[petsc-users] PCMG Solver Issue
Jacob Oest jacoboest87 at gmail.com
Thu Apr 4 15:43:12 CDT 2019
Dear all,
I am using petsc4py and can't seem to figure out an issue.
I need to solve the linear system KU = P, and K and U are correctly set up,
and using default ksp solvers i can easily solve the system. However, I am
trying to solve with pcmg and have two issues:
a) I get 'PETSC Error code 73 - object is in wrong state' when i try to
solve or setup the ksp.
b) What is the petsc4py equivalent to PCMGSetGalerkin? Can't seem to figure
it out.
Below is how I set up the solver, next is the error message, and lastly is
the result from KSPView()
Thanks in advance for any help you can provide!
*THE CODE:*
        RTOL = 1.0e-5
        ATOL = 1.0e-50
        DTOL = 1.0e3
        MAXITSGLOBAL = 200
        COARSE_RTOL = 1.0e-8
        COARSE_ATOL = 1.0e-50
        COARSE_DTOL = 1e3
        COARSE_MAXITS = 30
        COARSE_RESTART = 30
        SMOOTH_SWEEPS = 4
        # Fine grid Krylov Method
        self.ksp = petsc.KSP().create()
        self.ksp.setType('fgmres')
        self.ksp.setTolerances(rtol=RTOL, atol=ATOL, divtol=DTOL,
max_it=MAXITSGLOBAL)
        self.ksp.setInitialGuessNonzero(True)
        # Set operators
        self.ksp.setOperators(mesh.K, mesh.K)
        # Get Preconditioner and set it up
        pc = self.ksp.getPC()
        pc.setType('mg')
        self.ksp.setFromOptions()
        # Set all levels in the PCMG (zeroth entry is finest level):
        da_list = list()
        da_list.append(mesh.da_nodes)
        da_list.extend([da_obj for da_obj in
mesh.da_nodes.coarsenHierarchy(3)])
        # PCMG specific options
        pc.setMGLevels(mesh.mg_levels)
        pc.setMGType(0)  # multiplicative
        pc.setMGCycleType(1)  # v
        for k in range(1, mesh.mg_levels):
            r, _ = da_list[k].createInterpolation(da_list[k-1])
            pc.setMGInterpolation(k, r)
        # Avoid the default for the mg part
        cksp = pc.getMGCoarseSolve()
        cksp.setType('gmres')
        cksp.setGMRESRestart(COARSE_RESTART)
        cksp.setTolerances(rtol=COARSE_RTOL, atol=COARSE_ATOL,
divtol=COARSE_DTOL, max_it=COARSE_MAXITS)
        cpc = cksp.getPC()
        cpc.setType('sor')
        # Set smoothers on all levels
            dksp = pc.getMGSmoother(k)
            dpc = dksp.getPC()
            dksp.setType('gmres')
            dksp.setGMRESRestart(SMOOTH_SWEEPS)
            dksp.setTolerances(max_it=SMOOTH_SWEEPS)
            dpc.setType('sor')
*The Error:*
petsc4py.PETSc.Error: error code 73
[0] KSPSolve() line 725 in
/tmp/pip-req-build-goqa79r0/src/ksp/ksp/interface/itfunc.c
[0] KSPSetUp() line 391 in
[0] PCSetUp() line 932 in
/tmp/pip-req-build-goqa79r0/src/ksp/pc/interface/precon.c
[0] PCSetUp_MG() line 819 in
/tmp/pip-req-build-goqa79r0/src/ksp/pc/impls/mg/mg.c
[0] KSPCreateVecs() line 947 in
/tmp/pip-req-build-goqa79r0/src/ksp/ksp/interface/iterativ.c
[0] Object is in wrong state
[0] You requested a vector from a KSP that cannot provide one
*The KSPView():*
KSP Object: 1 MPI processes
  type: fgmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=200, nonzero initial guess
  tolerances:  relative=1e-05, absolute=1e-50, divergence=1000.
  left preconditioning
  using DEFAULT norm type for convergence test
PC Object: 1 MPI processes
  type: mg
  PC has not been set up so information may be incomplete
    type is MULTIPLICATIVE, levels=4 cycles=v
      Cycles per PCApply=1
      Not using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object: (mg_coarse_) 1 MPI processes
      type: gmres
Orthogonalization with no iterative refinement
      maximum iterations=30, initial guess is zero
      tolerances:  relative=1e-08, absolute=1e-50, divergence=1000.
    PC Object: (mg_coarse_) 1 MPI processes
      type: sor
        type = local_symmetric, iterations = 1, local iterations = 1, omega
= 1.
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object: (mg_levels_1_) 1 MPI processes
      type: gmres
        restart=4, using Classical (unmodified) Gram-Schmidt
      maximum iterations=4, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      using NONE norm type for convergence test
    PC Object: (mg_levels_1_) 1 MPI processes
      type: sor
= 1.
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object: (mg_levels_2_) 1 MPI processes
      type: gmres
    PC Object: (mg_levels_2_) 1 MPI processes
      type: sor
= 1.
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object: (mg_levels_3_) 1 MPI processes
      type: gmres
    PC Object: (mg_levels_3_) 1 MPI processes
      type: sor
= 1.
  linear system matrix = precond matrix:
  Mat Object: 1 MPI processes
    type: seqaij
    rows=4131, cols=4131, bs=3
    total: nonzeros=275625, allocated nonzeros=275625
    total number of mallocs used during MatSetValues calls =0
      using I-node routines: found 1377 nodes, limit used is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190404/86a74ed0/attachment.html>
