[petsc-users] Getting the connectivity from DMPlex
Jian Zhang - 3ME
J.Zhang-10 at tudelft.nl
Wed Aug 21 07:35:07 CDT 2019
Hi Matthew,
That is ok. May I ask you one more question?
Sorry. I just start to learn how to use DMPLex. If I have an msh file including the triangular elements (t3). After I use DMPlex to read this mesh, how can I know the element type (actually which is t3) by using the functions inside DMPlex?
Best,
Jian
Sent: 21 August 2019 14:24:56
To: Jian Zhang - 3ME
Cc: Jed Brown; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Getting the connectivity from DMPlex
On Wed, Aug 21, 2019 at 8:21 AM Jian Zhang - 3ME <J.Zhang-10 at tudelft.nl<mailto:J.Zhang-10 at tudelft.nl>> wrote:
Hi Matthew,
Thanks for your answer. I just looked at the pestc4py 3.11.0 (I think it is the newest one).
Actually, I did not find DMPlexGetClosure function in the DMPlex.pyx, also not in DM.pyx.
Sorry, I messed up the name in my mail. Its getTransitiveClosure()
https://bitbucket.org/petsc/petsc4py/src/9598d8fb2bb0baa79f99ebf76991ddecd1fd173e/src/PETSc/DMPlex.pyx#lines-332
Matt
Best,
Jian
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: 21 August 2019 14:03:19
Cc: Jed Brown; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Wed, Aug 21, 2019 at 7:48 AM Jian Zhang - 3ME via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi Jed,
Thank you very much. I tried to use DMPlexGetCone, but the output is the edge ids, not the vertice ids. For the function DMPlexGetClosureIndices, I can not find it in petsc4py. Do you know any alternative ways to solve this?
DMPlexGetClosure() should be in petsc4py. It also returns orientations, which you can just filter out.
Matt
Best,
Jian
From: Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>>
Sent: 21 August 2019 13:42:41
To: Jian Zhang - 3ME; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Jian Zhang - 3ME via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> writes:
> Hi guys,
> I am trying to get the element connectivity from DMPlex. The input is the element id, and the output should be the vertice ids. Which function should I use to achieve this? Thanks in advance.
See DMPlexGetCone or DMPlexGetClosureIndices.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190821/0c7a439e/attachment.html>
