[petsc-users] Failure of MUMPS
Michael Wick michael.wick.1980 at gmail.com
Thu Oct 11 14:26:35 CDT 2018
Thanks for all the suggestions!
Increasing the value of icntl_14 in MUMPS helps a lot for my case.
Do you have any suggestions for higher-order methods in saddle-point
problems?
Mike
Dave May <dave.mayhem23 at gmail.com> 于2018年10月11日周四 上午1:50写道:
> On Sat, 6 Oct 2018 at 12:42, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Oct 5, 2018 at 9:08 PM Mike Wick <michael.wick.1980 at gmail.com>
>> wrote:
>>> Hello PETSc team:
>>> I am trying to solve a PDE problem with high-order finite elements. The
>>> matrix is getting denser and my experience is that MUMPS just outperforms
>>> iterative solvers.
>> If the problem is elliptic, there is a lot of evidence that the P1
>> preconditioner is descent for the system. Some people
>> just project the system to P1, invert that with multigrid, and use that
>> as the PC for Krylov. It should be worth trying.
> Matt means project to P1 directly from your high order function space in
> one step. It is definitely worth trying.
> For those interested, this approach is first described and discussed (to
> my knowledge) in this paper:
> Persson, Per-Olof, and Jaime Peraire. "An efficient low memory implicit DG
> algorithm for time dependent problems." *44th AIAA Aerospace Sciences
> Meeting and Exhibit*. 2006.
>> Moreover, as Jed will tell you, forming matrices for higher order is
>> counterproductive. You should apply those matrix-free.
> I definitely agree with that.
> Cheers,
>   Dave
>>   Thanks,
>>      Matt
>>> For certain problems, MUMPS just fail in the middle for no clear reason.
>>> I just wander if there is any suggestion to improve the robustness of
>>> MUMPS? Or in general, any suggestion for interative solver with very
>>> high-order finite elements?
>>> Thanks!
>>> Mike
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181011/aca6cbcb/attachment-0001.html>
