[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
Balay, Satish
balay at mcs.anl.gov
Thu Oct 25 19:25:53 CDT 2018
you need
--with-matlab-dir=/Users/zhihui/Applications/MATLAB_R2018a.app
Satish
On Fri, 26 Oct 2018, avatar wrote:
> Thank Satish. It worked as you said. But when I rebuild petsc using
> ./configure --with-matlab
> It prompts
> Configuring PETSc to compile on your system
> TESTING: configureLibrary from config.packages.Matlab(config/BuildSystem/config/packages/Matlab.py:35) *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Could not find a functional Matlab
> Run with --with-matlab-dir=Matlabrootdir if you know where it is
> Then, I did the following. But it shows that "/Users/zhihui/Applications/MATLAB_R2018a.app/bin/matlab" nonexistent. However, it does exist as
> Scott-Grad-MBP:bin zhihui$ pwd
> Scott-Grad-MBP:bin zhihui$ ls
> activate_matlab.sh lcdata_utf8.xml matlab-glselector.sh mexsh
> deactivate_matlab.sh ldd matopts.sh optsetup.sh
> engopts.sh m3iregistry mex registry
> lcdata.xml maci64 mexext util
> lcdata.xsd matlab mexopts.sh
> Do you know what it is going on here?
> Scott-Grad-MBP:petsc-3.8.3 zhihui$ ./configure --with-matlab-dir=./../../../../Applications/MATLAB_R2018a/bin/matlab
> ERROR in COMMAND LINE ARGUMENT to ./configure
> Nonexistent directory: /Users/zhihui/Applications/MATLAB_R2018a/bin/matlab for key with-matlab-dir
> File "./config/configure.py", line 390, in petsc_configure
> framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:], loadArgDB = 0)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 110, in __init__
> self.createChildren()
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 321, in createChildren
> self.getChild(moduleName)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 306, in getChild
> config.setupDependencies(self)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/Configure.py", line 107, in setupDependencies
> obj = self.registerPythonFile(package,'config.packages')
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/Configure.py", line 63, in registerPythonFile
> utilityObj = self.framework.require(directory+utilityName, self)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 326, in require
> config = self.getChild(moduleName, keywordArgs)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 304, in getChild
> config.setup()
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/script.py", line 101, in setup
> logger.Logger.setup(self)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/logger.py", line 85, in setup
> args.ArgumentProcessor.setup(self)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/args.py", line 75, in setup
> self.setupArguments(self.argDB)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/script.py", line 85, in setupArguments
> self.setupHelp(self.help)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/packages/Matlab.py", line 15, in setupHelp
> help.addArgument('MATLAB', '-with-matlab-dir=<root dir>', nargs.ArgDir(None, None, 'Specify the root directory of the Matlab installation'))
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/help.py", line 107, in addArgument
> self.argDB.setType(self.getArgName(name), argType, forceLocal = 1)
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/RDict.py", line 213, in setType
> value.setValue(v.getValue())
> File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/nargs.py", line 324, in setValue
> raise ValueError('Nonexistent directory: '+str(value)+' for key '+str(self.key))
> ------------------ Original ------------------
> From: "Balay, Satish";<balay at mcs.anl.gov>;
> Date: Oct 26, 2018
> To: "avatar"<648934229 at qq.com>;
> Cc: "petsc-users"<petsc-users at mcs.anl.gov>;
> Subject: Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
> > Is there other way to overcome this problem? Because if I don't set TMPDIR as \tmp. My other project will break. And actually I don't even know where my project set up the TMPDIR value.
> I guess you need to read up on some basic unix and system admin.
> You probably meant to use:
> export TMPDIR=/tmp
> However - you have:
> export TMPDIR=tmp
> To overcome this problem - you do:
> export TMPDIR=/tmp
> Satish
