[petsc-users] Error with KSPSetUp and MatNest
Thu Apr 11 07:16:57 CDT 2019
On Thu, Apr 11, 2019 at 7:51 AM Klaij, Christiaan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Matt,
> As a happy MATNEST user, I got a bit worried when you wrote "we
> should remove MatCreateNest() completely".
This would not remove any of the Nest functionality, just the direct
interface to it, which is the problem.
> This happened last
> time I tried to use AIJ instead:
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2016-August/029973.html
> Has this problem been fixed in the meantime?
This looks like a problem with the Nest implementation, not AIJ? Maybe I am
misunderstanding it.
     Matt
> Chris
> > I think we should remove MatCreateNest() completely. We should have 1
> > mechanism for getting submatrices for creation, not 2, so we retain
> > MatCreateLocalRef(). Then if -mat_type nest was specified, it gives you
> > back an actually submatrix, otherwise it gives a view. This would do
> > everything that we currently do without this horrible MatNest interface
> > bubbling to the top.
> >    Matt
> dr. ir. Christiaan Klaij  | Senior Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
> MARIN news:
> http://www.marin.nl/web/News/News-items/42nd-FPSO-JIP-Week-April-812-Singapore.htm
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/8d989374/attachment-0001.html>
