[petsc-users] Approximation of matrix vector product by finite difference method
Matthew Knepley
knepley at gmail.com
Fri Sep 7 08:16:45 CDT 2018
On Fri, Sep 7, 2018 at 6:39 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
> Thank you very much for your reply.
> I'm a bit confused if I use what you recommend: - snes_fd -pc_type lu
> means that I explicitly construct the Jacobian matrix using the finite
> difference method, construct the precondition matrix using the completely
> LU decomposition, and solve the step size \ delta x with the GMRES method
> (default).
You should do this first in order to check that your code reproduces the
right physics.
Then you should do -snes_fd_color -snes_fd_color_use_mat -mat_coloring_type
greedy for larger problems.
Finally, if you want to go even larger, then you use -snes_mf and a user
preconditioner. However, there is not
much benefit of MF with a low order method because you will have to form
some preconditioner.
Matt
> In fact, what I want to use is to approximate the vector product of a
> matrix with finite difference, so that the explicit construction of
> Jacobian matrices can be avoided. If so, should I use MatrixFreeMethod? How
> should I set it up? If I want to set up precondition, what do I need to
> add?
> In addition, I want to output variables in each nolinear step. What should
> I add code to make SNES step by step?
> There may be many problems, but they bother me very much. I am looking
> forward to your reply.
> Thanks,
> Yingjie
> Matthew Knepley <knepley at gmail.com> 于2018年9月6日周四 下午10:34写道:
>> On Thu, Sep 6, 2018 at 4:47 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
>>> Dear Petsc developer:
>>> Hi,
>>> Thank you for your previous help.
>>> I recently modeled on PETSc's SNES example and wrote a computer program
>>> myself. This program is mainly for solving nonlinear equations of thermal
>>> hydraulics.
>>> ∇·(λ∇T) - ∇_y(ρ*Cp*u) - T_source = 0
>>> w*ρ*u = ρg - ∇_y(P)
>>> ∇·( 1/w * ∇P ) = - ∇( ρg / w )
>>> Where P, T and u are variables, the distribution represents pressure,
>>> temperature and velocity. The rest are nonlinear physical parameters and
>>> constants.
>>> Because the program is very preliminary, so I use - snes_mf so that I
>>> can save the part of writing to calculate the Jacobian matrix.
>>> After compiling and passing, I found that the residual function had not
>>> dropped to a small enough level, but the program stopped, as follows:
>>> Setting Up: -snes_mf -snes_monitor -draw_pause 10 -snes_view
>> First, do not use -snes_mf. It is not for testing, but for sophisticated
>> use. The first option you
>> might try is
>> -snes_fd -pc_type lu
>> That uses a full Jacobian and LU factorization for a direct solve. Always
>> run the solve using
>> -snes_view -snes_converged_reason -snes_monitor -ksp_converged_reason
>> -ksp_monitor_true_residual
>> When that gets too expensive, you can try
>> -snes_fd_color -snes_fd_color_use_mat -mat_coloring_type greedy
>> but that requires you to preallocate the Jacobian matrix correctly.
>> Thanks,
>> Matt
>>> 0 SNES Function norm 3.724996516631e+09
>>> 1 SNES Function norm 2.194322909557e+09
>>> 2 SNES Function norm 1.352051559826e+09
>>> 3 SNES Function norm 1.522311916217e+08
>>> SNES Object: 1 MPI processes
>>> type: newtonls
>>> maximum iterations=50, maximum function evaluations=10000
>>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>> total number of linear solver iterations=1298
>>> total number of function evaluations=11679
>>> norm schedule ALWAYS
>>> SNESLineSearch Object: 1 MPI processes
>>> type: bt
>>> interpolation: cubic
>>> alpha=1.000000e-04
>>> maxstep=1.000000e+08, minlambda=1.000000e-12
>>> tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>>> lambda=1.000000e-08
>>> maximum iterations=40
>>> KSP Object: 1 MPI processes
>>> type: gmres
>>> restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>> happy breakdown tolerance 1e-30
>>> maximum iterations=10000, initial guess is zero
>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>> left preconditioning
>>> using PRECONDITIONED norm type for convergence test
>>> PC Object: 1 MPI processes
>>> type: none
>>> linear system matrix = precond matrix:
>>> Mat Object: 1 MPI processes
>>> type: mffd
>>> rows=300, cols=300
>>> Matrix-free approximation:
>>> err=1.49012e-08 (relative error in function evaluation)
>>> Using wp compute h routine
>>> Does not compute normU
>>> I would like to know why the residual function can not continue to
>>> decline, and why the program will stop before convergence.
>>> I do not know much about the convergence criteria and convergence rules
>>> of PETSc for solving nonlinear equations. I hope I can get your help.
>>> I'm looking forward to your reply~
>>> Thanks,
>>> Yingjie
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/a25d2cab/attachment-0001.html>
