[petsc-users] [petsc-maint] Error during compile
    Mark Adams
    mfadams at lbl.gov
    Sun Dec 29 09:53:26 CST 2019
On Sun, Dec 29, 2019 at 9:09 AM 朱玉泉 <asachoo at shu.edu.cn> wrote:
> I'm sorry that I have deleted the gnu-opt directory and made from scratch,
> the same errors still occur. So, could you tell me what will you do if you
> face this problem?
I now see that you are using a very old version of PETSc. Unless someone
else can diagnose this you may have to upgrade PETSc. PETSc is very
reliable after you get configure done, but perhaps someone else can help.
Meanwhile I would just upgrade your PETSc version. Your old configure
captions should work, although some 3rd party packages are no longer
supported.
> -----原始邮件-----
> *发件人:*"Mark Adams" <mfadams at lbl.gov>
> *发送时间:*2019-12-29 21:28:07 (星期日)
> *收件人:* "朱玉泉" <asachoo at shu.edu.cn>
> *抄送:* petsc-maint <petsc-maint at mcs.anl.gov>
> *主题:* Re: [petsc-maint] Error during compile
> First thing I would do is start from scratch. Delete the gnu-opt
> directory, reconfigure and make.
> On Sun, Dec 29, 2019 at 6:02 AM 朱玉泉 <asachoo at shu.edu.cn> wrote:
>> I tried to install PETSc , but it had an error ,could you please tell me
>> how to deal it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191229/c379ca47/attachment-0001.html>
Name: ???? 2019-12-29 ??10.05.11.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191229/c379ca47/attachment-0002.png>
Name: ???? 2019-12-29 ??6.54.57.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191229/c379ca47/attachment-0003.png>
