[petsc-users] Getting the connectivity from DMPlex
Wed Aug 21 07:41:48 CDT 2019
On Wed, Aug 21, 2019 at 8:35 AM Jian Zhang - 3ME <J.Zhang-10 at tudelft.nl>
wrote:
> Hi Matthew,
> That is ok. May I ask you one more question?
> Sorry. I just start to learn how to use DMPLex. If I have an msh file
> including the triangular elements (t3). After I use DMPlex to read this
> mesh, how can I know the element type (actually which is t3) by using the
> functions inside DMPlex?
They are cells with cone size 3.
   Matt
> Best,
> Jian
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* 21 August 2019 14:24:56
> *To:* Jian Zhang - 3ME
> *Cc:* Jed Brown; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Getting the connectivity from DMPlex
> On Wed, Aug 21, 2019 at 8:21 AM Jian Zhang - 3ME <J.Zhang-10 at tudelft.nl>
> wrote:
>> Hi Matthew,
>> Thanks for your answer. I just looked at the pestc4py 3.11.0 (I think it
>> is the newest one).
>> Actually, I did not find DMPlexGetClosure function in the DMPlex.pyx,
>> also not in DM.pyx.
>> Sorry, I messed up the name in my mail. Its getTransitiveClosure()
> https://bitbucket.org/petsc/petsc4py/src/9598d8fb2bb0baa79f99ebf76991ddecd1fd173e/src/PETSc/DMPlex.pyx#lines-332
>   Thanks,
>     Matt
>> Best,
>> Jian
>> *Sent:* 21 August 2019 14:03:19
>> On Wed, Aug 21, 2019 at 7:48 AM Jian Zhang - 3ME via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi Jed,
>>> Thank you very much. I tried to use DMPlexGetCone, but the output is the
>>> edge ids, not the vertice ids. For the function DMPlexGetClosureIndices,
>>> I can not find it in petsc4py. Do you know any alternative ways to solve
>>> this?
>> DMPlexGetClosure() should be in petsc4py. It also returns orientations,
>> which you can just filter out.
>>   Thanks,
>>      Matt
>>> Best,
>>> Jian
>>> *From:* Jed Brown <jed at jedbrown.org>
>>> *Sent:* 21 August 2019 13:42:41
>>> *To:* Jian Zhang - 3ME; petsc-users at mcs.anl.gov
>>> Jian Zhang - 3ME via petsc-users <petsc-users at mcs.anl.gov> writes:
>>> > Hi guys,
>>> > I am trying to get the element connectivity from DMPlex. The input is
>>> the element id, and the output should be the vertice ids. Which function
>>> should I use to achieve this? Thanks in advance.
>>> See DMPlexGetCone or DMPlexGetClosureIndices.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190821/bb88931e/attachment.html>
