[petsc-users] Error with KSPSetUp and MatNest
Matthew Knepley
knepley at gmail.com
Thu Apr 11 09:00:23 CDT 2019
On Thu, Apr 11, 2019 at 9:58 AM Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Just like Manuel Colera Rico, I would like to begin with existing
> (sub)matrices and put them directly into a matnest.
> You seem to have understood that problem from the archive 2.5
> years ago... If my memory is correct, it was an attempt to
> create a mat and switch between -mat_type nest and aij on the
> command line.
> Okay, I will make an example once I get back from my trip and fix anything
that does not work.
Matt
> Chris
> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl | www.marin.nl
> [image: LinkedIn] <https://www.linkedin.com/company/marin> [image:
> YouTube] <http://www.youtube.com/marinmultimedia> [image: Twitter]
> <https://twitter.com/MARIN_nieuws> [image: Facebook]
> <https://www.facebook.com/marin.wageningen>
> MARIN news: First autonomous manoeuvring vessel trials held on North Sea
> <http://www.marin.nl/web/News/News-items/First-autonomous-manoeuvring-vessel-trials-held-on-North-Sea.htm>
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Thursday, April 11, 2019 2:16 PM
> *To:* Klaij, Christiaan
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Error with KSPSetUp and MatNest
> On Thu, Apr 11, 2019 at 7:51 AM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Matt,
>> As a happy MATNEST user, I got a bit worried when you wrote "we
>> should remove MatCreateNest() completely".
> This would not remove any of the Nest functionality, just the direct
> interface to it, which is the problem.
>> This happened last
>> time I tried to use AIJ instead:
>> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2016-August/029973.html
>> Has this problem been fixed in the meantime?
> This looks like a problem with the Nest implementation, not AIJ? Maybe I
> am misunderstanding it.
> Thanks,
> Matt
>> Chris
>> > I think we should remove MatCreateNest() completely. We should have 1
>> > mechanism for getting submatrices for creation, not 2, so we retain
>> > MatCreateLocalRef(). Then if -mat_type nest was specified, it gives you
>> > back an actually submatrix, otherwise it gives a view. This would do
>> > everything that we currently do without this horrible MatNest interface
>> > bubbling to the top.
>> > Matt
>> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
>> http://www.marin.nl
>> MARIN news:
>> http://www.marin.nl/web/News/News-items/42nd-FPSO-JIP-Week-April-812-Singapore.htm
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> *Help us improve the spam filter. If this message contains SPAM, click
> here
> <https://www.mailcontrol.com/sr/VaxGuPX0yKPGX2PQPOmvUqEZpHzWxmiI7TcWSqBM5JDxEDemOSATW7gNYv05LkIR8iuercSaQ0xkxH4nYzTQYQ==>
> to report. Thank you, MARIN Support Group*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/b473f4ae/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/b473f4ae/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/b473f4ae/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/b473f4ae/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/b473f4ae/attachment-0007.png>
