[petsc-users] Usage of AMG as preconditioner
    Michael Werner
    michael.werner at dlr.de
    Fri Sep 28 11:05:27 CDT 2018
Jed Brown writes:
> Michael Werner <michael.werner at dlr.de> writes:
>>>> >> > It uses unpreconditioned GMRES to estimate spectral
>>>> >> > bounds for
>>>> >> > the operator before using a Chebychev smoother.
> It is GMRES preconditioned by the diagonal.
>>> Moreover, in the incompressible limit, the compressible
>>> formulation can
>>> become very stiff,
>>> leading to failure of solvers. That is why you get the
>>> slightly
>>> compressible (adiabatic?) formulations.
>> Ah, too bad, I was already expecting something like that,
>> because
>> most of the applications I found so far were FEM/ elasticity
>> problems. Then I'll have to see if I can find some other
>> suitable
>> solution.
> You can implement a low-Mach preconditioner that would use
> multigrid.
> If you're working in conservative variables, then it requires a
> nonlinear change of variables to isolate the pressure space.
A low-Mach preconditioner might help with the current test cases,
however I also intend to apply this code to high-Mach number
flows, so I need to find a more general solution. Actually, the
high-Mach number applications are more important, since so far all
the low-Mach cases are small enough to be solved with direct
solvers.
I was also thinking about using a geometric multigrid approach via
DMPlex. As far as I understood, hyperbolic problems are difficult
to solve with AMG because the solver isn't aware of the underlying
structure of the problem. Therefore I would think that a geometric
multigrid approach should produce better results, right? Do you
think it would be worthwile to implement a DMPlex, or would I
still run into the same problems?
Kind regards,
Michael
