[petsc-users] Approximation of matrix vector product by finite difference method
Yingjie Wu
yjwu16 at gmail.com
Fri Sep 7 05:39:26 CDT 2018
Thank you very much for your reply.
I'm a bit confused if I use what you recommend: - snes_fd -pc_type lu
means that I explicitly construct the Jacobian matrix using the finite
difference method, construct the precondition matrix using the completely
LU decomposition, and solve the step size \ delta x with the GMRES method
(default).
In fact, what I want to use is to approximate the vector product of a
matrix with finite difference, so that the explicit construction of
Jacobian matrices can be avoided. If so, should I use MatrixFreeMethod? How
should I set it up? If I want to set up precondition, what do I need to
add?
In addition, I want to output variables in each nolinear step. What should
I add code to make SNES step by step?
There may be many problems, but they bother me very much. I am looking
forward to your reply.
Yingjie
Matthew Knepley <knepley at gmail.com> 于2018年9月6日周四 下午10:34写道:
> On Thu, Sep 6, 2018 at 4:47 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
>> Dear Petsc developer:
>> Hi,
>> Thank you for your previous help.
>> I recently modeled on PETSc's SNES example and wrote a computer program
>> myself. This program is mainly for solving nonlinear equations of thermal
>> hydraulics.
>> ∇·(λ∇T) - ∇_y(ρ*Cp*u) - T_source = 0
>> w*ρ*u = ρg - ∇_y(P)
>> ∇·( 1/w * ∇P ) = - ∇( ρg / w )
>> Where P, T and u are variables, the distribution represents pressure,
>> temperature and velocity. The rest are nonlinear physical parameters and
>> constants.
>> Because the program is very preliminary, so I use - snes_mf so that I can
>> save the part of writing to calculate the Jacobian matrix.
>> After compiling and passing, I found that the residual function had not
>> dropped to a small enough level, but the program stopped, as follows:
>> Setting Up: -snes_mf -snes_monitor -draw_pause 10 -snes_view
> First, do not use -snes_mf. It is not for testing, but for sophisticated
> use. The first option you
> might try is
> -snes_fd -pc_type lu
> That uses a full Jacobian and LU factorization for a direct solve. Always
> run the solve using
> -snes_view -snes_converged_reason -snes_monitor -ksp_converged_reason
> -ksp_monitor_true_residual
> When that gets too expensive, you can try
> -snes_fd_color -snes_fd_color_use_mat -mat_coloring_type greedy
> but that requires you to preallocate the Jacobian matrix correctly.
> Thanks,
> Matt
>> 0 SNES Function norm 3.724996516631e+09
>> 1 SNES Function norm 2.194322909557e+09
>> 2 SNES Function norm 1.352051559826e+09
>> 3 SNES Function norm 1.522311916217e+08
>> SNES Object: 1 MPI processes
>> type: newtonls
>> maximum iterations=50, maximum function evaluations=10000
>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>> total number of linear solver iterations=1298
>> total number of function evaluations=11679
>> norm schedule ALWAYS
>> SNESLineSearch Object: 1 MPI processes
>> type: bt
>> interpolation: cubic
>> alpha=1.000000e-04
>> maxstep=1.000000e+08, minlambda=1.000000e-12
>> tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>> lambda=1.000000e-08
>> maximum iterations=40
>> KSP Object: 1 MPI processes
>> type: gmres
>> restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> happy breakdown tolerance 1e-30
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>> type: none
>> linear system matrix = precond matrix:
>> Mat Object: 1 MPI processes
>> type: mffd
>> rows=300, cols=300
>> Matrix-free approximation:
>> err=1.49012e-08 (relative error in function evaluation)
>> Using wp compute h routine
>> Does not compute normU
>> I would like to know why the residual function can not continue to
>> decline, and why the program will stop before convergence.
>> I do not know much about the convergence criteria and convergence rules
>> of PETSc for solving nonlinear equations. I hope I can get your help.
>> I'm looking forward to your reply~
>> Thanks,
>> Yingjie
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/12657059/attachment-0001.html>
