[petsc-users] Usage of AMG as preconditioner
    Jed Brown
    jed at jedbrown.org
    Fri Sep 28 11:42:34 CDT 2018
Michael Werner <michael.werner at dlr.de> writes:
> A low-Mach preconditioner might help with the current test cases,
> however I also intend to apply this code to high-Mach number
> flows, so I need to find a more general solution. Actually, the
> high-Mach number applications are more important, since so far all
> the low-Mach cases are small enough to be solved with direct
> solvers.
> I was also thinking about using a geometric multigrid approach via
> DMPlex. As far as I understood, hyperbolic problems are difficult
> to solve with AMG because the solver isn't aware of the underlying
> structure of the problem. Therefore I would think that a geometric
> multigrid approach should produce better results, right? Do you
> think it would be worthwile to implement a DMPlex, or would I
> still run into the same problems?
Agglomeration-based geometric multigrid with block relaxation is a
common technique for unstructured compressible CFD, but there are a lot
of subtleties.  See FUN3D papers (Diskin, Thomas, sometimes Brandt) for
examples of this approach.
