[petsc-users] Unable to read in values thru namelist in Fortran after using PETSc 64bit in linux
TAY wee-beng zonexo at gmail.com
Tue Sep 18 01:39:14 CDT 2018
In that case, does it apply to all MPI subroutines such as MPI_ALLGATHER?
In other words, must I assign local_array_length etc as PetscMPIInt?
call
MPI_ALLGATHER(local_array_length,1,MPIU_INTEGER,array_length,1,MPIU_INTEGER,MPI_COMM_WORLD,ierr)
Or is it ok to change all integers from PetscInt to PetscMPIInt?
With the exception of ierr - PetscErrorCode
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
On 18/9/2018 1:39 PM, Balay, Satish wrote:
> https://www.mpich.org/static/docs/v3.1/www3/MPI_Comm_size.html
> int MPI_Comm_size( MPI_Comm comm, int *size )
> i.e there is no PetscInt here. [MPI does not know about PETSc datatypes]
> For convinence we provide PetscMPIInt to keep track of such variables
> [similarly PetscBLASInt]. For eg: Check src/vec/vec/examples/tests/ex2f.F
> Satish
> On Tue, 18 Sep 2018, TAY wee-beng wrote:
>> Hi,
>> I managed to find the error appearing after using PETSc 64bit in linux -
>> call MPI_COMM_SIZE(MPI_COMM_WORLD, num_procs, ierr)
>> I have assigned num_procs as PetscInt and I got 0 instead of 1 (for 1 procs)
>> Assigning num_procs as integer as the problem.
>> Is this supposed to be the case? Or is it a bug?
>> Yours sincerely,
>> On 8/9/2018 1:14 AM, Smith, Barry F. wrote:
>>>         You can try valgrind
>>>         http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>     Barry
>>>> On Sep 7, 2018, at 1:44 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> I found that I am unable to read in values thru namelist in Fortran after
>>>> using PETSc 64bit in linux.
>>>> I have a parameter txt file which is read in using namelist in Fortran:
>>>> namelist /body_input/ no_body, convex_body, motion_type, hover, wing_config
>>>> open (unit = 44 , FILE = "ibm3d_input.txt" , status = "old", iostat =
>>>> openstatus(4))
>>>>           if (openstatus(4) > 0) then
>>>>               print *, "ibm3d_input file not present or wrong filename."
>>>>               stop
>>>>           end if
>>>>           read (44,nml = solver_input)
>>>>           read (44,nml = grid_input)
>>>>           read (44,nml = body_input)...
>>>> After using PETSc 64bit, my code aborts and I realise that it is because
>>>> the values have became NaN. Strangely, it does not occur in windows with
>>>> VS2008.
>>>> I wonder if it's a bug with the Intel Fortran compiler 2018.
>>>> Anyone has similar experience?
>>>> Yours sincerely,
