[petsc-users] Usage of AMG as preconditioner
Mark Adams
mfadams at lbl.gov
Fri Sep 28 14:41:20 CDT 2018
As Jed says hyperbolic dominated systems are hard.
For geometric papers you can look at Jameson papers and Adams, Samtaney &
Brandt (MHD).
But be prepared to work. Good stuff but hard.
On Fri, Sep 28, 2018 at 12:42 PM Jed Brown <jed at jedbrown.org> wrote:
> Michael Werner <michael.werner at dlr.de> writes:
> > A low-Mach preconditioner might help with the current test cases,
> > however I also intend to apply this code to high-Mach number
> > flows, so I need to find a more general solution. Actually, the
> > high-Mach number applications are more important, since so far all
> > the low-Mach cases are small enough to be solved with direct
> > solvers.
> > I was also thinking about using a geometric multigrid approach via
> > DMPlex. As far as I understood, hyperbolic problems are difficult
> > to solve with AMG because the solver isn't aware of the underlying
> > structure of the problem. Therefore I would think that a geometric
> > multigrid approach should produce better results, right? Do you
> > think it would be worthwile to implement a DMPlex, or would I
> > still run into the same problems?
> Agglomeration-based geometric multigrid with block relaxation is a
> common technique for unstructured compressible CFD, but there are a lot
> of subtleties. See FUN3D papers (Diskin, Thomas, sometimes Brandt) for
> examples of this approach.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180928/af62dc4a/attachment.html>
