[petsc-users] Argument out of range error only in certain mpi sizes
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Wed Apr 10 12:58:39 CDT 2019
Hi PETSc developers,
I wanted to convert my code that in which I was using general Vec/Mat to
DMDA based grid management (nothing fancy just a 5-point complex stencil).
For this, I created a DA object and created the global solution vector
using this. This worked fine.
Now, I created the matrix using DMCreateMatrix and fill it using the
regular function. I get no error when I run the problem using mpirun -np 1
and I thought my matrix filling logic aligns with the DM non-zero locations
(Star Stencil, width 1). With mpirun -np 2, no errors either. But with
mpirun -np 4 or 8, I get errors which say : "Argument out of range/
Inserting a new nonzero at global row/column ... into matrix".
I would switch over the logic provided in KSP/ex46.c for filling the Matrix
via the MatSetStencil logic but I wanted to know what I was doing wrong in
my current code since I've never seen an error that depends on number of
mpi processes.
I'm attaching the code ( which works if the matrix is created without using
the DA, i.e. comment out line 159, uncomment 161/162 and I'm doing this on
a small grid to catch errors.).
Thanks in advance for the help.
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190410/16651565/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190410/16651565/attachment.obj>
