[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
avatar 648934229 at qq.com
Thu Oct 25 19:18:24 CDT 2018
Thank Satish. It worked as you said. But when I rebuild petsc using
./configure --with-matlab
It prompts
             Configuring PETSc to compile on your system
TESTING: configureLibrary from config.packages.Matlab(config/BuildSystem/config/packages/Matlab.py:35)         *******************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Could not find a functional Matlab
Run with --with-matlab-dir=Matlabrootdir if you know where it is
Then, I did the following. But it shows that "/Users/zhihui/Applications/MATLAB_R2018a.app/bin/matlab" nonexistent. However, it does exist as
Scott-Grad-MBP:bin zhihui$ pwd
Scott-Grad-MBP:bin zhihui$ ls
activate_matlab.sh	lcdata_utf8.xml		matlab-glselector.sh	mexsh
deactivate_matlab.sh	ldd			matopts.sh		optsetup.sh
engopts.sh		m3iregistry		mex			registry
lcdata.xml		maci64			mexext			util
lcdata.xsd		matlab			mexopts.sh
Do you know what it is going on here?
Scott-Grad-MBP:petsc-3.8.3 zhihui$ ./configure --with-matlab-dir=./../../../../Applications/MATLAB_R2018a/bin/matlab
                ERROR in COMMAND LINE ARGUMENT to ./configure
Nonexistent directory: /Users/zhihui/Applications/MATLAB_R2018a/bin/matlab for key with-matlab-dir
  File "./config/configure.py", line 390, in petsc_configure
    framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:], loadArgDB = 0)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 110, in __init__
    self.createChildren()
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 321, in createChildren
    self.getChild(moduleName)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 306, in getChild
    config.setupDependencies(self)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/Configure.py", line 107, in setupDependencies
    obj = self.registerPythonFile(package,'config.packages')
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/Configure.py", line 63, in registerPythonFile
    utilityObj                             = self.framework.require(directory+utilityName, self)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 326, in require
    config = self.getChild(moduleName, keywordArgs)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 304, in getChild
    config.setup()
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/script.py", line 101, in setup
    logger.Logger.setup(self)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/logger.py", line 85, in setup
    args.ArgumentProcessor.setup(self)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/args.py", line 75, in setup
    self.setupArguments(self.argDB)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/script.py", line 85, in setupArguments
    self.setupHelp(self.help)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/packages/Matlab.py", line 15, in setupHelp
    help.addArgument('MATLAB', '-with-matlab-dir=<root dir>', nargs.ArgDir(None, None, 'Specify the root directory of the Matlab installation'))
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/help.py", line 107, in addArgument
    self.argDB.setType(self.getArgName(name), argType, forceLocal = 1)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/RDict.py", line 213, in setType
    value.setValue(v.getValue())
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/nargs.py", line 324, in setValue
    raise ValueError('Nonexistent directory: '+str(value)+' for key '+str(self.key))
------------------ Original ------------------
Date:  Oct 26, 2018
To:  "avatar"<648934229 at qq.com>;
Cc:  "petsc-users"<petsc-users at mcs.anl.gov>;
Subject:  Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
On Fri, 26 Oct 2018, avatar wrote:
> Is there other way to overcome this problem? Because if I don't set TMPDIR as \tmp. My other project will break. And actually I don't even know where my project set up the TMPDIR value.
I guess you need to read up on some basic unix and system admin.
You probably meant to use:
export TMPDIR=/tmp
However  - you have:
export TMPDIR=tmp
To overcome this problem - you do:
export TMPDIR=/tmp
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181026/ccd6791d/attachment-0001.html>
