[petsc-users] Fortran interface of some petsc routines seem to be missing
Natacha BEREUX
natacha.bereux at gmail.com
Tue Nov 27 09:28:31 CST 2018
Hello,
I work on a Fortran software that uses PETSc for linear solvers. Therefore,
we have a PETSc interface to convert our matrices to PETSc Mat.
I have noticed several compiler warnings ( I use gfortran with
-Wimplicit-interface) during compilation. The warnings point out that some
(but not all) fortran interfaces are missing.
The behaviour is the same when I compile a PETSC example. Below is
src/vec/vec/examples/tutorials/ex9f.F compiled with gfortran.
mpif90 -c -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument
-Wimplicit-interface -g -O
-I/home/H03755/Librairies/petsc-3.10.1/include
-I/home/H03755/Librairies/petsc-3.10.1/linux-opt-mumps-ml-hypre-superlu/include
-I/home/H03755/dev/codeaster-prerequisites/v14/prerequisites/Mumps-512_consortium_aster3/MPI/include
-I/home/H03755/local/petsc/petsc-3.10.1/include -o ex9f.o ex9f.F90
ex9f.F90:34.53:
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
1
Warning: Procedure 'petscinitialize' called with an implicit interface at
(1)
ex9f.F90:42.91:
if (size .ne. 2) then; call PetscError(PETSC_COMM_WORLD,1,0,'Requires
2 processors'); call MPIU_Abort(PETSC_COMM_WORLD,1); endif
1
Warning: Procedure 'petscerror' called with an implicit interface at (1)
ex9f.F90:42.128:
1
Warning: Procedure 'mpiu_abort' called with an implicit interface at (1)
ex9f.F90:81.56:
& PETSC_DECIDE,nghost,ifrom,tarray,gxs,ierr)
1
Warning: Procedure 'veccreateghostwitharray' called with an implicit
interface at (1)
ex9f.F90:99.53:
call VecGetOwnershipRange(gx,rstart,rend,ierr)
1
Warning: Procedure 'vecgetownershiprange' called with an implicit interface
at (1)
ex9f.F90:115.93:
call
PetscViewerGetSubViewer(PETSC_VIEWER_STDOUT_WORLD,PETSC_COMM_SELF,subviewer,ierr)
1
Warning: Procedure 'petscviewergetsubviewer' called with an implicit
interface at (1)
ex9f.F90:117.97:
call
PetscViewerRestoreSubViewer(PETSC_VIEWER_STDOUT_WORLD,PETSC_COMM_SELF,subviewer,ierr)
1
Warning: Procedure 'petscviewerrestoresubviewer' called with an implicit
interface at (1)
ex9f.F90:121.31:
call PetscFinalize(ierr)
1
Warning: Procedure 'petscfinalize' called with an implicit interface at (1)
Why does the compiler complain ?
Did I miss something when I compiled PETSc library ? Is there a way to
properly generate all the Fortran interfaces in the compiled library ?
Or is it normal that PETSc only generates some interfaces but not all ?
In this case, is there a way to know which interfaces are explicitly and
automatically defined in PETSc library ? So that I can provide manually
the missing ones in my code ?
Thanks a lot for your help !
Best regards,
Natacha
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181127/b64ac046/attachment-0001.html>
