[petsc-users] Compile petsc using intel mpi
Edoardo alinovi
edoardo.alinovi at gmail.com
Thu Nov 29 03:12:09 CST 2018
Hello guys,
thank you very much for you suggestions and sorry for getting back you
late. Unfortunately, actually my attempts to compile with intel are not
successful.
Here my command:
sudo ./configure --prefix=/home/edo/software/petsc-3.10.2
PETSC_ARCH=arch-intel-opt --with-cc=mpiicc --with-cxx=mpiiccp
--with-fc=mpiifort FOPTFLAGS='-O3' COPTFLAGS='-O3' CXXOPTFLAGS='-O3'
--with-blas-lapack-dir=/home/edo/intel/mkl/lib/intel64/ --with-debugging=no
--download-fblaslapack=1 --download-superlu_dist --download-mumps
--download-hypre --download-metis --download-parmetis
The log file states that:
------------------ LOG ------------------
TEST checkCCompiler from
config.setCompilers(/home/edo/software/petsc_intel/config/BuildSystem/config/setCompilers.py:587)
TESTING: checkCCompiler from
config.setCompilers(config/BuildSystem/config/setCompilers.py:587)
Locate a functional C compiler
Checking for program /usr/sbin/mpiicc...not found
Checking for program /usr/bin/mpiicc...not found
Checking for program /sbin/mpiicc...not found
Checking for program /bin/mpiicc...not found
/home/edo/software/petsc_intel/lib/petsc/bin/win32fe/mpiicc...not found
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
C compiler you provided with -with-cc=mpiicc does not work.
It seems that petsc is not able to find mpiicc. However, the path to intel
is well defined in my .bashrc and I can easily compile a test file with
those compiler.
if I put the full path in --with-cc= ... then I get:
/home/edo/intel/compilers_and_libraries_2019/linux/mpi/intel64/bin/mpiicc...found
Defined make macro "CC" to
"/home/edo/intel/compilers_and_libraries_2019/linux/mpi/intel64/bin/mpiicc"
Pushing language C
All intermediate test results are stored in
/tmp/petsc-ZLGfap
/tmp/petsc-ZLGfap/config.setCompilers
Executing:
-c -o /tmp/petsc-ZLGfap/config.setCompilers/conftest.o
-I/tmp/petsc-ZLGfap/config.setCompilers
/tmp/petsc-ZLGfap/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 32512
stderr:
/home/edo/intel/compilers_and_libraries_2019/linux/mpi/intel64/bin/mpiicc:
line 557: icc: command not found
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Popping language C
Error testing C compiler: Cannot compile C with
Deleting "CC"
Do you see any error in my setup?
Thank you very much!
Edoardo Alinovi, Ph.D.
DICCA, Scuola Politecnica,
Universita' degli Studi di Genova,
1, via Montallegro,
16145 Genova, Italy
Il giorno mar 27 nov 2018 alle ore 17:16 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Tue, Nov 27, 2018 at 6:25 AM Edoardo alinovi via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear users,
>> I have installed intel parallel studio on my workstation and thus I
>> would like to take advantage of intel compiler.
>> Before messing up my installation, have you got some guidelines to
>> survive at this attempt? I have found here in the mailing list the
>> following instructions:
>> --with-cc=icc --with-fc=ifort --with-mpi-include=/path-to-intel
>> --with-mpi-lib=/path-to-intel
> Yes, this looks right.
>> Are they correct?
>> Also I have an already existing and clean installation of petsc using
>> openmpi. I would like to retain this installtion since it is working very
>> well and switching between the two somehow. Any tips on this?
> When you do the Intel configuration, use a different name like
> --PETSC_ARCH=arch-intelps-opt
> Thanks,
> Matt
>> I will never stop to say thank you for your precious support!
>> Edoardo
>> 1, via Montallegro,
>> 16145 Genova, Italy
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/542f174e/attachment.html>
