[petsc-users] error: Petsc has generated inconsistent data, MPI_Allreduce() called in different locations (code lines) on different processors
Eda Oktay eda.oktay at metu.edu.tr
Fri Apr 5 02:20:15 CDT 2019
Hello,
I am trying to calculate unweighted Laplacian of a matrix by using 2 cores.
If the size of matrix is in even number then my program works. However,
when I try to use a matrix having odd number for size, I guess since size
of the matrix cannot be divided into processors correctly, I get the
following error:
[0]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Petsc has generated inconsistent data
[1]PETSC ERROR: MPI_Allreduce() called in different locations (code lines)
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: MPI_Allreduce() called in different locations (code lines)
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
[0]PETSC ERROR: ./SON_YENI_DENEME_TEMIZ_ENYENI_FINAL on a
arch-linux2-c-debug named dfa.wls.metu.edu.tr by edaoktay Fri Apr  5
09:50:54 2019
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
--download-metis --download-parmetis --download-superlu_dist
--download-slepc --download-mpich
[1]PETSC ERROR: ./SON_YENI_DENEME_TEMIZ_ENYENI_FINAL on a
09:50:54 2019
[1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
[1]PETSC ERROR: [0]PETSC ERROR: #1 MatSetOption() line 5505 in
/home/edaoktay/petsc-3.10.3/src/mat/interface/matrix.c
#1 MatStashScatterBegin_BTS() line 843 in
/home/edaoktay/petsc-3.10.3/src/mat/utils/matstash.c
[1]PETSC ERROR: [0]PETSC ERROR: #2 MatSetOption() line 5505 in
#2 MatStashScatterBegin_BTS() line 843 in
[1]PETSC ERROR: #3 MatStashScatterBegin_Private() line 462 in
[0]PETSC ERROR: #3 main() line 164 in
/home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/SON_YENI_DENEME_TEMIZ_ENYENI_FINAL.c
[1]PETSC ERROR: #4 MatAssemblyBegin_MPIAIJ() line 774 in
/home/edaoktay/petsc-3.10.3/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: [0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -f
/home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/binary_files/airfoil1_binary
#5 MatAssemblyBegin() line 5251 in
[1]PETSC ERROR: [0]PETSC ERROR: -mat_partitioning_type parmetis
[0]PETSC ERROR: -unweighted
#6 main() line 169 in
[1]PETSC ERROR: PETSc Option Table entries:
[1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message
-------send entire error message to petsc-maint at mcs.anl.gov----------
-f
[1]PETSC ERROR: -mat_partitioning_type parmetis
[1]PETSC ERROR: -unweighted
[1]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
----------------End of Error Message -------send entire error message to
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
 where line 164 in my main program is MatSetOption and line 169
is MatAssemblyBegin. I am new to MPI usage so I did not understand why
MPI_Allreduce() causes a problem and how can I fix the problem.
Thank you,
Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190405/375f5012/attachment.html>
