[petsc-users] Problem to configure
Fazlul Huq
huq2090 at gmail.com
Tue Nov 20 16:44:36 CST 2018
Hello PETSc Developers,
I am trying to configure PETSc with ./configure --download-hypre
but I got the following message on terminal:
Configuring PETSc to compile on your system
TESTING: check from
config.libraries(config/BuildSystem/config/libraries.py:158)
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
Unable to find mpi in default locations!
Perhaps you can specify with --with-mpi-dir=<directory>
If you do not want MPI, then give --with-mpi=0
You might also consider using --download-mpich instead
The log file is attached herewith.
Thanks.
Sincerely,
Huq
Fazlul Huq
Graduate Research Assistant
Department of Nuclear, Plasma & Radiological Engineering (NPRE)
University of Illinois at Urbana-Champaign (UIUC)
E-mail: huq2090 at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181120/e039d642/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181120/e039d642/attachment-0001.bin>
