[petsc-users] PetscInitialize take various time to run on different node
Kun Jiao
KJiao at slb.com
Mon Aug 19 15:49:28 CDT 2019
I am running into a problem, different node/process take different time to run petscinitialize. The difference could be 5~10mins.
I put some check before petscinitialize, and after petscinitialize.
MPI_Init(argc, args);
int rank;
MPI_Comm_rank(MPI_COMM_WORLD, &rank );
std::cout << "I am here :"<< rank << "!!!!" << std::endl;
PetscErrorCode ierr = PetscInitialize(&argc, &args, (char*)0, help);
std::cout << "You am here 2:"<< rank << "!!!!" << std::endl;
"I am here" message was printout for every process, but not "You are here 2" message.
Very strange.
Any suggestion is appreciated.
Kun
Schlumberger-Private
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190819/f1f0b38b/attachment.html>
