[petsc-users] Solving complex linear sparse matrix in parallel + external library
Wed Nov 28 09:59:07 CST 2018
On Wed, Nov 28, 2018 at 10:26 AM Sal Am <tempohoper at gmail.com> wrote:
> Thank you indeed --download-mpich and using PETSC_ARCH/bin/mpiexec seems
> to work.
> Now I am wondering about the other problem namely getting the residual, is
> the residual only computed when using iterative solvers? Cause using
> richardson or gmres with 1 iteration while using MUMPS prints me nothing.
We had an optimization which did not print the residual with richardson,
since it is used often inside of other solvers where
you do not want this. Are you sure that the residual does not print with
GMRES?
    Matt
> On Tue, Nov 27, 2018 at 10:53 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Nov 27, 2018 at 4:29 AM Sal Am <tempohoper at gmail.com> wrote:
>>> This can happen if you use an 'mpiexec' which is from a different MPI
>>>> than the one you compiled PETSc with.
>>> that is odd, I tried removing the --download-mpich from the config and
>>> tried --with-mpi=1 (which should be default anyways) and retried it with
>>> --with-mpich=1.
>> Your MPI is still broken. Some default MPIs, like those installed with
>> Apple, are broken. If you are on Apple
>> I would recommend using --download-mpich, but make sure you use
>> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec.
>> If you reconfigure, you either have to specify a different --PETSC_ARCH,
>> or delete the $PETSC_DIR/$PETSC_ARCH completely. Otherwise, you can get bad
>> interaction with the libraries already sitting there.
>>   Thanks,
>>     Matt
>>> Current reconfig file:
>>>     '--download-mpich',
>>>     '--download-mumps',
>>>     '--download-scalapack',
>>>     '--download-superlu_dist',
>>>     '--with-cc=gcc',
>>>     '--with-clanguage=cxx',
>>>     '--with-cxx=g++',
>>>     '--with-debugging=no',
>>>     '--with-fc=gfortran',
>>>     '--with-mpi=1',
>>>     '--with-mpich=1',
>>>     '--with-scalar-type=complex',
>>>     'PETSC_ARCH=linux-opt'
>>> Still does not work though, I tried executing ex11 in
>>> ksp/ksp/example/tutorial/ex11 which should solve a linear system in
>>> parallel by running mpiexec -n 2 but it prints out
>>> Mat Object: 1 MPI processes
>>> twice.
>>> What am I missing?
>>> Why would you want a minimum iterations? Why not set a tolerance and a
>>>> max? What would you achieve with a minimum?
>>> I thought PETSc might not be iterating far enough, but after having had
>>> a look at KSPSetTolerances it makes more sense.
>>> Instead of 'preonly', where you do not want a residual, use 'richardson'
>>>> or 'gmres' with a max of 1 iterate (-ksp_max_it 1)
>>> So I tried that by executing: mpiexec -n 4 ./test -ksp_type richardson
>>> -pc_type lu -pc_factor_mat_solver_type mumps -ksp_max_it 1
>>> on the command line. However, nothing prints out on the terminal (aside
>>> from PetscPrintf if I have them enabled).
>>> Thank you.
>>> On Fri, Nov 16, 2018 at 12:00 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Nov 16, 2018 at 4:23 AM Sal Am via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>>> Hi,
>>>>> I have a few questions:
>>>>> 1. The following issue/misunderstanding:
>>>>> My code reads in two files one PETSc vector and one PETSc matrix (b
>>>>> and A from Ax=b, size ~65000x65000).
>>>>> and then calls KSP solver to solve it by running the following in the
>>>>> terminal:
>>>>> mpiexec - n 2 ./SolveSys -ksp_type preonly -pc_type lu
>>>>> -pc_factor_mat_solver mumps
>>>>> Now mumps is supposed to work in parallel and complex, but the code is
>>>>> not solved in parallel it seems. It just prints the result twice. Adding
>>>>> -log_view gives me
>>>>> "./SolveSys on a linux-opt named F8434 with 1 processor..." printed
>>>>> twice.
>>>>> 2. Using iterative solvers, I am having difficulty getting
>>>>> convergence. I found that there is a way to set the maximum number of
>>>>> iterations, but is there a minimum I can increase?
>>>>> 3. The residual is not computed when using direct external solvers.
>>>>> What is proper PETSc way of doing this?
>>>> 'richardson' or 'gmres' with a max of 1 iterate (-ksp_max_it 1)
>>>>   Thanks,
>>>>      Matt
>>>>> -----------------------------------------------------The
>>>>> code---------------------------------------
>>>>> #include <petscksp.h>
>>>>> #include <iostream>
>>>>> int main(int argc,char **args)
>>>>>   Vec            x,b;      /* approx solution, RHS */
>>>>>   Mat            A;            /* linear system matrix */
>>>>>   KSP            ksp;         /* linear solver context */
>>>>>   PetscReal      norm;         /* norm of solution error */
>>>>>   PC             pc;
>>>>>   PetscMPIInt    rank, size;
>>>>>   PetscViewer    viewer;
>>>>>   PetscInt       its, i;
>>>>>   PetscErrorCode ierr;
>>>>>   PetscScalar    *xa;
>>>>>   PetscBool      flg = PETSC_FALSE;
>>>>>   ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return
>>>>> ierr;
>>>>>   MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>>>>   MPI_Comm_size(PETSC_COMM_WORLD,&size);
>>>>>   #if !defined(PETSC_USE_COMPLEX)
>>>>>     SETERRQ(PETSC_COMM_WORLD,1,"This example requires complex
>>>>> numbers");
>>>>>   #endif
>>>>>          Compute the matrix and right-hand-side vector that define
>>>>>          the linear system, Ax = b.
>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD,"reading vector in binary from
>>>>> Vector_b.dat ...\n");CHKERRQ(ierr);
>>>>>   ierr =
>>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Vector_b.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>>>>   ierr = VecCreate(PETSC_COMM_WORLD, &b);CHKERRQ(ierr);
>>>>>   ierr = VecLoad(b,viewer); CHKERRQ(ierr);
>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD,"reading matrix in binary from
>>>>> Matrix_A.dat ...\n");CHKERRQ(ierr);
>>>>>   ierr =
>>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Matrix_A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>>>>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>>>>   ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>>>>>   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>>>>>   ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>>>>>                 Create the linear solver and set various options
>>>>>   PetscPrintf(PETSC_COMM_WORLD, "Creating KSP\n");
>>>>>   ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>   PetscPrintf(PETSC_COMM_WORLD, "KSP Operators\n");
>>>>>   ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>>>>   ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
>>>>>   ierr = PCSetType(pc, PCLU);CHKERRQ(ierr);
>>>>>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>                       Solve the linear system
>>>>>   ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>>>>>   ierr = KSPSetUpOnBlocks(ksp);CHKERRQ(ierr);
>>>>>   ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>>>>   PetscPrintf(PETSC_COMM_WORLD, "Solved");
>>>>>      Free work space.  All PETSc objects should be destroyed when they
>>>>>      are no longer needed.
>>>>>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>>>>>   ierr = VecDestroy(&x);CHKERRQ(ierr);
>>>>>   ierr = VecDestroy(&b);CHKERRQ(ierr);
>>>>>   ierr = MatDestroy(&A);CHKERRQ(ierr);
>>>>>   ierr = PetscFinalize();
>>>>>   return ierr;
>>>>> Kind regards,
>>>>> Sal
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181128/7ead0cf5/attachment.html>
