[petsc-users] Problem to configure
Balay, Satish
balay at mcs.anl.gov
Tue Nov 20 16:59:09 CST 2018
As the message suggests - you don't have MPI installed - so run:
./configure --download-hypre --download-mpich
Satish
On Tue, 20 Nov 2018, Fazlul Huq via petsc-users wrote:
> Hello PETSc Developers,
> I am trying to configure PETSc with ./configure --download-hypre
> but I got the following message on terminal:
> Configuring PETSc to compile on your system
> TESTING: check from
> config.libraries(config/BuildSystem/config/libraries.py:158)
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> Unable to find mpi in default locations!
> Perhaps you can specify with --with-mpi-dir=<directory>
> If you do not want MPI, then give --with-mpi=0
> You might also consider using --download-mpich instead
> The log file is attached herewith.
> Thanks.
> Sincerely,
> Huq
