[petsc-users] [petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
    Fande Kong
    fdkong.jd at gmail.com
    Tue Aug 20 19:22:47 CDT 2019
Never mind. I updated everything to point to gitlab. Everything looks fine for me now.
Fande
> On Aug 20, 2019, at 6:05 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>  Is it so difficult for you to change the link in your test system to petsc-pre-gitlab?
>  Barry
>> On Aug 20, 2019, at 4:40 PM, Fande Kong via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>> Any way to have the link https://bitbucket.org/petsc/petsc valid (read only) for a couple of weeks?  We have some tests that dynamically picks up a particular version of PETSc (master, maint, tag).  The link was removed now,  and that disabled us to have daily tests. If we could keep this link for a couple of weeks, that will give me a grace period to update all the impacted tests.
>> Any particular reason that we have to rename petsc to petsc-pre-gitlab?
>> Thanks,
>> Fande Kong,
>> On Tue, Aug 20, 2019 at 2:52 AM Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>> Dear Satish, are you planning to migrate petsc4py?
>> On Mon, 19 Aug 2019 at 23:47, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>> A note:
>> The bitbucket repository is saved at https://bitbucket.org/petsc/petsc-pre-gitlab
>> The git part is now read-only. The other parts [issues, PRs, wiki etc] are perhaps writable - but we should avoid that.
>> Satish
>>> On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
>>>   PETSc folks.
>>>    This announcement is for people who access PETSc from the BitBucket repository or post issues or have other activities with the Bitbucket repository
>>>   We have changed  the location of the PETSc repository from BitBucket to GitLab. For each copy of the repository you need to do
>>>   git remote set-url origin git at gitlab.com<mailto:git at gitlab.com>:petsc/petsc.git
>>>   or
>>>   git remote set-url origin https://gitlab.com/petsc/petsc.git
>>>   You will likely also want to set up an account on gitlab and remember to set the ssh key information
>>>   if you previously had write permission to the petsc repository and cannot write to the new repository please email bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov> with your GitLab
>>>   username and the email used
>>>    Please do not make pull requests to the Gitlab site yet; we will be manually processing the PR from the BitBucket site over the next couple of
>>>    days as we implement the testing.
>>>    Please be patient, this is all new to use and it may take a few days to get out all the glitches.
>>>    Thanks for your support
>>>    Barry
>>>   The reason for switching to GitLab is that it has a better testing system than BitBucket and Gitlab. We hope that will allow us to test and manage
>>>   pull requests more rapidly, efficiently and accurately, thus allowing us to improve and add to PETSc more quickly.
>> Lisandro Dalcin
>> Research Scientist
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
