[petsc-users] [petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
Smith, Barry F. bsmith at mcs.anl.gov
Tue Aug 20 19:25:34 CDT 2019
  Great
> On Aug 20, 2019, at 7:22 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Never mind. I updated everything to point to gitlab. Everything looks fine for me now.
> Fande
>> On Aug 20, 2019, at 6:05 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> Is it so difficult for you to change the link in your test system to petsc-pre-gitlab?
>> Barry
>>> On Aug 20, 2019, at 4:40 PM, Fande Kong via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>>> Any way to have the link https://bitbucket.org/petsc/petsc valid (read only) for a couple of weeks?  We have some tests that dynamically picks up a particular version of PETSc (master, maint, tag).  The link was removed now,  and that disabled us to have daily tests. If we could keep this link for a couple of weeks, that will give me a grace period to update all the impacted tests.
>>> Any particular reason that we have to rename petsc to petsc-pre-gitlab?
>>> Thanks,
>>> Fande Kong,
>>> On Tue, Aug 20, 2019 at 2:52 AM Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>>> Dear Satish, are you planning to migrate petsc4py?
>>> On Mon, 19 Aug 2019 at 23:47, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>>> A note:
>>> The bitbucket repository is saved at https://bitbucket.org/petsc/petsc-pre-gitlab
>>> The git part is now read-only. The other parts [issues, PRs, wiki etc] are perhaps writable - but we should avoid that.
>>> Satish
>>>> On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
>>>>  PETSc folks.
>>>>   This announcement is for people who access PETSc from the BitBucket repository or post issues or have other activities with the Bitbucket repository
>>>>  We have changed  the location of the PETSc repository from BitBucket to GitLab. For each copy of the repository you need to do
>>>>  git remote set-url origin git at gitlab.com<mailto:git at gitlab.com>:petsc/petsc.git
>>>>  or
>>>>  git remote set-url origin https://gitlab.com/petsc/petsc.git
>>>>  You will likely also want to set up an account on gitlab and remember to set the ssh key information
>>>>  if you previously had write permission to the petsc repository and cannot write to the new repository please email bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov> with your GitLab
>>>>  username and the email used
>>>>   Please do not make pull requests to the Gitlab site yet; we will be manually processing the PR from the BitBucket site over the next couple of
>>>>   days as we implement the testing.
>>>>   Please be patient, this is all new to use and it may take a few days to get out all the glitches.
>>>>   Thanks for your support
>>>>   Barry
>>>>  The reason for switching to GitLab is that it has a better testing system than BitBucket and Gitlab. We hope that will allow us to test and manage
>>>>  pull requests more rapidly, efficiently and accurately, thus allowing us to improve and add to PETSc more quickly.
>>> Lisandro Dalcin
>>> Research Scientist
>>> Extreme Computing Research Center (ECRC)
>>> King Abdullah University of Science and Technology (KAUST)
>>> http://ecrc.kaust.edu.sa/
