[petsc-users] Expecting Explanation
Sanjay Govindjee
s_g at berkeley.edu
Sat Nov 17 16:01:55 CST 2018
Throws the proper error on my machine:
$ ~/petsc-3.10.1/intel/bin/mpirun -np 2 ex6
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: This is a uniprocessor example only!
On 11/17/18 1:51 PM, Fazlul Huq via petsc-users wrote:
> Thanks for the answer.
> So, when I run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4
> ./ex6" shouldn't it spit out
> the error "This is a uniprocessor example only!"?
> But it didn't do that rather run the code 2/4 times.
> Thanks.
> Sincerely,
> Huq
> On Sat, Nov 17, 2018 at 1:12 PM Fazlul Huq <huq2090 at gmail.com
> <mailto:huq2090 at gmail.com>> wrote:
> Hello PETSc developers,
> In example 6 or vec section I don't understand this line:
> if (size != 1) SETERRQ(PETSC_COMM_SELF,1,"This is a uniprocessor
> example only!");
> I tried to run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4
> ./ex6" or even "mpiexec -n 1 ./ex6" it the code runs properly.
> Thanks.
> Sincerely,
> Huq
> Fazlul Huq
> Graduate Research Assistant
> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> University of Illinois at Urbana-Champaign (UIUC)
> E-mail: huq2090 at gmail.com <mailto:huq2090 at gmail.com>
> Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181117/faa199d5/attachment.html>
