[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
Balay, Satish balay at mcs.anl.gov
Thu Oct 25 19:05:03 CDT 2018
On Fri, 26 Oct 2018, avatar wrote:
> Is there other way to overcome this problem? Because if I don't set TMPDIR as \tmp. My other project will break. And actually I don't even know where my project set up the TMPDIR value.
I guess you need to read up on some basic unix and system admin.
You probably meant to use:
export TMPDIR=/tmp
However  - you have:
export TMPDIR=tmp
To overcome this problem - you do:
export TMPDIR=/tmp
Satish
