[petsc-users] IS Invert Not Permutation
Matthew Knepley
knepley at gmail.com
Thu Nov 29 06:35:16 CST 2018
On Thu, Nov 29, 2018 at 3:12 AM Florian Lindner <mailinglists at xgm.de> wrote:
> Am 28.11.18 um 18:12 schrieb Matthew Knepley:
> > On Wed, Nov 28, 2018 at 12:06 PM Florian Lindner <mailinglists at xgm.de
> <mailto:mailinglists at xgm.de>> wrote:
> > Hey,
> > thanks for your quick reply!
> > As far as I understand how MatSetLocalToGlobalMapping works, there
> is no way to create such a mapping that can be used for MatSetValuesLocal?
> > What I need is basically
> > MatSetValuesLocal row/col argument = 3 / 4 / 6 maps to local row/col
> 0 / 1 / 2
> > You are inverting the meaning of MatSetValuesLocal(). It takes in local
> indices (0, 1, 2) and sets the
> > values into a global matrix using global indices (3, 4, 6) which it gets
> from a compact table.
> > It you have global indices (3, 4, 6) use MatSetValues() directly.
> > Why are you trying to convert global indices to local indices, which
> requires a search.
> Hey,
> we are building a matrix for RBF interpolation. Given two sets of
> vertices, this requires to evaluate a function on every pair of vertices.
> The mesh is decomposed. The vertices have a globally unique, but not
> necessarily continous globalIndex.
> A rank 1 has the local portion of the mesh with the globalIndizes = {3, 4,
> 6}.
> | (1,1) (1,2) | (1,3) (1,4) (1,6) (1,7) (1,8) (off rank row)
> | (2,1) (2,2) | (2,3) (2,4) (2,6) (2,7) (3,8) (off rank row)
> (3,1) (3,2) | (3,3) (3,4) (3,6) | (3,7) (3,8)
> (4,1) (4,2) | (4,3) (4,4) (4,6) | (4,7) (4,8)
> (6,1) (6,2) | (6,3) (6,4) (6,6) | (6,7) (6,8)
> (more off rank rows)
> (marked processor boundaries with | and --)
> Going through local vertices, I could just count and use MatSetValuesLocal
> without a mapping and set the rows as {0, 1, 2}.
> But for the cols I need a global enumeration. Just counting is not an
> option. While the locally owned vertices are disjoint on each rank, each
> rank has some additional (halo like) vertices vertices. It does not own
> these (it doesn't build rows for them) but uses them building rows for its
> own vertices). The size of these halos depend on the basis function used. I
> can't use globalIndex directly, as it may contain holes and so on.
> For that I go through all local vertices and collect their globalIndex in
> an std::vector. My original implementation was to create an IS from the
> globalIndizes, ISInvertPermutation, ISAllGather and
> ISLocalToGlobalMappingCreateIS.
> My problem is, that InvertPermutation does not allow the IS to have holes
> in it.
> Following your advice, I use an AO instead and translate the rowIdx (that
> maybe I can omit) and the colIdx using AOApplicationToPetsc before calling
> MatSetValues, see below.
> Any thoughts on that matter are deeply appreciated!
Renumber the vertices to be contiguous. This is what we do when
repartitioning meshes.
Matt
> Best,
> Florian
> For that, my original implementation was to go ro
> > Thanks,
> > Matt
> > I seems to me, that if I set an index set with
> MatSetLocalToGlobalMapping like {3, 4, 6} it does the opposite. i.e. maps
> local {0, 1, 2] to global {3, 4, 6}
> > Therefore I probably need to create my own translation of {3, 4, 6}
> to {0, 1, 2}
> > A first sketch looks like that
> > mapping[rank] = {3, 4, 6}
> > for (auto i : mapping[rank]) {
> > for (auto j : mapping[rank]) {
> > cout << "Setting " << i << ", " << j << endl;
> > PetscScalar v[] = {i*10.0 + j};
> > PetscInt rows[] = {i};
> > PetscInt cols[] = {j};
> > AOApplicationToPetsc(ao, 1, rows);
> > AOApplicationToPetsc(ao, 1, cols);
> > cout << "Really setting " << rows[0] << ", " << cols[0] <<
> endl << endl;
> > ierr = MatSetValues(matrix, 1, rows, 1, cols, v,
> INSERT_VALUES); CHKERRQ(ierr);
> > which seems to work so far.
> > Any comments from your side are appreciated!
> > Of course, I should set as much values as possible using
> MatSetValues...
> > Best,
> > Florian
> > Am 27.11.18 um 16:33 schrieb Matthew Knepley:
> > > On Tue, Nov 27, 2018 at 10:17 AM Florian Lindner via petsc-users <
> petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <mailto:
> petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>> wrote:
> > > Hello,
> > > I have a range of local input data indices that I want to use
> for row indexing, say { 3, 4, 6}.
> > > For that, I create a matrix with a local number of rows of 3
> and map the indices {3, 4, 5} to these rows.
> > > It seems like you are trying to create a mapping and its inverse.
> We do that in
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/AOCreateMapping.html
> > > Note that this is not really scalable. Usually there is a way to
> restructure the code to avoid this.
> > > Thanks,
> > > Matt
> > > I create an index set:
> > > ISCreateGeneral(comm, myIndizes.size(), myIndizes.data(),
> PETSC_COPY_VALUES, &ISlocal);
> > > ISSetPermutation(ISlocal);
> > > ISInvertPermutation(ISlocal, myIndizes.size(), &ISlocalInv);
> > > ISAllGather(ISlocalInv, &ISglobal); // Gather the IS from all
> processors
> > > ISLocalToGlobalMappingCreateIS(ISglobal, &ISmapping); // Make
> it a mapping
> > > MatSetLocalToGlobalMapping(matrix, ISmapping, ISmapping); //
> Set mapping for rows and cols
> > > The InvertPermutation is required because, well, it seems that
> the direction the mapping stuff works in PETSc.
> > > Now I can use MatSetValues local to set rows {3, 4, 5} and
> actually set the local rows {1, 2, 3}.
> > > The problem is that the range of data vertices is not always
> contiguous, i.e. could be {3, 4, 6}. This seems to be not a permutation of
> PETSc, therefore ISSetPermutation fails and subsequently
> ISInvertPermutation.
> > > How can I still create such a mapping, so that:
> > > 3 -> 1
> > > 4 -> 2
> > > 6 -> 6
> > > row 5 is unassigned and will never be addressed.
> > > Thanks!
> > > Florian
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/17e13711/attachment-0001.html>
