[petsc-users] win32fe icl won't work
Sam Guo sam.guo at cd-adapco.com
Mon Dec 16 17:56:14 CST 2019
Dear PETSc dev team,
   I tried to compile petsc using intel compiler win32fe icl on cygwin but
encountered error. By the way, I am able to compile using visual studio
compiler win32fe cl.
             Configuring PETSc to compile on your system
Warning: "with-clean" is specified. Removing all build files from
arch-starccmplus_s===============================================================================
TESTING: checkCCompiler from
config.setCompilers(config/BuildSystem/config/setCompilers.py*******************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
C compiler you provided with -with-cc=win32fe icl does not work.
Cannot compile/link C with
/home/xianzhongg/dev/star/petsc/lib/petsc/bin/win32fe/win32fe icl.
BR,
Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191216/92e8e9a5/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191216/92e8e9a5/attachment-0001.obj>
