[petsc-users] Unable to read in values thru namelist in Fortran after using PETSc 64bit in linux
Matthew Knepley
knepley at gmail.com
Tue Sep 18 03:37:54 CDT 2018
On Tue, Sep 18, 2018 at 2:39 AM TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> In that case, does it apply to all MPI subroutines such as MPI_ALLGATHER?
> In other words, must I assign local_array_length etc as PetscMPIInt?
No. MPI _data_ arrays can be any type. Here you have specified MPIU_INTEGER,
which indicates PetscInt. If you had used MPI_INTEGER, then you would need a
PetscMPIInt.
Matt
> call
> MPI_ALLGATHER(local_array_length,1,MPIU_INTEGER,array_length,1,MPIU_INTEGER,MPI_COMM_WORLD,ierr)
> Or is it ok to change all integers from PetscInt to PetscMPIInt?
> With the exception of ierr - PetscErrorCode
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng (Zheng Weiming) 郑伟明
> Personal research webpage: http://tayweebeng.wixsite.com/website
> Youtube research showcase:
> https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
> linkedin: www.linkedin.com/in/tay-weebeng
> On 18/9/2018 1:39 PM, Balay, Satish wrote:
> > https://www.mpich.org/static/docs/v3.1/www3/MPI_Comm_size.html
> > int MPI_Comm_size( MPI_Comm comm, int *size )
> > i.e there is no PetscInt here. [MPI does not know about PETSc datatypes]
> > For convinence we provide PetscMPIInt to keep track of such variables
> > [similarly PetscBLASInt]. For eg: Check src/vec/vec/examples/tests/ex2f.F
> > Satish
> > On Tue, 18 Sep 2018, TAY wee-beng wrote:
> >> Hi,
> >> I managed to find the error appearing after using PETSc 64bit in linux -
> >> call MPI_COMM_SIZE(MPI_COMM_WORLD, num_procs, ierr)
> >> I have assigned num_procs as PetscInt and I got 0 instead of 1 (for 1
> procs)
> >> Assigning num_procs as integer as the problem.
> >> Is this supposed to be the case? Or is it a bug?
> >> Yours sincerely,
> >> On 8/9/2018 1:14 AM, Smith, Barry F. wrote:
> >>> You can try valgrind
> >>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> >>> Barry
> >>>> On Sep 7, 2018, at 1:44 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> >>>> Hi,
> >>>> I found that I am unable to read in values thru namelist in Fortran
> after
> >>>> using PETSc 64bit in linux.
> >>>> I have a parameter txt file which is read in using namelist in
> Fortran:
> >>>> namelist /body_input/ no_body, convex_body, motion_type, hover,
> wing_config
> >>>> open (unit = 44 , FILE = "ibm3d_input.txt" , status = "old", iostat =
> >>>> openstatus(4))
> >>>> if (openstatus(4) > 0) then
> >>>> print *, "ibm3d_input file not present or wrong
> filename."
> >>>> stop
> >>>> end if
> >>>> read (44,nml = solver_input)
> >>>> read (44,nml = grid_input)
> >>>> read (44,nml = body_input)...
> >>>> After using PETSc 64bit, my code aborts and I realise that it is
> because
> >>>> the values have became NaN. Strangely, it does not occur in windows
> with
> >>>> VS2008.
> >>>> I wonder if it's a bug with the Intel Fortran compiler 2018.
> >>>> Anyone has similar experience?
> >>>> Yours sincerely,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180918/6e3989a0/attachment.html>
