[petsc-users] [petsc-maint] Error during compile
Sun Dec 29 15:31:21 CST 2019
The problem is that your PETSc is old and your MPI is new. That type has
been removed from MPI. As Mark points out, please
upgrade PETSc and it will work. You could also try using an ancient MPI,
but that seems counterproductive.
     Matt
On Sun, Dec 29, 2019 at 10:54 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Sun, Dec 29, 2019 at 9:09 AM 朱玉泉 <asachoo at shu.edu.cn> wrote:
>> I'm sorry that I have deleted the gnu-opt directory and made from
>> scratch, the same errors still occur. So, could you tell me what will you
>> do if you face this problem?
> I now see that you are using a very old version of PETSc. Unless someone
> else can diagnose this you may have to upgrade PETSc. PETSc is very
> reliable after you get configure done, but perhaps someone else can help.
> Meanwhile I would just upgrade your PETSc version. Your old configure
> captions should work, although some 3rd party packages are no longer
> supported.
>> -----原始邮件-----
>> *发件人:*"Mark Adams" <mfadams at lbl.gov>
>> *发送时间:*2019-12-29 21:28:07 (星期日)
>> *收件人:* "朱玉泉" <asachoo at shu.edu.cn>
>> *抄送:* petsc-maint <petsc-maint at mcs.anl.gov>
>> *主题:* Re: [petsc-maint] Error during compile
>> First thing I would do is start from scratch. Delete the gnu-opt
>> directory, reconfigure and make.
>> On Sun, Dec 29, 2019 at 6:02 AM 朱玉泉 <asachoo at shu.edu.cn> wrote:
>>> I tried to install PETSc , but it had an error ,could you please tell me
>>> how to deal it.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191229/3ad3178f/attachment-0001.html>
Name: ???? 2019-12-29 ??6.54.57.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191229/3ad3178f/attachment-0001.png>
