[petsc-users] Error with KSPSetUp and MatNest
Manuel Colera Rico m.colera at upm.es
Wed Apr 10 10:29:37 CDT 2019
Hello,
I am trying to solve a system whose matrix is of type MatNest. If I
don't use KSPSetUp(), everything is fine. However, if I use that
routine, I get the following error:
0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Nest vector arguments 1 and 2 have different numbers of
blocks.
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.11.0, unknown
[0]PETSC ERROR:
/home/manu/Documents/FEM-fluids/C-codes/CLG2-ConvectionDiffusion/Debug/CLG2-ConvectionDiffusion
on a mcr_20190405 named mancolric by Unknown Wed Apr 10 17:20:16 2019
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran COPTFLAGS="-O3 -march=native -mtune=native"
CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
-march=native -mtune=native" --with-debugging=0 --download-fblaslapack
--download--f2cblaslapack --download-mpich --download--hypre
--download-scalapack --download-mumps --download-suitesparse
--download-ptscotch --download-pastix --with-matlab --with-openmp
[0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
/opt/PETSc_library/petsc-3.11.0/src/vec/vec/impls/nest/vecnest.c
[0]PETSC ERROR: #2 VecCopy() line 1614 in
/opt/PETSc_library/petsc-3.11.0/src/vec/vec/interface/vector.c
[0]PETSC ERROR: #3 KSPInitialResidual() line 63 in
/opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itres.c
[0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
/opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: #5 KSPSolve() line 782 in
/opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #6 mwe() line 55 in ../Tests/tests.c
Please find attached a MWE (it is a slight modification of that of the
post opened by Ce Qin,
https://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024230.html,
whose answer I have not found).
By the way, with the newest version of PETSc, Eclipse marks as errors
the commands PetscFree, CHKERRQ, PETSC_COMM_SELF,... although it
compiles and executes well. Perhaps it is a problem related to Eclipse,
but this did not happen with the older versions of PETSc.
Thanks and regards,
Manuel
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190410/94502cd5/attachment.bin>
