[petsc-users] Unable to read in values thru namelist in Fortran after using PETSc 64bit in linux
    Balay, Satish
    balay at mcs.anl.gov
    Tue Sep 18 00:39:40 CDT 2018
https://www.mpich.org/static/docs/v3.1/www3/MPI_Comm_size.html
int MPI_Comm_size( MPI_Comm comm, int *size )
i.e there is no PetscInt here. [MPI does not know about PETSc datatypes]
For convinence we provide PetscMPIInt to keep track of such variables
[similarly PetscBLASInt]. For eg: Check src/vec/vec/examples/tests/ex2f.F
Satish
On Tue, 18 Sep 2018, TAY wee-beng wrote:
> Hi,
> I managed to find the error appearing after using PETSc 64bit in linux -
> call MPI_COMM_SIZE(MPI_COMM_WORLD, num_procs, ierr)
> I have assigned num_procs as PetscInt and I got 0 instead of 1 (for 1 procs)
> Assigning num_procs as integer as the problem.
> Is this supposed to be the case? Or is it a bug?
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng (Zheng Weiming) 郑伟明
> Personal research webpage: http://tayweebeng.wixsite.com/website
> Youtube research showcase:
> https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
> linkedin: www.linkedin.com/in/tay-weebeng
> On 8/9/2018 1:14 AM, Smith, Barry F. wrote:
> >        You can try valgrind
> >        http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> >    Barry
> >> On Sep 7, 2018, at 1:44 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> >> Hi,
> >> I found that I am unable to read in values thru namelist in Fortran after
> >> using PETSc 64bit in linux.
> >> I have a parameter txt file which is read in using namelist in Fortran:
> >> namelist /body_input/ no_body, convex_body, motion_type, hover, wing_config
> >> open (unit = 44 , FILE = "ibm3d_input.txt" , status = "old", iostat =
> >> openstatus(4))
> >>          if (openstatus(4) > 0) then
> >>              print *, "ibm3d_input file not present or wrong filename."
> >>              stop
> >>          end if
> >>          read (44,nml = solver_input)
> >>          read (44,nml = grid_input)
> >>          read (44,nml = body_input)...
> >> After using PETSc 64bit, my code aborts and I realise that it is because
> >> the values have became NaN. Strangely, it does not occur in windows with
> >> VS2008.
> >> I wonder if it's a bug with the Intel Fortran compiler 2018.
> >> Anyone has similar experience?
> >> Yours sincerely,
