[petsc-users] Compile petsc using intel mpi
Tue Nov 27 10:16:09 CST 2018
On Tue, Nov 27, 2018 at 6:25 AM Edoardo alinovi via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear users,
> I have installed intel parallel studio on my workstation and  thus I would
> like to take advantage of intel compiler.
> Before messing up my installation, have you got some guidelines to survive
> at this attempt? I have found here in the mailing list the following
> instructions:
> --with-cc=icc --with-fc=ifort --with-mpi-include=/path-to-intel
> --with-mpi-lib=/path-to-intel
Yes, this looks right.
> Are they correct?
> Also I have an already existing and clean installation of petsc using
> openmpi. I would like to retain this installtion since it is working very
> well and switching between the two  somehow. Any tips on this?
When you do the Intel configuration, use a different name like
--PETSC_ARCH=arch-intelps-opt
    Matt
> I will never stop to say thank you for your precious support!
> Edoardo
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica,
> Universita' degli Studi di Genova,
> 1, via Montallegro,
> 16145 Genova, Italy
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181127/720b35da/attachment.html>
