[petsc-users] Expecting Explanation
Fazlul Huq huq2090 at gmail.com
Sat Nov 17 16:15:55 CST 2018
Thanks.
For some reason it's not showing on my machine.
I am using petsc-3.10.2
Sincerely,
Huq
On Sat, Nov 17, 2018 at 4:03 PM Sanjay Govindjee via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Throws the proper error on my machine:
> $ ~/petsc-3.10.1/intel/bin/mpirun -np 2 ex6
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: This is a uniprocessor example only!
>  On 11/17/18 1:51 PM, Fazlul Huq via petsc-users wrote:
> Thanks for the answer.
> So, when I run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4 ./ex6"
> shouldn't it spit out
> the error "This is a uniprocessor example only!"?
> But it didn't do that rather run the code 2/4 times.
> Thanks.
> Sincerely,
> Huq
> On Sat, Nov 17, 2018 at 1:12 PM Fazlul Huq <huq2090 at gmail.com> wrote:
>> Hello PETSc developers,
>> In example 6 or vec section I don't understand this line:
>> if (size != 1) SETERRQ(PETSC_COMM_SELF,1,"This is a uniprocessor example
>> only!");
>> I tried to run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4 ./ex6"
>> or even "mpiexec -n 1 ./ex6" it the code runs properly.
>> Thanks.
>> Sincerely,
>> Huq
>> Fazlul Huq
>> Graduate Research Assistant
>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>> University of Illinois at Urbana-Champaign (UIUC)
>> E-mail: huq2090 at gmail.com
> Fazlul Huq
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181117/131fc699/attachment-0001.html>
