Precision is double
TEST configureMkdir from config.programs(/home/ryan/projects/moose/petsc/config/BuildSystem/config/programs.py:23)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:23)
Make sure we can have mkdir automatically make intermediate directories
Checking for program /home/ryan/bin/mkdir...not found
Checking for program /usr/local/bin/mkdir...not found
Checking for program /usr/local/sbin/mkdir...not found
Checking for program /usr/bin/mkdir...found
Executing: /usr/bin/mkdir -p .conftest/tmp
Adding -p flag to /usr/bin/mkdir -p to automatically create directories
Defined make macro "MKDIR" to "/usr/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/home/ryan/projects/moose/petsc/config/BuildSystem/config/programs.py:45)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:45)
Check for autoreconf
Checking for program /home/ryan/bin/autoreconf...not found
Checking for program /usr/local/bin/autoreconf...not found
Checking for program /usr/local/sbin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
All intermediate test results are stored in /tmp/petsc-VuReVk/config.programs
Executing: cd /tmp/petsc-VuReVk/config.programs/autoconfdir&&/usr/bin/autoreconf
autoreconf test successful!
Checking for program /home/ryan/bin/libtoolize...not found
Checking for program /usr/local/bin/libtoolize...not found
Checking for program /usr/local/sbin/libtoolize...not found
Checking for program /usr/bin/libtoolize...found
TEST configurePrograms from config.programs(/home/ryan/projects/moose/petsc/config/BuildSystem/config/programs.py:72)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:72)
Check for the programs needed to build and run PETSc
Checking for program /home/ryan/bin/sh...not found
Checking for program /usr/local/bin/sh...not found
Checking for program /usr/local/sbin/sh...not found
Checking for program /usr/bin/sh...found
Defined make macro "SHELL" to "/usr/bin/sh"
Checking for program /home/ryan/bin/sed...not found
Checking for program /usr/local/bin/sed...not found
Checking for program /usr/local/sbin/sed...not found
Checking for program /usr/bin/sed...found
Defined make macro "SED" to "/usr/bin/sed"
Executing: /usr/bin/sed -i s/sed/sd/g "/tmp/petsc-VuReVk/config.programs/sed1"
Adding SEDINPLACE cmd: /usr/bin/sed -i
Defined make macro "SEDINPLACE" to "/usr/bin/sed -i"
Checking for program /home/ryan/bin/mv...not found
Checking for program /usr/local/bin/mv...not found
Checking for program /usr/local/sbin/mv...not found
Checking for program /usr/bin/mv...found
Defined make macro "MV" to "/usr/bin/mv"
Checking for program /home/ryan/bin/cp...not found
Checking for program /usr/local/bin/cp...not found
Checking for program /usr/local/sbin/cp...not found
Checking for program /usr/bin/cp...found
Defined make macro "CP" to "/usr/bin/cp"
Checking for program /home/ryan/bin/grep...not found
Checking for program /usr/local/bin/grep...not found
Checking for program /usr/local/sbin/grep...not found
Checking for program /usr/bin/grep...found
Defined make macro "GREP" to "/usr/bin/grep"
Checking for program /home/ryan/bin/rm...not found
Checking for program /usr/local/bin/rm...not found
Checking for program /usr/local/sbin/rm...not found
Checking for program /usr/bin/rm...found
Defined make macro "RM" to "/usr/bin/rm -f"
Checking for program /home/ryan/bin/diff...not found
Checking for program /usr/local/bin/diff...not found
Checking for program /usr/local/sbin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/tmp/petsc-VuReVk/config.programs/diff1" "/tmp/petsc-VuReVk/config.programs/diff2"
Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /home/ryan/projects/moose/petsc/lib/petsc/bin/win32fe/ps...not found
Checking for program /home/ryan/bin/gzip...not found
Checking for program /usr/local/bin/gzip...not found
Checking for program /usr/local/sbin/gzip...not found
Checking for program /usr/bin/gzip...found
Defined make macro "GZIP" to "/usr/bin/gzip"
Defined "HAVE_GZIP" to "1"
Defined make macro "PYTHON" to "/usr/bin/python2"
Checking for program /home/ryan/bin/m4...not found
Checking for program /usr/local/bin/m4...not found
Checking for program /usr/local/sbin/m4...not found
Checking for program /usr/bin/m4...found
Defined make macro "M4" to "/usr/bin/m4"
TEST configureMake from config.packages.make(/home/ryan/projects/moose/petsc/config/BuildSystem/config/packages/make.py:85)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:85)
Check Guesses for GNU make
Executing: gmake --version
GNUMake check failed: Could not execute "gmake --version":
/bin/sh: gmake: command not found
Executing: make --version
stdout:
GNU Make 4.2.1
Built for x86_64-pc-linux-gnu
Copyright (C) 1988-2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Checking for program /home/ryan/bin/make...not found
Checking for program /usr/local/bin/make...not found
Checking for program /usr/local/sbin/make...not found
Checking for program /usr/bin/make...found
Defined make macro "MAKE" to "/usr/bin/make"
TEST setupGNUMake from config.packages.make(/home/ryan/projects/moose/petsc/config/BuildSystem/config/packages/make.py:113)
TESTING: setupGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:113)
Setup other GNU make stuff
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
Defined make macro "MAKE_IS_GNUMAKE" to "1"
Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/make --print-directory"
Defined make macro "OMAKE" to "/usr/bin/make --no-print-directory"
Defined make macro "MAKE_PAR_OUT_FLG" to "--output-sync=recurse"
TEST configureMakeNP from config.packages.make(/home/ryan/projects/moose/petsc/config/BuildSystem/config/packages/make.py:161)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:161)
check no of cores on the build machine [perhaps to do make '-j ncores']
module multiprocessing found 4 cores: using make_np = 4
Defined make macro "MAKE_NP" to "4"
Defined make macro "MAKE_TEST_NP" to "2"
Defined make macro "MAKE_LOAD" to "6.0"
Defined make macro "NPMAX" to "4"
TEST alternateConfigureLibrary from config.packages.OpenMPI(/home/ryan/projects/moose/petsc/config/BuildSystem/config/package.py:805)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:805)
Called if --with-packagename=0; does nothing by default
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
TEST alternateConfigureLibrary from config.packages.MPICH(/home/ryan/projects/moose/petsc/config/BuildSystem/config/package.py:805)
TESTING: alternateConfigureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:805)
Pushing language C
TEST checkDependencies from config.packages.MPI(/home/ryan/projects/moose/petsc/config/BuildSystem/config/package.py:722)
TESTING: checkDependencies from config.packages.MPI(config/BuildSystem/config/package.py:722)
TEST configureLibrary from config.packages.MPI(/home/ryan/projects/moose/petsc/config/BuildSystem/config/packages/MPI.py:524)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:524)
Calls the regular package configureLibrary and then does an additional test needed by MPI
Checking for a functional MPI
Checking for library in Compiler specific search MPI: []
TEST check from config.libraries(/home/ryan/projects/moose/petsc/config/BuildSystem/config/libraries.py:158)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:158)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [MPI_Init MPI_Comm_create] in library [] []
Pushing language C
Executing: mpicc -c -o /tmp/petsc-VuReVk/config.libraries/conftest.o -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.compilers -I/tmp/petsc-VuReVk/config.utilities.closure -I/tmp/petsc-VuReVk/config.headers -I/tmp/petsc-VuReVk/config.utilities.cacheDetails -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.atomics -I/tmp/petsc-VuReVk/config.functions -I/tmp/petsc-VuReVk/config.utilities.featureTestMacros -I/tmp/petsc-VuReVk/config.utilities.missing -I/tmp/petsc-VuReVk/PETSc.options.scalarTypes -I/tmp/petsc-VuReVk/config.libraries -fPIC -fopenmp -g -O /tmp/petsc-VuReVk/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
return 0;
Pushing language C
Popping language C
Popping language C
No functions to check for in library [] []
Checking for headers Compiler specific search MPI: ['/usr/include', '/usr/lib/openmpi']
Pushing language C
TEST checkInclude from config.headers(/home/ryan/projects/moose/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['mpi.h'] in ['/usr/include', '/usr/lib/openmpi']
Checking include with compiler flags var CPPFLAGS ['/usr/include', '/usr/lib/openmpi']
Executing: mpicc -E -I/tmp/petsc-VuReVk/config.setCompilers -I/tmp/petsc-VuReVk/config.types -I/tmp/petsc-VuReVk/config.headers -I/usr/include -I/usr/lib/openmpi /tmp/petsc-VuReVk/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-VuReVk/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/tmp/petsc-VuReVk/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-VuReVk/config.headers/conftest.c" 2
# 1 "/tmp/petsc-VuReVk/config.headers/conffix.h" 1
# 1 "/usr/include/mpi.h" 1 3 4
# 232 "/usr/include/mpi.h" 3 4
# 1 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 1 3 4
# 149 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 216 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 328 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef int wchar_t;
# 426 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
typedef struct {
long long __max_align_ll __attribute__((__aligned__(__alignof__(long long))));
long double __max_align_ld __attribute__((__aligned__(__alignof__(long double))));
# 437 "/usr/lib/gcc/x86_64-pc-linux-gnu/8.2.1/include/stddef.h" 3 4
} max_align_t;
# 233 "/usr/include/mpi.h" 2 3 4
# 265 "/usr/include/mpi.h" 3 4
# 1 "/usr/include/mpi_portable_platform.h" 1 3 4
# 266 "/usr/include/mpi.h" 2 3 4
# 342 "/usr/include/mpi.h" 3 4
typedef ptrdiff_t MPI_Aint;
typedef long long MPI_Offset;
typedef long long MPI_Count;
typedef struct ompi_communicator_t *MPI_Comm;
typedef struct ompi_datatype_t *MPI_Datatype;
typedef struct ompi_errhandler_t *MPI_Errhandler;
typedef struct ompi_file_t *MPI_File;
typedef struct ompi_group_t *MPI_Group;
typedef struct ompi_info_t *MPI_Info;
typedef struct ompi_op_t *MPI_Op;
typedef struct ompi_request_t *MPI_Request;
typedef struct ompi_message_t *MPI_Message;
typedef struct ompi_status_public_t MPI_Status;
typedef struct ompi_win_t *MPI_Win;
typedef struct mca_base_var_enum_t *MPI_T_enum;
typedef struct ompi_mpit_cvar_handle_t *MPI_T_cvar_handle;
typedef struct mca_base_pvar_handle_t *MPI_T_pvar_handle;
typedef struct mca_base_pvar_session_t *MPI_T_pvar_session;
struct ompi_status_public_t {
int MPI_SOURCE;
int MPI_TAG;
int MPI_ERROR;
int _cancelled;
size_t _ucount;
typedef struct ompi_status_public_t ompi_status_public_t;
typedef int (MPI_Datarep_extent_function)(MPI_Datatype, MPI_Aint *, void *);
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype,
int, void *, MPI_Offset, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef void (ompi_file_errhandler_fn)(MPI_File *, int *, ...);
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef void (MPI_User_function)(void *, void *, int *, MPI_Datatype *);
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *,
void *, void *, int *);
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *,
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int,
void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *,
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_cancel_function)(void *, int);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn
__attribute__((__deprecated__("MPI_Comm_errhandler_fn was deprecated in MPI-2.2; use MPI_Comm_errhandler_function instead")));
typedef ompi_file_errhandler_fn MPI_File_errhandler_fn
__attribute__((__deprecated__("MPI_File_errhandler_fn was deprecated in MPI-2.2; use MPI_File_errhandler_function instead")));
typedef ompi_file_errhandler_fn MPI_File_errhandler_function;
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn
__attribute__((__deprecated__("MPI_Win_errhandler_fn was deprecated in MPI-2.2; use MPI_Win_errhandler_function instead")));
# 509 "/usr/include/mpi.h" 3 4
enum {
MPI_TAG_UB,
MPI_HOST,
MPI_IO,
MPI_WTIME_IS_GLOBAL,
MPI_APPNUM,
MPI_LASTUSEDCODE,
MPI_UNIVERSE_SIZE,
MPI_WIN_BASE,
MPI_WIN_SIZE,
MPI_WIN_DISP_UNIT,
MPI_WIN_CREATE_FLAVOR,
MPI_WIN_MODEL,
IMPI_CLIENT_SIZE,
IMPI_CLIENT_COLOR,
IMPI_HOST_SIZE,
IMPI_HOST_COLOR
# 623 "/usr/include/mpi.h" 3 4
enum {
MPI_IDENT,
MPI_CONGRUENT,
MPI_SIMILAR,
MPI_UNEQUAL
enum {
MPI_THREAD_SINGLE,
MPI_THREAD_FUNNELED,
MPI_THREAD_SERIALIZED,
MPI_THREAD_MULTIPLE
enum {
MPI_COMBINER_NAMED,
MPI_COMBINER_DUP,
MPI_COMBINER_CONTIGUOUS,
MPI_COMBINER_VECTOR,
MPI_COMBINER_HVECTOR_INTEGER,
MPI_COMBINER_HVECTOR,
MPI_COMBINER_INDEXED,
MPI_COMBINER_HINDEXED_INTEGER,
MPI_COMBINER_HINDEXED,
MPI_COMBINER_INDEXED_BLOCK,
MPI_COMBINER_STRUCT_INTEGER,
MPI_COMBINER_STRUCT,
MPI_COMBINER_SUBARRAY,
MPI_COMBINER_DARRAY,
MPI_COMBINER_F90_REAL,
MPI_COMBINER_F90_COMPLEX,
MPI_COMBINER_F90_INTEGER,
MPI_COMBINER_RESIZED,
MPI_COMBINER_HINDEXED_BLOCK
enum {
MPI_COMM_TYPE_SHARED,
OMPI_COMM_TYPE_HWTHREAD,
OMPI_COMM_TYPE_CORE,
OMPI_COMM_TYPE_L1CACHE,
OMPI_COMM_TYPE_L2CACHE,
OMPI_COMM_TYPE_L3CACHE,
OMPI_COMM_TYPE_SOCKET,
OMPI_COMM_TYPE_NUMA,
OMPI_COMM_TYPE_BOARD,
OMPI_COMM_TYPE_HOST,
OMPI_COMM_TYPE_CU,
OMPI_COMM_TYPE_CLUSTER
enum {
MPI_T_VERBOSITY_USER_BASIC,
MPI_T_VERBOSITY_USER_DETAIL,
MPI_T_VERBOSITY_USER_ALL,
MPI_T_VERBOSITY_TUNER_BASIC,
MPI_T_VERBOSITY_TUNER_DETAIL,
MPI_T_VERBOSITY_TUNER_ALL,
MPI_T_VERBOSITY_MPIDEV_BASIC,
MPI_T_VERBOSITY_MPIDEV_DETAIL,
MPI_T_VERBOSITY_MPIDEV_ALL
enum {
MPI_T_SCOPE_CONSTANT,
MPI_T_SCOPE_READONLY,
MPI_T_SCOPE_LOCAL,
MPI_T_SCOPE_GROUP,
MPI_T_SCOPE_GROUP_EQ,
MPI_T_SCOPE_ALL,
MPI_T_SCOPE_ALL_EQ
enum {
MPI_T_BIND_NO_OBJECT,
MPI_T_BIND_MPI_COMM,
MPI_T_BIND_MPI_DATATYPE,
MPI_T_BIND_MPI_ERRHANDLER,
MPI_T_BIND_MPI_FILE,
MPI_T_BIND_MPI_GROUP,
MPI_T_BIND_MPI_OP,
MPI_T_BIND_MPI_REQUEST,
MPI_T_BIND_MPI_WIN,
MPI_T_BIND_MPI_MESSAGE,
MPI_T_BIND_MPI_INFO
enum {
MPI_T_PVAR_CLASS_STATE,
MPI_T_PVAR_CLASS_LEVEL,
MPI_T_PVAR_CLASS_SIZE,
MPI_T_PVAR_CLASS_PERCENTAGE,
MPI_T_PVAR_CLASS_HIGHWATERMARK,
MPI_T_PVAR_CLASS_LOWWATERMARK,
MPI_T_PVAR_CLASS_COUNTER,
MPI_T_PVAR_CLASS_AGGREGATE,
MPI_T_PVAR_CLASS_TIMER,
MPI_T_PVAR_CLASS_GENERIC
# 820 "/usr/include/mpi.h" 3 4
__attribute__((visibility("default"))) int OMPI_C_MPI_TYPE_NULL_DELETE_FN( MPI_Datatype datatype,
int type_keyval,
void* attribute_val_out,
void* extra_state );
__attribute__((visibility("default"))) int OMPI_C_MPI_TYPE_NULL_COPY_FN( MPI_Datatype datatype,
int type_keyval,
void* extra_state,
void* attribute_val_in,
int* flag );
__attribute__((visibility("default"))) int OMPI_C_MPI_TYPE_DUP_FN( MPI_Datatype datatype,
int type_keyval,
void* extra_state,
int* flag );
__attribute__((visibility("default"))) int OMPI_C_MPI_COMM_NULL_DELETE_FN( MPI_Comm comm,
int comm_keyval,
__attribute__((visibility("default"))) int OMPI_C_MPI_COMM_NULL_COPY_FN( MPI_Comm comm,
int comm_keyval,
void* extra_state,
int* flag );
__attribute__((visibility("default"))) int OMPI_C_MPI_COMM_DUP_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag );
__attribute__((visibility("default"))) int OMPI_C_MPI_WIN_NULL_DELETE_FN( MPI_Win window,
int win_keyval,
__attribute__((visibility("default"))) int OMPI_C_MPI_WIN_NULL_COPY_FN( MPI_Win window, int win_keyval,
void* extra_state,
int* flag );
__attribute__((visibility("default"))) int OMPI_C_MPI_WIN_DUP_FN( MPI_Win window, int win_keyval,
void* extra_state,
int* flag );
# 874 "/usr/include/mpi.h" 3 4
__attribute__((visibility("default"))) extern struct ompi_predefined_communicator_t ompi_mpi_comm_world;
__attribute__((visibility("default"))) extern struct ompi_predefined_communicator_t ompi_mpi_comm_self;
__attribute__((visibility("default"))) extern struct ompi_predefined_communicator_t ompi_mpi_comm_null;
__attribute__((visibility("default"))) extern struct ompi_predefined_group_t ompi_mpi_group_empty;
__attribute__((visibility("default"))) extern struct ompi_predefined_group_t ompi_mpi_group_null;
__attribute__((visibility("default"))) extern struct ompi_predefined_request_t ompi_request_null;
__attribute__((visibility("default"))) extern struct ompi_predefined_message_t ompi_message_null;
__attribute__((visibility("default"))) extern struct ompi_predefined_message_t ompi_message_no_proc;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_null;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_min;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_max;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_sum;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_prod;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_land;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_band;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_lor;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_bor;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_lxor;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_bxor;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_maxloc;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_minloc;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_replace;
__attribute__((visibility("default"))) extern struct ompi_predefined_op_t ompi_mpi_op_no_op;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_datatype_null;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_char;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_signed_char;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_char;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_byte;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_short;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_short;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_int;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_unsigned;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_long;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_long;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_long_long_int;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_long_long;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_float;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_double;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_long_double;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_wchar;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_packed;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_cxx_bool;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_cxx_cplex;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_cxx_dblcplex;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_cxx_ldblcplex;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_logical;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_character;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_integer;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_real;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_dblprec;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_cplex;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_dblcplex;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_ldblcplex;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_2int;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_2integer;
__attribute__((visibility("default"))) extern struct ompi_predefined_datatype_t ompi_mpi_2real;
