[petsc-users] Solving complex linear sparse matrix in parallel + external library
Mark Adams mfadams at lbl.gov
Wed Nov 28 09:34:32 CST 2018
On Wed, Nov 28, 2018 at 10:27 AM Sal Am via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Thank you indeed --download-mpich and using PETSC_ARCH/bin/mpiexec seems
> to work.
> Now I am wondering about the other problem namely getting the residual, is
> the residual only computed when using iterative solvers? Cause using
> richardson or gmres with 1 iteration while using MUMPS prints me nothing.
This should work. Please send us all the output and your arguments, etc.
You can also add -ksp_view to print info about the solver configuration.
> On Tue, Nov 27, 2018 at 10:53 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Nov 27, 2018 at 4:29 AM Sal Am <tempohoper at gmail.com> wrote:
>>> This can happen if you use an 'mpiexec' which is from a different MPI
>>>> than the one you compiled PETSc with.
>>> that is odd, I tried removing the --download-mpich from the config and
>>> tried --with-mpi=1 (which should be default anyways) and retried it with
>>> --with-mpich=1.
>> Your MPI is still broken. Some default MPIs, like those installed with
>> Apple, are broken. If you are on Apple
>> I would recommend using --download-mpich, but make sure you use
>> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec.
>> If you reconfigure, you either have to specify a different --PETSC_ARCH,
>> or delete the $PETSC_DIR/$PETSC_ARCH completely. Otherwise, you can get bad
>> interaction with the libraries already sitting there.
>>   Thanks,
>>     Matt
>>> Current reconfig file:
>>>     '--download-mpich',
>>>     '--download-mumps',
>>>     '--download-scalapack',
>>>     '--download-superlu_dist',
>>>     '--with-cc=gcc',
>>>     '--with-clanguage=cxx',
>>>     '--with-cxx=g++',
>>>     '--with-debugging=no',
>>>     '--with-fc=gfortran',
>>>     '--with-mpi=1',
>>>     '--with-mpich=1',
>>>     '--with-scalar-type=complex',
>>>     'PETSC_ARCH=linux-opt'
>>> Still does not work though, I tried executing ex11 in
>>> ksp/ksp/example/tutorial/ex11 which should solve a linear system in
>>> parallel by running mpiexec -n 2 but it prints out
>>> Mat Object: 1 MPI processes
>>> twice.
>>> What am I missing?
>>> Why would you want a minimum iterations? Why not set a tolerance and a
>>>> max? What would you achieve with a minimum?
>>> I thought PETSc might not be iterating far enough, but after having had
>>> a look at KSPSetTolerances it makes more sense.
>>> Instead of 'preonly', where you do not want a residual, use 'richardson'
>>>> or 'gmres' with a max of 1 iterate (-ksp_max_it 1)
>>> So I tried that by executing: mpiexec -n 4 ./test -ksp_type richardson
>>> -pc_type lu -pc_factor_mat_solver_type mumps -ksp_max_it 1
>>> on the command line. However, nothing prints out on the terminal (aside
>>> from PetscPrintf if I have them enabled).
>>> Thank you.
>>> On Fri, Nov 16, 2018 at 12:00 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Nov 16, 2018 at 4:23 AM Sal Am via petsc-users <
>>>>> Hi,
>>>>> I have a few questions:
>>>>> 1. The following issue/misunderstanding:
>>>>> My code reads in two files one PETSc vector and one PETSc matrix (b
>>>>> and A from Ax=b, size ~65000x65000).
>>>>> and then calls KSP solver to solve it by running the following in the
>>>>> terminal:
>>>>> mpiexec - n 2 ./SolveSys -ksp_type preonly -pc_type lu
>>>>> -pc_factor_mat_solver mumps
>>>>> Now mumps is supposed to work in parallel and complex, but the code is
>>>>> not solved in parallel it seems. It just prints the result twice. Adding
>>>>> -log_view gives me
>>>>> "./SolveSys on a linux-opt named F8434 with 1 processor..." printed
>>>>> twice.
>>>>> 2. Using iterative solvers, I am having difficulty getting
>>>>> convergence. I found that there is a way to set the maximum number of
>>>>> iterations, but is there a minimum I can increase?
>>>>> 3. The residual is not computed when using direct external solvers.
>>>>> What is proper PETSc way of doing this?
>>>> 'richardson' or 'gmres' with a max of 1 iterate (-ksp_max_it 1)
>>>>   Thanks,
>>>>      Matt
>>>>> -----------------------------------------------------The
>>>>> code---------------------------------------
>>>>> #include <petscksp.h>
>>>>> #include <iostream>
>>>>> int main(int argc,char **args)
>>>>>   Vec            x,b;      /* approx solution, RHS */
>>>>>   Mat            A;            /* linear system matrix */
>>>>>   KSP            ksp;         /* linear solver context */
>>>>>   PetscReal      norm;         /* norm of solution error */
>>>>>   PC             pc;
>>>>>   PetscMPIInt    rank, size;
>>>>>   PetscViewer    viewer;
>>>>>   PetscInt       its, i;
>>>>>   PetscErrorCode ierr;
>>>>>   PetscScalar    *xa;
>>>>>   PetscBool      flg = PETSC_FALSE;
>>>>>   ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return
>>>>> ierr;
>>>>>   MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>>>>   MPI_Comm_size(PETSC_COMM_WORLD,&size);
>>>>>   #if !defined(PETSC_USE_COMPLEX)
>>>>>     SETERRQ(PETSC_COMM_WORLD,1,"This example requires complex
>>>>> numbers");
>>>>>   #endif
>>>>>          Compute the matrix and right-hand-side vector that define
>>>>>          the linear system, Ax = b.
>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD,"reading vector in binary from
>>>>> Vector_b.dat ...\n");CHKERRQ(ierr);
>>>>>   ierr =
>>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Vector_b.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>>>>   ierr = VecCreate(PETSC_COMM_WORLD, &b);CHKERRQ(ierr);
>>>>>   ierr = VecLoad(b,viewer); CHKERRQ(ierr);
>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD,"reading matrix in binary from
>>>>> Matrix_A.dat ...\n");CHKERRQ(ierr);
>>>>>   ierr =
>>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Matrix_A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>>>>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>>>>   ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>>>>>   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>>>>>   ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>>>>>                 Create the linear solver and set various options
>>>>>   PetscPrintf(PETSC_COMM_WORLD, "Creating KSP\n");
>>>>>   ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>   PetscPrintf(PETSC_COMM_WORLD, "KSP Operators\n");
>>>>>   ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>>>>   ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
>>>>>   ierr = PCSetType(pc, PCLU);CHKERRQ(ierr);
>>>>>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>                       Solve the linear system
>>>>>   ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>>>>>   ierr = KSPSetUpOnBlocks(ksp);CHKERRQ(ierr);
>>>>>   ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>>>>   PetscPrintf(PETSC_COMM_WORLD, "Solved");
>>>>>      Free work space.  All PETSc objects should be destroyed when they
>>>>>      are no longer needed.
>>>>>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>>>>>   ierr = VecDestroy(&x);CHKERRQ(ierr);
>>>>>   ierr = VecDestroy(&b);CHKERRQ(ierr);
>>>>>   ierr = MatDestroy(&A);CHKERRQ(ierr);
>>>>>   ierr = PetscFinalize();
>>>>>   return ierr;
>>>>> Kind regards,
>>>>> Sal
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181128/c5159586/attachment-0001.html>
