[petsc-users] Error with KSPSetUp and MatNest
Manuel Colera Rico m.colera at upm.es
Wed Apr 10 11:49:22 CDT 2019
Thank you for your answer, Matt. In the MWE example attached before,
both Nest vectors (the r.h.s. of the system and the vector of unknowns)
are composed of the same number of blocks (2). Indeed, PETSc is able to
solve the system if KSPSetUp() is not called, so the
system/MatNest/MatVec's must not incompatible at all. Therefore, I
wonder if I have missed to called something before this routine or if
this is a KSPSetUp's bug.
Of course one can always directly define a single matrix and a single
vector, but I find it easier to work with Nest matrices and vectors.
Moreover, I think that the moment to use them is from the beginning...
once all the code is developed, it is very hard to switch matrices types.
Manuel
On 4/10/19 5:41 PM, Matthew Knepley wrote:
> On Wed, Apr 10, 2019 at 11:29 AM Manuel Colera Rico via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>     Hello,
>     I am trying to solve a system whose matrix is of type MatNest. If I
>     don't use KSPSetUp(), everything is fine. However, if I use that
>     routine, I get the following error:
>     0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Invalid argument
>     [0]PETSC ERROR: Nest vector arguments 1 and 2 have different
>     numbers of
>     blocks.
> This seems self-explanatory. Nest vectors must have the same number of
> blocks to be compatible.
> More broadly, there should be no reason to use Nest vectors or
> matrices. It is an optimization to
> be used at the very end, only after you have profiled the code and
> seen that its important. You can
> do everything you want to do without ever touching Nest, and it looks
> like the Nest interface is a
> problem for your code right now.
>   Thanks,
>     Matt
>     [0]PETSC ERROR: See
>     http://www.mcs.anl.gov/petsc/documentation/faq.html
>     for trouble shooting.
>     [0]PETSC ERROR: Petsc Release Version 3.11.0, unknown
>     [0]PETSC ERROR:
>     /home/manu/Documents/FEM-fluids/C-codes/CLG2-ConvectionDiffusion/Debug/CLG2-ConvectionDiffusion
>     on a mcr_20190405 named mancolric by Unknown Wed Apr 10 17:20:16 2019
>     [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>     --with-fc=gfortran COPTFLAGS="-O3 -march=native -mtune=native"
>     CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
>     -march=native -mtune=native" --with-debugging=0
>     --download-fblaslapack
>     --download--f2cblaslapack --download-mpich --download--hypre
>     --download-scalapack --download-mumps --download-suitesparse
>     --download-ptscotch --download-pastix --with-matlab --with-openmp
>     [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
>     /opt/PETSc_library/petsc-3.11.0/src/vec/vec/impls/nest/vecnest.c
>     [0]PETSC ERROR: #2 VecCopy() line 1614 in
>     /opt/PETSc_library/petsc-3.11.0/src/vec/vec/interface/vector.c
>     [0]PETSC ERROR: #3 KSPInitialResidual() line 63 in
>     /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itres.c
>     [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
>     /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/impls/gmres/gmres.c
>     [0]PETSC ERROR: #5 KSPSolve() line 782 in
>     /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itfunc.c
>     [0]PETSC ERROR: #6 mwe() line 55 in ../Tests/tests.c
>     Please find attached a MWE (it is a slight modification of that of
>     the
>     post opened by Ce Qin,
>     https://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024230.html,
>     whose answer I have not found).
>     By the way, with the newest version of PETSc, Eclipse marks as errors
>     the commands PetscFree, CHKERRQ, PETSC_COMM_SELF,... although it
>     compiles and executes well. Perhaps it is a problem related to
>     Eclipse,
>     but this did not happen with the older versions of PETSc.
>     Thanks and regards,
>     Manuel
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190410/2391cd43/attachment.html>
