[petsc-users] Error with KSPSetUp and MatNest
Wed Apr 10 10:41:12 CDT 2019
On Wed, Apr 10, 2019 at 11:29 AM Manuel Colera Rico via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to solve a system whose matrix is of type MatNest. If I
> don't use KSPSetUp(), everything is fine. However, if I use that
> routine, I get the following error:
> 0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Nest vector arguments 1 and 2 have different numbers of
> blocks.
This seems self-explanatory. Nest vectors must have the same number of
blocks to be compatible.
More broadly, there should be no reason to use Nest vectors or matrices. It
is an optimization to
be used at the very end, only after you have profiled the code and seen
that its important. You can
do everything you want to do without ever touching Nest, and it looks like
the Nest interface is a
problem for your code right now.
    Matt
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.11.0, unknown
> [0]PETSC ERROR:
> /home/manu/Documents/FEM-fluids/C-codes/CLG2-ConvectionDiffusion/Debug/CLG2-ConvectionDiffusion
> on a mcr_20190405 named mancolric by Unknown Wed Apr 10 17:20:16 2019
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran COPTFLAGS="-O3 -march=native -mtune=native"
> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
> -march=native -mtune=native" --with-debugging=0 --download-fblaslapack
> --download--f2cblaslapack --download-mpich --download--hypre
> --download-scalapack --download-mumps --download-suitesparse
> --download-ptscotch --download-pastix --with-matlab --with-openmp
> [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
> /opt/PETSc_library/petsc-3.11.0/src/vec/vec/impls/nest/vecnest.c
> [0]PETSC ERROR: #2 VecCopy() line 1614 in
> /opt/PETSc_library/petsc-3.11.0/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #3 KSPInitialResidual() line 63 in
> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #5 KSPSolve() line 782 in
> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #6 mwe() line 55 in ../Tests/tests.c
> Please find attached a MWE (it is a slight modification of that of the
> post opened by Ce Qin,
> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024230.html,
> whose answer I have not found).
> By the way, with the newest version of PETSc, Eclipse marks as errors
> the commands PetscFree, CHKERRQ, PETSC_COMM_SELF,... although it
> compiles and executes well. Perhaps it is a problem related to Eclipse,
> but this did not happen with the older versions of PETSc.
> Thanks and regards,
> Manuel
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190410/209cee38/attachment-0001.html>
