[petsc-users] Expecting Explanation
Fazlul Huq
huq2090 at gmail.com
Sat Nov 17 16:18:52 CST 2018
Well.
I tried on other machine and it shows error message.
The fact is I understand the example.
Thanks again.
Sincerely,
Huq
On Sat, Nov 17, 2018 at 4:15 PM Fazlul Huq <huq2090 at gmail.com> wrote:
> Thanks.
> For some reason it's not showing on my machine.
> I am using petsc-3.10.2
> Sincerely,
> Huq
> On Sat, Nov 17, 2018 at 4:03 PM Sanjay Govindjee via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Throws the proper error on my machine:
>> $ ~/petsc-3.10.1/intel/bin/mpirun -np 2 ex6
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: This is a uniprocessor example only!
>> On 11/17/18 1:51 PM, Fazlul Huq via petsc-users wrote:
>> Thanks for the answer.
>> So, when I run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4 ./ex6"
>> shouldn't it spit out
>> the error "This is a uniprocessor example only!"?
>> But it didn't do that rather run the code 2/4 times.
>> Thanks.
>> Sincerely,
>> Huq
>> On Sat, Nov 17, 2018 at 1:12 PM Fazlul Huq <huq2090 at gmail.com> wrote:
>>> Hello PETSc developers,
>>> In example 6 or vec section I don't understand this line:
>>> if (size != 1) SETERRQ(PETSC_COMM_SELF,1,"This is a uniprocessor example
>>> only!");
>>> I tried to run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4
>>> ./ex6" or even "mpiexec -n 1 ./ex6" it the code runs properly.
>>> Thanks.
>>> Sincerely,
>>> Huq
>>> Fazlul Huq
>>> Graduate Research Assistant
>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>> University of Illinois at Urbana-Champaign (UIUC)
>>> E-mail: huq2090 at gmail.com
>> Fazlul Huq
> Fazlul Huq
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181117/7c57e186/attachment.html>
