[petsc-users] Solving complex linear sparse matrix in parallel + external library
Sal Am tempohoper at gmail.com
Thu Nov 29 09:45:35 CST 2018
It seems to be working now,
$ mpiexec -n 4 ./solveSystem -ksp_type gmres -pc_type lu
-pc_factor_mat_solver_type mumps -ksp_max_it 1 -ksp_monitor_true_residual
  0 KSP preconditioned resid norm 2.536556771280e+03 true resid norm
4.215007800243e+05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.020671994801e-11 true resid norm
5.239122706565e-08 ||r(i)||/||b|| 1.242968685909e-13
Thanks
On Wed, Nov 28, 2018 at 3:59 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 28, 2018 at 10:26 AM Sal Am <tempohoper at gmail.com> wrote:
>> Thank you indeed --download-mpich and using PETSC_ARCH/bin/mpiexec seems
>> to work.
>> Now I am wondering about the other problem namely getting the residual,
>> is the residual only computed when using iterative solvers? Cause using
>> richardson or gmres with 1 iteration while using MUMPS prints me nothing.
> We had an optimization which did not print the residual with richardson,
> since it is used often inside of other solvers where
> you do not want this. Are you sure that the residual does not print with
> GMRES?
>   Thanks,
>     Matt
>> On Tue, Nov 27, 2018 at 10:53 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Nov 27, 2018 at 4:29 AM Sal Am <tempohoper at gmail.com> wrote:
>>>> This can happen if you use an 'mpiexec' which is from a different MPI
>>>>> than the one you compiled PETSc with.
>>>> that is odd, I tried removing the --download-mpich from the config and
>>>> tried --with-mpi=1 (which should be default anyways) and retried it with
>>>> --with-mpich=1.
>>> Your MPI is still broken. Some default MPIs, like those installed with
>>> Apple, are broken. If you are on Apple
>>> I would recommend using --download-mpich, but make sure you use
>>> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec.
>>> If you reconfigure, you either have to specify a different --PETSC_ARCH,
>>> or delete the $PETSC_DIR/$PETSC_ARCH completely. Otherwise, you can get bad
>>> interaction with the libraries already sitting there.
>>>   Thanks,
>>>     Matt
>>>> Current reconfig file:
>>>>     '--download-mpich',
>>>>     '--download-mumps',
>>>>     '--download-scalapack',
>>>>     '--download-superlu_dist',
>>>>     '--with-cc=gcc',
>>>>     '--with-clanguage=cxx',
>>>>     '--with-cxx=g++',
>>>>     '--with-debugging=no',
>>>>     '--with-fc=gfortran',
>>>>     '--with-mpi=1',
>>>>     '--with-mpich=1',
>>>>     '--with-scalar-type=complex',
>>>>     'PETSC_ARCH=linux-opt'
>>>> Still does not work though, I tried executing ex11 in
>>>> ksp/ksp/example/tutorial/ex11 which should solve a linear system in
>>>> parallel by running mpiexec -n 2 but it prints out
>>>> Mat Object: 1 MPI processes
>>>> twice.
>>>> What am I missing?
>>>> Why would you want a minimum iterations? Why not set a tolerance and a
>>>>> max? What would you achieve with a minimum?
>>>> I thought PETSc might not be iterating far enough, but after having had
>>>> a look at KSPSetTolerances it makes more sense.
>>>> Instead of 'preonly', where you do not want a residual, use
>>>>> 'richardson' or 'gmres' with a max of 1 iterate (-ksp_max_it 1)
>>>> So I tried that by executing: mpiexec -n 4 ./test -ksp_type richardson
>>>> -pc_type lu -pc_factor_mat_solver_type mumps -ksp_max_it 1
>>>> on the command line. However, nothing prints out on the terminal (aside
>>>> from PetscPrintf if I have them enabled).
>>>> Thank you.
>>>> On Fri, Nov 16, 2018 at 12:00 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Nov 16, 2018 at 4:23 AM Sal Am via petsc-users <
>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> Hi,
>>>>>> I have a few questions:
>>>>>> 1. The following issue/misunderstanding:
>>>>>> My code reads in two files one PETSc vector and one PETSc matrix (b
>>>>>> and A from Ax=b, size ~65000x65000).
>>>>>> and then calls KSP solver to solve it by running the following in the
>>>>>> terminal:
>>>>>> mpiexec - n 2 ./SolveSys -ksp_type preonly -pc_type lu
>>>>>> -pc_factor_mat_solver mumps
>>>>>> Now mumps is supposed to work in parallel and complex, but the code
>>>>>> is not solved in parallel it seems. It just prints the result twice. Adding
>>>>>> -log_view gives me
>>>>>> "./SolveSys on a linux-opt named F8434 with 1 processor..." printed
>>>>>> twice.
>>>>>> 2. Using iterative solvers, I am having difficulty getting
>>>>>> convergence. I found that there is a way to set the maximum number of
>>>>>> iterations, but is there a minimum I can increase?
>>>>>> 3. The residual is not computed when using direct external solvers.
>>>>>> What is proper PETSc way of doing this?
>>>>>   Thanks,
>>>>>      Matt
>>>>>> -----------------------------------------------------The
>>>>>> code---------------------------------------
>>>>>> #include <petscksp.h>
>>>>>> #include <iostream>
>>>>>> int main(int argc,char **args)
>>>>>>   Vec            x,b;      /* approx solution, RHS */
>>>>>>   Mat            A;            /* linear system matrix */
>>>>>>   KSP            ksp;         /* linear solver context */
>>>>>>   PetscReal      norm;         /* norm of solution error */
>>>>>>   PC             pc;
>>>>>>   PetscMPIInt    rank, size;
>>>>>>   PetscViewer    viewer;
>>>>>>   PetscInt       its, i;
>>>>>>   PetscErrorCode ierr;
>>>>>>   PetscScalar    *xa;
>>>>>>   PetscBool      flg = PETSC_FALSE;
>>>>>>   ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return
>>>>>> ierr;
>>>>>>   MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>>>>>   MPI_Comm_size(PETSC_COMM_WORLD,&size);
>>>>>>   #if !defined(PETSC_USE_COMPLEX)
>>>>>>     SETERRQ(PETSC_COMM_WORLD,1,"This example requires complex
>>>>>> numbers");
>>>>>>   #endif
>>>>>>          Compute the matrix and right-hand-side vector that define
>>>>>>          the linear system, Ax = b.
>>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD,"reading vector in binary from
>>>>>> Vector_b.dat ...\n");CHKERRQ(ierr);
>>>>>>   ierr =
>>>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Vector_b.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>>>>>   ierr = VecCreate(PETSC_COMM_WORLD, &b);CHKERRQ(ierr);
>>>>>>   ierr = VecLoad(b,viewer); CHKERRQ(ierr);
>>>>>>   ierr = PetscPrintf(PETSC_COMM_WORLD,"reading matrix in binary from
>>>>>> Matrix_A.dat ...\n");CHKERRQ(ierr);
>>>>>>   ierr =
>>>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Matrix_A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>>>>>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>>>>>   ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>>>>>>   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>>>>>>   ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>>>>>>                 Create the linear solver and set various options
>>>>>>   PetscPrintf(PETSC_COMM_WORLD, "Creating KSP\n");
>>>>>>   ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>>   PetscPrintf(PETSC_COMM_WORLD, "KSP Operators\n");
>>>>>>   ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>>>>>   ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
>>>>>>   ierr = PCSetType(pc, PCLU);CHKERRQ(ierr);
>>>>>>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>>                       Solve the linear system
>>>>>>   ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>>>>>>   ierr = KSPSetUpOnBlocks(ksp);CHKERRQ(ierr);
>>>>>>   ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>>>>>   PetscPrintf(PETSC_COMM_WORLD, "Solved");
>>>>>>      Free work space.  All PETSc objects should be destroyed when they
>>>>>>      are no longer needed.
>>>>>>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>>>>>>   ierr = VecDestroy(&x);CHKERRQ(ierr);
>>>>>>   ierr = VecDestroy(&b);CHKERRQ(ierr);
>>>>>>   ierr = MatDestroy(&A);CHKERRQ(ierr);
>>>>>>   ierr = PetscFinalize();
>>>>>>   return ierr;
>>>>>> Kind regards,
>>>>>> Sal
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/769abcfc/attachment.html>
