[petsc-users] Refine DMPlex with a Refinement Function
Daniel Mckinnell
d_mckinnell at aol.co.uk
Fri Aug 2 08:10:42 CDT 2019
Thank you a lot, that works well for Simplex cells when running on one processor. Do you know anything that works for Tensor cells and/or when running in parallel?Thanks again for all of your help.Daniel
-----Original Message-----
To: Daniel Mckinnell <d_mckinnell at aol.co.uk>
CC: petsc-users <petsc-users at mcs.anl.gov>
Sent: Thu, 1 Aug 2019 17:36
Subject: Re: [petsc-users] Refine DMPlex with a Refinement Function
On Thu, 1 Aug 2019 at 16:59, Daniel Mckinnell via petsc-users <petsc-users at mcs.anl.gov> wrote:
I have been having some trouble trying to refine a DMPlex object using a Refinement Function. I have been working with reference to the code discussed here: https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2019-April/038341.html including the code from the GitHub directory mentioned. The error I have been getting is as follows:
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: No grid refiner of dimension 2 registered
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.11.2, unknown
[0]PETSC ERROR: ./fpf on a arch-linux2-c-debug named cromars by daniel Thu Aug 1 15:40:18 2019
[0]PETSC ERROR: Configure options −−download−f2cblaslapack=yes −−with−debugging=1 −−download−metis=yes −−download−parmetis=yes −−with−fortran−bindings=0 −−with−python=0 -download-openmpi=1 −−with−c−support −−with−clanguage=cxx
[0]PETSC ERROR: #1 DMPlexRefine_Internal() line 215 in /home/daniel/petsc/src/dm/impls/plex/plexadapt.c
[0]PETSC ERROR: #2 DMRefine_Plex() line 10381 in /home/daniel/petsc/src/dm/impls/plex/plexrefine.c
[0]PETSC ERROR: #3 DMRefine() line 1881 in /home/daniel/petsc/src/dm/interface/dm
I suspect you need to configure with --download-triangle? When you mark cells for refinement like this, petsc uses and external package to do the adaptation.
I'm not sure what options are available as packages, but triangle I think is one.
Cheers,
Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190802/b58e64ed/attachment-0001.html>
