[petsc-users] Approximation of matrix vector product by finite difference method
Smith, Barry F. bsmith at mcs.anl.gov
Fri Sep 7 12:25:25 CDT 2018
> On Sep 7, 2018, at 5:39 AM, Yingjie Wu <yjwu16 at gmail.com> wrote:
> Thank you very much for your reply.
> I'm a bit confused if I use what you recommend:  - snes_fd -pc_type lu means that I explicitly construct the Jacobian matrix using the finite difference method, construct the precondition matrix using the completely LU decomposition, and solve the step size \ delta x with the GMRES method (default).
> In fact, what I want to use is to approximate the vector product of a matrix with finite difference, so that the explicit construction of Jacobian matrices can be avoided. If so, should I use MatrixFreeMethod? How should I set it up? If I want to set up precondition, what do I need to add?
> In addition, I want to output variables in each nolinear step. What should I add code to make SNES step by step?
   SNESMonitorSet()
> There may be many problems, but they bother me very much. I am looking forward to your reply.
> Thanks,
> Yingjie
> Matthew Knepley <knepley at gmail.com> 于2018年9月6日周四 下午10:34写道:
> On Thu, Sep 6, 2018 at 4:47 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
> Dear Petsc developer:
> Hi,
> Thank you for your previous help.
> I recently modeled on PETSc's SNES example and wrote a computer program myself. This program is mainly for solving nonlinear equations of thermal hydraulics.
> ∇·(λ∇T) - ∇_y(ρ*Cp*u) - T_source = 0
> w*ρ*u = ρg - ∇_y(P)
>      ∇·( 1/w * ∇P ) =  - ∇( ρg / w )
> Where P, T and u are variables, the distribution represents pressure, temperature and velocity. The rest are nonlinear physical parameters and constants.
> Because the program is very preliminary, so I use - snes_mf so that I can save the part of writing to calculate the Jacobian matrix.
> After compiling and passing, I found that the residual function had not dropped to a small enough level, but the program stopped, as follows:
> Setting Up: -snes_mf  -snes_monitor  -draw_pause  10  -snes_view
> First, do not use -snes_mf. It is not for testing, but for sophisticated use. The first option you
> might try is
>    -snes_fd -pc_type lu
> That uses a full Jacobian and LU factorization for a direct solve. Always run the solve using
>   -snes_view -snes_converged_reason -snes_monitor -ksp_converged_reason -ksp_monitor_true_residual
> When that gets too expensive, you can try
>   -snes_fd_color -snes_fd_color_use_mat -mat_coloring_type greedy
> but that requires you to preallocate the Jacobian matrix correctly.
>   Thanks,
>     Matt
> 0 SNES Function norm 3.724996516631e+09
>   1 SNES Function norm 2.194322909557e+09
>   2 SNES Function norm 1.352051559826e+09
>   3 SNES Function norm 1.522311916217e+08
> SNES Object: 1 MPI processes
>   type: newtonls
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=1298
>   total number of function evaluations=11679
>   norm schedule ALWAYS
>   SNESLineSearch Object: 1 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
>     maximum iterations=40
>   KSP Object: 1 MPI processes
>     type: gmres
>       restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>       happy breakdown tolerance 1e-30
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>     left preconditioning
>     using PRECONDITIONED norm type for convergence test
>   PC Object: 1 MPI processes
>     type: none
>     linear system matrix = precond matrix:
>     Mat Object: 1 MPI processes
>       type: mffd
>       rows=300, cols=300
>         Matrix-free approximation:
>           err=1.49012e-08 (relative error in function evaluation)
>           Using wp compute h routine
>               Does not compute normU
> I would like to know why the residual function can not continue to decline, and why the program will stop before convergence.
> I do not know much about the convergence criteria and convergence rules of PETSc for solving nonlinear equations. I hope I can get your help.
> I'm looking forward to your reply~
> Thanks,
> Yingjie
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
