[petsc-users] PCMG Solver Issue
Smith, Barry F. bsmith at mcs.anl.gov
Thu Apr 4 16:51:59 CDT 2019
   Jacob,
       The two errors are related. PCMG uses KSPCreateVecs() on each level to create work vectors and KSPCreateVecs() uses the attached matrix to create the work vectors (via MatCreateVecs()). Since the Mat on the intermediate levels has not been created yet the error is generated while attempting to create the vectors. It you were able to set the PCMGSetGalerkin() option then the intermediate matrices would exist and the code would not fail at creating work vectors.
    I git grep the petsc4py code and it looks like inadvertently PCMGSetGalerkin() is missing. Someone who knows petsc4py will have to add that interface.
    For now you can try setting the option -pc_mg_galerkin both before calling KSPSetFromOptions.
   Barry
> On Apr 4, 2019, at 3:43 PM, Jacob Oest via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear all,
> I am using petsc4py and can't seem to figure out an issue.
> I need to solve the linear system KU = P, and K and U are correctly set up, and using default ksp solvers i can easily solve the system. However, I am trying to solve with pcmg and have two issues:
> a) I get 'PETSC Error code 73 - object is in wrong state' when i try to solve or setup the ksp.
> b) What is the petsc4py equivalent to PCMGSetGalerkin? Can't seem to figure it out.
> Below is how I set up the solver, next is the error message, and lastly is the result from KSPView()
> Thanks in advance for any help you can provide!
> THE CODE:
>         RTOL = 1.0e-5
>         ATOL = 1.0e-50
>         DTOL = 1.0e3
>         MAXITSGLOBAL = 200
>         COARSE_RTOL = 1.0e-8
>         COARSE_ATOL = 1.0e-50
>         COARSE_DTOL = 1e3
>         COARSE_MAXITS = 30
>         COARSE_RESTART = 30
>         SMOOTH_SWEEPS = 4
>         # Fine grid Krylov Method
>         self.ksp = petsc.KSP().create()
>         self.ksp.setType('fgmres')
>         self.ksp.setTolerances(rtol=RTOL, atol=ATOL, divtol=DTOL, max_it=MAXITSGLOBAL)
>         self.ksp.setInitialGuessNonzero(True)
>         # Set operators
>         self.ksp.setOperators(mesh.K, mesh.K)
>         # Get Preconditioner and set it up
>         pc = self.ksp.getPC()
>         pc.setType('mg')
>         self.ksp.setFromOptions()
>         # Set all levels in the PCMG (zeroth entry is finest level):
>         da_list = list()
>         da_list.append(mesh.da_nodes)
>         da_list.extend([da_obj for da_obj in mesh.da_nodes.coarsenHierarchy(3)])
>         # PCMG specific options
>         pc.setMGLevels(mesh.mg_levels)
>         pc.setMGType(0)  # multiplicative
>         pc.setMGCycleType(1)  # v
>         for k in range(1, mesh.mg_levels):
>             r, _ = da_list[k].createInterpolation(da_list[k-1])
>             pc.setMGInterpolation(k, r)
>         # Avoid the default for the mg part
>         cksp = pc.getMGCoarseSolve()
>         cksp.setType('gmres')
>         cksp.setGMRESRestart(COARSE_RESTART)
>         cksp.setTolerances(rtol=COARSE_RTOL, atol=COARSE_ATOL, divtol=COARSE_DTOL, max_it=COARSE_MAXITS)
>         cpc = cksp.getPC()
>         cpc.setType('sor')
>         # Set smoothers on all levels
>             dksp = pc.getMGSmoother(k)
>             dpc = dksp.getPC()
>             dksp.setType('gmres')
>             dksp.setGMRESRestart(SMOOTH_SWEEPS)
>             dksp.setTolerances(max_it=SMOOTH_SWEEPS)
>             dpc.setType('sor')
> The Error:
> petsc4py.PETSc.Error: error code 73
> [0] KSPSolve() line 725 in /tmp/pip-req-build-goqa79r0/src/ksp/ksp/interface/itfunc.c
> [0] KSPSetUp() line 391 in /tmp/pip-req-build-goqa79r0/src/ksp/ksp/interface/itfunc.c
> [0] PCSetUp() line 932 in /tmp/pip-req-build-goqa79r0/src/ksp/pc/interface/precon.c
> [0] PCSetUp_MG() line 819 in /tmp/pip-req-build-goqa79r0/src/ksp/pc/impls/mg/mg.c
> [0] KSPCreateVecs() line 947 in /tmp/pip-req-build-goqa79r0/src/ksp/ksp/interface/iterativ.c
> [0] Object is in wrong state
> [0] You requested a vector from a KSP that cannot provide one
> The KSPView():
> KSP Object: 1 MPI processes
>   type: fgmres
>     restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=200, nonzero initial guess
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=1000.
>   left preconditioning
>   using DEFAULT norm type for convergence test
> PC Object: 1 MPI processes
>   type: mg
>   PC has not been set up so information may be incomplete
>     type is MULTIPLICATIVE, levels=4 cycles=v
>       Cycles per PCApply=1
>       Not using Galerkin computed coarse grid matrices
>   Coarse grid solver -- level -------------------------------
>     KSP Object: (mg_coarse_) 1 MPI processes
>       type: gmres
>       maximum iterations=30, initial guess is zero
>       tolerances:  relative=1e-08, absolute=1e-50, divergence=1000.
>     PC Object: (mg_coarse_) 1 MPI processes
>       type: sor
>         type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object: (mg_levels_1_) 1 MPI processes
>       type: gmres
>         restart=4, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>       maximum iterations=4, initial guess is zero
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>       using NONE norm type for convergence test
>     PC Object: (mg_levels_1_) 1 MPI processes
>       type: sor
>   Up solver (post-smoother) same as down solver (pre-smoother)
>   Down solver (pre-smoother) on level 2 -------------------------------
>     KSP Object: (mg_levels_2_) 1 MPI processes
>       type: gmres
>     PC Object: (mg_levels_2_) 1 MPI processes
>       type: sor
>   Down solver (pre-smoother) on level 3 -------------------------------
>     KSP Object: (mg_levels_3_) 1 MPI processes
>       type: gmres
>     PC Object: (mg_levels_3_) 1 MPI processes
>       type: sor
>   linear system matrix = precond matrix:
>   Mat Object: 1 MPI processes
>     type: seqaij
>     rows=4131, cols=4131, bs=3
>     total: nonzeros=275625, allocated nonzeros=275625
>     total number of mallocs used during MatSetValues calls =0
>       using I-node routines: found 1377 nodes, limit used is 5
