[petsc-users] Failure of MUMPS
Thu Oct 11 16:16:45 CDT 2018
On Thu, Oct 11, 2018 at 3:26 PM Michael Wick <michael.wick.1980 at gmail.com>
wrote:
> Thanks for all the suggestions!
> Increasing the value of icntl_14 in MUMPS helps a lot for my case.
> Do you have any suggestions for higher-order methods in saddle-point
> problems?
It depends on what the Schur complement looks like.
   Matt
> Mike
> Dave May <dave.mayhem23 at gmail.com> 于2018年10月11日周四 上午1:50写道:
>> On Sat, 6 Oct 2018 at 12:42, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Oct 5, 2018 at 9:08 PM Mike Wick <michael.wick.1980 at gmail.com>
>>> wrote:
>>>> Hello PETSc team:
>>>> I am trying to solve a PDE problem with high-order finite elements. The
>>>> matrix is getting denser and my experience is that MUMPS just outperforms
>>>> iterative solvers.
>>> If the problem is elliptic, there is a lot of evidence that the P1
>>> preconditioner is descent for the system. Some people
>>> just project the system to P1, invert that with multigrid, and use that
>>> as the PC for Krylov. It should be worth trying.
>> Matt means project to P1 directly from your high order function space in
>> one step. It is definitely worth trying.
>> For those interested, this approach is first described and discussed (to
>> my knowledge) in this paper:
>> Persson, Per-Olof, and Jaime Peraire. "An efficient low memory implicit
>> DG algorithm for time dependent problems." *44th AIAA Aerospace Sciences
>> Meeting and Exhibit*. 2006.
>>> Moreover, as Jed will tell you, forming matrices for higher order is
>>> counterproductive. You should apply those matrix-free.
>> I definitely agree with that.
>> Cheers,
>>   Dave
>>>   Thanks,
>>>      Matt
>>>> For certain problems, MUMPS just fail in the middle for no clear
>>>> reason. I just wander if there is any suggestion to improve the robustness
>>>> of MUMPS? Or in general, any suggestion for interative solver with very
>>>> high-order finite elements?
>>>> Thanks!
>>>> Mike
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181011/3dbde352/attachment.html>
