[petsc-users] [petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
Balay, Satish
balay at mcs.anl.gov
Thu Aug 22 11:59:59 CDT 2019
On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
> PETSc folks.
> This announcement is for people who access PETSc from the BitBucket repository or post issues or have other activities with the Bitbucket repository
> We have changed the location of the PETSc repository from BitBucket to GitLab. For each copy of the repository you need to do
> git remote set-url origin git at gitlab.com<mailto:git at gitlab.com>:petsc/petsc.git
> or
> git remote set-url origin https://gitlab.com/petsc/petsc.git
> You will likely also want to set up an account on gitlab and remember to set the ssh key information
> if you previously had write permission to the petsc repository and cannot write to the new repository please email bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov> with your GitLab
> username and the email used
> Please do not make pull requests to the Gitlab site yet; we will be manually processing the PR from the BitBucket site over the next couple of
> days as we implement the testing.
> Please be patient, this is all new to use and it may take a few days to get out all the glitches.
Just an update:
We are still in the process of setting up the CI at gitlab. So we are
not yet ready to process PRs [or Merge Requests (MRs) in gitlab terminology]
As of now - we have the old jenkins equivalent [and a few additional]
tests working with gitlab setup. i.e
https://gitlab.com/petsc/petsc/pipelines/77669506
But we are yet to migrate all the regular [aka next] tests to this
infrastructure.
Satish
> Thanks for your support
> Barry
> The reason for switching to GitLab is that it has a better testing system than BitBucket and Gitlab. We hope that will allow us to test and manage
> pull requests more rapidly, efficiently and accurately, thus allowing us to improve and add to PETSc more quickly.
